2020 A8, 4.0 CXYA
Jef
HQ
Lulz, the copied file from gator seems to be tooooo large, so pasted into Notepad++, and cut/paste the first half of the wall -O- text and will reply with the 2nd half.
AutoScan: WAU8EAF82LN004143
VCDS Version: 20.9.1.0 (x64)  HEX-NET2 CB: 0.4529.4
Data version: 20200919 DS322.0
VIN: WAU8EAF82LN004143   License Plate:
Chassis Type: F8-AU65 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 29 36 39 3C 42 44 46 52 5F 61
          6D 74 75 81 82 A5 BA BB BC C4 CA CD CF D6 D7 DB DC DD
VIN: WAU8EAF82LN004143   Mileage: 122km-75miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
Address 01: Engine (------CXYA)       Labels: None
   Part No SW: 4N0 906 014 C    HW: 0P2 907 309 A
   Component: V8 4.0l TFSI  H31 0001
   Revision: 72H31000
   Coding: 0A2A0012256E010E34286000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114N0906014C 001001
   ROD: EV_ECM40TFS0114N0906014C.rod
   VCID: A90416EE190A3B13905-80FC
Readiness: 1000 0100
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4N0 927 158 K    HW: 0D5 927 156 P
   Component: 0D6  40TSINAR H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_VW53.rod
   VCID: BD2CD2BEFD82B7B3CCD-80E8
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 1907301870
   Part No SW: 4N0 907 379 AL    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0856
   Coding: 3CAA189D31A24B9A119F4C951880D2E2F539893C188CD28832184B47AF9C91
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 82566142C4FC084BF1F-80D6
   Part No SW: 4M4 959 760 D    HW: 4M4 959 760 D
   Component: MEM-BFS       009 0044
   Serial number: 00000387206254
   Coding: 001CB2400005BEA148438181A101A10081A100070700878700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU58.rod
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800130071940258087
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ800124081911470131
   Part No SW: 4N0 907 063 FE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0690
   Coding: 07500363E0691CCD070E57A81CEA9C2A131BB7111406009381000A000001160008690002001000000000070700470818180210304401F107000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: F6BE0D92983424EBCD7-80A2
   Subsystem 1 - Part No SW: 4N1 955 119     HW: 4N1 955 119
   Component: WWS651 190426  052 0915
   Serial number: 904753F0301911601512
   Coding: 7DC767
   Serial number: 23520112X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 21S22.07.1900690156
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00GI02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE108051923610931
   Interior Light Module:
   Subsystem 6 - Part No SW: 4N0 947 135 CT    HW: 4N0 947 135 CT
   Component: Dachelektroni  H42 0063
   Serial number: 00000488420000000000
   Coding: 200000
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA138871000073140828
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BJ22188270
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ22177609
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ22188269
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ22177607
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 B    HW: 4N0 907 605
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001919101901
   Coding: 040000
   Interior Light Module 2:
   Subsystem 13 - Part No SW: 4N0 947 111 F    HW: 4N0 947 111 F
   Component: Dachelektroni  H42 0060
   Serial number: 00000493800000000000
   Part No SW: 4N0 907 561 G    HW: 4N0 907 561
   Component: LRR4          H04 0332
   Coding: D4659F5458082C00010360E1000000BE4A1246484481009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: B53CCA9EC5B26FF304D-80E0
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H12 2720
   Serial number: 003YUM00TSV5
   Coding: BFFCF0C080C00500A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: C4DAA75A9E68C67B833-8090
   Left seat belt tensioner:
   Serial number: 00AI2019208734900000
   Coding: 0A0301
   Right seat belt tensioner:
   Serial number: 00AI2019230167700000
   Coding: 0A0301
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000C1GRQ0M
   Coding: 303237
   Subsystem 4 - Part No SW: -----------    HW: 480 003 108 19
   Serial number: 3570000000020B448F3J
   Subsystem 5 - Part No SW: -----------    HW: 480 003 108 19
   Serial number: 35800000000C9B54EF33
   Subsystem 6 - Part No SW: -----------    HW: 480 032 408 19
   Serial number: 351001C2454118309D1U
   Subsystem 7 - Part No SW: -----------    HW: 480 032 408 19
   Serial number: 352001C2454BD990587E
   Subsystem 8 - Part No SW: -----------    HW: 480 032 708 19
   Serial number: 355001C2452459405EF9
   Subsystem 9 - Part No SW: -----------    HW: 480 032 708 19
   Serial number: 356001C24CDCDA312F5X
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 208 19
   Component: CentrSensorXY  004 0148
   Serial number: I0O0001122C9CA6683C/
   Part No SW: 4N0 907 129 N    HW: 4N0 907 129 N
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: BC2ADFBAE698BEBBFB3-80E8
   Part No SW: 4N0 920 890 C    HW: 4N0 920 890 C
   Component: FBenUSAACC--- H12 0210
   Coding: 8BC600C17C88D7050285E16098804B0008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: B134FE8E31DA43D3585-80E4
   Part No SW: 4K0 907 468 L    HW: 4K0 907 468 C
   Component: Gateway       H05 0262
   Serial number: 1YF04079541601
   Coding: 020100050004064054960000005B0132DC98004018000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   Subsystem 1 - Part No SW: 4N0 951 523 K    HW: 4N0 951 523 K
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 A    HW: 4N0 915 181 A
   Serial number: 75885403001907190451
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: B032FB8A3AD04ADB57B-80E4
   Serial number: 00000387206700
   Coding: 001C9A400005BEA1480301012101210081A100070700878700000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU38.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800130071940258086
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ800124081911470130
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: BB28DCA6E396B983F29-80EE
   Part No SW: 4M1 959 953 D    HW: 4M1 959 953 C
   Component: TSG FS005 0189
   Serial number: YE007SFM19974
   Coding: 001DDB00520014C2B009A036
   VCID: BE2ED5B2F084ACABD57-80EA
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: B236F18234DC78CB21F-80E6
   Part No SW: 4N0 907 064 DG    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H15 0183
   Coding: 013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0101010011
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   VCID: F7A000969F3E5DE3D61-80A2
   ID - sensor:
   Serial number: 000000000ZY191902H0W
   Serial number: 00000000000047542097
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11929415
   Rear spoiler control module:
   Part No SW: 4M1 959 952 D    HW: 4M1 959 952 C
   Component: TSG BFS005 0189
   Serial number: YE007SFM25176
   Coding: 001DDB005E0014C2B009A034
   Part No SW: 4K0 035 084 D    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   054 2711
   Coding: 0156010200000000C1220002061C00302F0001E403F008048E
   VCID: A70010D60F1E0D63861-80F2
   Subsystem 1 - Part No: V03 959 804 CA
   Component: MIB2P_NA_Q218  0296
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4N0 919 605 G    HW: 4N0 919 605 C
   Component: DU AU651 Top  H43 0147
   Serial number: INX00114051900040356
   Compact disc data bank:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004419000087619019
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 C    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0147
   Serial number: INX00105061900050479
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900449809006
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 D    HW: 4N0 915 105 D
   Component: BMS_48V_LiIon H09 0206
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: AB08ECE613F62903629-80FE
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 8W5 959 107 D    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8791-2
   Coding: 1430
   VCID: C7C0B056AF5EED63661-8092
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4N0 907 777 AQ    HW: 4N0 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1808190673
   Coding: 105C583BF852
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 8944766EF9CA5B13B05-80DC
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130708657
   Coding: 303030
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120696
   Coding: 01C020FF4040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: A80213EA0200021B8FB-80FC
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 19070453566766
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4N1 919 617 B    HW: 4N1 919 617 B
   Component: HeadupDisplay H14 4910
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: B63ECD92D8B464EB0D7-80E2
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 020184000000000000FFD60000B0450C131F560000000000000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000072040080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001006
   ROD: EV_ZFASAU516_001.rod
   VCID: 8F70587687AE75236E1-80DA
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS004 0189
   Serial number: YE007SGL0353A
   Coding: 000DDB00000014C2E008A024
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: C2D6A142847CC84BB1F-8096
   Component: TSG HBFS004 0189
   Serial number: YE007SGL03844
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19307000503
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: F5BC0A9E85322FF3C4D-80A0
   Coding: 269050065113
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 7PP 941 571 AC    HW: 7PP 941 571 A
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 967E2D12B87484EB2D7-80C2
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 H    HW: 4N0 907 669 A
   Component: MRR_VR H16 0267
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
   VCID: BFD0A8B6F78EA5A3DE1-80EA
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H16 0267
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Coding: 229010065114
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_009_AU58.rod
End----------(Elapsed Time: 02:30, VBatt start/end: 14.3V/12.9V)-----------
blockmap-01-4N0-906-014-C_WAU8EAF82LN004143-20201024-1510.CSV
;Component:V8 4.0l TFSI  H31 0001, Coding:0A2A0012256E010E34286000000400000000000000000000
;EV_ECM40TFS0114N0906014C,001001,EV_ECM40TFS0114N0906014C.rod
;Saturday,24,October,2020,15:10:53:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: A90416EE190A3B13905-80FC
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WAU8EAF82LN004143,
IDE00019,Voltage terminal 30,14.180, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,748, /min
IDE00025,Coolant temperature,75, °C
IDE00078,Time since engine start,234, s
IDE00083,Throttle valve position (absolute),13.3, %
IDE00084,Absolute load value,22, %
IDE00085,Normed load value,8.6, %
IDE00086,Accelerator pedal position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,71.0, Nm
IDE00102,Control Module temperature,39.0, °C
IDE00148,Mean injection time,0.7304, ms
IDE00150,Pressure in brake servo unit,65.00, hPa
IDE00151,Oil fill level,78.176, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00159,Ignition timing angle retard cylinder 5,0.0, °
IDE00160,Ignition timing angle retard cylinder 6,0.0, °
IDE00161,Ignition timing angle retard cylinder 7,0.0, °
IDE00162,Ignition timing angle retard cylinder 8,0.0, °
IDE00167,Exhaust temperature 1 bank 1,436.5, °C
IDE00168,Exhaust temperature 1 bank 2,436.5, °C
IDE00172,A/C compressor torque,25.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-22.00, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-22.06, °
IDE00176,Camshaft adjustment: exhaust: bank 2: specified value,-22.00, °
IDE00177,Camshaft adjustment: exhaust: bank 2: actual value,-22.13, °
IDE00178,Camshaft adjustment intake bank 1: specified value,28.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,28.03, °
IDE00180,Camshaft adjustment intake bank 2: specified value,28.00, °
IDE00181,Camshaft adjustment intake bank 2: actual value,27.94, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00183,Camshaft adaptation intake bank 2: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00185,Camshaft adaptation exhaust bank 2: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,398.6, kPa
IDE00187,Coolant temperature at engine start,21.6, °C
IDE00188,Fuel high-pressure: actual value,7.0720, MPa
IDE00190,Charge air pressure: specified value,328.05, hPa
IDE00191,Charge air pressure: actual value,979.69, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,22.8, °C
IDE00194,Coolant temperature at radiator output: specified value,105.0, °C
IDE00196,Engine oil temperature,48.2, °C
IDE00201,High fuel pressure: specified value,6.9760, MPa
IDE00202,Low fuel pressure: specified value,400.0, kPa
IDE00304,Fuel level,5.00, l
IDE00350,Air mass: specified value,20.6, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00356-ENG57549,Cruise Control System (CCS): switch position-Bits 0-7,0,
IDE00357,Fuel temperature,51.0, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,981.52, hPa
IDE00371,Fuel consumption,1.62, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,42.96, %
IDE00381,Coolant fan 2: activation,47.65, %
IDE00392,Accelerator pedal: sensor voltage 1,749.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,374.0, mV
IDE00394,Camshaft position: start of phase window,120.34, °
IDE00395,Camshaft position: end of phase window,152.18, °
IDE00405,Crankshaft speed (RPM),752.0, /min
IDE00406,Camshaft RPM,377.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00408-ENG57549,Engine mount 1-Bits 0-7,1,
IDE00409-ENG57549,Engine mount 2-Bits 0-7,1,
IDE00410-ENG57549,Transmission mount 1-Bits 0-7,1,
IDE00411-ENG57549,Transmission mount 2-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00432,Particle filter: time since last regeneration,8.171, H
IDE00434,Particle filter: soot mass calculated,0, mg
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,11.2, Nm
IDE00496-ENG57549,Oil pressure switch valve activation-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,23, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.995 Lambda / -0.027 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.540, V
IDE00565,Current of oxygen sensor bank 2 sensor 1 (broadband sensor),0.992 Lambda / -0.031 mA,
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.545, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00584,Distance driven since erasing DTC memory,35, km
IDE00588,Fuel tank fill level,5.9, %
IDE00592,Status of oxygen sensor control,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,2.0, Degrees
IDE00595,Allocation of oxygen sensors,B1S1 B1S2   / B2S1 B2S2  ,
IDE00597,Long term adaptation of mixture formation bank 1,-7.0, %
IDE00598,Long-term adaptation of mixture formation: B2,-5.5, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,2,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00605,Short term adaptation of mixture formation bank 2,0.8, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,28.2, %
IDE00643,Minimum torque of electric machine,-165.1, Nm
IDE00644,Maximum torque of electric machine,125.8, Nm
IDE00657,Hybrid battery voltage,1023.97, V
IDE00738,Oxygen sensor test: bank 1: delta lambda,-0.00006,
IDE00739,Oxygen sensor test: bank 2: delta lambda,-0.00003,
IDE00752,Oxygen sensor control test,Test off,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside temperature,23.5, °C
IDE01028,Air temperature of H-V / hybrid battery,3003.6, °C
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator performance,0, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,3,
IDE01267,Height correction,0.96887,
IDE01378,Fuel high pressure: control deviation,0.0080, MPa
IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Starter activation: status-Bits 0-7,2,
IDE01407,Particle filter: fuel consumption since last regeneration,39.675, l
IDE01590,brake status,operated,
IDE01590-ENG127367,brake status-Test_Program_Channel 600,193,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.548, V
IDE01645,O2 sensor B2 voltage behind CAT,0.549, V
IDE01647,Result: O2 Sensor Aging Test B2 Downstream CAT,Test off,
IDE01647-ENG129417,Result: O2 Sensor Aging Test B2 Downstream CAT-Test_Program_Channel 379,235,
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test on,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,234,
IDE01666,Result of test of camshaft adjustment intake bank 2,Test on,
IDE01666-ENG129412,Result of test of camshaft adjustment intake bank 2-Test_Program_Channel 105,234,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test on,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,234,
IDE01668,Result of test of camshaft adjustment outlet bank 2,Test on,
IDE01668-ENG129419,Result of test of camshaft adjustment outlet bank 2-Test_Program_Channel 620,234,
IDE01678,O2 sensor test readiness downstream CAT: B2: result,Test off,
IDE01678-ENG129413,O2 sensor test readiness downstream CAT: B2: result-Test_Program_Channel 114,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01834,Battery voltage,14200, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.84, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,4.3115,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,16.8, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,1,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4170.0, mV
IDE01884,Camshaft adjustment intake bank 1: activation,36.923, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Fuel pump adaptation,59.8, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,23.557, %
IDE01899,Load value: corrected specified value,171.19, %
IDE01900,Charge press. ctrl.: spec. value,0.4, %
IDE01901,Lost torque adaptation: idle,10.6, Nm
IDE01902,Lost torque adaptation A/C compressor,16.9, Nm
IDE01903,Lost torque adaptation driving mode,15.8, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,28.6, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.93622,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.92291,
IDE01911,Leakage air,6.6, kg/h
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,122, km
IDE01923,Control module distance driven,121385, m
IDE01928,Close cam shaft angle at quantity control valve,27.5, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,0.000, MPa
IDE01932,High pressure pump injection volume,1.22, mm³
IDE01975,Numb.of misfir.: cylinder 1,44,
IDE01976,Numb.of misfir.: cylinder 2,139,
IDE01977,Numb.of misfir.: cylinder 3,36,
IDE01978,Numb.of misfir.: cylinder 4,135,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,222,
IDE02117,Relative load value,19.88, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,2.64, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,283.6, kPa
IDE02756,Number of manual engine starts,100,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,9.89, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,17,
IDE03010-MAS01627,Number of prevented stop processes-Steering,45,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,3,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,62,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,39,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,26,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,10,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,2,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,5,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,32770, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.520, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.484, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.959, V
IDE03279,Charge air pressure 2: actual value,979.69, hPa
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,47,
IDE03364,Numb.of misfir.: cylinder 6,94,
IDE03365,Numb.of misfir.: cylinder 7,85,
IDE03366,Numb.of misfir.: cylinder 8,24,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3457.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,At least one release missing,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.182, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,255,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,225,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.27, °
IDE03711,Mass flow through throttle valve,20.1, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03771,Turbocharger speed sensor 2,0, /min
IDE03794,Long-term fuel trim bank 2 at idle,-0.94, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,35.641, %
IDE03796,Camshaft adjustment: exhaust: bank 2: activation,35.834, %
IDE03797,Camshaft adjustment intake bank 2: activation,35.577, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,O2 Sensor B1-S2: Status-Bits 0-7,4,
IDE03808-ENG57549,Oxygen sensor bank 2 sensor 1: status-Bits 0-7,7,
IDE03809-ENG57549,Oxygen sensor bank 2 sensor 2: status-Bits 0-7,4,
IDE03810,Oxygen sensor B2: sensor 2: specified value,1.0000,
IDE03811,Test of oxygen sensors bank 2: Delta-Lambda: result,Test off,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
IDE03816,Exhaust flap bank 1,OFF,
IDE03816-ENG129421,Exhaust flap bank 1-Test_Program_Channel 825,136,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,59572.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.3, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,31.821, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,67696.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03823,O2 sensor heater B2-S2: activation,Htg.aC.OFF,
IDE03823-ENG127297,O2 sensor heater B2-S2: activation-Test_Program_Channel 123,217,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,147.7, Ohm
IDE03825,O2 sensor heater B2-S1: activation,30.945, %
IDE03826,Conversion test B2: measured value,4.0320,
IDE03827,Conversion test Bank 2: result,Test off,
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,235,
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03878,Misfires per 1000 revolutions of cylinder 7,0,
IDE03879,Misfires per 1000 revolutions of cylinder 8,0,
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.97598,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,1,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04000,Intake air temperature sensor,IAT 11/21:27/30, °C
IDE04002,Charge air pressure control,BP_A act:98 kPa / BP_B act:98 kPa,
IDE04003,Charge air temperature sensor,B1S1:24 °C / B2S1:26 °C,
IDE04010,Engine torque: normalized,10, %
IDE04011,Nominal torque,660, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:7100/7100 kPa,
IDE04085,Throttle valve,THR A cmd/rel:4/3 % / THR B cmd/rel:4/3 %,
IDE04101,Intake pressure,MAP_A:32.78 kPa abs / MAP_B:33.00 kPa abs,
IDE04110,Additional inputs and outputs,,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,0.0, mV
IDE04320,Throttle valve position 3,14, %
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04409,Intake manifold pressure: corrected,328.83, hPa
IDE04410,Intake manifold pressure: specified value,333.28, hPa
IDE04414,Cat conv temp: modeled,390, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,0,
IDE04629,AVS operating condition,1,
IDE04637,Engine temperature control actuator,0.00, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,11.3, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,68.5, Nm
IDE04693,Increasing desired torque intervention of ESP,-49545.2, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,924.45, hPa
IDE04872,Brake pedal value sensor: relative value filtered,399.99, %
IDE04873,Braking torque requested by driver,0.0, Nm
IDE04876-ENG57549,Charge map from e-machine/motor torque distribution-Bits 0-7,0,
IDE04882,Operating mode control expanded electrical driving,False result,
IDE04882-ENG127289,Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE,0,
IDE04885,Hybrid batt charge cond act val standardized,45.15, %
IDE04887,Powertrain target torque,66.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,15.9, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04913,Current speed of electric motor,719.0, /min
IDE04933,Number of fill level decreases,10,
IDE04934,Last odometer reading since fill level decrease,393210, km
IDE04935,Next to last odometer reading since fill level decrease,393210, km
IDE04936,3rd last mileage reading since fill level decrease,393210, km
IDE04956,Injection volume of high pressure pump 2,-2.92, mm³
IDE05127,Intake manifold pressure bank 2: corrected,326.88, hPa
IDE05128,Intake air temperature in intake manifold bank 1,24.8, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,326.33, hPa
IDE05141,Intake manifold pressure bank 2 raw value,328.67, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05215,EVAP valve diagnosis result correlation factor,0.00,
IDE05217,Hybrid battery charge current actual value,1023.97, A
IDE05219,Electric drive torque: actual value,-4.00, A
IDE05220,Electric drive voltage: actual value,47.00, V
IDE05221,Electric drive torque: actual value,-2.8, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05242,Phase angle adaptation request,0,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05327,Activation for electrical auxiliary coolant pump in HT circuit,0.00, %
IDE05330,Pulse-controlled inverter temperature: actual value,3003.6, °C
IDE05331,DC/DC converter temperature: actual value,-273.1, °C
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05334,Reset tire pressure monitoring display warnings,2.0, Nm
IDE05335,Electro-mechanical parking brake function test,0.0, Nm
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,3.0, °C
IDE05438,Rear cat conv temp main cat conv model value,398.0, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,398.4, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.0000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.0000,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0182, rad
IDE05444,Air filling: specified value,23.09, %
IDE05445,Pressure before throttle valve of pressure sensor,980.31, hPa
IDE05448,Long-term adaptat. of mixture form. bank 2 at partial load,0.99390,
IDE05449,O2 sensor 2: B1: internal resistance limit,2000, Ohm
IDE05450,O2 Sensor 2: B2: Internal Resistance Limit,2000, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00015,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00018,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.92, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,719.43, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05471,Cat converter oxygen storage capacity bank 2,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.23438,
IDE05475,Main cat converter OSC age correction factor bank 2,0.92969,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05477,Cat converter oxygen storage capacity bank 2 measured,0.0, mg
IDE05479,Misfire recognition reference moment,8.765, %
IDE05482,Tank venting adaptation factor,1.104,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,40.2, °C
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05761-ENG121419,Nominal operating condition: partial engine operation-Bhmbs,0,
IDE05762-ENG121418,Engine operating status partial engine operation-Bhmb,0,
IDE05797,Throttle valve adapter: specified value,5.820, %
IDE05928,Fuel consumption since DTC memory last erased,34.380, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,2.6578039, hPa
IDE05951,Charge pressure control adaptation value 2,3.4926093, hPa
IDE05952,Charge pressure control adaptation value 3,6.4007294, hPa
IDE05953,Charge pressure control adaptation value 4,1.0206854, hPa
IDE05954,Charge pressure control adaptation value 5,0.4254097, hPa
IDE05955,Charge pressure control adaptation value 6,1.6368949, hPa
IDE05956,Charge pressure control adaptation value 7,0.2164233, hPa
IDE05957,Charge pressure control adaptation value 8,0.0000000, hPa
IDE06014,Charge pressure control adaptation value 0,0.5598468, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,28.5, °C
IDE06021,Intake air temperature before throttle valve: raw value,24.9, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0160, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,76.8, °C
IDE06045-ENG57549,Output diagnostic test status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,57, hPa
IDE06056,Electric driving button status,0,
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06062,Throttle valve position 4,14.9, %
IDE06098,Sensor control factor: output value,1.01147,
IDE06112-ENG57549,Test of cylinder deactivation-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0280220, V*ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0146347, V*ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0382599, V*ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0213371, V*ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,160,
IDE06212,Fuel pressure rail 2,10.6660, MPa
IDE06213,Fuel pressure: target value: rail 2,10.6740, MPa
IDE06214,Throttle valve adapter bank 2: target value,5.727, %
IDE06255,Vehicle lateral acceleration,-0.01, g
IDE06256,Vehicle lateral acceleration: raw value,-0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,20,
IDE06307-MAS00109,Stop prevention history data-Hours,10,
IDE06307-MAS00110,Stop prevention history data-Minutes,28,
IDE06307-MAS00111,Stop prevention history data-Seconds,1,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Engine protection active,
IDE06308,Start request history data,CAT heating,
IDE06308,Start request history data,Restriction in start system,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,hood open,
IDE06308,Start request history data,Fuel gelling protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Auxiliary equipment power consumption too high,
IDE06308,Start request history data,Hybrid battery performance too low,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function prevention,
IDE06391,Oil temperature sensor 2,51.3, °C
IDE06392,Oil temperature sensor 2: raw value,2234.2, mV
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06552,Time since terminal 15 ON,349490, ms
IDE06567,Frequency counter deactivate start/stop function,0,
IDE06568,Stop prevention by driver frequency counter,95,
IDE06569,Frequency counter vehicle standstill,213,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,31.0, °C
IDE06610,Frequency counter vehicle standstill with stop,10,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,1,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,49,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06727,Timing deviation after chain replacement: intake bank 2,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.00, °
IDE06729,Timing deviation after chain replacement: exhaust bank 2,0.00, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06731,Timing deviation after other repairs: intake bank 2,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06733,Timing deviation after other repairs: exhaust bank 2,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06735,Timing deviation: current value intake bank 2,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06737,Timing deviation: current value exhaust bank 2,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,0,
IDE06739-ENG57549,Chain elongation: no. of valid initial values: intake bank 2-Bits 0-7,0,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,0,
IDE06741-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 2-Bits 0-7,0,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06743,Chain elongation: initial values valid: intake bank 2,not active,
IDE06743-ENG36870,Chain elongation: initial values valid: intake bank 2-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06745,Chain elongation: initial values valid: exhaust bank 2,not active,
IDE06745-ENG36870,Chain elongation: initial values valid: exhaust bank 2-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,3.3956, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,9.87, %
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,739.5, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06972,High-volt. battery: charge state: abs. value,327.67, %
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE06986,H-V battery charge current: maximum value,1023.97, A
IDE07001,Piston-cooling jets: activation,0,
IDE07002,Exhaust flap: activation,94.99, %
IDE07003,Exhaust flap bank 2: activation,94.99, %
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,124,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,133,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07068,Temperature sensor 2 for charge air cooler,30.7, °C
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07078,AVS result of last switch-over: intake,170,
IDE07079,AVS result of last switch-over: exhaust,170,
IDE07164,Number injections,16259,
IDE07165-ENG57549,Transmission Hybrid control: actual state-Bits 0-7,0,
IDE07170,Clutch K0: torque,3276.7, Nm
IDE07173-ENG57549,Electric drive motor: mode of operation-Bits 0-7,15,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07226-ENG57549,Operational state of the hybrid battery-Bits 0-7,7,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07241-ENG57549,Status transition of transmission control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,88.17, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07286,Electrically driven compressor: current,0, A
IDE07467,High pressure regulation rail 2: adaptation value,0.000, MPa
IDE07468,Fuel high pressure rail 2: regulator output value,-0.0640, MPa
IDE07469,Fuel high pressure rail 2: control deviation,0.0040, MPa
IDE07573,Throttle valve adapter: actual value,5.570, %
IDE07615,Operating of tank: empty or reserve,Too Small,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,91,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07660,Minimum permissible torque of e-machine,0.0, Nm
IDE07662,Minimum current permissible torque of e-machine,-165.1, Nm
IDE07663,Maximum current permissible torque of e-machine,131.4, Nm
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4170.0, mV
IDE07666,Spec. torque for electric drive: coordinated output signal,-25.5, Nm
IDE07667,Desired torque of regeneration,-64.4, Nm
IDE07716,Particulate filter input: temp. sensor 1: bank 1: raw value,-0.0, °C
IDE07718,Particulate filter output: temp. sensor 1: bank 1: raw value,-0.0, °C
IDE07724,Coolant temperature at engine outlet: calculated,64.2, °C
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,0.25, %
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,43.99, %
IDE07955,Throttle valve adapter bank 2: actual value,5.773, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08491,Intake air temperature 2 before throttle valve: raw value,26.1, °C
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09311-ENG57549,Pre-ignition counter cylinder 5-Bits 0-7,0,
IDE09312-ENG57549,Pre-ignition counter cylinder 6-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09317-ENG57549,Pre-ignition counter over serv.life cylinder 5-Bits 0-7,0,
IDE09318-ENG57549,Pre-ignition counter over serv.life cylinder 6-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,0,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,2,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,0,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09977,Control module temp.: max. value,67.7, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,1,
IDE10041,Intake camshaft B1 active operating state,1,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.0, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10063-ENG06679,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10064-ENG06679,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10065-ENG06679,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10066-ENG06679,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.0, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10067-ENG06679,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.0, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10068-ENG06679,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.0, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10069-ENG06679,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.0, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10070-ENG06679,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.0, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10071-ENG06679,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.0, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10072-ENG06679,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,0, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10122,Chain elongation outlet bank 2: mileage of the last adaptation,0, km
IDE10123,Chain elongation inlet bank 2: mileage of the last adaptation,0, km
IDE10302,Time since engine start,294.5, s
IDE10303,Integrated air masse at first engine start,3.4912, kg
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10580,Engine oil level: test method 1,100.0, %
IDE10581,Engine oil level: test method 2,119.7, %
IDE10582,Engine oil level: test method 3,106.3, %
IDE10630,O2 sensor befor CAT: delay time changeover rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE10671,Oxygen sensor before catalytic converter B. 2: filter const. transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,92, ml/mm
IDE10855-ENG57549,Pre-ignition counter over serv.life cylinder 8-Bits 0-7,0,
IDE10856-ENG57549,Pre-ignition counter over serv.life cylinder 7-Bits 0-7,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,hood open,
IDE10989,Immobilizer: historic data,Function locked due to frequent stalling,
IDE10994,Poor start counter at start-stop,0,
IDE11065-ENG57549,Accel. pedal pos. sensor 1-Bits 0-7,102,
IDE11065-ENG57549,Accel. pedal pos. sensor 1-Bits 0-7,2,
IDE11066-ENG57549,Accel. pedal pos. sensor 2-Bits 0-7,1,
IDE11066-ENG57549,Accel. pedal pos. sensor 2-Bits 0-7,51,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,1,
IDE11203,Oil pressure setpoint,281.9, kPa
IDE11267,Oil level: max. value: relative,-3276.8, %
IDE11268,Oil level: min. value: relative,3276.7, %
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,2.672, l
IDE11302-ENG57549,Engine oil level: test method 1 qualification-Bits 0-7,7,
IDE11303-ENG57549,Engine oil level: test method 3 qualification-Bits 0-7,1,
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,77,
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,3,
IDE11330,Oil press. control valve: activation pulse duty factor,53.49, %
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11492,Disengaging clutch actuator: spec. position,0.00000, mm
IDE11493,Disengaging clutch actuator: act. position,60.29220, mm
IDE11494-MAS03359,Disengaging clutch actuator: status-Text,Initialization,
IDE11495,Disengaging clutch actuator: current,-50.0, A
IDE11496,Disengaging clutch actuator: voltage,0.0, V
IDE11498,Decoupler actuator,-56.00, °C
IDE11499,Camshaft angle adaptation: inlet deviation: bank 2,0.000, °
IDE11531,Starter generator: number of restarts,0,
IDE11533,Starter generator: number of first starts,10,
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11568,Starter generator: status,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11929,I share of PID control of fully variable oil pump,4.56, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00006,
IDE12099-MAS10949,Decoupler actuator: manufacturers code: block A-Manufacturer code 1,0,
IDE12099-MAS10950,Decoupler actuator: manufacturers code: block A-Manufacturer code 2,0,
IDE12100-MAS10951,Decoupler actuator: manufacturers code: block B-Manufacturer code 3,0,
IDE12100-MAS10952,Decoupler actuator: manufacturers code: block B-Manufacturer code 4,0,
IDE12101,Decoupler actuator: actual torque,3276.7, Nm
IDE12104,Cylinder block coolant valve: pulse duty factor,0.00, %
IDE12106,Temperature sensor for cylinder block,-273.1, °C
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.000,
IDE12356-ENG57549,Pre-ignition counter cylinder 7-Bits 0-7,0,
IDE12357-ENG57549,Pre-ignition counter cylinder 8-Bits 0-7,0,
IDE12551,Camshaft adjustment intake bank 1: adaptation value,-1.21, °
IDE12663,Camshaft adjustment intake bank 2: adaptation value,-0.66, °
IDE12664,Camshaft adjustment outlet bank 1: adaptation value,2.26, °
IDE12665,Camshaft adjustment outlet bank 2: adaptation value,-1.76, °
IDE12688,Catalytic converter temperature bank 2: modeled,390, °C
IDE12748,Oil level: amount added MIN to MAX,2000, ml
IDE12765,Pressure: tank ventilation leads: bank 2,-576.17, hPa
IDE12766,Pressure: tank ventilation leads: bank 1,-542.58, hPa
IDE13010,Bank 1 tank breather system: adaptation factor,0.865,
IDE13011,Bank 2 tank breather system: adaptation factor,0.918,
IDE13012,Tank breather valve: activation duty factor,36.217, %
IDE13013,Bank 2 tank breather valve: activation duty factor,36.330, %
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,2500, mg
IDE13086,Particle filter: maximum soot build-up reached,3500, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.0000,
IDE13089,Particle filter: high soot accumulation ratio,3.0000,
IDE13090,Particle filter: maximum soot loading ratio reached,4.0000,
IDE13091,Particle filter: ash loading ratio,1.0000,
IDE13092,Particle filter: soot accumulation ratio,1.0000,
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2080,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13692,Starter generator: number of positioning operations,0,
IDE13693,Starter generator: engine control module condition state machine,Gen,
IDE13693-ENG39548,Starter generator: engine control module condition state machine-Test_Program_X Ex Chpd eiu Fhob Bys Cica nfrr6 sp UBYTE,4,
IDE13695,Starter generator: thermal load,28, %
IDE13696,Starter generator: actual mode 48V,1,
IDE13697,Starter generator: number of comfort stops,70,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13747,Tank venting system diagnosis: bench 2 results correlation factor,0.00,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14152,Oil level: maximum value: compensated,22.300, mm
IDE14153,Oil level: minimum value: compensated,54.828, mm
IDE14241,Exhaust flap bank 2: position feedback actual value,95.00, %
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14247,Exhaust flap: position feedback actual value,95.00, %
IDE14534,Knock control: error status,2147614720,
IDE15614,Time since first start of combustion engine,305350, ms
IDE80106,Analysis 106,00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 E6 03 B2 00 00 17 93 00 00 03 76 00 24 00 00 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,5.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,393.2, °C
MAS16067,Exhaust gas temperature at the probe before PreCat bank 2: model value,386.8, °C
MAS16074,Temperature in pre-cat bank 1: model value,431.3, °C
MAS16075,Temperature in pre-cat bank 2: model value,431.3, °C
MAS16088,Lambda driver request: specified value,15.9998,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.078,
MAS16098,Tank ventilation relative mixture proportion: actual value,1.97, %
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,Correct result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,Correct result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16537,Bank 2 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,392.73, °C
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,392.73, °C
MAS16713,Exh mss flw bef main cat conv bank 2 filtered,15.3, kg/h
MAS16836,Particle filter: pressure ration to new filter,0.2000,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17033,Radiator shutter 3: actual position,399.99, %
MAS17034,Radiator shutter 4: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.50,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,7.885, V
MAS17042,Heated oxygen sensor 2 bank 2: heat output normalized,0.50,
MAS17044,Heated oxygen sensor 2 bank 2: internal resistance,264, Ohm
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,300, Ohm
MAS17046,Heated oxygen sensor 2 Bank 2: target voltage adequate for rich conditions,0.000, V
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17048,Heated oxygen sensor 2 Bank 2: target voltage adequate for lean conditions,1.000, V
MAS17050,Heated oxygen sensor 1 bank 2: effective heater voltage,7.850, V
MAS17051,Heated oxygen sensor 1 bank 2: identified total time (lean -> rich),0.00, s
MAS17052,Heated oxygen sensor 1 Bank 2: adaptation value for dead time,0.00, s
MAS17054,Heated oxygen sensor 1 bank 2: identified total time (rich -> lean),0.00, s
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17057,Heated oxygen sensor 1 Bank 2: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17159,Activation radiator shutter 3: result,0.00, %
MAS17160,Activation radiator shutter 4: result,0.00, %
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG105012,Abo,0,
ENG105037,Acc Ped trq Des,39.0, Nm
ENG105054,Act Mod trq Clth,27.9, Nm
ENG119898,Actual_section_of_standard_test,0,
ENG105091,Afmim n,99.6, %
ENG105092,Afmim x,0.0, %
ENG105093,Afnmn,10200, /min
ENG105094,Afnmx,0, /min
ENG105095,AFS dm,29.0, kg/h
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,3.58, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,17.75, kg
ENG106228,Ambient air pressure,981, hPa
ENG106231,Ambient temperature,22.5, °C
ENG105192,APP r,0.00, %
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG105385,C Eng Us T t,23.1, °C
ENG101413,Calibration Identification,4N0014C 0001BVCB,
ENG99697,Calibration Verification Number,84 1D D0 6B,
ENG08772-ENG57549,Com cntr Bus Knk Out Tmr-Bits 0-7,0,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,255,
ENG106503,Coolant temperature at radiator outlet,22.5, °C
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG105761-ENG57549,DC_DC_transformer_mode_actual_state-Bits 0-7,7,
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,5,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,167,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,55,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,1,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,0,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-50000.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG112935,ElectricEnergyCoordinator_auxilary_systems_idle_speed_request,0.0, /min
ENG106110,ElectricEnergyCoordinator_electric_power_for_auxiliary_system_actual_value,352, W
ENG111593,Emachine_achievable_enginetorque_maximum_value,131.4, Nm
ENG112938,Emachine_achievable_enginetorque_quasistationary_maximum_value,131.4, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,-165.1, Nm
ENG112939,Emachine_achievable_generatortorque_quasistationary_maximum_value,-165.1, Nm
ENG115973,Engine Exhaust Flow Rate,30.6, kg/h
ENG20102,Engine Friction - Percent Torque,7.0, %
ENG112932,Engine_oil_temperature_measured_value,56.3, °C
ENG111034,Engine_temperature_modelbased_substitute_value,57.5, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG106223,Engine_torque_limitation_mechanical,3276.7, Nm
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,Correct result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,1,
ENG111568,EngineCoordinator_intervention_request_actual_value,No demand,
ENG111568-ENG36866,EngineCoordinator_intervention_request_actual_value-Test_Program_Co Eng Wp Dmd Req Set COMPU VERB UBYTE,0,
ENG111580,EngineCoordinator_Torque_commanded_value_Emachine,13.9, Nm
ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,55.00, °
ENG121110,Epm Ca S phi Adap Ref Pos O1 mp 1,87.91, °
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,8.000, l
ENG106677,Frm w,0.99826,
ENG106678,Frm2 w,0.99493,
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.50, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.50, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.34, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,0.00, %
ENG112931,Generator_load_from_CAN,0, W
ENG112929,Generator_torque_request,0.0, Nm
ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,0,
ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,0,
ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,0,
ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,0,
ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,0,
ENG121111-ENG57549,Glb Da Max Val 5-Bits 0-7,0,
ENG110577-ENG57549,Glb Da Min Val 0-Bits 0-7,0,
ENG121112-ENG57549,Glb Da Min Val 1-Bits 0-7,0,
ENG123647,Gsl Pfil dst Veh Cyc Rgn VW,121.704, km
ENG111600,HybridBattery_discharging_current_maximum_value,1023.97, A
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,29.2, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 03 00 78 00 03 00 03 00 03 00 03 00 02 00 03 00 02 00 03 00 17 00 03 00 00 00 00 00 04 00 01 00 01 00 03 00 01 00 03 00 02 00 03 00 02 00 03 00 00 00 00 00 00 00 00,
ENG107236,Knock_sensor_cylinder_5_voltage,0.0162605, V*ms
ENG107237,Knock_sensor_cylinder_6_voltage,0.0235489, V*ms
ENG107238,Knock_sensor_cylinder_7_voltage,0.0210464, V*ms
ENG107239,Knock_sensor_cylinder_8_voltage,0.0203957, V*ms
ENG121113,Kvakb i w,16996, µl
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Front Axle Lift System,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Motor,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor for drivers assistant systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel drive electronics,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,12 volt vehicle electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Air Conditioning,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2020,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,10,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,20,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,10,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,29,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,0,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,Motor,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,7,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,16,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,13,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,0,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,41,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,brakes,
ENG111606,Load value: unrestricted commanded value,25.78, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG107621,Milso l w,10.469, %
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-63.1, Nm
ENG111574,Mode_control_enabling_reserved_torque_combustion_engine,False result,
ENG111574-ENG127289,Mode_control_enabling_reserved_torque_combustion_engine-Test_Program_B TRUE UBYTE,0,
ENG111573,Mode_control_enabling_target_torque_combustion_engine,0,
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111570,Mode_control_request_overrun_fuel_cutoff,Correct result,
ENG111570-ENG127289,Mode_control_request_overrun_fuel_cutoff-Test_Program_B TRUE UBYTE,1,
ENG111572,Mode_control_sport_mode_activated,False result,
ENG111572-ENG127289,Mode_control_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG107662-ENG57549,Mode_control_start_mode_commanded_value-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,-5.6, Nm
ENG107664,Mode_control_torque_for_Emaschine_quasistationary_lower_limit,-165.0, Nm
ENG107665,Mode_control_torque_for_Emaschine_quasistationary_upper_limit,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00137,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108178,Pbksi a w,-58.8, kPa
ENG108262,Powertrain_overall_gear_ratio,15.12,
ENG111605,Pressure_before_throttle_valve_actual_value,980.31, hPa
ENG108333,Psini w,980.47, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG27083,Rba Io Sig Rtc st Diag Stop Count er,96,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,12.5, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,8.6, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG26207,Tasrg 2 w,31.14, °C
ENG109344,Tasrg w,29.05, °C
ENG109625,Temperature at air conditioner heat exchanger output,95.0, °C
ENG08688,Thr Vlv u Sens1 B1,0.737, V
ENG27182,Thr Vlv u Sens1 B2,0.741, V
ENG08689,Thr Vlv u Sens2 B1,4.268, V
ENG27183,Thr Vlv u Sens2 B2,4.258, V
ENG01775,Top_speed_limitation,200.000, km/h
ENG109532,Torque_distribution_Emachine_torque_commanded_value_stationary_distribution,-25.5, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,2.5, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,255,
ENG109626,TS t Clnt Eng Out,63.0, °C
ENG109653,Tumg,21.8, °C
ENG111604,Turbocharger_inlet_pressure_corrected_value,391.02, hPa
ENG119911,UEGO r Lam S1 B1,0.9961,
ENG27251,UEGO r Lam S1 B2,1.0100,
ENG115976,Vehicle Odometer,122.5, km
ENG109861,Vehicle speed,0.00, km/h
ENG01774,Velocity_limiter_setpoint,511.000, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,181, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,261714, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8438286, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,65445, s
Elapsed Time: 01:33
blockmap-02-4N0-927-158-K_WAU8EAF82LN004143-20201024-1512.CSV
;Component:0D6  40TSINAR H05 1001, Coding:100000
;EV_TCMALX52011,002015,EV_TCMALX52011_VW53.rod
;Saturday,24,October,2020,15:12:29:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: BD2CD2BEFD82B7B3CCD-80E8
Group,Description,Actual
IDE00001-ENG07549,Production mode-Adaption Stategy Mode,not active,
IDE00001,Production mode,not active,
IDE00018,Voltage terminal 15,14.2, V
IDE00019,Voltage terminal 30,14.185, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,755, /min
IDE00022,Transmission input speed,678.00, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024,ATF temperature,28, °C
IDE00025,Coolant temperature,63, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00026,Vehicle speed from transmission,valid,
IDE00027-MAS00179,Status of brake signals-Brake lamp switch,operated,
IDE00027-MAS00180,Status of brake signals-Brake pressure switch,operated,
IDE00027-MAS00181,Status of brake signals-Validity of brake pressure information,valid,
IDE00027-MAS00182,Status of brake signals-Validity of brake pedal information,valid,
IDE00028,Driving resistance index,-2,
IDE00031,Torque transmitting function,valid,
IDE00031,Torque transmitting function,15.1,
IDE00085,Normed load value,11.4, %
IDE00086,Accelerator pedal position,15, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00088-MAS00120,Status of vehicle condition influence-Traction control system,not active,
IDE00088-MAS00121,Status of vehicle condition influence-Electronic Differential Lock,not active,
IDE00088-MAS00122,Status of vehicle condition influence-Electronic Stability Program,not active,
IDE00088-MAS00123,Status of vehicle condition influence-Engine torque towing regulation,not active,
IDE00088-MAS00125,Status of vehicle condition influence-Cruise control system,passive,
IDE00088-MAS00126,Status of vehicle condition influence-Kickdown,not active,
IDE00088-MAS00127,Status of vehicle condition influence-brakes,active,
IDE00089,Driving position,P,
IDE00090,selected gear,without traction,
IDE00091,Status of starter lock,OFF,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,not active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00099-MAS00172,Driving mode sensor-Hall sensor A,not active,
IDE00099-MAS00173,Driving mode sensor-Hall sensor B,not active,
IDE00099-MAS00174,Driving mode sensor-Hall sensor C,active,
IDE00099-MAS00175,Driving mode sensor-Hall sensor D,not active,
IDE00100,Engine torque,0, Nm
IDE00101,Engine specified torque during transmission intervention,-3, Nm
IDE00102,Control Module temperature,26, °C
IDE00138,Total driving time,0.00, H
IDE00139,Economical driving time portion,0.0, %
IDE00140,Sport driving time portion,0.0, %
IDE00141,Manual driving time portion,0.0, %
IDE00540,Dynamic shift program,0,
IDE00541,Acceleration,0.0, 1/s²
IDE00542,Excessive temperature protection,0,
IDE00543,Deceleration mode / acceleration mode,Coasting,
IDE00544,Factor torque,Factor 2,
IDE00545,maximum permissible engine torque,720, Nm
IDE00546,Voltage supply of regulator valves,14.128, V
IDE00547,Torque converter amplification,1.00,
IDE00548,Converter clutch slip,0, /min
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00820,Activating and deactivating all development messages,not active,
IDE00915-MAS01185,Ambient conditions at heat shut-off-Status of temperature sensors,0,
IDE00915-MAS01186,Ambient conditions at heat shut-off-Shut-off temperature,145, °C
IDE00915-MAS02194,Ambient conditions at heat shut-off-Temperature 1,26, °C
IDE00915-MAS02195,Ambient conditions at heat shut-off-Temperature 2,28, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00920,Front left wheel speed,valid,
IDE00921,Wheel speed: right front,valid,
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00922,Left rear wheel speed,valid,
IDE00923,Right rear wheel speed,valid,
IDE00923,Right rear wheel speed,0.0, km/h
IDE01761,Route data,active,
IDE02583,Steering wheel Tiptronic switch,active,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Oil temperature too high,not active,
IDE03008-MAS03913,Stop process prevented-Adaptation procedure active,not active,
IDE03008-MAS03914,Stop process prevented-Pressure reservoir filling not completed,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not engaged,not active,
IDE03008-MAS14667,Stop process prevented-Clutch temperature load too high,not active,
IDE03008-MAS16362,Stop process prevented-Hydraulic oil: pressure supply not ensured,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,0,
IDE03010-MAS03912,Number of prevented stop processes-Oil temperature too high,0,
IDE03010-MAS03913,Number of prevented stop processes-Adaptation procedure active,0,
IDE03010-MAS03914,Number of prevented stop processes-Pressure reservoir filling not completed,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not engaged,0,
IDE03010-MAS14667,Number of prevented stop processes-Clutch temperature load too high,0,
IDE03010-MAS16362,Number of prevented stop processes-Hydraulic oil: pressure supply not ensured,0,
IDE03011-MAS03917,Number of requested start processes-Driver's request,0,
IDE03011-MAS06834,Number of requested start processes-Vehicle speed too high,0,
IDE03011-MAS11378,Number of requested start processes-Transmission fluid auxiliary hydraulic pump malfunction,0,
IDE03011-MAS20811,Number of requested start processes-Plausibility check of clutches faulty,0,
IDE04111,Individual gear display,D on/S on,
IDE04347-MAS07468,Expanded freeze frame conditions-selected gear,P,
IDE04347-MAS07469,Expanded freeze frame conditions-Target gear,P,
IDE04347-ENG102069,Expanded freeze frame conditions-Accelerator Pedal Position D,15.2, %
IDE04347-ENG28428,Expanded freeze frame conditions-ASR,not active,
IDE04347-ENG99470,Expanded freeze frame conditions-Automatic transmission input speed,0.00, /min
IDE04347-ENG100451,Expanded freeze frame conditions-Automatic transmission output speed,0.00, /min
IDE04347-ENG101851,Expanded freeze frame conditions-Automatic Transmission shift position,P,
IDE04347-ENG101095,Expanded freeze frame conditions-B008_Average Wheel Speed / Drive Shaft,0, km/h
IDE04347-ENG28285,Expanded freeze frame conditions-Brake,not active,
IDE04347-ENG101831,Expanded freeze frame conditions-C0010_Current Regulator No. 9,0.0, mA
IDE04347-ENG101867,Expanded freeze frame conditions-C009_Current Regulator No. 8,0.0, mA
IDE04347-ENG103259,Expanded freeze frame conditions-Calculated engine preset torque,-2, Nm
IDE04347-ENG103274,Expanded freeze frame conditions-CCS,not active,
IDE04347-ENG102274,Expanded freeze frame conditions-Control Module Voltage,13.076, V
IDE04347-ENG101834,Expanded freeze frame conditions-Current N215 Pressure control valve 1,0.0, mA
IDE04347-ENG99930,Expanded freeze frame conditions-Current N216 pressure reg.valve 2,0.0, mA
IDE04347-ENG102208,Expanded freeze frame conditions-Current N217 pressure reg.valve 3,0.0, mA
IDE04347-ENG100408,Expanded freeze frame conditions-Current N218 pressure reg.valve 4,0.0, mA
IDE04347-ENG101543,Expanded freeze frame conditions-Current N233 pressure reg.valve 5,0.0, mA
IDE04347-ENG101463,Expanded freeze frame conditions-Current N371 pressure reg. valve 6 lock-up clutch,0.0, mA
IDE04347-ENG101716,Expanded freeze frame conditions-Current N443 pressure reg.valve 7 main pressure,0.0, mA
IDE04347-ENG102805,Expanded freeze frame conditions-Current solenoid,0.0, mA
IDE04347-ENG98504,Expanded freeze frame conditions-Day,7,
IDE04347-ENG102053,Expanded freeze frame conditions-Desired State Solenoid Out 10,OFF,
IDE04347-ENG104161,Expanded freeze frame conditions-Desired State Solenoid Out 11,OFF,
IDE04347-ENG99231,Expanded freeze frame conditions-Desired State Solenoid Out 12,OFF,
IDE04347-ENG99490,Expanded freeze frame conditions-Desired State Solenoid Out 13,On,
IDE04347-ENG100651,Expanded freeze frame conditions-Desired State Solenoid Out 14,OFF,
IDE04347-ENG99228,Expanded freeze frame conditions-Diagnostic Fault Check Code,00 00 8A 5F,
IDE04347-ENG28372,Expanded freeze frame conditions-EDL,not active,
IDE04347-ENG99543,Expanded freeze frame conditions-Engine RPM,0, /min
IDE04347-ENG98585,Expanded freeze frame conditions-Engine torque,0, Nm
IDE04347-ENG98546,Expanded freeze frame conditions-ESP,not active,
IDE04347-ENG102638,Expanded freeze frame conditions-F012_State_TCM_Torque_Engagement,no requirement,
IDE04347-ENG103123,Expanded freeze frame conditions-F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
IDE04347-ENG07546,Expanded freeze frame conditions-F018_Maximum_allowed_Engine_Torque,720, Nm
IDE04347-ENG101750,Expanded freeze frame conditions-G001_TCM Chip Temperature,29, °C
IDE04347-ENG28249,Expanded freeze frame conditions-Hallsensor A,not active,
IDE04347-ENG28250,Expanded freeze frame conditions-Hallsensor B,not active,
IDE04347-ENG28253,Expanded freeze frame conditions-Hallsensor C,active,
IDE04347-ENG28251,Expanded freeze frame conditions-Hallsensor D,not active,
IDE04347-ENG98653,Expanded freeze frame conditions-Hour,13,
IDE04347-ENG99396,Expanded freeze frame conditions-internal error code,171,
IDE04347-ENG99127,Expanded freeze frame conditions-internal error type,0,
IDE04347-ENG28254,Expanded freeze frame conditions-Kickdown,not active,
IDE04347-ENG102357,Expanded freeze frame conditions-M014_Time Since Shift,7650, ms
IDE04347-ENG103371,Expanded freeze frame conditions-M015_Time Normal Mode,672, s
IDE04347-ENG100237,Expanded freeze frame conditions-M018_Time In Afterrun,0, s
IDE04347-ENG104072,Expanded freeze frame conditions-M019_Time Since Reset,7650, ms
IDE04347-ENG103130,Expanded freeze frame conditions-M021_KM Mileage,86,
IDE04347-ENG98739,Expanded freeze frame conditions-Minute,15,
IDE04347-ENG98748,Expanded freeze frame conditions-Month,8,
IDE04347-ENG28445,Expanded freeze frame conditions-MSR,not active,
IDE04347-ENG103297,Expanded freeze frame conditions-OK Byte - Snapshot valid,invalid,
IDE04347-ENG102101,Expanded freeze frame conditions-PIN In0,low,
IDE04347-ENG100393,Expanded freeze frame conditions-PIN In1,low,
IDE04347-ENG101177,Expanded freeze frame conditions-PIN In2,low,
IDE04347-ENG103794,Expanded freeze frame conditions-PIN In3,low,
IDE04347-ENG99856,Expanded freeze frame conditions-PIN KL15,high,
IDE04347-ENG98884,Expanded freeze frame conditions-Seconds,53,
IDE04347-ENG98903,Expanded freeze frame conditions-selected gear,without traction,
IDE04347-ENG102114,Expanded freeze frame conditions-State ATF Temperature Sensor,OK,
IDE04347-ENG104115,Expanded freeze frame conditions-State Brake Signal,OK,
IDE04347-ENG100649,Expanded freeze frame conditions-State Chip Temperature Sensor,OK,
IDE04347-ENG103681,Expanded freeze frame conditions-State Driving Direction,OK,
IDE04347-ENG103922,Expanded freeze frame conditions-State Engine Speed,OK,
IDE04347-ENG99717,Expanded freeze frame conditions-State Output Shaft Speed,OK,
IDE04347-ENG101631,Expanded freeze frame conditions-State Pedal,OK,
IDE04347-ENG101699,Expanded freeze frame conditions-State Plausibility Tolerance,narrow,
IDE04347-ENG100193,Expanded freeze frame conditions-State Position Switch,OK,
IDE04347-ENG100953,Expanded freeze frame conditions-State Torque 1,OK,
IDE04347-ENG102844,Expanded freeze frame conditions-State Turbin Speed,OK,
IDE04347-ENG100622,Expanded freeze frame conditions-State Wheel Speed Front Left,OK,
IDE04347-ENG103645,Expanded freeze frame conditions-State Wheel Speed Front Right,OK,
IDE04347-ENG103415,Expanded freeze frame conditions-State Wheel Speed Rear Left,OK,
IDE04347-ENG100555,Expanded freeze frame conditions-State Wheel Speed Rear Right,OK,
IDE04347-ENG07547,Expanded freeze frame conditions-Status Lock up Clutch,Open,
IDE04347-ENG101226,Expanded freeze frame conditions-Status Terminal 15,On,
IDE04347-ENG28407,Expanded freeze frame conditions-Tiptronic Manual Position,not active,
IDE04347-ENG28364,Expanded freeze frame conditions-Tiptronic Minus,not active,
IDE04347-ENG28283,Expanded freeze frame conditions-Tiptronic Plus,not active,
IDE04347-ENG28470,Expanded freeze frame conditions-Tiptronik Paddle Minus,not active,
IDE04347-ENG28431,Expanded freeze frame conditions-Tiptronik Paddle Plus,not active,
IDE04347-ENG98981,Expanded freeze frame conditions-Transmission fluid temperature,31, °C
IDE04347-ENG99034,Expanded freeze frame conditions-Voltage terminal 15,12.9, V
IDE04347-ENG99063,Expanded freeze frame conditions-Year,2020,
IDE04814,Transmission oil cooler valve,closed,
IDE05965,Driving time slice efficient,0.0, %
IDE06086-ENG117324,Launch control counter-upshift 1-2,0,
IDE06086-ENG117322,Launch control counter-upshift 2-3,0,
IDE06086-ENG117328,Launch control counter-upshift 3-4,0,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Pressure reservoir filling not completed,
IDE06307,Stop prevention history data,Hydraulic oil: pressure supply not ensured,
IDE06307,Stop prevention history data,Oil temperature too low,
IDE06307,Stop prevention history data,Gear 1 or 2 not engaged,
IDE06307,Stop prevention history data,Adaptation procedure active,
IDE06307,Stop prevention history data,Oil temperature too high,
IDE06307,Stop prevention history data,Clutch temperature load too high,
IDE06308,Start request history data,Vehicle speed too high,
IDE06308,Start request history data,Plausibility check of clutches faulty,
IDE06308,Start request history data,Transmission fluid auxiliary hydraulic pump malfunction,
IDE06308,Start request history data,Driver's request,
IDE06425,Dynamometer mode: functional,not activated,
IDE06425-ENG98891,Dynamometer mode: functional-Reserved,-1,
IDE06919,Torque converter clutch: status,Open,
IDE07063,Start/Stop Function present,activated by motor,
IDE07220,Fast adaptation: cancellation condition,Do not cancel,
IDE07437,Fill pressure: clutch A,-10, mbar
IDE07438,Adaptation counter: clutch A,0,
IDE07439,Fast fill time: clutch A,-4, ms
IDE07440,Adaptation counter: fast fill time: clutch A,1,
IDE07441,Fill pressure: clutch B,0, mbar
IDE07442,Adaptation counter: clutch B,0,
IDE07443,Fast fill time: clutch B,2, ms
IDE07444,Adaptation counter: fast fill time: clutch B,1,
IDE07445,Fill pressure: clutch C,120, mbar
IDE07446,Adaptation counter: clutch C,0,
IDE07447,Fast fill time: clutch C,2, ms
IDE07448,Adaptation counter: fast fill time: clutch C,1,
IDE07449,Fill pressure: clutch D,-100, mbar
IDE07450,Adaptation counter: clutch D,0,
IDE07451,Fast fill time: clutch D,10, ms
IDE07452,Adaptation counter: fast fill time: clutch D,1,
IDE07453,Fill pressure: clutch E,270, mbar
IDE07454,Adaptation counter: clutch E,2,
IDE07455,Fast fill time: clutch E,-14, ms
IDE07456,Adaptation counter: fast fill time: clutch E,2,
IDE07675,Clutch B: number of adaptations,0,
IDE07676,Fill pressure clutch B during park decoupling,0, mbar
IDE07677,Auto P counter,0,
IDE07678,N holding phase counter,19,
IDE07679,Counter engine off in P,135,
IDE07680,Counter insertion processes P,134,
IDE08728-MAS07468,Shift. process-selected gear,P,
IDE08728-MAS07469,Shift. process-Target gear,P,
IDE09396,Aux. hydraulic pump 1: actual RPM,0.00, /min
IDE10689,Auxiliary hydraulic pump for transmission oil: current,0.00, A
IDE11422-MAS01012,Sail function: activation preventions-Function not available.,No,
IDE11422-MAS02985,Sail function: activation preventions-Value,4294967295,
IDE11422-MAS07649,Sail function: activation preventions-Gas pedal depress.,No,
IDE11422-MAS07650,Sail function: activation preventions-Brake pedal depressed,No,
IDE11422-MAS12738,Sail function: activation preventions-Accel. pedal activated too quickly,No,
IDE11422-MAS12739,Sail function: activation preventions-Trailer hitched,No,
IDE11422-MAS12740,Sail function: activation preventions-Incline/decline excessive,No,
IDE11422-MAS12741,Sail function: activation preventions-Vehicle speed outside permitted range,No,
IDE11422-MAS12742,Sail function: activation preventions-Transmission adaption active,No,
IDE11422-MAS12743,Sail function: activation preventions-Transmission temp. outside permissible range,No,
IDE11422-MAS12744,Sail function: activation preventions-Exterior temperature outside permissible range,No,
IDE11422-MAS12745,Sail function: activation preventions-Event memory entry active,No,
IDE11422-MAS12746,Sail function: activation preventions-Coding of control module for automatic transmission incorrect,No,
IDE11422-MAS12747,Sail function: activation preventions-Engine drag torque control: ABS or ESC control active,No,
IDE11422-MAS12748,Sail function: activation preventions-Button for ASR and ESP activated,No,
IDE11422-MAS12749,Sail function: activation preventions-Activation prevented by engine control module,No,
IDE11422-MAS12750,Sail function: activation preventions-Activation prevented by battery energy management,No,
IDE11422-MAS12752,Sail function: activation preventions-Activation prevented by Climatronic control module,No,
IDE11422-MAS12753,Sail function: activation preventions-Activation prevented by ACC,No,
IDE11422-MAS12754,Sail function: activation preventions-Driving style insufficiently defined,No,
IDE11422-MAS12755,Sail function: activation preventions-Corner driving detected,No,
IDE11422-MAS12756,Sail function: activation preventions-Engine temperature too low/warm-up not finished,No,
IDE11422-MAS12757,Sail function: activation preventions-Deactivation by driver,No,
IDE11422-MAS12758,Sail function: activation preventions-Position of selector lever or drive program incorrect,No,
IDE11894-MAS01458,Auxiliary hydraulic pump transmission oil: operating point default-Operating condition,OFF,
IDE11894-MAS02985,Auxiliary hydraulic pump transmission oil: operating point default-Value,0,
IDE11914,Auxiliary hydraulic pump for transmission oil: supply voltage,14.40, V
IDE11915,Auxiliary hydraulic pump for transmission oil: internal temperature,23, °C
IDE12051-MAS01458,Auxiliary hydraulic pump trans.oil: feedback off operat.point-Operating condition,OFF,
IDE12051-MAS02985,Auxiliary hydraulic pump trans.oil: feedback off operat.point-Value,0,
ENG26447,2MC_communication_status,00,
ENG26448,2MC_reason_for_turning_high_side_switch_off,00 00,
ENG26449,2MC_transmission_output_speed,0, /min
ENG26450,2MC_transmission_output_speed_difference,0, /min
ENG26451,2MC_transmission_output_speed_status,0,
ENG07489,ADA_BFL_GLS_HS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG26460,ADA_BFL_GLS_K1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG26461,ADA_BFL_GLS_K2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07490,ADA_BFL_GLS_RS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07495,ADA_GA,00 00 00 00 00 00,
ENG07496,ADA_GA_CTR,00 00 00 00 00 00,
ENG07469,ADA_GE,00 36 00 00 00 00,
ENG07473,ADA_GLS_DRS_CTR_KF1,00 00 00 00 00 00 00 00 00 02 00 00,
ENG07481,ADA_GLS_DRS_KF1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00 00 00 00 00 03 03 00 00 00 00 00 00 00 00 00 FE FE 00 00 00 00 00 00 FE FE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07474,ADA_GLS_HS_CTR_KF1,00 31 00 38 00 31 00 2D 00 17 00 10 00 0F,
ENG07475,ADA_GLS_HS_CTR_KF1_KALT,00 22 00 31 00 26 00 25 00 17 00 10 00 0F,
ENG07476,ADA_GLS_HS_CTR_KF2,00 02 00 04 00 05 00 06 00 05 00 05 00 02,
ENG07477,ADA_GLS_HS_CTR_KF2_KALT,00 02 00 04 00 05 00 06 00 05 00 05 00 02,
ENG07482,ADA_GLS_HS_KF1,00 00 00 00 00 00 00 00 00 ED E7 FA 00 00 00 00 00 ED E0 FE 09 FE 00 00 00 00 F9 04 09 F9 FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 F8 FC 02 FB FD 00 00 00 F9 02 01 FC 09 05 00 00 01 02 FB 02 09 01 00 00 00 FC FC 01 FA F9 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 11 FD F9 FC 00 00 00 0E 0E FA F5 00 04 FF 00 FD FD FD FC 06 06 FF 00 00 FC FC 00 02 02 00 00 00 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 05 0E 08 00 00 00 04 03 02 0F 12 12 0C 00 04 04 F8 FC 0A 12 0C 00 00 00 FB FB 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC FB FF 00 00 00 00 00 F5 F4 F5 EF F6 FD 00 FD F6 F9 F6 EF F6 FD 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE 00 00 00 00 00 00 FE FD FF 00 00 00 00 00 FE FD 01 02 06 06 00 00 FE FE 02 02 06 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA FA 00 00 00 00 00 00 FA 05 05 FA 00 00 00 00 00 0B 05 FA 00 00 00 00 00 00 00 05 05 00 00 00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07483,ADA_GLS_HS_KF1_KALT,00 00 00 00 00 00 00 00 00 F1 EE FD 00 00 00 00 00 F1 ED 06 0A 00 00 00 00 00 FF 09 0A FB FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 F8 FC F4 E1 F1 00 00 00 F9 FD F4 DF F0 01 00 00 01 FD FC FE FF 01 00 00 00 FC FC 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 0D FB F5 FA 00 00 00 0A 0A F8 E6 F0 02 00 00 FD FD FD F1 F8 04 00 00 00 FC FC 00 02 02 00 00 00 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 02 07 04 00 00 00 04 03 F2 F6 FB FC 04 00 04 04 EB EA F7 FC 04 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC FB FF 00 00 00 00 00 F5 F4 F5 EF F6 FD 00 FD F6 F9 F6 EF F6 FD 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE 00 00 00 00 00 00 FE FD FF 00 00 00 00 00 FE FD 01 02 06 06 00 00 FE FE 02 02 06 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA FA 00 00 00 00 00 00 FA 05 05 FA 00 00 00 00 00 0B 05 FA 00 00 00 00 00 00 00 05 05 00 00 00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07484,ADA_GLS_HS_KF2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 F8 00 00 00 00 00 00 F8 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 F8 F8 00 02 02 00 00 00 F8 F8 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 FD FA FD 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 07 07 00 00 00 00 00 00 08 08 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA F5 FB 00 00 00 00 00 FA F5 FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 06 06 00 00 00 00 00 00 03 03 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00 00 00 00 00 03 03 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 08 00 00 00 00 00 00 08 08 03 03 00 00 00 00 00 00 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07485,ADA_GLS_HS_KF2_KALT,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 F8 00 00 00 00 00 00 F8 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 F8 F8 00 02 02 00 00 00 F8 F8 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 FD FA FD 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 07 07 00 00 00 00 00 00 08 08 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA F5 FB 00 00 00 00 00 FA F5 FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 06 06 00 00 00 00 00 00 03 03 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00 00 00 00 00 03 03 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 08 00 00 00 00 00 00 08 08 03 03 00 00 00 00 00 00 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07480,ADA_GLS_NRS_CTR_KF1,00 00 00 00 00 00 00 00 00 00,
