2011 4.2L A8 with intermittent parasitic drain
Car82
Edmonton, AB, Canada
C?ID=109559
I have been struggling with a intermittent parasitic drain. The vehicle goes dead after a few days of sitting. When I performed parasitic draw test, the car drops to 0.026 amps after about 1 - 2 minutes after the vehicle is locked, and holds that number after 15 minutes of being locked. But intermittently a few times, after 1-2 minutes it drops to 0.026amps, then after about 5 minutes the draw will jump up, and fluctuate between 0.246 amps to 0.283 amps. does anyone have any input based off the auto scanned? I have checked the basics. Battery is new within the past year and tests good. Did a visual inspection to insure everything stays off.
Monday,26,October,2020,18:10:55:51883
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: Continental auto
VIN: WAUCVAFD3BN001239   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 28 34 36 3B 3C
          42 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 84 85 88 89 8B 8E
          8F 90
VIN: WAUCVAFD3BN001239   Mileage: 226008km-140434miles
0E-Media Player 1 -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 94753 999 105110
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A18DB584D3582D66D-807E
10 Faults Found:
4592 - Knock Sensor 3 (G198)
          P1321 00 [096] - Signal too Small
4594 - Knock Sensor 3 (G198)
4596 - Knock Sensor 4 (G199)
          P1323 00 [096] - Signal too Small
4598 - Knock Sensor 4 (G199)
4629 - ECM Power Relay Load Circuit
          P068A 00 [104] - Opens Too Early
                    Engine speed: 0.00 /min
                    Coolant temperature: -40 °C
                    Intake air temperature: 2 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 12.816 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: full load
                    Engine operating condition-Test_Program_Channel 87: 7
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 225984 km
                    Date: 2020.10.25
                    Time: 00:00:35
                    Engine speed: 1085.50 /min
                    Normed load value: 41.2 %
                    Coolant temperature: -3 °C
                    Intake air temperature: -3 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 13.829 V
                    AFS dm: 59.3 kg/h
                    Median injection timing: 2.782 ms
                    Engine operating condition: Idling
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 225984 km
                    Date: 2020.10.25
                    Time: 00:01:37
                    Engine speed: 858.50 /min
                    Normed load value: 25.5 %
                    Coolant temperature: 4 °C
                    Intake air temperature: -2 °C
                    Voltage terminal 30: 14.135 V
                    AFS dm: 29.9 kg/h
                    Median injection timing: 1.488 ms
10597 - Cylinder 7
          P0307 00 [096] - Misfire Detected
                    Mileage: 225984 km
                    Date: 2020.10.25
                    Time: 00:01:37
                    AFS dm: 29.9 kg/h
11510 - Evap System Leak Detection or Fuel Vapor Temp Sensor
          P2025 00 [096] - Implausible Signal
4261 - System Voltage
          P0562 00 [096] - Too Low
                    Mileage: 226008 km
                    Date: 2020.10.26
                    Coolant temperature: 57 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 9.682 V
                    AFS dm: 0.0 kg/h
   Part No SW: 4H1 927 158 N    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   VCID: 3B36EE1CB2AF0B5E06-806E
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H09 0273
   Coding: 44F6B200226F4D00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 3228C33865E5CA16D5-8066
0462 - Supply voltage
          U1011 00 [136] - Voltage too Low
          [UzHardUndervoltage]
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:42:57
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 12
                    Bit Info 3: 80
                    Bit Info 4: 00
                    F-Path: 03
                    F-Type: 24
                    Uz: 63
0656 - Supply voltage
          [PowerSupplyPermanentLow]
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:32:12
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 17
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 3D
                    F-Type: 02
                    Uz: 62
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H21 0510
   Coding: 0D872000000000000000
   Shop #: WSC 47298 000 1048576
   VCID: 6E901748B95DAEF6F1-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 0210000020694013
                    Reset counter: 172
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:09:49
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 172
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:42:39
                    Fault Status: 00101101
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:41
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H07 0115
   Revision: AA000000    Serial number: 00001010176724
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 3522F8249C8BDD2EF0-8060
                    Reset counter: 170
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:25:01
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 4 Zonen H14 0045
