- Oct 24, 2020
- 3
- 0
- Cambridge, UK
- C?ID=385590
hi everyone. is here someone to help me? the car run and drive smooth. i already replaced the DPF differential pressure sensor and the exhaust pressure control valve(flap). the errors keep coming up.
Saturday,24,October,2020,14:15:29:09482
VIN: WAUZZZ8T1GA006097 License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72 AC
VIN: WAUZZZ8T1GA006097 Mileage: 120770km-75042miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 CL HW: 04L 907 309
Component: R4 2,0L EDC H23 8249
Revision: 85H23---
Coding: 0A194012232401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01104L906021CL 002009
ROD: EV_ECM20TDI011_AU48.rod
VCID: 71BFD2A8912B4A23ADD-8024
5940 - Exhaust Pressure Control Valve
P0475 00 [039] - Electrical Malfunction
Mileage: 120775 km
Date: 2020.10.24
Time: 14:03:55
Engine speed: 829.50 /min
Normed load value: 29.8 %
Coolant temperature: 73 °C
Intake air temperature: 59 °C
Voltage terminal 30: 13.780 V
Particle filter outlet temp.sens.1 bank 1: raw value: 86.4 °C
Exh.recircul.valve 1 bank 1: pos.feedback - Spec.value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback -Offset closed.: -0.74 %
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 55
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 25
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 0
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 7
Exh.recircul.valve 1 bank 1: pos.feedback - Uncnd vlt: 4310.6 mV
5923 - Exhaust Pressure Control Valve
P047F 00 [039] - Stuck Open
Mileage: 120775 km
Date: 2020.10.24
Time: 14:03:48
Engine speed: 828.00 /min
Normed load value: 29.4 %
Coolant temperature: 72 °C
Voltage terminal 30: 13.740 V
Particle filter outlet temp.sens.1 bank 1: raw value: 85.8 °C
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 24
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Coding: 411DCC01
Shop #: WSC 06325 000 00000
VCID: 074B9C708F2F6493139-8052
Part No SW: 8K0 907 064 KE HW: 8K0 907 064 KE
Component: BCM2 2.0 H15 0711
Coding: 03B44040000000000000
VCID: 7DA7FE98DDF33E43395-8028
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0815000071488007
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000103670010
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 BB HW: 8K2 820 043 BB
Revision: D1000000 Serial number: 01160620150109
Coding: 342400A000
VCID: 6A8DC5C4BC7DB9FBEC7-803E
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001091450602
Coding: 260000108034AFC00081400300001D0D001D030827090201000008004400020100000024000000
VCID: 78A9EF8CF2D11B6B6A3-802C
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 300515 H13 0080
Serial number: SWF15055305011
Coding: 00FD11
Component: G397_RLFS H06 0004
Serial number: 20365756
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002805151466
Serial number: 14F8CCA7000000000001
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H49 0610
Serial number: 003KFDD067JA
Coding: 30533938363030303030554A305238543053
VCID: 48C95F4CC231ABEBDA3-801C
Serial number: 6334MSME527B6B5BV
Serial number: 6344MSME520971356
Serial number: 6352QSME01540C6EJ
Serial number: 6362QSME405026702
Serial number: 63732SME63582378+
Serial number: 63832SME66580B564
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OFI000ID
Coding: 000016
VCID: 48C95F4CC2B1ABEBDA3-801C
Part No SW: 8T0 920 984 K HW: 8T0 920 984 K
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 5L+47NF6G
Coding: 33A5300003012600010000
VCID: 47CB5C70CFAFA493D39-8012
Part No SW: 8R0 907 468 T HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0070
Revision: 1Y090032 Serial number: 3241Y155250198
Coding: 80CF07FF00
VCID: 50F9772C3AE1632B823-8004
Serial number: 1109406903
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 15164000492011200410
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011002625C01450005
VCID: 56F5813418050D1B58F-8002
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0001884156
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E25399490F5E55B60F-806A
Revision: 00002001 Serial number: 0371104923
Coding: 013B0622A0B900C08320043680000047
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813045289406
VCID: 2D070ED84D136EC3C95-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
Coding: 011002225E01450005
VCID: 55F7863805030603515-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000386760
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D35848CDDC97B5C7-806E
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109F$0F8043557
Coding: 010103010000000001
VCID: 2B0300C0730760F3D71-807E
Part No SW: 8R2 035 666 J HW: 8R2 035 666 H
Component: H-BN-EU H49 0941
Revision: -------- Serial number: 515F 0F7540383
Coding: 130101040006A1ED01808B5E00000403E40000020000000000
VCID: 40D9476CEA8193AB123-8014
Subsystem 1 - Part No: 8R0 060 884 CR
Component: EUR 2015 2102
Component: DU7 High H42 0104
Serial number: A130FV0F3383463
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000002273208
Component: CD-Database 6208
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010002224001450005
VCID: 59EF8A08691B226375D-800C
Component: TSG HR H08 0305
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 151550524
ROD: EV_RDCMA00100.rod
VCID: 2D070ED84D936EC3C95-8078
End----------(Elapsed Time: 01:42, VBatt start/end: 14.5V/14.6V)-----------