ENG07488,ADA_GLS_NRS_KF1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07478,ADA_GLS_RS_CTR_KF1,00 01 00 01 00 03 00 03 00 04 00 0B 00 06,
ENG07479,ADA_GLS_RS_CTR_KF2,00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07486,ADA_GLS_RS_KF1,00 00 00 01 01 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 F7 00 00 00 00 00 00 F7 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F4 F4 00 00 00 00 00 00 F4 F4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F9 F9 00 00 00 00 00 00 F9 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 00 05 05 00 00 00 FF FF 00 05 0B 06 00 00 00 00 00 00 06 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 03 FF 00 00 00 00 00 04 03 FF 00 00 00 00 00 00 00 F9 F9 00 00 00 00 00 00 F9 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F4 F4 00 00 00 00 00 00 F4 EC F8 00 00 00 00 01 01 F8 F8 00 00 00 00 01 01 00 00 00 00 00 00 00 00 F9 F9 FC FC 00 00 00 00 F9 F9 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07487,ADA_GLS_RS_KF2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07471,ADA_PF,FF ED 00 00 00 80 FF 98 01 0E,
ENG07492,ADA_PF_CTR,00 00 00 00 00 00 00 00 00 02,
ENG26462,ADA_PF_CTR_KALT,00 00 00 00 00 00 00 00 00 00,
ENG26463,ADA_PF_KALT,00 00 00 00 00 00 00 00 00 00,
ENG26464,ADA_PF_SCTR,02 4A 00 F8 03 5A 01 49 01 4C,
ENG26465,ADA_PF_SCTR_KALT,02 4A 00 F8 03 5A 01 49 02 06,
ENG07493,ADA_PF_START_CTR,00 06 00 00 00 06 00 06 00 04,
ENG07470,ADA_PF2,00 00,
ENG07491,ADA_PF2_CTR,00 00,
ENG07472,ADA_TSF,FF FC 00 03 00 03 00 0B FF F2,
ENG07494,ADA_TSF_CTR,00 01 00 01 00 01 00 01 00 02,
ENG26466,ADA_TSF_SCTR,01 D1 00 AD 02 56 00 8F 01 5D,
ENG02482,Adaption_counter_PF_Lockup_clutch,0,
ENG02480,Adaption_counter_TSF_Lockup_clutch,0,
ENG02481-ENG98502,Adaption_inflation_current_PF_Lockup_clutch-Data,0, mA
ENG02479-ENG98502,Adaption_inflation_time_TSF_Lockup_clutch-Data,0.0, ms
ENG37600-MAS00711,Automatic Position Change-Odometer reading,0, km
ENG37600-ENG112386,Automatic Position Change-Event,0,
ENG37601-MAS00711,Automatic Position Change Diagnostic-Odometer reading,52, km
ENG37601-ENG112386,Automatic Position Change Diagnostic-Event,20,
ENG117298,Auxiliary_Oil_Pump_counter_temp_subzero,0,
ENG07468,Auxiliary_Oil_Pump_Error_Status,0,
ENG07466-ENG31833,Auxiliary_Oil_Pump_Hardware_Version-HW Sample,d,
ENG07466-ENG36249,Auxiliary_Oil_Pump_Hardware_Version-HW Sample Level,6,
ENG07466-ENG99001,Auxiliary_Oil_Pump_Hardware_Version-Variant,IEP400.1,
ENG122750,Auxiliary_Oil_Pump_Hours_Operating_Point_0,19, H
ENG122751,Auxiliary_Oil_Pump_Hours_Operating_Point_1,0, H
ENG122752,Auxiliary_Oil_Pump_Hours_Operating_Point_2,0, H
ENG122753,Auxiliary_Oil_Pump_Hours_Operating_Point_3,0, H
ENG07467,Auxiliary_Oil_Pump_ID,1309146662,
ENG07465-ENG32008,Auxiliary_Oil_Pump_Software_Version-Main Version,8,
ENG07465-ENG99001,Auxiliary_Oil_Pump_Software_Version-Variant,IEP400.1,
ENG07465-ENG99027,Auxiliary_Oil_Pump_Software_Version-Version,1,
ENG101095,B008_Average Wheel Speed / Drive Shaft,0, km/h
ENG07420-IDE00021,Backup Error Entry 1-Engine RPM,0.00, /min
ENG07420-IDE00022,Backup Error Entry 1-Transmission input speed,0, /min
ENG07420-IDE00023,Backup Error Entry 1-Transmission output speed,0, /min
ENG07420-IDE00024,Backup Error Entry 1-ATF temperature,65, °C
ENG07420-IDE00086,Backup Error Entry 1-Accelerator pedal position,15.2, %
ENG07420-IDE00100,Backup Error Entry 1-Engine torque,0, Nm
ENG07420-IDE00145,Backup Error Entry 1-Clutch status,0,
ENG07420-MAS00106,Backup Error Entry 1-Year,2019,
ENG07420-MAS00107,Backup Error Entry 1-Month,9,
ENG07420-MAS00108,Backup Error Entry 1-Day,24,
ENG07420-MAS00109,Backup Error Entry 1-Hours,15,
ENG07420-MAS00110,Backup Error Entry 1-Minutes,47,
ENG07420-MAS00111,Backup Error Entry 1-Seconds,44,
ENG07420-MAS00468,Backup Error Entry 1-Unlearning counter,255,
ENG07420-MAS00711,Backup Error Entry 1-Odometer reading,52, km
ENG07420-MAS00978,Backup Error Entry 1-Priority,2,
ENG07420-MAS00979,Backup Error Entry 1-Malfunction frequency counter,1,
ENG07420,Backup Error Entry 1,00 26,
ENG07420,Backup Error Entry 1,20 96 28 10 34 00 02 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 A5 02 85 91 02 88 01 21 0E 04 70 D1 0C 0C 21 0F 02 03 00 00 00 00 21 11 00 00 08 05 0A 10 2F 40 10 2E 40 10 31 00 21 13 00 10 05 00 00 21 16 00 00 21 10 FF FF 10 1E 00 21 12 00 03 01 66 10 2C 86 10 80 70 21 15 00 10 12 00 21 2F 38 8B,
ENG07420-ENG101797,Backup Error Entry 1-DTC value,00 00 00,
ENG07420-ENG28457,Backup Error Entry 1-Status Of DTC,00,
ENG07420-ENG28489,Backup Error Entry 1-Status Of DTC Bit 0,passive/sporadic,
ENG07420-ENG28302,Backup Error Entry 1-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07420-ENG28383,Backup Error Entry 1-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07420-ENG28451,Backup Error Entry 1-Status Of DTC Bit 3,Not confirmed,
ENG07420-ENG28462,Backup Error Entry 1-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07420-ENG28409,Backup Error Entry 1-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07420-ENG28336,Backup Error Entry 1-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07420-ENG28301,Backup Error Entry 1-Status Of DTC Bit 7,No warning display on,
ENG07429-IDE00021,Backup Error Entry 10-Engine RPM,0.00, /min
ENG07429-IDE00022,Backup Error Entry 10-Transmission input speed,0, /min
ENG07429-IDE00023,Backup Error Entry 10-Transmission output speed,0, /min
ENG07429-IDE00024,Backup Error Entry 10-ATF temperature,70, °C
ENG07429-IDE00086,Backup Error Entry 10-Accelerator pedal position,15.2, %
ENG07429-IDE00100,Backup Error Entry 10-Engine torque,0, Nm
ENG07429-IDE00145,Backup Error Entry 10-Clutch status,0,
ENG07429-MAS00106,Backup Error Entry 10-Year,2019,
ENG07429-MAS00107,Backup Error Entry 10-Month,9,
ENG07429-MAS00108,Backup Error Entry 10-Day,24,
ENG07429-MAS00109,Backup Error Entry 10-Hours,14,
ENG07429-MAS00110,Backup Error Entry 10-Minutes,44,
ENG07429-MAS00111,Backup Error Entry 10-Seconds,44,
ENG07429-MAS00468,Backup Error Entry 10-Unlearning counter,255,
ENG07429-MAS00711,Backup Error Entry 10-Odometer reading,51, km
ENG07429-MAS00978,Backup Error Entry 10-Priority,2,
ENG07429-MAS00979,Backup Error Entry 10-Malfunction frequency counter,1,
ENG07429,Backup Error Entry 10,00 26,
ENG07429,Backup Error Entry 10,20 96 28 10 34 00 21 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 E7 02 85 91 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 00 00 00 21 11 00 00 08 05 0A 10 2F 40 10 2E 10 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FF 10 1E 00 21 12 00 03 01 6B 10 2C 86 10 80 70 21 15 00 10 12 00 21 2F 38 DC,
ENG07429-ENG101797,Backup Error Entry 10-DTC value,00 00 00,
ENG07429-ENG28457,Backup Error Entry 10-Status Of DTC,00,
ENG07429-ENG28489,Backup Error Entry 10-Status Of DTC Bit 0,passive/sporadic,
ENG07429-ENG28302,Backup Error Entry 10-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07429-ENG28383,Backup Error Entry 10-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07429-ENG28451,Backup Error Entry 10-Status Of DTC Bit 3,Not confirmed,
ENG07429-ENG28462,Backup Error Entry 10-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07429-ENG28409,Backup Error Entry 10-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07429-ENG28336,Backup Error Entry 10-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07429-ENG28301,Backup Error Entry 10-Status Of DTC Bit 7,No warning display on,
ENG07421-IDE00021,Backup Error Entry 2-Engine RPM,0.00, /min
ENG07421-IDE00022,Backup Error Entry 2-Transmission input speed,0, /min
ENG07421-IDE00023,Backup Error Entry 2-Transmission output speed,0, /min
ENG07421-IDE00024,Backup Error Entry 2-ATF temperature,31, °C
ENG07421-IDE00086,Backup Error Entry 2-Accelerator pedal position,15.2, %
ENG07421-IDE00100,Backup Error Entry 2-Engine torque,0, Nm
ENG07421-IDE00145,Backup Error Entry 2-Clutch status,0,
ENG07421-MAS00106,Backup Error Entry 2-Year,2020,
ENG07421-MAS00107,Backup Error Entry 2-Month,8,
ENG07421-MAS00108,Backup Error Entry 2-Day,7,
ENG07421-MAS00109,Backup Error Entry 2-Hours,13,
ENG07421-MAS00110,Backup Error Entry 2-Minutes,15,
ENG07421-MAS00111,Backup Error Entry 2-Seconds,53,
ENG07421-MAS00468,Backup Error Entry 2-Unlearning counter,255,
ENG07421-MAS00711,Backup Error Entry 2-Odometer reading,86, km
ENG07421-MAS00978,Backup Error Entry 2-Priority,2,
ENG07421-MAS00979,Backup Error Entry 2-Malfunction frequency counter,2,
ENG07421,Backup Error Entry 2,00 AB,
ENG07421,Backup Error Entry 2,20 96 28 10 34 02 A0 10 3B FF 10 3A 00 00 10 33 FF F4 42 33 14 10 00 00 00 BD FF 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 00 80 00 21 11 00 00 08 05 0A 02 85 81 02 88 01 13 00 90 79 03 C8,
ENG07421-ENG101797,Backup Error Entry 2-DTC value,00 8A 5F,
ENG07421-ENG28457,Backup Error Entry 2-Status Of DTC,00,
ENG07421-ENG28489,Backup Error Entry 2-Status Of DTC Bit 0,passive/sporadic,
ENG07421-ENG28302,Backup Error Entry 2-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07421-ENG28383,Backup Error Entry 2-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07421-ENG28451,Backup Error Entry 2-Status Of DTC Bit 3,Not confirmed,
ENG07421-ENG28462,Backup Error Entry 2-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07421-ENG28409,Backup Error Entry 2-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07421-ENG28336,Backup Error Entry 2-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07421-ENG28301,Backup Error Entry 2-Status Of DTC Bit 7,No warning display on,
ENG07422-IDE00021,Backup Error Entry 3-Engine RPM,0.00, /min
ENG07422-IDE00022,Backup Error Entry 3-Transmission input speed,0, /min
ENG07422-IDE00023,Backup Error Entry 3-Transmission output speed,0, /min
ENG07422-IDE00024,Backup Error Entry 3-ATF temperature,26, °C
ENG07422-IDE00086,Backup Error Entry 3-Accelerator pedal position,15.2, %
ENG07422-IDE00100,Backup Error Entry 3-Engine torque,0, Nm
ENG07422-IDE00145,Backup Error Entry 3-Clutch status,0,
ENG07422-MAS00106,Backup Error Entry 3-Year,2019,
ENG07422-MAS00107,Backup Error Entry 3-Month,9,
ENG07422-MAS00108,Backup Error Entry 3-Day,13,
ENG07422-MAS00109,Backup Error Entry 3-Hours,18,
ENG07422-MAS00110,Backup Error Entry 3-Minutes,6,
ENG07422-MAS00111,Backup Error Entry 3-Seconds,46,
ENG07422-MAS00468,Backup Error Entry 3-Unlearning counter,255,
ENG07422-MAS00711,Backup Error Entry 3-Odometer reading,0, km
ENG07422-MAS00978,Backup Error Entry 3-Priority,2,
ENG07422-MAS00979,Backup Error Entry 3-Malfunction frequency counter,1,
ENG07422,Backup Error Entry 3,20 96 28 10 34 00 0F 10 3B FF 10 3A 00 00 10 33 FF F4 42 36 42 10 00 00 01 BD FF 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 01 C0 00 21 11 00 00 08 05 0A 02 85 89 02 88 01 13 00 90 18 43 88,
ENG07422,Backup Error Entry 3,00 B2,
ENG07422-ENG101797,Backup Error Entry 3-DTC value,00 6B 5D,
ENG07422-ENG28457,Backup Error Entry 3-Status Of DTC,00,
ENG07422-ENG28489,Backup Error Entry 3-Status Of DTC Bit 0,passive/sporadic,
ENG07422-ENG28302,Backup Error Entry 3-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07422-ENG28383,Backup Error Entry 3-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07422-ENG28451,Backup Error Entry 3-Status Of DTC Bit 3,Not confirmed,
ENG07422-ENG28462,Backup Error Entry 3-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07422-ENG28409,Backup Error Entry 3-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07422-ENG28336,Backup Error Entry 3-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07422-ENG28301,Backup Error Entry 3-Status Of DTC Bit 7,No warning display on,
ENG07423-IDE00021,Backup Error Entry 4-Engine RPM,0.00, /min
ENG07423-IDE00022,Backup Error Entry 4-Transmission input speed,0, /min
ENG07423-IDE00023,Backup Error Entry 4-Transmission output speed,0, /min
ENG07423-IDE00024,Backup Error Entry 4-ATF temperature,26, °C
ENG07423-IDE00086,Backup Error Entry 4-Accelerator pedal position,15.2, %
ENG07423-IDE00100,Backup Error Entry 4-Engine torque,0, Nm
ENG07423-IDE00145,Backup Error Entry 4-Clutch status,0,
ENG07423-MAS00106,Backup Error Entry 4-Year,2019,
ENG07423-MAS00107,Backup Error Entry 4-Month,9,
ENG07423-MAS00108,Backup Error Entry 4-Day,13,
ENG07423-MAS00109,Backup Error Entry 4-Hours,18,
ENG07423-MAS00110,Backup Error Entry 4-Minutes,7,
ENG07423-MAS00111,Backup Error Entry 4-Seconds,25,
ENG07423-MAS00468,Backup Error Entry 4-Unlearning counter,255,
ENG07423-MAS00711,Backup Error Entry 4-Odometer reading,0, km
ENG07423-MAS00978,Backup Error Entry 4-Priority,2,
ENG07423-MAS00979,Backup Error Entry 4-Malfunction frequency counter,1,
ENG07423,Backup Error Entry 4,00 81,
ENG07423,Backup Error Entry 4,20 96 28 10 34 00 36 10 3B FF 10 3A 00 00 10 33 FF F4 42 36 51 10 05 00 00 21 0E 00 70 D1 0D 0D 21 0F 02 10 2E 10 02 88 01 21 0D 00 40 03 01 40 10 24 00 00 10 25 00 00 10 26 00 00 10 27 00 00 10 28 00 00 10 29 00 00 08 05 0A 21 13 01 10 00 00 01 BD FF 10 2F 00 02 85 89 21 12 00,
ENG07423-ENG101797,Backup Error Entry 4-DTC value,00 6B 2A,
ENG07423-ENG28457,Backup Error Entry 4-Status Of DTC,00,
ENG07423-ENG28489,Backup Error Entry 4-Status Of DTC Bit 0,passive/sporadic,
ENG07423-ENG28302,Backup Error Entry 4-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07423-ENG28383,Backup Error Entry 4-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07423-ENG28451,Backup Error Entry 4-Status Of DTC Bit 3,Not confirmed,
ENG07423-ENG28462,Backup Error Entry 4-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07423-ENG28409,Backup Error Entry 4-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07423-ENG28336,Backup Error Entry 4-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07423-ENG28301,Backup Error Entry 4-Status Of DTC Bit 7,No warning display on,
ENG07424-IDE00021,Backup Error Entry 5-Engine RPM,0.00, /min
ENG07424-IDE00022,Backup Error Entry 5-Transmission input speed,0, /min
ENG07424-IDE00023,Backup Error Entry 5-Transmission output speed,0, /min
ENG07424-IDE00024,Backup Error Entry 5-ATF temperature,26, °C
ENG07424-IDE00086,Backup Error Entry 5-Accelerator pedal position,15.2, %
ENG07424-IDE00100,Backup Error Entry 5-Engine torque,0, Nm
ENG07424-IDE00145,Backup Error Entry 5-Clutch status,0,
ENG07424-MAS00106,Backup Error Entry 5-Year,2019,
ENG07424-MAS00107,Backup Error Entry 5-Month,9,
ENG07424-MAS00108,Backup Error Entry 5-Day,13,
ENG07424-MAS00109,Backup Error Entry 5-Hours,21,
ENG07424-MAS00110,Backup Error Entry 5-Minutes,18,
ENG07424-MAS00111,Backup Error Entry 5-Seconds,27,
ENG07424-MAS00468,Backup Error Entry 5-Unlearning counter,255,
ENG07424-MAS00711,Backup Error Entry 5-Odometer reading,0, km
ENG07424-MAS00978,Backup Error Entry 5-Priority,2,
ENG07424-MAS00979,Backup Error Entry 5-Malfunction frequency counter,1,
ENG07424,Backup Error Entry 5,00 26,
ENG07424,Backup Error Entry 5,20 96 28 10 34 00 15 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 E6 02 85 90 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 01 C0 00 21 11 00 00 08 05 0A 10 2F 00 10 2E 10 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FD 10 1E 00 21 12 00 03 01 40 10 2C 42 10 80 70 21 15 00 10 12 00 21 2F 38 D2,
ENG07424-ENG101797,Backup Error Entry 5-DTC value,00 00 00,
ENG07424-ENG28457,Backup Error Entry 5-Status Of DTC,00,
ENG07424-ENG28489,Backup Error Entry 5-Status Of DTC Bit 0,passive/sporadic,
ENG07424-ENG28302,Backup Error Entry 5-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07424-ENG28383,Backup Error Entry 5-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07424-ENG28451,Backup Error Entry 5-Status Of DTC Bit 3,Not confirmed,
ENG07424-ENG28462,Backup Error Entry 5-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07424-ENG28409,Backup Error Entry 5-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07424-ENG28336,Backup Error Entry 5-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07424-ENG28301,Backup Error Entry 5-Status Of DTC Bit 7,No warning display on,
ENG07425-IDE00021,Backup Error Entry 6-Engine RPM,0.00, /min
ENG07425-IDE00022,Backup Error Entry 6-Transmission input speed,0, /min
ENG07425-IDE00023,Backup Error Entry 6-Transmission output speed,0, /min
ENG07425-IDE00024,Backup Error Entry 6-ATF temperature,27, °C
ENG07425-IDE00086,Backup Error Entry 6-Accelerator pedal position,15.2, %
ENG07425-IDE00100,Backup Error Entry 6-Engine torque,0, Nm
ENG07425-IDE00145,Backup Error Entry 6-Clutch status,0,
ENG07425-MAS00106,Backup Error Entry 6-Year,2019,
ENG07425-MAS00107,Backup Error Entry 6-Month,9,
ENG07425-MAS00108,Backup Error Entry 6-Day,13,
ENG07425-MAS00109,Backup Error Entry 6-Hours,21,
ENG07425-MAS00110,Backup Error Entry 6-Minutes,19,
ENG07425-MAS00111,Backup Error Entry 6-Seconds,41,
ENG07425-MAS00468,Backup Error Entry 6-Unlearning counter,255,
ENG07425-MAS00711,Backup Error Entry 6-Odometer reading,0, km
ENG07425-MAS00978,Backup Error Entry 6-Priority,2,
ENG07425-MAS00979,Backup Error Entry 6-Malfunction frequency counter,1,
ENG07425,Backup Error Entry 6,00 B2,
ENG07425,Backup Error Entry 6,20 96 28 10 34 00 60 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 EA 10 00 00 01 BD FF 10 05 00 00 21 0E 00 21 0F 02 70 D1 0E 0E 03 00 01 C0 00 21 11 00 00 08 05 0A 02 85 90 02 88 01 13 00 90 78 03 C8,
ENG07425-ENG101797,Backup Error Entry 6-DTC value,00 6B 5D,
ENG07425-ENG28457,Backup Error Entry 6-Status Of DTC,00,
ENG07425-ENG28489,Backup Error Entry 6-Status Of DTC Bit 0,passive/sporadic,
ENG07425-ENG28302,Backup Error Entry 6-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07425-ENG28383,Backup Error Entry 6-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07425-ENG28451,Backup Error Entry 6-Status Of DTC Bit 3,Not confirmed,
ENG07425-ENG28462,Backup Error Entry 6-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07425-ENG28409,Backup Error Entry 6-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07425-ENG28336,Backup Error Entry 6-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07425-ENG28301,Backup Error Entry 6-Status Of DTC Bit 7,No warning display on,
ENG07426-IDE00021,Backup Error Entry 7-Engine RPM,0.00, /min
ENG07426-IDE00022,Backup Error Entry 7-Transmission input speed,0, /min
ENG07426-IDE00023,Backup Error Entry 7-Transmission output speed,0, /min
ENG07426-IDE00024,Backup Error Entry 7-ATF temperature,27, °C
ENG07426-IDE00086,Backup Error Entry 7-Accelerator pedal position,15.2, %
ENG07426-IDE00100,Backup Error Entry 7-Engine torque,0, Nm
ENG07426-IDE00145,Backup Error Entry 7-Clutch status,0,
ENG07426-MAS00106,Backup Error Entry 7-Year,2019,
ENG07426-MAS00107,Backup Error Entry 7-Month,9,
ENG07426-MAS00108,Backup Error Entry 7-Day,13,
ENG07426-MAS00109,Backup Error Entry 7-Hours,21,
ENG07426-MAS00110,Backup Error Entry 7-Minutes,27,
ENG07426-MAS00111,Backup Error Entry 7-Seconds,12,
ENG07426-MAS00468,Backup Error Entry 7-Unlearning counter,255,
ENG07426-MAS00711,Backup Error Entry 7-Odometer reading,0, km
ENG07426-MAS00978,Backup Error Entry 7-Priority,2,
ENG07426-MAS00979,Backup Error Entry 7-Malfunction frequency counter,1,
ENG07426,Backup Error Entry 7,00 26,
ENG07426,Backup Error Entry 7,20 96 28 10 34 01 F7 10 3B FF 10 3A 00 00 10 33 FF F4 42 39 12 02 85 90 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 01 80 00 21 11 00 00 08 05 0A 10 2F 40 10 2E 00 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FE 10 1E 00 21 12 00 03 01 40 10 2C 42 10 80 70 21 15 00 10 12 00 21 2F 39 00,
ENG07426-ENG101797,Backup Error Entry 7-DTC value,00 00 00,
ENG07426-ENG28457,Backup Error Entry 7-Status Of DTC,00,
ENG07426-ENG28489,Backup Error Entry 7-Status Of DTC Bit 0,passive/sporadic,
ENG07426-ENG28302,Backup Error Entry 7-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07426-ENG28383,Backup Error Entry 7-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07426-ENG28451,Backup Error Entry 7-Status Of DTC Bit 3,Not confirmed,
ENG07426-ENG28462,Backup Error Entry 7-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07426-ENG28409,Backup Error Entry 7-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07426-ENG28336,Backup Error Entry 7-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07426-ENG28301,Backup Error Entry 7-Status Of DTC Bit 7,No warning display on,
ENG07427-IDE00021,Backup Error Entry 8-Engine RPM,0.00, /min
ENG07427-IDE00022,Backup Error Entry 8-Transmission input speed,0, /min
ENG07427-IDE00023,Backup Error Entry 8-Transmission output speed,0, /min
ENG07427-IDE00024,Backup Error Entry 8-ATF temperature,72, °C
ENG07427-IDE00086,Backup Error Entry 8-Accelerator pedal position,15.2, %
ENG07427-IDE00100,Backup Error Entry 8-Engine torque,0, Nm
ENG07427-IDE00145,Backup Error Entry 8-Clutch status,0,
ENG07427-MAS00106,Backup Error Entry 8-Year,2019,
ENG07427-MAS00107,Backup Error Entry 8-Month,9,
ENG07427-MAS00108,Backup Error Entry 8-Day,24,
ENG07427-MAS00109,Backup Error Entry 8-Hours,14,
ENG07427-MAS00110,Backup Error Entry 8-Minutes,9,
ENG07427-MAS00111,Backup Error Entry 8-Seconds,1,
ENG07427-MAS00468,Backup Error Entry 8-Unlearning counter,255,
ENG07427-MAS00711,Backup Error Entry 8-Odometer reading,51, km
ENG07427-MAS00978,Backup Error Entry 8-Priority,2,
ENG07427-MAS00979,Backup Error Entry 8-Malfunction frequency counter,1,
ENG07427,Backup Error Entry 8,00 26,
ENG07427,Backup Error Entry 8,20 96 28 10 34 00 02 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 11 02 85 8F 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 00 00 00 21 11 00 00 08 05 0A 10 2F 00 10 2E 00 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FF 10 1E 00 21 12 00 03 01 6D 10 2C 86 10 80 70 21 15 00 10 12 00 21 2F 38 02,
ENG07427-ENG101797,Backup Error Entry 8-DTC value,00 00 00,
ENG07427-ENG28457,Backup Error Entry 8-Status Of DTC,00,
ENG07427-ENG28489,Backup Error Entry 8-Status Of DTC Bit 0,passive/sporadic,
ENG07427-ENG28302,Backup Error Entry 8-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07427-ENG28383,Backup Error Entry 8-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07427-ENG28451,Backup Error Entry 8-Status Of DTC Bit 3,Not confirmed,
ENG07427-ENG28462,Backup Error Entry 8-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07427-ENG28409,Backup Error Entry 8-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07427-ENG28336,Backup Error Entry 8-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07427-ENG28301,Backup Error Entry 8-Status Of DTC Bit 7,No warning display on,
ENG07428-IDE00021,Backup Error Entry 9-Engine RPM,0.00, /min
ENG07428-IDE00022,Backup Error Entry 9-Transmission input speed,0, /min
ENG07428-IDE00023,Backup Error Entry 9-Transmission output speed,0, /min
ENG07428-IDE00024,Backup Error Entry 9-ATF temperature,71, °C
ENG07428-IDE00086,Backup Error Entry 9-Accelerator pedal position,15.2, %
ENG07428-IDE00100,Backup Error Entry 9-Engine torque,0, Nm
ENG07428-IDE00145,Backup Error Entry 9-Clutch status,0,
ENG07428-MAS00106,Backup Error Entry 9-Year,2019,
ENG07428-MAS00107,Backup Error Entry 9-Month,9,
ENG07428-MAS00108,Backup Error Entry 9-Day,24,
ENG07428-MAS00109,Backup Error Entry 9-Hours,14,
ENG07428-MAS00110,Backup Error Entry 9-Minutes,39,
ENG07428-MAS00111,Backup Error Entry 9-Seconds,1,
ENG07428-MAS00468,Backup Error Entry 9-Unlearning counter,255,
ENG07428-MAS00711,Backup Error Entry 9-Odometer reading,51, km
ENG07428-MAS00978,Backup Error Entry 9-Priority,2,
ENG07428-MAS00979,Backup Error Entry 9-Malfunction frequency counter,1,
ENG07428,Backup Error Entry 9,20 96 28 10 34 00 3D 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 E0 02 85 91 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 00 00 00 21 11 00 00 08 05 0A 10 2F 40 10 2E 10 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FF 10 1E 00 21 12 00 03 01 6C 10 2C 86 10 80 70 21 15 00 10 12 00 21 2F 38 D1,
ENG07428,Backup Error Entry 9,00 26,
ENG07428-ENG101797,Backup Error Entry 9-DTC value,00 00 00,
ENG07428-ENG28457,Backup Error Entry 9-Status Of DTC,00,
ENG07428-ENG28489,Backup Error Entry 9-Status Of DTC Bit 0,passive/sporadic,
ENG07428-ENG28302,Backup Error Entry 9-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07428-ENG28383,Backup Error Entry 9-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07428-ENG28451,Backup Error Entry 9-Status Of DTC Bit 3,Not confirmed,
ENG07428-ENG28462,Backup Error Entry 9-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07428-ENG28409,Backup Error Entry 9-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07428-ENG28336,Backup Error Entry 9-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07428-ENG28301,Backup Error Entry 9-Status Of DTC Bit 7,No warning display on,
ENG101867,C009_Current Regulator No. 8,0.0, mA
ENG105392,C010_Current Regulator No. 9,0.0, mA
ENG101413,Calibration Identification,4N0158K 10012   ,
ENG99697,Calibration Verification Number,9A 8D CE CB,
ENG36558-ENG36666,Clutch_overheating_information-Clutch,none,
ENG36558-ENG98971,Clutch_overheating_information-Temperature,0, °C
ENG101834,Current N215 Pressure control valve 1,850.0, mA
ENG99930,Current N216 pressure reg.valve 2,50.0, mA
ENG102208,Current N217 pressure reg.valve 3,850.0, mA
ENG100408,Current N218 pressure reg.valve 4,319.9, mA
ENG101543,Current N233 pressure reg.valve 5,50.0, mA
ENG101463,Current N371 pressure reg. valve 6 lock-up clutch,50.0, mA
ENG101716,Current N443 pressure reg.valve 7 main pressure,653.1, mA
ENG102805,Current solenoid,0.0, mA
ENG07413,Desired_Torque_Filtered,0, Nm
ENG07412,Desired_Torque_Raw,0, Nm
ENG07416,Dynamic_Torque_Limitation,242, Nm
ENG07430-ENG125631,E Status OUT0-Break,No,
ENG07430-ENG07550,E Status OUT0-communication fault,No,
ENG07430-ENG07552,E Status OUT0-current too high,No,
ENG07430-ENG121961,E Status OUT0-Current too low,No,
ENG07430-ENG108945,E Status OUT0-short to battery,No,
ENG07430-ENG108946,E Status OUT0-short to ground,No,
ENG07430-ENG07551,E Status OUT0-wrong communication,No,
ENG07431-ENG125631,E Status OUT1-Break,No,
ENG07431-ENG07550,E Status OUT1-communication fault,No,
ENG07431-ENG07552,E Status OUT1-current too high,No,
ENG07431-ENG121961,E Status OUT1-Current too low,No,
ENG07431-ENG108945,E Status OUT1-short to battery,No,
ENG07431-ENG108946,E Status OUT1-short to ground,No,
ENG07431-ENG07551,E Status OUT1-wrong communication,No,
ENG07438-ENG125631,E Status OUT10-Break,Yes,
ENG07438-ENG07550,E Status OUT10-communication fault,No,
ENG07438-ENG07552,E Status OUT10-current too high,No,
ENG07438-ENG121961,E Status OUT10-Current too low,No,
ENG07438-ENG108945,E Status OUT10-short to battery,No,
ENG07438-ENG108946,E Status OUT10-short to ground,No,
ENG07438-ENG07551,E Status OUT10-wrong communication,No,
ENG07439-ENG125631,E Status OUT11-Break,No,
ENG07439-ENG07550,E Status OUT11-communication fault,No,
ENG07439-ENG07552,E Status OUT11-current too high,No,
ENG07439-ENG121961,E Status OUT11-Current too low,No,
ENG07439-ENG108945,E Status OUT11-short to battery,No,
ENG07439-ENG108946,E Status OUT11-short to ground,No,
ENG07439-ENG07551,E Status OUT11-wrong communication,No,
ENG07440-ENG125631,E Status OUT12-Break,No,
ENG07440-ENG07550,E Status OUT12-communication fault,No,
ENG07440-ENG07552,E Status OUT12-current too high,No,
ENG07440-ENG121961,E Status OUT12-Current too low,No,
ENG07440-ENG108945,E Status OUT12-short to battery,No,
ENG07440-ENG108946,E Status OUT12-short to ground,No,
ENG07440-ENG07551,E Status OUT12-wrong communication,No,
ENG07441-ENG125631,E Status OUT13-Break,No,
ENG07441-ENG07550,E Status OUT13-communication fault,No,
ENG07441-ENG07552,E Status OUT13-current too high,No,
ENG07441-ENG121961,E Status OUT13-Current too low,No,
ENG07441-ENG108945,E Status OUT13-short to battery,No,
ENG07441-ENG108946,E Status OUT13-short to ground,No,
ENG07441-ENG07551,E Status OUT13-wrong communication,No,
ENG07442-ENG125631,E Status OUT14-Break,No,
ENG07442-ENG07550,E Status OUT14-communication fault,No,
ENG07442-ENG07552,E Status OUT14-current too high,No,
ENG07442-ENG121961,E Status OUT14-Current too low,No,
ENG07442-ENG108945,E Status OUT14-short to battery,No,
ENG07442-ENG108946,E Status OUT14-short to ground,No,
ENG07442-ENG07551,E Status OUT14-wrong communication,No,
ENG07432-ENG125631,E Status OUT2-Break,No,
ENG07432-ENG07550,E Status OUT2-communication fault,No,
ENG07432-ENG07552,E Status OUT2-current too high,No,
ENG07432-ENG121961,E Status OUT2-Current too low,No,
ENG07432-ENG108945,E Status OUT2-short to battery,No,
ENG07432-ENG108946,E Status OUT2-short to ground,No,
ENG07432-ENG07551,E Status OUT2-wrong communication,No,
ENG07433-ENG125631,E Status OUT3-Break,No,
ENG07433-ENG07550,E Status OUT3-communication fault,No,
ENG07433-ENG07552,E Status OUT3-current too high,No,
ENG07433-ENG121961,E Status OUT3-Current too low,No,
ENG07433-ENG108945,E Status OUT3-short to battery,No,
ENG07433-ENG108946,E Status OUT3-short to ground,No,
ENG07433-ENG07551,E Status OUT3-wrong communication,No,
ENG07434-ENG125631,E Status OUT4-Break,No,
ENG07434-ENG07550,E Status OUT4-communication fault,No,
ENG07434-ENG07552,E Status OUT4-current too high,No,
ENG07434-ENG121961,E Status OUT4-Current too low,No,
ENG07434-ENG108945,E Status OUT4-short to battery,No,
ENG07434-ENG108946,E Status OUT4-short to ground,No,
ENG07434-ENG07551,E Status OUT4-wrong communication,No,
ENG07435-ENG125631,E Status OUT5-Break,No,
ENG07435-ENG07550,E Status OUT5-communication fault,No,
ENG07435-ENG07552,E Status OUT5-current too high,No,
ENG07435-ENG121961,E Status OUT5-Current too low,No,
ENG07435-ENG108945,E Status OUT5-short to battery,No,
ENG07435-ENG108946,E Status OUT5-short to ground,No,
ENG07435-ENG07551,E Status OUT5-wrong communication,No,
ENG07436-ENG125631,E Status OUT6-Break,No,
ENG07436-ENG07550,E Status OUT6-communication fault,No,
ENG07436-ENG07552,E Status OUT6-current too high,No,
ENG07436-ENG121961,E Status OUT6-Current too low,No,
ENG07436-ENG108945,E Status OUT6-short to battery,No,
ENG07436-ENG108946,E Status OUT6-short to ground,No,
ENG07436-ENG07551,E Status OUT6-wrong communication,No,
ENG07437-ENG125631,E Status OUT7-Break,No,
ENG07437-ENG07550,E Status OUT7-communication fault,No,
ENG07437-ENG07552,E Status OUT7-current too high,No,
ENG07437-ENG121961,E Status OUT7-Current too low,No,
ENG07437-ENG108945,E Status OUT7-short to battery,No,
ENG07437-ENG108946,E Status OUT7-short to ground,No,
ENG07437-ENG07551,E Status OUT7-wrong communication,No,
ENG07443-ENG07554,E Status UDRMV-Open Pin (Direct Fault Entry),No,
ENG07443-ENG07553,E Status UDRMV-plausi,No,
ENG07443-ENG108945,E Status UDRMV-short to battery,No,
ENG07443-ENG07556,E Status UDRMV-short to battery (Direct Fault Entry),No,
ENG07443-ENG108946,E Status UDRMV-short to ground,No,
ENG07443-ENG07555,E Status UDRMV-short to ground (Direct Fault Entry),No,
ENG125929,ECU_R,48 61 74 74 6F 72 69 00 42 6F 73 63 68 2E 54 43 5F 31 30 37 5F 30 30 30 31 2E 53 77 69 74 63 68 4F 76 65 72 2E 54 43 55 32 2E 56 30 30 31 00 41 50 50 4C 00 0C 19 08 11 06 58 09 08 01 20 00 10 69 01 00,
ENG125930,ECU_ST,01 00,
ENG100152-ENG104003,ECUNAME-ECU,TCM,
ENG100152,ECUNAME,TransmisCtrl,
ENG07457,E-Status CCHIP 1,00,
ENG07458,E-Status CCHIP 2,00,
ENG07456,E-Status CGT,00,
ENG07455,E-Status USENS,00,
ENG07408,F007_Inexact Torque Values Over Bus,OK,
ENG102638,F012_State_TCM_Torque_Engagement,no requirement,
ENG103123,F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
ENG106470,F015_TCM_Drag_Torque,3, Nm
ENG106472,F016_TCM_Torque_Gradient_Limitation,2550, Nm/s
ENG106562,Fixed WH-Position by Errormemory Entry,Automat-Gasse (X),
ENG07414,Friction_Torque,62, Nm
ENG26895,Hold_management_parking_lock_engagement_counter,0,
ENG106956,Immobilizer Snapshot 1,00 00 00 00 00 00,
ENG106957,Immobilizer Snapshot 2,00 00 00 00 00 00,
ENG26899-ENG30226,Intelligent Park Assist-00: Waehlhebel_04 WH_Sensorpos_roh != {X: M: Init: Fehler},No,
ENG26899-ENG30227,Intelligent Park Assist-01: P Taste betätigt,No,
ENG26899-ENG30228,Intelligent Park Assist-02: Tip paddles betätigt,No,
ENG26899-ENG39154,Intelligent Park Assist-03: IPA angelernt,Yes,
ENG26899-ENG30229,Intelligent Park Assist-04: Fahrbereitschaft vorhanden,Yes,
ENG26899-ENG30230,Intelligent Park Assist-05: GSG verfügbar,Yes,
ENG26899-ENG30231,Intelligent Park Assist-06: Parksperre ist richtig eingelegt,Yes,
ENG26899-ENG30232,Intelligent Park Assist-07: Geschwindigkeit < p_v_IPA_PP_Fzg_Stillstand,Yes,
ENG26899-ENG30233,Intelligent Park Assist-08: Geschwindigkeit < p_v_IPA_PP_MA_vmax_Eingriffe_Aktoren,Yes,
ENG26899-ENG30234,Intelligent Park Assist-09: Geschwindigkeit < p_v_IPA_PP_Fahrstufenwechsel,Yes,
ENG26899-ENG30235,Intelligent Park Assist-10: Geschwindigkeit ist intern gebildet,No,
ENG26899-ENG30236,Intelligent Park Assist-11: Geschwindigkeit ist konstanter Ersatzwert,No,
ENG26899-ENG30237,Intelligent Park Assist-14: IPA-relevanter Fehler im GSG vorhanden,No,
ENG26899-ENG30238,Intelligent Park Assist-16: IPA_01 Timeout vorhanden,No,
ENG26899-ENG30239,Intelligent Park Assist-17: IPA_01 BZ oder CRC Fehler vorhanden,No,
ENG26899-ENG30240,Intelligent Park Assist-19: Klemme 15 EIN,Yes,
ENG26899-ENG39155,Intelligent Park Assist-31: SWI_IPA_Verbaut != 0,Yes,
ENG26899-ENG31586,Intelligent Park Assist-GE_Status_GE_IPA,1,
ENG26899-ENG31876,Intelligent Park Assist-IPA_Fahrstufenwunsch,1,
ENG26899-ENG31878,Intelligent Park Assist-IPA_Status_IPA_GE,0,
ENG26899-ENG09848,Intelligent Park Assist-Value,2417492984,
ENG107149,K004_Adaptive Mode,0,
ENG107153,K005_ID Of Current Driving Program,0,
ENG107154,K006_Current Type Of Driver Counter,0,
ENG107156,K007_ID Of the Active Up-shift Prevention,00 00,
ENG107158,K008_ID Of The Active Down-shift Prevention,00 00,
ENG107331-ENG101735,L001_Engine Coding Information-Emission Type,no EOBD: OBD (US),
ENG107331-ENG98541,L001_Engine Coding Information-Engine code,215,
ENG107331-ENG98980,L001_Engine Coding Information-Transmission code,AL552,
ENG106453,Losses lock-up clutch,3, Nm
ENG07407-ENG07538,M001_Reception State Bus Messages-State Anhaenger,not received,
ENG07407-ENG07539,M001_Reception State Bus Messages-State Charisma,received,
ENG07407-ENG07531,M001_Reception State Bus Messages-State Deashboard,received,
ENG07407-ENG07535,M001_Reception State Bus Messages-State ECM,received,
ENG07407-ENG07544,M001_Reception State Bus Messages-State Elektronische Schaltbetätigung,received,
ENG07407-ENG07534,M001_Reception State Bus Messages-State ESP,received,
ENG07407-ENG07530,M001_Reception State Bus Messages-State Gateway,received,
ENG07407-ENG07545,M001_Reception State Bus Messages-State IPA,received,
ENG07407-ENG07540,M001_Reception State Bus Messages-State Klemmestatus,received,
ENG07407-ENG07541,M001_Reception State Bus Messages-State Klima,received,
ENG07407-ENG07536,M001_Reception State Bus Messages-State OBD,received,
ENG07407-ENG07529,M001_Reception State Bus Messages-State Parking Brake,received,
ENG07407-ENG07542,M001_Reception State Bus Messages-State Sara,received,
ENG07407-ENG07533,M001_Reception State Bus Messages-State Steering Angle,received,
ENG07407-ENG07532,M001_Reception State Bus Messages-State Steering Assist,received,
ENG07407-ENG07543,M001_Reception State Bus Messages-State Systeminfo,not received,
ENG07407-ENG07537,M001_Reception State Bus Messages-State TSK,received,
ENG102568-ENG102114,M010_Signal State (TCM)-State ATF Temperature Sensor,OK,
ENG102568-ENG100649,M010_Signal State (TCM)-State Chip Temperature Sensor,OK,
ENG102568-ENG99717,M010_Signal State (TCM)-State Output Shaft Speed,OK,
ENG102568-ENG101699,M010_Signal State (TCM)-State Plausibility Tolerance,narrow,
ENG102568-ENG100193,M010_Signal State (TCM)-State Position Switch,OK,
ENG102568-ENG102844,M010_Signal State (TCM)-State Turbin Speed,OK,
ENG102679-ENG103922,M011_Signal State Sig1 (ECU)-State Engine Speed,OK,
ENG102679-ENG101631,M011_Signal State Sig1 (ECU)-State Pedal,OK,
ENG102679-ENG100953,M011_Signal State Sig1 (ECU)-State Torque 1,OK,
ENG07409-ENG104115,M012_Signal State (Brake/Direction)-State Brake Signal,OK,
ENG07409-ENG103681,M012_Signal State (Brake/Direction)-State Driving Direction,OK,
ENG07409-ENG100622,M012_Signal State (Brake/Direction)-State Wheel Speed Front Left,OK,
ENG07409-ENG103645,M012_Signal State (Brake/Direction)-State Wheel Speed Front Right,OK,
ENG07409-ENG103415,M012_Signal State (Brake/Direction)-State Wheel Speed Rear Left,OK,
ENG07409-ENG100555,M012_Signal State (Brake/Direction)-State Wheel Speed Rear Right,OK,
ENG99597-ENG102101,M013_Switch-PIN In0,low,
ENG99597-ENG100393,M013_Switch-PIN In1,low,
ENG99597-ENG101177,M013_Switch-PIN In2,low,
ENG99597-ENG103794,M013_Switch-PIN In3,low,
ENG99597-ENG99856,M013_Switch-PIN KL15,high,
ENG102357,M014_Time Since Shift,7650, ms
ENG103371,M015_Time Normal Mode,439, s
ENG107503,M016_Faultcode + Faulttype Error Memory,00 00 00 00,
ENG107504,M017_Faultcode + Faulttype Backup Memory,00 26 00 00,
ENG100237,M018_Time In Afterrun,0, s
ENG104072,M019_Time Since Reset,7650, ms
ENG102788-MAS00106,M020_Time Stamp-Year,2020,
ENG102788-MAS00107,M020_Time Stamp-Month,10,
ENG102788-MAS00108,M020_Time Stamp-Day,24,
ENG102788-MAS00109,M020_Time Stamp-Hours,15,
ENG102788-MAS00110,M020_Time Stamp-Minutes,13,
ENG102788-MAS00111,M020_Time Stamp-Seconds,2,
ENG103130-MAS00711,M021_KM Mileage-Odometer reading,122, km
ENG106726,Maximum chip temperature,94, °C
ENG107851,Number WH-Resets for Permanen-Reset over Livetime,0,
ENG107852,Number WH-Resets to Permanent-Reset in Driving Cycle,0,
ENG107853,Number WH-Resets to Permanent-Reset over Livetime,0,
ENG27076,Preadaption_counter,0,
ENG38971-ENG26202,Programming history-Operating time,0, H
ENG38971-ENG39133,Programming history-Software,,
ENG108362-ENG102813,Q001_OBD Cycle And MIL State-Driving Cycle,active,
ENG108362-ENG98734,Q001_OBD Cycle And MIL State-mil,not active,
ENG108362-ENG99968,Q001_OBD Cycle And MIL State-WarmUp Cycle,not active,
ENG07417,Reserve_Torque,0, Nm
ENG07411,Sensors Supply Voltage,8.96, V
ENG109074,State GE_Test_Freigabe Bit,1,
ENG109075,State GE_WH_Abschalten Bit,0,
ENG109076,State GE_WH_Initialisierung Bit,0,
ENG109077,State GE_WH_Sperre Bit,1,
ENG109083,State WH_Test_Aktiv Bit,1,
ENG07415,Static_Torque_Limitation,680, Nm
ENG103216-ENG102053,Status electric parking lock holder solenoid-Desired State Solenoid Out 10,OFF,
ENG103216-ENG104161,Status electric parking lock holder solenoid-Desired State Solenoid Out 11,OFF,
ENG103216-ENG99231,Status electric parking lock holder solenoid-Desired State Solenoid Out 12,OFF,
ENG103216-ENG99490,Status electric parking lock holder solenoid-Desired State Solenoid Out 13,On,
ENG103216-ENG100651,Status electric parking lock holder solenoid-Desired State Solenoid Out 14,OFF,
ENG07418,Status_Reserve_Torque,not active,
ENG107872,System Supplier Boot Software Identification (BB),b97d0301,
ENG107872-ENG100456,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (BC),bgjb1902,
ENG107872-ENG113110,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (SB),bh1i0201,
ENG107872-ENG07548,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (SBS),911C0401,
ENG107872-ENG100638,System Supplier Boot Software Identification (BB)-System Supplier ECU Identification,103442028301,
ENG107872-ENG101391,System Supplier Boot Software Identification (BB)-System Supplier HW Identification,production,
ENG107872-ENG101224,System Supplier Boot Software Identification (BB)-System Supplier HW Version,19,
ENG107872-ENG103844,System Supplier Boot Software Identification (BB)-System Supplier Manufacturer Number,0077,
ENG107872-ENG99833,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 1,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG107872-ENG101511,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 2,A?,
ENG107872-ENG100387,System Supplier Boot Software Identification (BB)-System Supplier Production Date,03.09.19,
ENG107872-ENG103393,System Supplier Boot Software Identification (BB)-System Supplier Production Identification,ZFS-005,
ENG107872-ENG99218,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Gearbox,4995380,
ENG107872-ENG101400,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Mechatronics,1003442,
ENG107872-ENG102956,System Supplier Boot Software Identification (BB)-System Supplier Software Version,1001,
ENG107872-ENG100713,System Supplier Boot Software Identification (BB)-System Supplier SW Checksum,F8 31 2D F4 6B 3E D8 51,
ENG107872-ENG100221,System Supplier Boot Software Identification (BB)-System Supplier SW Identification,4N0K_AN16F1001,
ENG107872-ENG103167,System Supplier Boot Software Identification (BB)-System Supplier Test Stand Number,5120,
ENG27201-ENG36133,Torque_Converter_temperature_range-Range,0, min
ENG27201-ENG36131,Torque_Converter_temperature_range-Range 1,244, min
ENG27201-ENG36132,Torque_Converter_temperature_range-Range 2,32, min
ENG27201-ENG36137,Torque_Converter_temperature_range-Range 4,0, min
ENG27201-ENG36138,Torque_Converter_temperature_range-Range 5,0, min
ENG27201-ENG36139,Torque_Converter_temperature_range-Range 6,0, min
ENG27201-ENG36140,Torque_Converter_temperature_range-Range 7,0, min
ENG27201-ENG36141,Torque_Converter_temperature_range-Range 8,0, min
ENG105259,Transfer speed from ESP,valid,
ENG105259,Transfer speed from ESP,0.00, km/h
ENG116752-ENG02033,Transmission_construction_number_from_factory-Gearbox subnumber (HSL),000000000000001103034104,
ENG116752-ENG02045,Transmission_construction_number_from_factory-Mechatronic subnumber (GSL),000000000000001103128386,
ENG07450,U-Status 1 MCCOMP,00,
ENG07444,U-Status 1 RESSUP,00 00,
ENG07447,U-Status 1 RESZF,00,
ENG07451,U-Status 2 MCCOMP,00 00 00 00,
ENG07445,U-Status 2 RESSUP,00 00 00 00,
ENG07448,U-Status 2 RESZF,00 00,
ENG07446,U-Status 3 RESSUP,00 00 00 00,
ENG07449,U-Status 3 RESZF,00 00,
ENG07453,U-Status EEPROM,00 00,
ENG07454,U-Status EPROM,00 00,
ENG07452,U-Status WDOG,00 00 00 00,
Elapsed Time: 00:42
blockmap-03-4N0-907-379-AL_WAU8EAF82LN004143-20201024-1513.CSV
;Component:ESP9 Premium  H06 0856, Coding:3CAA189D31A24B9A119F4C951880D2E2F539893C188CD28832184B47AF9C91
;EV_ESP9BOSCHCMP,004011,EV_ESP9BOSCHCMP_004_AU65.rod
;Saturday,24,October,2020,15:13:14:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: 82566142C4FC084BF1F-80D6
Group,Description,Actual
IDE00019,Voltage terminal 30,14.375, V
IDE00020-MAS06489,Terminal 15 status-Terminal 15 signal,On,
IDE00020-MAS06490,Terminal 15 status-Terminal 15 load,On,
IDE00021,Engine RPM,736, /min
IDE00025,Coolant temperature,66, °C
IDE00078,Time since engine start,375, s
IDE00085,Normed load value,11.0, %
IDE00086,Accelerator pedal position,15, %
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00100,Engine torque,1, Nm
IDE00150-MAS00102,Pressure in brake servo unit-valid,-927.81, mbar
IDE00322,Status of basic setting,Basic setting not active,
IDE00326,Steering wheel angle,-1.79, °
IDE00556,Outside temperature,24, °C
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00611,Malfunction that has caused the ambient data to be stored,P0000,
IDE00920,Front left wheel speed,0.00, km/h
IDE00921,Wheel speed: right front,0.00, km/h
IDE00922,Left rear wheel speed,0.00, km/h
IDE00923,Right rear wheel speed,0.00, km/h
IDE01985-MAS06855,FAZIT identification test sum-Test sum,46 B0 44 18,
IDE02211-MAS03714,Brake pressure-Left front wheel,25.780, bar
IDE02211-MAS03716,Brake pressure-Left rear wheel,27.800, bar
IDE02211-MAS09170,Brake pressure-Brake pressure sensor 1,26.300, bar
IDE02239,Rotation rate sensor 1,0.00, rad/s
IDE02241,Lateral acceleration sensor 1,-0.19, m/s²
IDE02243,Rotation rate sensor 2,0.00, rad/s
IDE02245,Lateral acceleration sensor 2,0.00, m/s²
IDE02305,ESP brake application information,operated,
IDE02308,Status ESP button,Not operated,
IDE02309,Valve relay status,active,
IDE02310,Status of return flow pump,passive,
IDE02311-MAS12079,Left front wheel speed sensor installation position-Signal amplitude,0,
IDE02311-MAS12080,Left front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02311-MAS12081,Left front wheel speed sensor installation position-Current air gap: status,OK,
IDE02311-MAS12082,Left front wheel speed sensor installation position-Average air gap: status,OK,
IDE02312-MAS12079,Right front wheel speed sensor installation position-Signal amplitude,0,
IDE02312-MAS12080,Right front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02312-MAS12081,Right front wheel speed sensor installation position-Current air gap: status,OK,
IDE02312-MAS12082,Right front wheel speed sensor installation position-Average air gap: status,OK,
IDE02313-MAS12079,Left rear wheel speed sensor installation position-Signal amplitude,0,
IDE02313-MAS12080,Left rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02313-MAS12081,Left rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02313-MAS12082,Left rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02314-MAS12079,Right rear wheel speed sensor installation position-Signal amplitude,0,
IDE02314-MAS12080,Right rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02314-MAS12081,Right rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02314-MAS12082,Right rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02315,Direction of rotation front left wheel speed sensor,invalid,
IDE02316,Direction of rotation front right wheel speed sensor,invalid,
IDE02317,Direction of rotation rear left wheel speed sensor,invalid,
IDE02318,Direction of rotation rear right wheel speed sensor,invalid,
IDE02319-MAS02149,Hill start assistant signals-Hillside power take-off torque high wheel limit crawl torque,passive,
IDE02319-MAS02150,Hill start assistant signals-Engine torque high hillside power take-off torque,passive,
IDE02319-MAS02151,Hill start assistant signals-Q bit: incline angle EPB,passive,
IDE02319-MAS02153,Hill start assistant signals-Q bit EPB clutch pedal travel,active,
IDE02319-MAS02154,Hill start assistant signals-Q bit EPB switch position,passive,
IDE02319-MAS02155,Hill start assistant signals-EPB error status,passive,
IDE02538,Longitude Acceleration Sensor,-0.19, m/s²
IDE02611-MAS02964,Incline angle of parking brake-Angle value,-1.00, %
IDE02611-MAS09580,Incline angle of parking brake-Sensor status,valid value,
IDE02612-MAS01849,Parking brake tensioning force attained-Left,15500, N
IDE02612-MAS01850,Parking brake tensioning force attained-Right,15500, N
IDE02613,Status of parking brake button,Not operated,
IDE02626,Coding dynamic steering in ESP,Not coded,
IDE02656-MAS00128,System condition of parking brake-Distance Regulation,coded,
IDE02656-MAS01090,System condition of parking brake-Transmission,automatic,
IDE02656-MAS02575,System condition of parking brake-Initiation,will be performed.,
IDE02656-MAS02665,System condition of parking brake-Automatic closing at button malfunction,not active,
IDE02656-MAS02666,System condition of parking brake-Seat belt buckle scan,active,
IDE02656-MAS02669,System condition of parking brake-Automatic closing with engine off (key),not active,
IDE02656-MAS02670,System condition of parking brake-Gradual release of brake,not active,
IDE02656-MAS02672,System condition of parking brake-Start-stop,active,
IDE02656-MAS12067,System condition of parking brake-After automatic closing of the parking brake,Driver side door contact and belt switch,
IDE02656-MAS12068,System condition of parking brake-After manual closing of the parking brake,Driver side door contact and belt switch,
IDE02659-MAS01849,Parking brake status-Left,closed,
IDE02659-MAS01850,Parking brake status-Right,closed,
IDE03008-MAS04511,Stop process prevented-Skidding vehicle detected,not active,
IDE03008-MAS04512,Stop process prevented-Hard deceleration to standstill,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04514,Stop process prevented-Button for hill descent assist operated,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03008-MAS04516,Stop process prevented-ESP/ASR button pressed,not active,
IDE03008-MAS04594,Stop process prevented-Road inclination too high,not active,
IDE03010-MAS04511,Number of prevented stop processes-Skidding vehicle detected,0,
IDE03010-MAS04512,Number of prevented stop processes-Hard deceleration to standstill,1,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04514,Number of prevented stop processes-Button for hill descent assist operated,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS04516,Number of prevented stop processes-ESP/ASR button pressed,0,
IDE03010-MAS04594,Number of prevented stop processes-Road inclination too high,0,
IDE03011-MAS04511,Number of requested start processes-Skidding vehicle detected,0,
IDE03011-MAS04514,Number of requested start processes-Button for hill descent assist operated,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03011-MAS04516,Number of requested start processes-ESP/ASR button pressed,0,
IDE03315-MAS01000,Warnings-Warning text,0,
IDE03315-MAS01911,Warnings-Tone sensor,OFF,
IDE03315-MAS02590,Warnings-Red warning light,OFF,
IDE03315-MAS02591,Warnings-Yellow warning light,OFF,
IDE03315-MAS02592,Warnings-Red operating lamp,On,
IDE03315-MAS02593,Warnings-Green operating lamp,OFF,
IDE03315-MAS02594,Warnings-Indicator light in switch,On,
IDE03316-MAS02595,Deceleration: setpoint-Deceleration,0.00, m/s²
IDE03317,Transmission range gear recognition switch,Neutral,
IDE03491,Hydraulic pump run-on time,75, ms
IDE03493-MAS11867,Driver's door status-Driver door status: qualification,No malfunction,
IDE03493-MAS11868,Driver's door status-Driver door status,For,
IDE03680-MAS12015,Supply voltages-Terminal 30 for electronics,14.35, V
IDE03680-MAS12064,Supply voltages-Return pump,14.43, V
IDE03680-MAS12065,Supply voltages-ABS valves,14.35, V
IDE04253,Sys status of tire press monitoring display,5F 20,
IDE04451-IDE02763,Tire press monitoring display indictor lamp-System malfunction lamp: status,passive,
IDE04451-IDE02765,Tire press monitoring display indictor lamp-Pressure warning lamp: status,passive,
IDE04604-MAS02472,Accelerator pedal travel-Qualification bit,OFF,
IDE04604,Accelerator pedal travel,0.00, %
IDE05712,AUTO HOLD,Initialization/not installed,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,9,
IDE06307-MAS00108,Stop prevention history data-Day,24,
IDE06307-MAS00109,Stop prevention history data-Hours,9,
IDE06307-MAS00110,Stop prevention history data-Minutes,58,
IDE06307-MAS00111,Stop prevention history data-Seconds,59,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Hard deceleration to standstill,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Button for hill descent assist operated,
IDE06308,Start request history data,Roll back detection,
IDE06308,Start request history data,ESP/ASR button pressed,
IDE06308,Start request history data,Skidding vehicle detected,
IDE06425-MAS02832,Dynamometer mode: functional-Malfunction status,No malfunction,
IDE06752,Hill descent control button,Initialization/not installed,
IDE06921-MAS02472,Calculated vehicle speed-Qualification bit,OFF,
IDE06921,Calculated vehicle speed,0.00, km/h
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07641-MAS11138,Brake pedal position sensor-current zero point,0.12, mm
IDE07641-MAS11139,Brake pedal position sensor-calibrated zero point,0.17, mm
IDE07641-MAS11140,Brake pedal position sensor-PWM-signal: error status,No malfunction,
IDE07641-MAS11141,Brake pedal position sensor-Zero point: error status,Zero point adjusted and error-free,
IDE07641-MAS12886,Brake pedal position sensor-PWM-signal 1: raw value,20.50, %
IDE07641-MAS13158,Brake pedal position sensor-Brake pedal position: calculated,6.40, mm
IDE07905-MAS11308,Brake light switch status-"Driver braking" information from brake electronics,operated,
IDE07905-MAS11309,Brake light switch status-"Driver braking" information from brake booster,Not operated,
IDE07905-MAS11310,Brake light switch status-"Driver braking" information from brake electronics: qualif.,valid,
IDE07905-MAS11311,Brake light switch status-"Driver braking" information from brake booster: qualif.,valid,
IDE08343,Immobilizer Challenge,3C C0 3D DA,
IDE08623,OBD configuration,NO OBD,
IDE09285,Reason for tire monitoring warning,No warning display on,
IDE09286,Software version of tire monitoring display,R1409o,
IDE09287,Param. set version tire press monitoring display,DN0F,
IDE09288,Param. set tire press monitor display: checksum,E8 B0 40 A2 C7 8E AB F1,
IDE09289,Tire press monitor.display: diagnosis status,00 00 00 00,
IDE09580-MAS09177,RPM sensor: air gap-Left front: med. value,00,
IDE09580-MAS09178,RPM sensor: air gap-Left front: minimum,00,
IDE09580-MAS09179,RPM sensor: air gap-Left front: maximum,00,
IDE09580-MAS09180,RPM sensor: air gap-Right front: med. value,00,
IDE09580-MAS09181,RPM sensor: air gap-Right front: minimum,00,
IDE09580-MAS09182,RPM sensor: air gap-Right front: maximum,00,
IDE09580-MAS09183,RPM sensor: air gap-Left rear: med. value,00,
IDE09580-MAS09184,RPM sensor: air gap-Left rear: minimum,00,
IDE09580-MAS09185,RPM sensor: air gap-Left rear: maximum,00,
IDE09580-MAS09186,RPM sensor: air gap-Right rear: med. value,00,
IDE09580-MAS09187,RPM sensor: air gap-Right rear: minimum,00,
IDE09580-MAS09188,RPM sensor: air gap-Right rear: maximum,00,
IDE09581-MAS01853,RPM sensor: configuration-Left front,Sensor with rotation direction detection,
IDE09581-MAS01854,RPM sensor: configuration-Right front,Sensor with rotation direction detection,
IDE09581-MAS01855,RPM sensor: configuration-Left rear,Sensor with rotation direction detection,
IDE09581-MAS01856,RPM sensor: configuration-Right rear,Sensor with rotation direction detection,
IDE09581-MAS12016,RPM sensor: configuration-Front axle: number of terminals,48,
IDE09581-MAS12017,RPM sensor: configuration-Rear axle: number of terminals,48,
IDE10034-MAS01853,RPM sensor: overall wiring fault-Left front,0.00, %
IDE10034-MAS01854,RPM sensor: overall wiring fault-Right front,0.00, %
IDE10034-MAS01855,RPM sensor: overall wiring fault-Left rear,0.00, %
IDE10034-MAS01856,RPM sensor: overall wiring fault-Right rear,0.00, %
IDE10034-MAS09178,RPM sensor: overall wiring fault-Left front: minimum,0.00, %
IDE10034-MAS09179,RPM sensor: overall wiring fault-Left front: maximum,0.00, %
IDE10034-MAS09181,RPM sensor: overall wiring fault-Right front: minimum,0.00, %
IDE10034-MAS09182,RPM sensor: overall wiring fault-Right front: maximum,0.00, %
IDE10034-MAS09184,RPM sensor: overall wiring fault-Left rear: minimum,0.00, %
IDE10034-MAS09185,RPM sensor: overall wiring fault-Left rear: maximum,0.00, %
IDE10034-MAS09187,RPM sensor: overall wiring fault-Right rear: minimum,0.00, %
IDE10034-MAS09188,RPM sensor: overall wiring fault-Right rear: maximum,0.00, %
IDE10035-MAS09177,RPM sensor: single separation fault-Left front: med. value,0.00, µs
IDE10035-MAS09178,RPM sensor: single separation fault-Left front: minimum,0.00, %
IDE10035-MAS09179,RPM sensor: single separation fault-Left front: maximum,0.00, %
IDE10035-MAS09180,RPM sensor: single separation fault-Right front: med. value,0.00, µs
IDE10035-MAS09181,RPM sensor: single separation fault-Right front: minimum,0.00, %
IDE10035-MAS09182,RPM sensor: single separation fault-Right front: maximum,0.00, %
IDE10035-MAS09183,RPM sensor: single separation fault-Left rear: med. value,0.00, µs
IDE10035-MAS09184,RPM sensor: single separation fault-Left rear: minimum,0.00, %
IDE10035-MAS09185,RPM sensor: single separation fault-Left rear: maximum,0.00, %
IDE10035-MAS09186,RPM sensor: single separation fault-Right rear: med. value,0.00, µs
IDE10035-MAS09187,RPM sensor: single separation fault-Right rear: minimum,0.00, %
IDE10035-MAS09188,RPM sensor: single separation fault-Right rear: maximum,0.00, %
IDE10348,Trip distance data,32 00 00 00 00 00 00 00 00 00 03 00 00 00 00 57 41 55 38 45 41 46 38 32 4C 4E 30 30 34 31 34 33 2B BA 7A C7 01 85 A5 6C 00 06 00 02 00 7A 00 00,
IDE10667-MAS01447,Driving program for brake electronics-Act.val.,2,
IDE10667-MAS01448,Driving program for brake electronics-Target value,0,
IDE10667-MAS05631,Driving program for brake electronics-System status,available.,
IDE10787-MAS00106,Tire press. monitoring sys.: last warning-Year,2019, yr
IDE10787-MAS00107,Tire press. monitoring sys.: last warning-Month,9, Months
IDE10787-MAS00108,Tire press. monitoring sys.: last warning-Day,13, d
IDE10787-MAS00109,Tire press. monitoring sys.: last warning-Hours,22, H
IDE10787-MAS00110,Tire press. monitoring sys.: last warning-Minutes,10, min
IDE10787-MAS00711,Tire press. monitoring sys.: last warning-Odometer reading,0, km
IDE10787-MAS02832,Tire press. monitoring sys.: last warning-Malfunction status,02 05 00 00,
IDE10788-MAS00106,Tire press. monitoring sys.: second last warning-Year,2019, yr
IDE10788-MAS00107,Tire press. monitoring sys.: second last warning-Month,9, Months
IDE10788-MAS00108,Tire press. monitoring sys.: second last warning-Day,13, d
IDE10788-MAS00109,Tire press. monitoring sys.: second last warning-Hours,21, H
IDE10788-MAS00110,Tire press. monitoring sys.: second last warning-Minutes,28, min
IDE10788-MAS00711,Tire press. monitoring sys.: second last warning-Odometer reading,0, km
IDE10788-MAS02832,Tire press. monitoring sys.: second last warning-Malfunction status,02 05 00 00,
IDE10789-MAS00106,Tire press. monitoring sys.: third last warning-Year,2019, yr
IDE10789-MAS00107,Tire press. monitoring sys.: third last warning-Month,9, Months
IDE10789-MAS00108,Tire press. monitoring sys.: third last warning-Day,13, d
IDE10789-MAS00109,Tire press. monitoring sys.: third last warning-Hours,21, H
IDE10789-MAS00110,Tire press. monitoring sys.: third last warning-Minutes,28, min
IDE10789-MAS00711,Tire press. monitoring sys.: third last warning-Odometer reading,0, km
IDE10789-MAS02832,Tire press. monitoring sys.: third last warning-Malfunction status,02 05 00 00,
IDE10790-MAS00106,Tire press. monitoring sys.: fourth last warning-Year,2019, yr
IDE10790-MAS00107,Tire press. monitoring sys.: fourth last warning-Month,9, Months
IDE10790-MAS00108,Tire press. monitoring sys.: fourth last warning-Day,13, d
IDE10790-MAS00109,Tire press. monitoring sys.: fourth last warning-Hours,21, H
IDE10790-MAS00110,Tire press. monitoring sys.: fourth last warning-Minutes,27, min
IDE10790-MAS00711,Tire press. monitoring sys.: fourth last warning-Odometer reading,0, km
IDE10790-MAS02832,Tire press. monitoring sys.: fourth last warning-Malfunction status,02 02 00 00,
IDE10791-MAS00106,Tire press. monitoring sys.: fifth last warning-Year,2019, yr
IDE10791-MAS00107,Tire press. monitoring sys.: fifth last warning-Month,9, Months
IDE10791-MAS00108,Tire press. monitoring sys.: fifth last warning-Day,13, d
IDE10791-MAS00109,Tire press. monitoring sys.: fifth last warning-Hours,21, H
IDE10791-MAS00110,Tire press. monitoring sys.: fifth last warning-Minutes,20, min
IDE10791-MAS00711,Tire press. monitoring sys.: fifth last warning-Odometer reading,0, km
IDE10791-MAS02832,Tire press. monitoring sys.: fifth last warning-Malfunction status,02 05 00 00,
IDE10792-MAS00106,Tire press. monitoring sys.: last calibration-Year,2020, yr
IDE10792-MAS00107,Tire press. monitoring sys.: last calibration-Month,7, Months
IDE10792-MAS00108,Tire press. monitoring sys.: last calibration-Day,16, d
IDE10792-MAS00109,Tire press. monitoring sys.: last calibration-Hours,13, H
IDE10792-MAS00110,Tire press. monitoring sys.: last calibration-Minutes,3, min
IDE10792-MAS00711,Tire press. monitoring sys.: last calibration-Odometer reading,76, km
IDE10792-MAS02201,Tire press. monitoring sys.: last calibration-Temperature,22, °C
IDE10793-MAS00106,Tire press. monitoring sys.: second last calibration-Year,2019, yr
IDE10793-MAS00107,Tire press. monitoring sys.: second last calibration-Month,9, Months
IDE10793-MAS00108,Tire press. monitoring sys.: second last calibration-Day,24, d
IDE10793-MAS00109,Tire press. monitoring sys.: second last calibration-Hours,8, H
IDE10793-MAS00110,Tire press. monitoring sys.: second last calibration-Minutes,54, min
IDE10793-MAS00711,Tire press. monitoring sys.: second last calibration-Odometer reading,6, km
IDE10793-MAS02201,Tire press. monitoring sys.: second last calibration-Temperature,17, °C
IDE10794-MAS00106,Tire press. monitoring sys.: third last calibration-Year,2019, yr
IDE10794-MAS00107,Tire press. monitoring sys.: third last calibration-Month,9, Months
IDE10794-MAS00108,Tire press. monitoring sys.: third last calibration-Day,13, d
IDE10794-MAS00109,Tire press. monitoring sys.: third last calibration-Hours,21, H
IDE10794-MAS00110,Tire press. monitoring sys.: third last calibration-Minutes,20, min
IDE10794-MAS00711,Tire press. monitoring sys.: third last calibration-Odometer reading,0, km
IDE10794-MAS02201,Tire press. monitoring sys.: third last calibration-Temperature,25, °C
IDE10795-MAS00106,Tire press. monitoring sys.: fourth last calibration-Year,2000, yr
IDE10795-MAS00107,Tire press. monitoring sys.: fourth last calibration-Month,0, Months
IDE10795-MAS00108,Tire press. monitoring sys.: fourth last calibration-Day,0, d
IDE10795-MAS00109,Tire press. monitoring sys.: fourth last calibration-Hours,0, H
IDE10795-MAS00110,Tire press. monitoring sys.: fourth last calibration-Minutes,0, min
IDE10795-MAS00711,Tire press. monitoring sys.: fourth last calibration-Odometer reading,0, km
IDE10795-MAS02201,Tire press. monitoring sys.: fourth last calibration-Temperature,0, °C
IDE10796-MAS00106,Tire press. monitoring sys.: fifth last calibration-Year,2000, yr
IDE10796-MAS00107,Tire press. monitoring sys.: fifth last calibration-Month,0, Months
IDE10796-MAS00108,Tire press. monitoring sys.: fifth last calibration-Day,0, d
IDE10796-MAS00109,Tire press. monitoring sys.: fifth last calibration-Hours,0, H
IDE10796-MAS00110,Tire press. monitoring sys.: fifth last calibration-Minutes,0, min
IDE10796-MAS00711,Tire press. monitoring sys.: fifth last calibration-Odometer reading,0, km
IDE10796-MAS02201,Tire press. monitoring sys.: fifth last calibration-Temperature,0, °C
IDE11037,Brake light switch: qualification,active,
IDE11039,Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE11040,Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,254,
IDE11041,Tire pr.monit.sys.:counter for fast press. loss: le. rr.,254,
IDE11042,Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,249,
IDE11043,Tire pr.monit.sys.: counter for slow press. loss: le. frt,255,
IDE11044,Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,255,
IDE11045,Tire pr.monit.sys.: counter for slow press. loss: le. rr.,255,
IDE11046,Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,254,
IDE11053-MAS00179,Brake light switch: signal from engine ctrl. mod.-Brake lamp switch,Brake pedal depressed,
IDE11053-MAS12083,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal,operated,
IDE11053-MAS12084,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal: qualification,valid,
IDE11053-MAS12085,Brake light switch: signal from engine ctrl. mod.-Brake pedal information: plausibility,plausible,
IDE12610-MAS00106,Wheel loose recognition: latest warning-Year,2019, yr
IDE12610-MAS00107,Wheel loose recognition: latest warning-Month,9, Months
IDE12610-MAS00108,Wheel loose recognition: latest warning-Day,13, d
IDE12610-MAS00109,Wheel loose recognition: latest warning-Hours,22, H
IDE12610-MAS00110,Wheel loose recognition: latest warning-Minutes,10, min
IDE12610-MAS00711,Wheel loose recognition: latest warning-Odometer reading,0, km
IDE12610-MAS02201,Wheel loose recognition: latest warning-Temperature,23, °C
IDE12610-MAS02832,Wheel loose recognition: latest warning-Malfunction status,00 00 00 00,
IDE12611-MAS00106,Wheel loose detection: penultimate warning-Year,2019, yr
IDE12611-MAS00107,Wheel loose detection: penultimate warning-Month,9, Months
IDE12611-MAS00108,Wheel loose detection: penultimate warning-Day,13, d
IDE12611-MAS00109,Wheel loose detection: penultimate warning-Hours,21, H
IDE12611-MAS00110,Wheel loose detection: penultimate warning-Minutes,28, min
IDE12611-MAS00711,Wheel loose detection: penultimate warning-Odometer reading,0, km
IDE12611-MAS02201,Wheel loose detection: penultimate warning-Temperature,25, °C
IDE12611-MAS02832,Wheel loose detection: penultimate warning-Malfunction status,00 00 00 00,
IDE12612-MAS00106,Wheel loose recognition: third latest warning-Year,2019, yr
IDE12612-MAS00107,Wheel loose recognition: third latest warning-Month,9, Months
IDE12612-MAS00108,Wheel loose recognition: third latest warning-Day,13, d
IDE12612-MAS00109,Wheel loose recognition: third latest warning-Hours,21, H
IDE12612-MAS00110,Wheel loose recognition: third latest warning-Minutes,28, min
IDE12612-MAS00711,Wheel loose recognition: third latest warning-Odometer reading,0, km
IDE12612-MAS02201,Wheel loose recognition: third latest warning-Temperature,25, °C
IDE12612-MAS02832,Wheel loose recognition: third latest warning-Malfunction status,00 00 00 00,
ENG04544,Accelerator_pedal_position_requested_by_driver_or_cruise_control,0.00, %
ENG04547-ENG04671,Apply Counter left_right-Left_Brake_Full_Clamping_Force,35,
ENG04547-ENG04672,Apply Counter left_right-Left_Brake_Reduced_Clamping_Force,0,
ENG04547-ENG04669,Apply Counter left_right-Right_Brake_Full_Clamping_Force,35,
ENG04547-ENG04670,Apply Counter left_right-Right_Brake_Reduced_Clamping_Force,0,
ENG04525-ENG101167,BB_Num_and_SW_Version-Base version,8506,
ENG04525-ENG101969,BB_Num_and_SW_Version-BB-No.,99072,
ENG04525-ENG98430,BB_Num_and_SW_Version-Branch 1,0100,
ENG04525-ENG98431,BB_Num_and_SW_Version-Branch 2,0000,
ENG07087-ENG04744,Bootloader_Bosch_Signature_Status-Bosch_Signature,Yes,
ENG04560-IDE04450,Brake_pressure_at_BLS_change-Brake pressure sensor 1,22.904, bar
ENG04532,BTM_Driving_with_pushed_brakes,0, s
ENG04533-MAS00106,BTM_Last_occurence_of_driving_with_pushed_brakes-Year,2000, yr
ENG04533-MAS00107,BTM_Last_occurence_of_driving_with_pushed_brakes-Month,0, Months
ENG04533-MAS00108,BTM_Last_occurence_of_driving_with_pushed_brakes-Day,0, d
ENG04530-MAS00106,BTM_Last_occurence_of_maximum_temp_FL-Year,2020, yr
ENG04530-MAS00107,BTM_Last_occurence_of_maximum_temp_FL-Month,7, Months
ENG04530-MAS00108,BTM_Last_occurence_of_maximum_temp_FL-Day,17, d
ENG04528-MAS00106,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04528-MAS00107,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Month,0, Months
ENG04528-MAS00108,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04534-MAS00106,BTM_Last_reset_of_driving_with pushed_brakes-Year,2000, yr
ENG04534-MAS00107,BTM_Last_reset_of_driving_with pushed_brakes-Month,0, Months
ENG04534-MAS00108,BTM_Last_reset_of_driving_with pushed_brakes-Day,0, d
ENG04531-MAS00106,BTM_Last_reset_of_maximum_temp_FL-Year,2000, yr
ENG04531-MAS00107,BTM_Last_reset_of_maximum_temp_FL-Month,0, Months
ENG04531-MAS00108,BTM_Last_reset_of_maximum_temp_FL-Day,0, d
ENG04529-MAS00106,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04529-MAS00107,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Month,0, Months
ENG04529-MAS00108,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04545,BTM_Maximum_temp_of_temperature_brake_FL,249.00, °C
ENG04527,BTM_Time_of_temperature_FL_greater_than_temp_limit,0, s
ENG101413,Calibration Identification,4N0379AL0856d0E$,
ENG99697,Calibration Verification Number,C0 35 6D B4,
ENG04552-ENG04693,Driver_Presence_Status-Input_Signal_A_Belt_Error,No malfunction,
ENG04552-ENG04692,Driver_Presence_Status-Input_Signal_A_Belt_Status,not selected,
ENG04552-ENG04695,Driver_Presence_Status-Input_Signal_B_Door_Error,No malfunction,
ENG04552-ENG04694,Driver_Presence_Status-Input_Signal_B_Door_Status,Open,
ENG04562-MAS02141,DSDL_VIN_Check_Status-Monitoring VIN,active,
ENG04562-ENG04743,DSDL_VIN_Check_Status-VIN_Check_Status,will be performed.,
ENG100152-ENG104003,ECUNAME-ECU,BSCM,
ENG100152,ECUNAME,BrakeSystem,
ENG04543,EDS_active_flag,passive,
ENG04539-MAS00109,Engine_off_time-Hours,11, H
ENG04539-MAS00110,Engine_off_time-Minutes,10, min
ENG04542,Engine_torque_loss,1, Nm
ENG04540,Engine_torque_with_external_intervention,509, Nm
ENG04548-ENG04677,ESC_EPBi_Dataset_Daten-ESC_DS_Compatibility_Version,1022,
ENG04548-ENG04675,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Checksums,6D 1D AB 2A,
ENG04548-ENG04673,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_LogAdr,71 0D,
ENG04548-ENG04674,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Version,D0E4,
ENG04548-ENG04676,ESC_EPBi_Dataset_Daten-ESC_SW_Compatibility_Version,1022,
ENG04548-ENG04679,ESC_EPBi_Dataset_Daten-PBC_DS_Checksums,C3 53,
ENG04548-ENG32276,ESC_EPBi_Dataset_Daten-PBC_DS_Compatibility_Version,00 1C,
ENG04548-ENG04678,ESC_EPBi_Dataset_Daten-PBC_DS_Version,0004,
ENG04548-ENG04680,ESC_EPBi_Dataset_Daten-PBC_DSSW_Compatibility_Version,00 1C,
ENG04549-ENG04682,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04681,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_CS,Correct result,
ENG04549-ENG04684,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04683,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_CS,Correct result,
ENG07646,ESC_Function_mode,1,
ENG07088-ENG07109,ESP_Charisma_interface_signals-CHA_Ziel_FahrPr_ESP,0,
ENG07088-ENG07110,ESP_Charisma_interface_signals-ESP_Charisma_FahrPr,2,
ENG07088-ENG07111,ESP_Charisma_interface_signals-ESP_Charisma_Status,Init,
ENG04523,ESP_Sensor_unit_2_lateral_acceleration_confidence_factor,5,
ENG04521,ESP_Sensor_unit_2_turn_rate_confidence_factor,5,
ENG04522,ESP_Sensor_unit_lateral_acceleration_confidence_factor,0,
ENG04524,ESP_Sensor_unit_longitudinal_acceleration_confidence_factor,0,
ENG04520,ESP_Sensor_unit_turn_rate_confidence_factor,0,
ENG04536,FIBEX_Version,0812_10,
ENG04537,Lateral_acceleration_sensor_2_minus_lateral_acceleration_sensor_1,0.19200, m/s²
ENG111914-ENG04664,NoPata-BME Last5ICs,00000000 ,
ENG111914-ENG04660,NoPata-BME ThisIC,00000000 ,
ENG111914-ENG111902,NoPata-EPB Last5ICs,00000000 ,
ENG111914-ENG111895,NoPata-EPB ThisIC,00000000 ,
ENG111914-ENG111900,NoPata-Handtaschenlogik Last5ICs,00000000 ,
ENG111914-ENG111893,NoPata-Handtaschenlogik ThisIC,00000000 ,
ENG111914-ENG111904,NoPata-LUFE Last5ICs,00000000 ,
ENG111914-ENG111897,NoPata-LUFE ThisIC,00000000 ,
ENG111914-ENG111905,NoPata-QSP Last5ICs,00000000 ,
ENG111914-ENG111898,NoPata-QSP ThisIC,00000000 ,
ENG111914-ENG04663,NoPata-SCM Last5ICs,00000000 ,
ENG111914-ENG04659,NoPata-SCM ThisIC,00000000 ,
ENG111914-ENG111906,NoPata-Spoiler Last5ICs,00000000 ,
ENG111914-ENG111899,NoPata-Spoiler ThisIC,00000000 ,
ENG111914-ENG04662,NoPata-Systemdegradation Last5ICs,00000000 ,
ENG111914-ENG04658,NoPata-Systemdegradation ThisIC,00000000 ,
ENG111914-ENG04665,NoPata-TSK Last5ICs,00000000 ,
ENG111914-ENG04661,NoPata-TSK ThisIC,00000000 ,
ENG04553,PBC_SW_Version,092_00,
ENG04526-ENG99585,Steering_angle_sensor_data-LWI_QBit_Steering_wheel_angle,active,
ENG04526-ENG100735,Steering_angle_sensor_data-LWI_QBit_sub_data,active,
ENG04526-ENG99156,Steering_angle_sensor_data-LWI_sensor_status,OK,
ENG04526-ENG04627,Steering_angle_sensor_data-LWI_sub_data_SSI,valid,
ENG07092-ENG07114,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Day,31,
ENG07092-ENG07115,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Hour,31, H
ENG07092-ENG07118,Time_Mileage_RollerBenchMode_907_Deactivation-RBM KM,1048575, km
ENG07092-ENG07116,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Minute,63, min
ENG07092-ENG07113,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Month,15, Months
ENG07092-ENG07117,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Second,63, s
ENG07092-ENG07112,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Year,2127, yr
ENG04561-ENG04713,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Day,31,
ENG04561-ENG04714,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Hour,31, H
ENG04561-ENG04717,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 KM,1048575, km
ENG04561-ENG04715,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Minute,63, min
ENG04561-ENG04712,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Month,15, Months
ENG04561-ENG04716,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Second,63, s
ENG04561-ENG04718,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Status,active,
ENG04561-ENG04711,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Year,2127, yr
ENG04561-ENG04721,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Day,31,
ENG04561-ENG04722,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Hour,31, H
ENG04561-ENG04725,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 KM,1048575, km
ENG04561-ENG04723,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Minute,63, min
ENG04561-ENG04720,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Month,15, Months
ENG04561-ENG04724,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Second,63, s
ENG04561-ENG04726,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Status,active,
ENG04561-ENG04719,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Year,2127, yr
ENG04561-ENG04729,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Day,31,
ENG04561-ENG04730,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Hour,31, H
ENG04561-ENG04733,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 KM,1048575, km
ENG04561-ENG04731,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Minute,63, min
ENG04561-ENG04728,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Month,15, Months
ENG04561-ENG04732,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Second,63, s
ENG04561-ENG04734,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Status,active,
ENG04561-ENG04727,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Year,2127, yr
ENG04561-ENG04737,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Day,31,
