2011 JSW LED low beam Canbus errors
dougjt
DC, USA
C?ID=384245
Supposedly error-free H7 LEDs are reliably generating canbus errors. Is there any coding that can help?
Problem is warm diagnosis - no errors when headlights are off ... also no problem with lights on, key on, but engine not running. Why?
Voltage is set to 12.3 (byte 19). Errors at default 12.8v and at 13.6.
A coding solution would obviously be great, but guessing resistors are needed. Help with wiring color code, suggestions about resistance and wattage would be appreciated. Am thinking 8 ohm at 12.3 v should dissipate ~19 watts & hoping 19w + 8-10 watts (guesstimate) from LED is enough to satisfy controller that lights are OK. Does anyone know how much current draw is needed to avoid errors?
Car is US-spec TDI with MT, Polar FIS, Chinese VW radio, error-free H15 DRL/high beams
Jason
Tuesday,20,October,2020,10:11:51:09772
VIN: 3VWML7AJXBM620327   License Plate:
Mileage: 77880km-48392mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72 77
VIN: 3VWML7AJXBM620327   Mileage: 77880km-48392miles
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 03L 997 030 C    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H08---    Serial number:
   Coding: 0050072
   Shop #: WSC 12253 003 1048576
   VCID: 2E0509FD0C1527BBF0F-807A
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: 114B600C492400FA880E06E692200042B70000
   Shop #: WSC 00066 000 00000
   VCID: 74B1DB95AEB94D6B46B-8020
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00149
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7E691A5435463715-8020
   Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
   Component: BCM PQ35 B    011 1035
   Revision: BG011001
   Coding: 2D380E1F902F3EC4008800816000004401000086535D8560648020000040
   VCID: 34311B95EE390D6B86B-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 16071  21  0512
   Coding: 009795
9 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 152
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:18:12
                        Term 15 Off
                    Voltage: 12.05 V
                    Fault Status: 00101001
                    Reset counter: 152
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:18:12
                        Term 15 Off
                    Voltage: 12.00 V
                    Fault Status: 00101010
                    Fault Frequency: 13
                    Reset counter: 163
                    Mileage: 77800 km
                    Date: 2015.03.10
                    Time: 17:33:24
                    Voltage: 14.05 V
                    Fault Frequency: 14
                    Reset counter: 163
                    Mileage: 77800 km
                    Date: 2015.03.10
                    Time: 17:33:26
                    Voltage: 14.10 V
                    Reset counter: 162
                    Mileage: 77800 km
                    Date: 2015.03.10
                    Time: 15:59:26
                    Voltage: 11.60 V
                    Fault Frequency: 24
                    Reset counter: 162
                    Mileage: 68771 km
                    Date: 2014.04.08
                    Time: 17:29:19
                    Voltage: 13.35 V
                    Reset counter: 162
                    Mileage: 77800 km
                    Date: 2015.03.10
                    Time: 15:59:30
                    Voltage: 11.65 V
                    Reset counter: 152
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:18:12
                        Term 15 Off
                    Voltage: 12.00 V
                    Reset counter: 152
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:18:12
                        Term 15 Off
                    Voltage: 12.00 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R00NLAE
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F2AA1C9DBF00355D-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--000583H500
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME0D234653ZZZT
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME26165652ZZZR
   Serial number: 3511HSME451B5D22ZZZO
   Serial number: 3521HSME4A096322ZZZI
   Serial number: 35527SME21050523ZZZ.
   Serial number: 35627SME39600223ZZZ2
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JG2001AB
   Coding: 108A140000
   Shop #: WSC 00066 000 00185
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72BDDD8DD42D435B547-8026
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0037329
   Coding: 820000
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Component: KOMBI         H03 0406
   Coding: 270F01
   VCID: 2F3B14F9079F2EB3FB9-807A
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 26081001201699
   Coding: E9807F0640061300002002
                    Reset counter: 112
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:30:47
                    Reset counter: 112
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:30:47
03272 - Control Module for Audio Interface
                    Reset counter: 112
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:30:47
   Component: IMMO          H03 0406
   VCID: 6A8DC5EDFCFD8B9BEC7-803E
Address 2E: Media Player 3
Address 37: Navigation
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001284082
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 270BFCD92F6F76F3339-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005110181
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313F12811D2B3843EDD-8064
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: 6FBBD4F9C79F6EB3BB9-803A
   Component: J245EE20SKB13  H02 0220
02071 - Local Databus
                    Fault Status: 00101100
                    Fault Frequency: 15
                    Reset counter: 157
                    Mileage: 71688 km
                    Date: 2014.07.27
                    Time: 11:26:24
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001275852
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2809FFE52271798B3A3-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005087165
   Coding: 000490
   Part No SW: 6RF 035 187 E    HW: 6RD 035 187 B
   Component: Radio         565 Y510
   Revision: --------    Serial number: VWZZZ4J6270913
   Coding: 0E000440040005
   Shop #: WSC 00078 790 00103
   VCID: 4BC3606993C77293F71-801E
8 Faults Found:
                    Reset counter: 152
                    Mileage: 77500 km
                    Date: 2015.02.24
                    Time: 17:16:17
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 186
                    Mileage: 69528 km
                    Date: 2014.05.06
                    Time: 09:01:10
                    Reset counter: 186
                    Mileage: 69528 km
                    Date: 2014.05.06
                    Time: 09:01:10
                    Reset counter: 186
                    Mileage: 69528 km
                    Date: 2014.05.06
                    Time: 09:01:10
                    Fault Status: 00111011
                    Reset counter: 194
                    Mileage: 69704 km
                    Date: 2014.05.11
                    Time: 16:43:31
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 194
                    Mileage: 69704 km
                    Date: 2014.05.11
                    Time: 16:43:31
                    Reset counter: 194
                    Mileage: 69704 km
                    Date: 2014.05.11
                    Time: 16:43:31
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 194
                    Mileage: 69704 km
                    Date: 2014.05.11
                    Time: 16:43:31
Address 77: Telephone
End----------(Elapsed Time: 01:23, VBatt start/end: 11.8V/12.1V)-----------
I suggest measuring the current they're actually drawing when they're on. You don't necessarily have to do this in the car; you could do it "on the bench" with a 12V power supply and compare the current readings with a real H7 bulb.
