VW Passa CC 2012 Bi-Xenon AFS Powerunit
robertphu01
Pirate
Hungary
HI Folks,
Can somebody help me on the following problem?
In MY Passat CC the right AFS Power Unit failed which had a following numbers:
OEM number: 1T0 941 329 A
Part number: LeiMo links H06 0007
Cooding: 350000
I have bought a new one, but it has a different numbers like:
OEM number: 1T0 941 329 B
Part number: LeiMo links H06 0009
Cooding: 3F0000
At the moment the central AFS has the error code, the new power unit is not coded, but I am not able to code directly or even by the central AFS ECU, as it does not accept any coding because of "Coding Rejected, Error 10", so the new AFS unit remains on 3F0000 and I continuosly got right AFS power unit is not coded.
Do you think the problem is that, the new AFS Power Unit has a different OEM number and part number and does not fit to my car?
Will AFS ECU coding the new or used power unit with OEM NUMBER 1T0 941 329 A?
I am planing to buy an other AFS power unit with right OEM number, but I am afraid it won't work too.
Can you give any advice please?
Rob
South Molton, UK
To offer advice that is better than guesswork we'll need to see a full unedited VCDS Auto-Scan (using the English version of VCDS) of your Passat CC.
