Hello, i recently replaced my abs control module with a used unit. Yes I know this is not recommended but I figured I'd give it a shot before flipping out a grand for a new one. I replaced the unit and coded it using the long coding on the old unit (post failure). It accepted the code but i cant complete basic settings for g85 and a bunch of other group settings. They all say the same thing "error not available". I know g84 needs to be first then
G200, g201 etc. But am i doing something in the wrong sequence? Or is this just a sign of a bad unit. All help is appreciated.
3VWJZ7AJ6AM028648 License Plate:
> Chassis Type: AJ-VW36 (1K0)
> Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
> VIN: 3VWJZ7AJ6AM028648 Mileage: 88840km-55202miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: Malfunction 0010
> 04-Steering Angle -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: Malfunction 0010
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 25-Immobilizer -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 46-Central Conv. -- Status: OK 0000
> 52-Door Elect, Pass. -- Status: Malfunction 0010
> 56-Radio -- Status: OK 0000
> 62-Door, Rear Left -- Status: OK 0000
> 65-Tire Pressure -- Status: Malfunction 0010
> 72-Door, Rear Right -- Status: Malfunction 0010
> Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
> Part No SW: 07K 906 055 AG HW: 07K 906 055 M
> Component: 2,5l R5/4V G 9209
> Revision: G6H03--- Serial number:
> Coding: 0000075
> Shop #: WSC 09446 444 85684
> VCID: 73B3DB48E7B2A9C35F1-8026
> No fault code found.
> Readiness: 0000 0000
> Address 02: Auto Trans Labels: 09G-927-750.clb
> Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
> Component: AQ 250 6F 1631
> Revision: 00H76000 Serial number:
> Coding: 0000840
> Shop #: WSC 00066 000 00000
> VCID: 7DA7FD70D1F6EFB3395-8028
> Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
> Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
> Component: ESP MK60EC1 H45 0107
> Revision: 00H45001
> Coding: 114B400C49240002881102E8922100413000
> Shop #: WSC 41838 002 104857
> VCID: 7EA5FA7CD0F0F4AB20F-802A
> 3 Faults Found:
> 01435 - Brake Pressure Sensor 1 (G201)
> 005 - No or Incorrect Basic Setting / Adaptation
> Freeze Frame:
> Fault Status: 01100101
> Fault Priority: 2
> Fault Frequency: 2
> Reset counter: 36
> Mileage: 88817 km
> Time Indication: 0
> Date: 2015.03.13
> Time: 12:05:35
> Freeze Frame:
> Count: 16387
> Count: 32780
> Count: 12800
> Count: 279
> Count: 49152
> Count: 0
> Count: 0
> Count: 1536
> 00778 - Steering Angle Sensor (G85)
> Freeze Frame:
> Fault Priority: 2
> Fault Frequency: 2
> Reset counter: 36
> Mileage: 88817 km
> Time Indication: 0
> Date: 2015.03.13
> Time: 12:05:35
> Freeze Frame:
> Count: 16387
> Count: 32780
> Count: 12800
> Count: 295
> Count: 49152
> Count: 0
> Count: 0
> Count: 1536
> 01423 - Lateral Acceleration Sensor (G200)
> Freeze Frame:
> Fault Priority: 2
> Fault Frequency: 2
> Reset counter: 36
> Mileage: 88817 km
> Time Indication: 0
> Date: 2015.03.13
> Time: 12:05:35
> Freeze Frame:
> Count: 16387
> Count: 32780
> Count: 12800
> Count: 270
> Count: 49152
> Count: 0
> Count: 0
> Count: 1536
> Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
> Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
> Component: Climatic H13 0203
> Revision: 00006001
> Coding: 0000000000