ENG04561-ENG04738,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Hour,31, H
ENG04561-ENG04741,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 KM,1048575, km
ENG04561-ENG04739,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Minute,63, min
ENG04561-ENG04736,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Month,15, Months
ENG04561-ENG04740,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Second,63, s
ENG04561-ENG04742,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Status,active,
ENG04561-ENG04735,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Year,2127, yr
ENG110108-ENG103252,WAU Info KL15-FlexRay Transceiver PIN,passive,
ENG110108-ENG102268,WAU Info KL15-Klemme 15 PIN,active,
ENG04535,YAW_rate_sensor_2_minus_yawrate_sensor_1,0.00000, rad/s
Elapsed Time: 00:38
blockmap-06-4M4-959-760-D_WAU8EAF82LN004143-20201024-1513.CSV
;Component:MEM-BFS       009 0044, Coding:001CB2400005BEA148438181A101A10081A100070700878700000000000000
;EV_SCMPasseSideCONTIAU736,006009,EV_SCMPasseSideCONTIAU736_AU58.rod
;Saturday,24,October,2020,15:13:56:14741
;VCID: BD2CD2BEFD82B7B3CCD-80E8
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.40, V
IDE00102,Control Module temperature,42,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,224, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,844, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,33348,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32203,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32613,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,35,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,37,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1145,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33270,
IDE06511-MAS01391,Seat height adjustment-Block 2,32768,
IDE06511-MAS02282,Seat height adjustment-Position,33218,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,1,
IDE06511-MAS04160,Seat height adjustment-Load change,21,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,502,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,32969,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32460,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32813,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,3,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,59,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,509,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33039,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32766,
IDE06683-MAS02282,Seat inclination adjustment-Position,32938,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,14,
IDE06683-MAS04160,Seat inclination adjustment-Load change,18,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,273,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,32456,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,33259,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,32911,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32945,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,32445,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,32971,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,32838,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,32593,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,33259,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,32969,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,32945,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,32445,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,32971,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,32838,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08988-MAS01390,Head restraint adjustment-Block 1,32768,
IDE08988-MAS01391,Head restraint adjustment-Block 2,33204,
IDE08988-MAS02282,Head restraint adjustment-Position,32777,
IDE08988-MAS02955,Head restraint adjustment-Engine temperature,25, °C
IDE08988-MAS03129,Head restraint adjustment-Reset counter,12,
IDE08988-MAS04160,Head restraint adjustment-Load change,27,
IDE08988-MAS04337,Head restraint adjustment-Engine current,0, A
IDE08988-MAS05370,Head restraint adjustment-Direction of movement,Not operated,
IDE08988-MAS05563,Head restraint adjustment-Norming,standardized,
IDE08988-MAS05719,Head restraint adjustment-Maximum travel,436,
IDE08988-MAS12838,Head restraint adjustment-Standardization flag,standardized,
IDE08989-MAS01390,Seat depth adjustment-Block 1,32437,
IDE08989-MAS01391,Seat depth adjustment-Block 2,32914,
IDE08989-MAS02282,Seat depth adjustment-Position,32461,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,25, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,9,
IDE08989-MAS04160,Seat depth adjustment-Load change,11,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,standardized,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,477,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,standardized,
IDE08990-MAS01390,Backrest top adjustment-Block 1,33065,
IDE08990-MAS01391,Backrest top adjustment-Block 2,32662,
IDE08990-MAS02282,Backrest top adjustment-Position,32671,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,25, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,4,
IDE08990-MAS04160,Backrest top adjustment-Load change,6,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,standardized,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,403,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,standardized,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10617-IDE07856,Valve block 1: status supply voltage-Terminal status,iO,
IDE10617-IDE10544,Valve block 1: status supply voltage-Internal Supply Voltage,13.70, V
IDE10617-MAS00043,Valve block 1: status supply voltage-Terminal 30 power supply,14.40, V
IDE10617-MAS10469,Valve block 1: status supply voltage-Raw value,190, bit
IDE10618-IDE07856,Valve block 2: status supply voltage-Terminal status,iO,
IDE10618-IDE10544,Valve block 2: status supply voltage-Internal Supply Voltage,13.50, V
IDE10618-MAS00043,Valve block 2: status supply voltage-Terminal 30 power supply,14.30, V
IDE10618-MAS10469,Valve block 2: status supply voltage-Raw value,188, bit
IDE10638-IDE00361,Pressure sensor in valve block-Ambient air pressure,54787, hPa
IDE10638-MAS03458,Pressure sensor in valve block-Differential pressure,18689, hPa
IDE10638-MAS10975,Pressure sensor in valve block-Pre-pressure chamber,7941, hPa
IDE10691-IDE03019,Pressure of airbags-Pressure in air cushions for lumbar support 1,0, hPa
IDE10691-IDE03020,Pressure of airbags-Pressure in air cushions for lumbar support 2,0, hPa
IDE10691-IDE03021,Pressure of airbags-Pressure in air cushions for lumbar support 3,60, hPa
IDE10691-IDE03022,Pressure of airbags-Pressure in air cushions for left side bolster,0, hPa
IDE10691-IDE03023,Pressure of airbags-Pressure in air cushions for right side bolster,0, hPa
IDE10691-IDE03024,Pressure of airbags-Pressure in air cushions for left seatback bolster,0, hPa
IDE10691-IDE03025,Pressure of airbags-Pressure in air cushions for right seatback bolster,0, hPa
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,standardized,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,standardized,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,standardized,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,32768,
IDE11024-MAS01391,Headrest height adjustment-Block 2,33204,
IDE11024-MAS02282,Headrest height adjustment-Position,32777,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,25, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,12,
IDE11024-MAS04160,Headrest height adjustment-Load change,27,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,standardized,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,436,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,standardized,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
IDE12721-MAS15042,Pressure of airbags 2-Pressure in air cushion 1 in tilt adjustable foot rest,0, hPa
IDE12721-MAS15043,Pressure of airbags 2-Pressure in air cushion 2 in tilt adjustable foot rest,0, hPa
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,standardized,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,standardized,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,standardized,
ENG08879-IDE06510,Account_1-Adjustment for backrest angle,0,
ENG08879-IDE06511,Account_1-Seat height adjustment,0,
ENG08879-IDE06512,Account_1-Adjustment for seat forward/back position,0,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,0,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG08879-IDE08989,Account_1-Seat depth adjustment,0,
ENG08879-IDE08990,Account_1-Backrest top adjustment,0,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,0,
ENG08880-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG08880-IDE06511,Account_2-Seat height adjustment,0,
ENG08880-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,0,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG08881-IDE06511,Account_3-Seat height adjustment,0,
ENG08881-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,0,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Achse decodiert,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Normierroutine,
ENG05258-ENG05273,Entnormierursache-Axis_6,Normierroutine,
ENG05258-ENG05274,Entnormierursache-Axis_7,Normierroutine,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Achse decodiert,
ENG116729-ENG117054,info_developer-ax_da,80 2D 7E CC 80 C9 00 07 7F 65 7D CB 82 44 00 07 81 C2 80 00 81 F6 00 07 80 AA 7F FE 81 0F 00 07 7E CD 7E B5 80 92 00 07 80 09 80 00 81 B4 00 07 7F 9F 7F 96 81 29 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG116729-ENG117006,info_developer-gl_lo,34 4D 34 39 35 39 37 36 30 44 20 00 00 00 00 00 30 30 34 32 00 00 00 00 31 38 32 35 00 00 00 00 53 43 58 44 35 4B 4F 4D 46 4F 52 54 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 0A 04 04 04 04 04 04 04 02 02 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,not active,
ENG26210-ENG30378,Maximum travel-Axis_1_current,509,
ENG26210-ENG30379,Maximum travel-Axis_1_last,509,
ENG26210-ENG30380,Maximum travel-Axis_10_current,65535,
ENG26210-ENG30381,Maximum travel-Axis_10_last,0,
ENG26210-ENG30382,Maximum travel-Axis_2_current,1145,
ENG26210-ENG30383,Maximum travel-Axis_2_last,1145,
ENG26210-ENG30384,Maximum travel-Axis_3_current,502,
ENG26210-ENG30385,Maximum travel-Axis_3_last,501,
ENG26210-ENG30386,Maximum travel-Axis_4_current,273,
ENG26210-ENG30387,Maximum travel-Axis_4_last,273,
ENG26210-ENG30388,Maximum travel-Axis_5_current,477,
ENG26210-ENG30389,Maximum travel-Axis_5_last,0,
ENG26210-ENG30390,Maximum travel-Axis_6_current,436,
ENG26210-ENG30391,Maximum travel-Axis_6_last,436,
ENG26210-ENG30392,Maximum travel-Axis_7_current,403,
ENG26210-ENG30393,Maximum travel-Axis_7_last,0,
ENG26210-ENG30394,Maximum travel-Axis_8_current,65535,
ENG26210-ENG30395,Maximum travel-Axis_8_last,0,
ENG26210-ENG30396,Maximum travel-Axis_9_current,65535,
ENG26210-ENG30397,Maximum travel-Axis_9_last,0,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG05280-ENG05370,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_SBC,67, bit
ENG05280-ENG05376,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_Ventil_high,50, bit
ENG05280-ENG05373,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_Ventil_low,51, bit
ENG05280-ENG05372,Multikontur_LP_Temp_IVB-p_Status_Temp_SBC,iO,
ENG05280-ENG05378,Multikontur_LP_Temp_IVB-p_Status_Temp_Ventil_high,iO,
ENG05280-ENG05375,Multikontur_LP_Temp_IVB-p_Status_Temp_Ventil_low,iO,
ENG05280-ENG05371,Multikontur_LP_Temp_IVB-p_Temp_SBC,40, °C
ENG05280-ENG05377,Multikontur_LP_Temp_IVB-p_Temp_Ventil_high,30, °C
ENG05280-ENG05374,Multikontur_LP_Temp_IVB-p_Temp_Ventil_low,30, °C
ENG05281-ENG05370,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_SBC,59, bit
ENG05281-ENG05376,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_Ventil_high,47, bit
ENG05281-ENG05373,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_Ventil_low,49, bit
ENG05281-ENG05372,Multikontur_LP_Temp_MSG-p_Status_Temp_SBC,iO,
ENG05281-ENG05378,Multikontur_LP_Temp_MSG-p_Status_Temp_Ventil_high,iO,
ENG05281-ENG05375,Multikontur_LP_Temp_MSG-p_Status_Temp_Ventil_low,iO,
ENG05281-ENG05371,Multikontur_LP_Temp_MSG-p_Temp_SBC,35, °C
ENG05281-ENG05377,Multikontur_LP_Temp_MSG-p_Temp_Ventil_high,28, °C
ENG05281-ENG05374,Multikontur_LP_Temp_MSG-p_Temp_Ventil_low,29, °C
ENG05284-ENG05394,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_mitte,0, ms
ENG05284-ENG05393,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_oben,0, ms
ENG05284-ENG05395,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_unten,0, ms
ENG05284-ENG05397,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_SHK,0, ms
ENG05284-ENG05396,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_SHL,0, ms
ENG05284-ENG05399,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_mitte,0, ms
ENG05284-ENG05398,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_oben,0, ms
ENG05284-ENG05400,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_unten,0, ms
ENG05284-ENG05402,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_SHK,0, ms
ENG05284-ENG05401,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_SHL,0, ms
ENG05284-ENG05421,Multikontur_Selbstteststatus_IVB-p_Ergebnis,nicht aktiv und kein Fehler,
ENG05284-ENG05411,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD mitte,0, hPa
ENG05284-ENG05410,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD_oben,0, hPa
ENG05284-ENG05412,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD_unten,0, hPa
ENG05284-ENG05415,Multikontur_Selbstteststatus_IVB-p_Leckage_SHK_links,0, hPa
ENG05284-ENG05416,Multikontur_Selbstteststatus_IVB-p_Leckage_SHK_rechts,0, hPa
ENG05284-ENG05413,Multikontur_Selbstteststatus_IVB-p_Leckage_SHL_links,0, hPa
ENG05284-ENG05414,Multikontur_Selbstteststatus_IVB-p_Leckage_SHL_rechts,0, hPa
ENG05284-ENG05418,Multikontur_Selbstteststatus_IVB-p_Leckage_Vordruckkammer,0, hPa
ENG05284-ENG05419,Multikontur_Selbstteststatus_IVB-p_Leiterplattentemperatur,0, °C
ENG05284-ENG05404,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_mitte,0, hPa
ENG05284-ENG05403,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_oben,0, hPa
ENG05284-ENG05405,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_unten,0, hPa
ENG05284-ENG05408,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHK_links,0, hPa
ENG05284-ENG05409,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHK_rechts,0, hPa
ENG05284-ENG05406,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHL_links,0, hPa
ENG05284-ENG05407,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHL_rechts,0, hPa
ENG05284-ENG05417,Multikontur_Selbstteststatus_IVB-p_Startdruck_Vordruckkammer,0, hPa
ENG05284-ENG05420,Multikontur_Selbstteststatus_IVB-p_Status,inaktiv,
ENG05284-ENG32230,Multikontur_Selbstteststatus_IVB-p_Status_2,Lordose oben,
ENG05284-ENG32231,Multikontur_Selbstteststatus_IVB-p_Status_3,inaktiv,
ENG05284-ENG32232,Multikontur_Selbstteststatus_IVB-p_Status_4,Lordose oben,
ENG26986-ENG30413,Multikontur_Selbstteststatus_IVB_NFA-Blase,not active,
ENG26986-ENG30414,Multikontur_Selbstteststatus_IVB_NFA-Blase bei 1. Fehlerfall,not active,
ENG26986-ENG32222,Multikontur_Selbstteststatus_IVB_NFA-p_Befuellzeit_NFA,0, ms
ENG26986-ENG32223,Multikontur_Selbstteststatus_IVB_NFA-p_Entlueftzeit_NFA,0, ms
ENG26986-ENG05421,Multikontur_Selbstteststatus_IVB_NFA-p_Ergebnis,nicht aktiv und kein Fehler,
ENG26986-ENG32224,Multikontur_Selbstteststatus_IVB_NFA-p_Leckage_NFA_Blase_1,0, hPa
ENG26986-ENG32225,Multikontur_Selbstteststatus_IVB_NFA-p_Leckage_NFA_Blase_2,0, hPa
ENG26986-ENG32227,Multikontur_Selbstteststatus_IVB_NFA-p_Startdruck_LRD_Blase_2,0, hPa
ENG26986-ENG32228,Multikontur_Selbstteststatus_IVB_NFA-p_Startdruck_NFA_Blase_1,0, hPa
ENG26986-ENG32229,Multikontur_Selbstteststatus_IVB_NFA-p_Status_1,not active,
ENG26986-ENG32541,Multikontur_Selbstteststatus_IVB_NFA-Selbsttest Testschritt,not active,
ENG05285-ENG05422,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_1,0, ms
ENG05285-ENG05431,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_10,0, ms
ENG05285-ENG05423,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_2,0, ms
ENG05285-ENG05424,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_3,0, ms
ENG05285-ENG05425,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_4,0, ms
ENG05285-ENG05426,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_5,0, ms
ENG05285-ENG05427,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_6,0, ms
ENG05285-ENG05428,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_7,0, ms
ENG05285-ENG05429,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_8,0, ms
ENG05285-ENG05430,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_9,0, ms
ENG05285-ENG05432,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_1,0, hPa
ENG05285-ENG05441,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_10,0, hPa
ENG05285-ENG05433,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_2,0, hPa
ENG05285-ENG05434,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_3,0, hPa
ENG05285-ENG05435,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_4,0, hPa
ENG05285-ENG05436,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_5,0, hPa
ENG05285-ENG05437,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_6,0, hPa
ENG05285-ENG05438,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_7,0, hPa
ENG05285-ENG05439,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_8,0, hPa
ENG05285-ENG05440,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_9,0, hPa
ENG05285-ENG05421,Multikontur_Selbstteststatus_MSG-p_Ergebnis,nicht aktiv und kein Fehler,
ENG05285-ENG05419,Multikontur_Selbstteststatus_MSG-p_Leiterplattentemperatur,0, °C
ENG05285-ENG05420,Multikontur_Selbstteststatus_MSG-p_Status,inaktiv,
ENG05285-ENG32230,Multikontur_Selbstteststatus_MSG-p_Status_2,0,
ENG05285-ENG32231,Multikontur_Selbstteststatus_MSG-p_Status_3,inaktiv,
ENG05285-ENG32232,Multikontur_Selbstteststatus_MSG-p_Status_4,0,
ENG26987-ENG05422,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_1,0, ms
ENG26987-ENG05431,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_10,0, ms
ENG26987-ENG05423,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_2,0, ms
ENG26987-ENG05424,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_3,0, ms
ENG26987-ENG05425,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_4,0, ms
ENG26987-ENG05426,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_5,0, ms
ENG26987-ENG05427,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_6,0, ms
ENG26987-ENG05428,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_7,0, ms
ENG26987-ENG05429,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_8,0, ms
ENG26987-ENG05430,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_9,0, ms
ENG26987-ENG05432,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_1,0, hPa
ENG26987-ENG05441,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_10,0, hPa
ENG26987-ENG05433,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_2,0, hPa
ENG26987-ENG05434,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_3,0, hPa
ENG26987-ENG05435,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_4,0, hPa
ENG26987-ENG05436,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_5,0, hPa
ENG26987-ENG05437,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_6,0, hPa
ENG26987-ENG05438,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_7,0, hPa
ENG26987-ENG05439,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_8,0, hPa
ENG26987-ENG05440,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_9,0, hPa
ENG26987-ENG05421,Multikontur_Selbstteststatus_MSG_2-p_Ergebnis,nicht aktiv und kein Fehler,
ENG26987-ENG05419,Multikontur_Selbstteststatus_MSG_2-p_Leiterplattentemperatur,0, °C
ENG26987-ENG05420,Multikontur_Selbstteststatus_MSG_2-p_Status,inaktiv,
ENG26987-ENG32230,Multikontur_Selbstteststatus_MSG_2-p_Status_2,0,
ENG26987-ENG32231,Multikontur_Selbstteststatus_MSG_2-p_Status_3,inaktiv,
ENG26987-ENG32232,Multikontur_Selbstteststatus_MSG_2-p_Status_4,0,
ENG05282-ENG05379,Multikontur_Statistik_IVB-p_Ventil_1,49, counts
ENG05282-ENG05388,Multikontur_Statistik_IVB-p_Ventil_10,109, counts
ENG05282-ENG05389,Multikontur_Statistik_IVB-p_Ventil_11,109, counts
ENG05282-ENG05390,Multikontur_Statistik_IVB-p_Ventil_12,110, counts
ENG05282-ENG05391,Multikontur_Statistik_IVB-p_Ventil_13,110, counts
ENG05282-ENG05392,Multikontur_Statistik_IVB-p_Ventil_14,111, counts
ENG05282-ENG05380,Multikontur_Statistik_IVB-p_Ventil_2,89, counts
ENG05282-ENG05381,Multikontur_Statistik_IVB-p_Ventil_3,101, counts
ENG05282-ENG05382,Multikontur_Statistik_IVB-p_Ventil_4,21, counts
ENG05282-ENG05383,Multikontur_Statistik_IVB-p_Ventil_5,24, counts
ENG05282-ENG05384,Multikontur_Statistik_IVB-p_Ventil_6,24, counts
ENG05282-ENG05385,Multikontur_Statistik_IVB-p_Ventil_7,22, counts
ENG05282-ENG05386,Multikontur_Statistik_IVB-p_Ventil_8,130, counts
ENG05282-ENG05387,Multikontur_Statistik_IVB-p_Ventil_9,110, counts
ENG05283-ENG05379,Multikontur_Statistik_MSG-p_Ventil_1,24, counts
ENG05283-ENG05388,Multikontur_Statistik_MSG-p_Ventil_10,31, counts
ENG05283-ENG05380,Multikontur_Statistik_MSG-p_Ventil_2,34, counts
ENG05283-ENG05381,Multikontur_Statistik_MSG-p_Ventil_3,19, counts
ENG05283-ENG05382,Multikontur_Statistik_MSG-p_Ventil_4,0, counts
ENG05283-ENG05383,Multikontur_Statistik_MSG-p_Ventil_5,0, counts
ENG05283-ENG05384,Multikontur_Statistik_MSG-p_Ventil_6,9, counts
ENG05283-ENG05385,Multikontur_Statistik_MSG-p_Ventil_7,9, counts
ENG05283-ENG05386,Multikontur_Statistik_MSG-p_Ventil_8,16, counts
ENG05283-ENG05387,Multikontur_Statistik_MSG-p_Ventil_9,39, counts
ENG26988-ENG05379,Multikontur_Statistik_MSG2-p_Ventil_1,0, counts
ENG26988-ENG05388,Multikontur_Statistik_MSG2-p_Ventil_10,0, counts
ENG26988-ENG05380,Multikontur_Statistik_MSG2-p_Ventil_2,0, counts
ENG26988-ENG05381,Multikontur_Statistik_MSG2-p_Ventil_3,0, counts
ENG26988-ENG05382,Multikontur_Statistik_MSG2-p_Ventil_4,0, counts
ENG26988-ENG05383,Multikontur_Statistik_MSG2-p_Ventil_5,0, counts
ENG26988-ENG05384,Multikontur_Statistik_MSG2-p_Ventil_6,0, counts
ENG26988-ENG05385,Multikontur_Statistik_MSG2-p_Ventil_7,0, counts
ENG26988-ENG05386,Multikontur_Statistik_MSG2-p_Ventil_8,0, counts
ENG26988-ENG05387,Multikontur_Statistik_MSG2-p_Ventil_9,0, counts
ENG05288-ENG05446,p_Fehlerspeicher-p_Drucksensorfehler,Unknown (10),
ENG05288-ENG05448,p_Fehlerspeicher-p_DTC__Uebertemp 2,Unknown (21),
ENG05288-ENG05444,p_Fehlerspeicher-p_DTC_Ueberspannung,Unknown (104),
ENG05288-ENG05443,p_Fehlerspeicher-p_ECU_defekt,iO,
ENG05288-ENG05451,p_Fehlerspeicher-p_Grobleck_V1,p_aktuell_vorhanden,
ENG05288-ENG05454,p_Fehlerspeicher-p_Grobleck_V2,p_aktuell_vorhanden,
ENG05288-ENG05457,p_Fehlerspeicher-p_Grobleck_V3,p_aktuell_vorhanden,
ENG05288-ENG05460,p_Fehlerspeicher-p_Grobleck_V4,p_aktuell_vorhanden,
ENG05288-ENG05463,p_Fehlerspeicher-p_Grobleck_V5,p_aktuell_vorhanden,
ENG05288-ENG05466,p_Fehlerspeicher-p_Grobleck_V6,p_aktuell_vorhanden,
ENG05288-ENG05469,p_Fehlerspeicher-p_Grobleck_V7,p_aktuell_vorhanden,
ENG05288-ENG05447,p_Fehlerspeicher-p_Kompressor_pneumatisch,p_aktuell_vorhanden,
ENG05288-ENG05450,p_Fehlerspeicher-p_Neg_Leck_V1,Unknown (21),
ENG05288-ENG05453,p_Fehlerspeicher-p_Neg_Leck_V2,p_aktuell_vorhanden,
ENG05288-ENG05456,p_Fehlerspeicher-p_Neg_Leck_V3,p_aktuell_vorhanden,
ENG05288-ENG05459,p_Fehlerspeicher-p_Neg_Leck_V4,p_aktuell_vorhanden,
ENG05288-ENG05462,p_Fehlerspeicher-p_Neg_Leck_V5,p_aktuell_vorhanden,
ENG05288-ENG05465,p_Fehlerspeicher-p_Neg_Leck_V6,p_aktuell_vorhanden,
ENG05288-ENG05468,p_Fehlerspeicher-p_Neg_Leck_V7,p_aktuell_vorhanden,
ENG05288-ENG05449,p_Fehlerspeicher-p_Pos_Leck_V1,p_aktuell_vorhanden,
ENG05288-ENG05452,p_Fehlerspeicher-p_Pos_Leck_V2,p_aktuell_vorhanden,
ENG05288-ENG05455,p_Fehlerspeicher-p_Pos_Leck_V3,p_aktuell_vorhanden,
ENG05288-ENG05458,p_Fehlerspeicher-p_Pos_Leck_V4,p_aktuell_vorhanden,
ENG05288-ENG05461,p_Fehlerspeicher-p_Pos_Leck_V5,p_aktuell_vorhanden,
ENG05288-ENG05464,p_Fehlerspeicher-p_Pos_Leck_V6,p_aktuell_vorhanden,
ENG05288-ENG05467,p_Fehlerspeicher-p_Pos_Leck_V7,p_aktuell_vorhanden,
ENG05288-ENG05445,p_Fehlerspeicher-p_Unterspannung_DTC,p_aktuell_vorhanden,
ENG27019-ENG109828,p_overcurrent_slaves-Value_1,0,
ENG27019-ENG109829,p_overcurrent_slaves-Value_2,0,
ENG05286-ENG05442,p_SW_Date_IVB-p_SW-Date_ASCII,01 02 14 11 0A 32,
ENG05287-ENG05442,p_SW_Date_MSG-p_SW-Date_ASCII,0C 0A 14 10 10 21,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,144,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32777,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32777,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32671,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,32613,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,33218,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,32813,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32938,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32461,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,not active,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:27
blockmap-09-4N0-907-063-FE_WAU8EAF82LN004143-20201024-1514.CSV
;Component:BCM1 MLBevo   H10 0690, Coding:07500363E0691CCD070E57A81CEA9C2A131BB7111406009381000A000001160008690002001000000000070700470818180210304401F107000000000000000000
;EV_BCM1BOSCHAU651,016011,EV_BCM1BOSCHAU651_016.rod
;Saturday,24,October,2020,15:14:28:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: F6BE0D92983424EBCD7-80A2
Group,Description,Actual
IDE00025,Coolant temperature,68.40, °C
IDE00198,Refrigerant pressure,8.40, bar
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00970,Coolant fan activation: actual value,44.10, %
IDE00971,Coolant fan activation: specified value,44.10, %
IDE00972,Idle speed increase,not active,
IDE00983,Inside temperature,26.50, °C
IDE01063,Status of recirculation air,Automatic recirc. deactivated,
IDE01068,Rear blower voltage: actual value,4.70, V
IDE01069,Rear blower voltage: specified value,4.80, V
IDE01076,Time since ignition off,5, min
IDE01164-MAS06614,Parking aid button-Variant,Local data bus: operating unit 2,
IDE01164-MAS07693,Parking aid button-Button Status,Not operated,
IDE01164-MAS07694,Parking aid button-Button status on CAN,Not operated,
IDE01164-MAS07699,Parking aid button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Parking aid button-Indicator lamp activation,OFF,
IDE01227,Blower current,1.00, A
IDE01229,Blower current of rear fresh air blower,1.00, A
IDE01230,Control module for rear fresh air blower: temperature,31, °C
IDE01241,Position sensor in left side vent: voltage,not coded/not installed,
IDE01243,Position sensor in right side vent: voltage,not coded/not installed,
IDE01245,Position sensor in left center vent: voltage,not coded/not installed,
IDE01247,Position sensor in right center vent: voltage,not coded/not installed,
IDE01249,Left rear upper body vent position sensor: voltage,not coded/not installed,
IDE01251,Right rear upper body vent position sensor: voltage,not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,not coded/not installed,
IDE01266-MAS07806,Coolant shut-off valve-Specified status,not coded/not installed,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),not coded/not installed,
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,0,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,Not available,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,valid,
IDE01287,Counter of compressor switch-offs,0,
IDE01309,Recirculation air flap motor: actual value,10645,
IDE01311,Left side vent flap motor: actual value,11670,
IDE01312,Right side vent flap motor: actual value,11326,
IDE01313,Left footwell flap motor: actual value,10000,
IDE01314,Right footwell flap motor: actual value,10000,
IDE01315,Left center vent flap motor: actual value,10939,
IDE01316,Right center vent flap motor: actual value,10000,
IDE01319,Rear temperature flap motor: actual value,10000,
IDE01320,Rear air volume flap motor: actual value,10315,
IDE01321,Defrost flap motor for left side window: actual value,11048,
IDE01322,Defrost flap motor for right side window: actual value,11263,
IDE01323,Left rear upper body vent motor: actual value,11155,
IDE01324,Right rear upper body vent motor: actual value,11312,
IDE01325,Left B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01326,Right B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,Move flap motor,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating condition,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,blockage,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01332-IDE09056,Left footwell flap motor: diagnostic-Last operating state,blockage,
IDE01332-MAS01458,Left footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01333-IDE09056,Right footwell flap motor: diagnostic-Last operating state,blockage,
IDE01333-MAS01458,Right footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01334-IDE09056,Left center vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01334-MAS01458,Left center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01335-IDE09056,Right center vent flap motor: diagnostic-Last operating state,blockage,
IDE01335-MAS01458,Right center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01338-IDE09056,Rear temperature flap motor: diagnosis-Last operating state,Engine start,
IDE01338-MAS01458,Rear temperature flap motor: diagnosis-Operating condition,No routine started,
IDE01339-IDE09056,Rear air volume flap motor: diagnosis-Last operating state,Move flap motor,
IDE01339-MAS01458,Rear air volume flap motor: diagnosis-Operating condition,No routine started,
IDE01340-IDE09056,Defrost flap motor for left side window: diagnostic-Last operating state,Engine start,
IDE01340-MAS01458,Defrost flap motor for left side window: diagnostic-Operating condition,No routine started,
IDE01341-IDE09056,Defrost flap motor for right side window: diagnostic-Last operating state,Engine start,
IDE01341-MAS01458,Defrost flap motor for right side window: diagnostic-Operating condition,No routine started,
IDE01342-IDE09056,Left rear upper body vent motor: diagnostic-Last operating state,Move flap motor,
IDE01342-MAS01458,Left rear upper body vent motor: diagnostic-Operating condition,No routine started,
IDE01343-IDE09056,Right rear upper body vent motor: diagnostic-Last operating state,Move flap motor,
IDE01343-MAS01458,Right rear upper body vent motor: diagnostic-Operating condition,No routine started,
IDE01344-IDE09056,Left B-pillar shut-off flap motor: diagnostic-Last operating state,Engine start,
IDE01344-MAS01458,Left B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01345-IDE09056,Right B-pillar shut-off flap motor: diagnostic-Last operating state,Engine start,
IDE01345-MAS01458,Right B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01352,Temperature unit,°F,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Compressor active: no shut-off condition is present,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor active: no shut-off condition is present,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10305,
IDE01427,Right temperature flap motor: actual value,10261,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,Engine start,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating condition,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,Move flap motor,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,Move flap motor,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01433,Air quality status,Clean air,
IDE01455,Key number,2,
IDE01488-MAS01458,Auxiliary heating retrofit without CAN-Operating condition,not coded/not installed,
IDE01488-MAS05773,Auxiliary heating retrofit without CAN-Voltage of signal line,not coded/not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,not coded/not installed,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,29.20, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,26.90, °C
IDE01540-MAS07052,Left front heated seat-Setting,Not available,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,7.44, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,6.90, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Not available,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.02, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,not coded/not installed,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,30.00, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,27.70, °C
IDE01541-MAS07052,Right front heated seat-Setting,Not available,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,7.25, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,6.72, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Not available,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-IDE01270,Auxiliary Air Heater-Enabling for auxiliary heater operation,not coded/not installed,
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07913,Auxiliary Air Heater-Heating stage: current value,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01622,Fresh air blower: speed,1520, /min
IDE01687,Rear recirculation flap motor: actual value,10852,
IDE01688-IDE09056,Rear recirculation flap motor: diagnostic-Last operating state,Move flap motor,
IDE01688-MAS01458,Rear recirculation flap motor: diagnostic-Operating condition,No routine started,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Variant,Local data bus: operating unit 2,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,Not operated,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Not operated,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator lamp activation,OFF,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,7C 72 CC 60,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,can be reached,
IDE01992-SFT00041,Installation list: current installations-Left light control,can be reached,
IDE01992-SFT00057,Installation list: current installations-Right light control,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01992-SFT00216,Installation list: current installations-Projection module in left matrix headlamp,not attainable,
IDE01992-SFT00217,Installation list: current installations-Projection module in right matrix headlamp,not attainable,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,not attainable,
IDE01993-SFT00009,Control module reference number-Electronic central electric,Electronic central electric,
IDE01993-SFT00041,Control module reference number-Left light control,Left light control,
IDE01993-SFT00057,Control module reference number-Right light control,Right light control,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01993-SFT00216,Control module reference number-Projection module in left matrix headlamp,Projection module in left matrix headlamp,
IDE01993-SFT00217,Control module reference number-Projection module in right matrix headlamp,Projection module in right matrix headlamp,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,Central control for digital matrix light,
IDE01995-SFT00009,Control module protocol information-Electronic central electric,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Left light control,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Right light control,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE01995-SFT00216,Control module protocol information-Projection module in left matrix headlamp,ISO-TP,
IDE01995-SFT00217,Control module protocol information-Projection module in right matrix headlamp,ISO-TP,
IDE01995-SFT33232,Control module protocol information-Central control for digital matrix light,ISO-TP,
IDE02384-SFT00009,Status of event memory-Electronic central electric,OK,
IDE02384-SFT00041,Status of event memory-Left light control,OK,
IDE02384-SFT00057,Status of event memory-Right light control,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02384-SFT00216,Status of event memory-Projection module in left matrix headlamp,OK,
IDE02384-SFT00217,Status of event memory-Projection module in right matrix headlamp,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02433,Left rear temperature flap motor: actual value,10088,
IDE02434-IDE09056,Left rear temperature flap motor: diagnostic-Last operating state,No routine started,
IDE02434-MAS01458,Left rear temperature flap motor: diagnostic-Operating condition,Move flap motor,
IDE02436,Right rear temperature flap motor: actual value,10000,
IDE02437-IDE09056,Right rear temperature flap motor: diagnostic-Last operating state,blockage,
IDE02437-MAS01458,Right rear temperature flap motor: diagnostic-Operating condition,No routine started,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE02711-MAS09598,Rear wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear wiper-Error status via CAN,No error: no wiper activation,
IDE02834,Fresh air flap motor: actual value,10708,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,Move flap motor,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating condition,No routine started,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01957,Stop process prevented-Outside temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS03902,Stop process prevented-Adaptation A/C comfort stop activation,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,1,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,2,
IDE03010-MAS01957,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,360,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,670,
IDE03010-MAS03902,Number of prevented stop processes-Adaptation A/C comfort stop activation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),7,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),59,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,51,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01957,Number of requested start processes-Outside temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,0,
IDE03011-MAS03902,Number of requested start processes-Adaptation A/C comfort stop activation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03111-MAS06885,Interior lighting-Terminal 30 for interior lighting,84, %
IDE03111-MAS06886,Interior lighting-Dimming for interior lighting,0, %
IDE03111-MAS06986,Interior lighting-Footwell illumination rear,0, %
IDE03111-MAS06987,Interior lighting-Footwell illumination front,83, %
IDE03111-MAS09295,Interior lighting-Ambient lighting channel 1,not coded/not installed,
IDE03111-MAS09297,Interior lighting-Ambient illumination power supply,100, %
IDE03111-MAS12622,Interior lighting-Terminal 30 for interior lighting: current draw (effect. value),1, mA
IDE03111-MAS12623,Interior lighting-Foot well illumination: rear: current draw (effective value),0, mA
IDE03111-MAS12624,Interior lighting-Foot well illumination: front: current draw (effective value),47, mA
IDE03111-MAS12625,Interior lighting-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior lighting-Supply for ambient illumination: current draw (effective value),667, mA
IDE03111-MAS12627,Interior lighting-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03111-MAS12917,Interior lighting-Rear ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12918,Interior lighting-Rear ambient light.chan. 1: current drawn (effective value),not coded/not installed,
IDE03111-MAS12919,Interior lighting-Roof ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12920,Interior lighting-Roof ambient lighting channel 1: current drawn (effect. value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Left light control,Bus sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Right light control,Bus sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03150-SFT00216,Readiness for bus sleep mode-Projection module in left matrix headlamp,active,
IDE03150-SFT00217,Readiness for bus sleep mode-Projection module in right matrix headlamp,active,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,OFF,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,15200, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,Initialization,
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,On,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Bright,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,2172, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,At least one release missing,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03602,Left front level control system sensor,Measuring value not available,
IDE03604,Left rear level control system sensor,Measuring value not available,
IDE03620,Front jounce travel,Measuring value not available,
IDE03621,Rear jounce travel,Measuring value not available,
IDE03622,Left headlight beam adjusting motor: status,Measuring value not available,
IDE03623,Right headlight beam adjusting motor: status,Measuring value not available,
IDE03624,Left dynamic AFS light motor: specified value,Measuring value not available,
IDE03625,Right dynamic AFS light motor: specified value,Measuring value not available,
IDE03626,Left dynamic AFS light motor: status,Measuring value not available,
IDE03627,Right dynamic AFS light motor: status,Measuring value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measuring value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measuring value not available,
IDE03630,Left headlight beam adjusting motor: specified value,Measuring value not available,
IDE03631,Right headlight beam adjusting motor: specified value,Measuring value not available,
IDE03632,Left-/right hand driving switch-over,Measuring value not available,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,0.00, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,0.00, %
IDE03640,Dynamic AFS light,OFF,
IDE03662-MAS06614,ASR/ESP button-Variant,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator lamp activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Variant,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator lamp activation,not coded/not installed,
IDE03669,Status of light distribution,Measuring value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.37, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.28, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.45, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,14.10, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,14.30, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,14.37, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,14.37, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,14.35, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,14.44, V
IDE03727,Variable left front lighting specified position,Measuring value not available,
IDE03728,Variable right front lighting specified position,Measuring value not available,
IDE03788,Status of basic headlamp setting,Measuring value not available,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),Measuring value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measuring value not available,
IDE04312-IDE04095,System run time-Engine running time,475, s
IDE04312-MAS00084,System run time-Terminal 15 on,546, s
IDE04343-SFT00009,Bus identification-Electronic central electric,Bus master,
IDE04343-SFT00041,Bus identification-Left light control,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Right light control,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04343-SFT00216,Bus identification-Projection module in left matrix headlamp,AFS/From light data bus,
IDE04343-SFT00217,Bus identification-Projection module in right matrix headlamp,AFS/From light data bus,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,AFS/From light data bus,
IDE04741-MAS06614,Rear window defogger button-Variant,Local data bus: operating unit 1,
IDE04741-MAS07693,Rear window defogger button-Button Status,Not operated,
IDE04741-MAS07694,Rear window defogger button-Button status on CAN,Not operated,
IDE04741-MAS07699,Rear window defogger button-Status indicator light on CAN,OFF,
IDE04741-MAS08062,Rear window defogger button-Indicator lamp activation,OFF,
IDE04806-MAS06614,Driving profile selection button-Variant,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Variant,Local data bus: operating unit 1,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator lamp activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Variant,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator lamp activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,33.10, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,33.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,28.00, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,12.20, °C
IDE06091-MAS07055,Humidity sensor: interior-Response error,not active,
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,28.50, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,41.00, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,21.00, °C
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,24,
IDE06307-MAS00109,Stop prevention history data-Hours,15,
IDE06307-MAS00110,Stop prevention history data-Minutes,8,
IDE06307-MAS00111,Stop prevention history data-Seconds,58,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Interior temperature difference to specifications,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Interior comfort humidity too high (humidity sensor),
IDE06308,Start request history data,Fogging hazard (humidity sensor),
IDE06308,Start request history data,Maximum cooling and heating set,
IDE06308,Start request history data,Defrost active,
IDE06308,Start request history data,Adaptation A/C comfort stop activation,
IDE06308,Start request history data,Maximum permissible stop duration reached,
IDE06308,Start request history data,Dew point gradient,
IDE06308,Start request history data,Interior temperature difference to specifications,
IDE06308,Start request history data,Outside temperature,
IDE06308,Start request history data,Blowout temperature difference to specifications,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Variant,not coded/not installed,
IDE06752-MAS07693,Hill descent control button-Button Status,not coded/not installed,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Initialization/not installed,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator lamp activation,not coded/not installed,
IDE06807,Fresh-air door motor / specified value,10708,
IDE06808,Fresh-air door motor / dynamics,1221,
IDE06809,Left temp. door motor / specified value,10305,
IDE06810,Left temp. door motor / dynamics,1456,
IDE06811,Right temp. door motor: specified value,10261,
IDE06812,Right temp. door motor: dynamics,1453,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1528,
IDE06815,Recirc. air flap motor: spec.value,10661,
IDE06816,Recirc. air flap motor: dynamics,1574,
IDE06817,Rear temp. door motor: specified value,10000,
IDE06818,Rear temp. door motor: dynamics,1612,
IDE06823,Left center vent motor / specified value,11309,
IDE06824,Left center vent motor / dynamics,1008,
IDE06825,Right center vent motor: specified value,10000,
IDE06826,Right center vent motor: dynamics,1032,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07133,Fresh air blower motor: temperature,28, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07246-MAS01447,Left rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07246-MAS01448,Left rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07248-MAS01447,Left rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07248-MAS01448,Left rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07250-MAS01447,Right rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07250-MAS01448,Right rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07252-MAS01447,Right rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07252-MAS01448,Right rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07253-IDE11723,Installation info: rear seat ventilation-Fan 2 for left rear seat backrest,not installed,
IDE07253-IDE11724,Installation info: rear seat ventilation-Fan 2 for left rear seat cushion,not installed,
IDE07253-IDE11725,Installation info: rear seat ventilation-Fan 2 for right rear seat backrest,not installed,
IDE07253-IDE11726,Installation info: rear seat ventilation-Fan 2 for right rear seat cushion,not installed,
IDE07337-MAS01481,Control module for windshield washer pump: temperatures-Temperature in control module,28, °C
IDE07337-MAS11110,Control module for windshield washer pump: temperatures-Outdoor wind chill factor,23, °C
IDE07338,Control module for windshield washer pump: supply voltage,14.30, V
IDE07457,Rear air volume flap motor: spec. value,10315,
IDE07458,Rear air volume flap motor: dynamics,6304,
IDE07459,Left footwell door motor / specified value,10000,
IDE07460,Left footwell door motor: dynamics,962,
IDE07461,Right footwell door motor / specified value,10000,
IDE07462,Right footwell door motor: dynamics,969,
IDE07491,Left rear temp door motor: spec. value,10061,
IDE07492,Left rear temp door motor: dynamics,682,
IDE07493,Right rear temp door motor: spec. value,10000,
IDE07494,Right rear temp door motor: dynamics,711,
IDE07495,Left rear upper body vent motor: spec. value,11155,
IDE07496,Left rear upper body vent motor: dynamics,1481,
IDE07497,Right rear upper body vent motor: spec. value,11298,
IDE07498,Right rear upper body vent motor: dynamics,1492,
IDE07499,Left side vent flap motor: spec.value,11670,
IDE07500,Left side vent flap motor: dynamics,1670,
IDE07501,Right side vent flap motor: spec. value,11344,
IDE07502,Right side vent flap motor: dynamics,1793,
IDE07503,Rear recirc. air flap motor: spec.value,10852,
IDE07504,Rear recirc. air flap motor: dynamics,1704,
IDE07505,Left B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07506,Left B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1042,
IDE07507,Right B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07508,Right B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1083,
IDE07509,Defrost flap motor for left side window: spec. value,11048,
IDE07510,Defrost flap motor for left side window: dynamics,1048,
IDE07511,Defrost flap motor for right side window: spec. value,11263,
IDE07512,Defrost flap motor for right side window: dynamics,1263,
IDE07950-IDE04095,Historical data of motors-Engine running time,0, s
IDE07950-IDE09056,Historical data of motors-Last operating state,Unknown (31),
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,2, s
IDE07950-MAS00106,Historical data of motors-Year,2019,
IDE07950-MAS00107,Historical data of motors-Month,9,
IDE07950-MAS00108,Historical data of motors-Day,24,
IDE07950-MAS00109,Historical data of motors-Hours,13,
IDE07950-MAS00110,Historical data of motors-Minutes,50,
IDE07950-MAS00111,Historical data of motors-Seconds,49,
IDE07950-MAS01458,Historical data of motors-Operating condition,Dynamic calibration,
IDE07950-MAS03118,Historical data of motors-Logic address,127,
IDE07950-MAS03180,Historical data of motors-Local data bus,12,
IDE07950,Historical data of motors,12.20, V
IDE07991-MAS01580,A/C clutch-Activation,100, %
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,2.50, A
IDE07991-MAS12621,A/C clutch-Current draw (effective value),2217, mA
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,Open circuit/short circuit not yet recognized,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,Open circuit/short circuit not yet recognized,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left head area heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left head area heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left head area heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right head area heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right head area heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right head area heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal activation-Terminal 75 status,On,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal activation-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal activation-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,28 86 22 55,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,32, °C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,14.40, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,25, °C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,14.40, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,33, °C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,14.40, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,26, °C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,14.40, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,0, %
IDE08364-MAS01448,Left seat backrest fan 1: activation-Target value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Target value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,0, %
IDE08368-MAS01448,Right seat backrest fan 1: activation-Target value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,0, %
IDE08370-MAS01448,Right seat cushion fan 1: activation-Target value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08372,Fresh air blower: target speed,1520, /min
IDE08376-MAS01580,Right Daytime Running Lamp and Parking Light Lamp-Activation,not coded/not installed,
IDE08376-MAS01737,Right Daytime Running Lamp and Parking Light Lamp-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right Daytime Running Lamp and Parking Light Lamp-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and position lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and position lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and position lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right Front Side Marker Light-Activation,not coded/not installed,
IDE08382-MAS01737,Right Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left Front Side Marker Light-Activation,not coded/not installed,
IDE08383-MAS01737,Left Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running light lamp-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running light lamp-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running light lamp-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running light lamp-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,No malfunction,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,No malfunction,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light lamp-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light lamp-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light lamp-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light lamp-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light lamp-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light lamp-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,No malfunction,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),96, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,No malfunction,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),66, mA
IDE08402-IDE05742,Light switch-Light switch position,Not available,
IDE08402-IDE07956,Light switch-redundant signal line,OFF,
IDE08402-MAS03866,Light switch-Head-Up-Display button,Not available,
IDE08402-MAS03868,Light switch-Position of the Eyebox,Not available,
IDE08402-MAS06887,Light switch-Light switch position on CAN,Malfunction,
IDE08402-MAS06888,Light switch-Fog light button,Not available,
IDE08402-MAS06889,Light switch-Rear fog light button,Not available,
IDE08402-MAS06890,Light switch-Night vision system button,Not available,
IDE08402-MAS06891,Light switch-Control for Eyebox position,Not available,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.02, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,25.00, °C
IDE08408,Hood contact,closed,
IDE08408-MAS14040,Hood contact-Voltage ratio,98, %
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,OFF,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,not coded/not installed,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,not coded/not installed,
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),not coded/not installed,
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,37, %
IDE08502-MAS09777,A/C compressor regulator valve-Target current,381, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),384, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measuring value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,Measuring value not available,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measuring value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measuring value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,00,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,Programming not performed,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,00,
IDE08543-MAS04184,Garage door opener: last programming-Canceled by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Programming not performed,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,00,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,Programming not performed,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,00,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Canceled by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Programming not performed,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,00000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,00,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,Programming not performed,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Canceled by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Programming not performed,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,00000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,14.52, V
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08795-MAS06614,Rear shade button-Variant,not coded/not installed,
IDE08795-MAS07693,Rear shade button-Button Status,not coded/not installed,
IDE08795-MAS07694,Rear shade button-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,Not moving,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,was not local active,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,733,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,595,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,Not operated,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,Not operated,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,Not operated,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,Not operated,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,Not operated,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),0.00, A
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),0.00, A
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,14.41, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,31.60, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,45.78, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),116, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,operational,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control unit 2 for driving and convenience functions,operational,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Variant,Discreet wire,
IDE08979-MAS07693,Valet parking lock button-Button Status,Not operated,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator lamp activation,OFF,
IDE08980-MAS06614,Button for rear spoiler adjustment-Variant,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator lamp activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Variant,not coded/not installed,
IDE08981-MAS07693,Front display open/close button-Button Status,not coded/not installed,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Initialization/not installed,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Variant,not coded/not installed,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,not coded/not installed,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator lamp activation,not coded/not installed,
IDE08983-MAS06614,Driving profile selection button 2-Variant,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,No malfunction,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),1126, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,No malfunction,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),1102, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special vehicle control module-Variant,not coded/not installed,
IDE09920-MAS06992,Special vehicle control module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special vehicle control module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special vehicle control module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special vehicle control module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special vehicle control module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special vehicle control module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special vehicle control module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special vehicle control module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special vehicle control module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special vehicle control module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special vehicle control module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special vehicle control module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special vehicle control module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special vehicle control module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special vehicle control module-Suppression of interior illumination request,not coded/not installed,
IDE09922-MAS01448,Static headlamp range control-Target value,not coded/not installed,
IDE09922-MAS09527,Static headlamp range control-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlamp range control-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlamp range control-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlamp range control-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Automatic dimming interior mirror-Button Status,Not operated,
IDE09955-MAS09651,Automatic dimming interior mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Automatic dimming interior mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Automatic dimming interior mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,0, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,173,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,Not available,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,0.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,No malfunction,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,55.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,No malfunction,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),Not available,
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),Not available,
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),not coded/not installed,
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,50, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,55, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),0, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),63, mA
IDE10124-MAS07052,Front left seat heating-Setting,OFF,
IDE10124-MAS07921,Front left seat heating-Balance setting,Neutral,
IDE10124-MAS07951,Front left seat heating-Automatic down-shift,not active,
IDE10124-MAS15417,Front left seat heating-Area heating adjustment,OFF,
IDE10125-MAS07052,Front right seat heating-Setting,OFF,
IDE10125-MAS07921,Front right seat heating-Balance setting,Neutral,
IDE10125-MAS07951,Front right seat heating-Automatic down-shift,not active,
IDE10125-MAS15417,Front right seat heating-Area heating adjustment,OFF,
IDE10126-MAS07052,Rear left seat heating-Setting,OFF,
IDE10126-MAS07921,Rear left seat heating-Balance setting,Neutral,
IDE10126-MAS07951,Rear left seat heating-Automatic down-shift,not active,
IDE10126-MAS15417,Rear left seat heating-Area heating adjustment,OFF,
IDE10127-MAS07052,Rear right seat heating-Setting,OFF,
IDE10127-MAS07921,Rear right seat heating-Balance setting,Neutral,
IDE10127-MAS07951,Rear right seat heating-Automatic down-shift,not active,
IDE10127-MAS15417,Rear right seat heating-Area heating adjustment,OFF,
IDE10128-MAS01632,Front left seat cushion heating-Status,not active,
IDE10128-MAS05945,Front left seat cushion heating-Target temperature,OFF,
IDE10128-MAS05946,Front left seat cushion heating-Actual temp.,27.00, °C
IDE10128-MAS07929,Front left seat cushion heating-Power quota setting by energy management,0,
IDE10128-MAS12066,Front left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10128-MAS14067,Front left seat cushion heating-Actuation specified value,0, %
IDE10129-MAS01632,Seat backrest heater: left front-Status,not active,
IDE10129-MAS05945,Seat backrest heater: left front-Target temperature,OFF,
IDE10129-MAS05946,Seat backrest heater: left front-Actual temp.,29.00, °C
IDE10129-MAS07929,Seat backrest heater: left front-Power quota setting by energy management,0,
IDE10129-MAS12066,Seat backrest heater: left front-Cancellation status,Heating process interrupted,
IDE10129-MAS14067,Seat backrest heater: left front-Actuation specified value,0, %
IDE10130-MAS01632,Front right seat cushion heating-Status,not active,
IDE10130-MAS05945,Front right seat cushion heating-Target temperature,OFF,
IDE10130-MAS05946,Front right seat cushion heating-Actual temp.,27.00, °C
IDE10130-MAS07929,Front right seat cushion heating-Power quota setting by energy management,0,
IDE10130-MAS12066,Front right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10130-MAS14067,Front right seat cushion heating-Actuation specified value,0, %
IDE10131-MAS01632,Seat backrest heater: right front-Status,not active,
IDE10131-MAS05945,Seat backrest heater: right front-Target temperature,OFF,
IDE10131-MAS05946,Seat backrest heater: right front-Actual temp.,29.00, °C
IDE10131-MAS07929,Seat backrest heater: right front-Power quota setting by energy management,0,
IDE10131-MAS12066,Seat backrest heater: right front-Cancellation status,Heating process interrupted,
IDE10131-MAS14067,Seat backrest heater: right front-Actuation specified value,0, %
IDE10132-MAS01632,Rear left seat cushion heating-Status,not active,
IDE10132-MAS05945,Rear left seat cushion heating-Target temperature,OFF,
IDE10132-MAS05946,Rear left seat cushion heating-Actual temp.,29.00, °C
IDE10132-MAS07929,Rear left seat cushion heating-Power quota setting by energy management,0,
IDE10132-MAS12066,Rear left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10132-MAS14067,Rear left seat cushion heating-Actuation specified value,0, %
IDE10133-MAS01632,Seat backrest heater: left rear-Status,not active,
IDE10133-MAS05945,Seat backrest heater: left rear-Target temperature,OFF,
IDE10133-MAS05946,Seat backrest heater: left rear-Actual temp.,29.00, °C
IDE10133-MAS07929,Seat backrest heater: left rear-Power quota setting by energy management,0,
IDE10133-MAS12066,Seat backrest heater: left rear-Cancellation status,Heating process interrupted,
IDE10133-MAS14067,Seat backrest heater: left rear-Actuation specified value,0, %
IDE10134-MAS01632,Rear right seat cushion heating-Status,not active,
IDE10134-MAS05945,Rear right seat cushion heating-Target temperature,OFF,
IDE10134-MAS05946,Rear right seat cushion heating-Actual temp.,29.00, °C
IDE10134-MAS07929,Rear right seat cushion heating-Power quota setting by energy management,0,
IDE10134-MAS12066,Rear right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10134-MAS14067,Rear right seat cushion heating-Actuation specified value,0, %
IDE10135-MAS01632,Seat backrest heater: right rear-Status,not active,
IDE10135-MAS05945,Seat backrest heater: right rear-Target temperature,OFF,
IDE10135-MAS05946,Seat backrest heater: right rear-Actual temp.,30.00, °C
IDE10135-MAS07929,Seat backrest heater: right rear-Power quota setting by energy management,0,
IDE10135-MAS12066,Seat backrest heater: right rear-Cancellation status,Heating process interrupted,
IDE10135-MAS14067,Seat backrest heater: right rear-Actuation specified value,0, %
IDE10136-MAS01632,Front left door area heating-Status,not coded/not installed,
IDE10136-MAS05945,Front left door area heating-Target temperature,not coded/not installed,
IDE10136-MAS05946,Front left door area heating-Actual temp.,not coded/not installed,
IDE10136-MAS07929,Front left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10136-MAS12066,Front left door area heating-Cancellation status,not coded/not installed,
IDE10136-MAS14067,Front left door area heating-Actuation specified value,not coded/not installed,
IDE10138-MAS01632,Front right door area heating-Status,not coded/not installed,
IDE10138-MAS05945,Front right door area heating-Target temperature,not coded/not installed,
IDE10138-MAS05946,Front right door area heating-Actual temp.,not coded/not installed,
IDE10138-MAS07929,Front right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10138-MAS12066,Front right door area heating-Cancellation status,not coded/not installed,
IDE10138-MAS14067,Front right door area heating-Actuation specified value,not coded/not installed,
IDE10140-MAS01632,Rear left door area heating-Status,not coded/not installed,
IDE10140-MAS05945,Rear left door area heating-Target temperature,not coded/not installed,
IDE10140-MAS05946,Rear left door area heating-Actual temp.,not coded/not installed,
IDE10140-MAS07929,Rear left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10140-MAS12066,Rear left door area heating-Cancellation status,not coded/not installed,
IDE10140-MAS14067,Rear left door area heating-Actuation specified value,not coded/not installed,
IDE10142-MAS01632,Rear right door area heating-Status,not coded/not installed,
IDE10142-MAS05945,Rear right door area heating-Target temperature,not coded/not installed,
IDE10142-MAS05946,Rear right door area heating-Actual temp.,not coded/not installed,
IDE10142-MAS07929,Rear right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10142-MAS12066,Rear right door area heating-Cancellation status,not coded/not installed,
IDE10142-MAS14067,Rear right door area heating-Actuation specified value,not coded/not installed,
IDE10144-MAS01632,Front center arm rest heating-Status,not active,
IDE10144-MAS05945,Front center arm rest heating-Target temperature,OFF,
IDE10144-MAS05946,Front center arm rest heating-Actual temp.,34.00, °C
IDE10144-MAS07929,Front center arm rest heating-Power quota setting by energy management,0,
IDE10144-MAS12066,Front center arm rest heating-Cancellation status,Heating process interrupted,
IDE10144-MAS14067,Front center arm rest heating-Actuation specified value,0, %
IDE10145-MAS01632,Rear center arm rest heating-Status,not coded/not installed,
IDE10145-MAS05945,Rear center arm rest heating-Target temperature,not coded/not installed,
IDE10145-MAS05946,Rear center arm rest heating-Actual temp.,not coded/not installed,
IDE10145-MAS07929,Rear center arm rest heating-Power quota setting by energy management,not coded/not installed,
IDE10145-MAS12066,Rear center arm rest heating-Cancellation status,not coded/not installed,
IDE10145-MAS14067,Rear center arm rest heating-Actuation specified value,not coded/not installed,
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Target value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cup holder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cup holder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cup holder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cup holder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cup holder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cup holder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cup holder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cup holder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cup holder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cup holder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cup holder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,Measuring value not available,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,Measuring value not available,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,14.30, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,40, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,70, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10434,Roof electronics control module: dim. value-Indicator lamps,26, %
IDE10343-MAS10497,Roof electronics control module: dim. value-Ceiling contour lights: dim. value,0, %
IDE10343-MAS10498,Roof electronics control module: dim. value-Ceiling contour lights: diagnosis,Unknown (0),
IDE10343-MAS14264,Roof electronics control module: dim. value-Front search illumination,54, %
IDE10343-MAS14268,Roof electronics control module: dim. value-Left rear interior lamp: dimming value,0, %
IDE10343-MAS14269,Roof electronics control module: dim. value-Left rear interior light: diagnostics,No malfunction,
IDE10343-MAS14270,Roof electronics control module: dim. value-Right rear interior lamp: dimming value,0, %
IDE10343-MAS14271,Roof electronics control module: dim. value-Right rear interior lamp: diagnostics,No malfunction,
IDE10343-MAS15403,Roof electronics control module: dim. value-Front passenger airbag indicator lamp,29, %
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-IDE01097,Roof electronics control module: indicator lights-Front passenger airbag -disabled- indicator lamp,On,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10346-MAS14279,Roof electronics control module: indicator lights-Indicator lamp for emergency call: green,On,
IDE10346-MAS14280,Roof electronics control module: indicator lights-Indicator lamp for emergency call: red,OFF,
IDE10346-MAS15376,Roof electronics control module: indicator lights-Front passenger airbag indicator lamp on,OFF,
IDE10346-MAS15377,Roof electronics control module: indicator lights-Front passenger airbag lettering,On,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,6.24, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.44, kOhm
IDE10361-MAS07003,Driver information sensor-Engine Coolant Level Sensor 2,not coded/not installed,
IDE10482-MAS01632,Activation for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Activation for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Activation for external systems-Installation info.: external system,no system,
