2018 Golf GTE Hybrid J623-CUKB
Oldboy
Lincolnshire, UK
C?ID=389996
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: VAG Auto Barn
VIN: WVWZZZAUZJW812081   License Plate: FH18RHJ
Mileage: 28403km-17648mi   Repair Order: 1
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 4B 51 52 5F 75 8C
          A9 C0 C6 D6 D7
VIN: WVWZZZAUZJW812081   Mileage: 28403km-17648miles
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 BN    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 4518
   Revision: X3H22---
   Coding: 011D0012636405082008
   ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
   ROD: EV_ECM14TFS01104E906023BN.rod
   VCID: 6D92E890BCD13A277E-8038
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
32046 - Engine Coolant Bypass Valve 1
          P26B1 00 [096] - Stuck Closed
20122 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [032] - Implausible Signal
4178 - Fuel Injection Malfunction
          P0148 00 [096] - -
   Part No SW: 0DD 300 046 F    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01702200235
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: 2B1626884245F41720-807E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
   Component: ESC           H62 0856
   Revision: 00000000    Serial number: 61238000000524
   Coding: 01FA80A13821216E4777060861C42980011C84E26086947338B15078C20203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 74A4FDF4DFFBEBEFB1-8020
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
16401 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0012100420011001040500000010102A
   VCID: 085CB904B373FF0FED-805C
   Subsystem 3 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00102.1V.3C20370031
   Air quality sensor:
   Air Conditioning Compressor Sub:
H02
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 8101007602ÿÿÿÿ
   ROD: EV_BCMBOSCH_018.rod
   Component: WWS    180425  042 0551
   Serial number:         180504141251
   Component: RLHS  050 0107
   Serial number: SAY18M05D24H13M46S04
   Coding: 00A8DD
   Serial number: 000000000ZY180872UZ1
   Serial number: 00000000000030083406
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 13
   Part No SW: 5QA 919 294 E    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000308418618145
   Coding: 1471051811
   VCID: 4ED04F1C1197E13F67-801A
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 5500678159FFC728949C810580400600000000000000000000
   VCID: 3C3415D4B72B63AFB9-8068
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR04BM7P
   Coding: 98CCC000002000005C0000CF00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50EC51640BA3F7CF75-8004
   Belt Pretensioner left:
   Serial number: 34169677E22051830263
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E23051850310
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 205 18
   Serial number: 35700000000CB58DBF26
   Subsystem 4 - Part No SW: -----------    HW: 480 001 905 18
   Serial number: 35800000000D3CC46F2/
   Subsystem 5 - Part No SW: -----------    HW: 480 402 205 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001162B6CEB4F37G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 305 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001222AE89C4D38C
   Subsystem 7 - Part No SW: -----------    HW: 480 402 205 18
   Serial number: 35500012E2AF26F5F49R
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 19051804401265
   Coding: 0410
   VCID: 0248AB2C954FD55FB3-8056
   Part No SW: 5G1 920 794 A    HW: 5G1 920 794 A
   Component: KOMBI         409 3197
   Coding: 27AC7B082FC0060001886B111701030000000000
   VCID: 2D1228907C51FA273E-8078
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 07051811600757
   Coding: 020100176EF11000FB00527C5C1D00000001070100010000000300000000
   ROD: EV_GatewNF.rod
   VCID: 393A0CC0B8195687A2-806C
   Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180000957010078184
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 2345787204
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 54
                    Mileage: 28124 km
                    Date: 2020.03.17
                    Time: 08:00:02
                    Supply voltage: Terminal 30: 14.9 V
                    Terminal 15: OFF
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460010029
   Coding: 02720100331900000002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 52E85B6C05AF85DF43-8006
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861240418145954
   Serial number: 050518EE51349A
   Coding: 003F0620D001048000001000
   VCID: 43C66E28CAD51C57F8-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000021528844
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: C1020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73A6FEE8DAF5ECD7A8-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 06051810521655
   Coding: 000000070100164E00400101020000000000000000000000000000000000
   VCID: 72A8FBECA5EFE5DFA3-8026
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H15 1032
   Revision: 00H15000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 291ADC8048B9E607D2-807C
   Serial number: 080518EE803652
   Coding: 003F0020DE01048000801000
   VCID: 42C86B2CD5CF155FF3-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000021469343
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02731001FF0000005111010100880A001F0509E601200000CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 32283BEC656FA5DF63-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV1342416
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 02739001EA42980D3FFCBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW37.rod
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0921
   Serial number: VB020022
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006041
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 34243DF49F7BABEF71-8060
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C1830230351
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C1830230347
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C1830230346
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C1830230349
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C1830230358
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C1830230353
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C1830230357
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C1830230356
   Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0017
   Serial number: 180411201497
   VCID: 2E102F9C7157813F07-807A
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN181600530000
   Coding: 90
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4BD64608E285D41700-801E
   Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
   Component: OBC KOSTAL    H40 4013
   Revision: --------    Serial number: 2604180DC0008A
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 116A9460C029BEC73A-8044
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EB0DFDCE1B7B1BFD7-802A
End----------(Elapsed Time: 01:52, VBatt start/end: 13.2V/13.2V)-----------
