2015 transporter bcm coding
sarb
C?ID=105364
Retrofitted MFSW and CCS to 2015 transporter. A new BCM (09) fitted that supports the MFSW and CCS. MFSW and CCS work fine. I copied and paste old long coding from old BCM to the new BCM. Problem i have is as follows:
When i open the left front door the display in the dash shows the right door as open and when the front right door is oprn the display shows left door open.
Can anyone please advise how to overcome this issue?
Monday,26,October,2020,00:17:06:50819
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WV1ZZZ7HZFH023820   License Plate: WU64 XGF(NEW BCM)
Mileage: 261210km-162308mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZFH023820   Mileage: 261210km-162308miles
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GG    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H45 6291
   Revision: 26H45---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GG 003004
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 76B5E4D7F84B558B78F-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A60A9824AA9173A95E10
   Shop #: WSC 02737 790 49152
   VCID: 3A2D30E78C53F1EB5C7-806E
   Serial number: 27061404651667
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FCF7D07B1DCB20F-802A
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CA1F6FFC6670FDB0EB-8028
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 336190255
   Coding: F8A4303A0AF32C3112280E106E2B8C550080632F60860040320000000800
   Shop #: WSC 18752 008 00032
   VCID: 41DF470BE185A2331DD-8014
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU030061441813329
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU027061441785130
   Coding: 0000A0
   Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170002240860037504
   Coding: A40000
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 1
                    Mileage: 261210 km
                    Date: 2015.03.19
                    Time: 23:51:48
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00RK237
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353723DBA5CD1E93B15-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H03 0805
   Coding: 460A00
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 002000
   VCID: 70B9D2CF9AAF7BBBA23-8024
   Component: IMMO          H03 0805
   VCID: 6A8DC0A7BCF3816BEC7-803E
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000442040005
   Shop #: WSC 127395 840 08317
   VCID: 46D55417C8AB850B28F-8012
7 Faults Found:
00856 - Radio Antenna
                    Fault Status: 00111011
                    Reset counter: 0
                    Mileage: 261209 km
                    Date: 2015.03.10
                    Time: 08:08:20
                    Reset counter: 0
                    Mileage: 261209 km
                    Date: 2015.03.10
                    Time: 11:15:54
                    Reset counter: 0
                    Mileage: 261209 km
                    Date: 2015.03.10
                    Time: 11:15:54
00877 - Treble Speaker Rear Right (R16)
                    Fault Status: 00101011
                    Reset counter: 1
                    Mileage: 261210 km
                    Date: 2015.03.19
                    Time: 20:47:43
                    Reset counter: 1
                    Mileage: 261210 km
                    Date: 2015.03.19
                    Time: 23:51:53
01523 - Microphone for Telephone (R38)
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 1
                    Mileage: 261210 km
                    Date: 2015.03.19
                    Time: 23:53:16
End----------(Elapsed Time: 01:04, VBatt start/end: 13.4V/13.9V)-----------
siLc
Tallinn, Estonia
C?ID=330192
BCM was from a LHD donor but the recipient is RHD?
