New guy with the proverbial "help me please"
MTHines
SC, USA
I'll cut to the chase....looking to add an "AUX" input for a CarPlay unit (vendor is no help) I added to my 2017 S8. I saw a walk through to do that but ended up not seeing the same options on my side.
The pic below is where my efforts ended. Any help would be greatly appreciated. My scan will be below the pic link if I've done everything right. TIA
Link with walk through: https://integratedautomotive.co.uk/activating-aux-input-on-audi-mmi-3g-and-mmi-mib1/
pic noting limited coding - https://photos.google.com/photo/AF1QipOL3PCr3zDSRmFUUxMjXWm_6P_5GnrpZQ_JEjAY
Friday,23,October,2020,14:32:02:54171
VIN: WUAJ5AFD5HN900402 License Plate: S8
Mileage: 43328km-26922mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C
42 44 46 47 52 53 55 56 5F 62 65 6C 6D 6F 72 81 82 85 88 89
8B 8E 8F 90 A9 BA
VIN: WUAJ5AFD5HN900402 Mileage: 43328km-26922miles
6F-Centr. Conv. II -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
Address 01: Engine (------DDTA) Labels: None
Part No SW: 4H0 907 557 H HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 022A00326546000E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0907557H 001002
ROD: EV_ECM40TFS011_AU64.rod
VCID: 35372AC1E5CC4F13B15-8060
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [096] - Too Lean
Mileage: 42868 km
Date: 2020.10.12
Time: 16:06:52
Engine speed: 2188.00 /min
Normed load value: 16.5 %
Vehicle speed: 87 km/h
Coolant temperature: 99 °C
Intake air temperature: 50 °C
Voltage terminal 30: 13.664 V
Unlearning counter according OBD: 20
Engine status: COENG_RUNNING
Part No SW: 4H1 927 158 FF HW: 0BK 927 156 AD
Component: 0BK 40TFSIUSA H19 1006
Revision: --H19---
VCID: 79AFE6F189546B7315D-802C
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AC HW: 4H0 907 379 AC
Component: ESP PREMIUM H10 0930
Coding: D2FD82004BBF4100E200
ASAM Dataset: EV_ESPPremi 005025
ROD: EV_ESPPremi_005_AU64.rod
VCID: 73B3D4D9AB3811235F1-8026
0728 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Net_Dimmung_01_KL_58d_Error]
Reset counter: 15
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:02
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 31
F-Type: 21
Uz: AD
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H43 0582
Coding: 0D876F4E000000000000
VCID: 74B1D7C5AEB6161B46B-8020
Serial number: 3216000137991010
Fault Status: 00101101
Reset counter: 15
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:05
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000208474421
Coding: C018320085043201010001010101112131313333283333
VCID: 35372AC1E54C4F13B15-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 P HW: 4H0 820 043 P
Component: Klima 4 Zonen H20 0210
Coding: 680120785C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2D0702A10D9C07D3C95-8078
0245 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 56
Mileage: 38954 km
Date: 2020.06.05
Time: 16:48:19
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 1
Mileage: 42820 km
Date: 2020.10.01
Time: 22:33:00
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 GB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0368
Revision: 19020001 Serial number: 00001421339202
Coding: 01050011043C9FF2F90048C4A0003800009CD308AA08022180000894710017000060002D0B0000
VCID: 6E85C5ADC09A3CCBB0F-803A
Subsystem 1 - Part No SW: 4H1 955 119 D HW: 4H1 955 119 A
Component: WWS641 160605 H38 0100
Serial number: 160620203616
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 62066972
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Serial number: 14 07 2016 00002199
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02591D4C
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA124397000022592944
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 26B84A3800PAG0MUFU03
01229 - A/C Humidity Sensor (G260)
014 - Defective
Fault Status: 01101110
Reset counter: 56
Mileage: 38954 km
Date: 2020.06.05
Time: 16:48:25
01800 - Light Switch (E1)
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 00:00:01
03280 - Switch Position of Light-Switch Knob
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 00:00:11
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:11
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H21 0055
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002026
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2B030CB9338809E3D71-807E
12544 - Yaw Rate 1
C1020 85 [008] - Signal above allowable range
Reset counter: 239
Mileage: 42695 km
Date: 2020.08.24
Time: 23:21:50
Control Module temperature: 73 °C
Voltage terminal 15: 14.034 V
Velocity_vehicle_reference: -0.02 m/s
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_LRRS_FAIL]
Reset counter: 239
Mileage: 42695 km
Date: 2020.08.24
Time: 23:21:42
Voltage terminal 15: 13.866 V
Part No SW: 4H0 959 655 G HW: 4H0 959 655 G
Component: Airbag10.43 H63 0093
Revision: -------- Serial number: 003KC001DZ97
Coding: 303331323130303231384A55304C34483053
VCID: 3A2D39FDCCD2A06B5C7-806E
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R166140BKR5
Serial number: 3575HRB400K55BUCBP7X
Serial number: 3585HRB400O55CGC924/
Serial number: 3515JRB400C571NC88S7
Serial number: 3525JRB400Q571NCQPOA
Serial number: 3554VRB40145761QL12Z
Serial number: 3564VRB40145761QB12Q
1048581 - Databus
[CAN: 0x5F0 Dimmung_01 error value DI_KL_58d]