IDE10602-MAS01632,Reclining seat: lower leg support heating-Status,not coded/not installed,
IDE10602-MAS05945,Reclining seat: lower leg support heating-Target temperature,not coded/not installed,
IDE10602-MAS05946,Reclining seat: lower leg support heating-Actual temp.,not coded/not installed,
IDE10602-MAS07929,Reclining seat: lower leg support heating-Power quota setting by energy management,not coded/not installed,
IDE10602-MAS12066,Reclining seat: lower leg support heating-Cancellation status,not coded/not installed,
IDE10602-MAS14067,Reclining seat: lower leg support heating-Actuation specified value,not coded/not installed,
IDE10603-MAS01632,Reclining seat: foot sole heating-Status,not coded/not installed,
IDE10603-MAS05945,Reclining seat: foot sole heating-Target temperature,not coded/not installed,
IDE10603-MAS05946,Reclining seat: foot sole heating-Actual temp.,not coded/not installed,
IDE10603-MAS07929,Reclining seat: foot sole heating-Power quota setting by energy management,not coded/not installed,
IDE10603-MAS12066,Reclining seat: foot sole heating-Cancellation status,not coded/not installed,
IDE10603-MAS14067,Reclining seat: foot sole heating-Actuation specified value,not coded/not installed,
IDE10662-MAS00530,Light switch (button module)-Rear fog light indicator lamp,OFF,
IDE10662-MAS01632,Light switch (button module)-Status,operational,
IDE10662-MAS05451,Light switch (button module)-Low beam indicator lamp,OFF,
IDE10662-MAS06614,Light switch (button module)-Variant,Variant 1,
IDE10662-MAS06732,Light switch (button module)-Status local activity,not active,
IDE10662-MAS06888,Light switch (button module)-Fog light button,Not operated,
IDE10662-MAS06889,Light switch (button module)-Rear fog light button,Not operated,
IDE10662-MAS07055,Light switch (button module)-Response error,not active,
IDE10662-MAS07376,Light switch (button module)-Terminal 58xd,173,
IDE10662-MAS09817,Light switch (button module)-Terminal 58xs,0, %
IDE10662-MAS09820,Light switch (button module)-Terminal 58xt,55, %
IDE10662-MAS12385,Light switch (button module)-Automatic driving light control indicator lamp,On,
IDE10662-MAS12415,Light switch (button module)-Parking lamp indicator lamp,OFF,
IDE10662-MAS12416,Light switch (button module)-Daytime running lamp indicator lamp,OFF,
IDE10662-MAS12417,Light switch (button module)-Fog lights indicator lights,OFF,
IDE10662-MAS12419,Light switch (button module)-Side light button,not installed,
IDE10662-MAS12420,Light switch (button module)-Low-beam light button,not installed,
IDE10662-MAS12421,Light switch (button module)-Proximity sensor,no approach,
IDE10662-MAS14302,Light switch (button module)-Automatic high beam button/exterior lighting button,Not operated,
IDE10808-MAS06614,Directional stabilization assistance button-Variant,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator lamp activation,not coded/not installed,
IDE10809-MAS06993,Driver assistance systems control module-Request signal horn,not coded/not installed,
IDE10809-MAS13254,Driver assistance systems control module-Active parking function,not coded/not installed,
IDE10810-MAS06614,Button for side view camera-Variant,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE10945-MAS01580,Shut-off valve 1 for refrigerant-Activation,not coded/not installed,
IDE10945-MAS12621,Shut-off valve 1 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10946-MAS01580,Shut-off valve 2 for refrigerant-Activation,not coded/not installed,
IDE10946-MAS12621,Shut-off valve 2 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10964-MAS06614,Button for instrument panel vents-Variant,not coded/not installed,
IDE10964-MAS07693,Button for instrument panel vents-Button Status,not coded/not installed,
IDE10964-MAS07694,Button for instrument panel vents-Button status on CAN,Initialization/not installed,
IDE10964-MAS07699,Button for instrument panel vents-Status indicator light on CAN,OFF,
IDE10964-MAS08062,Button for instrument panel vents-Indicator lamp activation,not coded/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11348,Variable left front lighting: actual position,Measuring value not available,
IDE11349,Variable right front lighting: actual position,Measuring value not available,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,110, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,105, W/m²
IDE11361-MAS06732,Control unit for windshield washer pump-Status local activity,not active,
IDE11361-MAS12606,Control unit for windshield washer pump-Status of windshield wiper pump,not active,
IDE11361-MAS12607,Control unit for windshield washer pump-Status of wiper arm heater,not active,
IDE11361-MAS12608,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of upper change pos.,0, %
IDE11361-MAS12609,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of lower change pos.,0, %
IDE11361-MAS12610,Control unit for windshield washer pump-Activation of wiper arm heater,0, %
IDE11551-IDE01078,Status of identification data query on LIN-Bus-Fresh air blower: front,Data complete but not secured,
IDE11551-IDE06163,Status of identification data query on LIN-Bus-Humidity sensor: exterior,Data complete but not secured,
IDE11551-IDE11361,Status of identification data query on LIN-Bus-Control unit for windshield washer pump,Data complete but not secured,
IDE11551-IDE11719,Status of identification data query on LIN-Bus-Fan 1 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11720,Status of identification data query on LIN-Bus-Fan 1 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11721,Status of identification data query on LIN-Bus-Fan 1 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11722,Status of identification data query on LIN-Bus-Fan 1 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11723,Status of identification data query on LIN-Bus-Fan 2 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11724,Status of identification data query on LIN-Bus-Fan 2 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11725,Status of identification data query on LIN-Bus-Fan 2 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11726,Status of identification data query on LIN-Bus-Fan 2 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11794,Status of identification data query on LIN-Bus-Fragrance diffuser system control module,not coded/not installed,
IDE11551-IDE12358,Status of identification data query on LIN-Bus-Roof electronics control module 2,Data complete but not secured,
IDE11551-MAS00746,Status of identification data query on LIN-Bus-Wiper motor control module,Data complete but not secured,
IDE11551-MAS00747,Status of identification data query on LIN-Bus-Rain/Light Recognition Sensor,Data complete but not secured,
IDE11551-MAS00748,Status of identification data query on LIN-Bus-Light switch,Data complete but not secured,
IDE11551-MAS00749,Status of identification data query on LIN-Bus-Garage door opener control module,Data complete but not secured,
IDE11551-MAS00750,Status of identification data query on LIN-Bus-Garage door opener control head,not coded/not installed,
IDE11551-MAS00762,Status of identification data query on LIN-Bus-Automatic dimming interior mirror,Data complete but not secured,
IDE11551-MAS01562,Status of identification data query on LIN-Bus-Air quality sensor,not coded/not installed,
IDE11551-MAS08026,Status of identification data query on LIN-Bus-Control head for driving and comfort functions,Data complete but not secured,
IDE11551-MAS08027,Status of identification data query on LIN-Bus-Control unit 2 for driving and convenience functions,Data complete but not secured,
IDE11551-MAS10760,Status of identification data query on LIN-Bus-Coolant expansion valve: A/C,not coded/not installed,
IDE11551-MAS12901,Status of identification data query on LIN-Bus-Roof electronics control module,Data complete but not secured,
IDE11551-MAS12902,Status of identification data query on LIN-Bus-Adjustable Steering Column Control Module,Data complete but not secured,
IDE11551-MAS12903,Status of identification data query on LIN-Bus-Right Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12904,Status of identification data query on LIN-Bus-Left Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12905,Status of identification data query on LIN-Bus-Blower 1 for left front backrest,Data complete but not secured,
IDE11551-MAS12906,Status of identification data query on LIN-Bus-Blower 2 for left front backrest,not coded/not installed,
IDE11551-MAS12907,Status of identification data query on LIN-Bus-Blower 1 for left front seat cushion,Data complete but not secured,
IDE11551-MAS12908,Status of identification data query on LIN-Bus-Blower 2 for left front seat cushion,not coded/not installed,
IDE11551-MAS12909,Status of identification data query on LIN-Bus-Blower 1 for right front backrest,Data complete but not secured,
IDE11551-MAS12910,Status of identification data query on LIN-Bus-Blower 2 for right front backrest,not coded/not installed,
IDE11551-MAS12911,Status of identification data query on LIN-Bus-Blower 1 for right front seat cushion,Data complete but not secured,
IDE11551-MAS12912,Status of identification data query on LIN-Bus-Blower 2 for right front seat cushion,not coded/not installed,
IDE11551-MAS12913,Status of identification data query on LIN-Bus-Valve block 1 in front seat driver side,not coded/not installed,
IDE11551-MAS12914,Status of identification data query on LIN-Bus-Valve block 1 in front seat passenger side,not coded/not installed,
IDE11551-MAS12915,Status of identification data query on LIN-Bus-Cup holder with heating and cooling element,not coded/not installed,
IDE11551-MAS12916,Status of identification data query on LIN-Bus-Humidity sensor: interior,not coded/not installed,
IDE11551-MAS14926,Status of identification data query on LIN-Bus-Sensor for carbon dioxide content in the interior,not coded/not installed,
IDE11551-MAS14927,Status of identification data query on LIN-Bus-Rear A/C control and display head,Data complete but not secured,
IDE11551-MAS15174,Status of identification data query on LIN-Bus-Front A/C display control head,not coded/not installed,
IDE11551-MAS15185,Status of identification data query on LIN-Bus-Sensor for particulate matter content in the A/C,not coded/not installed,
IDE11551-MAS16271,Status of identification data query on LIN-Bus-Sensor for visibility distance measurement,not coded/not installed,
IDE11551-SFT09759,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor,not coded/not installed,
IDE11551-SFT09776,Status of identification data query on LIN-Bus-Ionization,not coded/not installed,
IDE11551-SFT09878,Status of identification data query on LIN-Bus-Rear A/C Control Head 6,Data complete but not secured,
IDE11551-SFT09902,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 2,not coded/not installed,
IDE11551-SFT09903,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 3,not coded/not installed,
IDE11551-SFT09929,Status of identification data query on LIN-Bus-Rear A/C Control Head 1,Data complete but not secured,
IDE11551-SFT09930,Status of identification data query on LIN-Bus-Rear A/C Control Head 2,Data complete but not secured,
IDE11551-SFT09931,Status of identification data query on LIN-Bus-Rear A/C Control Head 3,Data complete but not secured,
IDE11551-SFT09932,Status of identification data query on LIN-Bus-Rear A/C Control Head 4,Data complete but not secured,
IDE11551-SFT09933,Status of identification data query on LIN-Bus-Rear A/C Control Head 5,Data complete but not secured,
IDE11551-SFT10027,Status of identification data query on LIN-Bus-Control module for heating element 1,Data complete but not secured,
IDE11551-SFT10028,Status of identification data query on LIN-Bus-Control module for heating element 2,Data complete but not secured,
IDE11551-SFT10029,Status of identification data query on LIN-Bus-Control module for heating element 3,Data complete but not secured,
IDE11551-SFT10030,Status of identification data query on LIN-Bus-Control module for heating element 4,not coded/not installed,
IDE11619-MAS13023,Photo sensors for solar radiation (discrete)-Front left sunlight intensity,not coded/not installed,
IDE11619-MAS13024,Photo sensors for solar radiation (discrete)-Front right sunlight intensity,not coded/not installed,
IDE11619-MAS13025,Photo sensors for solar radiation (discrete)-Rear left sunlight intensity,41, W/m²
IDE11619-MAS13026,Photo sensors for solar radiation (discrete)-Rear right sunlight intensity,not coded/not installed,
IDE11619-MAS13077,Photo sensors for solar radiation (discrete)-Sunlight photo sensor,not coded/not installed,
IDE11619-MAS13078,Photo sensors for solar radiation (discrete)-Sunlight photo sensor 2,not coded/not installed,
IDE11619-MAS13079,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor,0.44, V
IDE11619-MAS13080,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor 2,not coded/not installed,
IDE11637,Outside air temperature internally calculated: climate,23.00, °C
IDE11641-MAS01632,Supply voltage for A/C actuators-Status,On,
IDE11641-MAS12621,Supply voltage for A/C actuators-Current draw (effective value),487, mA
IDE11642-MAS01632,Supply voltage 2 for A/C actuators-Status,On,
IDE11642-MAS12621,Supply voltage 2 for A/C actuators-Current draw (effective value),320, mA
IDE11643-MAS01632,Voltage supply for climate sensor system-Status,On,
IDE11643-MAS04121,Voltage supply for climate sensor system-Voltage,4.98, V
IDE11654-MAS05030,Evaporator temperature sensor-Resistance,6.71, kOhm
IDE11654-MAS13081,Evaporator temperature sensor-Air temperature downstream of evaporator,6.88, °C
IDE11655-MAS05030,Left footwell vent temperature sensor-Resistance,9.49, kOhm
IDE11655-MAS13082,Left footwell vent temperature sensor-Left footwell vent temperature,26.63, °C
IDE11656-MAS05030,Right footwell vent temperature sensor-Resistance,9.87, kOhm
IDE11656-MAS13083,Right footwell vent temperature sensor-Right footwell vent temperature,25.56, °C
IDE11657-MAS05030,Left rear upper body vent temperature sensor-Resistance,13.54, kOhm
IDE11657-MAS13084,Left rear upper body vent temperature sensor-Left rear vent temperature,17.63, °C
IDE11658-MAS05030,Right rear upper body vent temperature sensor-Resistance,14.78, kOhm
IDE11658-MAS13085,Right rear upper body vent temperature sensor-Right rear vent temperature,15.25, °C
IDE11659-MAS05030,Left rear footwell vent temperature sensor-Resistance,10.68, kOhm
IDE11659-MAS13086,Left rear footwell vent temperature sensor-Left rear footwell vent temperature,23.38, °C
IDE11660-MAS05030,Right rear footwell vent temperature sensor-Resistance,10.44, kOhm
IDE11660-MAS13087,Right rear footwell vent temperature sensor-Right rear footwell vent temperature,23.88, °C
IDE11692-MAS00359,Temperature sensor after heat exchanger-Coolant temperature,not coded/not installed,
IDE11692-MAS05030,Temperature sensor after heat exchanger-Resistance,not coded/not installed,
IDE11693-MAS05030,Left side air outlet temperature sensor-Resistance,14.94, kOhm
IDE11693-MAS13110,Left side air outlet temperature sensor-Left side air outlet temperature,14.94, °C
IDE11694-MAS05030,Right side air outlet temperature sensor-Resistance,15.24, kOhm
IDE11694-MAS13111,Right side air outlet temperature sensor-Right side air outlet temperature,14.25, °C
IDE11695-MAS05030,Left central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11695-MAS13112,Left central air outlet temperature sensor-Left center air outlet temperature,not coded/not installed,
IDE11696-MAS05030,Right central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11696-MAS13113,Right central air outlet temperature sensor-Right center air outlet temperature,not coded/not installed,
IDE11697-MAS05030,Front defrost flap air outlet temperature sensor-Resistance,not coded/not installed,
IDE11697-MAS13114,Front defrost flap air outlet temperature sensor-Defrosting air outlet temperature,not coded/not installed,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,not coded/not installed,
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded/not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,27.25, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,9.15, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,28.50, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,8.75, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,28.88, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,8.63, kOhm
IDE11774-IDE01290,Assembly position of users at local data bus 9-Recirculation flap motor,15,
IDE11774-IDE01292,Assembly position of users at local data bus 9-Left side vent motor,4,
IDE11774-IDE01293,Assembly position of users at local data bus 9-Right side vent motor,10,
IDE11774-IDE01294,Assembly position of users at local data bus 9-Left footwell flap motor,1,
IDE11774-IDE01295,Assembly position of users at local data bus 9-Right footwell flap motor,11,
IDE11774-IDE01296,Assembly position of users at local data bus 9-Left center vent motor,6,
IDE11774-IDE01297,Assembly position of users at local data bus 9-Right center vent motor,8,
IDE11774-IDE01300,Assembly position of users at local data bus 9-Rear temperature door motor,3,
IDE11774-IDE01301,Assembly position of users at local data bus 9-Rear air quantity motor,12,
IDE11774-IDE01304,Assembly position of users at local data bus 9-Left Rear Upper Body Vent Motor,0,
IDE11774-IDE01305,Assembly position of users at local data bus 9-Right Rear Upper Body Vent Motor,0,
IDE11774-IDE01422,Assembly position of users at local data bus 9-Defroster flap motor,7,
IDE11774-IDE01423,Assembly position of users at local data bus 9-Left temperature flap positioning motor,5,
IDE11774-IDE01424,Assembly position of users at local data bus 9-Right temperature flap positioning motor,13,
IDE11774-IDE02432,Assembly position of users at local data bus 9-Left rear temperature door motor,0,
IDE11774-IDE02435,Assembly position of users at local data bus 9-Right rear temperature door motor,0,
IDE11774-IDE02753,Assembly position of users at local data bus 9-Temperature flap motor,0,
IDE11774-IDE02833,Assembly position of users at local data bus 9-Fresh air door motor,14,
IDE11774-IDE07267,Assembly position of users at local data bus 9-Rear left air distribution servomotor,0,
IDE11774-IDE07268,Assembly position of users at local data bus 9-Rear right air distribution servomotor,0,
IDE11774-MAS07679,Assembly position of users at local data bus 9-Air distribution door motor,0,
IDE11774-MAS07681,Assembly position of users at local data bus 9-Left footwell temperature door motor,0,
IDE11774-MAS07682,Assembly position of users at local data bus 9-Right footwell temperature door motor,0,
IDE11774-MAS07683,Assembly position of users at local data bus 9-Left side window defroster door motor,0,
IDE11774-MAS07684,Assembly position of users at local data bus 9-Right side window defroster door motor,0,
IDE11774-MAS07685,Assembly position of users at local data bus 9-Rear air distribution door motor,0,
IDE11774-MAS07686,Assembly position of users at local data bus 9-Left B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07687,Assembly position of users at local data bus 9-Right B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07688,Assembly position of users at local data bus 9-Rear recirc. flap motor,0,
IDE11774-MAS11831,Assembly position of users at local data bus 9-Ctrl. motor for instrument panel vents,0,
IDE11775-IDE01290,Assembly position of users at local data bus 10-Recirculation flap motor,0,
IDE11775-IDE01292,Assembly position of users at local data bus 10-Left side vent motor,0,
IDE11775-IDE01293,Assembly position of users at local data bus 10-Right side vent motor,0,
IDE11775-IDE01294,Assembly position of users at local data bus 10-Left footwell flap motor,0,
IDE11775-IDE01295,Assembly position of users at local data bus 10-Right footwell flap motor,0,
IDE11775-IDE01296,Assembly position of users at local data bus 10-Left center vent motor,0,
IDE11775-IDE01297,Assembly position of users at local data bus 10-Right center vent motor,0,
IDE11775-IDE01300,Assembly position of users at local data bus 10-Rear temperature door motor,0,
IDE11775-IDE01301,Assembly position of users at local data bus 10-Rear air quantity motor,0,
IDE11775-IDE01304,Assembly position of users at local data bus 10-Left Rear Upper Body Vent Motor,0,
IDE11775-IDE01305,Assembly position of users at local data bus 10-Right Rear Upper Body Vent Motor,0,
IDE11775-IDE01422,Assembly position of users at local data bus 10-Defroster flap motor,0,
IDE11775-IDE01423,Assembly position of users at local data bus 10-Left temperature flap positioning motor,0,
IDE11775-IDE01424,Assembly position of users at local data bus 10-Right temperature flap positioning motor,0,
IDE11775-IDE02432,Assembly position of users at local data bus 10-Left rear temperature door motor,0,
IDE11775-IDE02435,Assembly position of users at local data bus 10-Right rear temperature door motor,0,
IDE11775-IDE02753,Assembly position of users at local data bus 10-Temperature flap motor,0,
IDE11775-IDE02833,Assembly position of users at local data bus 10-Fresh air door motor,0,
IDE11775-IDE07267,Assembly position of users at local data bus 10-Rear left air distribution servomotor,0,
IDE11775-IDE07268,Assembly position of users at local data bus 10-Rear right air distribution servomotor,0,
IDE11775-MAS07679,Assembly position of users at local data bus 10-Air distribution door motor,0,
IDE11775-MAS07681,Assembly position of users at local data bus 10-Left footwell temperature door motor,0,
IDE11775-MAS07682,Assembly position of users at local data bus 10-Right footwell temperature door motor,0,
IDE11775-MAS07683,Assembly position of users at local data bus 10-Left side window defroster door motor,0,
IDE11775-MAS07684,Assembly position of users at local data bus 10-Right side window defroster door motor,0,
IDE11775-MAS07685,Assembly position of users at local data bus 10-Rear air distribution door motor,0,
IDE11775-MAS07686,Assembly position of users at local data bus 10-Left B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07687,Assembly position of users at local data bus 10-Right B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07688,Assembly position of users at local data bus 10-Rear recirc. flap motor,0,
IDE11775-MAS11831,Assembly position of users at local data bus 10-Ctrl. motor for instrument panel vents,0,
IDE11776-IDE01290,Assembly position of users at local data bus 11-Recirculation flap motor,0,
IDE11776-IDE01292,Assembly position of users at local data bus 11-Left side vent motor,0,
IDE11776-IDE01293,Assembly position of users at local data bus 11-Right side vent motor,0,
IDE11776-IDE01294,Assembly position of users at local data bus 11-Left footwell flap motor,0,
IDE11776-IDE01295,Assembly position of users at local data bus 11-Right footwell flap motor,0,
IDE11776-IDE01296,Assembly position of users at local data bus 11-Left center vent motor,0,
IDE11776-IDE01297,Assembly position of users at local data bus 11-Right center vent motor,0,
IDE11776-IDE01300,Assembly position of users at local data bus 11-Rear temperature door motor,0,
IDE11776-IDE01301,Assembly position of users at local data bus 11-Rear air quantity motor,0,
IDE11776-IDE01304,Assembly position of users at local data bus 11-Left Rear Upper Body Vent Motor,5,
IDE11776-IDE01305,Assembly position of users at local data bus 11-Right Rear Upper Body Vent Motor,2,
IDE11776-IDE01422,Assembly position of users at local data bus 11-Defroster flap motor,0,
IDE11776-IDE01423,Assembly position of users at local data bus 11-Left temperature flap positioning motor,0,
IDE11776-IDE01424,Assembly position of users at local data bus 11-Right temperature flap positioning motor,0,
IDE11776-IDE02432,Assembly position of users at local data bus 11-Left rear temperature door motor,6,
IDE11776-IDE02435,Assembly position of users at local data bus 11-Right rear temperature door motor,1,
IDE11776-IDE02753,Assembly position of users at local data bus 11-Temperature flap motor,0,
IDE11776-IDE02833,Assembly position of users at local data bus 11-Fresh air door motor,0,
IDE11776-IDE07267,Assembly position of users at local data bus 11-Rear left air distribution servomotor,0,
IDE11776-IDE07268,Assembly position of users at local data bus 11-Rear right air distribution servomotor,0,
IDE11776-MAS07679,Assembly position of users at local data bus 11-Air distribution door motor,0,
IDE11776-MAS07681,Assembly position of users at local data bus 11-Left footwell temperature door motor,0,
IDE11776-MAS07682,Assembly position of users at local data bus 11-Right footwell temperature door motor,0,
IDE11776-MAS07683,Assembly position of users at local data bus 11-Left side window defroster door motor,0,
IDE11776-MAS07684,Assembly position of users at local data bus 11-Right side window defroster door motor,0,
IDE11776-MAS07685,Assembly position of users at local data bus 11-Rear air distribution door motor,0,
IDE11776-MAS07686,Assembly position of users at local data bus 11-Left B-pillar/footwell shut-off flap motor,4,
IDE11776-MAS07687,Assembly position of users at local data bus 11-Right B-pillar/footwell shut-off flap motor,3,
IDE11776-MAS07688,Assembly position of users at local data bus 11-Rear recirc. flap motor,7,
IDE11776-MAS11831,Assembly position of users at local data bus 11-Ctrl. motor for instrument panel vents,0,
IDE11777-IDE01290,Assembly position of users at local data bus 12-Recirculation flap motor,0,
IDE11777-IDE01292,Assembly position of users at local data bus 12-Left side vent motor,0,
IDE11777-IDE01293,Assembly position of users at local data bus 12-Right side vent motor,0,
IDE11777-IDE01294,Assembly position of users at local data bus 12-Left footwell flap motor,0,
IDE11777-IDE01295,Assembly position of users at local data bus 12-Right footwell flap motor,0,
IDE11777-IDE01296,Assembly position of users at local data bus 12-Left center vent motor,0,
IDE11777-IDE01297,Assembly position of users at local data bus 12-Right center vent motor,0,
IDE11777-IDE01300,Assembly position of users at local data bus 12-Rear temperature door motor,0,
IDE11777-IDE01301,Assembly position of users at local data bus 12-Rear air quantity motor,0,
IDE11777-IDE01304,Assembly position of users at local data bus 12-Left Rear Upper Body Vent Motor,0,
IDE11777-IDE01305,Assembly position of users at local data bus 12-Right Rear Upper Body Vent Motor,0,
IDE11777-IDE01422,Assembly position of users at local data bus 12-Defroster flap motor,0,
IDE11777-IDE01423,Assembly position of users at local data bus 12-Left temperature flap positioning motor,0,
IDE11777-IDE01424,Assembly position of users at local data bus 12-Right temperature flap positioning motor,0,
IDE11777-IDE02432,Assembly position of users at local data bus 12-Left rear temperature door motor,0,
IDE11777-IDE02435,Assembly position of users at local data bus 12-Right rear temperature door motor,0,
IDE11777-IDE02753,Assembly position of users at local data bus 12-Temperature flap motor,0,
IDE11777-IDE02833,Assembly position of users at local data bus 12-Fresh air door motor,0,
IDE11777-IDE07267,Assembly position of users at local data bus 12-Rear left air distribution servomotor,0,
IDE11777-IDE07268,Assembly position of users at local data bus 12-Rear right air distribution servomotor,0,
IDE11777-MAS07679,Assembly position of users at local data bus 12-Air distribution door motor,0,
IDE11777-MAS07681,Assembly position of users at local data bus 12-Left footwell temperature door motor,0,
IDE11777-MAS07682,Assembly position of users at local data bus 12-Right footwell temperature door motor,0,
IDE11777-MAS07683,Assembly position of users at local data bus 12-Left side window defroster door motor,1,
IDE11777-MAS07684,Assembly position of users at local data bus 12-Right side window defroster door motor,5,
IDE11777-MAS07685,Assembly position of users at local data bus 12-Rear air distribution door motor,0,
IDE11777-MAS07686,Assembly position of users at local data bus 12-Left B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07687,Assembly position of users at local data bus 12-Right B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07688,Assembly position of users at local data bus 12-Rear recirc. flap motor,0,
IDE11777-MAS11831,Assembly position of users at local data bus 12-Ctrl. motor for instrument panel vents,0,
IDE11789-MAS11878,Air quality in the interior-Degree of contamination,Unknown (255),
IDE11790,Carbon dioxide content in the interior,Initialization,
IDE11936-MAS06614,Button for defrost function-Variant,Local data bus: operating unit 1,
IDE11936-MAS07693,Button for defrost function-Button Status,Not operated,
IDE11936-MAS07694,Button for defrost function-Button status on CAN,Not operated,
IDE11936-MAS07699,Button for defrost function-Status indicator light on CAN,OFF,
IDE11936-MAS08062,Button for defrost function-Indicator lamp activation,OFF,
IDE11939-MAS06614,Button for auxiliary water heater-Variant,not coded/not installed,
IDE11939-MAS07693,Button for auxiliary water heater-Button Status,not coded/not installed,
IDE11939-MAS07694,Button for auxiliary water heater-Button status on CAN,Not operated,
IDE11939-MAS14852,Button for auxiliary water heater-Auxiliary coolant heater indicator lamp activation,not coded/not installed,
IDE11939-MAS14853,Button for auxiliary water heater-Activation of indicator lamp for auxiliary coolant heater timer,not coded/not installed,
IDE11939-MAS14854,Button for auxiliary water heater-Status off indicator lamp for auxiliary coolant heater on CAN,OFF,
IDE12151-MAS01580,Left LED headlamp power output module: supply-Activation,not coded/not installed,
IDE12151-MAS01737,Left LED headlamp power output module: supply-Diagnosis,not coded/not installed,
IDE12151-MAS12621,Left LED headlamp power output module: supply-Current draw (effective value),not coded/not installed,
IDE12152-MAS01580,Right LED headlamp power output module: supply-Activation,not coded/not installed,
IDE12152-MAS01737,Right LED headlamp power output module: supply-Diagnosis,not coded/not installed,
IDE12152-MAS12621,Right LED headlamp power output module: supply-Current draw (effective value),not coded/not installed,
IDE12284-MAS14215,Front A/C display control head 1: pin coding-Coding pin 1: specified value,Open,
IDE12284-MAS14216,Front A/C display control head 1: pin coding-Coding pin 2: specified value,Open,
IDE12284-MAS14217,Front A/C display control head 1: pin coding-Coding pin 3: specified value,Open,
IDE12284-MAS14218,Front A/C display control head 1: pin coding-Coding pin 1: actual value,Open,
IDE12284-MAS14219,Front A/C display control head 1: pin coding-Coding pin 2: actual value,Open,
IDE12284-MAS14220,Front A/C display control head 1: pin coding-Coding pin 3: actual value,Open,
IDE12286-MAS14215,Front A/C display control head 2: pin coding-Coding pin 1: specified value,Open,
IDE12286-MAS14216,Front A/C display control head 2: pin coding-Coding pin 2: specified value,Open,
IDE12286-MAS14217,Front A/C display control head 2: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12286-MAS14218,Front A/C display control head 2: pin coding-Coding pin 1: actual value,Open,
IDE12286-MAS14219,Front A/C display control head 2: pin coding-Coding pin 2: actual value,Open,
IDE12286-MAS14220,Front A/C display control head 2: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12287-MAS14215,Front A/C display control head 3: pin coding-Coding pin 1: specified value,Open,
IDE12287-MAS14216,Front A/C display control head 3: pin coding-Coding pin 2: specified value,Ground (GND),
IDE12287-MAS14217,Front A/C display control head 3: pin coding-Coding pin 3: specified value,Open,
IDE12287-MAS14218,Front A/C display control head 3: pin coding-Coding pin 1: actual value,Open,
IDE12287-MAS14219,Front A/C display control head 3: pin coding-Coding pin 2: actual value,Ground (GND),
IDE12287-MAS14220,Front A/C display control head 3: pin coding-Coding pin 3: actual value,Open,
IDE12288-MAS14215,Front A/C display control head 4: pin coding-Coding pin 1: specified value,Open,
IDE12288-MAS14216,Front A/C display control head 4: pin coding-Coding pin 2: specified value,Ground (GND),
IDE12288-MAS14217,Front A/C display control head 4: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12288-MAS14218,Front A/C display control head 4: pin coding-Coding pin 1: actual value,Open,
IDE12288-MAS14219,Front A/C display control head 4: pin coding-Coding pin 2: actual value,Ground (GND),
IDE12288-MAS14220,Front A/C display control head 4: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12289-MAS14215,Front A/C display control head 5: pin coding-Coding pin 1: specified value,Ground (GND),
IDE12289-MAS14216,Front A/C display control head 5: pin coding-Coding pin 2: specified value,Open,
IDE12289-MAS14217,Front A/C display control head 5: pin coding-Coding pin 3: specified value,Open,
IDE12289-MAS14218,Front A/C display control head 5: pin coding-Coding pin 1: actual value,Ground (GND),
IDE12289-MAS14219,Front A/C display control head 5: pin coding-Coding pin 2: actual value,Open,
IDE12289-MAS14220,Front A/C display control head 5: pin coding-Coding pin 3: actual value,Open,
IDE12290-MAS14215,Front A/C display control head 6: pin coding-Coding pin 1: specified value,Ground (GND),
IDE12290-MAS14216,Front A/C display control head 6: pin coding-Coding pin 2: specified value,Open,
IDE12290-MAS14217,Front A/C display control head 6: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12290-MAS14218,Front A/C display control head 6: pin coding-Coding pin 1: actual value,Ground (GND),
IDE12290-MAS14219,Front A/C display control head 6: pin coding-Coding pin 2: actual value,Open,
IDE12290-MAS14220,Front A/C display control head 6: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12292-MAS14221,Front A/C display control head 1: status-Button for air outlet: close,Not operated,
IDE12292-MAS14222,Front A/C display control head 1: status-Button for air outlet: open,Not operated,
IDE12292-MAS14223,Front A/C display control head 1: status-Setting for air outlet,Not operated,
IDE12292-MAS14224,Front A/C display control head 1: status-Air outlet specified value,100, %
IDE12292-MAS14225,Front A/C display control head 1: status-Air outlet specified level,4,
IDE12292-MAS14229,Front A/C display control head 1: status-Proximity sensor,not installed,
IDE12293-MAS14221,Front A/C display control head 2: status-Button for air outlet: close,Not operated,
IDE12293-MAS14222,Front A/C display control head 2: status-Button for air outlet: open,Not operated,
IDE12293-MAS14223,Front A/C display control head 2: status-Setting for air outlet,Not operated,
IDE12293-MAS14224,Front A/C display control head 2: status-Air outlet specified value,100, %
IDE12293-MAS14225,Front A/C display control head 2: status-Air outlet specified level,4,
IDE12293-MAS14229,Front A/C display control head 2: status-Proximity sensor,not installed,
IDE12294-MAS14221,Front A/C display control head 3: status-Button for air outlet: close,Not operated,
IDE12294-MAS14222,Front A/C display control head 3: status-Button for air outlet: open,Not operated,
IDE12294-MAS14223,Front A/C display control head 3: status-Setting for air outlet,Not operated,
IDE12294-MAS14224,Front A/C display control head 3: status-Air outlet specified value,0, %
IDE12294-MAS14225,Front A/C display control head 3: status-Air outlet specified level,0,
IDE12294-MAS14229,Front A/C display control head 3: status-Proximity sensor,not installed,
IDE12295-MAS14221,Front A/C display control head 4: status-Button for air outlet: close,Not operated,
IDE12295-MAS14222,Front A/C display control head 4: status-Button for air outlet: open,Not operated,
IDE12295-MAS14223,Front A/C display control head 4: status-Setting for air outlet,Not operated,
IDE12295-MAS14224,Front A/C display control head 4: status-Air outlet specified value,100, %
IDE12295-MAS14225,Front A/C display control head 4: status-Air outlet specified level,4,
IDE12295-MAS14229,Front A/C display control head 4: status-Proximity sensor,not installed,
IDE12296-MAS14221,Front A/C display control head 5: status-Button for air outlet: close,Not operated,
IDE12296-MAS14222,Front A/C display control head 5: status-Button for air outlet: open,Not operated,
IDE12296-MAS14223,Front A/C display control head 5: status-Setting for air outlet,Not operated,
IDE12296-MAS14224,Front A/C display control head 5: status-Air outlet specified value,100, %
IDE12296-MAS14225,Front A/C display control head 5: status-Air outlet specified level,4,
IDE12296-MAS14229,Front A/C display control head 5: status-Proximity sensor,not installed,
IDE12297-MAS14221,Front A/C display control head 6: status-Button for air outlet: close,Not operated,
IDE12297-MAS14222,Front A/C display control head 6: status-Button for air outlet: open,Not operated,
IDE12297-MAS14223,Front A/C display control head 6: status-Setting for air outlet,Not operated,
IDE12297-MAS14224,Front A/C display control head 6: status-Air outlet specified value,100, %
IDE12297-MAS14225,Front A/C display control head 6: status-Air outlet specified level,4,
IDE12297-MAS14229,Front A/C display control head 6: status-Proximity sensor,not installed,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12340-MAS10485,Roof electronics control module: reading lights left-Left front reading lamp: dim. value,0, %
IDE12340-MAS10489,Roof electronics control module: reading lights left-Left rear reading lamp: dim. value,0, %
IDE12340-MAS10490,Roof electronics control module: reading lights left-Left rear reading lamp: diagnosis,Unknown (0),
IDE12340-MAS10493,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: dim. value,0, %
IDE12340-MAS10494,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE12340-MAS14272,Roof electronics control module: reading lights left-Left rear reading lamp 2: dimming value,0, %
IDE12340-MAS14273,Roof electronics control module: reading lights left-Left rear reading lamp 2: diagnostic,No malfunction,
IDE12341-MAS10487,Roof electronics control module: reading lights right-Right front reading lamp: dim. value,0, %
IDE12341-MAS10491,Roof electronics control module: reading lights right-Right rear reading lamp: dim. value,0, %
IDE12341-MAS10492,Roof electronics control module: reading lights right-Right rear reading lamp: diagnosis,Unknown (0),
IDE12341-MAS10495,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: dim. value,0, %
IDE12341-MAS10496,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE12341-MAS14274,Roof electronics control module: reading lights right-Right rear reading lamp 2: dim. value,0, %
IDE12341-MAS14276,Roof electronics control module: reading lights right-Right rear reading lamp 2: diagnosis,No malfunction,
IDE12342-MAS06614,Button engine sound generation-Variant,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,OFF,
IDE12342-MAS08062,Button engine sound generation-Indicator lamp activation,not coded/not installed,
IDE12343-MAS07693,Automated driving button-Button Status,not coded/not installed,
IDE12343-MAS07694,Automated driving button-Button status on CAN,Initialization/not installed,
IDE12343-MAS14277,Automated driving button-Indicator lamp activation: color,not coded/not installed,
IDE12343-MAS14278,Automated driving button-Indicator lamp activation: mode,normal,
IDE12358-IDE00104,Roof electronics control module 2-DTC,0,
IDE12358-MAS01634,Roof electronics control module 2-Supply voltage,14.30, V
IDE12358-MAS02832,Roof electronics control module 2-Malfunction status,not faulty,
IDE12358-MAS05946,Roof electronics control module 2-Actual temp.,36, °C
IDE12358-MAS09113,Roof electronics control module 2-Maximum temperature,69, °C
IDE12399-MAS10434,Roof electronics control module 2: indicator lights/dimming value-Indicator lamps,26, %
IDE12399-MAS10489,Roof electronics control module 2: indicator lights/dimming value-Left rear reading lamp: dim. value,0, %
IDE12399-MAS10491,Roof electronics control module 2: indicator lights/dimming value-Right rear reading lamp: dim. value,0, %
IDE12399-MAS12701,Roof electronics control module 2: indicator lights/dimming value-Background lighting,54, %
IDE12399-MAS14266,Roof electronics control module 2: indicator lights/dimming value-Rear interior lamp: dimming value,0, %
IDE12399-MAS14305,Roof electronics control module 2: indicator lights/dimming value-Rear interior lamp rear indicator lamp,OFF,
IDE12400-MAS10421,Roof electronics control module 2: button-Left rear reading lamp switch,Not operated,
IDE12400-MAS10422,Roof electronics control module 2: button-Right rear reading lamp button,Not operated,
IDE12400-MAS14281,Roof electronics control module 2: button-Rear button for rear interior light,Not operated,
IDE12430-MAS06913,Operating and display unit: rear A/C: heated seats: left-Backrest heating: activation,0, %
IDE12430-MAS06914,Operating and display unit: rear A/C: heated seats: left-Seat cushion heating: activation,0, %
IDE12430-MAS07071,Operating and display unit: rear A/C: heated seats: left-Temperature sensor for seat cushion: resistance value,6.00, kOhm
IDE12430-MAS07072,Operating and display unit: rear A/C: heated seats: left-Temperature sensor for backrest: resistance value,6.00, kOhm
IDE12430-MAS07968,Operating and display unit: rear A/C: heated seats: left-Temp sensor offset in chassis ground,not installed,
IDE12430-MAS12630,Operating and display unit: rear A/C: heated seats: left-Backrest heater: current draw (effective value),0.00, A
IDE12430-MAS12631,Operating and display unit: rear A/C: heated seats: left-Seat cushion: current draw (effective value),0.00, A
IDE12431-MAS06913,Operating and display unit: rear A/C: heated seats: right-Backrest heating: activation,0, %
IDE12431-MAS06914,Operating and display unit: rear A/C: heated seats: right-Seat cushion heating: activation,0, %
IDE12431-MAS07071,Operating and display unit: rear A/C: heated seats: right-Temperature sensor for seat cushion: resistance value,6.00, kOhm
IDE12431-MAS07072,Operating and display unit: rear A/C: heated seats: right-Temperature sensor for backrest: resistance value,6.00, kOhm
IDE12431-MAS07968,Operating and display unit: rear A/C: heated seats: right-Temp sensor offset in chassis ground,not installed,
IDE12431-MAS12630,Operating and display unit: rear A/C: heated seats: right-Backrest heater: current draw (effective value),0.00, A
IDE12431-MAS12631,Operating and display unit: rear A/C: heated seats: right-Seat cushion: current draw (effective value),0.00, A
IDE12432-MAS00043,Operating and display unit: rear A/C: supply voltages-Terminal 30 power supply,14.20, V
IDE12432-MAS06838,Operating and display unit: rear A/C: supply voltages-Supply voltage: terminal 30 left,14.30, V
IDE12432-MAS06839,Operating and display unit: rear A/C: supply voltages-Supply voltage terminal 30 right,14.40, V
IDE12433-MAS01538,Operating and display unit: rear A/C: button operation-Left air distribution,Not operated,
IDE12433-MAS01539,Operating and display unit: rear A/C: button operation-Right air distribution,Not operated,
IDE12433-MAS01545,Operating and display unit: rear A/C: button operation-AUTO left,Not operated,
IDE12433-MAS01546,Operating and display unit: rear A/C: button operation-AUTO right,Not operated,
IDE12433-MAS01554,Operating and display unit: rear A/C: button operation-Left heated seat,Not operated,
IDE12433-MAS01555,Operating and display unit: rear A/C: button operation-Left seat ventilation,Not operated,
IDE12433-MAS01556,Operating and display unit: rear A/C: button operation-Right heated seat,Not operated,
IDE12433-MAS01557,Operating and display unit: rear A/C: button operation-Right seat ventilation,Not operated,
IDE12433-MAS01560,Operating and display unit: rear A/C: button operation-OFF,Not operated,
IDE12433-MAS03830,Operating and display unit: rear A/C: button operation-Footwell air distribution,Not operated,
IDE12433-MAS03831,Operating and display unit: rear A/C: button operation-Upper body vent air distribution,Not operated,
IDE12433-MAS03832,Operating and display unit: rear A/C: button operation-Air distribution up,Not operated,
IDE12433-MAS14438,Operating and display unit: rear A/C: button operation-Temperature left +,Not operated,
IDE12433-MAS14439,Operating and display unit: rear A/C: button operation-Temperature left -,Not operated,
IDE12433-MAS14440,Operating and display unit: rear A/C: button operation-Temperature right +,Not operated,
IDE12433-MAS14441,Operating and display unit: rear A/C: button operation-Temperature right -,Not operated,
IDE12433-MAS14442,Operating and display unit: rear A/C: button operation-Temperature +,Not operated,
IDE12433-MAS14443,Operating and display unit: rear A/C: button operation-Temperature -,Not operated,
IDE12433-MAS14444,Operating and display unit: rear A/C: button operation-Air quantity left +,Not operated,
IDE12433-MAS14445,Operating and display unit: rear A/C: button operation-Air quantity left -,Not operated,
IDE12433-MAS14446,Operating and display unit: rear A/C: button operation-Air quantity right +,Not operated,
IDE12433-MAS14447,Operating and display unit: rear A/C: button operation-Air quantity right -,Not operated,
IDE12433-MAS14448,Operating and display unit: rear A/C: button operation-Setting area for temperature: left,Not operated,
IDE12433-MAS14449,Operating and display unit: rear A/C: button operation-Setting area for temperature: right,Not operated,
IDE12433-MAS14450,Operating and display unit: rear A/C: button operation-Setting area for air volume: left,Not operated,
IDE12433-MAS14451,Operating and display unit: rear A/C: button operation-Setting area for air volume: right,Not operated,
IDE12433-MAS14452,Operating and display unit: rear A/C: button operation-Resistive sensors for activation recognition,not installed,
IDE12556,Left air vent cover motor: actual value,12883,
IDE12557,Left air vent cover motor: specified value,12883,
IDE12558,Left air vent cover motor: dynamics,2883,
IDE12561,Right air vent cover motor: actual value,12877,
IDE12562,Right air vent cover motor: specified value,12877,
IDE12563,Right air vent cover motor: dynamics,2877,
IDE12566,Center air vent cover motor: actual value,12846,
IDE12567,Center air vent cover motor: specified value,12846,
IDE12568,Center air vent cover motor: dynamics,2846,
IDE12571-IDE09056,Left air vent cover motor: diagnostic-Last operating state,blockage,
IDE12571-MAS01458,Left air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12572-IDE09056,Right air vent cover motor: diagnostic-Last operating state,blockage,
IDE12572-MAS01458,Right air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12573-IDE09056,Center air vent cover motor: diagnostic-Last operating state,blockage,
IDE12573-MAS01458,Center air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12605-MAS14822,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 1,0, %
IDE12605-MAS14823,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 2,0, %
IDE12605-MAS14824,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 3,0, %
IDE12605-MAS14825,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 4,0, %
IDE12605-MAS14826,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 5,0, %
IDE12605-MAS14827,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 6,0, %
IDE12605-MAS14828,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 7,0, %
IDE12605-MAS14829,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 1,0, %
IDE12605-MAS14830,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 2,0, %
IDE12605-MAS14831,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 3,0, %
IDE12605-MAS14832,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 4,0, %
IDE12605-MAS14833,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 5,0, %
IDE12605-MAS14834,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 6,0, %
IDE12605-MAS14835,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 7,0, %
IDE12606-MAS06526,Installation information multicolor ambient and contour lighting 2-Local data bus 5,B0 B1 A0 B2 B3 A2 B4 B5 A4 A5 B6 B7 A6 A7 FF FF,
IDE12606-MAS06527,Installation information multicolor ambient and contour lighting 2-Local data bus 6,40 41 42 FF FF FF FF FF FF FF FF C0 C1 C2 C3 FF,
IDE12606-MAS14771,Installation information multicolor ambient and contour lighting 2-Local data bus 7,20 21 22 23 30 31 32 33 50 51 52 FA FB F8 F9 FF,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12845,Operating and display unit: rear A/C: gradient sensor,Folded down,
IDE12882-MAS06614,Rear window shade button 2-Variant,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE12945-MAS01632,Door surface heating 2: left front-Status,not active,
IDE12945-MAS05945,Door surface heating 2: left front-Target temperature,OFF,
IDE12945-MAS05946,Door surface heating 2: left front-Actual temp.,30.00, °C
IDE12945-MAS07929,Door surface heating 2: left front-Power quota setting by energy management,0,
IDE12945-MAS12066,Door surface heating 2: left front-Cancellation status,Heating process interrupted,
IDE12945-MAS14067,Door surface heating 2: left front-Actuation specified value,0, %
IDE12946-MAS01632,Door surface heater 2: right front-Status,not active,
IDE12946-MAS05945,Door surface heater 2: right front-Target temperature,OFF,
IDE12946-MAS05946,Door surface heater 2: right front-Actual temp.,31.00, °C
IDE12946-MAS07929,Door surface heater 2: right front-Power quota setting by energy management,0,
IDE12946-MAS12066,Door surface heater 2: right front-Cancellation status,Heating process interrupted,
IDE12946-MAS14067,Door surface heater 2: right front-Actuation specified value,0, %
IDE12947-MAS01632,Door surface heater 2: left rear-Status,not coded/not installed,
IDE12947-MAS05945,Door surface heater 2: left rear-Target temperature,not coded/not installed,
IDE12947-MAS05946,Door surface heater 2: left rear-Actual temp.,not coded/not installed,
IDE12947-MAS07929,Door surface heater 2: left rear-Power quota setting by energy management,not coded/not installed,
IDE12947-MAS12066,Door surface heater 2: left rear-Cancellation status,not coded/not installed,
IDE12947-MAS14067,Door surface heater 2: left rear-Actuation specified value,not coded/not installed,
IDE12948-MAS01632,Door surface heater 2: right rear-Status,not coded/not installed,
IDE12948-MAS05945,Door surface heater 2: right rear-Target temperature,not coded/not installed,
IDE12948-MAS05946,Door surface heater 2: right rear-Actual temp.,not coded/not installed,
IDE12948-MAS07929,Door surface heater 2: right rear-Power quota setting by energy management,not coded/not installed,
IDE12948-MAS12066,Door surface heater 2: right rear-Cancellation status,not coded/not installed,
IDE12948-MAS14067,Door surface heater 2: right rear-Actuation specified value,not coded/not installed,
IDE12950-MAS07052,Foot level heating-Setting,not coded/not installed,
IDE14245-MAS19730,Component protection configuration-Configuration bit 1,not configured,
IDE14245-MAS19731,Component protection configuration-Configuration bit 0,not activated,
IDE14245-MAS19732,Component protection configuration-Configuration bit 2,not configured,
IDE14245-MAS19733,Component protection configuration-Configuration bit 3,not configured,
IDE14245-MAS19734,Component protection configuration-Configuration bit 4,not configured,
IDE14245-MAS19735,Component protection configuration-Configuration bit 5,not configured,
IDE14245-MAS19736,Component protection configuration-Configuration bit 6,not configured,
IDE14245-MAS19737,Component protection configuration-Configuration bit 7,not configured,
IDE14245-MAS19738,Component protection configuration-Configuration bit 8,not configured,
IDE14245-MAS19739,Component protection configuration-Configuration bit 9,not configured,
IDE14245-MAS19740,Component protection configuration-Configuration bit 10,not configured,
IDE14245-MAS19741,Component protection configuration-Configuration bit 11,not configured,
IDE14245-MAS19742,Component protection configuration-Configuration bit 12,not configured,
IDE14245-MAS19743,Component protection configuration-Configuration bit 13,not configured,
IDE14245-MAS19744,Component protection configuration-Configuration bit 14,not configured,
IDE14245-MAS19745,Component protection configuration-Configuration bit 15,not configured,
IDE14648-IDE06260,Integrated toll charge module-ID number,---------,
IDE14694-MAS01580,Projection module in left matrix headlamp: supply-Activation,not coded/not installed,
IDE14694-MAS01737,Projection module in left matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14694-MAS12621,Projection module in left matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE14695-MAS01580,Projection module in right matrix headlamp: supply-Activation,not coded/not installed,
IDE14695-MAS01737,Projection module in right matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14695-MAS12621,Projection module in right matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Inside temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
MAS02311-MAS06614,Steering wheel heating button-Variant,not coded/not installed,
MAS02311-MAS07693,Steering wheel heating button-Button Status,not coded/not installed,
MAS02311-MAS07694,Steering wheel heating button-Button status on CAN,Initialization/not installed,
MAS02311-MAS07699,Steering wheel heating button-Status indicator light on CAN,OFF,
MAS02311-MAS08062,Steering wheel heating button-Indicator lamp activation,not coded/not installed,
MAS17268,Functions which can be activated: connection error counter,11,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0B 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,7,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
SFT00032-MAS01632,High beam assistant-Status,active,
SFT00032-MAS02832,High beam assistant-Malfunction status,not faulty,
SFT00032-MAS09580,High beam assistant-Sensor status,OK,
SFT00032-MAS09581,High beam assistant-PWM specs.,100, %
SFT00032-MAS09582,High beam assistant-Status on combi,active,
SFT00032-MAS09583,High beam assistant-error status on combi,not faulty,
SFT00032-MAS09584,High beam assistant-Sensor status on combi,OK,
SFT00032-MAS09585,High beam assistant-Turn up headlights request,not active,
ENG26468-ENG30676,Aftermarket_auxiliary_heater-Counter_of_activation_of_child_lock,0,
ENG26468-ENG32740,Aftermarket_auxiliary_heater-State_of_child_lock,Unknown (255),
ENG02609,average_Voltage_terminals,14.30, V
ENG128341-ENG110385,Climate_OBD-Channel,0,
ENG128341-ENG02514,Climate_OBD-Comma,not active,
ENG128341-ENG99000,Climate_OBD-Value,-9999,
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,DF34,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,DF72,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,DF72,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,DF42,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,DF55,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,DF57,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,DF44,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,DF47,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,DF31,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,DF33,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,DF33,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,1.14F,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,08.13.00F,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,08.13.00F,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,08.13.00F,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,08.11.00F,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,08.13.00F,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,08.11.01F,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,08.12.00F,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,08.13.00F,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,08.07.00F,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,08.07.00F,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,08.08.00F,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,08.13.00F,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,08.11.00F,
ENG02611-ENG02852,EVLS-block_counter_axial_in,2,
ENG02611-ENG02851,EVLS-block_counter_axial_out,3,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,3,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,2,
ENG02611-ENG02847,EVLS-drivers_door_open,closed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not active,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not active,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not active,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not active,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,00000000 00000000 ,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,No malfunction,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,00000001 ,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,00000000 11000001 ,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,00000000 11000001 ,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,no_global_break_off,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,no_assignation,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,no_storage,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,no_button_mode,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,no_tip_mode,
ENG02611-ENG02846,EVLS-LSV_EE_switch,operated,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not active,
ENG48509-MAS17268,FoD_slave_operating_state-Functions which can be activated: connection error counter,02,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0B 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,available.,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition not met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,7,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG101323,Headlight leveling control state,Measuring value not available,
ENG02610,interior_temperature,26.00, °C
ENG116001-ENG116135,itm_toll_modul-itm_event_acknowledge,event_acknowledged,
ENG116001-ENG116125,itm_toll_modul-ITM_number_of_occupants,single_driver,
ENG116001-ENG116101,itm_toll_modul-itm_on_off,itm_off,
ENG107365,Left dynamic cornering light value,Measuring value not available,
ENG107366,Left headlight leveling motor position,Measuring value not available,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,not active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,973, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,356, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,306, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,5,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,138,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,182,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,140,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,140,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,0,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,0,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,0,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,15208,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,720,
ENG108468,Right dynamic cornering light value,Measuring value not available,
ENG108469,Right headlight leveling motor position,Measuring value not available,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,3,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,5,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG27168-ENG32809,sw_history-sw_version_1,----,
ENG27168-ENG32810,sw_history-sw_version_2,----,
ENG27168-ENG32811,sw_history-sw_version_3,----,
ENG27168-ENG32812,sw_history-sw_version_4,----,
ENG27168-ENG32813,sw_history-sw_version_5,----,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I688,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,l689,
ENG03703-ENG109174,sw_version_integration_ara-SW_VERSION,A688,
ENG03703-ENG32814,sw_version_integration_ara-sw_version_camera,A652,
ENG27169-ENG32815,sw_version_integration_klima-sw_version_climate_control,6890,
ENG27169-ENG32816,sw_version_integration_klima-sw_version_preh_uif,0000,
ENG27169-ENG32817,sw_version_integration_klima-sw_version_psd,P685,
ENG27169-ENG32818,sw_version_integration_klima-sw_version_ssb,0000,
ENG27170-ENG109174,sw_version_integration_sufk-SW_VERSION,H680,
ENG116032-ENG116128,tki_runtime-tki_runtime_100ms_max_1,2568, µs
ENG116032-ENG116113,tki_runtime-tki_runtime_100ms_max_2,4554, µs
ENG116032-ENG121530,tki_runtime-tki_runtime_100ms_max_3,1766, µs
ENG116032-ENG116119,tki_runtime-tki_runtime_10ms_max_1,2288, µs
ENG116032-ENG116133,tki_runtime-tki_runtime_10ms_max_2,1512, µs
ENG116032-ENG116089,tki_runtime-tki_runtime_20ms_max_1,3992, µs
ENG116032-ENG116141,tki_runtime-tki_runtime_overruns,0, µs
ENG116032-ENG116118,tki_runtime-tki_runtime_s0,6938, µs
ENG116032-ENG116110,tki_runtime-tki_runtime_s1,3223, µs
ENG116032-ENG116093,tki_runtime-tki_runtime_s2,6764, µs
ENG116032-ENG116122,tki_runtime-tki_runtime_s3,5467, µs
ENG116032-ENG116095,tki_runtime-tki_runtime_s4,6840, µs
ENG116032-ENG116121,tki_runtime-tki_runtime_s5,7707, µs
ENG116032-ENG116084,tki_runtime-tki_runtime_s6,6702, µs
ENG116032-ENG116117,tki_runtime-tki_runtime_s7,4817, µs
ENG116032-ENG116090,tki_runtime-tki_runtime_s8,6836, µs
ENG116032-ENG116102,tki_runtime-tki_runtime_s9,3296, µs
ENG116032-ENG116127,tki_runtime-tki_runtime_slotcycle_max,54646, µs
ENG121359-ENG127696,Washer_counter_pump1-Counter_1,0.10, s
ENG121359-ENG127697,Washer_counter_pump1-Counter_2,0.30, s
ENG121359-ENG127700,Washer_counter_pump1-Counter_3,0.00, s
ENG121359-ENG127699,Washer_counter_pump1-Counter_4,0.40, s
ENG121359-ENG127698,Washer_counter_pump1-Counter_5,0.30, s
ENG121359-ENG127701,Washer_counter_pump1-Counter_6,10.40, s
ENG121360-ENG127696,Washer_counter_sra-Counter_1,0.00, s
ENG121360-ENG127697,Washer_counter_sra-Counter_2,0.00, s
ENG121360-ENG127700,Washer_counter_sra-Counter_3,0.00, s
ENG121360-ENG127699,Washer_counter_sra-Counter_4,0.00, s
ENG121360-ENG127698,Washer_counter_sra-Counter_5,0.00, s
ENG121360-ENG127701,Washer_counter_sra-Counter_6,0.00, s
Elapsed Time: 03:43
blockmap-13-4N0-907-561-G_WAU8EAF82LN004143-20201024-1518.CSV
;Component:LRR4          H04 0332, Coding:D4659F5458082C00010360E1000000BE4A1246484481009E05
;EV_ACCBOSCHAU65X,002023,EV_ACCBOSCHAU65X_VW53.rod
;Saturday,24,October,2020,15:18:14:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: B53CCA9EC5B26FF304D-80E0
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.2, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,43, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE00973,Outside temperature,25.00, °C
IDE01788,Heated lens control signal,0.00, %
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B7 EC 5B 60,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE03208,Software version for suppliers,1037605556;SYSB_PLUS_PF_R230_MLBevo_D5_0332_KW06_I3.2;0;Compiled by gzu2bp on Tue Feb  5 14:55:54 2019$!,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,-0.617, °
IDE08769,Mirror deviation: vertical,0.215, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.051, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.253, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,00,
IDE09380-MAS00107,Performed adjustment-Month,01,
IDE09380-MAS00108,Performed adjustment-Day,01,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.00, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.00, °
IDE09380-MAS08806,Performed adjustment-Number of successful adjustment attempts,0,
IDE09380-MAS08807,Performed adjustment-Number of failed adjustment attempts,0,
IDE09906,Vertical deadjustment,0.056, °
IDE13392,Congestion pilot: status,OFF,
IDE13863,Sensor blindness: radar,no blindness detected,
ENG55046,ACSF_Identifier_01,ACSF_B2_TJP_1.0,
ENG26467,adjustment_calculation,On,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,6, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,6, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,6, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,0, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,6, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG26208-ENG98502,Steering_angle-Data,0.300, °
ENG119266-ENG98502,Yaw_rate-Data,0.000, rad/s
Elapsed Time: 00:07
blockmap-15-4N0-959-655-K_WAU8EAF82LN004143-20201024-1518.CSV
;Component:AirbagVW31    H12 2720, Coding:BFFCF0C080C00500A000003FF20D410000C5
;EV_AirbaVW31SMEAU65x,001032,EV_AirbaVW31SMEAU65x.rod
;Saturday,24,October,2020,15:18:24:14741
;VCID: C4DAA75A9E68C67B833-8090
IDE00821,Seat belt switch 2nd row driver's side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Seat belt switch 2nd row center,not installed,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.2, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01099,Driver side airbag igniter 2 ohm value,no measured value present,
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.3, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.7, Ohm
IDE01104,driver side rear airbag igniter ohm value,2.5, Ohm
IDE01105,Ft. pass.side rear airbag igniter ohm value,2.8, Ohm
IDE01106,Driver side head curtain airbag igniter ohm value,2.5, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.7, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,2.6, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.7, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,too large,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,too large,
IDE01114,Driver side belt force limiter igniter ohm value,2.2, Ohm
IDE01115,side belt force limiter igniter ohm value,2.6, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.7, Ohm
IDE01118,Rear center belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,2.9, Ohm
IDE01120,Driver side active head restraint igniter ohm value,2.6, Ohm
IDE01121,Passenger side active head restraint igniter ohm value,2.9, Ohm
IDE01193,Driver belt tensioner ohm value,416.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,412.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,too large,
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01204,Center rear seat occupied recognition ohm value,232.0, Ohm
IDE01205,Safety belt switch 2nd row driver side ohm value,too large,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,too large,
IDE01207,Safety belt switch center 2nd row ohm value,too large,
IDE01208,Seat belt switch 3rd row driver side ohm value,too large,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too large,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,not installed,
IDE01358,Right pedestrian protection igniter,not installed,
IDE01359,Front pedestrian protection trigger,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,2097151,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,1023,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,131071,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,too large,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,too large,
IDE01636,Pedestrian protection trigger: front ohmic value,too large,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,too large,
IDE03730,Driver airbag release valve igniter ohm value,3.1, Ohm
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,2.3, Ohm
IDE03800,Driver airbag release valve igniter,correct,
IDE03801,Frt.pass. airbag release valve igniter,correct,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: front passenger side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,0.0, A
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,0,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
IDE06121,Left belt tensioner tensioning cycles charac. curve 3,0,
IDE06122,Left belt tensioner tensioning cycles charac. curve 4,12,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,0,
IDE06125,Right belt tensioner tensioning cycles charac. curve 3,0,
IDE06126,Right belt tensioner tensioning cycles charac. curve 4,3,
IDE06128,Left belt tensioner temperature,36.0, °C
IDE06129,Right belt tensioner temperature,37.0, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,0.0, A
IDE06525,Left belt tensioner error status,0,
IDE06525,Left belt tensioner error status,00,
IDE06526,Right belt tensioner error status,0,
IDE06526,Right belt tensioner error status,00,
IDE06959,Seat occupant detection: diagnosis signal,38.5, %
IDE06960,Seat occupant detection: msmt. signal,0.0, %
IDE06961,Seat occupant detection: ref. signal,0.0, %
IDE07190,Igniter for battery open circuit 2nd battery,correct,
IDE07191,2nd Battery open circuit igniter ohm value,3.0, Ohm
IDE07192,Thorax airbag igniter,cannot be measured currently,
IDE07193,Igniter for window airbag Ohm-value,no measured value present,
IDE08436,Driver side seat belt tensioner igniter 3,cannot be measured currently,
IDE08437,Front passenger side third row seat belt tensioner igniter,cannot be measured currently,
IDE08438,Driver side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE08439,Frt.pass. side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE10187,Supply voltage [V],14.3, V
IDE10188,Left belt tensioner supply voltage [V],14.4, V
IDE10189,Right belt tensioner supply voltage [V],14.4, V
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,cannot be measured currently,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,cannot be measured currently,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,correct,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,2.6, Ohm
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,too large,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,not installed,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,too large,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,too large,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,too large,
IDE80003,Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80004,Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80005,Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80006,Analysis 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00001,Driver airbag igniter,correct,
MAS00002,Driver's Airbag Igniter 2,cannot be measured currently,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,correct,
MAS00008,Passenger side rear thorax airbag igniter,correct,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver's Safety Belt Tensioner Igniter 2,not installed,
MAS00016,Front passenger seat belt tensioner igniter 2,not installed,
MAS00017,Driver's Belt Force Limiter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00021,Center rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,correct,
MAS00023,Driver side active head restraint igniter,correct,
MAS00024,Igniter for active head restraint on frt. passenger side,correct,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition: driver side: rear,not installed,
MAS00039,Seat occupied recognition: passenger side: rear,not installed,
MAS00040,Seat occupied recognition: center: rear,Unknown (7),
MAS01634,Supply voltage,correct,
Elapsed Time: 00:24
blockmap-16-4N0-907-129-N_WAU8EAF82LN004143-20201024-1518.CSV
;Component:Lenks.Modul   H03 0005, Coding:
;EV_SMLSKLOAU736,007012,EV_SMLSKLOAU736_AU58.rod
;Saturday,24,October,2020,15:18:50:14741
;VCID: BC2ADFBAE698BEBBFB3-80E8
IDE00333,Driver assistance systems button,Not operated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Cruise control switch with ACC,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Tap acceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,8 positions,
IDE00356-MAS05360,Cruise Control System (CCS): switch position-Discreet wire,High-level,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE00356-MAS13642,Cruise Control System (CCS): switch position-Button for cruise control system,not installed,
IDE02068-MAS00106,Time stamp-Year,2019, yr
IDE02068-MAS00107,Time stamp-Month,9, m
IDE02068-MAS00108,Time stamp-Day,23, d
IDE02068-MAS00109,Time stamp-Hours,22, H
IDE02068-MAS00110,Time stamp-Minutes,14, min
IDE02068-MAS00111,Time stamp-Seconds,4, s
IDE02068-MAS00711,Time stamp-Odometer reading,3, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 55 38 45 41 46 38 32 4C 4E 30 30 34 31 34 33,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 4,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02743-IDE05742,High Beam-Light switch position,Not operated,
IDE02744-MAS02201,Steering wheel heating-Temperature,27, °C
IDE02744-MAS02323,Steering wheel heating-Voltage at switch,Low-level,
IDE02744-MAS02324,Steering wheel heating-Voltage at sensor,0.00, V
IDE02744-MAS03746,Steering wheel heating-Current: actual value,0.00, A
IDE02744-MAS04457,Steering wheel heating-PWM pulse duty factor,0, %
IDE03504-MAS03692,Personalized settings-Key 1,not detected,
IDE03504-MAS03693,Personalized settings-Key 2,detected,
IDE03504-MAS03694,Personalized settings-Key 3,not detected,
IDE03504-MAS03695,Personalized settings-Key 4,not detected,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,OFF,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,14313.28, mV
IDE03680-IDE00618,Supply voltages-5V voltage supply,4935.94, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,12278.91, mV
IDE05725-IDE01763,Dimmer terminal 58xs-Dimming,00,
IDE05725-MAS03873,Dimmer terminal 58xs-Duty cycle,0, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Positive,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in correct range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,in correct range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,0.3, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.7, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,No malfunction,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,0.4, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Negative,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Negative,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Positive,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in correct range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,in correct range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,0.3, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,No malfunction,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,0.4, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in correct range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Negative,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,4.7, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,5.3, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Negative,