   Coding: 488120B88C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2208337835055A9625-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [008] - Signal Amplitude Too High
                    Reset counter: 167
                    Mileage: 220887 km
                    Date: 2020.08.03
                    Time: 14:00:05
0141 - Motor for  Right Side Window Defrost Flap
          B10D8 29 [008] - Signal Implausible
                    Reset counter: 143
                    Mileage: 221150 km
                    Date: 2020.08.11
                    Time: 13:56:10
0235 - Supply voltage
                    Reset counter: 168
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:24
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
                    Reset counter: 83
                    Mileage: 193575 km
                    Date: 2018.07.04
                    Time: 09:14:52
0289 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:24
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
                    Reset counter: 168
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:24
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H11 0083
   Revision: 15011002    Serial number: 00000000570594
   Coding: 02002096163C9FF1DB008804A0003908009CD30882000121800008402000
   VCID: 291A2454403389CE64-807C
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 100610  H32 0040
   Serial number:         100612135207
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10003978
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 E    HW: 4H0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 27 04 2010  00000020
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R023C06
   Subsystem 5 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0275
   Serial number: WA100300000000073333
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 13284035000000000001
                    Reset counter: 170
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:16:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 00101100
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:42:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 A    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0120
   Revision: AA001001
   VCID: 1E700788097D7E7601-804A
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:39
                    Voltage: 7.60 V
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:42:58
                    Voltage: 7.50 V
                    Voltage: 12.70 V
   Part No SW: 4H0 919 475 F    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0020
   Revision: 11001001    Serial number: 55931009400076
   Coding: 300902
   ASAM Dataset: EV_AU57XParkiAssis2 002005
   ROD: EV_AU57XParkiAssis2.rod
   VCID: 3522F824948BDD2EF0-8060
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 170
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 170
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H21 0160
   Coding: 3601010201
   Shop #: WSC 23921 002 1048576
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 291A2454483389CE64-807C
10 Faults Found:
16384 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW]
                    Fault Frequency: 49
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:00:14
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 7.776 V
16640 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW1]
                    Fault Frequency: 74
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:00:14
17152 - Supply voltage
          [FAULT_VMON_VZ_CONFIRMED_LOW]
                    Reset counter: 174
                    Mileage: 214809 km
                    Date: 2020.01.22
                    Time: 16:18:18
                    Control Module temperature: 7 °C
                    Voltage terminal 15: 6.144 V
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 174
                    Mileage: 203326 km
                    Date: 2019.02.09
                    Time: 00:16:49
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 12.561 V
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.08
                    Time: 17:50:16
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 10.244 V
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.10
                    Time: 11:15:30
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 12.164 V
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 174
                    Mileage: 194468 km
                    Date: 2018.07.08
                    Time: 15:48:23
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 12.623 V
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.08
                    Time: 17:50:16
145152 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_SWA_FAIL]
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:02:14
                    Control Module temperature: 4 °C
                    Voltage terminal 15: 12.299 V
92416 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_LRRS_FAIL]
                    Reset counter: 174
                    Mileage: 226008 km
                    Date: 2020.10.26
                    Time: 14:51:44
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 9.303 V
   Part No SW: 4H0 959 655 A    HW: 4H0 959 655 A
   Component: Airbag10.43   H23 0026
   Revision: --------    Serial number: 003DB0011SN.
