Heated steering wheel retrofit
MacFever
Belgium
C?ID=186814
I have retrofitted a heated steering wheel in my Golf 7.5 R DSG from 2017
I changed clockspring, HVAC and DSG wheel with heat (and new airbag)
I used a Kufatec 16 to 14 pin adapter for the clockspring
Physically all is good BUT problems :
VCDS cant reach steering wheel anymore and plenty of malfunctions
Buttons on steering wheel dont work, car wont close up anymore I think due to the car does not recognize park position
Do I have to reprogram the clockspring ?
Sunday,18,October,2020,18:20:03:62293
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZAUZJW070108   License Plate:
Mileage: 106918km-66435mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 4B
          52 5F A5 A9
VIN: WVWZZZAUZJW070108   Mileage: 106918km-66435miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DJHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500122466050B3004
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 479DB9B4FE5EA1BE92-8012
20662 - Oxygen (Lambda) Sensor B1 S1
          P0131 00 [096] - Signal too Low
15077 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
                    Mileage: 106842 km
                    Date: 2020.10.17
                    Time: 08:38:32
                    Engine speed: 843.75 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 77 ∞C
                    Intake air temperature: 28 ∞C
                    Voltage terminal 30: 14.492 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 500 s
                    MAP_MES_SAE: 34 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.017 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 8050.0 kPa
17176 - Databus
17178 - Databus
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
                    Engine speed: 1324.50 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 9 ∞C
                    Intake air temperature: 10 ∞C
                    Voltage terminal 30: 11.542 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
21406 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
14870 - Bank 1: Camshaft A (Intake)
          P0011 00 [096] - Retard Setpoint not Reached (Over-Advanced)
                    Mileage: 104304 km
                    Date: 2020.09.02
                    Time: 21:14:52
                    Engine speed: 948.75 /min
                    Normed load value: 18.8 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 106 ∞C
                    Intake air temperature: 39 ∞C
                    Voltage terminal 30: 14.667 V
                    Unlearning counter according OBD: 31
                    CAM_VCP[IN_1]: 27.141 ∞
                    CAM_SP_IND_VCP[IN_1]: 15.500 ∞
                    MAP_MES_SAE: 33 kPa
                    Engine oil temperature: 106.0 ∞C
                    PWM_HLD_VCP[IN_1]: 44.037 %
                    STATE_PWM_VCP[IN_1]: pas
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1401
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2149072C303ABF8E3C-8074
   Revision: 00000000    Serial number: 62277000000861
   Coding: 01FA6BA15427216C4778070040CB6980D62A84E2E0029677384250F8C2A8430000000012121212B835351919323200
   VCID: 77FD0974CE3E113E22-8022
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:09
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0452389503
   Coding: 032C0C
   VCID: 3C77D658B798F2660F-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002001420041001110500020010102A
   VCID: 6DD12B1CBC62ABEEC8-8038
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
          B10CD 00 [008] - -
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.17
                    Time: 13:05:38
                    Voltage terminal 30: 10.5 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001723802089
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081F7A88B3C06EC65B-805C
   Component: WWS    170725  043 0551
   Serial number:         170816033156
   Component: RLHS  047 0105
   Serial number: S4Y17M08D30H01M47S23
   Coding: 00A8EE
   Serial number: 000000000ZY172040PN4
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971912870
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001QFPB600000
   Coding: 181801
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 92
                    Mileage: 106242 km
                    Date: 2020.09.25
                    Time: 00:00:46
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 64
                    Mileage: 102329 km
                    Date: 2020.08.14
                    Time: 09:30:59
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617230
   Coding: 0471155811
   VCID: 4B958584E23645DEB6-801E
13637426 - Databus
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C15DFFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E73DC50A184E07621-806A
2055 - Databus
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:11
                    Control Module temperature: 11 ∞C
                    Voltage terminal 15: 11.6 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
0803 - Databus
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
                    Voltage terminal 15: 11.5 V
2101 - Databus
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
                    Status_ACC_System: ACC_Init
2068 - Databus
                    Reset counter: 144
                    Mileage: 104304 km
                    Date: 2020.09.02
                    Time: 21:14:53
                    Control Module temperature: 29 ∞C
                    Voltage terminal 15: 13.2 V
                    Velocity_vehicle_reference: 3.25 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.08 m/s≤
   Serial number: 25071741350816
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 387FCA4883A0DE46EB-806C
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    005 0336
   Serial number: 003VVR3979G7
   Coding: 98CCC000000000005C0000CF000800000065
   VCID: 071D79B4BEDE61BE52-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 002 808 17
   Serial number: 35700000000D0DD4D72.