Elapsed Time: 00:05
blockmap-17-4N0-920-890-C_WAU8EAF82LN004143-20201024-1507.CSV
;Component:FBenUSAACC--- H12 0210, Coding:8BC600C17C88D7050285E16098804B0008000000
;EV_DashBoardAU65X,001017,EV_DashBoardAU65X_001_AU58.rod
;Saturday,24,October,2020,15:07:05:14741
;VCID: B134FE8E31DA43D3585-80E4
IDE00019,Voltage terminal 30,14.20, V
IDE00021,Engine RPM,1419, /min
IDE00025,Coolant temperature,19.50, °C
IDE00196,Engine oil temperature,21, °C
IDE00301,Mileage,122, km
IDE00310,Outside temperature,23.00, °C
IDE00316-IDE00500,Time-Hour,15, H
IDE00316-IDE00501,Time-Minute,7, min
IDE00316-MAS00111,Time-Seconds,1, s
IDE00317-IDE00502,Date-Year,2020, yr
IDE00317-IDE00503,Date-Month,10, Months
IDE00317-IDE00504,Date-Day,24, d
IDE00520,Photo transistor,253,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2180, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2246, mm
IDE01076,Time since ignition off,261494, s
IDE01985-ENG101043,FAZIT identification test sum-Checksum,AB 5F 41 E7,
IDE01985-ENG99027,FAZIT identification test sum-Version,81,
IDE02642,Outside temp.: displayed value,22.50, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,B3,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,37,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,500,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03471-ENG33312,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG43637,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,4.00, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,22.20, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,23.20, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,5.00, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.00, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,35.00, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,35.00, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.00, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.00, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.00, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.00, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.00, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.00, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.00, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,80, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0, km
IDE03474-IDE00304,Calculated volume-Fuel level,5.50, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,194, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,256, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,264, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,6.30, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.00, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.00, l
IDE03474-IDE00802,Calculated volume-Full volume,82.00, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,5.90, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-0.40, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-2.90, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,6.30, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,-0.40, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,not_available,
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,-2.90, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,6.30, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,6.30, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,6.30, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.16, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.00, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,7.00, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,20,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0000000,
IDE03506,Distance: high resolution,00 01 DE C4,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 01 33,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 4C,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 4C,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 01 33,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,42, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,60, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,49, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,42, °C
IDE06425-IDE06026,Dynamometer mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06924,Performance display,0,
IDE08343,Immobilizer Challenge,D4 1D 07 55,
IDE08775-MAS01390,Active driver info.-Block 1,DF 00 A4 44,
IDE08775-MAS01391,Active driver info.-Block 2,A2 7E 00 00,
IDE08775-MAS01392,Active driver info.-Block 3,00 00 00 00,
IDE08775-MAS01393,Active driver info.-Block 4,00 00 00 00,
IDE08775-MAS01394,Active driver info.-Block 5,00 00 00 00,
IDE08775-MAS01395,Active driver info.-Block 6,00 00 00 00,
IDE08775-MAS01396,Active driver info.-Block 7,00 00 00 00,
IDE08775-MAS01397,Active driver info.-Block 8,00 00 00 00,
IDE08775-MAS01398,Active driver info.-Block 9,00 00 00 00,
IDE08775-MAS01399,Active driver info.-Block 10,00 00 00 00,
IDE08775-MAS01400,Active driver info.-Block 11,00 00 00 00,
IDE08775-MAS01401,Active driver info.-Block 12,00 00 00 00,
IDE08775-MAS01402,Active driver info.-Block 13,00 00 00 00,
IDE08775-MAS01403,Active driver info.-Block 14,00 00 00 00,
IDE08775-MAS01404,Active driver info.-Block 15,00 00 00 00,
IDE08775-MAS01405,Active driver info.-Block 16,00 00 00 00,
IDE08775-MAS01406,Active driver info.-Block 17,00 00 00 00,
IDE08775-MAS01407,Active driver info.-Block 18,00 00 00 00,
IDE08775-MAS01408,Active driver info.-Block 19,00 00 00 00,
IDE08775-MAS01409,Active driver info.-Block 20,00 00 00 00,
IDE08776-MAS01390,Key-relevant driver information-Block 1,A4 44 A2 7E,
IDE08776-MAS01391,Key-relevant driver information-Block 2,00 00 00 00,
IDE08776-MAS01392,Key-relevant driver information-Block 3,00 00 00 00,
IDE08776-MAS01393,Key-relevant driver information-Block 4,00 00 00 00,
IDE08776-MAS01394,Key-relevant driver information-Block 5,00 00 00 00,
IDE08776-MAS01395,Key-relevant driver information-Block 6,00 00 00 00,
IDE08776-MAS01396,Key-relevant driver information-Block 7,00 00 00 00,
IDE08776-MAS01397,Key-relevant driver information-Block 8,00 00 00 00,
IDE08776-MAS01398,Key-relevant driver information-Block 9,00 00 00 00,
IDE08776-MAS01399,Key-relevant driver information-Block 10,00 00 00 00,
IDE08777-MAS00106,History memory: driver info.-Year,2020,
IDE08777-MAS00107,History memory: driver info.-Month,10,
IDE08777-MAS00108,History memory: driver info.-Day,24,
IDE08777-MAS00109,History memory: driver info.-Hours,15,
IDE08777-MAS00110,History memory: driver info.-Minutes,5,
IDE08777-MAS00111,History memory: driver info.-Seconds,53,
IDE08777-MAS01390,History memory: driver info.-Block 1,A4 44,
IDE10347-ENG118215,Trip distance challenge-Challenge,32 00 00 00 00 EE 3A B6 92 00 17 01 00 00 00 57 41 55 38 45 41 46 38 32 4C 4E 30 30 34 31 34 33 13 40 91 3D 51 0B BC E1 00 00,
IDE10348-ENG98502,Trip distance data-Data,32 00 00 00 00 00 00 00 00 00 17 01 00 00 00 57 41 55 38 45 41 46 38 32 4C 4E 30 30 34 31 34 33 3D 58 03 3F BE 4F A5 78 00 14 00 03 00 7A 00 00 92 00 00 03 D6 0B 00 60 09 00 4E 58 0A 00,
IDE12972,Oil: theoretical service interval,15000, km
IDE12973,Oil: service interval exceeded in km,Not available,
IDE12974,Oil service interval exceeded in days,Not available,
IDE12975,Oil: remaining driving distance,16060, km
IDE12976,Oil: remaining running time,266, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,miles,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,10000,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of dist. travelled,miles,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,20000,
IDE12977-MAS07273,Oil status-Inspection: time,631,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,266,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,100,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,64, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,56, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,56, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,45, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG99439,Instrument_recorder,02,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,146,
Elapsed Time: 00:53
blockmap-17-4N0-920-890-C_WAU8EAF82LN004143-20201024-1527.CSV
;Saturday,24,October,2020,15:27:28:14741
IDE00019,Voltage terminal 30,14.30, V
IDE00021,Engine RPM,750, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,87, °C
IDE00310,Outside temperature,27.50, °C
IDE00316-IDE00501,Time-Minute,27, min
IDE00316-MAS00111,Time-Seconds,24, s
IDE02642,Outside temp.: displayed value,23.00, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,A6,
IDE03474-IDE00304,Calculated volume-Fuel level,4.60, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,200, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,5.70, l
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,5.30, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,5.70, l
IDE03474-ENG102894,Calculated volume-averaged_volume,5.70, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,5.70, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,5.70, l
blockmap-19-4K0-907-468-L_WAU8EAF82LN004143-20201024-1508.CSV
;Component:Gateway       H05 0262, Coding:020100050004064054960000005B0132DC98004018000000097D078E10000000
;EV_Gatew31xAU65x,003190,EV_Gatew31xAU65x_AU58.rod
;Saturday,24,October,2020,15:08:03:14741
;VCID: BD2CD2BEFD82B7B3CCD-80E8
IDE00009,Date of manufacture,19 08 14,
IDE00010,Serial number,1YF04079541601,
IDE00019,Voltage terminal 30,14.50, V
IDE00020-MAS00044,Terminal 15 status-Terminal 15 power supply,14.40, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,178*2020-10-15-11:33*00.4*01*00679**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00*00000**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,178*2020-10-15-11:26*22.5*01**,
IDE00056,History data 1,178*2020-10-12-14:34*24.1*01**,
IDE00056,History data 1,178*2020-10-13-07:51*17.0*01**,
IDE00056,History data 1,178*2020-10-15-11:18*25.5*01**,
IDE00056,History data 1,178*2020-10-15-11:28*25.5*01**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00*00000**,
IDE00058,History data 3,141*2020-07-14-17:53*T*0*0*075*041*0010*0*00.0*00.0**,
IDE00058,History data 3,145*2020-07-16-12:24*T*0*0*075*041*009C*0*00.0*00.0**,
IDE00058,History data 3,143*2020-07-15-16:34*T*0*0*078*043*0010*0*00.0*00.0**,
IDE00058,History data 3,144*2020-07-15-22:56*T*0*0*072*039*000C*0*00.0*00.0**,
IDE00058,History data 3,142*2020-07-15-16:29*T*0*0*076*042*0010*0*00.0*00.0**,
IDE00058,History data 3,146*2020-07-17-08:05*T*0*0*089*050*020C*0*00.0*00.0**,
IDE00058,History data 3,140*2020-07-14-17:52*T*0*0*075*041*0010*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,015*2019-09-13-21:29*01*070*09*VAO*690831V39S*10003*00249*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*000000*0000*00.0*000*00*-00.0*00000*00000*0000*00000000*000*00.0*00.0*0000.0**,
IDE00061,History data 6,180*2020-10-20-10:27*034*+16*+000.7*0078*01*00.06**,
IDE00061,History data 6,172*2020-09-28-13:59*025*+24*+000.7*0000*00*00.01**,
IDE00061,History data 6,*00.03**169*2020-09-05-17:23*049*+36*+000.3*0000*00,
IDE00061,History data 6,*00.35**167*2020-09-05-15:11*042*+32*+000.3*0000*00,
IDE00061,History data 6,173*2020-09-28-14:00*029*+24*+003.0*0000*00*00.15**,
IDE00061,History data 6,179*2020-10-19-15:08*033*+19*+008.4*0000*00*00.46**,
IDE00061,History data 6,171*2020-09-25-18:5-25-18:52*024*+19*+000.6*0000*00,
IDE00061,History data 6,176*2020-10-02-16:35*030*+20*+001.6*0000*00*00.15**,
IDE00061,History data 6,175*2020-09-30-14:42*033*+16*+002.5*0000*00*00.28**,
IDE00061,History data 6,178*2020-10-08-08:32*025*+19*+000.2*0000*00*00.00**,
IDE00061,History data 6,177*2020-10-06-12:07*027*+14*+002.0*0000*00*00.25**,
IDE00061,History data 6,*00.00**168*2020-09-05-16:06*052*+34*+002.5*0000*00,
IDE00061,History data 6,*00.03**170*2020-09-08-09:33*043*+23*+000.2*0001*01,
IDE00061,History data 6,174*2020-09-30-12:20*027*+11*+000.2*0000*00*00.01**,
IDE00061,History data 6,181*2020-10-21-14:25*033*+19*+000.6*0000*00*00.03**,
IDE00062,History data 7,0341.4**169*2020-09-05-17:24*042*+001.6*00.0*00.1*,
IDE00062,History data 7,173*2020-09-28-14:09*026*-001.2*00.0*00.0*0046.2**,
IDE00062,History data 7,181*2020-10-21-14:28*019*-002.4*00.0*00.0*0040.8**,
IDE00062,History data 7,178*2020-10-08-08:33*018*-005.1*00.0*00.1*0238.0**,
IDE00062,History data 7,170*2020-09-08-09:35*dZ 023*-006.6*00.0*00.1*,
IDE00062,History data 7,0064.1**168*2020-09-05-16:28*048*-002.2*00.0*00.4*,
IDE00062,History data 7,171*2020-09-25-18:54*023*-001.4*00.0*00.0*0045.3**,
IDE00062,History data 7,0000.7**166*2020-09-05-12:49*040*+001.9*00.0*00.1*,
IDE00062,History data 7,176*2020-10-02-16:44*022*-002.1*00.0*00.0*0091.3**,
IDE00062,History data 7,179*2020-10-19-15:36*027*-000.6*00.0*00.1*0002.1**,
IDE00062,History data 7,180*2020-10-20-10:31*032*-001.2*00.0*00.0*0027.8**,
IDE00062,History data 7,175*2020-09-30-15:00*028*-001.8*00.0*00.1*0048.5**,
IDE00062,History data 7,174*2020-09-30-12:21*026*-000.6*00.0*00.0*0002.3**,
IDE00062,History data 7,177*2020-10-06-12:22*024*-001.6*00.0*00.0*0038.5**,
IDE00062,History data 7,0000.9**167*2020-09-05-15:13*049*-000.7*00.0*00.0*,
IDE00063,History data 8,159*2020-08-07-13:11*1*+31.7*13.1*054*+28**,
IDE00063,History data 8,145*2020-07-16-12:25*1*+03.3*14.4*075*+26**,
IDE00063,History data 8,000*2020-07-16-12:41*1*+00.0*12.9*088*+26**,
IDE00063,History data 8,000*2020-07-16-12:41*1*+00.5*12.8*088*+26**,
IDE00063,History data 8,162*2020-08-07-13:47*1*+00.4*12.7*064*+30*99*00*00*01*00*00*000*000*00**,
IDE00063,History data 8,000*2020-07-16-12:27*1*+01.8*14.5*084*+26**,
IDE00064,History data 9,178*2020-10-09-08:27*091*091*051*022*00240*04.4*+23*09.7*02.3*00000*00010**,
IDE00064,History data 9,126*2020-04-19-21:16*093*093*075*038*00120*03.8*+29*09.9*02.4*00000*00001**,
IDE00064,History data 9,*00000**000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000,
IDE00064,History data 9,149*2020-07-18-06:24*097*095*072*039*00178*03.8*+35*10.2*02.3*00000*00003**,
IDE00064,History data 9,108*2019-12-10-11:02*100*100*071*040*00069*03.6*+20*10.0*02.4*00000*00001**,
IDE00064,History data 9,109*2020-01-04-06:02*100*098*063*034*00073*03.8*+20*09.9*02.4*00000*00001**,
IDE00064,History data 9,*00001**104*2019-10-03-09:48*100*100*087*047*00059*03.4*+12*10.2*02.4*00000,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,163*2020-08-29-00:13*097*097*045*020*00217*04.4*+35*09.8*02.4*00000*00005**,
IDE00064,History data 9,*00001**000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000,
IDE00064,History data 9,105*01**105*2019-11-10-09:15*100*100*076*034*00064*03.8*+03*09.8*02.4*00000,
IDE00065,History data 10,177*2020-10-06-12:20*80**,
IDE00065,History data 10,04.0*0**000*2000-01-01-00:00*0*000*000*+00*00*00*+00*,
IDE00065,History data 10,000*2000-01-01-00:00*00*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00065,History data 10,178*2020-10-08-08:33*88**,
IDE00065,History data 10,000*2000-01-01-00:00*00**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000*000*+00*00*00*+00*04.0*0**,
IDE00065,History data 10,0dZ 00*2000-01-01-00:00*0*000*000*+00*00*00*+00*,
IDE00065,History data 10,177*2020-10-06-12:22*80**,
IDE00065,History data 10,179*2020-10-19-15:21*88*00000*00000*00000*00024*00000*00000*00000*00031**,
IDE00065,History data 10,179*2020-10-19-15:21*88**,
IDE00065,History data 10,177*2020-10-06-12:18*88**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000*000*+00*00*00*+00*04.0*0*00000*00000*00000**,
IDE00066,History data 11,180*2020-10-20-10:27*000*000*000*000*0000*004*00.0*00.7*071*027*072*034*00*00000*00007*00000*00008*00000**,
IDE00066,History data 11,169*2020-09-05-17:23*000*000*000*000*0000*000*00.1*00.4*087*048*087*049*00**,
IDE00066,History data 11,166*2020-09-05-12:47*000*000*000*000*0004*001*00.1*00.4*072*038*072*039*00**,
IDE00066,History data 11,168*2020-09-05-16:06*000*000*000*000*0072*021*00.1*02.6*088*049*091*052*00**,
IDE00066,History data 11,167*2020-09-05-15:11*000*000*000*000*0000*001*00.1*00.4*077*040*077*042*00**,
IDE00066,History data 11,170*2020-09-08-09:33*000*000*000*000*0000*002*00.0*00.2*078*042*079*043*00**,
IDE00067,History data 12,178*2020-10-08-08:33*FFFC*01*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,177*2020-10-06-12:07*FFFC*01*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,181*2020-10-21-14:25*FFFC*01*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,179*2020-10-19-15:08*FFFC*01*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,182*2020-10-24-15:05*FFFC*01*00*0000*00*00*0000*00*00**,
IDE00068,History data 13,177*2020-10-06-12:07*7*00.00*000*000*000*000*000*000*056**,
IDE00068,History data 13,170*2020-09-08-09:33*7*00.00*000*000*000*000*000*000*054**,
IDE00068,History data 13,171*2020-09-25-18:52*7*00.00*000*000*000*000*000*000*055**,
IDE00068,History data 13,169*2020-09-05-17:24*7*00.00*000*000*000*000*000*000*053**,
IDE00068,History data 13,178*2020-10-08-08:33*7*00.00*000*000*000*000*000*000*057**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE00071,History data 16,138*2020-07-07-18:30*000*000*000*00.01*002*000*000**,
IDE00102,Control Module temperature,30, °C
IDE00725,Manufacturer test stand number,0001,
IDE00726,Component group and serial number,5416,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,0,
IDE00767-ENG05081,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 00,
IDE00767-ENG05078,No. of unscheduled ECU resets-Last_WD_Reset_Reason,00,
IDE00767-ENG05082,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,0,
IDE00767-ENG05079,No. of unscheduled ECU resets-Wd_Reset_Counter,0,
IDE00767-ENG33384,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Dimmer terminal 58d,Measuring value not available,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,-84109727,
IDE01712-MAS01780,GPS Position-Width,35906462,
IDE01712-MAS02230,GPS Position-Height,292, m
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,181*2020-10-21-14:25*1*002*00.03*002000*056*058*023**,
IDE01804,History data 18,180*2020-10-20-10:27*1*001*00.06*002000*055*058*023**,
IDE01804,History data 18,180*2020-10-20-10:27*2*000*00.00*002020*054*058*023**,
IDE01804,History data 18,179*2020-10-19-15:26*3*000*00.30*000040*053*057*023**,
IDE01804,History data 18,179*2020-10-19-15:26*1*008*00.46*000080*054*057*023**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01805,History data 19,070*2019-09-24-12:54*0010*0019.6*0000.7*0008.4*0100*010738FF*000*000*001**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01806,History data 20,147*2020-07-17-08:05*3973*111*090*+223E5FB*-5036AFE**,
IDE01807,History data 21,00082*00034*00000*00003**,
IDE01807,History data 21,00000*00000*00000*00000**,
IDE01807,History data 21,00133*00031*00011*00002**,
IDE01807,History data 21,00104*00005*00000**,
IDE01807,History data 21,00083*00089*00035*00096**,
IDE01807,History data 21,00000*00000*00000**,
IDE01807,History data 21,000122**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,00007*00000*00001**,
IDE01807,History data 21,00110*00007*00002**,
IDE01807,History data 21,00050*00058*00050*00014*00007**,
IDE01807,History data 21,00010*00000*00000*00000*00000*00000*00000*00000*00000*00001*00000**,
IDE01807,History data 21,00142*00567*00404*07681**,
IDE01807,History data 21,00007*00000*00004*00000*00000**,
IDE01808,History data 22,168*2020-09-05-16:27*2*0*008*000*090*091*0**,
IDE01808,History data 22,169*2020-09-05-17:34*2*0*010*002*087*091*0**,
IDE01808,History data 22,179*2020-10-19-15:42*2*0*012*002*063*072*0*00078*00009**,
IDE01808,History data 22,179*2020-10-19-15:21*2*0*003*001*054*057*0**,
IDE01808,History data 22,168*2020-09-05-16:09*2*0*002*000*088*089*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000*00000*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,0*0000**000*2000-01-01-00:0,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,Z *000*2000-01-01-00:0,
IDE01812,History data 26,000*2000-01-01-00:00*0000*d,
IDE01813,History data 27,000*2000-01-01-00:00*0000**,
IDE01813,History data 27,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,Nur für BEV                                             ,
IDE01817,History data 31,                                                        ,
IDE01817,History data 31,,
IDE01818,History data 32,000*2000-00-00-00:00*0*000*000*00.0*00.0*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,000*2000-00-00-00:00*0*0*000*000.0*00.0*00.0*000.0*00.0**,
IDE01821,History data 35,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01823,History data 37,000*2000-01-01-00:00*0*0*0*0*0*0*0*0*0**,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,000*2000-01-01-00:00*000*000*000**,
IDE01825,History data 39,,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*+00**,
IDE01826,History data 40,016*2019-09-13-21:33*3*4*0*0*2*049.90*020.00*+24**,
IDE01826,History data 40,016*2019-09-13-21:32*3*4*0*0*2*038.85*020.00*+24**,
IDE01827,Specified generator voltage,10.6, V
IDE01833-MAS06105,Battery version-Rated battery capacity,70, Ah
IDE01833-MAS06106,Battery version-Battery technology,EMB,
IDE01833-MAS06107,Battery version-Battery manufacturer,Varta,
IDE01834,Battery voltage,14.678, V
IDE01836,Battery current,20.239, A
IDE01837,Temperature of battery sensor,25, °C
IDE01838,Battery temperature,22, °C
IDE01839,Battery charge level,62, %
IDE01841,Battery internal resistance,4.0,
IDE01842,Usable battery charge,29, Ah
IDE01843,Battery voltage at rest,12.3, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Parking heater,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.80, Ah
IDE01849,Previous journey duration,0.01, H
IDE01850,Overall energy balance,10003.60, Ah
IDE01851,Entire energy throughput,250.1, Ah
IDE01852,Static current measurement: result,10, mA
IDE01853,Static current measurement: status,Measurement end,
IDE01854-MAS09891,Energy reclamation request-recuperation active,not active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,2880, As
IDE01855,Generator current,0.0, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,active: local wakeup event,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,active: local wakeup event,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,active: local wakeup event,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,active: local wakeup event,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active: local wakeup event,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,active: local wakeup event,
IDE01864-MAS17841,Status of current bus communication-Data bus CAN 8,active: local wakeup event,
IDE01864-MAS17947,Status of current bus communication-FlexRay star 4,not installed,
IDE01948,Battery internal resistance not normed,4.2,
IDE01971,Lowest recorded control module temperature,0, °C
IDE01972,Highest recorded control module temperature,64, °C
IDE01985-MAS06855,FAZIT identification test sum-Test sum,2F FD 13 56,
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-IDE15844,Installation list: current installations-Fuel cell drive control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Electronics,available.,
IDE01992-SFT00002,Installation list: current installations-Transmission Electronics,available.,
IDE01992-SFT00003,Installation list: current installations-Brake electronics,available.,
IDE01992-SFT00006,Installation list: current installations-Seat adjustment: passenger's side,available.,
IDE01992-SFT00007,Installation list: current installations-Display/control head,Not available,
IDE01992-SFT00008,Installation list: current installations-Climate Control Module,Not available,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,available.,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine electronics 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Distance Regulation,available.,
IDE01992-SFT00021,Installation list: current installations-Airbag,available.,
IDE01992-SFT00022,Installation list: current installations-Steering column electronics systems,available.,
IDE01992-SFT00023,Installation list: current installations-Instrument cluster,available.,
IDE01992-SFT00024,Installation list: current installations-Auxiliary/parking heating,Not available,
IDE01992-SFT00025,Installation list: current installations-Data Bus OBD Interface,available.,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High beam assistant,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery management 2,available.,
IDE01992-SFT00034,Installation list: current installations-All-wheel drive electronics,Not available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Convertible top operation,Not available,
IDE01992-SFT00039,Installation list: current installations-Display/operating unit rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Rear A/C control head,Not available,
IDE01992-SFT00042,Installation list: current installations-Control module for wireless charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering column lock,Not available,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Differential lock electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat adjustment: driver side,available.,
IDE01992-SFT00060,Installation list: current installations-Lane change assistance,available.,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Driver's door electronics,available.,
IDE01992-SFT00067,Installation list: current installations-Brake Electronics 2,Not available,
IDE01992-SFT00068,Installation list: current installations-Power steering,available.,
IDE01992-SFT00070,Installation list: current installations-Comfort system central control module,Not available,
IDE01992-SFT00070,Installation list: current installations-Comfort system central control module,available.,
IDE01992-SFT00072,Installation list: current installations-Seat adjustment: rear driver's side,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat adjustment 3. seat row,Not available,
IDE01992-SFT00081,Installation list: current installations-Electric drive,Not available,
IDE01992-SFT00082,Installation list: current installations-Passenger's door electronics,available.,
IDE01992-SFT00090,Installation list: current installations-Automated longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat adjustment: rear passenger side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information electronics 1,available.,
IDE01992-SFT00095,Installation list: current installations-Information electronics 1,Not available,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring System (TPMS),Not available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Not available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamic control module,Not available,
IDE01992-SFT00108,Installation list: current installations-Rear view camera system,Not available,
IDE01992-SFT00109,Installation list: current installations-Rear lid electronics,available.,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,available.,
IDE01992-SFT00117,Installation list: current installations-Emergency call module and communication unit,Not available,
IDE01992-SFT00117,Installation list: current installations-Emergency call module and communication unit,available.,
IDE01992-SFT00118,Installation list: current installations-Parking aid,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery control additional memory 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Selector lever,available.,
IDE01992-SFT00130,Installation list: current installations-Head-Up-Display,available.,
IDE01992-SFT00130,Installation list: current installations-Head-Up-Display,Not available,
IDE01992-SFT00132,Installation list: current installations-Night vision system,Not available,
IDE01992-SFT00139,Installation list: current installations-Distance regulation 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Hybrid Battery Management,Not available,
IDE01992-SFT00165,Installation list: current installations-Front sensor for drivers assistant systems,Not available,
IDE01992-SFT00165,Installation list: current installations-Front sensor for drivers assistant systems,available.,
IDE01992-SFT00166,Installation list: current installations-Microphone control module,Not available,
IDE01992-SFT00169,Installation list: current installations-Structure-borne sound actuator,Not available,
IDE01992-SFT00172,Installation list: current installations-Reducing Agent Metering System,Not available,
IDE01992-SFT00186,Installation list: current installations-Subframe mount,available.,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,Not available,
IDE01992-SFT00195,Installation list: current installations-Electric drive 3,Not available,
IDE01992-SFT00196,Installation list: current installations-Voltage converter,available.,
IDE01992-SFT00197,Installation list: current installations-Thermal management,Not available,
IDE01992-SFT00198,Installation list: current installations-High-voltage battery charger,Not available,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Not available,
IDE01992-SFT00205,Installation list: current installations-Laser for adaptive cruise control,available.,
IDE01992-SFT00206,Installation list: current installations-Electric drive 2,Not available,
IDE01992-SFT00207,Installation list: current installations-Lane Change Assistant 2,available.,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,available.,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,available.,
IDE01992-SFT00221,Installation list: current installations-Sunroof control module 2,available.,
IDE01992-SFT33028,Installation list: current installations-High voltage converter,Not available,
IDE01992-SFT33031,Installation list: current installations-Antenna module,Not available,
IDE01992-SFT33032,Installation list: current installations-Control unit for hood ornament,Not available,
IDE01992-SFT33041,Installation list: current installations-Right exterior rear view mirror,Not available,
IDE01992-SFT33042,Installation list: current installations-Left exterior rear view mirror,Not available,
IDE01992-SFT33043,Installation list: current installations-HV battery charging unit 2,Not available,
IDE01992-SFT33044,Installation list: current installations-High voltage converter 2,Not available,
IDE01992-SFT33045,Installation list: current installations-Remote Multifunction Module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT09760,Installation list: current installations-Sunroof control module,available.,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,49,
IDE01993-IDE15844,Control module reference number-Fuel cell drive control module,00,
IDE01993-SFT00001,Control module reference number-Engine Electronics,76,
IDE01993-SFT00002,Control module reference number-Transmission Electronics,77,
IDE01993-SFT00003,Control module reference number-Brake electronics,13,
IDE01993-SFT00003,Control module reference number-Brake electronics,05,
IDE01993-SFT00006,Control module reference number-Seat adjustment: passenger's side,4D,
IDE01993-SFT00007,Control module reference number-Display/control head,8E,
IDE01993-SFT00008,Control module reference number-Climate Control Module,46,
IDE01993-SFT00009,Control module reference number-Electronic central electric,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,61,
IDE01993-SFT00017,Control module reference number-Engine electronics 2,78,
IDE01993-SFT00019,Control module reference number-Distance Regulation,57,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00021,Control module reference number-Airbag,06,
IDE01993-SFT00022,Control module reference number-Steering column electronics systems,0C,
IDE01993-SFT00023,Control module reference number-Instrument cluster,14,
IDE01993-SFT00024,Control module reference number-Auxiliary/parking heating,6A,
IDE01993-SFT00025,Control module reference number-Data Bus OBD Interface,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High beam assistant,30,
IDE01993-SFT00033,Control module reference number-Battery management 2,9C,
IDE01993-SFT00034,Control module reference number-All-wheel drive electronics,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Convertible top operation,2D,
IDE01993-SFT00039,Control module reference number-Display/operating unit rear,93,
IDE01993-SFT00040,Control module reference number-Rear A/C control head,00,
IDE01993-SFT00042,Control module reference number-Control module for wireless charging,8F,
IDE01993-SFT00043,Control module reference number-Steering column lock,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Differential lock electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat adjustment: driver side,4C,
IDE01993-SFT00060,Control module reference number-Lane change assistance,08,
IDE01993-SFT00060,Control module reference number-Lane change assistance,4E,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Driver's door electronics,4A,
IDE01993-SFT00067,Control module reference number-Brake Electronics 2,C8,
IDE01993-SFT00068,Control module reference number-Power steering,12,
IDE01993-SFT00070,Control module reference number-Comfort system central control module,00,
IDE01993-SFT00070,Control module reference number-Comfort system central control module,8B,
IDE01993-SFT00072,Control module reference number-Seat adjustment: rear driver's side,87,
IDE01993-SFT00080,Control module reference number-Seat adjustment 3. seat row,95,
IDE01993-SFT00081,Control module reference number-Electric drive,03,
IDE01993-SFT00081,Control module reference number-Electric drive,7C,
IDE01993-SFT00082,Control module reference number-Passenger's door electronics,4B,
IDE01993-SFT00090,Control module reference number-Automated longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat adjustment: rear passenger side,88,
IDE01993-SFT00095,Control module reference number-Information electronics 1,73,
IDE01993-SFT00095,Control module reference number-Information electronics 1,00,
IDE01993-SFT00095,Control module reference number-Information electronics 1,F2,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring System (TPMS),0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamic control module,24,
IDE01993-SFT00108,Control module reference number-Rear view camera system,69,
IDE01993-SFT00109,Control module reference number-Rear lid electronics,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,00,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,F0,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,67,
IDE01993-SFT00118,Control module reference number-Parking aid,00,
IDE01993-SFT00128,Control module reference number-Battery control additional memory 1,AE,
IDE01993-SFT00129,Control module reference number-Selector lever,53,
IDE01993-SFT00130,Control module reference number-Head-Up-Display,00,
IDE01993-SFT00130,Control module reference number-Head-Up-Display,1B,
IDE01993-SFT00132,Control module reference number-Night vision system,27,
IDE01993-SFT00139,Control module reference number-Distance regulation 2,00,
IDE01993-SFT00140,Control module reference number-Hybrid Battery Management,7B,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,F1,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,04,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,4F,
IDE01993-SFT00166,Control module reference number-Microphone control module,00,
IDE01993-SFT00169,Control module reference number-Structure-borne sound actuator,1C,
IDE01993-SFT00172,Control module reference number-Reducing Agent Metering System,2A,
IDE01993-SFT00186,Control module reference number-Subframe mount,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Electric drive 3,43,
IDE01993-SFT00196,Control module reference number-Voltage converter,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-High-voltage battery charger,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser for adaptive cruise control,89,
IDE01993-SFT00206,Control module reference number-Electric drive 2,00,
IDE01993-SFT00206,Control module reference number-Electric drive 2,B8,
IDE01993-SFT00207,Control module reference number-Lane Change Assistant 2,07,
IDE01993-SFT00207,Control module reference number-Lane Change Assistant 2,8A,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,59,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,9D,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,9E,
IDE01993-SFT00221,Control module reference number-Sunroof control module 2,A0,
IDE01993-SFT33028,Control module reference number-High voltage converter,B7,
IDE01993-SFT33031,Control module reference number-Antenna module,BA,
IDE01993-SFT33032,Control module reference number-Control unit for hood ornament,00,
IDE01993-SFT33041,Control module reference number-Right exterior rear view mirror,C5,
IDE01993-SFT33042,Control module reference number-Left exterior rear view mirror,C4,
IDE01993-SFT33043,Control module reference number-HV battery charging unit 2,C6,
IDE01993-SFT33044,Control module reference number-High voltage converter 2,C7,
IDE01993-SFT33045,Control module reference number-Remote Multifunction Module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,F3,
IDE01993-SFT09760,Control module reference number-Sunroof control module,84,
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-IDE15844,Status of event memory-Fuel cell drive control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Electronics,OK,
IDE02384-SFT00002,Status of event memory-Transmission Electronics,OK,
IDE02384-SFT00003,Status of event memory-Brake electronics,OK,
IDE02384-SFT00006,Status of event memory-Seat adjustment: passenger's side,OK,
IDE02384-SFT00007,Status of event memory-Display/control head,OK,
IDE02384-SFT00008,Status of event memory-Climate Control Module,OK,
IDE02384-SFT00009,Status of event memory-Electronic central electric,OK,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine electronics 2,OK,
IDE02384-SFT00019,Status of event memory-Distance Regulation,OK,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering column electronics systems,OK,
IDE02384-SFT00023,Status of event memory-Instrument cluster,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary/parking heating,OK,
IDE02384-SFT00025,Status of event memory-Data Bus OBD Interface,OK,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High beam assistant,OK,
IDE02384-SFT00033,Status of event memory-Battery management 2,OK,
IDE02384-SFT00034,Status of event memory-All-wheel drive electronics,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Convertible top operation,OK,
IDE02384-SFT00039,Status of event memory-Display/operating unit rear,OK,
IDE02384-SFT00040,Status of event memory-Rear A/C control head,OK,
IDE02384-SFT00042,Status of event memory-Control module for wireless charging,OK,
IDE02384-SFT00043,Status of event memory-Steering column lock,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Differential lock electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat adjustment: driver side,OK,
IDE02384-SFT00060,Status of event memory-Lane change assistance,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Driver's door electronics,OK,
IDE02384-SFT00067,Status of event memory-Brake Electronics 2,OK,
IDE02384-SFT00068,Status of event memory-Power steering,OK,
IDE02384-SFT00070,Status of event memory-Comfort system central control module,OK,
IDE02384-SFT00072,Status of event memory-Seat adjustment: rear driver's side,OK,
IDE02384-SFT00080,Status of event memory-Seat adjustment 3. seat row,OK,
IDE02384-SFT00081,Status of event memory-Electric drive,OK,
IDE02384-SFT00082,Status of event memory-Passenger's door electronics,OK,
IDE02384-SFT00090,Status of event memory-Automated longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat adjustment: rear passenger side,OK,
IDE02384-SFT00095,Status of event memory-Information electronics 1,OK,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring System (TPMS),OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamic control module,OK,
IDE02384-SFT00108,Status of event memory-Rear view camera system,OK,
IDE02384-SFT00109,Status of event memory-Rear lid electronics,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00117,Status of event memory-Emergency call module and communication unit,OK,
IDE02384-SFT00118,Status of event memory-Parking aid,OK,
IDE02384-SFT00128,Status of event memory-Battery control additional memory 1,OK,
IDE02384-SFT00129,Status of event memory-Selector lever,OK,
IDE02384-SFT00130,Status of event memory-Head-Up-Display,OK,
IDE02384-SFT00132,Status of event memory-Night vision system,OK,
IDE02384-SFT00139,Status of event memory-Distance regulation 2,OK,
IDE02384-SFT00140,Status of event memory-Hybrid Battery Management,OK,
IDE02384-SFT00165,Status of event memory-Front sensor for drivers assistant systems,OK,
IDE02384-SFT00166,Status of event memory-Microphone control module,OK,
IDE02384-SFT00169,Status of event memory-Structure-borne sound actuator,OK,
IDE02384-SFT00172,Status of event memory-Reducing Agent Metering System,OK,
IDE02384-SFT00186,Status of event memory-Subframe mount,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Electric drive 3,OK,
IDE02384-SFT00196,Status of event memory-Voltage converter,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-High-voltage battery charger,OK,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser for adaptive cruise control,OK,
IDE02384-SFT00206,Status of event memory-Electric drive 2,OK,
IDE02384-SFT00207,Status of event memory-Lane Change Assistant 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Sunroof control module 2,OK,
IDE02384-SFT33028,Status of event memory-High voltage converter,OK,
IDE02384-SFT33031,Status of event memory-Antenna module,OK,
IDE02384-SFT33032,Status of event memory-Control unit for hood ornament,OK,
IDE02384-SFT33041,Status of event memory-Right exterior rear view mirror,OK,
IDE02384-SFT33042,Status of event memory-Left exterior rear view mirror,OK,
IDE02384-SFT33043,Status of event memory-HV battery charging unit 2,OK,
IDE02384-SFT33044,Status of event memory-High voltage converter 2,OK,
IDE02384-SFT33045,Status of event memory-Remote Multifunction Module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT09760,Status of event memory-Sunroof control module,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Anti-play protection,not active,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09775,Steering wheel heating-Steering wheel temp.,82, °C
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent mode,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,31,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,0,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,24,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent mode,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charge contingency,0,
IDE03011-MAS06004,Number of requested start processes-Special start request,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Bus sleep mode,
IDE03150-IDE15844,Readiness for bus sleep mode-Fuel cell drive control module,Bus sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Electronics,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Electronics,active,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,Bus sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,active,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat adjustment: passenger's side,Bus sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display/control head,Bus sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-Climate Control Module,Bus sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Bus sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine electronics 2,Bus sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Distance Regulation,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering column electronics systems,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Instrument cluster,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary/parking heating,Bus sleep mode,
IDE03150-SFT00025,Readiness for bus sleep mode-Data Bus OBD Interface,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Bus sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High beam assistant,Bus sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery management 2,active,
IDE03150-SFT00034,Readiness for bus sleep mode-All-wheel drive electronics,Bus sleep mode,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Bus sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Convertible top operation,Bus sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display/operating unit rear,Bus sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Rear A/C control head,Bus sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control module for wireless charging,Bus sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering column lock,Bus sleep mode,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Bus sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Differential lock electronics,Bus sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat adjustment: driver side,Bus sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,active,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,Bus sleep mode,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Bus sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Driver's door electronics,active,
IDE03150-SFT00067,Readiness for bus sleep mode-Brake Electronics 2,Bus sleep mode,
IDE03150-SFT00068,Readiness for bus sleep mode-Power steering,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Comfort system central control module,Bus sleep mode,
IDE03150-SFT00070,Readiness for bus sleep mode-Comfort system central control module,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat adjustment: rear driver's side,Bus sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat adjustment 3. seat row,Bus sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Electric drive,Bus sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Passenger's door electronics,active,
IDE03150-SFT00090,Readiness for bus sleep mode-Automated longitudinal control,Bus sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat adjustment: rear passenger side,Bus sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information electronics 1,active,
IDE03150-SFT00095,Readiness for bus sleep mode-Information electronics 1,Bus sleep mode,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring System (TPMS),Bus sleep mode,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Bus sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamic control module,Bus sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Rear view camera system,Bus sleep mode,
IDE03150-SFT00109,Readiness for bus sleep mode-Rear lid electronics,Bus sleep mode,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,active,
IDE03150-SFT00117,Readiness for bus sleep mode-Emergency call module and communication unit,Bus sleep mode,
IDE03150-SFT00117,Readiness for bus sleep mode-Emergency call module and communication unit,active,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking aid,Bus sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery control additional memory 1,Bus sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Selector lever,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head-Up-Display,Bus sleep mode,
IDE03150-SFT00130,Readiness for bus sleep mode-Head-Up-Display,active,
IDE03150-SFT00132,Readiness for bus sleep mode-Night vision system,Bus sleep mode,
IDE03150-SFT00139,Readiness for bus sleep mode-Distance regulation 2,Bus sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Hybrid Battery Management,Bus sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for drivers assistant systems,Bus sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for drivers assistant systems,active,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone control module,Bus sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Structure-borne sound actuator,Bus sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reducing Agent Metering System,Bus sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Subframe mount,Bus sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Bus sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Electric drive 3,Bus sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-Voltage converter,active,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,Bus sleep mode,
IDE03150-SFT00198,Readiness for bus sleep mode-High-voltage battery charger,Bus sleep mode,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,Bus sleep mode,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser for adaptive cruise control,Bus sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Electric drive 2,Bus sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistant 2,Bus sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistant 2,active,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Bus sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Bus sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Bus sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Sunroof control module 2,active,
IDE03150-SFT33028,Readiness for bus sleep mode-High voltage converter,Bus sleep mode,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Bus sleep mode,
IDE03150-SFT33032,Readiness for bus sleep mode-Control unit for hood ornament,Bus sleep mode,
IDE03150-SFT33041,Readiness for bus sleep mode-Right exterior rear view mirror,Bus sleep mode,
IDE03150-SFT33042,Readiness for bus sleep mode-Left exterior rear view mirror,Bus sleep mode,
IDE03150-SFT33043,Readiness for bus sleep mode-HV battery charging unit 2,Bus sleep mode,
IDE03150-SFT33044,Readiness for bus sleep mode-High voltage converter 2,Bus sleep mode,
IDE03150-SFT33045,Readiness for bus sleep mode-Remote Multifunction Module,Bus sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Bus sleep mode,
IDE03150-SFT09760,Readiness for bus sleep mode-Sunroof control module,active,
IDE03205,Manufacturer code,YSN,
IDE03212,Start/stop conditions,Stop prohibition: no start request,
IDE03213,Start/stop enable,At least one release missing,
IDE03477-MAS00106,GPS time-Year,Not available,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,No malfunction,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,No malfunction,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,No malfunction,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,No malfunction,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,No malfunction,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,No malfunction,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,available.,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Data bus Sensor/Hybrid,
IDE04343-IDE15844,Bus identification-Fuel cell drive control module,Unknown,
IDE04343-SFT00001,Bus identification-Engine Electronics,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Electronics,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brake electronics,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brake electronics,FlexRay B data bus,
IDE04343-SFT00006,Bus identification-Seat adjustment: passenger's side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display/control head,Infotainment data bus,
IDE04343-SFT00008,Bus identification-Climate Control Module,Comfort CAN bus 2,
IDE04343-SFT00009,Bus identification-Electronic central electric,Comfort CAN bus 2,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Data bus Flexray A,
IDE04343-SFT00017,Bus identification-Engine electronics 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Distance Regulation,FlexRay B data bus,
IDE04343-SFT00021,Bus identification-Airbag,FlexRay B data bus,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00022,Bus identification-Steering column electronics systems,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Instrument cluster,Combi/dashboard data bus,
IDE04343-SFT00024,Bus identification-Auxiliary/parking heating,Extended data bus,
IDE04343-SFT00025,Bus identification-Data Bus OBD Interface,Bus master,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High beam assistant,Extended data bus,
IDE04343-SFT00033,Bus identification-Battery management 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All-wheel drive electronics,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Convertible top operation,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display/operating unit rear,Infotainment data bus,
IDE04343-SFT00040,Bus identification-Rear A/C control head,Unknown,
IDE04343-SFT00042,Bus identification-Control module for wireless charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering column lock,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Differential lock electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat adjustment: driver side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,Extended data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,FlexRay B data bus,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Driver's door electronics,Comfort data bus,
IDE04343-SFT00067,Bus identification-Brake Electronics 2,Data bus Flexray A,
IDE04343-SFT00068,Bus identification-Power steering,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Comfort system central control module,Comfort data bus,
IDE04343-SFT00070,Bus identification-Comfort system central control module,Unknown,
IDE04343-SFT00072,Bus identification-Seat adjustment: rear driver's side,Comfort data bus,
IDE04343-SFT00080,Bus identification-Seat adjustment 3. seat row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Flexray A,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Sensor/Hybrid,
IDE04343-SFT00082,Bus identification-Passenger's door electronics,Comfort data bus,
IDE04343-SFT00090,Bus identification-Automated longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat adjustment: rear passenger side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information electronics 1,Infotainment data bus,
IDE04343-SFT00095,Bus identification-Information electronics 1,VLAN_Infotainment,
IDE04343-SFT00095,Bus identification-Information electronics 1,Unknown,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring System (TPMS),Extended data bus,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamic control module,Comfort data bus,
IDE04343-SFT00108,Bus identification-Rear view camera system,Extended data bus,
IDE04343-SFT00109,Bus identification-Rear lid electronics,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,Unknown,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,VLAN_Connect,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,Data bus connect,
IDE04343-SFT00118,Bus identification-Parking aid,Unknown,
IDE04343-SFT00128,Bus identification-Battery control additional memory 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Selector lever,Combi/dashboard data bus,
IDE04343-SFT00130,Bus identification-Head-Up-Display,Unknown,
IDE04343-SFT00130,Bus identification-Head-Up-Display,Combi/dashboard data bus,
IDE04343-SFT00132,Bus identification-Night vision system,Extended data bus,
IDE04343-SFT00139,Bus identification-Distance regulation 2,Unknown,
IDE04343-SFT00140,Bus identification-Hybrid Battery Management,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,VLAN_FAS,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,Data bus Flexray A,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,FlexRay B data bus,
IDE04343-SFT00166,Bus identification-Microphone control module,Unknown,
IDE04343-SFT00169,Bus identification-Structure-borne sound actuator,Extended data bus,
IDE04343-SFT00172,Bus identification-Reducing Agent Metering System,Extended data bus,
IDE04343-SFT00186,Bus identification-Subframe mount,Extended data bus,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Extended data bus,
IDE04343-SFT00195,Bus identification-Electric drive 3,Data bus Flexray A,
IDE04343-SFT00196,Bus identification-Voltage converter,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-High-voltage battery charger,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser for adaptive cruise control,FlexRay B data bus,
IDE04343-SFT00206,Bus identification-Electric drive 2,Data bus Flexray A,
IDE04343-SFT00207,Bus identification-Lane Change Assistant 2,FlexRay B data bus,
IDE04343-SFT00207,Bus identification-Lane Change Assistant 2,Extended data bus,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Comfort CAN bus 2,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,FlexRay B data bus,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,FlexRay B data bus,
IDE04343-SFT00221,Bus identification-Sunroof control module 2,Comfort data bus,
IDE04343-SFT33031,Bus identification-Antenna module,Infotainment data bus,
IDE04343-SFT33032,Bus identification-Control unit for hood ornament,Unknown,
IDE04343-SFT33041,Bus identification-Right exterior rear view mirror,Comfort CAN bus 2,
IDE04343-SFT33042,Bus identification-Left exterior rear view mirror,Comfort CAN bus 2,
IDE04343-SFT33043,Bus identification-HV battery charging unit 2,Data bus Sensor/Hybrid,
IDE04343-SFT33044,Bus identification-High voltage converter 2,Data bus Sensor/Hybrid,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,VLAN_FAS,
IDE04343-SFT09760,Bus identification-Sunroof control module,Comfort data bus,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,Not operated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,Not operated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,Not operated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,no function,
IDE05583-IDE09851,Break recommendation-Function active,No,
IDE05583-MAS03095,Break recommendation-Function status,not installed,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Break recommendation-deactivation status,Switched off: not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,DB 70 1C 66 58,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine Control Module,
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Start-stop,
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Profile 2,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,Profile 4,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,23, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,0, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG04216,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG04217,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG04218,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,516, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,540, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,0, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,0, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,0, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,0, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,0, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2000, yr
IDE06230-MAS00107,Break recommend.: last message-Month,1, m
IDE06230-MAS00108,Break recommend.: last message-Day,1, d
IDE06230-MAS00109,Break recommend.: last message-Hours,0, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,0, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,0, s
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,no warning,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,Malfunction,
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,Malfunction,
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,19,
IDE06307-MAS00109,Stop prevention history data-Hours,15,
IDE06307-MAS00110,Stop prevention history data-Minutes,21,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,Possible standing time too short,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Battery state of charge too low,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,1,
IDE06308-MAS00108,Start request history data-Day,1,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06577,Supplier Identification,--------------------------------,
IDE06805-MAS09523,Status of voltage freedom-Transformer for electrical drive,Initialization,
IDE06805-MAS09524,Status of voltage freedom-Hybrid Battery Management,Initialization,
IDE06805-MAS09525,Status of voltage freedom-Control module for wireless charging,Initialization,
IDE06805-MAS09526,Status of voltage freedom-High-voltage battery charger,Initialization,
IDE06805-MAS11874,Status of voltage freedom-Overall status,Initialization,
IDE06805-SFT00195,Status of voltage freedom-Electric drive 3,Initialization,
IDE06805-SFT00206,Status of voltage freedom-Electric drive 2,Initialization,
IDE06805-SFT33043,Status of voltage freedom-HV battery charging unit 2,Initialization,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,0,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,0,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,5,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,14,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,35,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,0,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,26,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,2,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,0,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,0,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,2,
IDE07431-IDE04447,Status: driving mode selection for AFS & headlamp range control-Function status,not engaged,
IDE07431-IDE06260,Status: driving mode selection for AFS & headlamp range control-ID number,0,
IDE07431-MAS01156,Status: driving mode selection for AFS & headlamp range control-Communication status,OK,
IDE07431-MAS01447,Status: driving mode selection for AFS & headlamp range control-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,2,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.75, V
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.25, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.30, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,Malfunction,
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,472, A
IDE07847-MAS00976,Start stop requests without reason-Counter,0,
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Comfort,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,Not Used,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07873-MAS08879,Driving mode selection activated profiles-Profile 13,Not Used,
IDE07873-MAS08880,Driving mode selection activated profiles-Profile 14,Not Used,
IDE07873-MAS08881,Driving mode selection activated profiles-Profile 15,Not Used,
IDE08343,Immobilizer Challenge,5B AD A5 F6,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08490,Activation of diagnosis via ethernet,active,
IDE08530-MAS00106,Connection status online basic services-Year,2030, yr
IDE08530-MAS00107,Connection status online basic services-Month,4, m
IDE08530-MAS00108,Connection status online basic services-Day,10, d
IDE08530-MAS00109,Connection status online basic services-Hours,24, H
IDE08530-MAS00110,Connection status online basic services-Minutes,19, min
IDE08530-MAS00111,Connection status online basic services-Seconds,5, s
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,0,
IDE08531-MAS00106,Connection status online license services-Year,Not available,
IDE08531-MAS00107,Connection status online license services-Month,Not available,
IDE08531-MAS00108,Connection status online license services-Day,Not available,
IDE08531-MAS00109,Connection status online license services-Hours,Not available,
IDE08531-MAS00110,Connection status online license services-Minutes,Not available,
IDE08531-MAS07132,Connection status online license services-Code status,1792255,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531-MAS07134,Connection status online license services-ID services,8704,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,Not available,
IDE08531-MAS07137,Connection status online license services-Exp. month,Not available,
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08600-IDE04447,Status drive profile selec. for rear-wheel drive-Function status,not engaged,
IDE08600-IDE06260,Status drive profile selec. for rear-wheel drive-ID number,0,
IDE08600-MAS01156,Status drive profile selec. for rear-wheel drive-Communication status,OK,
IDE08600-MAS01447,Status drive profile selec. for rear-wheel drive-Act.val.,0,
IDE08601-IDE04447,Drive profile selection for actuator for exterior noise-Function status,engaged,
IDE08601-IDE06260,Drive profile selection for actuator for exterior noise-ID number,0,
IDE08601-MAS01156,Drive profile selection for actuator for exterior noise-Communication status,OK,
IDE08601-MAS01447,Drive profile selection for actuator for exterior noise-Act.val.,0,
IDE08602-IDE04447,Status drive profile selec. for active steering-Function status,not engaged,
IDE08602-IDE06260,Status drive profile selec. for active steering-ID number,0,
IDE08602-MAS01156,Status drive profile selec. for active steering-Communication status,OK,
IDE08602-MAS01447,Status drive profile selec. for active steering-Act.val.,0,
IDE08605-IDE04447,Status drive profile for level control system-Function status,engaged,
IDE08605-IDE06260,Status drive profile for level control system-ID number,0,
IDE08605-MAS01156,Status drive profile for level control system-Communication status,OK,
IDE08605-MAS01447,Status drive profile for level control system-Act.val.,2,
IDE08611-IDE04447,Status drive profile for stabilizer-Function status,engaged,
IDE08611-IDE06260,Status drive profile for stabilizer-ID number,0,
IDE08611-MAS01156,Status drive profile for stabilizer-Communication status,OK,
IDE08611-MAS01447,Status drive profile for stabilizer-Act.val.,0,
IDE08614-IDE04447,Status drive profile for engine operating conditions-Function status,not engaged,
IDE08614-IDE06260,Status drive profile for engine operating conditions-ID number,0,
IDE08614-MAS01156,Status drive profile for engine operating conditions-Communication status,OK,
IDE08614-MAS01447,Status drive profile for engine operating conditions-Act.val.,0,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,not engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08798-IDE04447,Status: drive profile for Matrix-Beam-Function status,engaged,
IDE08798-IDE06260,Status: drive profile for Matrix-Beam-ID number,0,
IDE08798-MAS01156,Status: drive profile for Matrix-Beam-Communication status,OK,
IDE08798-MAS01447,Status: drive profile for Matrix-Beam-Act.val.,2,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,not engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,9,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE08956-MAS08051,H-V power distro-Power allocation thermal management,6400, W
IDE08956-MAS08052,H-V power distro-Power quota: 12 V electrical system,1500, W
IDE08956-MAS08054,H-V power distro-Power quota: comfort loads,3000, W
IDE08956-MAS13094,H-V power distro-Power allocation by engine electronics,Malfunction,
IDE08956-MAS13095,H-V power distro-Power allocation by high-voltage battery charger,Malfunction,
IDE08956-MAS13096,H-V power distro-Power allocation by hybrid battery management,Malfunction,
IDE08956-MAS13097,H-V power distro-Power drawn by voltage transformer for electric drive,Malfunction,
IDE08956-MAS13098,H-V power distro-Power drawn by thermal management,Malfunction,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,65250,
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),18.00,
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,10.00, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,18.00,
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,34.00, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,900, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,6.00,
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.00, l/100km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,28, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,25, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,28, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,28, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,Malfunction,
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,Malfunction,
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,20, km
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,20, km
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,not installed,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,10.00, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,9.00, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,10.00, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,10.00, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,10.00, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,9.00, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.00, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,18.00,
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,18.00,
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,18.00,
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,18.00,
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,18.00,
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,18.00,
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.00,
IDE09080-MAS12005,Energy storage unit-Tank capacity with conventional fuel for range calculation,3.00, l
IDE09080-MAS12006,Energy storage unit-Energy content of HV battery for range calculation,0,
IDE09080-MAS12007,Energy storage unit-Tank capacity with CNG for range calculation,0.00, l
IDE09080-MAS12008,Energy storage unit-Tank capacity with LPG for range calculation,0.00, l
IDE09467,MAC address,48 C5 8D 2D E1 13,
IDE09468-MAS01390,IPv4 address-Block 1,192,
IDE09468-MAS01391,IPv4 address-Block 2,168,
IDE09468-MAS01392,IPv4 address-Block 3,10,
IDE09468-MAS01393,IPv4 address-Block 4,2,
IDE09469-MAS01390,IPv6 address-Block 1,00 00,
IDE09469-MAS01391,IPv6 address-Block 2,00 00,
IDE09469-MAS01392,IPv6 address-Block 3,00 00,
IDE09469-MAS01393,IPv6 address-Block 4,00 00,
IDE09469-MAS01394,IPv6 address-Block 5,00 00,
IDE09469-MAS01395,IPv6 address-Block 6,00 00,
IDE09469-MAS01396,IPv6 address-Block 7,00 00,
IDE09469-MAS01397,IPv6 address-Block 8,00 00,
IDE09891-SFT00081,Voltage converter for electric drive: status of electric drive-Electric drive,No malfunction detected,
IDE09891-SFT00195,Voltage converter for electric drive: status of electric drive-Electric drive 3,No malfunction detected,
IDE09891-SFT00206,Voltage converter for electric drive: status of electric drive-Electric drive 2,No malfunction detected,
IDE09892-MAS02832,Hybrid battery management: status of electric drive-Malfunction status,No malfunction detected,
IDE09892-MAS03001,Hybrid battery management: status of electric drive-Mode,Standby-mode,
IDE09893-MAS02832,High voltage battery charger: status of electric drive-Malfunction status,No malfunction detected,
IDE09893-MAS03001,High voltage battery charger: status of electric drive-Mode,not active,
IDE09893-MAS17068,High voltage battery charger: status of electric drive-High-voltage battery charger 2: actual status,Standby-mode,
IDE09893-MAS17070,High voltage battery charger: status of electric drive-High-voltage battery charger 2: error status,No malfunction detected,
IDE09893-MAS17071,High voltage battery charger: status of electric drive-High-voltage charging management: current mode,not active,
IDE09893-MAS17072,High voltage battery charger: status of electric drive-High-voltage charging management: error status,No malfunction detected,
IDE09894-MAS13356,Thermal management: status of electric drive-Error status additional air heating,Initialization,
IDE09894-MAS13357,Thermal management: status of electric drive-Mode additional air heating,Initialization,
IDE09894-MAS13358,Thermal management: status of electric drive-Error status A/C compressor,Initialization,
IDE09894-MAS13359,Thermal management: status of electric drive-Mode A/C compressor,Initialization,
IDE09895-MAS13099,Engine electronics: status of electric drive-Error status electric drive,Initialization,
IDE09895-MAS13100,Engine electronics: status of electric drive-Electric drive mode,Initialization,
IDE09895-MAS13101,Engine electronics: status of electric drive-Error status of electric machine,Initialization,
IDE09895-MAS13102,Engine electronics: status of electric drive-Electric machine mode,255,
IDE09896-MAS02832,Ctrl. module for contactless charging: status of electric drive-Malfunction status,No malfunction detected,
IDE09896-MAS03001,Ctrl. module for contactless charging: status of electric drive-Mode,not active,
IDE09897-MAS02246,Volt. converter for elec. drive: high-volt. activ. restrict.-Timeout,not active,
IDE09897-MAS09518,Volt. converter for elec. drive: high-volt. activ. restrict.-Safety line,not active,
IDE09897-MAS09519,Volt. converter for elec. drive: high-volt. activ. restrict.-Message error,not active,
IDE09897-MAS09542,Volt. converter for elec. drive: high-volt. activ. restrict.-Error status init. error,not active,
IDE09897-MAS09544,Volt. converter for elec. drive: high-volt. activ. restrict.-No component function,not active,
IDE09897-MAS09546,Volt. converter for elec. drive: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09897-MAS12345,Volt. converter for elec. drive: high-volt. activ. restrict.-Active discharge fault,not active,
IDE09898-MAS02246,Hybrid batt. management:  H-V activ. restriction-Timeout,not active,
IDE09898-MAS03123,Hybrid batt. management:  H-V activ. restriction-Reduced performance,not active,
IDE09898-MAS09513,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 1 failed,not active,
IDE09898-MAS09514,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 2 failed,not active,
IDE09898-MAS09518,Hybrid batt. management:  H-V activ. restriction-Safety line,not active,
IDE09898-MAS09519,Hybrid batt. management:  H-V activ. restriction-Message error,not active,
IDE09898-MAS09520,Hybrid batt. management:  H-V activ. restriction-Safety connector,not active,
IDE09898-MAS09541,Hybrid batt. management:  H-V activ. restriction-Act. mode init. error,not active,
IDE09898-MAS09542,Hybrid batt. management:  H-V activ. restriction-Error status init. error,not active,