   Coding: 303143303132303030314A55304C34483053
   VCID: 3424C5209FF1C426C7-8060
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1053100PFR
   Serial number: 3575HRB40596CMJOBONJ
   Serial number: 3585HRB40576CMJO58FV
   Serial number: 3515JRB40556DUG6HGU4
   Serial number: 3525JRB40576094IBHS9
   Serial number: 3554VRB405J6NG4EKOFL
   Serial number: 3564VRB405H6NG4EFP01
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 170
          [Powersupply lower threshold fall short of]
                    Reset counter: 170
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JFA00010
   Coding: 0004BC
   VCID: 3228C3386DE5CA16D5-8066
   Subsystem 1 - Part No SW: 4H0 951 528     HW: 4H0 951 528
   Component: E221 - MFL  H04 0009
   Serial number: 31 05 2010  33010150
                    Reset counter: 170
                    Reset counter: 168
   Part No SW: 4H0 920 830 C    HW: 4H0 920 830 E
   Component: TBenRDWACCNV- H30 0297
   Revision: 25030006    Serial number: 658270610593005
   Coding: 0B8608017F000008020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU64.rod
   VCID: 25022864242BADAE40-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 F    HW: 4H0 919 204 F
   Component: Analoguhr D4  H04 0210
   Serial number: 1100615001717
          [Supply voltage too low]
                    Reset counter: 156
   Part No SW: 4H0 907 468 D    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0183
   Revision: --------    Serial number: 00000000023308
   Coding: 00C1034A00
   ASAM Dataset: EV_GatewUDS 001023
   ROD: EV_GatewUDS_AU57.rod
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0130
   Serial number: 00000000005640104921
0017 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 170
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:10:00
                    Voltage terminal 30: 5.1 V
                    Voltage terminal 15: 5.1 V
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 171
                    Mileage: 215268 km
                    Date: 2020.05.07
                    Time: 10:47:04
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 12 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 179
                    Reset counter: 173
                    Mileage: 215268 km
                    Date: 2020.05.07
                    Time: 14:05:22
                    Voltage terminal 30: 11.7 V
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4H0 907 144 A    HW: 4H0 907 144 A
   Component: DYNAMIKLENK.  H06 0080
   Revision: 51001005    Serial number: --------------
   Coding: 8B0000
   VCID: 26002F68512DA6B649-8072
                    Reset counter: 170
                    Count: 91
                    Count: 1
                    Hex Value: 0x0039
                    Hex Value: 0x0401
                    Hex Value: 0x0200
                    Hex Value: 0xFFFF
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H14 0045
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001038
   ROD: EV_AirCondiHeck.rod
   VCID: 312ACC3460E3F10EAC-8064
0077 - Supply voltage
                    Reset counter: 168
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:24
0102 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:24
   Part No SW: 4H0 907 553 B    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H16 0095
   Coding: 008006
   ASAM Dataset: EV_AirSuspe 003017
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2B16DE5C42CF9BDE96-807E
136194 - Supply voltage
          [VersorgungsspannungSpannung zu niedrig]
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:42:37
          C10C8 00 [008] - -
                    Reset counter: 172
                    Mileage: 226008 km
                    Date: 2020.10.26
                    Time: 12:49:59
   Component: MEM-FS        H07 0115
   Revision: AA000000    Serial number: 00001010177012
   Coding: C0183B0085053201010001010101112131313333203333
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:47:09
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:31:04
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0015
   Revision: --------    Serial number: EJ1BPA37004NMA0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D12D0447CDB95EE88-8078
1048835 - Supply voltage
          U1011 00 [040] - Voltage too Low
          [ECU temporarily disturbed: Undervoltage T30]
                    Reset counter: 156
                    DCU Temperature: 13 °C
                    Voltage Clamp 15: 6.1 V
                    Voltage Clamp 30: 5.7 V
                    Ignition Cycle Count: 42984
                    Voltage UBDZ: 5.7 V
                    Voltage VDD1: 1.5 V
                    Voltage VDD3: 3.3 V
                    Voltage VDD3_STUCK: 1.9 V
                    Voltage VDD5: 5.0 V
                    Voltage VBG2: 2.5 V
                    Voltage GNDA: 0.0 V
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0060
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   Coding: 0000001
   VCID: 6D921044745B55EEC8-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0060
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F30.06.1000H010003CH10385ÿ
   Subsystem 4 - Serial number: H10385ÿ
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:44:39
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:44:39
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:44:39
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000105481902
   Coding: 011F13205E00628202000003
   Shop #: WSC 02312 785 00200
   VCID: 3B36EE1CBAAF0B5E06-806E
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:45:57
   Revision: 00002001    Serial number: 0000000000
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000010565
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO1026130U
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0070
   Serial number: A2010000000000109716
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000437W
                    Reset counter: 172
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:41
   Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0070
   Revision: CJ007000    Serial number: 00000000000555
   VCID: 1B760E9C1A6F6B5EE6-804E
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000105394591
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:32:21
   Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
   Component: EPB-4         H03 0009
   Revision: --------    Serial number: 00000000004074
   ASAM Dataset: EV_ParkiBrake 001015
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 281C21505339B0C67B-807C
10554390 - Supply voltage
          [FC_LOW_V_BATT]
                    Reset counter: 130
                    Date: 2127.15.00
                    Time: 31:63:63
                    Voltage terminal 30: 6.9 V
                    Internal Fault ID: 40
                    Vehicle speed: 510 km/h
                    Network management state: Reset
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Emergency running mode
                    Status ParkingBrake left: Initializing
                    Status ParkingBrake right: Initializing
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357     HW: 4H4 907 357
   Component: ....AFS13.... H01 0070
   Serial number: 100601-0004-005
   Coding: 12116F33701AB200
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 6FAE0A4CB657A7FEFA-803A
H02 0006
   Coding: 1C0000
H02 0006
   Coding: 1C0000
   Part No SW: 4H0 035 082     HW: 4H0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 441EY0A7502579
