2019 Q5 Adaptive Front Light System Help
Reihenmotor5
I have a 2019 Tiguan SEL-P R Line and my wife picked up a 2019 Audi Q5 Premier Plus. I'm looking to try and enable additional headlight functions to her Audi like I did with my Tiguan. On my Tiguan I went into 4B to add features such as: City Light, Rain Light, Intersection Light with Route Data, Predictive AFS, Dynamical Low Beam Light, High Beam Assist and Highway Light. After poking around her Audi it appears most of this functionality is located under 09 Long Coding, but I need to know what can and can't be coded and also error that need/can be cleared out with Basic Settings after making changes. I see the following which may be needed and below are current default settings:
Afs Activation - Not enabled (does this need to be enabled in order to get the horizontal movement that matches steering input outside of the default limited degree of change?)
Crossing Light with Route Data - Not enabled (expect this to be Intersection Light with Route Data)
City Light - Not enabled
Weather Light - Not enabled (is this Audi's version of Rain Light, or will this impact the all weather light button that's on the light switch?)
I wasn't able to find predictive AFS, but maybe Afs activation encompasses this information? I did utilize OBD11's app function to turn on High Beam Assist on her Audi to enable that function. Unlike VW it doesn't appear you can make this persistent, unless someone knows how to do this also, that would be great.
I'd love to get these additional functions and capabilities enabled since U.S. headlight regulations is terrible and I've found in the country with no street lighting my VW outperforms her Audi when it comes to visibility at night.
Thanks for any help that can be provided. Here is my mod doc and under Exterior Lights you'll see what I found and turned on - tinyurl.com/TigRLineMods
Mari
C?ID=150535
... we'd like to see a full and unedited autoscan of the car...
Reihenmotor5
Sunday,06,September,2020,10:10:26:56344
VIN: WA1BNBFY6K2045173   License Plate:
Mileage: 21157km-13146mi   Repair Order:
Chassis Type: FY-AU49 (80A)
Scan: 01 02 03 08 09 15 16 17 19 22 29 36 39 3C 42 44 46 47 52 5F
          6C 6D 75 81 A5 BB BC CA CF D6 D7
VIN: WA1BNBFY6K2045173   Mileage: 21157km-13146miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DJYA)       Labels: None
   Part No SW: 80A 906 259 F    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0006
   Revision: --H15---
   Coding: 2A6500322526012E74280000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS02080A906259F 001008
   ROD: EV_ECM20TFS02080A906259F.rod
   VCID: 2E050CCFE09A84FBF0F-807A
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181028020103053700
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 DJ    HW: 0HK 927 156 B
   Component: 0CJ 20TFSINAR H01 0005
   Revision: --H01---    Serial number: 0000000342
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 74B1DEA74E36EE2B46B-8020
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180289000537
   Part No SW: 80A 907 379 AB    HW: 80A 907 379
   Component: ESP9 Plus     H17 0777
   Coding: 4CAA40BE28A60A9B919F589820805292E5359A32021450891A044A49A7AC59
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 6FBBD1CB2710CDF3BB9-803A
   Part No SW: 80A 820 043 N    HW: 80A 820 043 N
   Component: Klima Zone 3  H60 0251
   Coding: 640809095548000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2809FAD7C27EDACB3A3-807C
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002847172
   Serial number: 4112DE4900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Coding: 07500363E1691CCD050587159CAE9CB9110B3D08000000000000000020001A010A630122025705
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 03538D7B1B98D9934F1-8056
   Subsystem 1 - Part No SW: 80B 955 119 A    HW: 80B 955 119
   Component: 426 LL 181117  040 0581
   Serial number: 00000001811132104624
   Coding: FFC7F7
   Serial number: 22043346X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 16 12 2018  83500212
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00OE02
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20181213003019 00030
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE103121824110490
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 80A 947 135 AN    HW: 80A 947 135
   Component: Dachmodul Q5  H32 0330
   Serial number: Q00073970
   Coding: 0D0101
   Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000245742004
   Part No SW: 80A 959 655 L    HW: 80A 959 655 L
   Component: AirbagVW30    053 0605
   Serial number: 003W1M043NZ.
