Abs coding after 4motion retrofit transporter t5 2005
zanzei26
Verified VCDS-User
Norway
C?ID=237538
Hi, i have bought an t5 transporter, this car was originally an 2wd automatic but is now retrofitted with an manual transmission and 4motion.
all the coding except abs brake coding is done. when i open the coding section in the abs module the label file says to contact rosstech for help with the coding.
complete autoscan is included.
can anyone find out the correct coding of the brake electronics module for my car?
currently i dont have neither esp or traction control.
abs module is the original one from factory.
Autoscan follows:
Sunday,18,October,2020,21:39:40:61980
Dealer/Shop Name: tc
Workshop Code: 000 12345 000000
VIN: WV1ZZZ7HZ7H132436 License Plate: VEGARD1
Mileage: 269780km-167633mi Repair Order:
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H132436 Mileage: 269780km-167633miles
Address 01: Engine Labels: 070-906-016-BPC.clb
Part No SW: 070 997 016 M HW: 070 997 016 M
Component: R5 2,5L EDC G000SG 0860
Revision: --H05--- Serial number: VWZ7Z0G5307530
Coding: 0000132
Shop #: WSC 00003 512 00128
VCID: 241111B652C4DEEB16B-513C
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl
Part No SW: 7H0 907 379 R HW: 7H0 907 379 R
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0002592
Shop #: WSC 12345 000 00000
VCID: 44D1B136B284FEEB36B-5118
003 - Mechanical Failure
Fault Status: 01100011
Mileage: 269784 km
Count: 128
Count: 4353
Count: 199
Count: 2049
00493 - ESP-Sensor Unit (G419)
014 - Defective
Fault Status: 01101110
Mileage: 269784 km
Count: 128
Count: 4353
Count: 208
Count: 2049
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H2 907 040 C
Component: CLIMAtronic T5 4221
Coding: 0011040
Shop #: WSC 02757 790 00000
VCID: 280905862EEC3A8B3A3-5118
Subsystem 1 - Part No: 7H7 907 049 A
Component: Display_2_ClimaT5 X 0307
00229 - Refrigerant Pressure
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 AE
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000869
Shop #: WSC 02756 790 00000
VCID: 75B71CF2A9DE1763715-5118
00901 - Back-Up Lamps
01598 - Drive Battery Voltage
Address 0B: Sec. Air Heating Labels: None
Part No: 7H0 819 002 R
Component: Luftstandheizung, D 0429
Revision: 00061429 Serial number: 0097616
VCID: 3537DCF2E95E5763B15-4B00
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0010
Coding: 13123
Shop #: WSC 02756
VCID: 221D17AE4DD0D0DB647-5118
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 851 R
Coding: 00112
VCID: 3A2DCFCEC540B81B5C7-5118
WV1ZZZ7HZ7H132436 VWZ7Z0G5307530
Part No: 6N0 909 901
Coding: 00022
Shop #: WSC 02756
VCID: 70B92DE6D3BC324BA23-5118
49-00 - No Communications
Address 22: AWD Labels: 7H0-907-554.clb
Part No: 7H0 907 554 F
Component: HALDEX 4Motion 2110
Coding: 0000001
VCID: 3333E2EAE72A49539F1-5118
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C11 Komfortgerᴠ 0004
Coding: 00025
Shop #: WSC 02756
VCID: 323DE7EE1D30405B947-4B00
Address 6E: Ctrl Head Roof Labels: Redir Fail!
Part No SW: 7H5 919 044 G HW: 7H5 919 044 G
Component: J702 Dachdisplay 0500
Revision: 1010107S Serial number: 00000000030668
Coding: 0000006
VCID: 3635DBFEF4585C7BB8F-5118
Reset counter: 23
Date: 2021.06.18
Time: 23:36:14
Address 76: Park Assist Labels: 7H0-919-283.lbl
Part No: 7H0 919 283
Component: Parkingsyst. T5 T5M 401
Coding: 10127
VCID: 6FBB2E9ACE822DB3BB9-513C
End----(Elapsed Time: 05:41, VBatt start/end: 11.5V/11.8V. VIgn 11.7V)-----
I don't have a coding chart for this, but I don't think you can fix this via coding:
"ESP-Sensor Unit (G419) -- Defective"
zanzei26
Verified VCDS-User
Norway
C?ID=237538
That fault is on the todo list. But i still have to tell the abs system that the car now is 4wd and not 2wd
zanzei26
Verified VCDS-User
Norway
C?ID=237538
Anyone? Just need to know the correct coding for the esp mk25e1 module. Does anyone have this module in their transporter t5 4motion 2005?
NZDubNurd
New Zealand
C?ID=230482
I'm not well-versed with T5's, though we do have a 2013 2.0 BiTdi 4motion manual for a work van.
Is the 2WD ABS unit capable of being coded to 4WD?
In my Touran conversion, I had to fit an ABS unit that was compatible with 4WD.
In the Touran, the 2WD unit didn't have the software to cope, but I also had to change the ESP sensor to one that reported data the 4WD needed. You may have similar issues, though I'm not sure of any of the details, having not fiddled with T5's at all.
Also the code:
has been known to mean the plug wiring loops don't match the drivetrain ECU's or coding.
You may need to research which units are used in 4WD versions, and which wiring changes or module changes may be required.
andythechief
Barnstaple, England and Linz, Austria
C?ID=65958
Here is my 2008 T5 4motion LWB abs module scan:
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000092
   Shop #: WSC 02736 790 00000
   VCID: C5C236608D3AA3AEE0-513C
The whole scan is under the reference scan section.
Don't forget that 4motion functionality varied by generation.