   Coding: 020007010000000001
   VCID: 5EF0478849FD3E7641-800A
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:39
                    Voltage: 7.00 V
                    Reset counter: 172
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:05
                    Voltage: 7.50 V
   Part No SW: 4H0 035 664     HW: 4H0 035 664
   Component: H-BN-NA       H46 0104
   Revision: --------    Serial number: 417F.0A7506088
   Coding: 010200000001F9EF7D160F0E00000003FC000100
   VCID: 64847560679114A697-8030
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDA26001WJT
   Subsystem 3 - Part No SW: 4H1 919 600 C    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0062
   Serial number: 00000000014248
   Component: CD-Database  1886
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:43:39
                    Voltage: 7.00 V
                    Reset counter: 205
                    Mileage: 212035 km
                    Date: 2019.10.16
                    Time: 17:49:26
                    Bin. Bits: 00000000 01000000
                    Bin. Bits: 00000010 00000000
                    Bin. Bits: 00000000 00000000
03367 - Supply Voltage for Display Module
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:31:23
                    Voltage: 8.20 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000105593637
   Coding: 010F13204000628202000003
   VCID: 3A38EB18B59532561D-806E
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:45:54
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H03---    Serial number: 525PA8-J05D0OQ
   Coding: 1021002
   VCID: 65826864ACAB6DAE80-8030
                    Reset counter: 156
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 170
                        Term 15 Off
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 F
   Component: HDSG-Modul    H11 0036
   Revision: 09145325    Serial number: 158000003
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
0014 - Supply voltage
          [Versorgungsspannung dauerhaft zu niedrig]
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:44:37
                    Voltage terminal 30: 6.55 V
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000006461
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6386767C6A9F139E6E-8036
0003 - Supply voltage
                    Reset counter: 170
                    Date: 2127.15.00
                    Time: 31:63:63
                    Voltage terminal 30: 5.7 V
                    Control Module temperature: 10 °C
                    Processor load: 100.0 %
                    Status terminal 58s: OFF
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000105593629
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:32:19
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731     HW: 4H1 927 731
   Component: GSM-LL        H04 0081
   Revision: 0L0D4011    Serial number: SN100506  0083
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 6A981B588DB542D6AD-803E
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0026
   Serial number: 0K84AE40005858
   Coding: 1101
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H07 0006
   Serial number: 00000000001007512000
4097 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Steuergeraet fuer Nachtsichtsystem: Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 170
                    Voltage terminal 15: 6.3 V
                    Image processor: temperature: -3 °C
                    Microprocessor malfunction type: Cold_start_reset
                    Image processor: error number: 00 00
4098 - Supply voltage
          [Steuergeraet fuer Nachtsichtsystem: Versorgungsspannung: unterer Grenzwert unterschritten]
                    Reset counter: 170
   Part No SW: 4H0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H22 0016
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 271E226C5E27BFBE72-8072
0232 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Functional_restrictions_low_voltage]
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:27
                    Outside air temperature: 75.5 °C
                    Voltage terminal 15: 6.2 V
                    Control Module temperature: -1.0 °C
0233 - Supply voltage
          [Ubat_too_low]
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:30:45
                    Outside air temperature: 74.0 °C
                    Voltage terminal 15: 8.5 V
                    Control Module temperature: -9.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 E    HW: 4H0 907 182 E
   Component: IVB           H03 0027
   Serial number: 00452512094201
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2C14DD4047C19CE69F-8078
0002 - Supply voltage
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:30:59
0004 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 172
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00452512092901
   Coding: 364FF2
                    Reset counter: 170
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:30:59
          U1400 00 [008] - -
                    Reset counter: 172
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Component: ACC3          H15 0160
   Coding: 3601010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
10 Faults Found:
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW]
                    Fault Frequency: 44
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:00:14
                    Voltage terminal 15: 7.744 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1400 00 [008] - -
                    Fault Frequency: 47
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:00:14
                    Reset counter: 174
                    Mileage: 214809 km
                    Date: 2020.01.22
                    Time: 16:18:18
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 6.080 V
          U1113 00 [008] - -
                    Reset counter: 174
                    Mileage: 203326 km
                    Date: 2019.02.09
                    Time: 00:16:49
                    Control Module temperature: 13 °C
                    Voltage terminal 15: 12.624 V
154624 - Door Contact Switch
          C1076 29 [008] - Signal Implausible
                    Reset counter: 174
                    Mileage: 215268 km
                    Date: 2020.04.11
                    Voltage terminal 15: 11.219 V
          U1113 00 [008] - -
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.08
                    Time: 17:50:16
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 10.298 V
          U1113 00 [008] - -
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.10
                    Time: 11:15:30
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 12.134 V
          U1113 00 [008] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 174
                    Mileage: 194468 km
                    Date: 2018.07.08
                    Time: 15:48:23
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 12.681 V
          U1113 00 [008] - -
                    Reset counter: 174
                    Mileage: 218352 km
                    Date: 2020.07.08
                    Time: 17:50:16
          U1113 00 [008] - -
                    Reset counter: 174
                    Mileage: 200946 km
                    Date: 2018.11.05
                    Time: 00:02:14
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 12.238 V
Address 8E: Image Processing (J851)       Labels:* Redir Fail!
