New member | 2020 | Audi Q8 | Prestige
TranV
MA, USA
C?ID=100252
Hello all,
I am still new to this forum and would like to share my AutoScan. My car is in perfect working condition, except couple of weeks ago I had to drop it off to the dealership to have the Emergency Call function reset (went off grid and it got disconnected with AT&T service). However, when I did the AutoScan, I saw some faults. Would someone please help me with this before I share the log? Thank you.
Saturday,24,October,2020,09:40:11:13150
VIN: WA1FVAF12LD023451   License Plate:
Mileage: 7813km-4854mi   Repair Order:
Chassis Type: F1-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 36 3C 42 44 46 47 52 5F 61 6D 74
          75 81 82 A5 BB BC C4 CA CC CF D6 D7 DB DC DE
VIN: WA1FVAF12LD023451   Mileage: 7813km-4854miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DCBD)       Labels: None
   Part No SW: 4M8 907 559 A    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0003
   Revision: B8H11000
   Coding: 2A2A00122566010E34286000000400000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TFS0114M8907559A 001003
   ROD: EV_ECM30TFS0114M8907559A.rod
   VCID: 3D2732F8CDF29B03795-8068
   Part No SW: 4M0 927 158 AM    HW: 0D5 927 156 P
   Component: 0D5 30TFSINAR H05 1004
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_AU58.rod
   VCID: 7F5B08F0877E49132B9-802A
   Automatic Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 2002201061
   Part No SW: 4M6 907 379 AF    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0857
   Coding: 28AA149631A40B9993A25C96087E52E2F53A8914288CD0C93A104A47AF5C91
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 015F8E08F18A3FE35DD-8054
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000363C0291CDD070E57889CEF9C38130B37110406009701010A0019331601086309024010000000000303004308185802000044010104000000000000000000
   Shop #: WSC 00001 444 00000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7BA3FCE093665533071-802E
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301916102364
   Coding: 7DC727
   Serial number: 24474224X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S10.03.2000691249
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00M902
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE113121923611065
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0416
   Serial number: Q00869941
   Coding: 0D0104
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H07 0200
   Serial number: WA140323000078323966
   Coding: 0A0100
   Seat Backrest Fan 1 Front Left:
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK06487320
   Seat Cushion Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK06669717
   Seat Backrest Fan 1 Front Right:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK06669581
   Seat Cushion Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK057A2632
67735 - Databus
          [MxB not available]
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:49
                    average_Voltage_terminals: 13.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 19.50 °C
                    interior_temperature: 20.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
   Part No SW: 4M0 907 561 M    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: D6659F5458082C00010360E10000003E4A1246484401009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 3A2D39E4DCDCAC3B5C7-806E
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 13.7 V
                    Steering_angle-Data: -3.600 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.514 °
                    Misalignment angle: horiz: fast algorithm: 0.390 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 19.50 °C
                    Sensor blindness: radar: no blindness detected
2345 - Databus
          [FAULT_CAMERA_ERROR]
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
2359 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_SENSOR_DISTURBED]
                    Reset counter: 35
                    Mileage: 7789 km
                    Date: 2020.10.22
                    Time: 07:16:16
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 14.1 V
                    Velocity_vehicle_reference: 5.70 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.72 m/s²
                    Steering_angle-Data: 198.000 °
                    Yaw_rate-Data: 7.316 rad/s
                    Misalignment angle: horiz: 0.579 °
                    Misalignment angle: horiz: fast algorithm: 0.694 °
                    Outside air temperature: 13.50 °C
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H12 2720
   Serial number: 003YUM011YZV
   Coding: AECCFCC000C00000A000003FF20D410000C5
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 44D1471CAE18EACB36B-8010
   Belt Pretensioner left:
   Serial number: 00AI2019246050600000
   Coding: 02F001
   Belt Pretensioner right:
   Serial number: 00AI2020053365200000
   Coding: 02F001
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000CU07R0G
   Coding: 303134
   Subsystem 4 - Part No SW: -----------    HW: 480 002 301 20
   Serial number: 357000000008168C944O
   Subsystem 5 - Part No SW: -----------    HW: 480 002 301 20
   Serial number: 35800000000012695343
   Subsystem 6 - Part No SW: -----------    HW: 480 030 603 20
   Serial number: 351002C04E18FA312C18
   Subsystem 7 - Part No SW: -----------    HW: 480 030 603 20
   Serial number: 352002C0434BD400BE24
   Subsystem 8 - Part No SW: -----------    HW: 480 032 002 20
   Serial number: 355002C04E230A206B70
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 002 20
   Serial number: 356002C0435311705DC$
   Side Sensor B-Pillar Driver Front:
   Subsystem 10 - Part No SW: -----------    HW: 480 030 603 20
   Component: SideSens_B_Df  002 0149
   Serial number: I0P002C04E1072E0AB1Z
   Side Sensor B-Pillar Passenger Front:
   Subsystem 11 - Part No SW: -----------    HW: 480 030 603 20
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q002C045EB10E098D8
   Part No SW: 4N0 907 129 Q    HW: 4N0 907 129 Q
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 3FDB48F0C7FE89136B9-806A
   Part No SW: 4K0 920 890 B    HW: 4K0 920 890 B
   Component: FBenUSAACC--- H12 0212
   Coding: 8BC610C77C88D7050283E16098804B0008003000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2D0702B81D920B83C95-8078
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Fault Frequency: 8
                    Reset counter: 36
                    Mileage: 7515 km
                    Date: 2020.10.13
                    Time: 08:07:58
   Part No SW: 4K0 907 468 Q    HW: 4K0 907 468 C
   Component: Gateway       H06 0272
   Serial number: 1AF02135298501
   Coding: 020100050004064054960000005B0132DC9A004710000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x.rod
   VCID: 42DD4104B40CE4FB047-8016
   Subsystem 1 - Part No SW: 4M8 951 523 A    HW: 4M8 951 523 A
   Component: J453 MFL  H07 0004
   Serial number: 20200303094545 30616
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 7588520200200306088B
