S Tronic DL501 - Uncommon DTC Codes
Pavlito
Czech Republic
C?ID=32266 (NRRT)
HI guys..
Today new here
It's looks I am in blind street. Have anybody experienced issue with S-Tronic DL501 as I did not find following DTC codes in any tread on this forum ?
Wondering if anybody could lead me on the good way to solve this out.
Anyway - Had taken out mechatronic, changed all solenoids and electrical boards and problem still there. Basic calibration did not pass through "Distance sensor calibration" otherwise all basic adaptation went fine.
Looks like the problem is mechanical ? outside of Mechatronic module ?? Anybody ? Thank you for any help !!
Transmission DTCs:
Wednesday,07,October,2020,13:31:17:09136
VCDS Version: Release 20.4.2 (x64) Running on Windows 7 x64
                Address 02: Auto Trans       Labels: 0B5-927-156.clb
Control Module Part Number: 8K9 927 156 M    HW: 0B5 927 156 K
  Component and/or Version: 0B5 30 TDIRdW H03 0003
           Software Coding: 000001
            Work Shop Code: WSC 06325 000 00000
              ASAM Dataset: EV_TCMDL501021 001015 (AU48)
                       ROD: EV_TCMDL501021.rod
                      VCID: 4799A734FE8E44BE92-8012
23684 - Shift Fork 4
          P2850 00 [237] - Uncommanded Movement
                    Mileage: 186830 km
                    Date: 2020.09.02
                    Time: 11:17:53
                    Engine speed: 2531 /min
                    Transmission input speed: 2531 /min
                    Transmission output speed: 1382 /min
                    Engine torque: 400 Nm
                    Transmission fluid temperature: 60 °C
                    Accelerator position: 64.8 %
                    Clutch status: Beide Kupplungen können Moment übertragen
                    Gear selector: gear 4: standardized end position-Data: -9.02 mm
                    Gear selector: gear 6: standardized end position-Data: 9.03 mm
                    Current of gear Solen.val. 4-6-Data: 701.7 mA
                    S003_Svw_S_Gs[G46]-Data: 7.35 mm
                    U003_Glr_iVentEinsatzNeg[Gs46]-Data: 650.0 mA
                    U007_Glr_iVentEinsatzPos[Gs46]-Data: 716.3 mA
                    GssDiag_Ct_EreignEingelVerlass[GANG4]: 0
                    GssDiag_Ct_EreignEingelVerlass[GANG6]: 4
                    GssDiag_T_EingelVerlass[GS46]-Data: 3 ms
                    Gss_Counter_EreignEingelVerlassGesamt[GS46]: 11
                    Gss_kmStand_EreignEingelVerlassGesamt[GS46]: 186816
24379 - Gear Selector
          P187F 00 [104] - Position Deviation
                    Fault Frequency: 18
                    Mileage: 184818 km
                    Date: 2020.08.07
                    Time: 19:40:14
                    Engine speed: 3632 /min
                    Transmission input speed: 3632 /min
                    Transmission output speed: 1521 /min
                    Engine torque: -64 Nm
                    Transmission fluid temperature: 76 °C
                    Accelerator position: 0.0 %
18011 - Gear Selector 2
          P187B 00 [032] - Engagement not successful
                    Reset counter: 35
                    Mileage: 185176 km
                    Date: 2020.08.11
                    Time: 09:08:26
                    Engine speed: 601 /min
                    Transmission input speed: 601 /min
                    Engine torque: -12 Nm
                    Transmission fluid temperature: 82 °C
                    Clutch status: Beide Kupplungen offen
                    Unlearning counter according OBD: 35
Does not belong in Forum Support & Feedback. Moving to New Users section.
Been here?
Coolant, water ingress and corrosion problems at the 0B5 Mechatronic connector aren't uncommon. When dealing with a TCM that won't communicate at all -or- is packed full of random DTCs such as P1893, P1894, P1892, P1890, U0100, U0146, P2850, U0100, U0212 and U0401 please see this thread: https://forums.ross-tech.com/index.php?threads/15276/
Pavlito
Czech Republic
C?ID=32266 (NRRT)
HI guys..
Today new here
Transmission DTCs:
                    Mileage: 186830 km
                    Date: 2020.09.02
                    Time: 11:17:53
                    Fault Frequency: 18
                    Mileage: 184818 km
                    Date: 2020.08.07
                    Time: 19:40:14
                    Reset counter: 35
                    Mileage: 185176 km
                    Date: 2020.08.11
                    Time: 09:08:26
ANYBODY ???