   Part No SW: 4H0 907 107     HW: 4H0 907 107
   Component: BV-SG         H25 0008
   Serial number: 000040051406107
   Coding: 01A18201
   ASAM Dataset: EV_BVS 001007
   ROD: EV_BVS.rod
   VCID: 648475606F9114A697-8030
0010 - Supply voltage
          [Ubat_too_low]
                    Reset counter: 174
                    Mileage: 225985 km
                    Date: 2020.10.22
                    Time: 09:32:40
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] - -
          [DPC_SystemError]
                    Fault Frequency: 49
                    Reset counter: 174
                    Mileage: 214880 km
                    Date: 2020.02.01
                    Time: 01:16:00
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H04 0070
   Coding: 0066F609031F037E070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
12585216 - Supply voltage
                    Reset counter: 170
                    Mileage: 225944 km
                    Date: 2020.10.18
                    Time: 16:46:08
          U1101 00 [008] - Active
                    Reset counter: 156
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:25:00
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H04 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 70AC0930AB69B806E3-8024
                    Reset counter: 170
                    Reset counter: 156
                    Mileage: 225635 km
                    Date: 2020.10.11
                    Time: 10:24:40
End----(Elapsed Time: 03:12, VBatt start/end: 12.3V/11.9V. VIgn 12.0V)-----
That scan is so full of fault codes that the signal-to-noise ratio is very, very low.
There shouldn't be a draw of hundreds of milliamps once things go to sleep. Please try this method to figure out where that current is going:
dieseldub
Bay Area, CA
C?ID=28764
Measuring mV drop across fuses as outlined in the post Uwe linked is definitely the way to go, but what can make it challenging is if the spike in draw doesn't last super long and is also coinciding with waking up multiple systems. I've had that happen NUMEROUS times with old Touaregs... especially ones with the door handle touch sensors.
They would go from drawing around 0.050 A or less (considered acceptable range for early Touaregs and Phaetons--all other models, 0.030 A max) to out of the blue pulling more than 4 A (yes, no decimal point, four whole amps) and you hear what sounds like various relays under the dash randomly clicking. Turns out it's sort of normal for them to do that about twice in the first 15 minutes of being armed.
But when the door handle touch sensors are wigging out, it will just keep on waking up those same systems over and over again. I had to put my meter into a mode where it records the average draw and I would evaluate after an entire hour. It would average somewhere in the 0.200 A range with it waking up intermittently then going back to sleep (sleep being closer to 0.050, waking up was 4 whole amps for a brief moment before the draw reduces back to 0.200 A range for awhile before slowly dropping back to 0.050 A).
It took me awhile to think of even trying it, but I would go and unplug all 4 door handle sensors, run the test again, it would do that spike twice in the first 15 minutes, but then averaged out over an hour, it was pretty close to that 0.050 A mark, let it sit for longer still, the average became even better since it wasn't getting more than just those 2 initial spikes.
The A8 you're working on is clearly a newer generation that doesn't draw as much once fully asleep, so YMMV on this tip. But it's certainly still possible to have the touch sensors waking things up intermittently.