131687 - Control Module for Emergency Call and Communications
          U1421 00 [008] - No Communication
          [Timeout_Node_0x67_DiagAdress_0075_ConBox]
                    Reset counter: 23
                    Mileage: 7530 km
                    Date: 2020.10.13
                    Time: 17:57:35
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000408264028
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 3B233CE0D3E69533471-806E
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007TAV03173
   Coding: 001DCB42520014C0A009A436
   Shop #: WSC 31414 050 00001
   VCID: 46D55D149824D8DB28F-8012
   Coding: B8000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D11C404AC547B947-8066
   Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0542
   Coding: 013400004FB100C0650FA0046C01880203004000810426502F0400200F04823F001E0101010F11
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 0B43AC20C3C665B3371-805E
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY2003515QC
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000984330
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4M8 945 069 C    HW: 4M8 945 069 C
   Component: SHL_li1  H04 0004
   Serial number: 069C2002190000129811
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14501133
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4M8 945 217 G    HW: 4M8 945 217 G
   Component: SHL_li2  H04 0004
   Serial number: 217G2002210000130559
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4M8 945 070 C    HW: 4M8 945 070 C
   Component: SHL_re1  H04 0004
   Serial number: 070C2003020000132423
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4M8 945 218 G    HW: 4M8 945 218 G
   Component: SHL_re2  H04 0004
   Serial number: 218G2002210000130559
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D03TPMW
   Coding: 0135360A00AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E79C4E58CACB16B-8070
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007TAV16226
   Coding: 001DCB025E0014C0A009A434
   VCID: 45D75A18A522D3C3215-8010
   Part No SW: 4K0 035 084 D    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   056 2711
   Coding: 0135360200000000C1220002061C00302F0001E403F008048E
   VCID: 270BF0903F6E21D3339-8072
   Subsystem 1 - Part No: V03 959 804 CH
   Component: MIB2P_NA_Q120  0446
   Subsystem 2 - Part No SW: 4M8 919 605 L    HW: 4M8 919 605 F
   Component: DU AU536 Top  H32 0053
   Serial number: INX00110121900150398
   Compact Disc Database:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004420000030312036
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00125111900170847
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 052000127944014
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290FF6A8297A17A325D-807C
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 2830
   VCID: 343117DCFEB85A4B86B-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 CB    HW: 4M8 907 777 D
   Component: Fahrwerk-SG   H52 2135
   Serial number: 0703201069
   Coding: 185C30307844
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 03538400EB962DF34F1-8056
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F121270
   Coding: 01C020FF4040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809F3AC32702EAB3A3-807C
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Fault Frequency: 136
                    Reset counter: 39
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:29:36
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 20012558353701
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M8 919 617 F    HW: 4M8 919 617 F
   Component: HeadupDisplay H06 4910
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 40D94B0CBA00F6EB123-8014
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 020182000000000000FBD60000F0450C139F7600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000078D00080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F7BB830B7DE5993DB9-805A
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: YE007TAP15781
   Coding: 000DCB02000014C0E008A024
   VCID: 48C9532C9230CEABDA3-801C
   Component: TSG HBFS004 0425
   Serial number: YE007TAP12141
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC20117001474
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_VW38.rod
   VCID: 75B7EAD8B5420343715-8020
   Coding: 228040053632
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 N    HW: 4N0 903 028 N
   Component: BSG-HP1-65    H17 0523
   Serial number: 10032000020093
   Coding: 20000400000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 36352DD4E8C4485BB8F-8062
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BDD1C4C42C147B547-8026
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 H    HW: 4N0 907 669 A
   Component: MRR_VR H16 0267
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651_AU58.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H16 0267
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 2313E4804B56CDF36F1-8076
End----(Elapsed Time: 02:06, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Saturday,24,October,2020,09:43:10:13150
   Revision: B8H11000
   Revision: --H05---
   Coding: 100000
   Coding: 7DC727
   Coding: 02005D
   Coding: 250000
   Coding: 0D0104
   Coding: 0A0100
67735 - Databus
          [MxB not available]
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:49
2342 - Databus
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
2345 - Databus
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
                    Reset counter: 35
                    Mileage: 7789 km
                    Date: 2020.10.22
                    Time: 07:16:16
   Coding: 02F001
   Coding: 02F001
   Occupant Detection:
   Coding: 303134
16777089 - Databus
                    Fault Frequency: 8
                    Reset counter: 36
                    Mileage: 7515 km
                    Date: 2020.10.13
                    Time: 08:07:58
                    Reset counter: 23
                    Mileage: 7530 km
                    Date: 2020.10.13
                    Time: 17:57:35
   Coding: 0FDC00
   Rear Light Left 1:
   Rear Light Left 2:
   Rear Light Right 1:
   Rear Light Right 2:
   Volume Control 1:
   Media socket:
   Coding: 2830
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 39
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:29:36
   Coding: 4700E0
4107 - Databus
                    Reset counter: 22
                    Mileage: 7515 km
                    Date: 2020.10.12
                    Time: 16:23:47
   Coding: 0FDC00
   Coding: 001000
   Coding: 001000
   Coding: 800000
End----------(Elapsed Time: 01:59, VBatt start/end: 13.2V/12.9V)-----------
South Molton, UK
They are all intermittent faults, clear them all and see if any come back.
It's not uncommon for these complex modern vehicles to have firmware that sometimes wakes up "on the wrong side of bed", if everything is working fine then the faults can be just clered.