IDE09898-MAS09543,Hybrid batt. management:  H-V activ. restriction-Operating mode error,not active,
IDE09898-MAS09544,Hybrid batt. management:  H-V activ. restriction-No component function,not active,
IDE09898-MAS09545,Hybrid batt. management:  H-V activ. restriction-Sequence error,not active,
IDE09898-MAS09546,Hybrid batt. management:  H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09898-MAS12351,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement error,not active,
IDE09898-MAS13068,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement initialization error,not active,
IDE09899-MAS02246,Eng. electronics: H-V activ. restriction-Timeout,not active,
IDE09899-MAS09519,Eng. electronics: H-V activ. restriction-Message error,not active,
IDE09899-MAS09541,Eng. electronics: H-V activ. restriction-Act. mode init. error,not active,
IDE09899-MAS09545,Eng. electronics: H-V activ. restriction-Sequence error,not active,
IDE09899-MAS09547,Eng. electronics: H-V activ. restriction-Error status drive motor: init. error,not active,
IDE09899-MAS09548,Eng. electronics: H-V activ. restriction-Error status drive: init. error,not active,
IDE09899-MAS09549,Eng. electronics: H-V activ. restriction-Drive condition: init. error,not active,
IDE09899-MAS09550,Eng. electronics: H-V activ. restriction-Safety line power electronics,not active,
IDE09899-MAS09551,Eng. electronics: H-V activ. restriction-Part. oper.,not active,
IDE09899-MAS09552,Eng. electronics: H-V activ. restriction-HV shut-down due to operating strategy,not active,
IDE09899-MAS09553,Eng. electronics: H-V activ. restriction-no component function drive motor,not active,
IDE09899-MAS09554,Eng. electronics: H-V activ. restriction-no component function drive,not active,
IDE09900-MAS02246,H-V batt. charger H-V activ. restriction-Timeout,not active,
IDE09900-MAS09519,H-V batt. charger H-V activ. restriction-Message error,not active,
IDE09900-MAS09546,H-V batt. charger H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09901-MAS02246,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Timeout,not active,
IDE09901-MAS09518,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Safety line,not active,
IDE09901-MAS09519,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Message error,not active,
IDE09901-MAS09541,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09901-MAS09542,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Error status init. error,not active,
IDE09901-MAS09543,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Operating mode error,not active,
IDE09901-MAS09544,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-No component function,not active,
IDE09901-MAS09546,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09901-MAS12351,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09901-MAS13068,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement initialization error,not active,
IDE09902-MAS02246,A/C compressor: H-V activ. restriction-Timeout,not active,
IDE09902-MAS09518,A/C compressor: H-V activ. restriction-Safety line,not active,
IDE09902-MAS09519,A/C compressor: H-V activ. restriction-Message error,not active,
IDE09902-MAS09541,A/C compressor: H-V activ. restriction-Act. mode init. error,not active,
IDE09902-MAS09542,A/C compressor: H-V activ. restriction-Error status init. error,not active,
IDE09902-MAS09544,A/C compressor: H-V activ. restriction-No component function,not active,
IDE09902-MAS09545,A/C compressor: H-V activ. restriction-Sequence error,not active,
IDE09902-MAS12351,A/C compressor: H-V activ. restriction-HV voltage measurement error,not active,
IDE09903-MAS02246,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Timeout,not active,
IDE09903-MAS09518,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Safety line,not active,
IDE09903-MAS09519,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Message error,not active,
IDE09903-MAS09541,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09903-MAS09542,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Error status init. error,not active,
IDE09903-MAS09544,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-No component function,not active,
IDE09903-MAS09545,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Sequence error,not active,
IDE09903-MAS12351,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09904-MAS00799,Airbag: H-V activ. restriction-Airbag control module,not active,
IDE09904-MAS02246,Airbag: H-V activ. restriction-Timeout,not active,
IDE09904-MAS09519,Airbag: H-V activ. restriction-Message error,not active,
IDE09904-MAS09521,Airbag: H-V activ. restriction-Light accident detected,not active,
IDE09904-MAS09522,Airbag: H-V activ. restriction-Severe accident detected,not active,
IDE09905-IDE08968,H-V activ. restriction-HV charge management,not active,
IDE09905-MAS00799,H-V activ. restriction-Airbag control module,not active,
IDE09905-MAS08044,H-V activ. restriction-Thermal management,not active,
IDE09905-MAS09516,H-V activ. restriction-Engine Electronics,not active,
IDE09905-MAS09523,H-V activ. restriction-Transformer for electrical drive,not active,
IDE09905-MAS09524,H-V activ. restriction-Hybrid Battery Management,not active,
IDE09905-MAS09525,H-V activ. restriction-Control module for wireless charging,not active,
IDE09905-MAS09526,H-V activ. restriction-High-voltage battery charger,not active,
IDE09905-MAS09555,H-V activ. restriction-HV activation prohibited due to accident,not active,
IDE09905-MAS09557,H-V activ. restriction-HV activation prohibited due to de-activation,not active,
IDE09905-MAS09558,H-V activ. restriction-HV activation prohibited due to blocking,not active,
IDE09905-MAS12352,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1,not active,
IDE09905-MAS12353,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2,not active,
IDE09905-MAS17064,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 3,not active,
IDE09905-MAS17065,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 4,not active,
IDE09905-MAS17066,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 5,not active,
IDE09905-SFT00195,H-V activ. restriction-Electric drive 3,not active,
IDE09905-SFT00206,H-V activ. restriction-Electric drive 2,not active,
IDE09905-SFT33043,H-V activ. restriction-HV battery charging unit 2,not active,
IDE10084-MAS03950,Hybrid drive operating mode-Combustion engine: status,Engine running,
IDE10084-MAS09828,Hybrid drive operating mode-Status of drive readiness hybrid,active,
IDE10084-MAS09829,Hybrid drive operating mode-Engine start in start-stop mode active,not active,
IDE10084-MAS09830,Hybrid drive operating mode-Engine stop in start-stop mode active,not active,
IDE10084-MAS09831,Hybrid drive operating mode-Engine running or driver readiness at engine stop,active,
IDE10341-SFT09757,Install. list of subsystems: act. install.-Generator,Not available,
IDE10341-SFT09777,Install. list of subsystems: act. install.-Multifunction steering wheel control module,available.,
IDE10341-SFT09783,Install. list of subsystems: act. install.-Battery Monitoring Control Module,available.,
IDE10341-SFT09833,Install. list of subsystems: act. install.-Inverter for electrical outlet,Not available,
IDE10341-SFT09960,Install. list of subsystems: act. install.-Starter generator,Not available,
IDE10341-SFT10046,Install. list of subsystems: act. install.-Steering Wheel Touch Recognition Control Module,Not available,
IDE10342-IDE02068,Standard - ambient data 1: status-Time stamp,Up-to-date,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,Up-to-date,
IDE10365-MAS10445,Message mirroring: bus allocation-Data bus CAN 1,Comfort data bus,
IDE10365-MAS10446,Message mirroring: bus allocation-Data bus CAN 2,Instrument cluster data bus,
IDE10365-MAS10447,Message mirroring: bus allocation-Data bus CAN 3,Data bus Sensor/Hybrid,
IDE10365-MAS10448,Message mirroring: bus allocation-Data bus CAN 4,Infotainment data bus,
IDE10365-MAS10449,Message mirroring: bus allocation-Data bus CAN 5,Extended data bus,
IDE10365-MAS10450,Message mirroring: bus allocation-Data bus CAN 6,Data bus diagnostics,
IDE10365-MAS11107,Message mirroring: bus allocation-Data bus CAN 7,Comfort CAN bus 2,
IDE10365-MAS17841,Message mirroring: bus allocation-Data bus CAN 8,Data bus connect,
IDE10505,History data 45,014*2019-09-13-21:19*1*050*000*000*000*000*000*004*000*000*000**,
IDE10505,History data 45,011*2019-09-12-00:13*1*050*000*000*000*000*000*001*000*000*000**,
IDE10505,History data 45,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE10505,History data 45,013*2019-09-13-21:18*1*050*000*000*000*000*000*003*000*000*000**,
IDE10505,History data 45,012*2019-09-12-01:41*1*050*000*000*000*000*000*002*000*000*000**,
IDE10506,History data 46,000*2000-01-01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00*00000**,
IDE10506,History data 46,000*2000-01dZ -01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00,
IDE10510-MAS00106,History data 50-Year,2019,
IDE10510-MAS00107,History data 50-Month,9,
IDE10510-MAS00108,History data 50-Day,24,
IDE10510-MAS00109,History data 50-Hours,15, H
IDE10510-MAS00110,History data 50-Minutes,49, min
IDE10510-MAS01632,History data 50-Status,activated,
IDE10510-ENG05061,History data 50-Activation_Bus_Knock_Out,activated,
IDE10510-ENG05062,History data 50-Activation_Cluster_Sleep,activated,
IDE10510-ENG05063,History data 50-Activation_Cluster_Start,activated,
IDE10510-ENG05064,History data 50-Activation_FUNC_Monitoring,activated,
IDE10510-ENG05058,History data 50-Activation_Keeping_Awake,activated,
IDE10510-ENG05059,History data 50-Activation_Logical_Wakeup,activated,
IDE10510-ENG05060,History data 50-Activation_Physical_Wakeup,activated,
IDE10510-ENG05065,History data 50-Activation_Subbus_Monitoring,activated,
IDE10510-ENG06839,History data 50-Aktivitaetsstatus_Busaktivitaet,activated,
IDE10510-ENG118680,History data 50-Cycle_Counter,84,
IDE10510-ENG06840,History data 50-Status_Activation_Car_Wake_Up,activated,
IDE10510-ENG118681,History data 50-Time_Since_Clamp_15_Off,0.00, H
IDE10510-ENG05057,History data 50-Total_Cycle_Counter,182,
IDE10511-MAS03174,History data 51-Comfort data bus,0.80, H
IDE10511-MAS03175,History data 51-Extended data bus,0.00, H
IDE10511-MAS03177,History data 51-Infotainment data bus,2.40, H
IDE10511-MAS03179,History data 51-Local data bus 2,0.00, H
IDE10511-MAS03180,History data 51-Local data bus,0.00, H
IDE10511-MAS03181,History data 51-Flexray databus,1.90, H
IDE10511-MAS05686,History data 51-Data bus diagnostics,0.50, H
IDE10511-MAS05972,History data 51-Local data bus 3,0.00, H
IDE10511-MAS07380,History data 51-Data bus Sensor/Hybrid,0.80, H
IDE10511-MAS10036,History data 51-Data bus diagnosis 2,1.90, H
IDE10511-MAS12183,History data 51-Comfort CAN bus 2,0.80, H
IDE10511-MAS14086,History data 51-Instrument cluster data bus,0.00, H
IDE10511-MAS16912,History data 51-VLAN_FAS,0.00, H
IDE10511-MAS16913,History data 51-VLAN_Infotainment,0.00, H
IDE10511-MAS16915,History data 51-VLAN_Komfort,0.00, H
IDE10511-MAS17153,History data 51-Data bus connect,0.00, H
IDE10511-MAS18934,History data 51-VLAN_Connect,0.00, H
IDE10511-MAS18935,History data 51-VLAN_Gateway,2.40, H
IDE10511-MAS18936,History data 51-VLAN_Internet,0.00, H
IDE10511-MAS20669,History data 51-VLAN_Remote_FC,0.00, H
IDE10511-ENG118679,History data 51-Total_Bus_Active,2.40, H
IDE10512-MAS03174,History data 52-Comfort data bus,972,
IDE10512-MAS03175,History data 52-Extended data bus,4,
IDE10512-MAS03177,History data 52-Infotainment data bus,182,
IDE10512-MAS03179,History data 52-Local data bus 2,0,
IDE10512-MAS03180,History data 52-Local data bus,0,
IDE10512-MAS03181,History data 52-Flexray databus,22,
IDE10512-MAS05686,History data 52-Data bus diagnostics,0,
IDE10512-MAS05972,History data 52-Local data bus 3,0,
IDE10512-MAS07380,History data 52-Data bus Sensor/Hybrid,0,
IDE10512-MAS10036,History data 52-Data bus diagnosis 2,0,
IDE10512-MAS12183,History data 52-Comfort CAN bus 2,254,
IDE10512-MAS14086,History data 52-Instrument cluster data bus,89,
IDE10512-MAS16912,History data 52-VLAN_FAS,5198,
IDE10512-MAS16913,History data 52-VLAN_Infotainment,41,
IDE10512-MAS16915,History data 52-VLAN_Komfort,1,
IDE10512-MAS17153,History data 52-Data bus connect,401,
IDE10512-MAS18934,History data 52-VLAN_Connect,6351,
IDE10512-MAS18935,History data 52-VLAN_Gateway,3304,
IDE10512-MAS18936,History data 52-VLAN_Internet,0,
IDE10512-MAS20669,History data 52-VLAN_Remote_FC,0,
IDE10513-MAS03174,History data 53-Comfort data bus,401,
IDE10513-MAS03175,History data 53-Extended data bus,41,
IDE10513-MAS03177,History data 53-Infotainment data bus,5198,
IDE10513-MAS03179,History data 53-Local data bus 2,1,
IDE10513-MAS03180,History data 53-Local data bus,0,
IDE10513-MAS03181,History data 53-Flexray databus,3304,
IDE10513-MAS05686,History data 53-Data bus diagnostics,21,
IDE10513-MAS05972,History data 53-Local data bus 3,0,
IDE10513-MAS07380,History data 53-Data bus Sensor/Hybrid,6351,
IDE10513-MAS10036,History data 53-Data bus diagnosis 2,3286,
IDE10513-MAS12183,History data 53-Comfort CAN bus 2,449,
IDE10513-MAS14086,History data 53-Instrument cluster data bus,21,
IDE10513-MAS16912,History data 53-VLAN_FAS,41,
IDE10513-MAS16913,History data 53-VLAN_Infotainment,8,
IDE10513-MAS16915,History data 53-VLAN_Komfort,0,
IDE10513-MAS17153,History data 53-Data bus connect,91,
IDE10513-MAS18934,History data 53-VLAN_Connect,4,
IDE10513-MAS18935,History data 53-VLAN_Gateway,7684,
IDE10513-MAS18936,History data 53-VLAN_Internet,0,
IDE10513-MAS20669,History data 53-VLAN_Remote_FC,0,
IDE10514-MAS03174,History data 54-Comfort data bus,652,
IDE10514-MAS03175,History data 54-Extended data bus,0,
IDE10514-MAS03177,History data 54-Infotainment data bus,0,
IDE10514-MAS03179,History data 54-Local data bus 2,0,
IDE10514-MAS03180,History data 54-Local data bus,0,
IDE10514-MAS03181,History data 54-Flexray databus,166,
IDE10514-MAS05686,History data 54-Data bus diagnostics,0,
IDE10514-MAS05972,History data 54-Local data bus 3,0,
IDE10514-MAS07380,History data 54-Data bus Sensor/Hybrid,0,
IDE10514-MAS10036,History data 54-Data bus diagnosis 2,0,
IDE10514-MAS12183,History data 54-Comfort CAN bus 2,260,
IDE10514-MAS14086,History data 54-Instrument cluster data bus,137,
IDE10514-MAS16912,History data 54-VLAN_FAS,326,
IDE10514-MAS16913,History data 54-VLAN_Infotainment,585,
IDE10514-MAS16915,History data 54-VLAN_Komfort,382,
IDE10514-MAS17153,History data 54-Data bus connect,80,
IDE10514-MAS18934,History data 54-VLAN_Connect,237,
IDE10514-MAS18935,History data 54-VLAN_Gateway,305,
IDE10514-MAS18936,History data 54-VLAN_Internet,385,
IDE10514-MAS20669,History data 54-VLAN_Remote_FC,388,
IDE10515-MAS03174,History data 55-Comfort data bus,91,
IDE10515-MAS03175,History data 55-Extended data bus,8,
IDE10515-MAS03177,History data 55-Infotainment data bus,41,
IDE10515-MAS03179,History data 55-Local data bus 2,0,
IDE10515-MAS03180,History data 55-Local data bus,0,
IDE10515-MAS03181,History data 55-Flexray databus,7684,
IDE10515-MAS05686,History data 55-Data bus diagnostics,0,
IDE10515-MAS05972,History data 55-Local data bus 3,0,
IDE10515-MAS07380,History data 55-Data bus Sensor/Hybrid,4,
IDE10515-MAS10036,History data 55-Data bus diagnosis 2,0,
IDE10515-MAS12183,History data 55-Comfort CAN bus 2,0,
IDE10515-MAS14086,History data 55-Instrument cluster data bus,17,
IDE10515-MAS16912,History data 55-VLAN_FAS,0,
IDE10515-MAS16913,History data 55-VLAN_Infotainment,0,
IDE10515-MAS16915,History data 55-VLAN_Komfort,0,
IDE10515-MAS17153,History data 55-Data bus connect,652,
IDE10515-MAS18934,History data 55-VLAN_Connect,0,
IDE10515-MAS18935,History data 55-VLAN_Gateway,166,
IDE10515-MAS18936,History data 55-VLAN_Internet,0,
IDE10515-MAS20669,History data 55-VLAN_Remote_FC,0,
IDE10516-ENG05046,History data 56-Cluster_1_Start_Error_Counter,327,
IDE10516-ENG30616,History data 56-Cluster_10_Counter,75,
IDE10516-ENG30617,History data 56-Cluster_10_Sleep_Error_Counter,0,
IDE10516-ENG30618,History data 56-Cluster_10_Start_Error_Counter,0,
IDE10516-ENG115136,History data 56-Cluster_11_Counter,897,
IDE10516-ENG114934,History data 56-Cluster_11_Sleep_Error_Counter,0,
IDE10516-ENG115145,History data 56-Cluster_11_Start_Error_Counter,0,
IDE10516-ENG114928,History data 56-Cluster_12_Counter,327,
IDE10516-ENG115123,History data 56-Cluster_12_Sleep_Error_Counter,0,
IDE10516-ENG115108,History data 56-Cluster_12_Start_Error_Counter,0,
IDE10516-ENG114947,History data 56-Cluster_13_Counter,342,
IDE10516-ENG114959,History data 56-Cluster_13_Sleep_Error_Counter,0,
IDE10516-ENG115194,History data 56-Cluster_13_Start_Error_Counter,0,
IDE10516-ENG115200,History data 56-Cluster_14_Counter,3284,
IDE10516-ENG115069,History data 56-Cluster_14_Sleep_Error_Counter,0,
IDE10516-ENG115061,History data 56-Cluster_14_Start_Error_Counter,0,
IDE10516-ENG115196,History data 56-Cluster_15_Counter,2862,
IDE10516-ENG114963,History data 56-Cluster_15_Sleep_Error_Counter,0,
IDE10516-ENG115117,History data 56-Cluster_15_Start_Error_Counter,0,
IDE10516-ENG115075,History data 56-Cluster_16_Counter,0,
IDE10516-ENG115066,History data 56-Cluster_16_Sleep_Error_Counter,0,
IDE10516-ENG115209,History data 56-Cluster_16_Start_Error_Counter,0,
IDE10516-ENG115168,History data 56-Cluster_17_Counter,0,
IDE10516-ENG115078,History data 56-Cluster_17_Sleep_Error_Counter,0,
IDE10516-ENG115049,History data 56-Cluster_17_Start_Error_Counter,0,
IDE10516-ENG115202,History data 56-Cluster_18_Counter,0,
IDE10516-ENG115182,History data 56-Cluster_18_Sleep_Error_Counter,0,
IDE10516-ENG115181,History data 56-Cluster_18_Start_Error_Counter,0,
IDE10516-ENG115148,History data 56-Cluster_19_Counter,0,
IDE10516-ENG115081,History data 56-Cluster_19_Sleep_Error_Counter,0,
IDE10516-ENG114961,History data 56-Cluster_19_Start_Error_Counter,0,
IDE10516-ENG05047,History data 56-Cluster_2_Sleep_Error_Counter,0,
IDE10516-ENG115191,History data 56-Cluster_20_Counter,0,
IDE10516-ENG114944,History data 56-Cluster_20_Sleep_Error_Counter,0,
IDE10516-ENG115156,History data 56-Cluster_20_Start_Error_Counter,0,
IDE10516-ENG115175,History data 56-Cluster_21_Counter,0,
IDE10516-ENG115208,History data 56-Cluster_21_Sleep_Error_Counter,0,
IDE10516-ENG115043,History data 56-Cluster_21_Start_Error_Counter,0,
IDE10516-ENG115023,History data 56-Cluster_22_Counter,0,
IDE10516-ENG115076,History data 56-Cluster_22_Sleep_Error_Counter,0,
IDE10516-ENG115151,History data 56-Cluster_22_Start_Error_Counter,0,
IDE10516-ENG115133,History data 56-Cluster_23_Counter,0,
IDE10516-ENG115042,History data 56-Cluster_23_Sleep_Error_Counter,0,
IDE10516-ENG115135,History data 56-Cluster_23_Start_Error_Counter,0,
IDE10516-ENG115019,History data 56-Cluster_24_Counter,0,
IDE10516-ENG115080,History data 56-Cluster_24_Sleep_Error_Counter,0,
IDE10516-ENG115055,History data 56-Cluster_24_Start_Error_Counter,0,
IDE10516-ENG05048,History data 56-Cluster_3_Counter,326,
IDE10516-ENG05050,History data 56-Cluster_3_Sleep_Error_Counter,0,
IDE10516-ENG05049,History data 56-Cluster_3_Start_Error_Counter,342,
IDE10516-ENG05051,History data 56-Cluster_4_Counter,305,
IDE10516-ENG05053,History data 56-Cluster_4_Sleep_Error_Counter,0,
IDE10516-ENG05052,History data 56-Cluster_4_Start_Error_Counter,3284,
IDE10516-ENG05054,History data 56-Cluster_5_Counter,585,
IDE10516-ENG05056,History data 56-Cluster_5_Sleep_Error_Counter,0,
IDE10516-ENG05055,History data 56-Cluster_5_Start_Error_Counter,2862,
IDE10516-ENG30619,History data 56-Cluster_6_Counter,385,
IDE10516-ENG30620,History data 56-Cluster_6_Sleep_Error_Counter,0,
IDE10516-ENG30621,History data 56-Cluster_6_Start_Error_Counter,0,
IDE10516-ENG30622,History data 56-Cluster_7_Counter,382,
IDE10516-ENG30623,History data 56-Cluster_7_Sleep_Error_Counter,0,
IDE10516-ENG30624,History data 56-Cluster_7_Start_Error_Counter,0,
IDE10516-ENG30625,History data 56-Cluster_8_Counter,388,
IDE10516-ENG30626,History data 56-Cluster_8_Sleep_Error_Counter,0,
IDE10516-ENG30627,History data 56-Cluster_8_Start_Error_Counter,0,
IDE10516-ENG30628,History data 56-Cluster_9_Counter,419,
IDE10516-ENG30629,History data 56-Cluster_9_Sleep_Error_Counter,0,
IDE10516-ENG30630,History data 56-Cluster_9_Start_Error_Counter,0,
IDE10516-ENG05045,History data 56-Cluster_Sleep_1_Error_Counter,0,
IDE10516-ENG05043,History data 56-Cluster_Start_1_Counter,80,
IDE10516-ENG05044,History data 56-Cluster_Start_1_Error_Counter,897,
IDE10516-ENG06838,History data 56-Cluster_Start_2_Counter,237,
IDE10517-MAS00106,History data 57-Year,2020, yr
IDE10517-MAS00107,History data 57-Month,10, m
IDE10517-MAS00108,History data 57-Day,24, d
IDE10517-MAS00109,History data 57-Hours,15, H
IDE10517-MAS00110,History data 57-Minutes,5, min
IDE10517-ENG20570,History data 57-Bus_1,Unknown (0),
IDE10517-ENG20572,History data 57-Bus_2,Unknown (0),
IDE10517-ENG20574,History data 57-Bus_3,Unknown (0),
IDE10517-ENG20576,History data 57-Bus_4,Unknown (0),
IDE10517-ENG20578,History data 57-Bus_5,Unknown (0),
IDE10517-ENG20571,History data 57-Bus_Active_Time_1,0.00, H
IDE10517-ENG20573,History data 57-Bus_Active_Time_2,0.00, H
IDE10517-ENG20575,History data 57-Bus_Active_Time_3,0.00, H
IDE10517-ENG20577,History data 57-Bus_Active_Time_4,0.00, H
IDE10517-ENG20579,History data 57-Bus_Active_Time_5,0.00, H
IDE10517-ENG118680,History data 57-Cycle_Counter,83,
IDE10517-ENG118681,History data 57-Time_Since_Clamp_15_Off,0.00, H
IDE10518-ENG28832,History data 58-Awake_Time_ECU_1,0.00, H
IDE10518-ENG28835,History data 58-Awake_Time_ECU_2,0.00, H
IDE10518-ENG28838,History data 58-Awake_Time_ECU_3,0.00, H
IDE10518-ENG28841,History data 58-Awake_Time_ECU_4,0.00, H
IDE10518-ENG28844,History data 58-Awake_Time_ECU_5,0.00, H
IDE10518-ENG28833,History data 58-Bus_ECU_1,0,
IDE10518-ENG28836,History data 58-Bus_ECU_2,0,
IDE10518-ENG28839,History data 58-Bus_ECU_3,0,
IDE10518-ENG28842,History data 58-Bus_ECU_4,0,
IDE10518-ENG28845,History data 58-Bus_ECU_5,0,
IDE10518-ENG28834,History data 58-Cluster_ECU_1,00 00 00,
IDE10518-ENG28837,History data 58-Cluster_ECU_2,00 00 00,
IDE10518-ENG28840,History data 58-Cluster_ECU_3,00 00 00,
IDE10518-ENG28843,History data 58-Cluster_ECU_4,00 00 00,
IDE10518-ENG28846,History data 58-Cluster_ECU_5,00 00 00,
IDE10518-ENG118680,History data 58-Cycle_Counter,83,
IDE10518-ENG106038,History data 58-ECU_1,0,
IDE10518-ENG106039,History data 58-ECU_2,0,
IDE10518-ENG28620,History data 58-ECU_3,0,
IDE10518-ENG106040,History data 58-ECU_4,0,
IDE10518-ENG106041,History data 58-ECU_5,0,
IDE10518-ENG28618,History data 58-Repeat_Counter_ECU_1,0,
IDE10518-ENG28619,History data 58-Repeat_Counter_ECU_2,0,
IDE10518-ENG28621,History data 58-Repeat_Counter_ECU_3,0,
IDE10518-ENG28622,History data 58-Repeat_Counter_ECU_4,0.00,
IDE10518-ENG28623,History data 58-Repeat_Counter_ECU_5,0,
IDE10519-ENG28833,History data 59-Bus_ECU_1,25,
IDE10519-ENG28836,History data 59-Bus_ECU_2,15,
IDE10519-ENG28839,History data 59-Bus_ECU_3,15,
IDE10519-ENG28842,History data 59-Bus_ECU_4,15,
IDE10519-ENG28845,History data 59-Bus_ECU_5,15,
IDE10519-ENG28834,History data 59-Cluster_ECU_1,00 00 11,
IDE10519-ENG28837,History data 59-Cluster_ECU_2,00 00 00,
IDE10519-ENG28840,History data 59-Cluster_ECU_3,00 00 00,
IDE10519-ENG28843,History data 59-Cluster_ECU_4,00 00 00,
IDE10519-ENG28846,History data 59-Cluster_ECU_5,00 00 00,
IDE10519-ENG118680,History data 59-Cycle_Counter,83,
IDE10519-ENG106038,History data 59-ECU_1,14,
IDE10519-ENG106039,History data 59-ECU_2,75,
IDE10519-ENG28620,History data 59-ECU_3,74,
IDE10519-ENG106040,History data 59-ECU_4,76,
IDE10519-ENG106041,History data 59-ECU_5,77,
IDE10519-ENG28847,History data 59-Logical_Wakeup_ECU_1,7,
IDE10519-ENG28848,History data 59-Logical_Wakeup_ECU_2,5,
IDE10519-ENG28849,History data 59-Logical_Wakeup_ECU_3,4,
IDE10519-ENG28850,History data 59-Logical_Wakeup_ECU_4,4,
IDE10519-ENG28851,History data 59-Logical_Wakeup_ECU_5,3,
IDE10520-ENG28833,History data 60-Bus_ECU_1,15,
IDE10520-ENG28836,History data 60-Bus_ECU_2,25,
IDE10520-ENG28839,History data 60-Bus_ECU_3,24,
IDE10520-ENG28842,History data 60-Bus_ECU_4,29,
IDE10520-ENG28845,History data 60-Bus_ECU_5,30,
IDE10520-ENG28834,History data 60-Cluster_ECU_1,00 01 0B,
IDE10520-ENG28837,History data 60-Cluster_ECU_2,00 00 00,
IDE10520-ENG28840,History data 60-Cluster_ECU_3,00 00 00,
IDE10520-ENG28843,History data 60-Cluster_ECU_4,00 00 00,
IDE10520-ENG28846,History data 60-Cluster_ECU_5,00 00 00,
IDE10520-ENG118680,History data 60-Cycle_Counter,83,
IDE10520-ENG106038,History data 60-ECU_1,139,
IDE10520-ENG106039,History data 60-ECU_2,14,
IDE10520-ENG28620,History data 60-ECU_3,255,
IDE10520-ENG106040,History data 60-ECU_4,255,
IDE10520-ENG106041,History data 60-ECU_5,255,
IDE10520-ENG28852,History data 60-Physical_Wakeup_ECU_1,4,
IDE10520-ENG28853,History data 60-Physical_Wakeup_ECU_2,3,
IDE10520-ENG28854,History data 60-Physical_Wakeup_ECU_3,2,
IDE10520-ENG28855,History data 60-Physical_Wakeup_ECU_4,2,
IDE10520-ENG28856,History data 60-Physical_Wakeup_ECU_5,2,
IDE10521-ENG28833,History data 61-Bus_ECU_1,0,
IDE10521-ENG28836,History data 61-Bus_ECU_2,0,
IDE10521-ENG28839,History data 61-Bus_ECU_3,0,
IDE10521-ENG28842,History data 61-Bus_ECU_4,0,
IDE10521-ENG28845,History data 61-Bus_ECU_5,0,
IDE10521-ENG28857,History data 61-Bus_Knock_Out_ECU_1,0,
IDE10521-ENG30432,History data 61-Bus_Knock_Out_ECU_2,0,
IDE10521-ENG28858,History data 61-Bus_Knock_Out_ECU_3,0,
IDE10521-ENG28859,History data 61-Bus_Knock_Out_ECU_4,0,
IDE10521-ENG28860,History data 61-Bus_Knock_Out_ECU_5,0,
IDE10521-ENG118680,History data 61-Cycle_Counter,83,
IDE10521-ENG106038,History data 61-ECU_1,0,
IDE10521-ENG106039,History data 61-ECU_2,0,
IDE10521-ENG28620,History data 61-ECU_3,0,
IDE10521-ENG106040,History data 61-ECU_4,0,
IDE10521-ENG106041,History data 61-ECU_5,0,
IDE10522-ENG28833,History data 62-Bus_ECU_1,15,
IDE10522-ENG28836,History data 62-Bus_ECU_2,15,
IDE10522-ENG28839,History data 62-Bus_ECU_3,25,
IDE10522-ENG28842,History data 62-Bus_ECU_4,26,
IDE10522-ENG28845,History data 62-Bus_ECU_5,15,
IDE10522-ENG28861,History data 62-Car_Wake_Up_Counter_ECU_1,3,
IDE10522-ENG28863,History data 62-Car_Wake_Up_Counter_ECU_2,3,
IDE10522-ENG28865,History data 62-Car_Wake_Up_Counter_ECU_3,2,
IDE10522-ENG28867,History data 62-Car_Wake_Up_Counter_ECU_4,2,
IDE10522-ENG28869,History data 62-Car_Wake_Up_Counter_ECU_5,2,
IDE10522-ENG28862,History data 62-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10522-ENG28864,History data 62-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10522-ENG28866,History data 62-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10522-ENG28868,History data 62-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10522-ENG28870,History data 62-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10522-ENG118680,History data 62-Cycle_Counter,83,
IDE10522-ENG106038,History data 62-ECU_1,74,
IDE10522-ENG106039,History data 62-ECU_2,75,
IDE10522-ENG28620,History data 62-ECU_3,14,
IDE10522-ENG106040,History data 62-ECU_4,20,
IDE10522-ENG106041,History data 62-ECU_5,76,
IDE10523-ENG28833,History data 63-Bus_ECU_1,25,
IDE10523-ENG28836,History data 63-Bus_ECU_2,15,
IDE10523-ENG28839,History data 63-Bus_ECU_3,15,
IDE10523-ENG28842,History data 63-Bus_ECU_4,23,
IDE10523-ENG28845,History data 63-Bus_ECU_5,27,
IDE10523-ENG28871,History data 63-Cluster_Sleep_ECU_1,11,
IDE10523-ENG28872,History data 63-Cluster_Sleep_ECU_2,8,
IDE10523-ENG28873,History data 63-Cluster_Sleep_ECU_3,5,
IDE10523-ENG28874,History data 63-Cluster_Sleep_ECU_4,1,
IDE10523-ENG28875,History data 63-Cluster_Sleep_ECU_5,1,
IDE10523-ENG118680,History data 63-Cycle_Counter,83,
IDE10523-ENG106038,History data 63-ECU_1,14,
IDE10523-ENG106039,History data 63-ECU_2,139,
IDE10523-ENG28620,History data 63-ECU_3,74,
IDE10523-ENG106040,History data 63-ECU_4,118,
IDE10523-ENG106041,History data 63-ECU_5,240,
IDE10524-ENG28833,History data 64-Bus_ECU_1,15,
IDE10524-ENG28836,History data 64-Bus_ECU_2,15,
IDE10524-ENG28839,History data 64-Bus_ECU_3,3916,
IDE10524-ENG28842,History data 64-Bus_ECU_4,132,
IDE10524-ENG28845,History data 64-Bus_ECU_5,82,
IDE10524-ENG28876,History data 64-Cluster_1_Start,0,
IDE10524-ENG28877,History data 64-Cluster_2_Start,0,
IDE10524-ENG28878,History data 64-Cluster_3_Start,0,
IDE10524-ENG28879,History data 64-Cluster_4_Start,0,
IDE10524-ENG28880,History data 64-Cluster_5_Start,0,
IDE10524-ENG28881,History data 64-Cluster_Start_ECU_1,16,
IDE10524-ENG28882,History data 64-Cluster_Start_ECU_2,13,
IDE10524-ENG28883,History data 64-Cluster_Start_ECU_3,11,
IDE10524-ENG28884,History data 64-Cluster_Start_ECU_4,2319,
IDE10524-ENG28885,History data 64-Cluster_Start_ECU_5,2319,
IDE10524-ENG118680,History data 64-Cycle_Counter,83,
IDE10524-ENG106038,History data 64-ECU_1,75,
IDE10524-ENG106039,History data 64-ECU_2,35,
IDE10524-ENG28620,History data 64-ECU_3,77,
IDE10524-ENG106040,History data 64-ECU_4,0,
IDE10524-ENG106041,History data 64-ECU_5,0,
IDE10525-ENG28887,History data 65-Awake_Time_FUNC_1,0.00, H
IDE10525-ENG28890,History data 65-Awake_Time_FUNC_2,0.00, H
IDE10525-ENG28893,History data 65-Awake_Time_FUNC_3,0.00, H
IDE10525-ENG28896,History data 65-Awake_Time_FUNC_4,0.00, H
IDE10525-ENG28899,History data 65-Awake_Time_FUNC_5,0.00, H
IDE10525-ENG118680,History data 65-Cycle_Counter,83,
IDE10525-ENG28886,History data 65-FUNC_1,17,
IDE10525-ENG28889,History data 65-FUNC_2,2,
IDE10525-ENG28892,History data 65-FUNC_3,14,
IDE10525-ENG28895,History data 65-FUNC_4,25,
IDE10525-ENG28898,History data 65-FUNC_5,12,
IDE10525-ENG28888,History data 65-Physical_Wakeup_FUNC_1,8,
IDE10525-ENG28891,History data 65-Physical_Wakeup_FUNC_2,6,
IDE10525-ENG28894,History data 65-Physical_Wakeup_FUNC_3,2,
IDE10525-ENG28897,History data 65-Physical_Wakeup_FUNC_4,2,
IDE10525-ENG28900,History data 65-Physical_Wakeup_FUNC_5,1,
IDE10526-MAS00106,History data 66-Year,2020,
IDE10526-MAS00107,History data 66-Month,9,
IDE10526-MAS00108,History data 66-Day,5,
IDE10526-MAS00109,History data 66-Hours,17, H
IDE10526-MAS00110,History data 66-Minutes,23, min
IDE10526-ENG28832,History data 66-Awake_Time_ECU_1,0.40, H
IDE10526-ENG28835,History data 66-Awake_Time_ECU_2,0.00, H
IDE10526-ENG28838,History data 66-Awake_Time_ECU_3,0.00, H
IDE10526-ENG28841,History data 66-Awake_Time_ECU_4,0.00, H
IDE10526-ENG28844,History data 66-Awake_Time_ECU_5,0.00, H
IDE10526-ENG28833,History data 66-Bus_ECU_1,15,
IDE10526-ENG28836,History data 66-Bus_ECU_2,0,
IDE10526-ENG28839,History data 66-Bus_ECU_3,0,
IDE10526-ENG28842,History data 66-Bus_ECU_4,0,
IDE10526-ENG28845,History data 66-Bus_ECU_5,0,
IDE10526-ENG28834,History data 66-Cluster_ECU_1,00 00 28,
IDE10526-ENG28837,History data 66-Cluster_ECU_2,00 00 00,
IDE10526-ENG28840,History data 66-Cluster_ECU_3,00 00 00,
IDE10526-ENG28843,History data 66-Cluster_ECU_4,00 00 00,
IDE10526-ENG28846,History data 66-Cluster_ECU_5,00 00 00,
IDE10526-ENG118680,History data 66-Cycle_Counter,70,
IDE10526-ENG106038,History data 66-ECU_1,76,
IDE10526-ENG106039,History data 66-ECU_2,0,
IDE10526-ENG28620,History data 66-ECU_3,0,
IDE10526-ENG106040,History data 66-ECU_4,0,
IDE10526-ENG106041,History data 66-ECU_5,0,
IDE10526-ENG28618,History data 66-Repeat_Counter_ECU_1,0,
IDE10526-ENG28619,History data 66-Repeat_Counter_ECU_2,0,
IDE10526-ENG28621,History data 66-Repeat_Counter_ECU_3,0,
IDE10526-ENG28622,History data 66-Repeat_Counter_ECU_4,0,
IDE10526-ENG28623,History data 66-Repeat_Counter_ECU_5,0,
IDE10526-ENG118681,History data 66-Time_Since_Clamp_15_Off,0.40, H
IDE10527-MAS00106,History data 67-Year,2020,
IDE10527-MAS00107,History data 67-Month,7,
IDE10527-MAS00108,History data 67-Day,22,
IDE10527-MAS00109,History data 67-Hours,17, H
IDE10527-MAS00110,History data 67-Minutes,0, min
IDE10527-ENG28833,History data 67-Bus_ECU_1,25,
IDE10527-ENG28836,History data 67-Bus_ECU_2,15,
IDE10527-ENG28839,History data 67-Bus_ECU_3,0,
IDE10527-ENG28842,History data 67-Bus_ECU_4,0,
IDE10527-ENG28845,History data 67-Bus_ECU_5,0,
IDE10527-ENG28834,History data 67-Cluster_ECU_1,00 00 11,
IDE10527-ENG28837,History data 67-Cluster_ECU_2,00 00 00,
IDE10527-ENG28840,History data 67-Cluster_ECU_3,00 00 00,
IDE10527-ENG28843,History data 67-Cluster_ECU_4,00 00 00,
IDE10527-ENG28846,History data 67-Cluster_ECU_5,00 00 00,
IDE10527-ENG118680,History data 67-Cycle_Counter,53,
IDE10527-ENG106038,History data 67-ECU_1,14,
IDE10527-ENG106039,History data 67-ECU_2,35,
IDE10527-ENG28620,History data 67-ECU_3,0,
IDE10527-ENG106040,History data 67-ECU_4,0,
IDE10527-ENG106041,History data 67-ECU_5,0,
IDE10527-ENG28847,History data 67-Logical_Wakeup_ECU_1,72,
IDE10527-ENG28848,History data 67-Logical_Wakeup_ECU_2,68,
IDE10527-ENG28849,History data 67-Logical_Wakeup_ECU_3,0,
IDE10527-ENG28850,History data 67-Logical_Wakeup_ECU_4,0,
IDE10527-ENG28851,History data 67-Logical_Wakeup_ECU_5,0,
IDE10527-ENG118681,History data 67-Time_Since_Clamp_15_Off,0.50, H
IDE10528-MAS00106,History data 68-Year,2020,
IDE10528-MAS00107,History data 68-Month,7,
IDE10528-MAS00108,History data 68-Day,5,
IDE10528-MAS00109,History data 68-Hours,15, H
IDE10528-MAS00110,History data 68-Minutes,25, min
IDE10528-ENG28833,History data 68-Bus_ECU_1,29,
IDE10528-ENG28836,History data 68-Bus_ECU_2,30,
IDE10528-ENG28839,History data 68-Bus_ECU_3,22,
IDE10528-ENG28842,History data 68-Bus_ECU_4,22,
IDE10528-ENG28845,History data 68-Bus_ECU_5,0,
IDE10528-ENG28834,History data 68-Cluster_ECU_1,00 00 00,
IDE10528-ENG28837,History data 68-Cluster_ECU_2,00 00 00,
IDE10528-ENG28840,History data 68-Cluster_ECU_3,00 00 00,
IDE10528-ENG28843,History data 68-Cluster_ECU_4,00 00 00,
IDE10528-ENG28846,History data 68-Cluster_ECU_5,00 00 00,
IDE10528-ENG118680,History data 68-Cycle_Counter,34,
IDE10528-ENG106038,History data 68-ECU_1,255,
IDE10528-ENG106039,History data 68-ECU_2,255,
IDE10528-ENG28620,History data 68-ECU_3,255,
IDE10528-ENG106040,History data 68-ECU_4,255,
IDE10528-ENG106041,History data 68-ECU_5,0,
IDE10528-ENG28852,History data 68-Physical_Wakeup_ECU_1,255,
IDE10528-ENG28853,History data 68-Physical_Wakeup_ECU_2,255,
IDE10528-ENG28854,History data 68-Physical_Wakeup_ECU_3,254,
IDE10528-ENG28855,History data 68-Physical_Wakeup_ECU_4,253,
IDE10528-ENG28856,History data 68-Physical_Wakeup_ECU_5,0,
IDE10528-ENG118681,History data 68-Time_Since_Clamp_15_Off,0.00, H
IDE10529-MAS00106,History data 69-Year,2019,
IDE10529-MAS00107,History data 69-Month,9,
IDE10529-MAS00108,History data 69-Day,24,
IDE10529-MAS00109,History data 69-Hours,16, H
IDE10529-MAS00110,History data 69-Minutes,1, min
IDE10529-ENG28833,History data 69-Bus_ECU_1,26,
IDE10529-ENG28836,History data 69-Bus_ECU_2,0,
IDE10529-ENG28839,History data 69-Bus_ECU_3,0,
IDE10529-ENG28842,History data 69-Bus_ECU_4,0,
IDE10529-ENG28845,History data 69-Bus_ECU_5,0,
IDE10529-ENG28857,History data 69-Bus_Knock_Out_ECU_1,6,
IDE10529-ENG30432,History data 69-Bus_Knock_Out_ECU_2,0,
IDE10529-ENG28858,History data 69-Bus_Knock_Out_ECU_3,0,
IDE10529-ENG28859,History data 69-Bus_Knock_Out_ECU_4,0,
IDE10529-ENG28860,History data 69-Bus_Knock_Out_ECU_5,0,
IDE10529-ENG118680,History data 69-Cycle_Counter,0,
IDE10529-ENG106038,History data 69-ECU_1,27,
IDE10529-ENG106039,History data 69-ECU_2,0,
IDE10529-ENG28620,History data 69-ECU_3,0,
IDE10529-ENG106040,History data 69-ECU_4,0,
IDE10529-ENG106041,History data 69-ECU_5,0,
IDE10529-ENG118681,History data 69-Time_Since_Clamp_15_Off,0.10, H
IDE10530-MAS00106,History data 70-Year,2000,
IDE10530-MAS00107,History data 70-Month,1,
IDE10530-MAS00108,History data 70-Day,1,
IDE10530-MAS00109,History data 70-Hours,0, H
IDE10530-MAS00110,History data 70-Minutes,0, min
IDE10530-ENG28833,History data 70-Bus_ECU_1,0,
IDE10530-ENG28836,History data 70-Bus_ECU_2,0,
IDE10530-ENG28839,History data 70-Bus_ECU_3,0,
IDE10530-ENG28842,History data 70-Bus_ECU_4,0,
IDE10530-ENG28845,History data 70-Bus_ECU_5,0,
IDE10530-ENG28861,History data 70-Car_Wake_Up_Counter_ECU_1,0,
IDE10530-ENG28863,History data 70-Car_Wake_Up_Counter_ECU_2,0,
IDE10530-ENG28865,History data 70-Car_Wake_Up_Counter_ECU_3,0,
IDE10530-ENG28867,History data 70-Car_Wake_Up_Counter_ECU_4,0,
IDE10530-ENG28869,History data 70-Car_Wake_Up_Counter_ECU_5,0,
IDE10530-ENG28862,History data 70-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10530-ENG28864,History data 70-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10530-ENG28866,History data 70-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10530-ENG28868,History data 70-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10530-ENG28870,History data 70-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10530-ENG118680,History data 70-Cycle_Counter,0,
IDE10530-ENG106038,History data 70-ECU_1,0,
IDE10530-ENG106039,History data 70-ECU_2,0,
IDE10530-ENG28620,History data 70-ECU_3,0,
IDE10530-ENG106040,History data 70-ECU_4,0,
IDE10530-ENG106041,History data 70-ECU_5,0,
IDE10530-ENG118681,History data 70-Time_Since_Clamp_15_Off,0.00, H
IDE10531-MAS00106,History data 71-Year,2020,
IDE10531-MAS00107,History data 71-Month,7,
IDE10531-MAS00108,History data 71-Day,22,
IDE10531-MAS00109,History data 71-Hours,17, H
IDE10531-MAS00110,History data 71-Minutes,0, min
IDE10531-ENG28833,History data 71-Bus_ECU_1,25,
IDE10531-ENG28836,History data 71-Bus_ECU_2,0,
IDE10531-ENG28839,History data 71-Bus_ECU_3,0,
IDE10531-ENG28842,History data 71-Bus_ECU_4,0,
IDE10531-ENG28845,History data 71-Bus_ECU_5,0,
IDE10531-ENG28871,History data 71-Cluster_Sleep_ECU_1,86,
IDE10531-ENG28872,History data 71-Cluster_Sleep_ECU_2,0,
IDE10531-ENG28873,History data 71-Cluster_Sleep_ECU_3,0,
IDE10531-ENG28874,History data 71-Cluster_Sleep_ECU_4,0,
IDE10531-ENG28875,History data 71-Cluster_Sleep_ECU_5,0,
IDE10531-ENG118680,History data 71-Cycle_Counter,53,
IDE10531-ENG106038,History data 71-ECU_1,14,
IDE10531-ENG106039,History data 71-ECU_2,0,
IDE10531-ENG28620,History data 71-ECU_3,0,
IDE10531-ENG106040,History data 71-ECU_4,0,
IDE10531-ENG106041,History data 71-ECU_5,0,
IDE10531-ENG118681,History data 71-Time_Since_Clamp_15_Off,0.50, H
IDE10532-MAS00106,History data 72-Year,2020,
IDE10532-MAS00107,History data 72-Month,7,
IDE10532-MAS00108,History data 72-Day,22,
IDE10532-MAS00109,History data 72-Hours,17, H
IDE10532-MAS00110,History data 72-Minutes,0, min
IDE10532-ENG28833,History data 72-Bus_ECU_1,15,
IDE10532-ENG28836,History data 72-Bus_ECU_2,15,
IDE10532-ENG28839,History data 72-Bus_ECU_3,15,
IDE10532-ENG28842,History data 72-Bus_ECU_4,15,
IDE10532-ENG28845,History data 72-Bus_ECU_5,15,
IDE10532-ENG28876,History data 72-Cluster_1_Start,0,
IDE10532-ENG28877,History data 72-Cluster_2_Start,0,
IDE10532-ENG28878,History data 72-Cluster_3_Start,0,
IDE10532-ENG28879,History data 72-Cluster_4_Start,0,
IDE10532-ENG28880,History data 72-Cluster_5_Start,0,
IDE10532-ENG28834,History data 72-Cluster_ECU_1,0,
IDE10532-ENG28837,History data 72-Cluster_ECU_2,0,
IDE10532-ENG28840,History data 72-Cluster_ECU_3,0,
IDE10532-ENG28843,History data 72-Cluster_ECU_4,0,
IDE10532-ENG28846,History data 72-Cluster_ECU_5,0,
IDE10532-ENG28881,History data 72-Cluster_Start_ECU_1,211,
IDE10532-ENG28882,History data 72-Cluster_Start_ECU_2,211,
IDE10532-ENG28883,History data 72-Cluster_Start_ECU_3,210,
IDE10532-ENG28884,History data 72-Cluster_Start_ECU_4,207,
IDE10532-ENG28885,History data 72-Cluster_Start_ECU_5,27,
IDE10532-ENG118680,History data 72-Cycle_Counter,53,
IDE10532-ENG106038,History data 72-ECU_1,35,
IDE10532-ENG106039,History data 72-ECU_2,160,
IDE10532-ENG28620,History data 72-ECU_3,132,
IDE10532-ENG106040,History data 72-ECU_4,75,
IDE10532-ENG106041,History data 72-ECU_5,77,
IDE10532-ENG118681,History data 72-Time_Since_Clamp_15_Off,0.50, H
IDE10533-MAS00106,History data 73-Year,2020,
IDE10533-MAS00107,History data 73-Month,7,
IDE10533-MAS00108,History data 73-Day,22,
IDE10533-MAS00109,History data 73-Hours,17, H
IDE10533-MAS00110,History data 73-Minutes,0, min
IDE10533-ENG28907,History data 73-Activetime_MIB,0.00, H
IDE10533-ENG28904,History data 73-Activetime_MOST,0.00, H
IDE10533-ENG28901,History data 73-Activetime_MU,0.00, H
IDE10533-ENG118680,History data 73-Cycle_Counter,52,
IDE10533-ENG28903,History data 73-State_MMI,3,
IDE10533-ENG28906,History data 73-State_MOST,1,
IDE10533-ENG118681,History data 73-Time_Since_Clamp_15_Off,0.50, H
IDE10533-ENG28905,History data 73-WakeUps_MOST,1,
IDE10533-ENG28902,History data 73-WakeUps_MU,1,
IDE10534-MAS00106,History data 74-Year,2020,
IDE10534-MAS00107,History data 74-Month,7,
IDE10534-MAS00108,History data 74-Day,22,
IDE10534-MAS00109,History data 74-Hours,17, H
IDE10534-MAS00110,History data 74-Minutes,0, min
IDE10534-ENG28887,History data 74-Awake_Time_FUNC_1,0.50, H
IDE10534-ENG28890,History data 74-Awake_Time_FUNC_2,0.50, H
IDE10534-ENG28893,History data 74-Awake_Time_FUNC_3,0.00, H
IDE10534-ENG28896,History data 74-Awake_Time_FUNC_4,0.00, H
IDE10534-ENG28899,History data 74-Awake_Time_FUNC_5,0.00, H
IDE10534-ENG118680,History data 74-Cycle_Counter,53,
IDE10534-ENG28886,History data 74-FUNC_1,2,
IDE10534-ENG28889,History data 74-FUNC_2,17,
IDE10534-ENG28892,History data 74-FUNC_3,0,
IDE10534-ENG28895,History data 74-FUNC_4,0,
IDE10534-ENG28898,History data 74-FUNC_5,0,
IDE10534-ENG28888,History data 74-Physical_Wakeup_FUNC_1,40,
IDE10534-ENG28891,History data 74-Physical_Wakeup_FUNC_2,9,
IDE10534-ENG28894,History data 74-Physical_Wakeup_FUNC_3,0,
IDE10534-ENG28897,History data 74-Physical_Wakeup_FUNC_4,0,
IDE10534-ENG28900,History data 74-Physical_Wakeup_FUNC_5,0,
IDE10534-ENG118681,History data 74-Time_Since_Clamp_15_Off,0.50, H
IDE10535-MAS03174,History data 75-Comfort data bus,0,
IDE10535-MAS03175,History data 75-Extended data bus,0,
IDE10535-MAS03177,History data 75-Infotainment data bus,0,
IDE10535-MAS03179,History data 75-Local data bus 2,0,
IDE10535-MAS03180,History data 75-Local data bus,0,
IDE10535-MAS03181,History data 75-Flexray databus,24,
IDE10535-MAS05686,History data 75-Data bus diagnostics,0,
IDE10535-MAS05972,History data 75-Local data bus 3,0,
IDE10535-MAS07380,History data 75-Data bus Sensor/Hybrid,0,
IDE10535-MAS10036,History data 75-Data bus diagnosis 2,0,
IDE10535-MAS12183,History data 75-Comfort CAN bus 2,0,
IDE10535-MAS14086,History data 75-Instrument cluster data bus,0,
IDE10535-MAS16912,History data 75-VLAN_FAS,513,
IDE10535-MAS16913,History data 75-VLAN_Infotainment,258,
IDE10535-MAS16915,History data 75-VLAN_Komfort,768,
IDE10535-MAS17153,History data 75-Data bus connect,771,
IDE10535-MAS18934,History data 75-VLAN_Connect,257,
IDE10535-MAS18935,History data 75-VLAN_Gateway,257,
IDE10535-MAS18936,History data 75-VLAN_Internet,771,
IDE10535-MAS20669,History data 75-VLAN_Remote_FC,769,
IDE10623-IDE04447,Status drive profile for roll stabilization-Function status,engaged,
IDE10623-IDE06260,Status drive profile for roll stabilization-ID number,0,
IDE10623-MAS01156,Status drive profile for roll stabilization-Communication status,OK,
IDE10623-MAS01447,Status drive profile for roll stabilization-Act.val.,0,
IDE10624-IDE04447,Status: driving profile selection for sport differential-Function status,engaged,
IDE10624-IDE06260,Status: driving profile selection for sport differential-ID number,0,
IDE10624-MAS01156,Status: driving profile selection for sport differential-Communication status,OK,
IDE10624-MAS01447,Status: driving profile selection for sport differential-Act.val.,0,
IDE10625-IDE04447,Stat.driv.profile select.for warn.in case of. risk of collision-Function status,not engaged,
IDE10625-IDE06260,Stat.driv.profile select.for warn.in case of. risk of collision-ID number,0,
IDE10625-MAS01156,Stat.driv.profile select.for warn.in case of. risk of collision-Communication status,OK,
IDE10625-MAS01447,Stat.driv.profile select.for warn.in case of. risk of collision-Act.val.,0,
IDE10626-IDE04447,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Function status,not engaged,
IDE10626-IDE06260,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-ID number,0,
IDE10626-MAS01156,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Communication status,OK,
IDE10626-MAS01447,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Act.val.,0,
IDE10627-IDE04447,Status driving profile selection for hybrid battery management-Function status,engaged,
IDE10627-IDE06260,Status driving profile selection for hybrid battery management-ID number,0,
IDE10627-MAS01156,Status driving profile selection for hybrid battery management-Communication status,OK,
IDE10627-MAS01447,Status driving profile selection for hybrid battery management-Act.val.,0,
IDE10628-IDE04447,Status: driving profile selection for emerg. brake assistance-Function status,not engaged,
IDE10628-IDE06260,Status: driving profile selection for emerg. brake assistance-ID number,0,
IDE10628-MAS01156,Status: driving profile selection for emerg. brake assistance-Communication status,OK,
IDE10628-MAS01447,Status: driving profile selection for emerg. brake assistance-Act.val.,0,
IDE10629-IDE04447,Status: driving profile select. for rear axle differential lock-Function status,not engaged,
IDE10629-IDE06260,Status: driving profile select. for rear axle differential lock-ID number,0,
IDE10629-MAS01156,Status: driving profile select. for rear axle differential lock-Communication status,OK,
IDE10629-MAS01447,Status: driving profile select. for rear axle differential lock-Act.val.,0,
IDE10644-MAS06193,Driving profile selection: statistics distance driven-Profile 1,0, km
IDE10644-MAS06194,Driving profile selection: statistics distance driven-Profile 2,83, km
IDE10644-MAS06195,Driving profile selection: statistics distance driven-Profile 3,35, km
IDE10644-MAS06196,Driving profile selection: statistics distance driven-Profile 4,0, km
IDE10644-MAS06197,Driving profile selection: statistics distance driven-Profile 5,0, km
IDE10644-MAS06198,Driving profile selection: statistics distance driven-Profile 6,0, km
IDE10644-MAS06199,Driving profile selection: statistics distance driven-Profile 7,0, km
IDE10644-MAS06200,Driving profile selection: statistics distance driven-Profile 8,0, km
IDE10644-MAS08875,Driving profile selection: statistics distance driven-Profile 9,0, km
IDE10644-MAS08876,Driving profile selection: statistics distance driven-Profile 10,0, km
IDE10644-MAS08877,Driving profile selection: statistics distance driven-Profile 11,0, km
IDE10644-MAS08878,Driving profile selection: statistics distance driven-Profile 12,0, km
IDE10644-MAS08879,Driving profile selection: statistics distance driven-Profile 13,0, km
IDE10644-MAS08880,Driving profile selection: statistics distance driven-Profile 14,0, km
IDE10644-MAS08881,Driving profile selection: statistics distance driven-Profile 15,0, km
IDE10655-MAS00106,Pause recommendation: hist. data-Year,2020, yr
IDE10655-MAS00107,Pause recommendation: hist. data-Month,10, m
IDE10655-MAS00108,Pause recommendation: hist. data-Day,19, d
IDE10655-MAS00109,Pause recommendation: hist. data-Hours,15, H
IDE10655-MAS00110,Pause recommendation: hist. data-Minutes,36, min
IDE10655-MAS00111,Pause recommendation: hist. data-Seconds,46, s
IDE10655-MAS03401,Pause recommendation: hist. data-Parameter 1,0.40,
IDE10655-MAS03402,Pause recommendation: hist. data-Parameter 2,1.00,
IDE10655-MAS03403,Pause recommendation: hist. data-Parameter 3,1.42,
IDE10655-MAS03404,Pause recommendation: hist. data-Parameter 4,4.27,
IDE10655-MAS03405,Pause recommendation: hist. data-Parameter 5,0, %
IDE10655-MAS10985,Pause recommendation: hist. data-Overall drive duration,22, min
IDE10655-MAS10986,Pause recommendation: hist. data-Drive duration in active speed range,7, min
IDE10655-MAS10987,Pause recommendation: hist. data-Drive duration with warning readiness,0, min
IDE10655-MAS10988,Pause recommendation: hist. data-No. of warnings issued,00,
IDE10655-MAS14091,Pause recommendation: hist. data-Travel duration until first warning,0, min
IDE10656-MAS10989,Pause recommended: use-No. of drives with activated pause recommendation,00 00,
IDE10656-MAS10990,Pause recommended: use-No. of drives with deactivated pause recommendation,00 1E,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,OK,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,0,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,63,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10927-MAS11760,Total static current-current total quiescent current,0, mA
IDE10927-MAS11761,Total static current-Total time quiescent current exceeded,0.0, H
IDE10973,Generator voltage,10.6, V
IDE10974,12-Volt Vehicle electrical system: malfunction status,No malfunction,
IDE11191-MAS12370,Open circuit detection: H-V lines-Wiring circuit 1,Mode not active,
IDE11191-MAS12371,Open circuit detection: H-V lines-Wiring circuit 2,Malfunction,
IDE11191-MAS17061,Open circuit detection: H-V lines-Wiring circuit 3,Mode not active,
IDE11191-MAS17062,Open circuit detection: H-V lines-Wiring circuit 4,Mode not active,
IDE11191-MAS17063,Open circuit detection: H-V lines-Wiring circuit 5,Mode not active,
IDE11284-MAS00106,Sending status of online functions: history data-Year,2255, yr
IDE11284-MAS00107,Sending status of online functions: history data-Month,15, m
IDE11284-MAS00108,Sending status of online functions: history data-Day,31, d
IDE11284-MAS00109,Sending status of online functions: history data-Hours,31, H
IDE11284-MAS00110,Sending status of online functions: history data-Minutes,63, min
IDE11284-MAS00111,Sending status of online functions: history data-Seconds,63, s
IDE11284-MAS07134,Sending status of online functions: history data-ID services,ID_OTV,
IDE11284-MAS12545,Sending status of online functions: history data-Send attempt: status,not OK,
IDE11485-MAS02832,HV voltage converter: status for electric drive-Malfunction status,No malfunction detected,
IDE11485-MAS03001,HV voltage converter: status for electric drive-Mode,Standby-mode,
IDE11486-MAS02246,HV battery charge management: HV activation restriction-Timeout,not active,
IDE11486-MAS09518,HV battery charge management: HV activation restriction-Safety line,not active,
IDE11486-MAS09519,HV battery charge management: HV activation restriction-Message error,not active,
IDE11486-MAS09541,HV battery charge management: HV activation restriction-Act. mode init. error,not active,
IDE11486-MAS09542,HV battery charge management: HV activation restriction-Error status init. error,not active,
IDE11486-MAS09543,HV battery charge management: HV activation restriction-Operating mode error,not active,
IDE11486-MAS09544,HV battery charge management: HV activation restriction-No component function,not active,
IDE11486-MAS09545,HV battery charge management: HV activation restriction-Sequence error,not active,
IDE11486-MAS12351,HV battery charge management: HV activation restriction-HV voltage measurement error,not active,
IDE11486-MAS13068,HV battery charge management: HV activation restriction-HV voltage measurement initialization error,not active,
IDE11586-IDE04447,Status drive profile selection for integral steering-Function status,not engaged,
IDE11586-IDE06260,Status drive profile selection for integral steering-ID number,0,
IDE11586-MAS01156,Status drive profile selection for integral steering-Communication status,OK,
IDE11586-MAS01447,Status drive profile selection for integral steering-Act.val.,0,
IDE11661-IDE06930,Autonomous operation states-Voltage converter: status: Status,Malfunction,
IDE11661-IDE08958,Autonomous operation states-H-V system: start request,not active,
IDE11661-MAS07605,Autonomous operation states-charging request,Malfunction,
IDE11661-MAS08040,Autonomous operation states-Automatic recharging of starter battery,not active,
IDE11661-MAS13088,Autonomous operation states-Preconditioning of the interior,Malfunction,
IDE11661-MAS13089,Autonomous operation states-High-voltage vehicle electrical system: status,not active,
IDE11662-MAS13090,H-V power distribution-Energy allocation thermal management,12700, Wh
IDE11662-MAS13091,H-V power distribution-Energy allocation12-volt electrical system,102300, Wh
IDE11662-MAS13092,H-V power distribution-Energy content of the high-voltage battery,Malfunction,
IDE11663,H-V energy management mode,Standby-mode,
IDE11664,Requirement to recharge the H-V battery charging management,not active,
IDE11671-MAS02246,H-V power transformers: prohibition on turning-on H-V-Timeout,not active,
IDE11671-MAS09518,H-V power transformers: prohibition on turning-on H-V-Safety line,not active,
IDE11671-MAS09519,H-V power transformers: prohibition on turning-on H-V-Message error,not active,
IDE11671-MAS09541,H-V power transformers: prohibition on turning-on H-V-Act. mode init. error,not active,
IDE11671-MAS09542,H-V power transformers: prohibition on turning-on H-V-Error status init. error,not active,
IDE11671-MAS09543,H-V power transformers: prohibition on turning-on H-V-Operating mode error,not active,
IDE11671-MAS09544,H-V power transformers: prohibition on turning-on H-V-No component function,not active,
IDE11671-MAS09545,H-V power transformers: prohibition on turning-on H-V-Sequence error,not active,
IDE11671-MAS12351,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement error,not active,
IDE11671-MAS13068,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement initialization error,not active,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11675-MAS02246,Roll stabilization: prohibition on turning-on 48V-Timeout,not active,
IDE11675-MAS09519,Roll stabilization: prohibition on turning-on 48V-Message error,not active,
IDE11675-MAS09541,Roll stabilization: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11675-MAS09542,Roll stabilization: prohibition on turning-on 48V-Error status init. error,not active,
IDE11675-MAS09543,Roll stabilization: prohibition on turning-on 48V-Operating mode error,not active,
IDE11675-MAS09544,Roll stabilization: prohibition on turning-on 48V-No component function,not active,
IDE11675-MAS09545,Roll stabilization: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11676-MAS18704,Airbag: prohibition on turning-on 48V-History of minor accident,not active,
IDE11676-MAS18705,Airbag: prohibition on turning-on 48V-History of serious accident,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11682-IDE04447,Status of driving profile selection for exhaust flaps-Function status,engaged,
IDE11682-IDE06260,Status of driving profile selection for exhaust flaps-ID number,0,
IDE11682-MAS01156,Status of driving profile selection for exhaust flaps-Communication status,OK,
IDE11682-MAS01447,Status of driving profile selection for exhaust flaps-Act.val.,2,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No malfunction detected,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,Initialization,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Initialization,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,Initialization,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,Initialization,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,20,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,No malfunction detected,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,48V-network activated,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,No malfunction detected,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Step-down mode,
IDE11686-MAS02832,Anti-roll stabilization: status for 48V power-Malfunction status,Initialization,
IDE11686-MAS03001,Anti-roll stabilization: status for 48V power-Mode,Initialization,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 14 00 00 00 00 00 00 00 00 00 00 00 03 00 00,
IDE11755-MAS14856,IP network: VLANs-VLAN,4,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,48 C5 8D 2D E1 11,
IDE11869-IDE09467,IP network: NDP cache-MAC address,48 C5 8D 27 CC 22,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FE 80 00 00 00 00 00 00 4A C5 8D FF FE 27 CC 22,
IDE11869-MAS14856,IP network: NDP cache-VLAN,4,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT09769,48V activation restriction-Auxiliary Air Heater Control Module/PTC,not active,
IDE11911-SFT09997,48V activation restriction-Electrical compressor,not active,
IDE12084-MAS14046,Component protection participant status-Node address of the immobilizer master,00 8B,
IDE12084-MAS14047,Component protection participant status-Generation of the immobilizer master,Generation 2,
IDE12084-MAS14048,Component protection participant status-Authentication status of the immobilizer master,valid authentication,
IDE12084-MAS14053,Component protection participant status-Status of start authentication,switched on,
IDE12084-MAS14054,Component protection participant status-Start authentication can be deactivated,No,
IDE12084-MAS14055,Component protection participant status-Immobilizer master sends authentication request,Yes,
IDE12084-MAS14056,Component protection participant status-Status of the IKA key for immobilizer master,IKA key stored,
IDE12084-MAS14059,Component protection participant status-Node address of the component protection participant,00 27,
IDE12084-MAS14060,Component protection participant status-Prioritized participant,Yes,
IDE12084-MAS14061,Component protection participant status-Authentication status of the component protection participant,incompletely authenticated,
IDE12084-MAS14062,Component protection participant status-Participant extended start authentication,No,
IDE12084-MAS14063,Component protection participant status-Component protection participant sends authentication request,No,
IDE12084-MAS14064,Component protection participant status-Status of the IKA key for component protection participants,no IKA key stored,
IDE12238,I network: discarded messages counter,0,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12581-ENG28833,History data 76-Bus_ECU_1,26,
IDE12581-ENG28836,History data 76-Bus_ECU_2,23,
IDE12581-ENG28839,History data 76-Bus_ECU_3,0,
IDE12581-ENG28842,History data 76-Bus_ECU_4,0,
IDE12581-ENG28845,History data 76-Bus_ECU_5,0,
IDE12581-ENG118680,History data 76-Cycle_Counter,83,
IDE12581-ENG106038,History data 76-ECU_1,20,
IDE12581-ENG106039,History data 76-ECU_2,119,
IDE12581-ENG28620,History data 76-ECU_3,0,
IDE12581-ENG106040,History data 76-ECU_4,0,
IDE12581-ENG106041,History data 76-ECU_5,0,
IDE12581-ENG30992,History data 76-ECU_Knock_Out_ECU_1,15, min
IDE12581-ENG30993,History data 76-ECU_Knock_Out_ECU_2,20, min
IDE12581-ENG30994,History data 76-ECU_Knock_Out_ECU_3,0, min
IDE12581-ENG30995,History data 76-ECU_Knock_Out_ECU_4,0, min
IDE12581-ENG30996,History data 76-ECU_Knock_Out_ECU_5,0, min
IDE12581-ENG31201,History data 76-Fkt_Ausloesung_ECU_1,0,
IDE12581-ENG31202,History data 76-Fkt_Ausloesung_ECU_2,0,
IDE12581-ENG31203,History data 76-Fkt_Ausloesung_ECU_3,0,
IDE12581-ENG31204,History data 76-Fkt_Ausloesung_ECU_4,0,
IDE12581-ENG31205,History data 76-Fkt_Ausloesung_ECU_5,0,
IDE12581-ENG32787,History data 76-Sub_System_Aktiv_ECU_1,0,
IDE12581-ENG32788,History data 76-Sub_System_Aktiv_ECU_2,0,
IDE12581-ENG32789,History data 76-Sub_System_Aktiv_ECU_3,0,
IDE12581-ENG32790,History data 76-Sub_System_Aktiv_ECU_4,0,
IDE12581-ENG32791,History data 76-Sub_System_Aktiv_ECU_5,0,
IDE12581-ENG33300,History data 76-Veto_Aktiv_ECU_1,0,
IDE12581-ENG33301,History data 76-Veto_Aktiv_ECU_2,0,
IDE12581-ENG33302,History data 76-Veto_Aktiv_ECU_3,0,
IDE12581-ENG33303,History data 76-Veto_Aktiv_ECU_4,0,
IDE12581-ENG33304,History data 76-Veto_Aktiv_ECU_5,0,
IDE12583-MAS00106,History data 77-Year,2000, yr
IDE12583-MAS00107,History data 77-Month,1, m
IDE12583-MAS00108,History data 77-Day,1, d
IDE12583-MAS00109,History data 77-Hours,0, H
IDE12583-MAS00110,History data 77-Minutes,0, min
IDE12583-ENG28833,History data 77-Bus_ECU_1,0,
IDE12583-ENG28836,History data 77-Bus_ECU_2,0,
IDE12583-ENG28839,History data 77-Bus_ECU_3,0,
IDE12583-ENG28842,History data 77-Bus_ECU_4,0,
IDE12583-ENG28845,History data 77-Bus_ECU_5,0,
IDE12583-ENG118680,History data 77-Cycle_Counter,0,
IDE12583-ENG106038,History data 77-ECU_1,0,
IDE12583-ENG106039,History data 77-ECU_2,0,
IDE12583-ENG28620,History data 77-ECU_3,0,
IDE12583-ENG106040,History data 77-ECU_4,0,
IDE12583-ENG106041,History data 77-ECU_5,0,
IDE12583-ENG30992,History data 77-ECU_Knock_Out_ECU_1,0, min
IDE12583-ENG30993,History data 77-ECU_Knock_Out_ECU_2,0, min
IDE12583-ENG30994,History data 77-ECU_Knock_Out_ECU_3,0, min
IDE12583-ENG30995,History data 77-ECU_Knock_Out_ECU_4,0, min
IDE12583-ENG30996,History data 77-ECU_Knock_Out_ECU_5,0, min
IDE12583-ENG31201,History data 77-Fkt_Ausloesung_ECU_1,0,
IDE12583-ENG31202,History data 77-Fkt_Ausloesung_ECU_2,0,
IDE12583-ENG31203,History data 77-Fkt_Ausloesung_ECU_3,0,
IDE12583-ENG31204,History data 77-Fkt_Ausloesung_ECU_4,0,
IDE12583-ENG31205,History data 77-Fkt_Ausloesung_ECU_5,0,
IDE12583-ENG32787,History data 77-Sub_System_Aktiv_ECU_1,0,
IDE12583-ENG32788,History data 77-Sub_System_Aktiv_ECU_2,0,
IDE12583-ENG32789,History data 77-Sub_System_Aktiv_ECU_3,0,
IDE12583-ENG32790,History data 77-Sub_System_Aktiv_ECU_4,0,
IDE12583-ENG32791,History data 77-Sub_System_Aktiv_ECU_5,0,
IDE12583-ENG118681,History data 77-Time_Since_Clamp_15_Off,0.00, H
IDE12583-ENG33300,History data 77-Veto_Aktiv_ECU_1,0,
IDE12583-ENG33301,History data 77-Veto_Aktiv_ECU_2,0,
IDE12583-ENG33302,History data 77-Veto_Aktiv_ECU_3,0,
IDE12583-ENG33303,History data 77-Veto_Aktiv_ECU_4,0,
IDE12583-ENG33304,History data 77-Veto_Aktiv_ECU_5,0,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,Initialization,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,Initialization,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,Initialization,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initialization,
IDE13018-MAS02246,Electrical drive 2: high-voltage switch on prevention-Timeout,not active,
IDE13018-MAS09518,Electrical drive 2: high-voltage switch on prevention-Safety line,not active,
IDE13018-MAS09519,Electrical drive 2: high-voltage switch on prevention-Message error,not active,
IDE13018-MAS09542,Electrical drive 2: high-voltage switch on prevention-Error status init. error,not active,
IDE13018-MAS09544,Electrical drive 2: high-voltage switch on prevention-No component function,not active,
IDE13018-MAS09546,Electrical drive 2: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13018-MAS12345,Electrical drive 2: high-voltage switch on prevention-Active discharge fault,not active,
IDE13019-MAS02246,Electrical drive 3: high-voltage switch on prevention-Timeout,not active,
IDE13019-MAS09518,Electrical drive 3: high-voltage switch on prevention-Safety line,not active,
IDE13019-MAS09519,Electrical drive 3: high-voltage switch on prevention-Message error,not active,
IDE13019-MAS09542,Electrical drive 3: high-voltage switch on prevention-Error status init. error,not active,
IDE13019-MAS09544,Electrical drive 3: high-voltage switch on prevention-No component function,not active,
IDE13019-MAS09546,Electrical drive 3: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13019-MAS12345,Electrical drive 3: high-voltage switch on prevention-Active discharge fault,not active,
IDE13033-MAS15531,Communication status of emergency call module: analysis-Components 1,Not available,
IDE13033-MAS15532,Communication status of emergency call module: analysis-Components 2,Not available,
IDE13033-MAS15533,Communication status of emergency call module: analysis-Components 3,Not available,
IDE13033-MAS15534,Communication status of emergency call module: analysis-Components 4,available.,
IDE13033-MAS15535,Communication status of emergency call module: analysis-Components 5,available.,
IDE13057-MAS15615,Lithium ions starter battery-Battery: fault status,No malfunction,
IDE13057-MAS15620,Lithium ions starter battery-Battery cut-out element: fault status,No malfunction,
IDE13140,History data 78,********0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0***********************************************************************,
IDE13140,History data 78,0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*******************************************************************************,
IDE13140,History data 78,0000000*2000-01-01-00:00:00*000*00*0*0*0*0*00*00*00000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0***********************************************************************,
IDE13140,History data 78,********0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*********************,
IDE13141,History data 79,0000000*2000-01-01-00:00:00**,
IDE13142,History data 80,********0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0***********************************************************************,
IDE13142,History data 80,********0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*********************,
IDE13142,History data 80,0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*******************************************************************************,
IDE13142,History data 80,0000000*2000-01-01-00:00:00*000*00*0*0*0*0*|\ 000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0***********************************************************************,
IDE13398-MAS11501,Driving profile history data 5-Charging,0, min
IDE13398-MAS13105,Driving profile history data 5-Electrical travel,0, min
IDE13398-MAS13106,Driving profile history data 5-Hybrid driving,0, min
IDE13398-MAS20668,Driving profile history data 5-Battery hold mode,0, min
IDE13402-MAS06193,Driving profile history data 6-Profile 1,0, km
IDE13402-MAS06194,Driving profile history data 6-Profile 2,0, km
IDE13402-MAS06195,Driving profile history data 6-Profile 3,0, km
IDE13402-MAS06196,Driving profile history data 6-Profile 4,0, km
IDE13573-IDE11095,Advanced StartStop display version-Rqmt. spec. version,18,
IDE13573-MAS01483,Advanced StartStop display version-Software version,01,
IDE13754-MAS03095,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,78, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,production,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755,Diagnosis filter: history data,0000000*2000-01-01-00:00:00*0*,
IDE13755,Diagnosis filter: history data,0000000*2017-10-23-00:00:01*6*,
IDE13755,Diagnosis filter: history data,FFFFFFF*2000-01-01-00:00:00*6*,
IDE13848-MAS06568,Onboard network components: medium-voltage-Auxiliary Heater,not installed,
IDE13848-MAS10933,Onboard network components: medium-voltage-Roll stabilization,not installed,
IDE13848-MAS11243,Onboard network components: medium-voltage-Battery Management 48V,installed,
IDE13848-MAS16949,Onboard network components: medium-voltage-Active setup verification,not installed,
IDE13848-MAS16953,Onboard network components: medium-voltage-Belt driven starter generator 48V,installed,
IDE13848-MAS17010,Onboard network components: medium-voltage-48V Vehicle Electrical System Storage Capacitor,not installed,
IDE13848-SFT00196,Onboard network components: medium-voltage-Voltage converter,installed,
IDE13848-SFT09997,Onboard network components: medium-voltage-Electrical compressor,not installed,
IDE13849-IDE12114,Onboard network diagnosis 48V 1-48V vehicle electrical system diagnosis,not requested,
IDE13849-MAS01867,Onboard network diagnosis 48V 1-Measurement,OK,
IDE13849-MAS15721,Onboard network diagnosis 48V 1-Battery management 48V power supply battery,9, A
IDE13850-MAS01867,Onboard network diagnosis 48V 2-Measurement,OK,
IDE13850-MAS06864,Onboard network diagnosis 48V 2-Generator actual voltage,48.00, V
IDE13850-MAS15119,Onboard network diagnosis 48V 2-48-Volt vehicle electrical system,active,
IDE13850-MAS15722,Onboard network diagnosis 48V 2-Battery management 48V: actual voltage,47.75, V
IDE13850-MAS16957,Onboard network diagnosis 48V 2-Electrically driven compressor: current voltage,Initialization,
IDE13850-MAS16958,Onboard network diagnosis 48V 2-Voltage converter: current voltage,48.00, V
IDE13850-MAS16959,Onboard network diagnosis 48V 2-Roll stabilization front axis current voltage,Initialization,
IDE13850-MAS16960,Onboard network diagnosis 48V 2-Roll stabilization rear axis current voltage,Initialization,
IDE13850-MAS16961,Onboard network diagnosis 48V 2-Active setup verification front axle current voltage,Initialization,
IDE13850-MAS16962,Onboard network diagnosis 48V 2-Active setup verification rear axle current voltage,Initialization,
IDE13862-MAS02246,High-voltage battery charger 2: do not turn on high voltage-Timeout,not active,
IDE13862-MAS09518,High-voltage battery charger 2: do not turn on high voltage-Safety line,not active,
IDE13862-MAS09519,High-voltage battery charger 2: do not turn on high voltage-Message error,not active,
IDE13862-MAS09542,High-voltage battery charger 2: do not turn on high voltage-Error status init. error,not active,
IDE13862-MAS09544,High-voltage battery charger 2: do not turn on high voltage-No component function,not active,
IDE13862-MAS09546,High-voltage battery charger 2: do not turn on high voltage-Voltage disconnect. init. error,not active,
IDE13862-MAS12351,High-voltage battery charger 2: do not turn on high voltage-HV voltage measurement error,not active,
IDE13862-MAS13068,High-voltage battery charger 2: do not turn on high voltage-HV voltage measurement initialization error,not active,
IDE13873,Ethernet status electrical error,No malfunction,
IDE13948-MAS17220,Stack memory-Stack memory extract,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14133-MAS01364,48V electrical system: reduced network operation-Stage 1,not active,
IDE14133-MAS01365,48V electrical system: reduced network operation-Stage 2,not active,
IDE14133-MAS02246,48V electrical system: reduced network operation-Timeout,not active,
IDE14133-MAS02832,48V electrical system: reduced network operation-Malfunction status,0,
IDE14133-MAS03123,48V electrical system: reduced network operation-Reduced performance,not active,
IDE14133-MAS17920,48V electrical system: reduced network operation-timeout 2,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650,
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not activated,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.00, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,25.00, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,22.00, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,20.00, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,19.00, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,20.00, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,21.00, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,23.00, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,26.00, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,30.00, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.00, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,25.00, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,22.00, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,20.00, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,19.00, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,20.00, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,21.00, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,23.00, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,26.00, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,30.00, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650,
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,Initialization,
IDE14151-MAS17928,Route-based range calculation-Maximum range,Initialization,
IDE14151-MAS17929,Route-based range calculation-Total coverage,Not available,
IDE14151-MAS17930,Route-based range calculation-Range from destination,Not available,
IDE14151-MAS17931,Route-based range calculation-Route-based range,0,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14162-MAS17987,High-voltage electrical system: target installation-High-voltage battery,not requested,
IDE14162-ENG30825,High-voltage electrical system: target installation-desired_value_02,not requested,
IDE14162-ENG30826,High-voltage electrical system: target installation-desired_value_03,not requested,
IDE14162-ENG30827,High-voltage electrical system: target installation-desired_value_04,not requested,
IDE14162-ENG30828,High-voltage electrical system: target installation-desired_value_05,not requested,
IDE14162-ENG30829,High-voltage electrical system: target installation-desired_value_06,not requested,
IDE14162-ENG30830,High-voltage electrical system: target installation-desired_value_07,not requested,
IDE14162-ENG30831,High-voltage electrical system: target installation-desired_value_08,not requested,
IDE14162-ENG30832,High-voltage electrical system: target installation-desired_value_09,not requested,
IDE14162-ENG30833,High-voltage electrical system: target installation-desired_value_10,not requested,
IDE14162-ENG30834,High-voltage electrical system: target installation-desired_value_11,not requested,
IDE14162-ENG30835,High-voltage electrical system: target installation-desired_value_12,not requested,
IDE14162-ENG30836,High-voltage electrical system: target installation-desired_value_13,not requested,
IDE14162-ENG30837,High-voltage electrical system: target installation-desired_value_14,not requested,
IDE14162-ENG30838,High-voltage electrical system: target installation-desired_value_15,not requested,
IDE14162-ENG30839,High-voltage electrical system: target installation-desired_value_16,not requested,
IDE14162-ENG30840,High-voltage electrical system: target installation-desired_value_17,not requested,
IDE14162-ENG30841,High-voltage electrical system: target installation-desired_value_18,not requested,
IDE14162-ENG30842,High-voltage electrical system: target installation-desired_value_19,not requested,
IDE14162-ENG30843,High-voltage electrical system: target installation-desired_value_20,not requested,
IDE14162-ENG30844,High-voltage electrical system: target installation-desired_value_21,not requested,
IDE14162-ENG30845,High-voltage electrical system: target installation-desired_value_22,not requested,
IDE14162-ENG30846,High-voltage electrical system: target installation-desired_value_23,not requested,
IDE14162-ENG30847,High-voltage electrical system: target installation-desired_value_24,not requested,
IDE14163-MAS17986,MV electrical system: target installation-Medium-voltage battery,not requested,
IDE14163-ENG30825,MV electrical system: target installation-desired_value_02,not requested,
IDE14163-ENG30826,MV electrical system: target installation-desired_value_03,not requested,
IDE14163-ENG30827,MV electrical system: target installation-desired_value_04,not requested,
IDE14163-ENG30828,MV electrical system: target installation-desired_value_05,not requested,