   Subsystem 2 - Part No SW: -----------    HW: 480 002 508 17
   Serial number: 3580000000063B5CD62V
   Subsystem 3 - Part No SW: -----------    HW: 480 402 208 17
   Serial number: 3510001B3268F0A356F8
   Subsystem 4 - Part No SW: -----------    HW: 480 401 908 17
   Serial number: 3520001C32645342470K
   Subsystem 5 - Part No SW: -----------    HW: 480 402 408 17
   Serial number: 3550001C92527AF39226
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 27081704220507
   Coding: 0C10
   VCID: 09197F8CA8CA17CE44-805C
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 03AD301E7F8C000801886B0B5401000080000000
   VCID: 2A5BE0004D0C7CD66D-807E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006716870
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3365FD649AC63D1EDE-8066
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160001432300046295
   Coding: 2DFFFF
   Serial number: 1498805004
8526363 - Crash Shut-Down
          B189C F0 [009] - Active
                    Reset counter: 104
                    Mileage: 88741 km
                    Date: 2019.11.07
                    Time: 14:46:29
                    Supply voltage: Terminal 30: 11.5 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.17
                    Time: 13:03:10
                    Supply voltage: Terminal 30: 10.6 V
                    Terminal 15: On
   Serial number: HA1-00003.07.17
   Coding: 0001
   VCID: 4A9B8080ED4C5CD68D-801E
   Revision: 00000000    Serial number: 17000231395002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467FE789FC83A26C7-8060
   Component: HRE_Master    H12 0080
   Serial number: 0450454321
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D71DB5CAC82FB6E38-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0445414616
   Coding: 020111
   Serial number: 120817EHC28488
   Coding: 003F1220D000040000001000
   VCID: 4385ADA4CA668D9E4E-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000016033352
   Coding: 110000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 137
                    Mileage: 106676 km
                    Date: 2020.10.10
                    Time: 22:22:55
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A7BD040BDACCC561D-806E
16272 - Steering Angle Sensor
                    Reset counter: 108
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.00 V
                    Temperature: 24.0 ∞C
                    KFC: 3F
                    KFA: 00 90
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.02 V
                    uAdSensI_SwitchedKl30_xdu16: 12.01 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD00T92J
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E53EC1071E410F6B1-807A
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 220717EGM06333
   Coding: 003F1020DE00040000801000
   VCID: 428BA8A0D57C849645-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000015932781
   Coding: 090000
   Part No SW: 5NA 035 022 A    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1121
   Serial number: A846H0HS006621
   Coding: 02731001000000005111010200880A101F0107F4012004009F
   VCID: 3169F76C60DA0F0EAC-8064
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2320690
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 18081712P11259
   Coding: 0003070000000401002623548150A90098000E300040
1123173 - Databus
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:11
                    Outside air temperature: 9.5 ∞C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1275 - Unknown Error Code
          B182E F0 [008] - Unknown Error Elaboration
                    Reset counter: 185
                    Mileage: 99451 km
                    Date: 2020.07.25
                    Time: 12:26:29
                    Control Module temperature: 56 ∞C
                    Outside air temperature: 26.0 ∞C
                    Vehicle speed: 13.51 km/h
                    System run time: 3417.1 s
                    mid: 01 63
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 170725201890
   VCID: 2F6DF11476EE19FEBA-807A
End-------------------------(Elapsed Time: 05:43)--------------------------
Address 19,3Q0 907 530 G,channel IDE08348-Start/stop start voltage limit,adapted from,7.6 V,to,12 V,
After I did another log :
Friday,23,October,2020,18:15:08:62293
Mileage: 107056km-66521mi   Repair Order:
          52 5F A5 A9
VIN: WVWZZZAUZJW070108   Mileage: 107056km-66521miles
16-Steering wheel -- Status: Cannot be reached 0100
   Revision: --H13---
7 Faults Found:
                    Mileage: 106842 km
                    Date: 2020.10.17
                    Time: 08:38:32
                    Unlearning counter according OBD: 33
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 500 s
                    MAP_MES_SAE: 34 kPa
17176 - Databus
17178 - Databus
          U1123 00 [096] - Received Error Message
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
                    Unlearning counter according OBD: 34
                    Mileage: 104304 km
                    Date: 2020.09.02
                    Time: 21:14:52
                    Unlearning counter according OBD: 25
                    MAP_MES_SAE: 33 kPa
19854 - Steering Column Control Module
          U0212 00 [039] - No Communications
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:28
                    Engine speed: 1376.25 /min
                    Normed load value: 24.3 %
                    Coolant temperature: 17 ∞C
                    Intake air temperature: 19 ∞C
                    Voltage terminal 30: 11.503 V
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 13.0 ∞C
                    Time since engine start: 0.4 s
                    T_ES: 20 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: No
                    T_AST_SAE: 0 s
   Revision: 00H06V07
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:09
   Coding: 032C0C
   Part No SW: 5G1 907 044 P    HW: 5G1 907 044 P
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 08020104203100011105100C0010110A
   ASAM Dataset: EV_ACClimaBHBVW37X 005134
   VCID: 3561C37C94B2232EF0-8060
   Air quality sensor:
8 Faults Found:
