A6 C7 2012 Central Electric Module security code
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Friday,23,October,2020,11:39:39:34670
VIN: WAUZZZ4G9BN031310   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310   Mileage: 181969km-113070miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBDBC8F-8032
6368 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
          P0018 00 [039] - Incorrect Correlation
                    Mileage: 181969 km
                    Date: 2020.10.23
                    Time: 11:34:42
                    Engine speed: 692.00 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 12.695 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 136.17647 mg/stroke
                    Calculated oil temperature: 84
                    Engine: operating status: IS
                    ENVD_CAM_IN_2: 0
                    Battery voltage: 12.593750 V
Readiness: 0110 0001
   Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0024
   Revision: --H10---    Serial number: 0000000785
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5BB8F-8062
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F739BB0F-803A
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 05B82F00000000000000
   VCID: 77ABE8BBBFC53253639-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 06051100040574
   Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562D3339-8072
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [009] - Electrical Failure
                    Reset counter: 222
                    Mileage: 181969 km
                    Date: 2020.10.23
                    Time: 11:34:35
                    Voltage terminal 30: 13.09 V
                    Outside air temperature: 36.5 °C
                    Interior temperature: 21.62 °C
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000001044197
   Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
   VCID: 33331CABEB3D1E739F1-8066
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5228C6A5000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 222
                    Mileage: 181969 km
                    Date: 2020.10.23
                    Time: 11:34:00
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901107004778
   Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E42355D-806C
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BRPH
   Coding: 30323436313330303631554A305234473053
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110505000939
   Coding: 000034
   VCID: 303913A71A2B256BE23-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
   Component: TBenGb        H34 0312
   Revision: 19100074    Serial number: 658020411593026
   Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C63EDD-8064
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141378
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303913A71AAB256BE23-8064
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Serial number: 11130001538021200181
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 06051100040012
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A93FB9-807A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200UA850
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D994883C95-8078
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5EB123-8014
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0010073316
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A7177B947-8066
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 222
                    Mileage: 181969 km
                    Date: 2020.10.23
                    Time: 11:34:37
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FDB409BD775CA136B9-806A
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000070722
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FBB2C7-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110502-0004-033
   Coding: 1121A633F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
          [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                    Reset counter: 222
                    Mileage: 181969 km
                    Date: 2020.10.23
                    Time: 11:34:39
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA134B9-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787FB647-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7FB047-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970C3015-8070
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0C3C15-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 6FBBD0DBC7157A93BB9-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 70B9D3A7DA2B656BA23-8024
End----------(Elapsed Time: 02:06, VBatt start/end: 13.2V/13.2V)-----------
I need to brighten the DRL but I have no security code to access it. The one posted in the forum "20113" didn't work for me. Any one with suggestion?