   Coding: AEFCFCC000800000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3C21368726E6666B4EB-8068
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 80A857705K0285S01538
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 80A857706K0303S00785
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J18000AP9R00G
   Coding: 303033
   Subsystem 4 - Part No SW: -----------    HW: 480 002 010 18
   Serial number: 35700000000B9329A43N
   Subsystem 5 - Part No SW: -----------    HW: 480 002 010 18
   Serial number: 3580000000039768A43N
   Subsystem 6 - Part No SW: -----------    HW: 480 033 110 18
   Serial number: 351001C180E615F09F7H
   Subsystem 7 - Part No SW: -----------    HW: 480 033 010 18
   Serial number: 352000C2481082209BF+
   Subsystem 8 - Part No SW: -----------    HW: 480 032 210 18
   Serial number: 355001C140BE7DB1098J
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 210 18
   Serial number: 356001C140BE75815DBL
   Central Sensor XY:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 009 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001BB2953C45970Z
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 CB    HW: 80A 907 129 CB
   Component: Lenks.Modul   H02 0005
   VCID: 6A8DC0DF1CF228DBEC7-803E
   Part No SW: 8W5 920 890 E    HW: 8W5 920 890 E
   Component: FBenUSA       H20 0417
   Coding: 01E78EC5A888CF05022369601800000008000000
   ASAM Dataset: EV_DashBoardAU736 001032
   VCID: 45D75363552C27A3215-8010
   Part No SW: 80A 907 468 C    HW: 80A 907 468 A
   Component: Gateway       H05 0207
   Serial number: 1HF03025019901
   Coding: 030100010000064029070000005900324C3A0007100000000175078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x.rod
   Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
   Component: J453 MFL  H06 0004
   Serial number: 20181211233223 01319
   Serial number: 6268516200
131687 - Control Module for Emergency Call and Communications
          U1421 00 [008] - No Communication
          [Timeout_Node_0x67_DiagAdress_0075_ConBox]
                    Reset counter: 33
                    Mileage: 20465 km
                    Date: 2020.08.28
                    Time: 02:36:01
Address 22: AWD (J492)       Labels:* None
   Part No SW: 80A 927 755     HW: 0CJ 927 749 A
   Component: Q5_DL3_N_SD5H01 0006
   Serial number: 18299B3326
   Coding: 11070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6C81C6C7160636EB9EB-8038
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 C    HW: 80A 907 397 C
   Component: LCM_MLBevo    H07 0022
   VCID: 2F3B11CBE7908DF3FB9-807A
   Component: MEM-FS        009 0042
   Serial number: 12A14834404294
   Coding: 005C1B400000B4010000010101010000000000000000000000000000000000
   VCID: 79AFEF936954934315D-802C
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 80A 907 566 A    HW: 80A 907 566
   Component: MRR1Rear      H20 0431
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 2B0305DBD388F1D3D71-807E
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: CLSM1RKL002O0
   Coding: 005F8B005E00148000010032
   VCID: 40D942774A0E028B123-8014
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F17B3F1A49B03EDD-8064
   Part No SW: 4N0 907 064 CP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0164
   Coding: 013400004FB100C06509A0006C01980203024000810026502F0000000F04803F001E0001000010
   ASAM Dataset: EV_BCM2CONTIAU651 009009
   ROD: EV_BCM2CONTIAU651_009_AU49.rod
   VCID: 7F5B018B7770BD732B9-802A
   Ignition key:
   Serial number: 000000000ZY182751U7T
   Serial number: 00000000000045486940
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11203510
   Rear Spoiler Adjustment:
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 25
                    Mileage: 19722 km
                    Date: 2020.08.22
                    Time: 11:34:37
                    Supply voltages-Supply voltage: Terminal 30: 12.520 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.506 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.555 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
                    general_additional_freeze_frame-interior_temperature: -50.0 ∞C
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 00
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAJTK03GJ1K
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 196FCF1389147343B5D-804C
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: CLSM1RKG00HTF
   Coding: 005F8B005E00148000010030
   VCID: 3FDB418B37F07D736B9-806A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 C    HW: 8W5 035 880
   Component: MU-P-LNS-US   035 1316
   Serial number: A798L0J9466057
   Coding: 012406020000000051220002041A00332F0015E401700904FE
   Subsystem 1 - Part No SW: V03 959 803 AG    HW: -----------
   Component: NAR 2020/2021  --- 0079
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL06675
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 12111800000000000237
   Compact Disc Database:
   Component: Gracenote2  --- 3013
          B11CF 53 [008] - Deactivated
                    Reset counter: 31
                    Mileage: 19474 km
                    Date: 2020.07.24
                    Time: 10:51:45
                    Voltage terminal 30: 12.5 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [008] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 15
                    Mileage: 19477 km
                    Date: 2020.08.20
                    Time: 15:30:03
                    Voltage terminal 30: 14.4 V
   Component: RVC Compact   H15 0250
   Coding: 0224060102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33331DBB0BB8A9139F1-8066
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C748-5750-7
   Coding: 0730
   VCID: 4ACD605F7C32C8DBCC7-801E
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120263
   Coding: 01C020FE4040800000
   ROD: EV_ConBoxAU651_002.rod
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 45
                    Mileage: 19474 km
                    Date: 2020.07.24
                    Time: 10:25:17
   Part No SW: 80B 713 041 N    HW: 80B 713 041 N
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20181127005747
   ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 B    HW: 80A 907 217 A
   Component: BVS           H17 0052
   Coding: 0404020600000201022023A2A50000FE00F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 2517F3E3B56CC7A3015-8070
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: CLSM1RKE00KWQ
   Coding: 000F8B000000148040000020
   VCID: 42DD487F4402109B047-8016
   Component: TSG HBFS003 0188
   Serial number: CLSM1RKE00KGN
   Coding: 22800004260C
   ROD: EV_SunRoofCONTIAU736_009_AU49.rod
   VCID: 75B7E3A3454CF723715-8020
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 80A 907 590 A    HW: 80A 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176BC92B7F006533839-8042
End----(Elapsed Time: 02:25, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
