I just got this DTC, I have confirmed I can operate the window using convenience close and open - so the window can operate if the door controller tells it to.
I also tried a new switch which also didn’t work, so I very much doubt it is the switch. All other buttons and functions on the door work. These are Gen4 controllers, not stock, but they have been in there for more than a year, so I believe reasonably stock.
Wondering if there are any ideas - has anyone seen this DTC?
66304 - Switch for Drivers Side Window Regulator
B11F0 29 [009] - Signal Implausible
Reset counter: 150
Mileage: 171373 km
Date: 2020.10.22
Time: 13:13:40
Autoscan:
Reset counter: 150
Mileage: 171373 km
Date: 2020.10.22
Time: 13:13:40
Autoscan:
Thursday,22,October,2020,13:17:54:08140
VIN: WVWNK73C09E096517 License Plate:
Mileage: 171374km-106484mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72
VIN: WVWNK73C09E096517 Mileage: 171370km-106484miles
0F-Digital Radio -- Status: Not registered 0011
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AF HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3318
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 05314 000 00000
VCID: 6E85C81A8C96F9BBB0F-803A
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 171155 km
Date: 2015.03.15
Time: 14:37:49
Temperature: 90.0°C
Temperature: 48.0°C
Absolute Pres.: 960.0 mbar
Voltage: 12.446 V
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AJ HW: 3C0 614 109 T
Component: J104 C4 440 V2 0016
Revision: --025--- Serial number: 00000786422456
Coding: 0002421
Shop #: WSC 00017 666 02327
VCID: 6695B03AA46631FBC8F-8032
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D66296A2EF4BA23-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009135800
Coding: 8F8C8F2700041A00870000630F000000005B7F4D00401120000000000000
Shop #: WSC 05124 123 12345
VCID: 3333196EA73494539F1-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 031008 004 0206
Coding: 00046997
Shop #: WSC 05124
Fault Status: 00101100
Reset counter: 186
Mileage: 171336 km
Voltage: 13.80 V
03267 - Unlocking of Hatch / Trunk Lid
Fault Status: 01111100
Reset counter: 150
Mileage: 171021 km
Voltage: 14.40 V
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 190
Mileage: 171373 km
Voltage: 11.50 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0476922
Coding: 0000000
00003 - Control Module
Fault Status: 00101110
Reset counter: 250
Mileage: 144245 km
Date: 2011.08.02
Time: 19:20:57
Reset counter: 82
Mileage: 170731 km
Date: 2015.03.15
Time: 15:00:23
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__003 VW10 HI 1815
Revision: 19013000 Serial number: 0039BPQ7V11S
Coding: 0012339
Shop #: WSC 05311 000 00000
VCID: 7AADF44AC0DEA51B1C7-802E
Subsystem 1 - Serial number: 6333FTS611243198
Subsystem 2 - Serial number: 6343FTS645622908
Subsystem 3 - Serial number: 6353ETS6FOA0V5KJ
Subsystem 4 - Serial number: 6363ETS6OU4VVVNR
Subsystem 5 - Serial number: 6374CTS6H9JQVVNR
Subsystem 6 - Serial number: 6384CTS6TRF1V5KR
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C5953507CN
Coding: 0000712
VCID: 74B1DA72E2BAD36B46B-8020
Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Coding: 00000226
Part No SW: 3C0 920 871 R HW: 3C0 920 871 R
Component: KOMBI H04 0107
Coding: 360D00
Shop #: WSC 05314 115 12345
VCID: 3333196EABB494539F1-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C05031F
Coding: F9817F06020202002002
Shop #: WSC 05314 123 12345
VCID: 2A0D040A70FED59B2C7-807E
Reset counter: 131
Mileage: 171021 km
Date: 2015.03.15
Time: 22:06:40
Part No SW: 3C0 959 433 AT HW: 3C0 959 433 AT
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 06402 785 00200
VCID: 7CA1F252CAEA9B2B0EB-8028
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0501
Revision: 12110009 Serial number: 0001817230
Coding: 0010F7
Shop #: WSC 05311 115 12345
VCID: 6D87CF168D1002A3895-8038
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388__TSG-HL 004 0307
Serial number: 00000000707439
Coding: 0004D0
Reset counter: 150
Mileage: 171373 km
Date: 2020.10.22
Time: 13:13:40
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.081 0502
Revision: 1AH02240 Serial number: 00083290202402
Coding: 0000258
VCID: 392F2B4685586E0355D-806C
Component: KSG PQ46 ELV 042 0612
Coding: 13900E80D10306767204141FF08A8F0E087C01
Shop #: WSC 94718 999 15553
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0000306918
Coding: 0015F6
ROD: EV_DCU52BrosePasseSide.rod
VCID: 79AFEB46C958AE0315D-802C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389__TSG-HR 004 0307
Serial number: 00000000727654
Coding: 0004D0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000208591
Coding: 0000057
VCID: 2809FE026EF2E78B3A3-807C
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0136
Coding: 2323457
VCID: 34311A72A23A936B86B-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5406
Revision: -------- Serial number: VWZZZ4J6253087
Coding: 16000440010005
Shop #: WSC 127395 840 08317
VCID: 46D550BAC8A611FB28F-8012
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 E
Component: J605 HECKDECKEL 0600
Revision: 00H27001
Shop #: WSC 23250 384 715754
VCID: 303916625622AF4BE23-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0600
Subsystem 2 - Serial number: 0800H27001001B0050ÿ
00317 - Rear Lid Control Module (J605)
Reset counter: 160
Mileage: 170946 km
Date: 2015.03.15
Time: 17:08:30
End----(Elapsed Time: 01:28, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
