2015 Skoda Yeti 125kw TDI 4x4 - Haldex, ABS and Steering Assist Fault codes
StinkyPete
Upper Hutt, New Zealand
C?ID=114757
Hi Folks,
I'm a newbie here but a longtime user of Ross Techs great diagnostic tools.
This problem is with my wifes car. she was driving and went to accelerate away at an intersection and nothing happened, she described it "like her foot has slipped of the accelerator." Next the dash lights ups like a Christmas tree with multiple warning lamps lit..!! Apart from this glitch the car drives as normal.
I hooked up the VAG Com and did a scan, below is an edited version of the log with multiple fault codes showing for ABS, Haldex 4WD system and Steering. The codes clear OK but return as soon as the car is started and moved. The steering fault may be a red herring looking at the date and time is was logged??
I suspect it is one issue somewhere which is causing this chain of events and I’m thinking it may be the ABS sensor on the left rear wheel that is the culprit but this is just a hunch. I’d appreciate input from others who may have experience a similar set of of faults and what the outcome was.
Cheers
Stinky Pete
Saturday,24,October,2020,17:19:19:64391
VCDS Version: 20.4.2.0 (x64)
Skoda Yeti TDI 125kw 4x4
VIN: TMBME75L3F6051285
Mileage: 85120km-52891mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 5F 62 69 72
VIN: TMBME75L3F6051285   Mileage: 85120km-52891miles
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 963F600E092701FB690D06EC901E8082A1000020
   Shop #: WSC 33361 790 00066
   VCID: 040D62A487E098A637-8050
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:16:22
                    Count: 7
                    Count: 15
                    Count: 4096
                    Count: 128
                    Count: 34048
                    Count: 8448
                    Count: 65282
                    Fault Status: 00100011
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:17:44
                    Count: 64
                    Count: 4608
                    Count: 75
                    Count: 50739
                    Count: 2
                    Count: 1
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 180
                    Mileage: 85082 km
                    Date: 2015.03.17
                    Time: 15:25:03
                    Count: 16384
                    Count: 6
                    Count: 12800
                    Count: 71
                    Count: 43776
                    Count: 64256
                    Count: 65026
                    Count: 10752
                    Fault Status: 01101100
                    Reset counter: 181
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:16:22
                    Count: 2
                    Count: 14
                    Count: 4096
                    Count: 72
                    Count: 44032
                    Count: 8448
                    Count: 65283
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00023.10.14
   Coding: 0301
   Shop #: WSC 73430 790 00066
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 52A194FC0514C616F5-8006
16670 - All-Wheel Drive
          C1113 07 [008] - Mechanical Failure
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2020.10.24
                    Time: 12:17:39
16656 - Databus
                    Reset counter: 221
                    Mileage: 85067 km
                    Date: 2020.10.24
                    Time: 12:16:22
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 71     3501
   Revision: 00H22000
   VCID: 3973C35070A2154E14-806C
                    Fault Status: 00101101
                    Reset counter: 221
                    Mileage: 85121 km
                    Date: 2015.03.17
                    Time: 17:14:41
                    Voltage: 12.25 V
                        DD
                    Temperature: 38.0°C
End-------------------------(Elapsed Time: 03:08)--------------------------
Hi and welcome.
Please post the whole scan for context. I don't think any of these faults explain a dead accelerator.
StinkyPete
C?ID=114757
There is a fault with a glow plug at the moment but I wouldn't have thought that was related. Keep in mind that my wifes foot may have slipped off the accelerator and all of that is coincidence. When asked she couldn't say exactly when the lights came up on the dash but the date and times on the faults are roughly when she thought it went a bit flat.
Here is the full scan.
