Loss of steering assist on Q5
Lgibson
C?ID=41716
This seems strange but I'm not familiar with electro-mechanical steering. Straight ahead the wheel is somewhat heavy, then very heavy when beginning a turn, then normal when past that initial resistance when assistance kicks in. No faults stored that I can see. It is 260 miles to the dealer. Would there be any troubleshooting technique anyone could suggest?
Saturday,24,October,2020,15:31:39:34689
VCDS Version: 19.6.2.2
VIN: WA1LFAFP1FA028697   License Plate:
Mileage: 133940km-83226mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 62
          6D 72 77
VIN: WA1LFAFP1FA028697   Mileage: 133940km-83226miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 L    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 39334 003 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
   ROD: EV_ECM20TFS0118R1907115L.rod
   VCID: 3E78A8E3A1F034BF97-806A
22593 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
   Part No SW: 8R0 927 158 AS    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H18 1001
   Revision: --H18---
   VCID: 0E183823D1D0E43F27-805A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 151D1803
   Shop #: WSC 06335 000 00000
   VCID: 1122235FC8EEFBC73A-8044
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0D854040000000000000
   VCID: 07160D07B6AAB577E4-8052
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0514000101519014
   Serial number: 0214000131068015
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 108
                    Mileage: 130749 km
                    Date: 2020.04.22
                    Time: 12:47:52
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01190720141196
   Coding: 6481208000
   VCID: 77F67DC7C64AC5F794-8022
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000851187702
   Coding: 26000091863CAFE00100488300003D0D0F1CC60822090221000008004000030100000000000000
   VCID: 76E870C3C140BCFF8F-8022
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140619  H12 0050
   Serial number: 90243014140613210726
   Coding: 01DD13
   Serial number: 22899110
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001207140127
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R9VWW03
   Serial number: F9688B37000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12AAB1
   Coding: 303634313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4C9CF22BE74C962F09-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000KS9T
   Serial number: 6334MSME482C5708J
   Serial number: 6344MSME47685909M
   Serial number: 6352QSME3744206EH
   Serial number: 6362QSME0C441456E
   Serial number: 63732SME65430F4E7
   Serial number: 63832SME60433950U
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NGN000SH
   Coding: 000037
   VCID: 4894CE3BFB347A0F2D-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 R    HW: 8R0 920 950 R
   Component: KOMBIINSTR.   H07 0564
   Revision: 00300000    Serial number: ZCW54HE7F
   Coding: 8B9622000301D705020000
   VCID: 458AC70FCC266767D6-8010
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V147120AF0
   Coding: 80C303FF00
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 2510063903
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 3972BBFFB0DE1387A2-806C
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000108979300
   Coding: 00581B00000000000000
   VCID: 4280DC13DD08505FF3-8016
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000109616973
   Coding: 011D13205E00440004
   VCID: 4FA6E5271E5AAD376C-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0029727509
   Coding: 100000010000
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3F86D5E7A6FA3DB79C-806A
   Revision: 00002001    Serial number: 0341508319
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000866438
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 H    HW: 8R0 035 223 F
   Component: DSP STD       H11 0470
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 316283DF68AEDBC71A-8064
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000109781778
   VCID: 4E98F8231950A43F67-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000482645
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A70A4F3BDD8189FAB-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2063566
   Coding: 040200020105850043D9070800
   VCID: 438ED917C2125957F8-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Fault Frequency: 84
                    Reset counter: 7
                    Mileage: 114066 km
                    Date: 2019.05.18
                    Time: 18:53:50
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000109869345
   Coding: 010C13204000240004
   VCID: 4688C003F1206C7FDF-8012
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7AAFEFA4F62FA78E-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000110842978
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005383044
   Coding: 0010370
   VCID: 3E78A8E369F034BF97-806A
End-------------------------(Elapsed Time: 04:28)--------------------------
Hmm... No relevant faults. Not sure what to make of that.
Lgibson
C?ID=41716
Well, I’m going with seized u-joints on the intermediate steering shaft in view of the absence of electrical problems. There is anecdotal evidence out there.
  • Informative
