- Jun 23, 2015
- 17
- 4
- Brisbane,Australia
- C?ID=250826
Hey all,
Was just hoping for some input as to what the below may be. The error started randomly. I've provided a full scan below. Car was running fine and all of the sudden started to run rough and gave me this code. Prior to this code it did have lambada sensor code that i cleared up and planned to change but not sure if they are related. I've got another Audi A3 with the same engine which functions fine so i assumed it maybe the coil pack - switched it out and plugged them in this one and it gave me the same error. Perhaps spark plugs? or is there more to this. I've put up both the scans that way you get an idea what it gave me with the lambada sensor and now the cylinder disabling.
Current error with cylinder disabling -
Previous scan with Lambada sensor code -
Any help with this would be greatly appreciated.
Friday,23,October,2020,09:25:58:10020
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ8P8AA134296 License Plate: AUDICYLD
Mileage: 135840km-84407mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 61 62 72
VIN: WAUZZZ8P8AA134296 Mileage: 135840km-84407miles
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH15--- Serial number: AUX7Z0J1FNF0DY
Coding: 0143000C24070160
Shop #: WSC 06314 067 57207
VCID: 41890AFD18AEEE8E5C-8014
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Mileage: 135849 km
Date: 2020.10.22
Time: 09:03:04
RPM: 800 /min
Load: 20.0 %
Temperature: 38.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
004874 - Cylinder Disabling
P130A - 000 - - MIL ON
Fault Status: 11100000
Mileage: 135849 km
Date: 2020.10.22
Time: 09:22:38
RPM: 743 /min
Load: 18.8 %
Temperature: 59.0°C
Temperature: 27.0°C
Voltage: 14.351 V
Readiness: 1110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
Component: GSG DSG AG7 451 9032
Revision: 00045014 Serial number: CU501904026543
Shop #: WSC 19615 002 1048576
VCID: 3A7B7D117578BD561D-806E
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13424012092500FEC80D02ED901F0081390800
Shop #: WSC 06314 000 00000
VCID: 7AFBBD11F5F87D565D-802E
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000300 Serial number: 8P0820043BM
VCID: 78FFA7190BF46F462B-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB0051AC0207040E00100095C417E2BAA306DD929E4000E840041
VCID: 326B55316D084516D5-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 231
Mileage: 135849 km
Date: 2020.10.21
Time: 12:46:48
Voltage: 14.05 V
Term 50 Off
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB005NKC3
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FAD3CC516FA08FEDA-801A
Serial number: 3572DRB40000A93C6A1.
Serial number: 3582DRB40000A934A8C0
Serial number: 35128RB400005502CABK
Serial number: 35228RB4000055CE380N
Serial number: 35547RB40000557040AB
Serial number: 35647RB4000055703DBP
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0012142
VCID: 468319E13180C9B669-8012
Component: E0221 H02 0100
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 D HW: 8P0 920 932 D
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005031085
Coding: 0000728
Shop #: WSC 12345 067 57207
VCID: 35616E2D5C66522EF0-8060
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J1020701EF
Coding: ED817F06100202042103
VCID: 6BD588554AA2D4DED6-803E
01304 - Radio
Reset counter: 15
Mileage: 135849 km
Date: 2020.10.21
Time: 12:47:04
Revision: D0H03005 Serial number: AUX7Z0J1FNF0DY
Shop #: WSC 35680 000 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0000660
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31695A3DA80E7E0EAC-8064
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158954996076
VCID: 3663692141605936F9-8062
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0000660
VCID: 479D14E5368AD0BE92-8012
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Coding: 0000013
VCID: 7AFBBD1135F87D565D-802E
Address 56: Radio
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J1020701EF
Coding: 0302085A
VCID: 68DFF7599B54FFC6BB-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790997018
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 428B05F11DA8F59645-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 438500F502B2FC9E4E-8016
End-------------------------(Elapsed Time: 02:16)--------------------------
Address 01: DTCs cleared
Thursday,22,October,2020,11:08:32:10020
VIN: WAUZZZ8P8AA134296 License Plate: AUDIBLACKSMOKE
008817 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 - 000 - too Rich - Intermittent
Mileage: 135786 km
Date: 2020.10.21
Time: 00:03:07
RPM: 2008 /min
Load: 9.8 %
Speed: 61.0 km/h
Temperature: 93.0°C
Temperature: 27.0°C
Voltage: 14.097 V
Revision: 00H30001
Revision: 00105 AK
Coding: 00DD13
Coding: 024C2D
Reset counter: 221
Mileage: 135419 km
Date: 2020.10.15
Time: 10:06:23
Voltage: 12.35 V
Term 50 Off
Coding: 0012142
01304 - Radio
Coding: 0000728
01304 - Radio
Fault Frequency: 36
Reset counter: 14
Mileage: 135419 km
Date: 2020.10.15
Time: 10:06:44
Coding: 0000660
Revision: 00H17000
Coding: 0000660
Coding: 0000013
Address 56: Radio
Coding: 0302085A
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 02:18)--------------------------
