- Oct 24, 2020
- 3
- 2
- Upper Hutt, New Zealand
- C?ID=114757
Hi Folks,
I'm a newbie here but a longtime user of Ross Techs great diagnostic tools.
This problem is with my wifes car. she was driving and went to accelerate away at an intersection and nothing happened, she described it "like her foot has slipped of the accelerator." Next the dash lights ups like a Christmas tree with multiple warning lamps lit..!! Apart from this glitch the car drives as normal.
I hooked up the VAG Com and did a scan, below is an edited version of the log with multiple fault codes showing for ABS, Haldex 4WD system and Steering. The codes clear OK but return as soon as the car is started and moved. The steering fault may be a red herring looking at the date and time is was logged??
I suspect it is one issue somewhere which is causing this chain of events and I’m thinking it may be the ABS sensor on the left rear wheel that is the culprit but this is just a hunch. I’d appreciate input from others who may have experience a similar set of of faults and what the outcome was.
Cheers
Stinky Pete
Cheers
Stinky Pete
Saturday,24,October,2020,17:19:19:64391
VCDS Version: 20.4.2.0 (x64)
Skoda Yeti TDI 125kw 4x4
VIN: TMBME75L3F6051285
Mileage: 85120km-52891mi Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 5F 62 69 72
VIN: TMBME75L3F6051285 Mileage: 85120km-52891miles
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 963F600E092701FB690D06EC901E8082A1000020
Shop #: WSC 33361 790 00066
VCID: 040D62A487E098A637-8050
Reset counter: 220
Mileage: 85067 km
Date: 2015.03.17
Time: 12:16:22
Count: 7
Count: 15
Count: 4096
Count: 128
Count: 34048
Count: 8448
Count: 65282
Fault Status: 00100011
Reset counter: 220
Mileage: 85067 km
Date: 2015.03.17
Time: 12:17:44
Count: 64
Count: 4608
Count: 75
Count: 50739
Count: 2
Count: 1
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 180
Mileage: 85082 km
Date: 2015.03.17
Time: 15:25:03
Count: 16384
Count: 6
Count: 12800
Count: 71
Count: 43776
Count: 64256
Count: 65026
Count: 10752
Fault Status: 01101100
Reset counter: 181
Mileage: 85067 km
Date: 2015.03.17
Time: 12:16:22
Count: 2
Count: 14
Count: 4096
Count: 72
Count: 44032
Count: 8448
Count: 65283
Part No SW: 0AY 907 554 J HW: 0AY 907 554 J
Component: Haldex4Motion H52 7522
Serial number: HA1-00023.10.14
Coding: 0301
Shop #: WSC 73430 790 00066
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 52A194FC0514C616F5-8006
16670 - All-Wheel Drive
C1113 07 [008] - Mechanical Failure
Reset counter: 220
Mileage: 85067 km
Date: 2020.10.24
Time: 12:17:39
16656 - Databus
Reset counter: 221
Mileage: 85067 km
Date: 2020.10.24
Time: 12:16:22
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 71 3501
Revision: 00H22000
VCID: 3973C35070A2154E14-806C
Fault Status: 00101101
Reset counter: 221
Mileage: 85121 km
Date: 2015.03.17
Time: 17:14:41
Voltage: 12.25 V
DD
Temperature: 38.0°C
End-------------------------(Elapsed Time: 03:08)--------------------------