IDE14163-ENG30829,MV electrical system: target installation-desired_value_06,not requested,
IDE14163-ENG30830,MV electrical system: target installation-desired_value_07,not requested,
IDE14163-ENG30831,MV electrical system: target installation-desired_value_08,not requested,
IDE14163-ENG30832,MV electrical system: target installation-desired_value_09,not requested,
IDE14163-ENG30833,MV electrical system: target installation-desired_value_10,not requested,
IDE14163-ENG30834,MV electrical system: target installation-desired_value_11,not requested,
IDE14163-ENG30835,MV electrical system: target installation-desired_value_12,not requested,
IDE14163-ENG30836,MV electrical system: target installation-desired_value_13,not requested,
IDE14163-ENG30837,MV electrical system: target installation-desired_value_14,not requested,
IDE14163-ENG30838,MV electrical system: target installation-desired_value_15,not requested,
IDE14163-ENG30839,MV electrical system: target installation-desired_value_16,not requested,
IDE14163-ENG30840,MV electrical system: target installation-desired_value_17,not requested,
IDE14163-ENG30841,MV electrical system: target installation-desired_value_18,not requested,
IDE14163-ENG30842,MV electrical system: target installation-desired_value_19,not requested,
IDE14163-ENG30843,MV electrical system: target installation-desired_value_20,not requested,
IDE14163-ENG30844,MV electrical system: target installation-desired_value_21,not requested,
IDE14163-ENG30845,MV electrical system: target installation-desired_value_22,not requested,
IDE14163-ENG30846,MV electrical system: target installation-desired_value_23,not requested,
IDE14163-ENG30847,MV electrical system: target installation-desired_value_24,not requested,
IDE14164-MAS00478,Low-voltage electrical system: target installation-Reserved,not requested,
IDE14164-MAS17988,Low-voltage electrical system: target installation-LV battery,not requested,
IDE14164-ENG30828,Low-voltage electrical system: target installation-desired_value_05,not requested,
IDE14165-MAS00478,Actual installation of high-voltage electrical system-Reserved,not detected,
IDE14165-MAS17987,Actual installation of high-voltage electrical system-High-voltage battery,not detected,
IDE14166-MAS17986,Actual installation of MV electrical system-Medium-voltage battery,detected,
IDE14166-ENG30271,Actual installation of MV electrical system-actual_value_02,detected,
IDE14166-ENG30272,Actual installation of MV electrical system-actual_value_03,detected,
IDE14166-ENG30273,Actual installation of MV electrical system-actual_value_04,not detected,
IDE14166-ENG30274,Actual installation of MV electrical system-actual_value_05,not detected,
IDE14166-ENG30275,Actual installation of MV electrical system-actual_value_06,not detected,
IDE14166-ENG30276,Actual installation of MV electrical system-actual_value_07,not detected,
IDE14166-ENG30277,Actual installation of MV electrical system-actual_value_08,detected,
IDE14166-ENG30278,Actual installation of MV electrical system-actual_value_09,not detected,
IDE14166-ENG30279,Actual installation of MV electrical system-actual_value_10,not detected,
IDE14166-ENG30280,Actual installation of MV electrical system-actual_value_11,not detected,
IDE14166-ENG30281,Actual installation of MV electrical system-actual_value_12,not detected,
IDE14166-ENG30282,Actual installation of MV electrical system-actual_value_13,not detected,
IDE14166-ENG30283,Actual installation of MV electrical system-actual_value_14,not detected,
IDE14166-ENG30284,Actual installation of MV electrical system-actual_value_15,not detected,
IDE14166-ENG30285,Actual installation of MV electrical system-actual_value_16,not detected,
IDE14166-ENG30286,Actual installation of MV electrical system-actual_value_17,not detected,
IDE14166-ENG30287,Actual installation of MV electrical system-actual_value_18,not detected,
IDE14166-ENG30288,Actual installation of MV electrical system-actual_value_19,not detected,
IDE14166-ENG30289,Actual installation of MV electrical system-actual_value_20,not detected,
IDE14166-ENG30290,Actual installation of MV electrical system-actual_value_21,not detected,
IDE14166-ENG30291,Actual installation of MV electrical system-actual_value_22,not detected,
IDE14166-ENG30292,Actual installation of MV electrical system-actual_value_23,not detected,
IDE14166-ENG30293,Actual installation of MV electrical system-actual_value_24,not detected,
IDE14167-MAS00478,Actual installation of low-voltage electrical system-Reserved,not detected,
IDE14167-MAS00478,Actual installation of low-voltage electrical system-Reserved,detected,
IDE14167-MAS17988,Actual installation of low-voltage electrical system-LV battery,not detected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,24,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,9,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,57,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,3,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,122, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Unknown (0),
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Unknown (0),
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,3,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS01758-IDE00500,Date / time-Hour,19, H
MAS01758-IDE00501,Date / time-Minute,9, min
MAS01758-IDE00502,Date / time-Year,2020, yr
MAS01758-IDE00503,Date / time-Month,10, m
MAS01758-IDE00504,Date / time-Day,24, d
MAS01758-MAS00111,Date / time-Seconds,56, s
MAS01758-MAS02238,Date / time-Up-to-date,Winter time,
MAS01758-MAS03617,Date / time-Time zone,0.00, H
MAS20349-MAS04394,DoIP connection status-Connection status,active,
MAS20349-MAS13793,DoIP connection status-Control module identification,67,
ENG06732-ENG06827,12V_zustart_prohibition-12V_start_system_error,00 04,
ENG06732-ENG06826,12V_zustart_prohibition-12V_zustart_prohibition_on_drive,00 58,
ENG06732-ENG06825,12V_zustart_prohibition-12V_zustart_prohibition_on_stop,00 00,
ENG08764-MAS01867,48V_overvoltage_check-Measurement,OK,
ENG08764-ENG09344,48V_overvoltage_check-Bms_48V_actual_voltage,48.00, V
ENG08764-ENG09345,48V_overvoltage_check-Bms_48V_Soc,50.00, %
ENG08769-MAS11874,48V_Zero_potential_status-Overall status,48V_zero_potential_not_detected,
ENG04784,Break_Recommendation_Index,1.00,
ENG04785-ENG126257,Break_Recommendation_TTNR-TTNR_DS,0,
ENG04785-ENG126256,Break_Recommendation_TTNR-TTNR_SW,60053,
ENG06743,Challenge_KS,8B C7 95 92,
ENG06744-MAS06854,Checksumme_KS-Version,81,
ENG06744-MAS06855,Checksumme_KS-Test sum,2F FD 13 56,
ENG08767-ENG09366,coldstart_requirement_engine-requirement_12V_start,not active,
ENG08767-ENG09367,coldstart_requirement_engine-requirement_48V_start,active,
ENG118784-ENG05030,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Active_Body_Control,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG05036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Autonomous_Emergency_Breaking,not active,
ENG118784-ENG05035,Driv._Prof._Sel._Coord._Retry_State-Retry_State_battery_management,not active,
ENG118784-ENG118738,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Beam_Control,not active,
ENG118784-ENG05018,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG05023,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Centre_and_rear_axle_differential,not active,
ENG118784-ENG118735,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Climatronic,not active,
ENG118784-ENG05029,Driv._Prof._Sel._Coord._Retry_State-Retry_State_corner_assist,not active,
ENG118784-ENG05032,Driv._Prof._Sel._Coord._Retry_State-Retry_State_cruise_control,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG05024,Driv._Prof._Sel._Coord._Retry_State-Retry_State_e_quattro,not active,
ENG118784-ENG05031,Driv._Prof._Sel._Coord._Retry_State-Retry_State_E_Sound,not active,
ENG118784-ENG05038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Differential_Lock,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG05037,Driv._Prof._Sel._Coord._Retry_State-Retry_State_engine_operating_state,not active,
ENG118784-ENG05021,Driv._Prof._Sel._Coord._Retry_State-Retry_State_exhaust_gas_flaps,not active,
ENG118784-ENG05039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Objects,not active,
ENG118784-ENG05040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Pedestrian,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG05041,Driv._Prof._Sel._Coord._Retry_State-Retry_State_integral_steering,not active,
ENG118784-ENG05034,Driv._Prof._Sel._Coord._Retry_State-Retry_State_lift_control_unit,not active,
ENG118784-ENG05025,Driv._Prof._Sel._Coord._Retry_State-Retry_State_matrixbeam,not active,
ENG118784-ENG05022,Driv._Prof._Sel._Coord._Retry_State-Retry_State_middle_differential,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG05015,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Rear_Axle_Differential,not active,
ENG118784-ENG05027,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_axle_steering,not active,
ENG118784-ENG05017,Driv._Prof._Sel._Coord._Retry_State-Retry_State_ride-height_control_system,not active,
ENG118784-ENG118740,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Routing_Adaption,not active,
ENG118784-ENG05020,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sailing_suggestion,not active,
ENG118784-ENG05033,Driv._Prof._Sel._Coord._Retry_State-Retry_State_servo_tronic,not active,
ENG118784-ENG05019,Driv._Prof._Sel._Coord._Retry_State-Retry_State_sidepanel_seat,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG05026,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Spoiler_Control_Unit,not active,
ENG118784-ENG05028,Driv._Prof._Sel._Coord._Retry_State-Retry_State_stabilisation_control_unit,not active,
ENG118784-ENG118731,Driv._Prof._Sel._Coord._Retry_State-Retry_State_StartStop,not active,
ENG118784-ENG05016,Driv._Prof._Sel._Coord._Retry_State-Retry_State_steering_control_unit,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118786-ENG05042,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile_BMA,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG06742-MAS02832,eABC_48V_status-Malfunction status,Initialization,
ENG06742-MAS03001,eABC_48V_status-Mode,Initialization,
ENG118766,eASS_operation_status,Emergency running mode,
ENG04786-ENG05075,Ehr_segment_load-attribute_pool,3.50,
ENG04786-ENG05074,Ehr_segment_load-segment_pool,0.00,
ENG04786-ENG05076,Ehr_segment_load-speedlimit_pool,0.00,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,243.6, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,257.7, Ah
ENG04782,EM_bdm_error_state,0,
ENG106123,EM_blAlternator On,OFF,
ENG26761,EM_Current_Control,not active,
ENG118437,EM_IAlternatorReserve,0.0, A
ENG118434,EM_LoadResponse Time,6, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,90, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,90, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,Release,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,Release,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,Release,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,Release,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,No enabling,
ENG118780-ENG04973,EM_Recuperation_Precondition-battery_disconnected,Release,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,Release,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,Release,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,Release,
ENG118780-ENG30744,EM_Recuperation_Precondition-dc_source_activity,Release,
ENG118780-ENG30745,EM_Recuperation_Precondition-dc_source_diagnosis,Release,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,Release,
ENG118780-ENG31832,EM_Recuperation_Precondition-hv_cutoff_level,Release,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,Release,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,Release,
ENG118780-ENG32123,EM_Recuperation_Precondition-mv_cutoff_level,Release,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,Release,
ENG118780-ENG104256,EM_Recuperation_Precondition-production_mode,Release,
ENG118780-ENG04974,EM_Recuperation_Precondition-trailer_dedection,Release,
ENG118780-ENG111086,EM_Recuperation_Precondition-Transport_Mode,Release,
ENG106169,EM_valHlkLevelRequirement,950, W
ENG106169,EM_valHlkLevelRequirement,Stage 1,
ENG06717,EM_vehicle_bus_state,11 07 3C FF,
ENG04777,EM_vehicle_state,02 10,
ENG04779-ENG04996,EM_voltage_control_state-EM_das_control_state,0,
ENG04779-ENG04995,EM_voltage_control_state-EM_gas_control_state,0,
ENG04779-ENG04997,EM_voltage_control_state-EM_ras_control_state,0,
ENG04779-ENG04998,EM_voltage_control_state-EM_Ureg_control_state,1,
ENG04776,EMZ_state,6,
ENG04775,engine_identifier,4,
ENG04780,freewheel_info,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,250100,
ENG118782-ENG05091,Gateway app. software identification-software_version_cGW,------,
ENG118782-ENG05083,Gateway app. software identification-software_version_cha,320200,
ENG118782-ENG05090,Gateway app. software identification-software_version_eHorizont,200100,
ENG118782-ENG05085,Gateway app. software identification-software_version_HvEm,------,
ENG118782-ENG05086,Gateway app. software identification-software_version_HvK,------,
ENG118782-ENG05092,Gateway app. software identification-software_version_MvEM,------,
ENG118782-ENG05093,Gateway app. software identification-software_version_MVK,------,
ENG118782-ENG05084,Gateway app. software identification-software_version_NvEm,190302,
ENG118782-ENG05087,Gateway app. software identification-software_version_ObDc,------,
ENG118782-ENG05088,Gateway app. software identification-software_version_PE,066310,
ENG118782-ENG05089,Gateway app. software identification-software_version_range,200302,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,120201,
ENG04773-ENG120608,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x01,00 00 00,
ENG04773-ENG120609,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x02,00 00 00,
ENG04773-ENG04886,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x03,00 00 00,
ENG04773-ENG31556,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x04,00 00 00,
ENG04773-ENG31557,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x05,00 00 00,
ENG04773-ENG31558,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x06,00 00 00,
ENG04773-ENG31559,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x07,00 00 00,
ENG04773-ENG31560,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x08,00 00 00,
ENG04773-ENG04887,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0A,00 00 00,
ENG04773-ENG04888,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0B,00 00 00,
ENG04773-ENG04889,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0C,00 00 00,
ENG04773-ENG04890,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0E,00 00 00,
ENG04773-ENG04891,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0F,00 00 00,
ENG04773-ENG04892,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x12,00 00 00,
ENG04773-ENG04893,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x13,00 00 00,
ENG04773-ENG04894,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x14,00 00 00,
ENG04773-ENG04895,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x15,00 00 00,
ENG04773-ENG04896,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x16,00 00 00,
ENG04773-ENG04897,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1A,00 00 00,
ENG04773-ENG04898,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1B,00 00 00,
ENG04773-ENG04899,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1C,00 00 00,
ENG04773-ENG04900,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1E,00 00 00,
ENG04773-ENG04901,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x23,10 00 00,
ENG04773-ENG04902,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x24,00 00 00,
ENG04773-ENG04903,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x27,04 00 00,
ENG04773-ENG04904,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2A,00 00 00,
ENG04773-ENG04905,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2B,00 00 00,
ENG04773-ENG04906,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2C,00 00 00,
ENG04773-ENG04907,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2D,00 00 00,
ENG04773-ENG04908,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2E,00 00 00,
ENG04773-ENG04909,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x30,00 00 00,
ENG04773-ENG04910,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x31,00 00 00,
ENG04773-ENG04912,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x3B,00 00 00,
ENG04773-ENG04913,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x41,00 00 00,
ENG04773-ENG04914,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x42,00 00 00,
ENG04773-ENG31561,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x43,00 00 00,
ENG04773-ENG04915,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x44,00 01 00,
ENG04773-ENG04916,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x46,00 00 00,
ENG04773-ENG04917,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x47,02 00 00,
ENG04773-ENG116879,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x49,00 00 00,
ENG04773-ENG04918,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4A,00 00 00,
ENG04773-ENG04919,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4B,01 00 00,
ENG04773-ENG04920,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4C,08 00 00,
ENG04773-ENG04921,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4D,08 00 00,
ENG04773-ENG04922,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4E,00 00 00,
ENG04773-ENG04923,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4F,00 00 00,
ENG04773-ENG04924,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x53,00 00 00,
ENG04773-ENG04925,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x56,00 00 00,
ENG04773-ENG04926,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x57,00 00 00,
ENG04773-ENG31562,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x59,00 00 00,
ENG04773-ENG04928,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x60,00 00 00,
ENG04773-ENG31563,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x61,00 00 00,
ENG04773-ENG04929,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x63,00 00 00,
ENG04773-ENG04930,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x64,00 00 00,
ENG04773-ENG120610,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x67,00 00 00,
ENG04773-ENG04931,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x69,00 00 00,
ENG04773-ENG04932,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x6A,00 00 00,
ENG04773-ENG04933,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x73,00 00 00,
ENG04773-ENG04934,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x76,00 00 00,
ENG04773-ENG04935,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x77,00 00 00,
ENG04773-ENG04936,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x78,00 00 00,
ENG04773-ENG04937,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7B,00 00 00,
ENG04773-ENG04938,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7C,00 00 00,
ENG04773-ENG04939,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x80,00 00 00,
ENG04773-ENG04940,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x84,10 00 00,
ENG04773-ENG04941,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x87,08 00 00,
ENG04773-ENG04942,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x88,08 00 00,
ENG04773-ENG31564,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x89,00 00 00,
ENG04773-ENG04943,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8A,00 00 00,
ENG04773-ENG04944,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8B,00 00 00,
ENG04773-ENG120611,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8C,00 00 00,
ENG04773-ENG04945,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8E,00 00 00,
ENG04773-ENG04946,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8F,00 00 00,
ENG04773-ENG04947,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x93,00 00 00,
ENG04773-ENG04948,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x94,00 00 00,
ENG04773-ENG04949,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x95,08 00 00,
ENG04773-ENG04951,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9C,00 00 00,
ENG04773-ENG04952,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9D,00 00 00,
ENG04773-ENG04953,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9E,00 00 00,
ENG04773-ENG04954,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xA0,10 00 00,
ENG04773-ENG31565,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAE,5A 02 20,
ENG04773-ENG00603,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB5,00 00 00,
ENG04773-ENG120612,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB7,00 00 00,
ENG04773-ENG31566,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB8,00 00 00,
ENG04773-ENG120613,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xBA,00 00 00,
ENG04773-ENG120614,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC3,00 00 00,
ENG04773-ENG120615,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC4,00 00 00,
ENG04773-ENG120616,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC5,00 00 00,
ENG04773-ENG120617,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC6,00 00 00,
ENG04773-ENG120618,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC7,00 00 00,
ENG04773-ENG120619,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC8,00 00 00,
ENG04773-ENG120620,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF0,00 00 00,
ENG04773-ENG120621,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF1,00 00 00,
ENG04773-ENG120622,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF2,00 00 00,
ENG04773-ENG116981,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF3,00 00 00,
ENG04773-ENG00604,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF5,00 00 00,
ENG04773-ENG00605,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF6,00 00 00,
ENG04773-ENG00606,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF7,00 00 00,
ENG04772-ENG120623,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x01,0,
ENG04772-ENG120624,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x02,0,
ENG04772-ENG04819,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03,0,
ENG04772-ENG04833,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E,0,
ENG04772-ENG04878,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93,0,
ENG04772-ENG04879,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94,0,
ENG04772-ENG04880,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95,0,
ENG04772-ENG04882,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C,2,
ENG04772-ENG31568,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04,0,
ENG04772-ENG31569,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05,2,
ENG04772-ENG31570,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06,2,
ENG04772-ENG31571,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07,0,
ENG04772-ENG31572,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08,0,
ENG04772-ENG04820,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A,0,
ENG04772-ENG04821,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B,0,
ENG04772-ENG04822,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C,2,
ENG04772-ENG04823,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E,2,
ENG04772-ENG04824,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F,0,
ENG04772-ENG04825,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12,2,
ENG04772-ENG04826,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13,2,
ENG04772-ENG04827,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14,2,
ENG04772-ENG04828,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15,2,
ENG04772-ENG04829,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16,0,
ENG04772-ENG04830,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A,0,
ENG04772-ENG04831,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B,2,
ENG04772-ENG04832,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C,0,
ENG04772-ENG04834,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23,2,
ENG04772-ENG06781,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24,0,
ENG04772-ENG04835,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27,0,
ENG04772-ENG04836,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A,0,
ENG04772-ENG04837,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B,0,
ENG04772-ENG04838,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C,0,
ENG04772-ENG04839,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D,0,
ENG04772-ENG04840,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E,0,
ENG04772-ENG04841,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30,0,
ENG04772-ENG04842,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31,0,
ENG04772-ENG04844,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B,0,
ENG04772-ENG04845,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41,2,
ENG04772-ENG04846,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42,0,
ENG04772-ENG31573,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43,0,
ENG04772-ENG04847,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44,0,
ENG04772-ENG04848,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46,0,
ENG04772-ENG04849,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47,0,
ENG04772-ENG116935,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49,0,
ENG04772-ENG04850,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A,2,
ENG04772-ENG04851,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B,2,
ENG04772-ENG04852,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C,2,
ENG04772-ENG04853,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D,2,
ENG04772-ENG04854,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E,2,
ENG04772-ENG31574,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F,2,
ENG04772-ENG04856,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53,2,
ENG04772-ENG04857,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56,0,
ENG04772-ENG04858,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57,0,
ENG04772-ENG31575,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59,0,
ENG04772-ENG04860,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60,0,
ENG04772-ENG31576,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61,0,
ENG04772-ENG06782,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63,0,
ENG04772-ENG04861,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64,0,
ENG04772-ENG120625,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x67,2,
ENG04772-ENG04862,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69,0,
ENG04772-ENG04863,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A,0,
ENG04772-ENG04864,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73,2,
ENG04772-ENG04865,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76,2,
ENG04772-ENG04866,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77,2,
ENG04772-ENG04867,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78,0,
ENG04772-ENG04868,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B,0,
ENG04772-ENG04869,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C,0,
ENG04772-ENG04870,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80,2,
ENG04772-ENG04871,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84,2,
ENG04772-ENG04872,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87,0,
ENG04772-ENG04873,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88,0,
ENG04772-ENG31577,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89,0,
ENG04772-ENG04874,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A,2,
ENG04772-ENG04875,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B,2,
ENG04772-ENG120626,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8C,0,
ENG04772-ENG04876,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E,0,
ENG04772-ENG04877,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F,0,
ENG04772-ENG04883,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D,0,
ENG04772-ENG04884,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E,0,
ENG04772-ENG04885,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0,2,
ENG04772-ENG31578,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE,0,
ENG04772-ENG00607,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB5,0,
ENG04772-ENG120627,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB7,0,
ENG04772-ENG31579,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8,0,
ENG04772-ENG120628,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBA,0,
ENG04772-ENG120629,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC3,0,
ENG04772-ENG120630,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC4,0,
ENG04772-ENG120631,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC5,0,
ENG04772-ENG120632,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC6,0,
ENG04772-ENG120633,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC7,0,
ENG04772-ENG120634,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC8,0,
ENG04772-ENG120635,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF0,2,
ENG04772-ENG120636,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF1,0,
ENG04772-ENG120637,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF2,0,
ENG04772-ENG117001,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3,0,
ENG04772-ENG00608,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF5,0,
ENG04772-ENG00609,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF6,0,
ENG04772-ENG00610,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF7,0,
ENG55095-ENG55684,GW_component_failure_01-EEPROM_failure,TestComplete_PASS,
ENG55095-ENG56255,GW_component_failure_01-GW_component_failure,TestComplete_PASS,
ENG55095-ENG55931,GW_component_failure_01-RAM_failure,TestComplete_PASS,
ENG55095-ENG55804,GW_component_failure_01-ROM_failure,TestComplete_PASS,
ENG55095-ENG56627,GW_component_failure_01-WD_failure,TestComplete_PASS,
ENG55095-ENG56336,GW_component_failure_01-xx_failure,TestComplete_PASS,
ENG114576-ENG115215,hvk_Electrical_component_error-eem_component_01,0,
ENG114576-ENG115086,hvk_Electrical_component_error-eem_component_02,0,
ENG114576-ENG115120,hvk_Electrical_component_error-eem_component_03,0,
ENG114576-ENG115092,hvk_Electrical_component_error-eem_component_04,0,
ENG114576-ENG115192,hvk_Electrical_component_error-eem_component_05,0,
ENG114576-ENG114919,hvk_Electrical_component_error-eem_component_06,0,
ENG114576-ENG114932,hvk_Electrical_component_error-eem_component_07,0,
ENG114576-ENG115054,hvk_Electrical_component_error-eem_component_08,0,
ENG114576-ENG115197,hvk_Electrical_component_error-eem_component_09,0,
ENG114576-ENG115157,hvk_Electrical_component_error-eem_component_10,0,
ENG114576-ENG115128,hvk_Electrical_component_error-eem_component_11,0,
ENG114576-ENG115153,hvk_Electrical_component_error-eem_component_12,0,
ENG114576-ENG115002,hvk_Electrical_component_error-eem_component_13,0,
ENG114576-ENG114953,hvk_Electrical_component_error-eem_component_14,0,
ENG114576-ENG114956,hvk_Electrical_component_error-eem_component_15,0,
ENG114576-ENG114984,hvk_Electrical_component_error-eem_component_16,0,
ENG06145-ENG06200,hvk_high_voltag_total_discharge_prevention-dcdc_target_mode,0,
ENG06145-ENG06199,hvk_high_voltag_total_discharge_prevention-hvk_total_discharge_prevention_state,0,
ENG06145-ENG06201,hvk_high_voltag_total_discharge_prevention-tme_ekk_target_mode,0,
ENG06145-ENG06202,hvk_high_voltag_total_discharge_prevention-tme_hvptc_target_mode,0,
ENG06144-ENG30377,hvk_high_voltage_zero_potential-awc_zero_potential,0,
ENG06144-ENG06195,hvk_high_voltage_zero_potential-bms_failure_state,0,
ENG06144-ENG06192,hvk_high_voltage_zero_potential-bms_zero_potential,0,
ENG06144-ENG06194,hvk_high_voltage_zero_potential-em1_zero_potential,0,
ENG06144-ENG39278,hvk_high_voltage_zero_potential-em2_zero_potential,0,
ENG06144-ENG39279,hvk_high_voltage_zero_potential-em3_zero_potential,0,
ENG06144-ENG39295,hvk_high_voltage_zero_potential-Flexray_status,0,
ENG06144-ENG39330,hvk_high_voltage_zero_potential-HCAN_status,1,
ENG06144-ENG06198,hvk_high_voltage_zero_potential-hvk_total_zero_potential,1,
ENG06144-ENG06196,hvk_high_voltage_zero_potential-hvlm_connector_plug_state,0,
ENG06144-ENG39358,hvk_high_voltage_zero_potential-lad_2_zero_potential,0,
ENG06144-ENG06193,hvk_high_voltage_zero_potential-lad_zero_potential,0,
ENG26975-ENG30888,MFLe_LIN-DI_Emblem,OFF,
ENG26975-ENG46163,MFLe_LIN-DI_KL_50xs,0,
ENG26975-ENG46164,MFLe_LIN-DI_KL_58xt,55,
ENG26975-ENG30921,MFLe_LIN-Dimmung_01_gueltig,valid,
ENG26975-ENG31890,MFLe_LIN-Klemme_15_MFL,On,
ENG26975-ENG31892,MFLe_LIN-KLR_Modusanforderung,Normal_mode,
ENG26975-ENG31980,MFLe_LIN-LR_HZG_Freigabe,no_restriction,
ENG26975-ENG31981,MFLe_LIN-LR_HZG_on_off,OFF,
ENG26975-ENG32052,MFLe_LIN-MFLe_Anzeige_LaunchControl,display_off,
ENG26975-ENG32053,MFLe_LIN-MFLe_Anzeige_MAP,OFF,
ENG26975-ENG32054,MFLe_LIN-MFLe_Anzeige_Sport,display_off,
ENG26975-ENG32055,MFLe_LIN-MFLe_Anzeige_Sport_Plus,display_off,
ENG26975-ENG32056,MFLe_LIN-MFLe_Tastencode_alt_neu,apply_keycode_new,
ENG26975-ENG32226,MFLe_LIN-P_Mode_MFL,OFF,
ENG06740,MVEM_dc_current_Mv,18.0, A
ENG06739,MVEM_dc_power_desired,0, W
ENG06734,MVEM_DC_voltage_desired,36.00, V
ENG06741,MVEM_dc_voltage_Mv,47.50, V
ENG06736-ENG09198,MVEM_Derating_voltage-Derating_group_A,39.00, V
ENG06736-ENG09199,MVEM_Derating_voltage-Derating_group_B,39.00, V
ENG06736-ENG09200,MVEM_Derating_voltage-Derating_group_C,41.25, V
ENG06736-ENG09337,MVEM_Derating_voltage-Derating_Umax_feedback,54.0, V
ENG06738,MVEM_EMG_level_of_capacity,0.025, %
ENG06737,MVEM_Emg_voltage_desired,52.25, V
ENG06733,MVEM_Mv_current,8, A
ENG08763-ENG09342,MVEM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG08763-ENG09343,MVEM_recommendation_Dcdc-Dcdc_buck_mode,active,
ENG08762-ENG09338,MVEM_release-12V_coldstart_release,No enabling,
ENG08762-ENG09339,MVEM_release-12V_warmstart_release,No enabling,
ENG08762-ENG09340,MVEM_release-48V_coldstart_release,No enabling,
ENG08762-ENG09341,MVEM_release-start_stopp_support_release,No enabling,
ENG06735,MVEM_RSG_maximal_current,508, A
ENG08761-ENG09336,MVEM_RSG_maximal_voltage-RSG_maximal_voltage,52.25, V
ENG06718-ENG120644,NVEM_12Vrsg_input_parameter-rsg_cutoff_rotation_speed,3000, /min
ENG06718-ENG06798,NVEM_12Vrsg_input_parameter-rsg_exciter current_limit,16.0, A
ENG06718-ENG06800,NVEM_12Vrsg_input_parameter-rsg_load_response_time,3, s
ENG06718-ENG06801,NVEM_12Vrsg_input_parameter-rsg_target_mode,0,
ENG06718-ENG06797,NVEM_12Vrsg_input_parameter-rsg_voltage_desired,10.6, V
ENG04778-ENG55511,NVEM_Hlr_release-Release_FlHz_hl,No enabling,
ENG04778-ENG55512,NVEM_Hlr_release-Release_FlHz_hr,No enabling,
ENG04778-ENG55513,NVEM_Hlr_release-Release_FlHz_rest_seat,No enabling,
ENG04778-ENG55514,NVEM_Hlr_release-Release_FlHz_vl,No enabling,
ENG04778-ENG55515,NVEM_Hlr_release-Release_FlHz_vr,No enabling,
ENG04778-ENG04987,NVEM_Hlr_release-Release_FSH,OFF,
ENG04778-ENG04986,NVEM_Hlr_release-Release_HSH,No enabling,
ENG04778-ENG04989,NVEM_Hlr_release-Release_KRH_vl,No enabling,
ENG04778-ENG04988,NVEM_Hlr_release-Release_KRH_vr,No enabling,
ENG04778-ENG04990,NVEM_Hlr_release-Release_LRH,No enabling,
ENG04778-ENG04991,NVEM_Hlr_release-Release_PTC,No enabling,
ENG04778-ENG04992,NVEM_Hlr_release-Release_PTC_linear,0, W
ENG04778-ENG04975,NVEM_Hlr_release-Release_SIH_Fond,Release,
ENG04778-ENG04979,NVEM_Hlr_release-Release_SIH_hl,No enabling,
ENG04778-ENG04978,NVEM_Hlr_release-Release_SIH_hr,No enabling,
ENG04778-ENG04977,NVEM_Hlr_release-Release_SIH_vl,No enabling,
ENG04778-ENG04976,NVEM_Hlr_release-Release_SIH_vr,No enabling,
ENG04778-ENG04983,NVEM_Hlr_release-Release_SIL_hl,No enabling,
ENG04778-ENG04982,NVEM_Hlr_release-Release_SIL_hr,No enabling,
ENG04778-ENG04981,NVEM_Hlr_release-Release_SIL_vl,No enabling,
ENG04778-ENG04980,NVEM_Hlr_release-Release_SIL_vr,No enabling,
ENG04778-ENG04985,NVEM_Hlr_release-Release_Sp_heatin_codriver,No enabling,
ENG04778-ENG04984,NVEM_Hlr_release-Release_Sp_heatin_driver,No enabling,
ENG04778-ENG32447,NVEM_Hlr_release-Release_TCH,No enabling,
ENG06726,NVEM_Hv_DcDc_voltage_desired_nv,10.6, V
ENG04783,NVEM_hybrid_info,3,
ENG06728,NVEM_Mv_DcDc_curren_nv,58, A
ENG06729,NVEM_Mv_DcDc_current_reserve_nv,166, A
ENG06731,NVEM_Mv_DcDc_level_of_capacity,26.4, %
ENG06730,NVEM_Mv_DcDc_voltage_desired_nv,14.7, V
ENG06727,NVEM_Mv_DcDc_voltage_nv,0.0, V
ENG04774-ENG06796,NVEM_Voltage_Request-Voltage_Request_BCM,not active,
ENG04774-ENG04969,NVEM_Voltage_Request-Voltage_Request_ClimatControl,not active,
ENG04774-ENG04968,NVEM_Voltage_Request-Voltage_Request_engine,not active,
ENG04774-ENG04966,NVEM_Voltage_Request-Voltage_Request_EPS,not active,
ENG04774-ENG04967,NVEM_Voltage_Request-Voltage_Request_ESP,not active,
ENG04774-ENG04970,NVEM_Voltage_Request-Voltage_Request_GearControl,not active,
ENG04774-ENG04971,NVEM_Voltage_Request-Voltage_Request_Reduction_Alternator_Load,not active,
ENG55147-ENG56699,OBD_CALID-CALID,GW4K0468L-0262--,
ENG55148-ENG55422,OBD_CVN-CVN,6E 3E E6 27,
ENG04788-ENG98667,operation_hours-Kilometers,182,
ENG08771-ENG09431,Stack_Size_Max-Stack_Size_Max_ISR,51, %
ENG08771-ENG09408,Stack_Size_Max-Stack_Size_Max_Task_01,29, %
ENG08771-ENG09409,Stack_Size_Max-Stack_Size_Max_Task_02,51, %
ENG08771-ENG09410,Stack_Size_Max-Stack_Size_Max_Task_03,51, %
ENG08771-ENG09411,Stack_Size_Max-Stack_Size_Max_Task_04,40, %
ENG08771-ENG09412,Stack_Size_Max-Stack_Size_Max_Task_05,46, %
ENG08771-ENG09413,Stack_Size_Max-Stack_Size_Max_Task_06,39, %
ENG08771-ENG09414,Stack_Size_Max-Stack_Size_Max_Task_07,50, %
ENG08771-ENG09415,Stack_Size_Max-Stack_Size_Max_Task_08,71, %
ENG08771-ENG09416,Stack_Size_Max-Stack_Size_Max_Task_09,74, %
ENG08771-ENG09417,Stack_Size_Max-Stack_Size_Max_Task_10,47, %
ENG08771-ENG09418,Stack_Size_Max-Stack_Size_Max_Task_11,33, %
ENG08771-ENG09419,Stack_Size_Max-Stack_Size_Max_Task_12,28, %
ENG08771-ENG09420,Stack_Size_Max-Stack_Size_Max_Task_13,61, %
ENG08771-ENG09421,Stack_Size_Max-Stack_Size_Max_Task_14,0, %
ENG08771-ENG09422,Stack_Size_Max-Stack_Size_Max_Task_15,0, %
ENG08771-ENG09423,Stack_Size_Max-Stack_Size_Max_Task_16,0, %
ENG08771-ENG09424,Stack_Size_Max-Stack_Size_Max_Task_17,0, %
ENG08771-ENG09425,Stack_Size_Max-Stack_Size_Max_Task_18,0, %
ENG08771-ENG09426,Stack_Size_Max-Stack_Size_Max_Task_19,0, %
ENG08771-ENG09427,Stack_Size_Max-Stack_Size_Max_Task_20,0, %
ENG08771-ENG09428,Stack_Size_Max-Stack_Size_Max_Task_21,0, %
ENG08771-ENG09429,Stack_Size_Max-Stack_Size_Max_Task_22,0, %
ENG08771-ENG09430,Stack_Size_Max-Stack_Size_Max_Task_23,0, %
ENG04781,StartStop_info,1,
ENG08770-ENG09376,State_Dataset_AuxFunktions-Datensatz_0,valid,
ENG08770-ENG09377,State_Dataset_AuxFunktions-Datensatz_1,valid,
ENG08770-ENG09392,State_Dataset_AuxFunktions-Datensatz_10,valid,
ENG08770-ENG09393,State_Dataset_AuxFunktions-Datensatz_11,valid,
ENG08770-ENG09394,State_Dataset_AuxFunktions-Datensatz_12,valid,
ENG08770-ENG09395,State_Dataset_AuxFunktions-Datensatz_13,valid,
ENG08770-ENG09396,State_Dataset_AuxFunktions-Datensatz_14,valid,
ENG08770-ENG09397,State_Dataset_AuxFunktions-Datensatz_15,valid,
ENG08770-ENG09398,State_Dataset_AuxFunktions-Datensatz_16,valid,
ENG08770-ENG09399,State_Dataset_AuxFunktions-Datensatz_17,valid,
ENG08770-ENG09400,State_Dataset_AuxFunktions-Datensatz_18,valid,
ENG08770-ENG09401,State_Dataset_AuxFunktions-Datensatz_19,valid,
ENG08770-ENG09402,State_Dataset_AuxFunktions-Datensatz_1A,valid,
ENG08770-ENG09403,State_Dataset_AuxFunktions-Datensatz_1B,valid,
ENG08770-ENG09404,State_Dataset_AuxFunktions-Datensatz_1C,valid,
ENG08770-ENG09405,State_Dataset_AuxFunktions-Datensatz_1D,valid,
ENG08770-ENG09406,State_Dataset_AuxFunktions-Datensatz_1E,valid,
ENG08770-ENG09407,State_Dataset_AuxFunktions-Datensatz_1F,valid,
ENG08770-ENG09378,State_Dataset_AuxFunktions-Datensatz_2,valid,
ENG08770-ENG09379,State_Dataset_AuxFunktions-Datensatz_3,valid,
ENG08770-ENG09380,State_Dataset_AuxFunktions-Datensatz_4,valid,
ENG08770-ENG09381,State_Dataset_AuxFunktions-Datensatz_5,valid,
ENG08770-ENG09382,State_Dataset_AuxFunktions-Datensatz_6,valid,
ENG08770-ENG09383,State_Dataset_AuxFunktions-Datensatz_7,valid,
ENG08770-ENG09384,State_Dataset_AuxFunktions-Datensatz_8,valid,
ENG08770-ENG09385,State_Dataset_AuxFunktions-Datensatz_9,valid,
ENG08770-ENG09386,State_Dataset_AuxFunktions-Datensatz_A,valid,
ENG08770-ENG09387,State_Dataset_AuxFunktions-Datensatz_B,valid,
ENG08770-ENG09388,State_Dataset_AuxFunktions-Datensatz_C,valid,
ENG08770-ENG09389,State_Dataset_AuxFunktions-Datensatz_D,valid,
ENG08770-ENG09390,State_Dataset_AuxFunktions-Datensatz_E,valid,
ENG08770-ENG09391,State_Dataset_AuxFunktions-Datensatz_F,valid,
ENG06146-MAS00106,Status_to_a_agree_a_appointment_online-Year,2000,
ENG06146-MAS00107,Status_to_a_agree_a_appointment_online-Month,0,
ENG06146-MAS00108,Status_to_a_agree_a_appointment_online-Day,0,
ENG06146-MAS00109,Status_to_a_agree_a_appointment_online-Hours,0,
ENG06146-MAS00110,Status_to_a_agree_a_appointment_online-Minutes,0,
ENG06146-MAS00111,Status_to_a_agree_a_appointment_online-Seconds,0,
ENG06146-ENG28929,Status_to_a_agree_a_appointment_online-Status_OTV_remind_Flag,no_Set,
ENG06146-ENG28928,Status_to_a_agree_a_appointment_online-Status_OTV_Trigger,no_Set,
ENG08634-ENG120595,Transportmode_Status-Transport_Protection,not activated,
ENG08634-ENG98982,Transportmode_Status-Transportmode,not activated,
ENG27267-ENG05094,Voltage_Comfort_2_CAN-Voltage_CAN_High,2.36, V
ENG27267-ENG05095,Voltage_Comfort_2_CAN-Voltage_CAN_Low,0.00, V
ENG04789-ENG05094,Voltage_Comfort_CAN-Voltage_CAN_High,2.46, V
ENG04789-ENG05095,Voltage_Comfort_CAN-Voltage_CAN_Low,0.00, V
ENG55183-ENG05094,Voltage_Connect_CAN-Voltage_CAN_High,2.30, V
ENG55183-ENG05095,Voltage_Connect_CAN-Voltage_CAN_Low,0.00, V
ENG27268-ENG05094,Voltage_Dashboard_CAN-Voltage_CAN_High,2.44, V
ENG27268-ENG05095,Voltage_Dashboard_CAN-Voltage_CAN_Low,0.00, V
ENG04792-ENG05094,Voltage_Extended_CAN-Voltage_CAN_High,2.46, V
ENG04792-ENG05095,Voltage_Extended_CAN-Voltage_CAN_Low,0.00, V
ENG04790-ENG05094,Voltage_Hybrid_CAN-Voltage_CAN_High,2.40, V
ENG04790-ENG05095,Voltage_Hybrid_CAN-Voltage_CAN_Low,0.00, V
ENG04791-ENG05094,Voltage_Infotainment_CAN-Voltage_CAN_High,2.36, V
ENG04791-ENG05095,Voltage_Infotainment_CAN-Voltage_CAN_Low,0.00, V
ENG55196,Wakelocks,not activated,
ENG55196,Wakelocks,activated,
Elapsed Time: 02:38
Jef
HQ
blockmap-29-80A-907-397-D_WAU8EAF82LN004143-20201024-1518.CSV
;Component:LCM_MLBevo    H07 0022, Coding:
;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW53.rod
;Saturday,24,October,2020,15:18:58:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: B032FB8A3AD04ADB57B-80E4
Group,Description,Actual
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,161,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,1,
IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.20, V
IDE06876-MAS01482,Signature light lamp faulty-Hardware version,not installed,
IDE06876-MAS01483,Signature light lamp faulty-Software version,not installed,
IDE06876-MAS12381,Signature light lamp faulty-Software subversion,0F,
IDE06876-ENG14244,Signature light lamp faulty-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,0E 1A AC 52 00,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Watchdog Reset,
IDE08742-MAS01155,Operating time-Control module,20.74, H
IDE08742-MAS03835,Operating time-Position lamps,3.77, H
IDE08742-MAS09325,Operating time-Daytime running lamps,6.37, H
IDE08742-MAS09330,Operating time-Reflector for low beam,0.00, H
IDE08742-MAS09332,Operating time-Turn signal lamps,0.48, H
IDE08742-MAS09333,Operating time-Side marker lamps,3.77, H
IDE08742-MAS09334,Operating time-Parking lamps,0.00, H
IDE09492-MAS01155,Temperatures-Control module,53.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,62.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,30.00, °C
IDE09768-MAS04121,LED channel 1-Voltage,11.95, V
IDE09768-MAS04136,LED channel 1-Current,1000, mA
IDE09768-MAS09022,LED channel 1-PWM value,100.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,1,
IDE09768-MAS09328,LED channel 1-Primary function,Daytime running lamps,
IDE09768-MAS09329,LED channel 1-Secondary function,Daytime running lamps,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,3,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal lamps,
IDE09769-MAS09329,LED channel 2-Secondary function,Turn signal lamps,
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Side marker lamps,
IDE09774-MAS03835,Number of activations-Position lamps,97,
IDE09774-MAS09325,Number of activations-Daytime running lamps,137,
IDE09774-MAS09330,Number of activations-Reflector for low beam,0,
IDE09774-MAS09332,Number of activations-Turn signal lamps,4036,
IDE09774-MAS09333,Number of activations-Side marker lamps,97,
IDE09774-MAS09334,Number of activations-Parking lamps,0,
IDE09775-MAS09336,High temperature operating times for control unit-between 95°C and 105°C,4.09, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,2.21, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,2.11, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 38,
IDE09828-MAS01155,Head lamp variant-Control module,E0 38,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28929,
IDE09916-MAS09565,Data set names-Data set name,A8D5LEDSWSAE,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Position lamps,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lamps,2,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal lamps,0,
IDE11124-MAS12195,Headlamp Range Control Motor-Reference run status,not performed,
IDE11124-MAS12196,Headlamp Range Control Motor-Fault position,not approached,
IDE11124-MAS12199,Headlamp Range Control Motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlamp Range Control Motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11124-MAS12207,Headlamp Range Control Motor-Low beam inclination,-697.50, mm
IDE11125-MAS12195,Adaptive Cornering Lamp Motor-Reference run status,not performed,
IDE11125-MAS12196,Adaptive Cornering Lamp Motor-Fault position,not approached,
IDE11125-MAS12199,Adaptive Cornering Lamp Motor-Adjustment speed,normal,
IDE11125-MAS12206,Adaptive Cornering Lamp Motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11125-MAS12209,Adaptive Cornering Lamp Motor-Swivel angle,Unknown,
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardware version,not installed,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Software version,not installed,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
blockmap-36-4M4-959-760-D_WAU8EAF82LN004143-20201024-1519.CSV
;Component:MEM-FS        009 0044, Coding:001C9A400005BEA1480301012101210081A100070700878700000000004000
;EV_SCMDriveSideCONTIAU736,006009,EV_SCMDriveSideCONTIAU736_AU38.rod
;Saturday,24,October,2020,15:19:03:14741
;VCID: BD2CD2BEFD82B7B3CCD-80E8
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.40, V
IDE00102,Control Module temperature,43,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,208, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,3912, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,33341,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32196,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32600,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,32,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,91,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1145,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33272,
IDE06511-MAS01391,Seat height adjustment-Block 2,32769,
IDE06511-MAS02282,Seat height adjustment-Position,33213,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,19,
IDE06511-MAS04160,Seat height adjustment-Load change,73,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,503,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,32978,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32427,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32790,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,106,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,331,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,551,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33051,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32781,
IDE06683-MAS02282,Seat inclination adjustment-Position,32938,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,5,
IDE06683-MAS04160,Seat inclination adjustment-Load change,40,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,270,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,32600,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,33213,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32789,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32938,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,32465,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,32958,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,32823,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,32433,
IDE08989-MAS01391,Seat depth adjustment-Block 2,32909,
IDE08989-MAS02282,Seat depth adjustment-Position,32465,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,25, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,2,
IDE08989-MAS04160,Seat depth adjustment-Load change,4,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,standardized,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,476,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,standardized,
IDE08990-MAS01390,Backrest top adjustment-Block 1,33067,
IDE08990-MAS01391,Backrest top adjustment-Block 2,32664,
IDE08990-MAS02282,Backrest top adjustment-Position,32958,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,25, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,3,
IDE08990-MAS04160,Backrest top adjustment-Load change,5,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,standardized,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,403,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,standardized,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10617-IDE07856,Valve block 1: status supply voltage-Terminal status,iO,
IDE10617-IDE10544,Valve block 1: status supply voltage-Internal Supply Voltage,13.60, V
IDE10617-MAS00043,Valve block 1: status supply voltage-Terminal 30 power supply,14.40, V
IDE10617-MAS10469,Valve block 1: status supply voltage-Raw value,189, bit
IDE10618-IDE07856,Valve block 2: status supply voltage-Terminal status,iO,
IDE10618-IDE10544,Valve block 2: status supply voltage-Internal Supply Voltage,13.50, V
IDE10618-MAS00043,Valve block 2: status supply voltage-Terminal 30 power supply,14.30, V
IDE10618-MAS10469,Valve block 2: status supply voltage-Raw value,187, bit
IDE10638-IDE00361,Pressure sensor in valve block-Ambient air pressure,54787, hPa
IDE10638-MAS03458,Pressure sensor in valve block-Differential pressure,256, hPa
IDE10638-MAS10975,Pressure sensor in valve block-Pre-pressure chamber,55043, hPa
IDE10691-IDE03019,Pressure of airbags-Pressure in air cushions for lumbar support 1,0, hPa
IDE10691-IDE03020,Pressure of airbags-Pressure in air cushions for lumbar support 2,0, hPa
IDE10691-IDE03021,Pressure of airbags-Pressure in air cushions for lumbar support 3,0, hPa
IDE10691-IDE03022,Pressure of airbags-Pressure in air cushions for left side bolster,0, hPa
IDE10691-IDE03023,Pressure of airbags-Pressure in air cushions for right side bolster,0, hPa
IDE10691-IDE03024,Pressure of airbags-Pressure in air cushions for left seatback bolster,0, hPa
IDE10691-IDE03025,Pressure of airbags-Pressure in air cushions for right seatback bolster,0, hPa
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,standardized,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,standardized,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,standardized,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,32767,
IDE11024-MAS01391,Headrest height adjustment-Block 2,33203,
IDE11024-MAS02282,Headrest height adjustment-Position,32823,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,25, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,18,
IDE11024-MAS04160,Headrest height adjustment-Load change,24,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,standardized,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,436,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,standardized,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
IDE12721-MAS15042,Pressure of airbags 2-Pressure in air cushion 1 in tilt adjustable foot rest,0, hPa
IDE12721-MAS15043,Pressure of airbags 2-Pressure in air cushion 2 in tilt adjustable foot rest,0, hPa
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,standardized,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,standardized,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,standardized,
ENG08879-IDE06510,Account_1-Adjustment for backrest angle,32600,
ENG08879-IDE06511,Account_1-Seat height adjustment,33213,
ENG08879-IDE06512,Account_1-Adjustment for seat forward/back position,32789,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,32938,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG08879-IDE08989,Account_1-Seat depth adjustment,32465,
ENG08879-IDE08990,Account_1-Backrest top adjustment,32958,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,32823,
ENG08880-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG08880-IDE06511,Account_2-Seat height adjustment,0,
ENG08880-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,0,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG08881-IDE06511,Account_3-Seat height adjustment,0,
ENG08881-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,0,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Achse decodiert,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Normierroutine,
ENG05258-ENG05273,Entnormierursache-Axis_6,Normierroutine,
ENG05258-ENG05274,Entnormierursache-Axis_7,Normierroutine,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Achse decodiert,
ENG116729-ENG117054,info_developer-ax_da,80 16 7E AB 80 D2 00 07 7F 58 7D C4 82 3D 00 07 81 BD 80 01 81 F8 00 07 80 AA 80 0D 81 1B 00 07 7E D1 7E B1 80 8D 00 07 80 37 7F FF 81 B3 00 07 80 BE 7F 98 81 2B 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG116729-ENG117006,info_developer-gl_lo,34 4D 34 39 35 39 37 36 30 44 20 00 00 00 00 00 30 30 34 32 00 00 00 00 31 38 32 35 00 00 00 00 53 43 58 44 35 4B 4F 4D 46 4F 52 54 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6A 00 07 04 04 04 04 04 04 04 00 00 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 0C 00 00 00 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,active,
ENG26210-ENG30378,Maximum travel-Axis_1_current,551,
ENG26210-ENG30379,Maximum travel-Axis_1_last,551,
ENG26210-ENG30380,Maximum travel-Axis_10_current,65535,
ENG26210-ENG30381,Maximum travel-Axis_10_last,0,
ENG26210-ENG30382,Maximum travel-Axis_2_current,1145,
ENG26210-ENG30383,Maximum travel-Axis_2_last,0,
ENG26210-ENG30384,Maximum travel-Axis_3_current,503,
ENG26210-ENG30385,Maximum travel-Axis_3_last,0,
ENG26210-ENG30386,Maximum travel-Axis_4_current,270,
ENG26210-ENG30387,Maximum travel-Axis_4_last,0,
ENG26210-ENG30388,Maximum travel-Axis_5_current,476,
ENG26210-ENG30389,Maximum travel-Axis_5_last,0,
ENG26210-ENG30390,Maximum travel-Axis_6_current,436,
ENG26210-ENG30391,Maximum travel-Axis_6_last,0,
ENG26210-ENG30392,Maximum travel-Axis_7_current,403,
ENG26210-ENG30393,Maximum travel-Axis_7_last,0,
ENG26210-ENG30394,Maximum travel-Axis_8_current,65535,
ENG26210-ENG30395,Maximum travel-Axis_8_last,0,
ENG26210-ENG30396,Maximum travel-Axis_9_current,65535,
ENG26210-ENG30397,Maximum travel-Axis_9_last,0,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG05280-ENG05370,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_SBC,66, bit
ENG05280-ENG05376,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_Ventil_high,49, bit
ENG05280-ENG05373,Multikontur_LP_Temp_IVB-p_AD_Wert_Temp_Ventil_low,50, bit
ENG05280-ENG05372,Multikontur_LP_Temp_IVB-p_Status_Temp_SBC,iO,
ENG05280-ENG05378,Multikontur_LP_Temp_IVB-p_Status_Temp_Ventil_high,iO,
ENG05280-ENG05375,Multikontur_LP_Temp_IVB-p_Status_Temp_Ventil_low,iO,
ENG05280-ENG05371,Multikontur_LP_Temp_IVB-p_Temp_SBC,39, °C
ENG05280-ENG05377,Multikontur_LP_Temp_IVB-p_Temp_Ventil_high,29, °C
ENG05280-ENG05374,Multikontur_LP_Temp_IVB-p_Temp_Ventil_low,30, °C
ENG05281-ENG05370,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_SBC,58, bit
ENG05281-ENG05376,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_Ventil_high,46, bit
ENG05281-ENG05373,Multikontur_LP_Temp_MSG-p_AD_Wert_Temp_Ventil_low,48, bit
ENG05281-ENG05372,Multikontur_LP_Temp_MSG-p_Status_Temp_SBC,iO,
ENG05281-ENG05378,Multikontur_LP_Temp_MSG-p_Status_Temp_Ventil_high,iO,
ENG05281-ENG05375,Multikontur_LP_Temp_MSG-p_Status_Temp_Ventil_low,iO,
ENG05281-ENG05371,Multikontur_LP_Temp_MSG-p_Temp_SBC,35, °C
ENG05281-ENG05377,Multikontur_LP_Temp_MSG-p_Temp_Ventil_high,27, °C
ENG05281-ENG05374,Multikontur_LP_Temp_MSG-p_Temp_Ventil_low,28, °C
ENG05284-ENG05394,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_mitte,0, ms
ENG05284-ENG05393,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_oben,0, ms
ENG05284-ENG05395,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_LRD_unten,0, ms
ENG05284-ENG05397,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_SHK,0, ms
ENG05284-ENG05396,Multikontur_Selbstteststatus_IVB-p_Befuellzeit_SHL,0, ms
ENG05284-ENG05399,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_mitte,0, ms
ENG05284-ENG05398,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_oben,0, ms
ENG05284-ENG05400,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_LRD_unten,0, ms
ENG05284-ENG05402,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_SHK,0, ms
ENG05284-ENG05401,Multikontur_Selbstteststatus_IVB-p_Entlueftzeit_SHL,0, ms
ENG05284-ENG05421,Multikontur_Selbstteststatus_IVB-p_Ergebnis,nicht aktiv und kein Fehler,
ENG05284-ENG05411,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD mitte,0, hPa
ENG05284-ENG05410,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD_oben,0, hPa
ENG05284-ENG05412,Multikontur_Selbstteststatus_IVB-p_Leckage_LRD_unten,0, hPa
ENG05284-ENG05415,Multikontur_Selbstteststatus_IVB-p_Leckage_SHK_links,0, hPa
ENG05284-ENG05416,Multikontur_Selbstteststatus_IVB-p_Leckage_SHK_rechts,0, hPa
ENG05284-ENG05413,Multikontur_Selbstteststatus_IVB-p_Leckage_SHL_links,0, hPa
ENG05284-ENG05414,Multikontur_Selbstteststatus_IVB-p_Leckage_SHL_rechts,0, hPa
ENG05284-ENG05418,Multikontur_Selbstteststatus_IVB-p_Leckage_Vordruckkammer,0, hPa
ENG05284-ENG05419,Multikontur_Selbstteststatus_IVB-p_Leiterplattentemperatur,0, °C
ENG05284-ENG05404,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_mitte,0, hPa
ENG05284-ENG05403,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_oben,0, hPa
ENG05284-ENG05405,Multikontur_Selbstteststatus_IVB-p_Startdruck_LRD_unten,0, hPa
ENG05284-ENG05408,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHK_links,0, hPa
ENG05284-ENG05409,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHK_rechts,0, hPa
ENG05284-ENG05406,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHL_links,0, hPa
ENG05284-ENG05407,Multikontur_Selbstteststatus_IVB-p_Startdruck_SHL_rechts,0, hPa
ENG05284-ENG05417,Multikontur_Selbstteststatus_IVB-p_Startdruck_Vordruckkammer,0, hPa
ENG05284-ENG05420,Multikontur_Selbstteststatus_IVB-p_Status,inaktiv,
ENG05284-ENG32230,Multikontur_Selbstteststatus_IVB-p_Status_2,Lordose oben,
ENG05284-ENG32231,Multikontur_Selbstteststatus_IVB-p_Status_3,inaktiv,
ENG05284-ENG32232,Multikontur_Selbstteststatus_IVB-p_Status_4,Lordose oben,
ENG26986-ENG30413,Multikontur_Selbstteststatus_IVB_NFA-Blase,not active,
ENG26986-ENG30414,Multikontur_Selbstteststatus_IVB_NFA-Blase bei 1. Fehlerfall,not active,
ENG26986-ENG32222,Multikontur_Selbstteststatus_IVB_NFA-p_Befuellzeit_NFA,0, ms
ENG26986-ENG32223,Multikontur_Selbstteststatus_IVB_NFA-p_Entlueftzeit_NFA,0, ms
ENG26986-ENG05421,Multikontur_Selbstteststatus_IVB_NFA-p_Ergebnis,nicht aktiv und kein Fehler,
ENG26986-ENG32224,Multikontur_Selbstteststatus_IVB_NFA-p_Leckage_NFA_Blase_1,0, hPa
ENG26986-ENG32225,Multikontur_Selbstteststatus_IVB_NFA-p_Leckage_NFA_Blase_2,0, hPa
ENG26986-ENG32227,Multikontur_Selbstteststatus_IVB_NFA-p_Startdruck_LRD_Blase_2,0, hPa
ENG26986-ENG32228,Multikontur_Selbstteststatus_IVB_NFA-p_Startdruck_NFA_Blase_1,0, hPa
ENG26986-ENG32229,Multikontur_Selbstteststatus_IVB_NFA-p_Status_1,not active,
ENG26986-ENG32541,Multikontur_Selbstteststatus_IVB_NFA-Selbsttest Testschritt,not active,
ENG05285-ENG05422,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_1,0, ms
ENG05285-ENG05431,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_10,0, ms
ENG05285-ENG05423,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_2,0, ms
ENG05285-ENG05424,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_3,0, ms
ENG05285-ENG05425,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_4,0, ms
ENG05285-ENG05426,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_5,0, ms
ENG05285-ENG05427,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_6,0, ms
ENG05285-ENG05428,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_7,0, ms
ENG05285-ENG05429,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_8,0, ms
ENG05285-ENG05430,Multikontur_Selbstteststatus_MSG-p_Befuellzeit_Blase_9,0, ms
ENG05285-ENG05432,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_1,0, hPa
ENG05285-ENG05441,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_10,0, hPa
ENG05285-ENG05433,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_2,0, hPa
ENG05285-ENG05434,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_3,0, hPa
ENG05285-ENG05435,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_4,0, hPa
ENG05285-ENG05436,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_5,0, hPa
ENG05285-ENG05437,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_6,0, hPa
ENG05285-ENG05438,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_7,0, hPa
ENG05285-ENG05439,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_8,0, hPa
ENG05285-ENG05440,Multikontur_Selbstteststatus_MSG-p_Entlueftdruck_Blase_9,0, hPa
ENG05285-ENG05421,Multikontur_Selbstteststatus_MSG-p_Ergebnis,nicht aktiv und kein Fehler,
ENG05285-ENG05419,Multikontur_Selbstteststatus_MSG-p_Leiterplattentemperatur,0, °C
ENG05285-ENG05420,Multikontur_Selbstteststatus_MSG-p_Status,inaktiv,
ENG05285-ENG32230,Multikontur_Selbstteststatus_MSG-p_Status_2,0,
ENG05285-ENG32231,Multikontur_Selbstteststatus_MSG-p_Status_3,inaktiv,
ENG05285-ENG32232,Multikontur_Selbstteststatus_MSG-p_Status_4,0,
ENG26987-ENG05422,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_1,0, ms
ENG26987-ENG05431,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_10,0, ms
ENG26987-ENG05423,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_2,0, ms
ENG26987-ENG05424,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_3,0, ms
ENG26987-ENG05425,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_4,0, ms
ENG26987-ENG05426,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_5,0, ms
ENG26987-ENG05427,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_6,0, ms
ENG26987-ENG05428,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_7,0, ms
ENG26987-ENG05429,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_8,0, ms
ENG26987-ENG05430,Multikontur_Selbstteststatus_MSG_2-p_Befuellzeit_Blase_9,0, ms
ENG26987-ENG05432,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_1,0, hPa
ENG26987-ENG05441,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_10,0, hPa
ENG26987-ENG05433,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_2,0, hPa
ENG26987-ENG05434,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_3,0, hPa
ENG26987-ENG05435,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_4,0, hPa
ENG26987-ENG05436,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_5,0, hPa
ENG26987-ENG05437,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_6,0, hPa
ENG26987-ENG05438,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_7,0, hPa
ENG26987-ENG05439,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_8,0, hPa
ENG26987-ENG05440,Multikontur_Selbstteststatus_MSG_2-p_Entlueftdruck_Blase_9,0, hPa
ENG26987-ENG05421,Multikontur_Selbstteststatus_MSG_2-p_Ergebnis,nicht aktiv und kein Fehler,
ENG26987-ENG05419,Multikontur_Selbstteststatus_MSG_2-p_Leiterplattentemperatur,0, °C
ENG26987-ENG05420,Multikontur_Selbstteststatus_MSG_2-p_Status,inaktiv,
ENG26987-ENG32230,Multikontur_Selbstteststatus_MSG_2-p_Status_2,0,
ENG26987-ENG32231,Multikontur_Selbstteststatus_MSG_2-p_Status_3,inaktiv,
ENG26987-ENG32232,Multikontur_Selbstteststatus_MSG_2-p_Status_4,0,
ENG05282-ENG05379,Multikontur_Statistik_IVB-p_Ventil_1,129, counts
ENG05282-ENG05388,Multikontur_Statistik_IVB-p_Ventil_10,145, counts
ENG05282-ENG05389,Multikontur_Statistik_IVB-p_Ventil_11,138, counts
ENG05282-ENG05390,Multikontur_Statistik_IVB-p_Ventil_12,137, counts
ENG05282-ENG05391,Multikontur_Statistik_IVB-p_Ventil_13,137, counts
ENG05282-ENG05392,Multikontur_Statistik_IVB-p_Ventil_14,140, counts
ENG05282-ENG05380,Multikontur_Statistik_IVB-p_Ventil_2,52, counts
ENG05282-ENG05381,Multikontur_Statistik_IVB-p_Ventil_3,76, counts
ENG05282-ENG05382,Multikontur_Statistik_IVB-p_Ventil_4,75, counts
ENG05282-ENG05383,Multikontur_Statistik_IVB-p_Ventil_5,63, counts
ENG05282-ENG05384,Multikontur_Statistik_IVB-p_Ventil_6,63, counts
ENG05282-ENG05385,Multikontur_Statistik_IVB-p_Ventil_7,76, counts
ENG05282-ENG05386,Multikontur_Statistik_IVB-p_Ventil_8,188, counts
ENG05282-ENG05387,Multikontur_Statistik_IVB-p_Ventil_9,138, counts
ENG05283-ENG05379,Multikontur_Statistik_MSG-p_Ventil_1,120, counts
ENG05283-ENG05388,Multikontur_Statistik_MSG-p_Ventil_10,135, counts
ENG05283-ENG05380,Multikontur_Statistik_MSG-p_Ventil_2,125, counts
ENG05283-ENG05381,Multikontur_Statistik_MSG-p_Ventil_3,113, counts
ENG05283-ENG05382,Multikontur_Statistik_MSG-p_Ventil_4,0, counts
ENG05283-ENG05383,Multikontur_Statistik_MSG-p_Ventil_5,0, counts
ENG05283-ENG05384,Multikontur_Statistik_MSG-p_Ventil_6,124, counts
ENG05283-ENG05385,Multikontur_Statistik_MSG-p_Ventil_7,126, counts
ENG05283-ENG05386,Multikontur_Statistik_MSG-p_Ventil_8,152, counts
ENG05283-ENG05387,Multikontur_Statistik_MSG-p_Ventil_9,139, counts
ENG26988-ENG05379,Multikontur_Statistik_MSG2-p_Ventil_1,0, counts
ENG26988-ENG05388,Multikontur_Statistik_MSG2-p_Ventil_10,0, counts
ENG26988-ENG05380,Multikontur_Statistik_MSG2-p_Ventil_2,0, counts
ENG26988-ENG05381,Multikontur_Statistik_MSG2-p_Ventil_3,0, counts
ENG26988-ENG05382,Multikontur_Statistik_MSG2-p_Ventil_4,0, counts
ENG26988-ENG05383,Multikontur_Statistik_MSG2-p_Ventil_5,0, counts
ENG26988-ENG05384,Multikontur_Statistik_MSG2-p_Ventil_6,0, counts
ENG26988-ENG05385,Multikontur_Statistik_MSG2-p_Ventil_7,0, counts
ENG26988-ENG05386,Multikontur_Statistik_MSG2-p_Ventil_8,0, counts
ENG26988-ENG05387,Multikontur_Statistik_MSG2-p_Ventil_9,0, counts
ENG05288-ENG05446,p_Fehlerspeicher-p_Drucksensorfehler,Unknown (10),
ENG05288-ENG05448,p_Fehlerspeicher-p_DTC__Uebertemp 2,Unknown (21),
ENG05288-ENG05444,p_Fehlerspeicher-p_DTC_Ueberspannung,Unknown (104),
ENG05288-ENG05443,p_Fehlerspeicher-p_ECU_defekt,iO,
ENG05288-ENG05451,p_Fehlerspeicher-p_Grobleck_V1,p_aktuell_vorhanden,
ENG05288-ENG05454,p_Fehlerspeicher-p_Grobleck_V2,p_aktuell_vorhanden,
ENG05288-ENG05457,p_Fehlerspeicher-p_Grobleck_V3,p_aktuell_vorhanden,
ENG05288-ENG05460,p_Fehlerspeicher-p_Grobleck_V4,p_aktuell_vorhanden,
ENG05288-ENG05463,p_Fehlerspeicher-p_Grobleck_V5,p_aktuell_vorhanden,
ENG05288-ENG05466,p_Fehlerspeicher-p_Grobleck_V6,p_aktuell_vorhanden,
ENG05288-ENG05469,p_Fehlerspeicher-p_Grobleck_V7,p_aktuell_vorhanden,
ENG05288-ENG05447,p_Fehlerspeicher-p_Kompressor_pneumatisch,p_aktuell_vorhanden,
ENG05288-ENG05450,p_Fehlerspeicher-p_Neg_Leck_V1,Unknown (21),
ENG05288-ENG05453,p_Fehlerspeicher-p_Neg_Leck_V2,p_aktuell_vorhanden,
ENG05288-ENG05456,p_Fehlerspeicher-p_Neg_Leck_V3,p_aktuell_vorhanden,
ENG05288-ENG05459,p_Fehlerspeicher-p_Neg_Leck_V4,p_aktuell_vorhanden,
ENG05288-ENG05462,p_Fehlerspeicher-p_Neg_Leck_V5,p_aktuell_vorhanden,
ENG05288-ENG05465,p_Fehlerspeicher-p_Neg_Leck_V6,p_aktuell_vorhanden,
ENG05288-ENG05468,p_Fehlerspeicher-p_Neg_Leck_V7,p_aktuell_vorhanden,
ENG05288-ENG05449,p_Fehlerspeicher-p_Pos_Leck_V1,p_aktuell_vorhanden,
ENG05288-ENG05452,p_Fehlerspeicher-p_Pos_Leck_V2,p_aktuell_vorhanden,
ENG05288-ENG05455,p_Fehlerspeicher-p_Pos_Leck_V3,p_aktuell_vorhanden,
ENG05288-ENG05458,p_Fehlerspeicher-p_Pos_Leck_V4,p_aktuell_vorhanden,
ENG05288-ENG05461,p_Fehlerspeicher-p_Pos_Leck_V5,p_aktuell_vorhanden,
ENG05288-ENG05464,p_Fehlerspeicher-p_Pos_Leck_V6,p_aktuell_vorhanden,
ENG05288-ENG05467,p_Fehlerspeicher-p_Pos_Leck_V7,p_aktuell_vorhanden,
ENG05288-ENG05445,p_Fehlerspeicher-p_Unterspannung_DTC,p_aktuell_vorhanden,
ENG27019-ENG109828,p_overcurrent_slaves-Value_1,0,
ENG27019-ENG109829,p_overcurrent_slaves-Value_2,0,
ENG05286-ENG05442,p_SW_Date_IVB-p_SW-Date_ASCII,01 02 14 11 0A 32,
ENG05287-ENG05442,p_SW_Date_MSG-p_SW-Date_ASCII,0C 0A 14 10 10 21,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,106,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32823,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32823,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32958,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,32600,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,33213,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,32790,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32938,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32465,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:26
blockmap-39-80A-907-397-D_WAU8EAF82LN004143-20201024-1519.CSV
;Component:LCM_MLBevo    H07 0022, Coding:
;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW53.rod
;Saturday,24,October,2020,15:19:32:14741
;VCDS Version: Beta 20.9.1 (x64)  Data version: 20200919 DS322.0
;VCID: B032FB8A3AD04ADB57B-80E4
Group,Description,Actual
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,160,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,1,
IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.30, V
IDE06876-MAS01482,Signature light lamp faulty-Hardware version,not installed,
IDE06876-MAS01483,Signature light lamp faulty-Software version,not installed,
IDE06876-MAS12381,Signature light lamp faulty-Software subversion,0F,
IDE06876-ENG14244,Signature light lamp faulty-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,0F 1A AC 52 00,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Watchdog Reset,
IDE08742-MAS01155,Operating time-Control module,21.05, H
IDE08742-MAS03835,Operating time-Position lamps,3.76, H
IDE08742-MAS09325,Operating time-Daytime running lamps,6.39, H
IDE08742-MAS09330,Operating time-Reflector for low beam,0.00, H
IDE08742-MAS09332,Operating time-Turn signal lamps,0.48, H
IDE08742-MAS09333,Operating time-Side marker lamps,3.76, H
IDE08742-MAS09334,Operating time-Parking lamps,0.00, H
IDE09492-MAS01155,Temperatures-Control module,52.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,65.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,33.00, °C
IDE09768-MAS04121,LED channel 1-Voltage,11.95, V
IDE09768-MAS04136,LED channel 1-Current,1000, mA
IDE09768-MAS09022,LED channel 1-PWM value,100.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,2,
IDE09768-MAS09328,LED channel 1-Primary function,Daytime running lamps,
IDE09768-MAS09329,LED channel 1-Secondary function,Daytime running lamps,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,2,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal lamps,
IDE09769-MAS09329,LED channel 2-Secondary function,Turn signal lamps,
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Side marker lamps,
IDE09774-MAS03835,Number of activations-Position lamps,97,
IDE09774-MAS09325,Number of activations-Daytime running lamps,150,
IDE09774-MAS09330,Number of activations-Reflector for low beam,0,
IDE09774-MAS09332,Number of activations-Turn signal lamps,3819,
IDE09774-MAS09333,Number of activations-Side marker lamps,97,
IDE09774-MAS09334,Number of activations-Parking lamps,0,
IDE09775-MAS09336,High temperature operating times for control unit-between 95°C and 105°C,4.15, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,1.91, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,1.82, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 38,
IDE09828-MAS01155,Head lamp variant-Control module,E0 38,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28929,
IDE09916-MAS09565,Data set names-Data set name,A8D5LEDSWSAE,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Position lamps,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lamps,4,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal lamps,0,
IDE11124-MAS12195,Headlamp Range Control Motor-Reference run status,not performed,
IDE11124-MAS12196,Headlamp Range Control Motor-Fault position,not approached,
IDE11124-MAS12199,Headlamp Range Control Motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlamp Range Control Motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11124-MAS12207,Headlamp Range Control Motor-Low beam inclination,-697.50, mm
IDE11125-MAS12195,Adaptive Cornering Lamp Motor-Reference run status,not performed,
IDE11125-MAS12196,Adaptive Cornering Lamp Motor-Fault position,not approached,
IDE11125-MAS12199,Adaptive Cornering Lamp Motor-Adjustment speed,normal,
IDE11125-MAS12206,Adaptive Cornering Lamp Motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11125-MAS12209,Adaptive Cornering Lamp Motor-Swivel angle,Unknown,
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardware version,not installed,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Software version,not installed,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
blockmap-3C-4N0-907-566-H_WAU8EAF82LN004143-20201024-1519.CSV
;Component:MRR_HR H16 0267, Coding:0FDC00
;EV_RearRadarS1DelphAU651,001018,EV_RearRadarS1DelphAU651.rod
;Saturday,24,October,2020,15:19:36:14741
;VCID: BB28DCA6E396B983F29-80EE
IDE00010,Serial number,19022200790177,
IDE00018,Voltage terminal 15,Measuring value not available,
IDE00019,Voltage terminal 30,14.40, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,56, °C
IDE00104-ENG46733,DTC-Reset_1,101,
IDE00104-ENG46734,DTC-Reset_1_data,no_additional_data,
IDE00104-ENG46735,DTC-Reset_2,no_reset,
IDE00104-ENG46736,DTC-Reset_2_data,no_additional_data,
IDE00767,No. of unscheduled ECU resets,00 00,