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:03
Revision: -------- Serial number: 01335PGB0008O
Coding: 0000FC
VCID: 372B20C9FF40BD03A39-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Serial number: 24 03 2016 B0071660
Reset counter: 15
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:00
Part No SW: 4H0 920 881 B HW: 4H0 920 881 B
Component: TBenUSAACCNV- H55 0902
Revision: 41081213 Serial number: 658150716592033
Coding: 0B470803BF51D705020100
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 2A0D09BD3C7210EB2C7-807E
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 P HW: 4H0 919 204 P
Component: Analoguhr D4 H05 0225
Serial number: 2160607001156
Part No SW: 4H0 907 468 AH HW: 4H0 907 468 AC
Revision: -------- Serial number: 00000002319554
Coding: 80E1034804
VCID: 77ABE0C9BF407D03639-8022
Subsystem 1 - Part No SW: 4H0 915 181 G HW: 4H0 915 181 G
Component: J367-BDM H08 0270
Serial number: 53188B07531481346599
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 19
Mileage: 43318 km
Date: 2020.10.22
Time: 16:17:29
Voltage terminal 30: 11.7 V
Voltage terminal 15: 0.0 V
Control Module temperature: 36 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 19
Mileage: 43329 km
Date: 2020.10.22
Time: 22:00:12
Voltage terminal 30: 12.1 V
Control Module temperature: 26 °C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 19
Mileage: 42820 km
Date: 2020.10.01
Time: 22:22:10
Voltage terminal 30: 11.2 V
Voltage terminal 15: 11.3 V
Control Module temperature: 25 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 090000
VCID: 3A2D39FDCC52A06B5C7-806E
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 A HW: 4H0 857 511 A
Component: FLA H04 0021
Revision: AB001001
Coding: 04018B6B74745D545420363E00
VCID: 2809F3B522FE22FB3A3-807C
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 001007160001022
VCID: 2809F3B5227E22FB3A3-807C
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 J HW: 4H0 919 158 J
Component: Klima Fond H17 0200
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck.rod
VCID: 372B20C9FFC0BD03A39-8062
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B18A9079075C3FB9-807A
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000208473991
Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7100UYWC
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 382923F5F2DEB27BAA3-806C
Part No SW: 4H0 907 566 F HW: 4H0 907 566 F
Component: SWA Master H08 0040
Serial number: 0408648191
Coding: 040211
ROD: EV_LaneChangAssis_VW51.rod
VCID: 333314D9EBB851239F1-8066
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4H0 907 568 F HW: 4H0 907 568 F
Component: SWA Slave H08 0040
Serial number: 0403714515
Coding: 040211
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H08 0280
Revision: -------- Serial number: 0000208530552
Coding: 011F1F005E0062C202003017
VCID: 48C9533582BEC2FBDA3-801C
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000092666
Coding: 011001010000
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0410177922
Coding: 0106023A00FA7185B0B0C7C0020316000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000358116
Subsystem 3 - Part No SW: 4H0 959 591 B HW: 8V3 959 591 A
Component: J245 PS50.402 H03 0004
Serial number: 0000FST0012C4VE00000
Coding: 101F00
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H13 0080
Serial number: A2016000000000126854
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS014 H06 0005
Serial number: WOO1000HN1G
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93827563
Reset counter: 15
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:05
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000019701
Coding: 030000
VCID: 1C61DF6566A6FE5BAEB-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H08 0280
Revision: -------- Serial number: 0000208580625
Coding: 011F1F005E0062C202003006
VCID: 3C213FE5C6669E5B4EB-8068
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001921828
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313F1ED111A46333EDD-8064
465152 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_DI_KL58D_ERROR_VALUE]
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:01
Voltage terminal 30: 11.4 V
Internal Fault ID: 191
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Component: MxB-ECU 001 0100
Coding: 02720A1122600400
VCID: 343117C5EEB6561B86B-8060
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E00200
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E00200
13706005 - Databus
[Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_11]
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:08
Address 56: Radio (R) Labels: None
Part No SW: 4GD 035 082 H HW: 4GD 035 082
Component: Radio U SIRIU H66 0138
Revision: AB001007 Serial number: 315GX0G2510917
Coding: 020007010000000001
VCID: 392F26F1C954AB7355D-806C
Part No SW: 4H0 035 746 M HW: 4H0 035 746 J
Component: H-BNT-NA H44 1038
Revision: -------- Serial number: 503GY0G7525521
Coding: 03020000020BFDEF7D12CB1E00000003140001000000000000
VCID: 323D11DD1422582B947-8066
Subsystem 1 - Part No: 8R0 060 884 DQ
Component: NAR 2016/2017 1402
Subsystem 2 - Part No SW: 4H0 919 604 H HW: 4H0 919 604 H
Component: DU8 D4 SV NB H63 0060
Serial number: AUZ8ZDGY900YGZH
Subsystem 3 - Part No SW: 4H1 919 600 M HW: 4H1 919 600
Component: E380 BDT D4 H11 0110
