I need help for fuel pressure.
Erdzhan
Bulgaria
Hi all,
Someone who understand from values, could you please check the logs from the links below, and comment something not in norm.
  1. https://datazap.me/u/erdzhan/log-1603268054?log=0&data=
  2. https://datazap.me/u/erdzhan/log-1603268054?log=1&data=
About the problem why I'm checking those values :
The car is VW Golf 6 1.6TDI 105hp, and after engine replacing I have loss of power and very high fuel consumption like 10-11/100kml. combinated.
Already checked values is for Turbo, MAP, MAF, injectors everything is good, there is no problem but for example when i drove on hill i should down gear to 3th. i have now power on 4-5th.
Sorry for the long post, but i will really appreciate all comments/ideas to what i should check/log.
DrPeter
16.4905° S, 151.7375° W
This on it's face value does not look like a fuel pressure concern, the 'Actual' seems to follow the Specified rather well.
So what should be the fuel economy? and how are you calculating the consumption?
By the calculation below, I would expect that should be double the mpg...
235.215/(10 L/100km) = 23.521 US mpg
Is there any history? drag on the brakes? Air intake concerns? Problem with gravity? Is the tail pipe and area blackened with soot?
Maybe an Auto-Scan would be helpful, thanks
drpeter
