2012 CC low voltage issues no start
keokitron
WA, USA
C?ID=416824
below is my full scan of the car. I have tested the starter, alternator, every fuse and relay I could find
also fully charged the battery but still almost every system in this car is showing low voltage
I think I found every ground connection in the engine bay all seemed to have a good no connection and no corrosion
also driver window will not roll up.
im thinking there is a short somewhere which is constantly drawing power causing all the systems to have low voltage
any ideas to look for would be super helpful
thanks in advance
Wednesday,21,October,2020,16:01:13:25509
VCDS Version: 20.4.2.0 (x64) HEX-NET2 CB: 0.4527.4
VIN: WVWMP7ANXCE504692 License Plate:
Mileage: 187200km-116320mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 56 62
          65 72 77
VIN: WVWMP7ANXCE504692   Mileage: 187200km-116320miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 027 FD HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 3951
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 040401081C070160
Shop #: WSC 26061 444 100755
   VCID: 72B6B150D8A91BCB547-8026
001378 - System Voltage
P0562 - 000 - Too Low
Temperature: 3.0°C
Temperature: 6.0°C
Absolute Pres.: 990.0 mbar
                    Voltage: 8.255 V
012372 - Starter Will Not Turn
P3054 - 000 - Jammed or Electrical Malfunction - Intermittent
RPM: 122 /min
Temperature: 12.0°C
Temperature: 19.0°C
                    Voltage: 8.128 V
000274 - Intake Air Temp. Sensor (G42)
P0112 - 000 - Signal too Low - Intermittent
RPM: 259 /min
Load: 48.6 %
Temperature: 11.0°C
Temperature: 141.0°C
Absolute Pres.: 1000.0 mbar
                    Voltage: 10.795 V
Readiness: 1110 1101
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 3509
Revision: 05351112 Serial number: 00001011141325
Shop #: WSC 44551 111 44551
   VCID: 251C9A0C59E73C73015-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
Component: J104 C2 450M V4D2 0005
Revision: --H07--- Serial number: 00000003550861
Coding: 0000399
Shop #: WSC 05311 000 00000
   VCID: 37204044F34BBEE3A39-8062
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:07:50
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 8.25 V
Bin. Bits: 00111110
Count: 115
                    Hex Value: 0x0000
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
Shop #: WSC 00015 115 00000
ROD: EV_ClimaBasis_VW46.rod
   VCID: 3D2C526CDDF794B3795-8068
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:07:33
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
Component: BCM PQ47 H+ 413 0452
Revision: BC413001
Coding: 0000000000000000009802259400840440517C8840600D605C8060200040
   VCID: 3924467CC95FA89355D-806C
   Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
Component: Wischer 17111 10 0603
   Coding: 00B795
Component: RLS 101210 05 54 0403
   Coding: 0330ED
9 Faults Found:
Fault Frequency: 24
Reset counter: 250
Mileage: 187205 km
Date: 2014.03.30
                    Time: 00:13:38
Term 15 Off
Voltage: 13.05 V
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:07:17
Voltage: 7.65 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 250
Mileage: 187205 km
Date: 2014.03.30
                    Time: 00:13:51
Term 15 Off
Voltage: 12.45 V
00985 - Right Tail Light (M2)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 211
Mileage: 165684 km
Date: 2012.11.07
                    Time: 19:59:15
Voltage: 13.90 V
Fault Status: 00101010
Reset counter: 250
Mileage: 157288 km
Date: 2012.05.30
                    Time: 13:36:19
Voltage: 14.20 V
01516 - Terminal 30; Left
Reset counter: 250
Mileage: 187205 km
Date: 2014.03.30
                    Time: 00:13:52
Term 15 Off
Voltage: 12.45 V
Reset counter: 210
Mileage: 157288 km
Date: 2012.05.30
                    Time: 13:36:12
Voltage: 14.20 V
Fault Frequency: 65
Reset counter: 202
Mileage: 157288 km
Date: 2012.05.30
                    Time: 13:36:12
Voltage: 14.20 V
Fault Status: 00101001
Reset counter: 250
Mileage: 187204 km
Date: 2014.03.30
                    Time: 08:09:23
Term 15 Off
Voltage: 12.60 V
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__30S VW10 HI 1918
Revision: 22014000 Serial number: 003JZPPKFS42
Coding: 0012371
   VCID: 4BC80CB49FC32A03F71-801E
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000025A5
   Subsystem 3 - Serial number: 0011.11.100000300000650158ÿ†63
   Subsystem 4 - Serial number: 650158ÿ†6332MTS648993210 ÿ†63
   Subsystem 5 - Serial number: 93210 ÿ†6342MTS692143120 ÿ†63
   Subsystem 6 - Serial number: 43120 ÿ†6351HTS6MO4KH9KR ÿ†63
   Subsystem 7 - Serial number: KH9KR ÿ†6361HTS6TACRH9KR ÿ†63
   Subsystem 8 - Serial number: RH9KR ÿ†63727TS6EOPUF6KR ÿ†63
   Subsystem 9 - Serial number: UF6KR ÿ†63827TS6JHHUF6KJ ÿ
   Subsystem 10 - Serial number: UF6KJ ÿ
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:05:42
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 42
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:05:42
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101213300747
Coding: 098A270000
   VCID: 6B88AC34F303CA03971-803E
Component: E221__MFL-TK6 H06 0022
   Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:40
136194 - Supply voltage
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:28
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Reset counter: 250
Date: 2000.01.01
365060 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 250
Mileage: 187205 km
Date: 2020.04.04
                    Time: 00:04:26
Part No SW: 3C8 920 970 Q HW: 3C8 920 970 Q
Component: KOMBI H20 0420
Coding: 240F00
Shop #: WSC 05314 115 00000
   VCID: 3A265970CCD9A38B5C7-806E
[Supply voltage too low]
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:07:42
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 151210F1000047
Coding: 469006
Shop #: WSC 05314 000 00000
   VCID: 343A7748EE3D55FB86B-8060
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:07:10
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128R2CBA03
Coding: 0000002
   VCID: 75BC8A4CA9C70CF3715-8020
Part No SW: 3AA 959 433 A HW: 3AA 959 433 A
Component: IMMO 042 0399
Revision: 00042000 Serial number: VWZCZ000000000
Component: ELV 029 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.26
                    Time: 00:00:28
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7668966053
   VCID: 2802933822F5211B3A3-807C
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:05:40
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:06:10
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0501
Revision: 12110009 Serial number: 0001885864
Coding: 0004B7
Shop #: WSC 05311 115 00000
   VCID: 6D8CA22CCD17C433895-8038
   Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001787478
   Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 250
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:07:56
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:25
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 250
Mileage: 187205 km
Date: 2020.04.04
                    Time: 00:10:20
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.303 0802
Revision: 1AH03729 Serial number: 00103370279301
Coding: 0000258
   VCID: 3B285C74CF639A83471-806E
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Fault Frequency: 8
Reset counter: 250
(no units): 2.0
                    Voltage: 10.40 V
Reset counter: 251
Voltage: 0.10 V
Voltage: 5.10 V
Voltage: 0.10 V
Not Occup.