Skoda Yeti  VIN: TMBME75L3F6051285
Address 01: Engine (J623-CFJA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 SE    HW: 03L 907 309 AG
   Component: R4 2.0l TDI   H25 9979
   Revision: 42H25---    Serial number:
   Coding: 001D0012042700080000
   Shop #: WSC 00500 824 00000
   ASAM Dataset: EV_ECM20TDI01103L906018SE 003007
   ROD: EV_ECM20TDI01103L906018SE.rod
   VCID: 7F07ED48E606FB7E6A-802A
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [237] - Electrical Fault
                    Mileage: 77819 km
                    Date: 2020.03.14
                    Time: 10:24:09
                    Engine speed: 943.00 /min
                    Normed load value: 40.8 %
                    Coolant temperature: 13 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.340 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 148
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 1500 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 5
                    Glow cycles above temperature threshold-Bits 0-7: 36
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 1
                    Outside air temperature: 15.0 °C
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 016 E    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4005
   Revision: 05653104    Serial number: 00001411140375
   VCID: 162928EC217C1A36D9-8042
   Revision: 00H46001
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:16:22
                    Count: 7
                    Count: 15
                    Count: 4096
                    Count: 128
                    Count: 34048
                    Count: 8448
                    Count: 65282
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:17:44
                    Count: 64
                    Count: 4608
                    Count: 75
                    Count: 50739
                    Count: 2
                    Count: 1
                    Reset counter: 180
                    Mileage: 85082 km
                    Date: 2015.03.17
                    Time: 15:25:03
                    Count: 16384
                    Count: 6
                    Count: 12800
                    Count: 71
                    Count: 43776
                    Count: 64256
                    Count: 65026
                    Count: 10752
                    Reset counter: 181
                    Mileage: 85067 km
                    Date: 2015.03.17
                    Time: 12:16:22
                    Count: 2
                    Count: 14
                    Count: 4096
                    Count: 72
                    Count: 44032
                    Count: 8448
                    Count: 65283
   Part No SW: 3T0 907 044 CD    HW: 3T0 907 044 CD
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 76E9086CC93CBA3639-8022
   Part No SW: 1K0 937 086 AA    HW: 1K0 937 086 AA
   Component: BCM PQ35  M   112 0771
   Revision: AF112771
   Coding: 4E000ABCE01BF1C0400800C0110001EC4B7000AE526D8160E48140000040
   VCID: 6FE73D08BE668BFEFA-803A
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Component: RLS 071214 05  54  0403
   Coding: 0630ED
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 G    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0011
   Revision: --H06---    Serial number: 28231433303288
   Coding: 108106
   ASAM Dataset: EV_EPHVA18SKxxx0000 002001
   ROD: EV_EPHVA18SKxxx0000_002.rod
   VCID: 458BBFA0C45A61AE60-8010
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAU13MV
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3163FB7060D2DD0EAC-8064
   Serial number: 3572MSME3626184BZZZY
   Serial number: 3582MSME2D325D4AZZZ3
   Serial number: 3516KSME65627D33ZZZY
   Serial number: 3526KSME474F7D33ZZZ3
   Part No SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20141209201822
   Coding: 1882140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 71E33B70A0529D0EEC-8024
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000A0743101114
   Coding: 820000
   Part No SW: 5L0 920 840 R    HW: 5L0 920 840 R
   Component: KOMBI         H04 0905
   Coding: 120A00
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 3A71DC5CBDA41E561D-806E
   Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1653
   Revision:   H57       Serial number: 041214F2000032
   Coding: 356323
   VCID: 7EF9104CE90CF27661-802A
   Coding: 0301
                    Reset counter: 220
                    Mileage: 85067 km
                    Date: 2020.10.24
                    Time: 12:17:39
16656 - Databus
                    Reset counter: 221
                    Mileage: 85067 km
                    Date: 2020.10.24
                    Time: 12:16:22
   Component: IMMO          H04 0905
   VCID: 6AD12C1C8D846ED6AD-803E
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000128458362
   Coding: 01150220D001231004
   VCID: 4689B8ACF15C6AB669-8012
   Revision: 00H22000
                    Reset counter: 221
                    Mileage: 85121 km
                    Date: 2015.03.17
                    Time: 17:14:41
                    Voltage: 12.25 V
                        DD
                    Temperature: 38.0°C
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000127704807
   Coding: 01150020D001231004
   VCID: 458BBFA0CC5A61AE60-8010
   Part No SW: 5L0 035 200     HW: 5L0 035 200
   Component: MU-S--ER      H05 0135
   Serial number: SKZAZ2P4653911
   Coding: 03130600FF00000011510001000828002F0000C60120810000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 5BBF79D852DE075E26-800E
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 E    HW: 7N0 959 795 E
   Component: TSG HL        H03 0553
   Revision:             Serial number: 0000128362335
   Coding: 010000200001531004
   Revision: 3A001001    Serial number: 00008200086696
   Coding: 0300000100000000
   Shop #: WSC 23068 002 1048576
   VCID: 3065FE7463D8D406A3-8064
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H03 0553
   Revision:             Serial number: 0000128363520
StinkyPete
C?ID=114757
It turned out my hunch was right!! The ABS sensors on the left side are the same both front and rear so I swapped them around, cleared the DTC's and started the car up. The lights re lit immediately and a quick VCDS scan showed the fault had moved to the front. I replaced the sensor with a new one, cleared all the codes and the Xmas tree dashboard is no more. I can't really explain the loss of power around the time the fault happened but such is life...... The car is running fine with no issues now.
