I recently took my wife's Q5 in for service due to the following faults:
20136 - PCV Valve Malfunction
P052E 00 [104] - -
19581 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
The dealer replaced the purge valve for the EVAP error, but the acted like they did not even see the PCV error.
When I got home, I rescanned and the PCV error had returned on the 20 minute ride home.
I am concerned that they are trying to kick the can down the road as the certified used car & Audi Care warranty expire in January. I don't want to have to pay for this repair right after the warranty expires!
My question is since this fault is "confirmed", does that give me any leverage to demand they complete the repair?
P052E 00 [104] - -
Thursday,15,October,2020,13:08:29:26024
VIN: WA1D7AFP5HA071461 License Plate: AUDI Q5
Mileage: 104510km-64939mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1D7AFP5HA071461 Mileage: 104510km-64939miles
Address 01: Engine (J623-CTUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8R0 907 551 F HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0006
Revision: --H07---
Coding: 2A2A0034052601060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218R0907551F 001006
ROD: EV_ECM30TFS0218R0907551F.rod
VCID: 3B23307633E3FA53471-806E
P052E 00 [104] - -
Fault Frequency: 16
Mileage: 99598 km
Date: 2020.08.08
Time: 12:34:07
Engine speed: 703.00 /min
Normed load value: 17.6 %
Coolant temperature: 96 °C
Intake air temperature: 54 °C
Voltage terminal 30: 12.695 V
Engine speed: actual: 672 /min
MAF_ENVD: 163.41176 mg/stroke
Coolant temperature (unfiltered): 95.25 °C
Engine: operating status: IS
Engine load: 17.578125 %
Vehicle speed: actual: 0 km/h
Mileage: 103867 km
Date: 2020.10.01
Time: 17:37:56
Engine speed: 1772.00 /min
Normed load value: 40.8 %
Vehicle speed: 112 km/h
Intake air temperature: 33 °C
Voltage terminal 30: 14.218 V
Unlearning counter according OBD: 19
CRLC_BAS_DIAGCPS: 0.09
CRLC_COR_DIAGCPS: 0.05
PRS_DIF_AMP_MAP_DIAGCPS_ENVD: 280 hPa
RATIO_MAF_MAX_COR_DIAGCPS_ENVD: 0.352
MAP_1_ENVD: 679.25000 hPa
Vehicle speed: actual: 112 km/h
Engine speed: 0.00 /min
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Part No SW: 8R0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H22 1004
Revision: --H22---
Coding: 000002
VCID: 08499FBA32B561CB1A3-805C
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 191D1C03
Shop #: WSC 06335 000 00000
VCID: 117FB2DE416F2003CDD-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0DA54040000000000000
VCID: 08499FBA323561CB1A3-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3216000228735012
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01101020161344
Coding: 6621228080
VCID: 77ABEC464FCB1E33639-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001497268401
Coding: 26000091863CAFE00100488300003D0D0F9CC708A6090221000008004000030100000034000000
VCID: 78A9EF7A42D5114B6A3-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 161006 H13 0050
Serial number: 90243014160926143237
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 62346770
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000000810160214
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0278435D
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 16C88F4800PAG0MUFU03
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H53 0812
Serial number: 003NED17BUR0
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC163AA664D4DEBFEB-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5810000R160000UXW2
Serial number: 6334MSME5B2B740AN
Serial number: 6344MSME5B5D1272K
Serial number: 6352QSME686D404AS
Serial number: 6362QSME6D6D3B66%
Serial number: 63732SME616B07580
Serial number: 63832SME616B267EA
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 91560PJI000BC
Coding: 000037
VCID: 48C95FBA72B5A1CBDA3-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 N HW: 8R0 920 981 N
Component: KOMBIINSTR. H35 0567
Revision: 00300000 Serial number: 036428DAH
Coding: 8BB622000301D705020000
VCID: 45D7568E45A7BCA3215-8010
Part No SW: 8R0 907 468 AF HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0071
Revision: 1Z140033 Serial number: 3341Z16A0508D1
Coding: 80CF07FF00
VCID: 035388960B1342934F1-8056
Subsystem 1 - Part No SW: 80A 915 181 A HW: 80A 915 181 A
Component: J367-BDMHella H06 9070
Serial number: 7636151804
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 16280003062011200410
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000219425271
Coding: 01581B00000000000000
VCID: 42DD4D9254898B9B047-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H07 0071
Serial number: 0419160932
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3FDB446627FBE6736B9-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H07 0071
Serial number: 0419275440
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H03 0511
Revision: Serial number: 0000222704211
Coding: 011D13215E00440004
VCID: 4FFB74A697DB76F39B9-801A
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H54 0702
Revision: 00000001 Serial number: 0000317899
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
VCID: 46D551827821B7BB28F-8012
Revision: 00002001 Serial number: 0419488875
Coding: 0126023A20FA709584B0053600040047
Component: GTO BF H01 0080
Serial number: 00000000000001148849
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813063646210
VCID: 2D070E2EFD1764E3C95-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H03 0511
Revision: Serial number: 0000222995064
VCID: 4EC569A290D17FFB90F-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H03 0005
Revision: -------- Serial number: 00000001845297
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D35723CD9C35B5C7-806E
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H66 0138
Revision: AB001007 Serial number: 156J90G2737199
Coding: 020007010000000001
VCID: 2517F60EA5E75CA3015-8070
Part No SW: 8R1 035 746 K HW: 8R1 035 746 G
Component: H-BNT-NA H44 1040
Revision: -------- Serial number: 523JU0G5001255
Coding: 160200060005A1EF55028B5E00000403140000000000000000
VCID: 3FDB4466277BE6736B9-806A
Subsystem 1 - Part No: 8R0 060 884 DQ
Component: NAR 2016/2017 1402
Component: DU7 High H42 0104
Serial number: A130J%0G3639654
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002617686
Component: CD-Database 6890
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H02 0510
Revision: Serial number: 0000223117444
Coding: 010C13204000240004
VCID: 46D5518278A1B7BB28F-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H11--- Serial number: 525PA8-JB8A2MG
Coding: 1020010
VCID: 34311B4A123D352B86B-8060
Address 6D: Trunk Elect. (J605) Labels: 4L0-910-945.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D273E6E2D77F463795-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H02 0510
Revision: Serial number: 0000223117445
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----[CODE]