                        Not Occup.
Component: KSG PQ47 ELV 042 0631
Coding: 13910F8001862E521204141FF08A0F0E085801
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:07:18
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 00000008
   VCID: 6FB0B824C79B3623BB9-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0501
Revision: 14110009 Serial number: 0001894062
Coding: 0004B6
   VCID: 6E8EA520C0113F2BB0F-803A
   Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001773067
   Coding: 000490
                    Reset counter: 250
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:07:56
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:26
Reset counter: 250
Mileage: 187205 km
Date: 2020.04.04
                    Time: 00:10:20
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Reset counter: 250
Mileage: 187205 km
Date: 2020.04.07
                    Time: 00:04:15
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000088325
Coding: 0022057
   VCID: 33387454E73352C39F1-8066
Fault Status: 00110010
Reset counter: 210
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:04:51
Voltage: 8.30 V
Count: 50
Hex Value: 0x12E0
Hex Value: 0x0001
                    Hex Value: 0x0202
Reset counter: 210
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:07:19
Voltage: 7.60 V
Count: 48
Hex Value: 0x12F2
Hex Value: 0x0001
                    Hex Value: 0x2020
Fault Status: 00110000
Fault Frequency: 9
Reset counter: 250
Voltage: 8.90 V
Count: 110
Hex Value: 0x0173
Hex Value: 0x0082
                    Hex Value: 0x4040
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0013
Revision: -----12S Serial number: VWZ4Z7K1173161
Coding: 0100040004
   VCID: 6296C11004498B4B247-8036
Fault Frequency: 12
Reset counter: 210
Mileage: 157288 km
Date: 2012.05.30
                    Time: 01:47:09
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:04:57
Reset counter: 250
Mileage: 187205 km
Date: 2014.08.17
                    Time: 03:06:18
Part No SW: 3AA 907 273 B HW: 3AA 907 273 B
Component: RDKBERU30 H08 0008
Serial number: 10000000012909
ASAM Dataset: EV_RDKBERU30 003010
ROD: EV_RDKBERU30_003.rod
   VCID: 33387454EBB352C39F1-8066
12656662 - Databus
[CAN Signal Kl15 fehlende Botschaft]
Reset counter: 250
Mileage: 187205 km
Date: 2020.04.04
                    Time: 00:11:55
12656671 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
[Gateway keine CAN Kommunikation]
8397314 - Front Right TPMS Sensor
C1051 31 [008] - No Signal
8397569 - Rear Left TPMS Sensor
C1052 04 [008] - Internal System Fault
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Fault Frequency: 136
Reset counter: 210
Mileage: 180401 km
Date: 2019.07.09
                    Time: 22:54:22
                    Vehicle speed: 18 km/h
Outside air temperature: 9.5 °C
Reception level antenna 1: 310 mV
                    Offset level antenna 1: 260 mV
8397826 - Rear Right TPMS Sensor
C1053 31 [008] - No Signal
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007669041538
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
   VCID: 3236715014A95BCB947-8066
[Klemme 30: unterer Grenzwert unterschritten]
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:11
U1400 00 [008] - -
Reset counter: 250
Mileage: 187205 km
Date: 2020.03.26
                    Time: 03:06:09
End----(Elapsed Time: 01:43, VBatt start/end: 10.9V/10.9V. VIgn 10.9V)-----
Hi and welcome.
10.9V does not look good.
Have you measured voltage directly at the battery terminals?
keokitron
WA, USA
C?ID=416824
Hi and welcome.
yes.
I fully charged the battery and it has 12+ volts
took out the alternator had it tested and its good also took out the starter and that tested good.
Im going to do some more diag today to see what I can find.
I tested continuity there is resistance from positive to negative cables.
tested the ground to any body connection and it has good continuity.
im thinking there is a short somewhere in the car?
it would have to be constant draw on all circuits whatever it is.
worst case scenario a bad ecu?
im sure it will be something simple just a pain in the butt hunting.
I guess its worth it for picking up a R-line cc for 500 bucks lol
South Molton, UK
First step to trace a current drain is to check the voltage drop across the fuses - this is an easier way to determine which circuits are drawing current.
If the battery has 12+V but you're seeing less than 11V at the diagnostic socket, then there is a significant voltage drop somewhere, which is likely the cause of your troubles. Poke around with a volt meter until you find the drop.