328455 - Position Sensor for Rear Temperature Flap Motor
          B1096 15 [009] - Open or Short to Plus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:00:05
                    Voltage terminal 30: 12.0 V
                    Outside air temperature: 17.5 ∞C
                    Interior temperature: 0.0 ∞C
                    Rear temperature flap: actual value: 0.0 %
                    Rear temperature flap: actual value: 20
                    Rear temperature flap: specified value: 15
197634 - Temperature Sensor for Rear Vent
          B1089 15 [009] - Open or Short to Plus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Voltage terminal 30: 12.1 V
459020 - Databus
                    Reset counter: 150
                    Mileage: 5208 km
                    Date: 2016.10.18
                    Time: 00:00:05
459021 - Databus
                    Reset counter: 150
                    Mileage: 5208 km
                    Date: 2016.10.18
                    Time: 10:58:38
262914 - Refrigerant Pressure
          B10AB F0 [024] - Too Low
                    Reset counter: 107
                    Mileage: 5208 km
                    Date: 2016.10.18
                    Time: 00:00:07
                    Outside air temperature: 20.0 ∞C
                    Engine speed: 0 /min
                    Temperature after evaporator: 19.7 ∞C
                    System run time-Terminal 15 on: 5 s
590084 - Control Module for Auxiliary Heater
          B10C0 31 [009] - No Signal
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:31
                    Voltage terminal 30: 13.5 V
                    System run time-Engine running time: 4 s
                    System run time-Terminal 15 on: 4 s
459027 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:35
655618 - Control/Display Unit for Rear Climatronic
          B10AA 31 [009] - No Signal
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:32
   Coding: 00A8EE
   Sun Roof:
   Coding: 181801
                    Reset counter: 92
                    Mileage: 106242 km
                    Date: 2020.09.25
                    Time: 00:00:46
                    Reset counter: 64
                    Mileage: 102329 km
                    Date: 2020.08.14
                    Time: 09:30:59
544533 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:00:07
559381 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:30
   Coding: 0471155811
12718594 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:33
13637426 - Databus
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
13688835 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:33
7 Faults Found:
2055 - Databus
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:11
0803 - Databus
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
2101 - Databus
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:10
2177 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:33
                    Control Module temperature: 20 ∞C
                    Voltage terminal 15: 14.0 V
1076 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:28
                    Voltage terminal 15: 11.4 V
1116 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:59
                    Control Module temperature: 21 ∞C
                    Voltage terminal 15: 14.5 V
                    Velocity_vehicle_reference: -0.23 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.40 m/s≤
2068 - Databus
                    Reset counter: 110
                    Mileage: 104304 km
                    Date: 2020.09.02
                    Time: 21:14:53
16776975 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:32
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
131596 - Steering Column Control Module
          U0212 00 [009] - No Communications
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:30
                    Supply voltage: Terminal 30: 11.6 V
                    Terminal 15: On
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:00:02
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: OFF
                    Reset counter: 110
                    Mileage: 88741 km
                    Date: 2019.11.07
                    Time: 14:46:29
                    Terminal 15: On
                    Reset counter: 143
                    Mileage: 106880 km
                    Date: 2020.10.17
                    Time: 13:03:10
                    Terminal 15: On
   Coding: 0001
12666373 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:00:04
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: 20 01
                    WFS State: 00 06
                    Voltage: 68
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Coding: 02011103
   Coding: 020111
119301 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:28
   Coding: 110000
                    Reset counter: 137
                    Mileage: 106676 km
                    Date: 2020.10.10
                    Time: 22:22:55
   Coding: 9107
                    Reset counter: 115
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 18.0 ∞C
                    KFC: 3F
                    KFA: 00 90
                    uioUdNotFilt_xdu16: 12.23 V
                    uAdSensI_SwitchedKl30_xdu16: 12.24 V
   Coding: 090000
1123173 - Databus
                    Reset counter: 150
                    Mileage: 106880 km
                    Date: 2020.10.18
                    Time: 10:49:11
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123369 - Databus
                    Reset counter: 110
                    Mileage: 107056 km
                    Date: 2020.10.21
                    Time: 00:10:34
                    System run time: 7.8 s
                    Voltage terminal 15: 14.1 V
                    mid: 02 91
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
                    Reset counter: 108
                    Mileage: 99451 km
                    Date: 2020.07.25
                    Time: 12:26:29
                    mid: 01 63
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End-------------------------(Elapsed Time: 06:01)--------------------------