Serial number: 00000000222236
Component: CD-Database 6890
02244 - Button in Control Head is Stuck
Reset counter: 17
Mileage: 43308 km
Date: 2020.10.21
Time: 14:03:36
Voltage: 14.10 V
Hex Value: 0x0005
not available
Fault Status: 00101011
Fault Frequency: 148
Reset counter: 14
Mileage: 42681 km
Date: 2020.08.21
Time: 10:29:21
Voltage: 12.40 V
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H08 0280
Revision: -------- Serial number: 0000209959191
Coding: 010F1F00400062C202003006
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000030160
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0187279
Coding: 020F000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Functional limitation by undervoltage]
Fault Frequency: 8
Reset counter: 1
Mileage: 42819 km
Date: 2020.10.01
Time: 16:42:55
Voltage terminal 30: 7.8 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 184600954
Coding: 021004C120
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBBD8A9C71035C3BB9-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000213220
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393A4991BD881A32F1-8036
0086 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Funktionseinschraenkung durch empfangenen Fehlerwert des Signals DI_KL_58s]
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:03
Voltage terminal 30: 13.7 V
Control Module temperature: 32 °C
Processor load: 35.0 %
Color setting Ambient: Red
Status terminal 58s: On
Component: TSG HR H08 0280
Revision: -------- Serial number: 0000209959192
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H09 0083
Revision: 0L0D5015 Serial number: SN160624 0167
ROD: EV_GSM2x3Mono_AU64.rod
10001 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[CAN__MSG_DIMMUNG__ERROR]
Reset counter: 16
Mileage: 43308 km
Date: 2020.10.21
Time: 11:48:01
Voltage terminal 15: 10.2 V
Voltage terminal 30: 10.3 V
Driving position: P
Selector lever position: drive lane (X)
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4H0 919 617 HW: 4H0 919 617
Component: HeadUpDisplay H20 0023
Coding: C20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 6D87C2A1CD1CC7D3895-8038
Component: DPC-SG H27 0081
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C010FA536860EDBDEB-8078
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00027384071801
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00027384073101
Coding: 364FF2
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7601010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002023
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 290FF6B139741BF325D-807C
12544 - Yaw Rate 1
Reset counter: 239
Mileage: 42695 km
Date: 2020.08.24
Time: 23:21:42
Control Module temperature: 66 °C
Voltage terminal 15: 13.919 V
Component: BV-SG H34 0090
Serial number: 005002450807167
Coding: 01C19A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H16 0080
Coding: 0066F609031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 323D11DD14A2582B947-8066
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 160423200056
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813007107401
ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 03:12, VBatt start/end: 14.5V/14.4V)-----------
@MTHines: Hi. Based purely on the instructions from Integrated Automotive in your link -I note that Byte8 of the long-code string on your hex5F module has the value hex7D, or Binary 0111 1101. Remembering that Binary numbers are read from right-to-left (so, Bit0 is the right most digit), this means that Bit4(the bold Bit)=1 and Bit5 (the Bit in the larger font)=1.
Integrated Automotive says "In order to successfully activate the AUX-IN[PR-UE3] on your MMI head unit, you will need to first deselect AMI[PR-UE7]"
So - it seems that you have indeed activated Bit4 (i.e. AUX-IN[PR-UE3]). However, apparently you need to deselect Bit 5 (i.e. AMI[PR-UE7]) - which means that the Binary number for Byte 8 should be 0101 1101, or hex5D.
When you have made the change correctly, check that the long-code string on the hex5F module reads;
03020000020BFDEF5D12CB1E00000003140001000000000000
MTHines
SC, USA
Thanks Don!! I'm gonna need more coffee before I attempt that this morning. Gonna take me a bit to grasp what you are telling me LOL
@MTHines: My apology for launching into techno math speak - I often make the mistake of being lazy in my explanations (it's a habit that I should address)!
What I should have said is that the difference between the data in your auto-scan and the instruction in your link purely relates to Byte 8, Bit 5 on the long code in the module Address 5F: Information Electr. (J794) in your auto scan.
To fix this- simply follow the instructions in your link and remove the tick from Bit5 on the screenshot below (which I have thieved from your link):
If you have correctly done this, when you get to the screenshot below (again thieved from your link):
- you should see the following long code values in the 2 x boxes:
Current coding: 03020000020BFDEF7D12CB1E00000003140001000000000000
New Coding: 03020000020BFDEF5D12CB1E00000003140001000000000000
Once you have confirmed these values - complete the instructions in your link
MTHines
SC, USA
Thanks again Don and I apologize for making a mess of my explanation.
I sorted out accessing the green screen and activated the AUX input through that.