IDE00925,Yaw rate,0.00, °/s
IDE01352,Temperature unit,°C,
IDE01763,Dimming,Very dark,
IDE02049,Trailer detected,Towing recognition control module not coded,
IDE02057,Dynamic calibration: status,active,
IDE02389,Ambient brightness,60, %
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,37,
IDE03197-MAS02477,Rain/Light Recognition Sensor-Front brightness,355,
IDE03197-ENG09275,Rain/Light Recognition Sensor-Brightness_forwards_Textual,numerical value: no text,
IDE03201-MAS00037,Date of last calibration-Calibration status,Calibration successfully completed,
IDE03201-MAS02356,Date of last calibration-Type of calibration,End of assembly line,
IDE03201-MAS11921,Date of last calibration-Malfunction cause,Correct result,
IDE03505-IDE12792,Personalized settings dimming-Personalization of user account 1,2,
IDE03505-IDE12794,Personalized settings dimming-Personalization of user account 2,2,
IDE03505-IDE12796,Personalized settings dimming-Personalization of user account 3,2,
IDE03505-IDE12798,Personalized settings dimming-Personalization of user account 4,2,
IDE03505-IDE12800,Personalized settings dimming-Personalization of user account 5,2,
IDE03505-IDE12802,Personalized settings dimming-Personalization of user account 6,2,
IDE03505-IDE12804,Personalized settings dimming-Personalization of user account 7,2,
IDE05068,Driver side warning light flashing cycle,OFF,
IDE05069,Frt.pass. side warning light flashing cycle,OFF,
IDE05070,Curve radius,5614.60, m
IDE05071,Lane change assistance button,not installed,
IDE05073,Dimming value of driver side warning light,0, %
IDE05074,Dimming value of frt.pass. side warning light,0, %
IDE05075,Status of driver side warning light,OFF,
IDE05076,Status of frt.pass. side warning light,OFF,
IDE05393,Currently used key,Personalization of user account 1,
IDE07159-MAS01155,Control module switch-off: counter-Control module,Initial value,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,Initial value,
IDE08221-MAS03385,Personalization settings key 1-Lane change assistance,On,
IDE08221-MAS15693,Personalization settings key 1-Exit warning,On,
IDE08221-MAS15695,Personalization settings key 1-Turning assistance,On,
IDE08221-MAS15696,Personalization settings key 1-Rear cross traffic assistant,On,
IDE08221-MAS16112,Personalization settings key 1-Rear cross traffic assistant: autonomous braking,On,
IDE08221-MAS16113,Personalization settings key 1-Pre sense: rear,On,
IDE08222-MAS03385,Personalization settings key 2-Lane change assistance,On,
IDE08222-MAS15693,Personalization settings key 2-Exit warning,On,
IDE08222-MAS15695,Personalization settings key 2-Turning assistance,On,
IDE08222-MAS15696,Personalization settings key 2-Rear cross traffic assistant,On,
IDE08222-MAS16112,Personalization settings key 2-Rear cross traffic assistant: autonomous braking,On,
IDE08222-MAS16113,Personalization settings key 2-Pre sense: rear,On,
IDE08223-MAS03385,Personalization settings key 3-Lane change assistance,On,
IDE08223-MAS15693,Personalization settings key 3-Exit warning,On,
IDE08223-MAS15695,Personalization settings key 3-Turning assistance,On,
IDE08223-MAS15696,Personalization settings key 3-Rear cross traffic assistant,On,
IDE08223-MAS16112,Personalization settings key 3-Rear cross traffic assistant: autonomous braking,On,
IDE08223-MAS16113,Personalization settings key 3-Pre sense: rear,On,
IDE08224-MAS03385,Personalization settings key 4-Lane change assistance,On,
IDE08224-MAS15693,Personalization settings key 4-Exit warning,On,
IDE08224-MAS15695,Personalization settings key 4-Turning assistance,On,
IDE08224-MAS15696,Personalization settings key 4-Rear cross traffic assistant,On,
IDE08224-MAS16112,Personalization settings key 4-Rear cross traffic assistant: autonomous braking,On,
IDE08224-MAS16113,Personalization settings key 4-Pre sense: rear,On,
IDE09780,System condition ctrl. mod.,Terminal 15 on,
IDE09781,Syst. condition lane change assistance,available.,
IDE09782,System condition rear cross traffic assistant,available.,
IDE09784,Functional status of lane change assist.,passive,
IDE09785,Function condition rear cross traffic assistant,passive,
IDE10587,Exit warning: function condition,active,
IDE10588,Exit warning: system condition,Terminal 15 on,
IDE12747,Measured receiving power,not detected,
IDE12747,Measured receiving power,50, %
IDE12792-MAS03385,Personalization of user account 1-Lane change assistance,On,
IDE12792-MAS15693,Personalization of user account 1-Exit warning,On,
IDE12792-MAS15695,Personalization of user account 1-Turning assistance,On,
IDE12792-MAS15696,Personalization of user account 1-Rear cross traffic assistant,On,
IDE12792-MAS16112,Personalization of user account 1-Rear cross traffic assistant: autonomous braking,On,
IDE12792-MAS16113,Personalization of user account 1-Pre sense: rear,On,
IDE12794-MAS03385,Personalization of user account 2-Lane change assistance,On,
IDE12794-MAS15693,Personalization of user account 2-Exit warning,On,
IDE12794-MAS15695,Personalization of user account 2-Turning assistance,On,
IDE12794-MAS15696,Personalization of user account 2-Rear cross traffic assistant,On,
IDE12794-MAS16112,Personalization of user account 2-Rear cross traffic assistant: autonomous braking,On,
IDE12794-MAS16113,Personalization of user account 2-Pre sense: rear,On,
IDE12796-MAS03385,Personalization of user account 3-Lane change assistance,On,
IDE12796-MAS15693,Personalization of user account 3-Exit warning,On,
IDE12796-MAS15695,Personalization of user account 3-Turning assistance,On,
IDE12796-MAS15696,Personalization of user account 3-Rear cross traffic assistant,On,
IDE12796-MAS16112,Personalization of user account 3-Rear cross traffic assistant: autonomous braking,On,
IDE12796-MAS16113,Personalization of user account 3-Pre sense: rear,On,
IDE12798-MAS03385,Personalization of user account 4-Lane change assistance,On,
IDE12798-MAS15693,Personalization of user account 4-Exit warning,On,
IDE12798-MAS15695,Personalization of user account 4-Turning assistance,On,
IDE12798-MAS15696,Personalization of user account 4-Rear cross traffic assistant,On,
IDE12798-MAS16112,Personalization of user account 4-Rear cross traffic assistant: autonomous braking,On,
IDE12798-MAS16113,Personalization of user account 4-Pre sense: rear,On,
IDE12800-MAS03385,Personalization of user account 5-Lane change assistance,On,
IDE12800-MAS15693,Personalization of user account 5-Exit warning,On,
IDE12800-MAS15695,Personalization of user account 5-Turning assistance,On,
IDE12800-MAS15696,Personalization of user account 5-Rear cross traffic assistant,On,
IDE12800-MAS16112,Personalization of user account 5-Rear cross traffic assistant: autonomous braking,On,
IDE12800-MAS16113,Personalization of user account 5-Pre sense: rear,On,
IDE12802-MAS03385,Personalization of user account 6-Lane change assistance,On,
IDE12802-MAS15693,Personalization of user account 6-Exit warning,On,
IDE12802-MAS15695,Personalization of user account 6-Turning assistance,On,
IDE12802-MAS15696,Personalization of user account 6-Rear cross traffic assistant,On,
IDE12802-MAS16112,Personalization of user account 6-Rear cross traffic assistant: autonomous braking,On,
IDE12802-MAS16113,Personalization of user account 6-Pre sense: rear,On,
IDE12804-MAS03385,Personalization of user account 7-Lane change assistance,On,
IDE12804-MAS15693,Personalization of user account 7-Exit warning,On,
IDE12804-MAS15695,Personalization of user account 7-Turning assistance,On,
IDE12804-MAS15696,Personalization of user account 7-Rear cross traffic assistant,On,
IDE12804-MAS16112,Personalization of user account 7-Rear cross traffic assistant: autonomous braking,On,
IDE12804-MAS16113,Personalization of user account 7-Pre sense: rear,On,
IDE13062,Assistance system monitor: version,0F 00,
IDE13096,Rear cross traffic assistant: left warning level,none,
IDE13107,Rear cross traffic assistant: right warning level,none,
IDE13109,Short distance calibration: status,not active,
IDE13109-MAS15813,Short distance calibration: status-Short distance calibration: progress,0, %
IDE13109-MAS16462,Short distance calibration: status-Short distance calibration: completed counter,00 00,
IDE13109-MAS16463,Short distance calibration: status-Short distance calibration: successfully completed counter,00 8D,
IDE13128,Measured angle,-0.03, °
IDE13129,Measured angle: end of line,-0.03, °
IDE13130,Measured angle: customer service,Initial value,
IDE13131,Static angle offset,-0.03, °
IDE13132,Dynamic angle offset,-0.32, °
IDE13133,Measured angle: short distance,Initial value,
IDE13158,Dynamic angle of set in the current terminal 15 cycle,-0.32, °
IDE13187-MAS03385,Personalization settings key 5-Lane change assistance,On,
IDE13187-MAS15693,Personalization settings key 5-Exit warning,On,
IDE13187-MAS15695,Personalization settings key 5-Turning assistance,On,
IDE13187-MAS15696,Personalization settings key 5-Rear cross traffic assistant,On,
IDE13187-MAS16112,Personalization settings key 5-Rear cross traffic assistant: autonomous braking,On,
IDE13187-MAS16113,Personalization settings key 5-Pre sense: rear,On,
IDE13188-MAS03385,Personalization settings key 6-Lane change assistance,On,
IDE13188-MAS15693,Personalization settings key 6-Exit warning,On,
IDE13188-MAS15695,Personalization settings key 6-Turning assistance,On,
IDE13188-MAS15696,Personalization settings key 6-Rear cross traffic assistant,On,
IDE13188-MAS16112,Personalization settings key 6-Rear cross traffic assistant: autonomous braking,On,
IDE13188-MAS16113,Personalization settings key 6-Pre sense: rear,On,
IDE13189-MAS03385,Personalization settings key 7-Lane change assistance,On,
IDE13189-MAS15693,Personalization settings key 7-Exit warning,On,
IDE13189-MAS15695,Personalization settings key 7-Turning assistance,On,
IDE13189-MAS15696,Personalization settings key 7-Rear cross traffic assistant,On,
IDE13189-MAS16112,Personalization settings key 7-Rear cross traffic assistant: autonomous braking,On,
IDE13189-MAS16113,Personalization settings key 7-Pre sense: rear,On,
IDE13872,Manual calibration,Initial value,
IDE13982,Active user account,Personalization of user account 1,
IDE14217-IDE00906,Doppler Position-Object distance,Initial value,
IDE14217-IDE13128,Doppler Position-Measured angle,Initial value,
Elapsed Time: 00:07
blockmap-42-4M1-959-953-D_WAU8EAF82LN004143-20201024-1519.CSV
;Component:TSG FS005 0189, Coding:001DDB00520014C2B009A036
;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHCONT_VW27.rod
;Saturday,24,October,2020,15:19:46:14741
;VCID: BE2ED5B2F084ACABD57-80EA
IDE00310,Outside temperature,25.00, °C
IDE01766-MAS02248,Distance impulses-Signal state,Not available,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.30, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Bus sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,52, %
IDE04539-MAS02229,Mirror memory-Y coordinate,57, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,55, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,40, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,Not operated,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,Not operated,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,Not operated,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,48, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,Not operated,
IDE08205-MAS01453,Closing assistance-Blocking detection,not active,
IDE08205-MAS02103,Closing assistance-Signal from door lock: catch,operated,
IDE08205-MAS05370,Closing assistance-Direction of movement,Not operated,
IDE08205-MAS08613,Closing assistance-Return contact,closed,
IDE08205-MAS08614,Closing assistance-Closing assist motor current,0.00, A
IDE08205-MAS09346,Closing assistance-Door position,closed,
IDE08205-MAS09347,Closing assistance-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,1,
IDE08795,Rear shade button,not installed,
IDE09071-MAS00030,Seat belt positioner-Seat occupied recognition,not active,
IDE09071-MAS02666,Seat belt positioner-Seat belt buckle scan,Open,
IDE09071-MAS05370,Seat belt positioner-Direction of movement,Not available,
IDE09071-MAS08502,Seat belt positioner-Standardized belt feeder,No,
IDE09071-MAS08503,Seat belt positioner-End stop of Hall sensor,not detected,
IDE09071-MAS08504,Seat belt positioner-Position of belt feeder,Not available,
IDE09071-MAS08505,Seat belt positioner-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not active,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,28, °C
IDE12336-MAS03095,Door heating element 2-Function status,in correct range,
IDE12336-MAS04136,Door heating element 2-Current,0.00, A
IDE12336-MAS09022,Door heating element 2-PWM value,0, %
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,Not operated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,Not operated,
IDE12422-IDE04411,Driver side front door control head-Child safety button,Not operated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y direction),Position bottom,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,Not operated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,Not operated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,Not operated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,operated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,Not operated,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,Not operated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,Not operated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,Not operated,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,Not operated,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,Not operated,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,Not operated,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,Not operated,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,Not operated,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6),
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,40,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,0,
IDE14109,Excess temperature shutdown of close assist,not active,
MAS01872,Rear lid remote control lock switch,Not operated,
MAS02099,Switch for inside door handle,Not operated,
MAS02100,Switch for outside door handle,Not operated,
MAS02101,Child safety lock,not active,
MAS06010,Ambient light,Not available,
Elapsed Time: 00:07
blockmap-44-4N0-909-144-E_WAU8EAF82LN004143-20201024-1519.CSV
;Component:EPS_MLBEVO2BS H22 0505, Coding:B4000101010000
;EV_EPSVWBSAU426,010017,EV_EPSVWBSAU426_010.rod
;Saturday,24,October,2020,15:19:56:14741
;VCID: B236F18234DC78CB21F-80E6
IDE00102-IDE00655,Control Module temperature-Temperature of processor circuit board,23.22, °C
IDE00102-IDE04181,Control Module temperature-Rotor temperature,21.90, °C
IDE00102-MAS02955,Control Module temperature-Engine temperature,24.26, °C
IDE00102-MAS04448,Control Module temperature-Output stage temperature,27.53, °C
IDE00609-IDE10203,Communication status of data bus 1-Audi drive select: drive program,Communication,
IDE00609-MAS00772,Communication status of data bus 1-Battery Monitoring Control Module,Communication,
IDE00609-MAS00795,Communication status of data bus 1-Data Bus On Board Diagnostic Interface,Communication,
IDE00609-MAS00796,Communication status of data bus 1-Engine Control Module,Communication,
IDE00609-MAS00802,Communication status of data bus 1-Control module for distance control,Not coded,
IDE00609-MAS00805,Communication status of data bus 1-Lane assistance control module,Communication,
IDE00609-MAS00807,Communication status of data bus 1-Parallel parking assistance control module,Not coded,
IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,Not coded,
IDE00609-MAS00821,Communication status of data bus 1-Central ctrl. unit for comfort system,Communication,
IDE00609-MAS00824,Communication status of data bus 1-Steering column electronic systems control module,Communication,
IDE00609-MAS00830,Communication status of data bus 1-Trailer recognition control module,No communication,
IDE00609-MAS01172,Communication status of data bus 1-Development messages,No communication,
IDE00609-MAS08787,Communication status of data bus 1-Maneuvering assistant,Not coded,
IDE00609-MAS11240,Communication status of data bus 1-ABS Control Module,Communication,
IDE00609-MAS13015,Communication status of data bus 1-Routing assistant with park-steering system,Not coded,
IDE00609-MAS13019,Communication status of data bus 1-Chassis Control,Communication,
IDE00924-MAS02125,Steering angle-Steering wheel angle speed,0, °/s
IDE00924-MAS02126,Steering angle-Steering angle sensor: status,System OK,
IDE00924-MAS02961,Steering angle-Engine angle,242.09, °
IDE00924-MAS02981,Steering angle-Overlay angle,0.00, °
IDE00924-MAS02983,Steering angle-Steering wheel angle,0.40, °
IDE00924-MAS02984,Steering angle-Steering angle speed,-2.77, °/s
IDE00924-MAS13060,Steering angle-Steering pinion angle: offset corrected,-0.18, °
IDE02068-MAS00106,Time stamp-Year,2020, yr
IDE02068-MAS00107,Time stamp-Month,10, m
IDE02068-MAS00108,Time stamp-Day,24, d
IDE02068-MAS00109,Time stamp-Hours,15, H
IDE02068-MAS00110,Time stamp-Minutes,19, min
IDE02068-MAS00111,Time stamp-Seconds,50, s
IDE02068-MAS00711,Time stamp-Odometer reading,122, km
IDE03008-MAS05361,Stop process prevented-Manual steering torque too high,active,
IDE03008-MAS05409,Stop process prevented-Calculated steering angle too large,active,
IDE03008-MAS14902,Stop process prevented-Limp home mode active,active,
IDE03010-MAS05361,Number of prevented stop processes-Manual steering torque too high,0,
IDE03010-MAS05409,Number of prevented stop processes-Calculated steering angle too large,0,
IDE03010-MAS14902,Number of prevented stop processes-Limp home mode active,0,
IDE03011-ENG31516,Number of requested start processes-Frequency_counter_value_Restart,0,
IDE03471-IDE10940,Vehicle configuration-Steering assist. without eng. running,not active,
IDE03471-MAS01172,Vehicle configuration-Development messages,not active,
IDE03471-MAS01891,Vehicle configuration-Lane assist,coded,
IDE03471-MAS02145,Vehicle configuration-ESP ADS coding,Active steering not coded,
IDE03471-MAS02672,Vehicle configuration-Start-stop,Not coded,
IDE03471-MAS03400,Vehicle configuration-Audi drive select,coded,
IDE03471-MAS03504,Vehicle configuration-XCP,not active,
IDE03471-MAS08071,Vehicle configuration-Hybrid drive,coded,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Not coded,
IDE03471-MAS08786,Vehicle configuration-Parallel Parking Assistance,Not coded,
IDE03471-MAS08940,Vehicle configuration-Collision warning,coded,
IDE03471-MAS12072,Vehicle configuration-Active Steering,Not coded,
IDE03471-MAS12200,Vehicle configuration-Steering recommendation,coded,
IDE03471-MAS12217,Vehicle configuration-Constant steering ratio,Not coded,
IDE03471-MAS12218,Vehicle configuration-Variable steering ratio,coded,
IDE03471-MAS12579,Vehicle configuration-Maneuvering assistant,Not coded,
IDE03471-MAS13015,Vehicle configuration-Routing assistant with park-steering system,Not coded,
IDE03471-MAS13016,Vehicle configuration-Parking assistant with cross-parking function,Not coded,
IDE03471-MAS13017,Vehicle configuration-Traffic jam assistant,Not coded,
IDE03471-MAS15107,Vehicle configuration-Drivetrain actuation,Not coded,
IDE03471-MAS15537,Vehicle configuration-Congestion pilot,Not coded,
IDE03471-MAS15637,Vehicle configuration-Dynamic all wheel drive,Not coded,
IDE03471-ENG110582,Vehicle configuration-Activation_update_programming_without_rest_bus_simulation,not active,
IDE03471-ENG55870,Vehicle configuration-Assistenz_System_Monitor_message,not active,
IDE03471-ENG22723,Vehicle configuration-deactivation_characteristic_curves_flash_via_data_set,not active,
IDE03471-ENG29829,Vehicle configuration-Power_class_2,Not coded,
IDE03471-ENG36875,Vehicle configuration-Torsion_Bar_Stiffness,Torsion_Bar_Stiffness_1_active,
IDE03471-ENG110616,Vehicle configuration-Update_programming_without_bus_simulation,not active,
IDE03471-ENG110746,Vehicle configuration-V_limit_kL30_disconnect,18.00, km/h
IDE03471-ENG36895,Vehicle configuration-Variable_steering_ratio_12_2,Not coded,
IDE03471-ENG36675,Vehicle configuration-Variable_steering_ratio_14_6,Not coded,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.45, V
IDE03680-MAS02953,Supply voltages-Battery status,connected,
IDE03680-MAS03838,Supply voltages-Output stage voltage,14.45, V
IDE03680-MAS03839,Supply voltages-GDU status,Driving program,
IDE03681-MAS01853,Wheel speed-Left front,0.00, km/h
IDE03681-MAS01854,Wheel speed-Right front,0.00, km/h
IDE03681-MAS01855,Wheel speed-Left rear,0.00, km/h
IDE03681-MAS01856,Wheel speed-Right rear,0.00, km/h
IDE03682-MAS00371,motor position sensor-Engine RPM,-16, °/s
IDE03682-MAS02282,motor position sensor-Position,-0.65, °
IDE03682-MAS02961,motor position sensor-Engine angle,242.18, °
IDE03682-MAS03083,motor position sensor-Cosine signal,3.31, °
IDE03682-MAS03211,motor position sensor-Sine signal,3.05, °
IDE03682-MAS03840,motor position sensor-Engine position test value,0.84, V
IDE03682-ENG55413,motor position sensor-Resolver_excitation,4.02, V
IDE03723-MAS11513,End stops for steering-End stop left,Adapted,
IDE03723-MAS11514,End stops for steering-End stop right,Adapted,
IDE03723-MAS13021,End stops for steering-Permissible deviation of the calculated offset,OK,
IDE03723-MAS13061,End stops for steering-calculated rack position in right mechanical end-stop,-68.25, mm
IDE03723-MAS13062,End stops for steering-calculated rack position in right mechanical end-stop,67.77, mm
IDE03723-MAS13063,End stops for steering-calculated engine angle in the right mechanical end-stop,160.86, °
IDE03723-MAS13064,End stops for steering-calculated engine angle in the left mechanical end-stop,163.96, °
IDE03723-MAS15438,End stops for steering-LWI fine synchronization,will be performed.,
IDE03724-MAS02998,Straight line running-Angle value offset,1.14, °
IDE03724-MAS03528,Straight line running-Long term adaptation value,1.14, °
IDE03724-MAS03529,Straight line running-Short term adaptation value,0.00, °
IDE03725-IDE09693,Steering Assistance-Charisma driving program: system status,available.,
IDE03725-MAS02974,Steering Assistance-Target force,274, N
IDE03725-MAS03002,Steering Assistance-Driving program,Program 2,
IDE03726-MAS02974,Parallel Parking Assistance-Target force,0, N
IDE03726-MAS05631,Parallel Parking Assistance-System status,0,
IDE03726-MAS12323,Parallel Parking Assistance-Steering wheel angle control: P-term,0.00, °/s
IDE03726-MAS12324,Parallel Parking Assistance-Steering wheel angle control: I-term,0.00, °/s
IDE03726-MAS12326,Parallel Parking Assistance-Park. steer. funct.: reason for abort,0,
IDE03734-MAS02965,Support power-Performance percentage,100.00, %
IDE03734-MAS12809,Support power-Power reduction factor: low voltage,100.00, %
IDE03734-MAS12810,Support power-Power reduction factor: temperature,100.00, %
IDE03735-MAS02961,Steering torque-Engine angle,242.12, °
IDE03735-MAS03841,Steering torque-Engine steering torque: limited required torque,0.00, Nm
IDE03735-MAS03842,Steering torque-Engine steering torque: setpoint,0.02, Nm
IDE03735-MAS04735,Steering torque-Current engine torques (ACTUAL),0.00, Nm
IDE04561-MAS00370,Switch-on and shut-off conditions-Vehicle speed,0.00, km/h
IDE04561-MAS00371,Switch-on and shut-off conditions-Engine RPM,756.00, /min
IDE04561-MAS03680,Switch-on and shut-off conditions-Terminal 15 status measured,On,
IDE04561-MAS06982,Switch-on and shut-off conditions-Terminal 15 status signal,On,
IDE04561-MAS09828,Switch-on and shut-off conditions-Status of drive readiness hybrid,Drive readiness,
IDE04562-MAS02976,Steering torque sensor-Sensor 1 supply,4.99, V
IDE04562-MAS02978,Steering torque sensor-Steering torque sensor 1,0.19, Nm
IDE04562-MAS02979,Steering torque sensor-Steering torque sensor 2,0.19, Nm
IDE04562-MAS03791,Steering torque sensor-Actual steering torque value,0.19, Nm
IDE04562-MAS03844,Steering torque sensor-Engine steering torque sensor: model value,-0.74, Nm
IDE04562-MAS03845,Steering torque sensor-Engine steering torque sensor: average value,0.19, Nm
IDE04562-ENG50779,Steering torque sensor-Power_Supply_DME2_OV_state,System OK,
IDE04562-ENG50780,Steering torque sensor-Power_Supply_DME2_UV_state,System OK,
IDE05963-MAS09952,ASSY part number-Part Number,-----------,
IDE05963-MAS11961,ASSY part number-Serial number,-----------,
IDE05963-ENG36854,ASSY part number-Steering_generation_status,--------,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Manual steering torque too high,
IDE06307,Stop prevention history data,Limp home mode active,
IDE06307,Stop prevention history data,Calculated steering angle too large,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Manual steering torque too high,
IDE11509-MAS03401,Cutoff 1-Parameter 1,FF FF,
IDE11509-MAS03402,Cutoff 1-Parameter 2,FF FF,
IDE11509-MAS03403,Cutoff 1-Parameter 3,FF FF,
IDE11509-MAS03404,Cutoff 1-Parameter 4,FF FF,
IDE11509-MAS03405,Cutoff 1-Parameter 5,FF FF,
IDE11509-MAS03406,Cutoff 1-Parameter 6,FF FF,
IDE11509-MAS03407,Cutoff 1-Parameter 7,FF FF,
IDE11509-MAS03408,Cutoff 1-Parameter 8,FF FF,
IDE11509-MAS03409,Cutoff 1-Parameter 9,FF FF,
IDE11509-MAS03410,Cutoff 1-Parameter 10,FF,
IDE11509-MAS03411,Cutoff 1-Parameter 11,FF,
IDE11510-MAS03401,Cutoff 2-Parameter 1,FF FF,
IDE11510-MAS03402,Cutoff 2-Parameter 2,FF FF,
IDE11510-MAS03403,Cutoff 2-Parameter 3,FF FF,
IDE11510-MAS03404,Cutoff 2-Parameter 4,FF FF,
IDE11510-MAS03405,Cutoff 2-Parameter 5,FF FF,
IDE11510-MAS03406,Cutoff 2-Parameter 6,FF FF,
IDE11510-MAS03407,Cutoff 2-Parameter 7,FF FF,
IDE11510-MAS03408,Cutoff 2-Parameter 8,FF FF,
IDE11510-MAS03409,Cutoff 2-Parameter 9,FF FF,
IDE11510-MAS03410,Cutoff 2-Parameter 10,FF,
IDE11510-MAS03411,Cutoff 2-Parameter 11,FF,
IDE11511-MAS03401,Cutoff 3-Parameter 1,FF FF,
IDE11511-MAS03402,Cutoff 3-Parameter 2,FF FF,
IDE11511-MAS03403,Cutoff 3-Parameter 3,FF FF,
IDE11511-MAS03404,Cutoff 3-Parameter 4,FF FF,
IDE11511-MAS03405,Cutoff 3-Parameter 5,FF FF,
IDE11511-MAS03406,Cutoff 3-Parameter 6,FF FF,
IDE11511-MAS03407,Cutoff 3-Parameter 7,FF FF,
IDE11511-MAS03408,Cutoff 3-Parameter 8,FF FF,
IDE11511-MAS03409,Cutoff 3-Parameter 9,FF FF,
IDE11511-MAS03410,Cutoff 3-Parameter 10,FF,
IDE11511-MAS03411,Cutoff 3-Parameter 11,FF,
IDE11887-MAS00976,Mechanical load: status-Counter,7C AA,
IDE11887-MAS13728,Mechanical load: status-Resetting the load counter: status,00,
IDE11887-MAS16824,Mechanical load: status-Load counter end stops,00 00,
IDE11887-MAS16825,Mechanical load: status-Aggregate load counter,00 00 00 65,
IDE13384-MAS16374,Driving assistant steering requisition-Congestion assistant status,OFF,
IDE13384-MAS16375,Driving assistant steering requisition-Congestion assistant steering rack position,0.00, mm
IDE13384-MAS16378,Driving assistant steering requisition-Power steering congestion assistant status,Deactivated,
IDE13384-MAS16403,Driving assistant steering requisition-Release congestion pilot,No,
IDE13384-MAS16404,Driving assistant steering requisition-Power steering: control variable,0, %
IDE13384-MAS16405,Driving assistant steering requisition-Power steering: control variable sign,Positive,
IDE13384-ENG36700,Driving assistant steering requisition-BVS_suppression,00,
IDE13389-IDE00490,Driving assistant torque-Status directional stabilization assistance,operational,
IDE13389-MAS16408,Driving assistant torque-Emergency steer assistant status,operational,
IDE13389-MAS16409,Driving assistant torque-Power steering lane assist status,operational,
IDE13389-ENG55838,Driving assistant torque-DRS_state,operational,
IDE13389-ENG36721,Driving assistant torque-EPA_state_DSR,operational,
IDE13389-ENG36723,Driving assistant torque-EPS_state_AWA,operational,
IDE13413-ENG36722,Steering stroke-EPS_end_stop_state,Expansion,
IDE13413-ENG36727,Steering stroke-FA_levelVAL,7F,
IDE13413-ENG36728,Steering stroke-FA_levelVAR 2,7F,
IDE13413-ENG36828,Steering stroke-NR_controller_state,Unknown (0),
IDE13414-ENG55810,calculated steering angle: synchronization-BLW_Synchronising_State,fine_Synchronising,
IDE13414-ENG36693,calculated steering angle: synchronization-BLW_Synchronising_State_error,No malfunction,
IDE13414-ENG36694,calculated steering angle: synchronization-BLW_Synchronising_State_Init,Default,
IDE13415-ENG36852,Rack position-Steering_gear_rack_position_sign,Positive,
IDE13415-ENG46649,Rack position-Steering_gear_rack_position_value,0.00, mm
IDE13415-ENG56587,Rack position-Valid_bit_Steering_gear_rack_position,valid value,
IDE13851-ENG36840,Software bypass-SFS_Switch_State,ARS_on,
IDE13851-ENG36850,Software bypass-Software_module_state,ARS_active,
Elapsed Time: 00:16
blockmap-46-4N0-907-064-DG_WAU8EAF82LN004143-20201024-1520.CSV
;Component:BCM2 MLBevo H15 0183, Coding:013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0101010011
;EV_BCM2CONTIAU651,010009,EV_BCM2CONTIAU651_010_VW53.rod
;Saturday,24,October,2020,15:20:16:14741
;VCID: F7A000969F3E5DE3D61-80A2
IDE00027-MAS04423,Status of brake signals-Automatic braking signal via CAN,active,
IDE00027-MAS04424,Status of brake signals-Driver brakes signal via CAN,active,
IDE00027-MAS06469,Status of brake signals-Brake light signal,active,
IDE00027-MAS06470,Status of brake signals-Brake light signal via CAN,active,
IDE00027-MAS06471,Status of brake signals-Request emergency brake display,OFF,
IDE00027-MAS15241,Status of brake signals-Brake light signal from brake booster control module,Not available,
IDE00096-MAS00364,Selector lever position-Shift lever / selector lever position,Selector lever in position P,
IDE00096-MAS06480,Selector lever position-Transmission park selector switch,not coded/not installed,
IDE00306-MAS02227,Fuel Level Sensor 1-Quality,10,
IDE00306-MAS06614,Fuel Level Sensor 1-Variant,Two-wire sensor,
IDE00306-MAS06615,Fuel Level Sensor 1-Soiling resistance,not coded/not installed,
IDE00306-MAS06621,Fuel Level Sensor 1-Raw value 1,06 C0,
IDE00306-MAS06622,Fuel Level Sensor 1-Raw value 2,not coded/not installed,
IDE00306-MAS06623,Fuel Level Sensor 1-Sensor including soiling resistance,not coded/not installed,
IDE00306-MAS06624,Fuel Level Sensor 1-Sensor without soiling resistance,200,
IDE00306-MAS06643,Fuel Level Sensor 1-Resistance 1: measurable value,200,
IDE00306-MAS06644,Fuel Level Sensor 1-Resistance 2: measurable value,not coded/not installed,
IDE00307-MAS02227,Fuel Level Sensor 2-Quality,10,
IDE00307-MAS06614,Fuel Level Sensor 2-Variant,Two-wire sensor,
IDE00307-MAS06615,Fuel Level Sensor 2-Soiling resistance,not coded/not installed,
IDE00307-MAS06621,Fuel Level Sensor 2-Raw value 1,07 98,
IDE00307-MAS06622,Fuel Level Sensor 2-Raw value 2,not coded/not installed,
IDE00307-MAS06623,Fuel Level Sensor 2-Sensor including soiling resistance,not coded/not installed,
IDE00307-MAS06624,Fuel Level Sensor 2-Sensor without soiling resistance,256,
IDE00307-MAS06643,Fuel Level Sensor 2-Resistance 1: measurable value,256,
IDE00307-MAS06644,Fuel Level Sensor 2-Resistance 2: measurable value,not coded/not installed,
IDE00308-MAS02227,Fuel Level Sensor 3-Quality,numerical value: no text,
IDE00308-MAS06614,Fuel Level Sensor 3-Variant,not coded/not installed,
IDE00308-MAS06615,Fuel Level Sensor 3-Soiling resistance,not coded/not installed,
IDE00308-MAS06621,Fuel Level Sensor 3-Raw value 1,not coded/not installed,
IDE00308-MAS06622,Fuel Level Sensor 3-Raw value 2,not coded/not installed,
IDE00308-MAS06623,Fuel Level Sensor 3-Sensor including soiling resistance,not coded/not installed,
IDE00308-MAS06624,Fuel Level Sensor 3-Sensor without soiling resistance,not coded/not installed,
IDE00308-MAS06643,Fuel Level Sensor 3-Resistance 1: measurable value,not coded/not installed,
IDE00308-MAS06644,Fuel Level Sensor 3-Resistance 2: measurable value,not coded/not installed,
IDE00309-MAS02227,Fuel Level Sensor 4-Quality,10,
IDE00309-MAS06614,Fuel Level Sensor 4-Variant,Two-wire sensor,
IDE00309-MAS06615,Fuel Level Sensor 4-Soiling resistance,not coded/not installed,
IDE00309-MAS06621,Fuel Level Sensor 4-Raw value 1,07 B3,
IDE00309-MAS06622,Fuel Level Sensor 4-Raw value 2,not coded/not installed,
IDE00309-MAS06623,Fuel Level Sensor 4-Sensor including soiling resistance,not coded/not installed,
IDE00309-MAS06624,Fuel Level Sensor 4-Sensor without soiling resistance,264,
IDE00309-MAS06643,Fuel Level Sensor 4-Resistance 1: measurable value,264,
IDE00309-MAS06644,Fuel Level Sensor 4-Resistance 2: measurable value,not coded/not installed,
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,3,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,OFF,
IDE01464-MAS06528,Rear window defogger-Release status,No enabling,
IDE01464-MAS06996,Rear window defogger-Validity of filtered outside temperature,valid,
IDE01464-MAS06997,Rear window defogger-Outside temperature: filtered,23.0, °C
IDE01464-MAS09460,Rear window defogger-Release status: convert. top ctrl. mod.,Not available,
IDE01464-MAS13453,Rear window defogger-Load requirement of 12 V energy management,no request,
IDE01537-MAS01581,Front windshield heater-Power consumption,not coded/not installed,
IDE01537-MAS01737,Front windshield heater-Diagnosis,numerical value: no text,
IDE01537-MAS04737,Front windshield heater-Indicator lamp,not coded/not installed,
IDE01537-MAS05030,Front windshield heater-Resistance,not coded/not installed,
IDE01537-MAS05851,Front windshield heater-Current power consumption,not coded/not installed,
IDE01537-MAS06535,Front windshield heater-Resistance: lower limit value,not coded/not installed,
IDE01537-MAS06536,Front windshield heater-Resistance: upper limit value,not coded/not installed,
IDE01537-MAS06537,Front windshield heater-Power consumption: target value,not coded/not installed,
IDE01537-MAS06726,Front windshield heater-Hardware / software version,not coded/not installed,
IDE01537-MAS06732,Front windshield heater-Status local activity,not coded/not installed,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,For,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,For,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02711-MAS01580,Rear wiper-Activation,not coded/not installed,
IDE02711-MAS07731,Rear wiper-No. of wisher cycles,not coded/not installed,
IDE02711-MAS07732,Rear wiper-Number of recognized blockings,not coded/not installed,
IDE02711-MAS07733,Rear wiper-Requirements rear window wiper,not coded/not installed,
IDE02711-MAS07939,Rear wiper-Rear window wiper motor diagnostic,not coded/not installed,
IDE02711-MAS07940,Rear wiper-Contact switch for rear window wiper end shelf,not coded/not installed,
IDE02711-MAS07965,Rear wiper-Contact switch for rear window wiper end shelf diagnostic,not coded/not installed,
IDE03008-MAS09566,Stop process prevented-Key not in vehicle,not active,
IDE03010-MAS09566,Number of prevented stop processes-Key not in vehicle,0,
IDE03527-MAS12075,CAN signals-Keyless entry and start authorization: driver info,0,
IDE03659-MAS03834,Roller test bench mode-Emergency signal flashing,not active,
IDE03659-MAS06320,Roller test bench mode-Status rolling mode,not active,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.455, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.427, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.357, V
IDE04254-MAS00215,Play protection for central locking-Fuel filler lid,not active,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking system,not active,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,0.7, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,-7.6, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,numerical value: no text,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.0, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.0, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,numerical value: no text,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS00976,DWA History data for alarm triggering-Counter,4,
IDE05828-MAS02545,DWA History data for alarm triggering-Last,Activation by external system,
IDE05828-MAS02546,DWA History data for alarm triggering-Second to last,Activation by external system,
IDE05828-MAS02547,DWA History data for alarm triggering-Third to last,Activation by external system,
IDE05828-MAS02548,DWA History data for alarm triggering-Fourth to last,Activation by external system,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,1,
IDE06307,Stop prevention history data,Key not in vehicle,
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded/not installed,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS04968,Vehicle positioning system-Vehicle positioning alarm,not coded/not installed,
IDE06926-MAS00106,History memory: reset counter-Year,2000,
IDE06926-MAS00107,History memory: reset counter-Month,0,
IDE06926-MAS00108,History memory: reset counter-Day,0,
IDE06926-MAS00109,History memory: reset counter-Hours,0,
IDE06926-MAS00110,History memory: reset counter-Minutes,0,
IDE06926-MAS00111,History memory: reset counter-Seconds,0,
IDE06926,History memory: reset counter,Watchdog Reset,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,not coded/not installed,
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,not coded/not installed,
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,not coded/not installed,
IDE07293-IDE00500,History data of panic alarm-Hour,5,
IDE07293-IDE00501,History data of panic alarm-Minute,18,
IDE07293-MAS00107,History data of panic alarm-Month,7,
IDE07293-MAS00108,History data of panic alarm-Day,29,
IDE07293-MAS04478,History data of panic alarm-Cause for alarm activation,Panic button,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,closed,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08176,History data doors,11100001 ,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,closed,
IDE08177-MAS09895,Central locking system-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking system-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,unlocked,
IDE08177-MAS16237,Central locking system-Outside door handles,Initialization,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,Not operated,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,OFF,
IDE08180-IDE00500,History data central locking: last event-Hour,1,
IDE08180-IDE00501,History data central locking: last event-Minute,37,
IDE08180-MAS00106,History data central locking: last event-Year,not known,
IDE08180-MAS00107,History data central locking: last event-Month,10,
IDE08180-MAS00108,History data central locking: last event-Day,22,
IDE08180-MAS00111,History data central locking: last event-Seconds,30,
IDE08180-MAS01551,History data central locking: last event-Key number,2,
IDE08180-MAS06441,History data central locking: last event-Control-section / cause,Remote control,
IDE08181-IDE00500,History data central locking: second-to-last event-Hour,14,
IDE08181-IDE00501,History data central locking: second-to-last event-Minute,31,
IDE08181-MAS00106,History data central locking: second-to-last event-Year,not known,
IDE08181-MAS00107,History data central locking: second-to-last event-Month,10,
IDE08181-MAS00108,History data central locking: second-to-last event-Day,21,
IDE08181-MAS00111,History data central locking: second-to-last event-Seconds,0,
IDE08181-MAS01551,History data central locking: second-to-last event-Key number,2,
IDE08181-MAS06441,History data central locking: second-to-last event-Control-section / cause,Remote control,
IDE08182-IDE00500,History data central locking: third-to-last event-Hour,14,
IDE08182-IDE00501,History data central locking: third-to-last event-Minute,29,
IDE08182-MAS00106,History data central locking: third-to-last event-Year,not known,
IDE08182-MAS00107,History data central locking: third-to-last event-Month,10,
IDE08182-MAS00108,History data central locking: third-to-last event-Day,21,
IDE08182-MAS00111,History data central locking: third-to-last event-Seconds,45,
IDE08182-MAS01551,History data central locking: third-to-last event-Key number,2,
IDE08182-MAS06441,History data central locking: third-to-last event-Control-section / cause,Remote control,
IDE08183-IDE00500,History data central locking: fourth-to-last event-Hour,14,
IDE08183-IDE00501,History data central locking: fourth-to-last event-Minute,29,
IDE08183-MAS00106,History data central locking: fourth-to-last event-Year,not known,
IDE08183-MAS00107,History data central locking: fourth-to-last event-Month,10,
IDE08183-MAS00108,History data central locking: fourth-to-last event-Day,21,
IDE08183-MAS00111,History data central locking: fourth-to-last event-Seconds,0,
IDE08183-MAS01551,History data central locking: fourth-to-last event-Key number,2,
IDE08183-MAS06441,History data central locking: fourth-to-last event-Control-section / cause,Remote control,
IDE08184-IDE00500,History data central locking: fifth-to-last event-Hour,14,
IDE08184-IDE00501,History data central locking: fifth-to-last event-Minute,29,
IDE08184-MAS00106,History data central locking: fifth-to-last event-Year,not known,
IDE08184-MAS00107,History data central locking: fifth-to-last event-Month,10,
IDE08184-MAS00108,History data central locking: fifth-to-last event-Day,21,
IDE08184-MAS00111,History data central locking: fifth-to-last event-Seconds,0,
IDE08184-MAS01551,History data central locking: fifth-to-last event-Key number,2,
IDE08184-MAS06441,History data central locking: fifth-to-last event-Control-section / cause,Remote control,
IDE08187-MAS02362,Request direction flashing-Flashing: right,not active,
IDE08187-MAS02363,Request direction flashing-Flashing: left,not active,
IDE08189-MAS04309,Malfunction status flasher-Turn signal front left,No malfunction,
IDE08189-MAS04310,Malfunction status flasher-Turn signal front right,No malfunction,
IDE08189-MAS04311,Malfunction status flasher-Left rear turn signal,No malfunction,
IDE08189-MAS04312,Malfunction status flasher-Turn signal rear right,No malfunction,
IDE08190-MAS01281,Request exterior illumination-Back-up lamp,OFF,
IDE08190-MAS03836,Request exterior illumination-Rear fog lamp,OFF,
IDE08190-MAS06466,Request exterior illumination-Parking light left,OFF,
IDE08190-MAS06467,Request exterior illumination-Parking light right,OFF,
IDE08190-MAS06468,Request exterior illumination-Tail lamp,OFF,
IDE08194-MAS06982,Signals vehicle electrical system control module-Terminal 15 status signal,On,
IDE08194-MAS07716,Signals vehicle electrical system control module-Last status: terminal 15,On,
IDE08195-MAS06483,Access/Start Authorization Button-Access/start authorization button: contact 1,Not operated,
IDE08195-MAS06484,Access/Start Authorization Button-Access/start authorization button: contact 2,Not operated,
IDE08195-MAS06485,Access/Start Authorization Button-Access/start authorization button: contact 3,Not operated,
IDE08195-MAS06486,Access/Start Authorization Button-Access/start authorization button: contact 4,Not operated,
IDE08196-IDE12848,Terminal activation-Remote start relay or preconditioning,not active,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,active,
IDE08196-MAS07383,Terminal activation-Terminal 15 on CAN,active,
IDE08196-MAS07386,Terminal activation-Terminal 50 on CAN,not active,
IDE08196-MAS07715,Terminal activation-Activation: terminal 15,active,
IDE08196-MAS07716,Terminal activation-Last status: terminal 15,active,
IDE08196-MAS07719,Terminal activation-Terminal 50 status,not active,
IDE08197-IDE02666,Alarm horn for anti-theft warning system-Convertible top status,not coded/not installed,
IDE08197-MAS06495,Alarm horn for anti-theft warning system-Engine hood contact switch,closed,
IDE08197-MAS06507,Alarm horn for anti-theft warning system-Trailer disconnected,not coded/not installed,
IDE08197-MAS07350,Alarm horn for anti-theft warning system-Left headlamp,not coded/not installed,
IDE08197-MAS07351,Alarm horn for anti-theft warning system-Right headlamp,not coded/not installed,
IDE08197-MAS11121,Alarm horn for anti-theft warning system-Glass breakage sensor or glove box,not coded/not installed,
IDE08199-IDE00500,History data anti-theft protection: last event-Hour,8,
IDE08199-IDE00501,History data anti-theft protection: last event-Minute,43,
IDE08199-MAS00106,History data anti-theft protection: last event-Year,2019,
IDE08199-MAS00107,History data anti-theft protection: last event-Month,9,
IDE08199-MAS00108,History data anti-theft protection: last event-Day,24,
IDE08199-MAS04478,History data anti-theft protection: last event-Cause for alarm activation,Interior Monitoring,
IDE08200-IDE00500,History data anti-theft protection: second-to-last event-Hour,0,
IDE08200-IDE00501,History data anti-theft protection: second-to-last event-Minute,0,
IDE08200-MAS00106,History data anti-theft protection: second-to-last event-Year,2000,
IDE08200-MAS00107,History data anti-theft protection: second-to-last event-Month,0,
IDE08200-MAS00108,History data anti-theft protection: second-to-last event-Day,0,
IDE08200-MAS04478,History data anti-theft protection: second-to-last event-Cause for alarm activation,No alarm,
IDE08201-IDE00500,History data anti-theft protection: third-to-last event-Hour,0,
IDE08201-IDE00501,History data anti-theft protection: third-to-last event-Minute,0,
IDE08201-MAS00106,History data anti-theft protection: third-to-last event-Year,2000,
IDE08201-MAS00107,History data anti-theft protection: third-to-last event-Month,0,
IDE08201-MAS00108,History data anti-theft protection: third-to-last event-Day,0,
IDE08201-MAS04478,History data anti-theft protection: third-to-last event-Cause for alarm activation,No alarm,
IDE08202-IDE00500,History data anti-theft protection: fourth-to-last event-Hour,0,
IDE08202-IDE00501,History data anti-theft protection: fourth-to-last event-Minute,0,
IDE08202-MAS00106,History data anti-theft protection: fourth-to-last event-Year,2000,
IDE08202-MAS00107,History data anti-theft protection: fourth-to-last event-Month,0,
IDE08202-MAS00108,History data anti-theft protection: fourth-to-last event-Day,0,
IDE08202-MAS04478,History data anti-theft protection: fourth-to-last event-Cause for alarm activation,No alarm,
IDE08203-MAS05851,Rear shades-Current power consumption,0.00, A
IDE08203-MAS06258,Rear shades-Left child safety,not active,
IDE08203-MAS06259,Rear shades-Right child safety,not active,
IDE08203-MAS06513,Rear shades-Driver side rear window shade button,Not operated,
IDE08203-MAS06514,Rear shades-assenger side rear window shade button,Not operated,
IDE08203-MAS06515,Rear shades-Rear shade button,NOT-DEFINED,
IDE08203-MAS06516,Rear shades-Rear window shade status,retracted,
IDE08203-MAS06517,Rear shades-Rear spoiler counter,0,
IDE08204-MAS06520,Rear Lid Closed Sensor-Rear lid -closed- sensor 1,not coded/not installed,
IDE08204-MAS06521,Rear Lid Closed Sensor-Rear lid -closed- sensor 2,not coded/not installed,
IDE08204-MAS06522,Rear Lid Closed Sensor-Rear lid: Status,not coded/not installed,
IDE08206-MAS06714,Local data bus: bus level malfunction-Local data bus: malfunction status,No malfunction,
IDE08206-MAS06715,Local data bus: bus level malfunction-Local data bus 2: malfunction status,No malfunction,
IDE08206-MAS06716,Local data bus: bus level malfunction-Local data bus 3: malfunction status,No malfunction,
IDE08206-MAS06717,Local data bus: bus level malfunction-Local data bus 4: malfunction status,not coded/not installed,
IDE08206-MAS06718,Local data bus: bus level malfunction-Local data bus 5: malfunction status,not coded/not installed,
IDE08206-MAS06719,Local data bus: bus level malfunction-Local data bus 6: malfunction status,not coded/not installed,
IDE08206-MAS06720,Local data bus: bus level malfunction-Local data bus: malfunction counter,0,
IDE08206-MAS06721,Local data bus: bus level malfunction-Local data bus 2: malfunction counter,0,
IDE08206-MAS06722,Local data bus: bus level malfunction-Local data bus 3: malfunction counter,0,
IDE08206-MAS06723,Local data bus: bus level malfunction-Local data bus 4: malfunction counter,not coded/not installed,
IDE08206-MAS06724,Local data bus: bus level malfunction-Local data bus 5: malfunction counter,not coded/not installed,
IDE08206-MAS06725,Local data bus: bus level malfunction-Local data bus 6: malfunction counter,not coded/not installed,
IDE08208-MAS06528,Rear lid opener control module-Release status,No enabling,
IDE08208-MAS06529,Rear lid opener control module-Trailer recognition,no approach,
IDE08208-MAS06532,Rear lid opener control module-Foot gestic recognition,No foot gestic,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,No,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,No,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,00000000 ,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,00000000 ,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,00000000 ,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,00000000 ,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,00000000 ,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,00000000 ,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,00000000 ,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,20 74 66 53,
IDE08240,Transponder ID Key 2,20 74 66 6C,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,02 57 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,1C E3 C4 F0,
IDE08343,Immobilizer Challenge,C7 FA 13 B2,
IDE08479,Signal type,no flashing function active,
IDE08631,Received Signal Strength Indicator (RSSI),123,
IDE09133-MAS01580,Output 1 for exterior lighting-Activation,100.0, %
IDE09133-MAS05851,Output 1 for exterior lighting-Current power consumption,142, mA
IDE09133-MAS08347,Output 1 for exterior lighting-Assigned event code,B133600,
IDE09133-MAS08349,Output 1 for exterior lighting-Type of connected lamp,LED,
IDE09134-MAS01580,Output 2 for exterior lighting-Activation,0.0, %
IDE09134-MAS05851,Output 2 for exterior lighting-Current power consumption,0, mA
IDE09134-MAS08347,Output 2 for exterior lighting-Assigned event code,B12CB00,
IDE09134-MAS08349,Output 2 for exterior lighting-Type of connected lamp,LED,
IDE09135-MAS01580,Output 3 for exterior lighting-Activation,100.0, %
IDE09135-MAS05851,Output 3 for exterior lighting-Current power consumption,126, mA
IDE09135-MAS08347,Output 3 for exterior lighting-Assigned event code,B143400,
IDE09135-MAS08349,Output 3 for exterior lighting-Type of connected lamp,LED,
IDE09136-MAS01580,Output 4 for exterior lighting-Activation,100.0, %
IDE09136-MAS05851,Output 4 for exterior lighting-Current power consumption,134, mA
IDE09136-MAS08347,Output 4 for exterior lighting-Assigned event code,B143600,
IDE09136-MAS08349,Output 4 for exterior lighting-Type of connected lamp,LED,
IDE09137-MAS01580,Output 5 for exterior lighting-Activation,0.0, %
IDE09137-MAS05851,Output 5 for exterior lighting-Current power consumption,0, mA
IDE09137-MAS08347,Output 5 for exterior lighting-Assigned event code,B12BF00,
IDE09137-MAS08349,Output 5 for exterior lighting-Type of connected lamp,LED,
IDE09138-MAS01580,Output 6 for exterior lighting-Activation,0.0, %
IDE09138-MAS05851,Output 6 for exterior lighting-Current power consumption,0, mA
IDE09138-MAS08347,Output 6 for exterior lighting-Assigned event code,B12C100,
IDE09138-MAS08349,Output 6 for exterior lighting-Type of connected lamp,LED,
IDE09139-MAS01580,Output 7 for exterior lighting-Activation,Output not used,
IDE09139-MAS05851,Output 7 for exterior lighting-Current power consumption,Output not used,
IDE09139-MAS08347,Output 7 for exterior lighting-Assigned event code,Unknown (0),
IDE09139-MAS08349,Output 7 for exterior lighting-Type of connected lamp,Output not used,
IDE09140-MAS01580,Output 8 for exterior lighting-Activation,0.0, %
IDE09140-MAS05851,Output 8 for exterior lighting-Current power consumption,0, mA
IDE09140-MAS08347,Output 8 for exterior lighting-Assigned event code,B12C700,
IDE09140-MAS08349,Output 8 for exterior lighting-Type of connected lamp,LED,
IDE09141-MAS01580,Output 9 for exterior lighting-Activation,0.0, %
IDE09141-MAS05851,Output 9 for exterior lighting-Current power consumption,0, mA
IDE09141-MAS08347,Output 9 for exterior lighting-Assigned event code,B12CC00,
IDE09141-MAS08349,Output 9 for exterior lighting-Type of connected lamp,LED,
IDE09142-MAS01580,Output 10 for exterior lighting-Activation,100.0, %
IDE09142-MAS05851,Output 10 for exterior lighting-Current power consumption,129, mA
IDE09142-MAS08347,Output 10 for exterior lighting-Assigned event code,B143500,
IDE09142-MAS08349,Output 10 for exterior lighting-Type of connected lamp,LED,
IDE09143-MAS01580,Output 11 for exterior lighting-Activation,0.0, %
IDE09143-MAS05851,Output 11 for exterior lighting-Current power consumption,0, mA
IDE09143-MAS08347,Output 11 for exterior lighting-Assigned event code,B12C000,
IDE09143-MAS08349,Output 11 for exterior lighting-Type of connected lamp,LED,
IDE09144-MAS01580,Output 12 for exterior lighting-Activation,100.0, %
IDE09144-MAS05851,Output 12 for exterior lighting-Current power consumption,120, mA
IDE09144-MAS08347,Output 12 for exterior lighting-Assigned event code,B133500,
IDE09144-MAS08349,Output 12 for exterior lighting-Type of connected lamp,LED,
IDE09145-MAS01580,Output 13 for exterior lighting-Activation,0.0, %
IDE09145-MAS05851,Output 13 for exterior lighting-Current power consumption,0, mA
IDE09145-MAS08347,Output 13 for exterior lighting-Assigned event code,B121500,
IDE09145-MAS08349,Output 13 for exterior lighting-Type of connected lamp,LED,
IDE09146-MAS01580,Output 14 for exterior lighting-Activation,100.0, %
IDE09146-MAS05851,Output 14 for exterior lighting-Current power consumption,137, mA
IDE09146-MAS08347,Output 14 for exterior lighting-Assigned event code,B143700,
IDE09146-MAS08349,Output 14 for exterior lighting-Type of connected lamp,LED,
IDE09147-MAS01580,Output 15 for exterior lighting-Activation,0.0, %
IDE09147-MAS05851,Output 15 for exterior lighting-Current power consumption,0, mA
IDE09147-MAS08347,Output 15 for exterior lighting-Assigned event code,B12BE00,
IDE09147-MAS08349,Output 15 for exterior lighting-Type of connected lamp,LED,
IDE09148-MAS01580,Output 16 for exterior lighting-Activation,0.0, %
IDE09148-MAS05851,Output 16 for exterior lighting-Current power consumption,0, mA
IDE09148-MAS08347,Output 16 for exterior lighting-Assigned event code,B12C800,
IDE09148-MAS08349,Output 16 for exterior lighting-Type of connected lamp,LED,
IDE09149-MAS01580,Output 17 for exterior lighting-Activation,100.0, %
IDE09149-MAS05851,Output 17 for exterior lighting-Current power consumption,155, mA
IDE09149-MAS08347,Output 17 for exterior lighting-Assigned event code,B12C600,
IDE09149-MAS08349,Output 17 for exterior lighting-Type of connected lamp,LED,
IDE09150-MAS01580,Output 18 for exterior lighting-Activation,100.0, %
IDE09150-MAS05851,Output 18 for exterior lighting-Current power consumption,215, mA
IDE09150-MAS08347,Output 18 for exterior lighting-Assigned event code,B133300,
IDE09150-MAS08349,Output 18 for exterior lighting-Type of connected lamp,LED,
IDE09151-MAS01580,Output 19 for exterior lighting-Activation,100.0, %
IDE09151-MAS05851,Output 19 for exterior lighting-Current power consumption,236, mA
IDE09151-MAS08347,Output 19 for exterior lighting-Assigned event code,B133400,
IDE09151-MAS08349,Output 19 for exterior lighting-Type of connected lamp,LED,
IDE09153-MAS01580,Output 20 for exterior lighting-Activation,Output not used,
IDE09153-MAS05851,Output 20 for exterior lighting-Current power consumption,Output not used,
IDE09153-MAS08347,Output 20 for exterior lighting-Assigned event code,Unknown (0),
IDE09153-MAS08349,Output 20 for exterior lighting-Type of connected lamp,Output not used,
IDE09157-MAS01580,Output 21 for exterior lighting-Activation,Output not used,
IDE09157-MAS05851,Output 21 for exterior lighting-Current power consumption,Output not used,
IDE09157-MAS08347,Output 21 for exterior lighting-Assigned event code,Unknown (0),
IDE09157-MAS08349,Output 21 for exterior lighting-Type of connected lamp,Output not used,
IDE09218-MAS06793,Key information-Number of adapted keys,2,
IDE09218-MAS07008,Key information-Number of keys to be adapted,2,
IDE09218-MAS08428,Key information-Number of the active key,2,
IDE09220-MAS01551,Information of last change code error-Key number,255,
IDE09220-MAS08433,Information of last change code error-Last OK counter status control module,FF FF FF FF,
IDE09220-MAS08434,Information of last change code error-Last OK counter status control module: redundant,FF FF FF FF,
IDE09220-MAS08435,Information of last change code error-Last OK counter status key,FF FF FF FF,
IDE09220-MAS08436,Information of last change code error-Counter status control module at error event,FF FF FF FF,
IDE09220-MAS08437,Information of last change code error-Counter status control module at error event: redundant,FF FF FF FF,
IDE09220-MAS08438,Information of last change code error-Counter status key at error event,FF FF FF FF,
IDE09220-MAS08460,Information of last change code error-Time between last OK recognition and error event,6553.500, s
IDE09221-MAS03692,Change code counter status-Key 1,Not adapted,
IDE09221-MAS03693,Change code counter status-Key 2,00 00 10 4F,
IDE09221-MAS03694,Change code counter status-Key 3,Not adapted,
IDE09221-MAS03695,Change code counter status-Key 4,Not adapted,
IDE09221-MAS03696,Change code counter status-Key 5,Not adapted,
IDE09221-MAS03697,Change code counter status-Key 6,Not adapted,
IDE09221-MAS03698,Change code counter status-Key 7,Not adapted,
IDE09221-MAS03699,Change code counter status-Key 8,Not adapted,
IDE09250-MAS08462,Key search in vehicle interior-Authenticated key in search area,00000010 ,
IDE09250-MAS08463,Key search in vehicle interior-Authenticated key,00000010 ,
IDE09250-MAS08464,Key search in vehicle interior-Recognized key,00000010 ,
IDE09252-MAS08462,Key search in luggage compartment-Authenticated key in search area,00000010 ,
IDE09252-MAS08463,Key search in luggage compartment-Authenticated key,00000010 ,
IDE09252-MAS08464,Key search in luggage compartment-Recognized key,00000010 ,
IDE09253-MAS08462,Key search in left area-Authenticated key in search area,00000000 ,
IDE09253-MAS08463,Key search in left area-Authenticated key,00000010 ,
IDE09253-MAS08464,Key search in left area-Recognized key,00000010 ,
IDE09254-MAS08462,Key search in right area-Authenticated key in search area,00000000 ,
IDE09254-MAS08463,Key search in right area-Authenticated key,00000010 ,
IDE09254-MAS08464,Key search in right area-Recognized key,00000010 ,
IDE09255-MAS08462,Key search in rear area-Authenticated key in search area,00000000 ,
IDE09255-MAS08463,Key search in rear area-Authenticated key,00000000 ,
IDE09255-MAS08464,Key search in rear area-Recognized key,00000000 ,
IDE09401-IDE00500,History data central locking: sixth-to-last event-Hour,10,
IDE09401-IDE00501,History data central locking: sixth-to-last event-Minute,40,
IDE09401-MAS00106,History data central locking: sixth-to-last event-Year,not known,
IDE09401-MAS00107,History data central locking: sixth-to-last event-Month,10,
IDE09401-MAS00108,History data central locking: sixth-to-last event-Day,20,
IDE09401-MAS00111,History data central locking: sixth-to-last event-Seconds,45,
IDE09401-MAS01551,History data central locking: sixth-to-last event-Key number,2,
IDE09401-MAS06441,History data central locking: sixth-to-last event-Control-section / cause,Remote control,
IDE09402-IDE00500,History data central locking: seventh-to-last event-Hour,10,
IDE09402-IDE00501,History data central locking: seventh-to-last event-Minute,33,
IDE09402-MAS00106,History data central locking: seventh-to-last event-Year,not known,
IDE09402-MAS00107,History data central locking: seventh-to-last event-Month,10,
IDE09402-MAS00108,History data central locking: seventh-to-last event-Day,20,
IDE09402-MAS00111,History data central locking: seventh-to-last event-Seconds,30,
IDE09402-MAS01551,History data central locking: seventh-to-last event-Key number,2,
IDE09402-MAS06441,History data central locking: seventh-to-last event-Control-section / cause,Remote control,
IDE09403-IDE00500,History data central locking: eighth-to-last event-Hour,10,
IDE09403-IDE00501,History data central locking: eighth-to-last event-Minute,33,
IDE09403-MAS00106,History data central locking: eighth-to-last event-Year,not known,
IDE09403-MAS00107,History data central locking: eighth-to-last event-Month,10,
IDE09403-MAS00108,History data central locking: eighth-to-last event-Day,20,
IDE09403-MAS00111,History data central locking: eighth-to-last event-Seconds,0,
IDE09403-MAS01551,History data central locking: eighth-to-last event-Key number,2,
IDE09403-MAS06441,History data central locking: eighth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09404-IDE00500,History data central locking: ninth-to-last event-Hour,10,
IDE09404-IDE00501,History data central locking: ninth-to-last event-Minute,25,
IDE09404-MAS00106,History data central locking: ninth-to-last event-Year,not known,
IDE09404-MAS00107,History data central locking: ninth-to-last event-Month,10,
IDE09404-MAS00108,History data central locking: ninth-to-last event-Day,20,
IDE09404-MAS00111,History data central locking: ninth-to-last event-Seconds,0,
IDE09404-MAS01551,History data central locking: ninth-to-last event-Key number,2,
IDE09404-MAS06441,History data central locking: ninth-to-last event-Control-section / cause,Remote control,
IDE09405-IDE00500,History data central locking: tenth-to-last event-Hour,15,
IDE09405-IDE00501,History data central locking: tenth-to-last event-Minute,44,
IDE09405-MAS00106,History data central locking: tenth-to-last event-Year,not known,
IDE09405-MAS00107,History data central locking: tenth-to-last event-Month,10,
IDE09405-MAS00108,History data central locking: tenth-to-last event-Day,19,
IDE09405-MAS00111,History data central locking: tenth-to-last event-Seconds,15,
IDE09405-MAS01551,History data central locking: tenth-to-last event-Key number,2,
IDE09405-MAS06441,History data central locking: tenth-to-last event-Control-section / cause,Remote control,
IDE09406-IDE00500,History data central locking: eleventh-to-last event-Hour,15,
IDE09406-IDE00501,History data central locking: eleventh-to-last event-Minute,44,
IDE09406-MAS00106,History data central locking: eleventh-to-last event-Year,not known,
IDE09406-MAS00107,History data central locking: eleventh-to-last event-Month,10,
IDE09406-MAS00108,History data central locking: eleventh-to-last event-Day,19,
IDE09406-MAS00111,History data central locking: eleventh-to-last event-Seconds,15,
IDE09406-MAS01551,History data central locking: eleventh-to-last event-Key number,2,
IDE09406-MAS06441,History data central locking: eleventh-to-last event-Control-section / cause,Remote control,
IDE09407-IDE00500,History data central locking: twelfth-to-last event-Hour,15,
IDE09407-IDE00501,History data central locking: twelfth-to-last event-Minute,44,
IDE09407-MAS00106,History data central locking: twelfth-to-last event-Year,not known,
IDE09407-MAS00107,History data central locking: twelfth-to-last event-Month,10,
IDE09407-MAS00108,History data central locking: twelfth-to-last event-Day,19,
IDE09407-MAS00111,History data central locking: twelfth-to-last event-Seconds,15,
IDE09407-MAS01551,History data central locking: twelfth-to-last event-Key number,2,
IDE09407-MAS06441,History data central locking: twelfth-to-last event-Control-section / cause,Remote control,
IDE09408-IDE00500,History data central locking: thirteenth-to-last event-Hour,15,
IDE09408-IDE00501,History data central locking: thirteenth-to-last event-Minute,43,
IDE09408-MAS00106,History data central locking: thirteenth-to-last event-Year,not known,
IDE09408-MAS00107,History data central locking: thirteenth-to-last event-Month,10,
IDE09408-MAS00108,History data central locking: thirteenth-to-last event-Day,19,
IDE09408-MAS00111,History data central locking: thirteenth-to-last event-Seconds,45,
IDE09408-MAS01551,History data central locking: thirteenth-to-last event-Key number,2,
IDE09408-MAS06441,History data central locking: thirteenth-to-last event-Control-section / cause,Remote control,
IDE09409-IDE00500,History data central locking: fourteenth-to-last event-Hour,15,
IDE09409-IDE00501,History data central locking: fourteenth-to-last event-Minute,26,
IDE09409-MAS00106,History data central locking: fourteenth-to-last event-Year,not known,
IDE09409-MAS00107,History data central locking: fourteenth-to-last event-Month,10,
IDE09409-MAS00108,History data central locking: fourteenth-to-last event-Day,19,
IDE09409-MAS00111,History data central locking: fourteenth-to-last event-Seconds,15,
IDE09409-MAS01551,History data central locking: fourteenth-to-last event-Key number,2,
IDE09409-MAS06441,History data central locking: fourteenth-to-last event-Control-section / cause,Auto lock,
IDE09410-IDE00500,History data central locking: fifteenth-to-last event-Hour,15,
IDE09410-IDE00501,History data central locking: fifteenth-to-last event-Minute,26,
IDE09410-MAS00106,History data central locking: fifteenth-to-last event-Year,not known,
IDE09410-MAS00107,History data central locking: fifteenth-to-last event-Month,10,
IDE09410-MAS00108,History data central locking: fifteenth-to-last event-Day,19,
IDE09410-MAS00111,History data central locking: fifteenth-to-last event-Seconds,0,
IDE09410-MAS01551,History data central locking: fifteenth-to-last event-Key number,2,
IDE09410-MAS06441,History data central locking: fifteenth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09411-IDE00500,History data central locking: sixteenth-to-last event-Hour,15,
IDE09411-IDE00501,History data central locking: sixteenth-to-last event-Minute,14,
IDE09411-MAS00106,History data central locking: sixteenth-to-last event-Year,not known,
IDE09411-MAS00107,History data central locking: sixteenth-to-last event-Month,10,
IDE09411-MAS00108,History data central locking: sixteenth-to-last event-Day,19,
IDE09411-MAS00111,History data central locking: sixteenth-to-last event-Seconds,45,
IDE09411-MAS01551,History data central locking: sixteenth-to-last event-Key number,2,
IDE09411-MAS06441,History data central locking: sixteenth-to-last event-Control-section / cause,Auto lock,
IDE09412-IDE00500,History data central locking: seventeenth-to-last event-Hour,15,
IDE09412-IDE00501,History data central locking: seventeenth-to-last event-Minute,14,
IDE09412-MAS00106,History data central locking: seventeenth-to-last event-Year,not known,
IDE09412-MAS00107,History data central locking: seventeenth-to-last event-Month,10,
IDE09412-MAS00108,History data central locking: seventeenth-to-last event-Day,19,
IDE09412-MAS00111,History data central locking: seventeenth-to-last event-Seconds,30,
IDE09412-MAS01551,History data central locking: seventeenth-to-last event-Key number,2,
IDE09412-MAS06441,History data central locking: seventeenth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09413-IDE00500,History data central locking: eighteenth-to-last event-Hour,11,
IDE09413-IDE00501,History data central locking: eighteenth-to-last event-Minute,17,
IDE09413-MAS00106,History data central locking: eighteenth-to-last event-Year,not known,
IDE09413-MAS00107,History data central locking: eighteenth-to-last event-Month,10,
IDE09413-MAS00108,History data central locking: eighteenth-to-last event-Day,15,
IDE09413-MAS00111,History data central locking: eighteenth-to-last event-Seconds,15,
IDE09413-MAS01551,History data central locking: eighteenth-to-last event-Key number,2,
IDE09413-MAS06441,History data central locking: eighteenth-to-last event-Control-section / cause,Remote control,
IDE09414-IDE00500,History data central locking: nineteenth-to-last event-Hour,14,
IDE09414-IDE00501,History data central locking: nineteenth-to-last event-Minute,30,
IDE09414-MAS00106,History data central locking: nineteenth-to-last event-Year,not known,
IDE09414-MAS00107,History data central locking: nineteenth-to-last event-Month,10,
IDE09414-MAS00108,History data central locking: nineteenth-to-last event-Day,12,
IDE09414-MAS00111,History data central locking: nineteenth-to-last event-Seconds,0,
IDE09414-MAS01551,History data central locking: nineteenth-to-last event-Key number,2,
IDE09414-MAS06441,History data central locking: nineteenth-to-last event-Control-section / cause,Re-locking to opening via radio or outside door handle sensor,
IDE09415-IDE00500,History data central locking: twentieth-to-last event-Hour,8,
IDE09415-IDE00501,History data central locking: twentieth-to-last event-Minute,33,
IDE09415-MAS00106,History data central locking: twentieth-to-last event-Year,not known,
IDE09415-MAS00107,History data central locking: twentieth-to-last event-Month,10,
IDE09415-MAS00108,History data central locking: twentieth-to-last event-Day,8,
IDE09415-MAS00111,History data central locking: twentieth-to-last event-Seconds,45,
IDE09415-MAS01551,History data central locking: twentieth-to-last event-Key number,2,
IDE09415-MAS06441,History data central locking: twentieth-to-last event-Control-section / cause,Remote control,
IDE09416,Control line for dynamic turn signal,not active,
IDE09840-MAS09380,CU for tailgate opener: counter readings-proximity detected,02 38,
IDE09840-MAS09381,CU for tailgate opener: counter readings-Foot gestic detected,02 38,
IDE09840-MAS09382,CU for tailgate opener: counter readings-De-activation,00 D2,
IDE09840-MAS09383,CU for tailgate opener: counter readings-Play protection activation,00 00,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE09841-MAS09386,CU for tailgate opener: sensor status-Sensor module connected,No,
IDE09917-MAS03692,Last change code counter status-Key 1,Not adapted,
IDE09917-MAS03693,Last change code counter status-Key 2,00 00 10 20,
IDE09917-MAS03694,Last change code counter status-Key 3,Not adapted,
IDE09917-MAS03695,Last change code counter status-Key 4,Not adapted,
IDE09917-MAS03696,Last change code counter status-Key 5,Not adapted,
IDE09917-MAS03697,Last change code counter status-Key 6,Not adapted,
IDE09917-MAS03698,Last change code counter status-Key 7,Not adapted,
IDE09917-MAS03699,Last change code counter status-Key 8,Not adapted,
IDE10096-MAS01551,Radio remote control: last radio shot-Key number,2,
IDE10096-MAS06879,Radio remote control: last radio shot-Checksum,OK,
IDE10096-MAS08411,Radio remote control: last radio shot-Button for vehicle locking,operated,
IDE10096-MAS08412,Radio remote control: last radio shot-Button for vehicle unlocking,Not operated,
IDE10096-MAS08413,Radio remote control: last radio shot-Button for luggage compartment unlocking,Not operated,
IDE10096-MAS08414,Radio remote control: last radio shot-Panic button,Not operated,
IDE10096-MAS08415,Radio remote control: last radio shot-Battery status,New,
IDE10096-MAS08419,Radio remote control: last radio shot-Key condition,OK,
IDE10096-MAS08421,Radio remote control: last radio shot-Transponder ID: Byte 1,66,
IDE10096-MAS08422,Radio remote control: last radio shot-Cryptography,OK,
IDE10096-MAS08423,Radio remote control: last radio shot-Rolling code information,Detection area 1,
IDE10096-MAS08427,Radio remote control: last radio shot-Time since last radio shot,255, s
IDE10096-MAS13216,Radio remote control: last radio shot-Front windshield remote unlocking button,Not operated,
IDE10096-MAS13230,Radio remote control: last radio shot-Freely assignable button,Not operated,
IDE10097-IDE01442,Comfort closing convert. top/rear lid-Pressing a button,no key actuated,
IDE10097-MAS06528,Comfort closing convert. top/rear lid-Release status,not enabled,
IDE10097-MAS08432,Comfort closing convert. top/rear lid-Requirement,No,
IDE10097-MAS09907,Comfort closing convert. top/rear lid-Key search,not active,
IDE10097-MAS09908,Comfort closing convert. top/rear lid-Key within reach,No,
IDE10097-MAS09909,Comfort closing convert. top/rear lid-Number of key searches,0,
IDE10097-MAS09910,Comfort closing convert. top/rear lid-Number of key responses,0,
IDE10098-MAS09911,Zone and area information key 1 - 4-Key 1: Zone information,not installed,
IDE10098-MAS09912,Zone and area information key 1 - 4-Key 1: Area information,not installed,
IDE10098-MAS09913,Zone and area information key 1 - 4-Key 2: Zone information,not installed,
IDE10098-MAS09914,Zone and area information key 1 - 4-Key 2: Area information,not installed,
IDE10098-MAS09915,Zone and area information key 1 - 4-Key 3: Zone information,Not adapted,
IDE10098-MAS09916,Zone and area information key 1 - 4-Key 3: Area information,Not adapted,
IDE10098-MAS09917,Zone and area information key 1 - 4-Key 4: Zone information,Not adapted,
IDE10098-MAS09918,Zone and area information key 1 - 4-Key 4: Area information,Not adapted,
IDE10099-MAS09919,Zone and area information key 5 - 8-Key 5: Zone information,Not adapted,
IDE10099-MAS09920,Zone and area information key 5 - 8-Key 5: Area information,Not adapted,
IDE10099-MAS09921,Zone and area information key 5 - 8-Key 6: Zone information,Not adapted,
IDE10099-MAS09922,Zone and area information key 5 - 8-Key 6: Area information,Not adapted,
IDE10099-MAS09923,Zone and area information key 5 - 8-Key 7: Zone information,Not adapted,
IDE10099-MAS09924,Zone and area information key 5 - 8-Key 7: Area information,Not adapted,
IDE10099-MAS09925,Zone and area information key 5 - 8-Key 8: Zone information,Not adapted,
IDE10099-MAS09926,Zone and area information key 5 - 8-Key 8: Area information,Not adapted,
IDE10100-MAS09931,Individual activation of antennae for access and start system-Access/start system antenna 1 in vehicle interior,176,
IDE10100-MAS09932,Individual activation of antennae for access and start system-Access/start system antenna in luggage compartment,152,
IDE10100-MAS09933,Individual activation of antennae for access and start system-Left Access/Start Authorization Antenna,156,
IDE10100-MAS09934,Individual activation of antennae for access and start system-Right Access/Start Authorization Antenna,140,
IDE10100-MAS09935,Individual activation of antennae for access and start system-Access/start system antenna 2 in vehicle interior,254,
IDE10159-MAS09936,Outside door handle sens.: frt. left-Unlocking sensor: proximity detected,No,
IDE10159-MAS09937,Outside door handle sens.: frt. left-Locking sensor: proximity detected,No,
IDE10159-MAS09938,Outside door handle sens.: frt. left-Unlocking sensor: activation detected,No,
IDE10159-MAS09939,Outside door handle sens.: frt. left-Locking sensor: activation detected,No,
IDE10159-MAS09951,Outside door
