- Oct 21, 2020
- 11
- 1
- Saratoga Springs NY
- C?ID=414452
Hello everyone I have a 2013 Audi s7 and my transmission has been a complete nightmare since I purchased it in July. The day after I bought it the car would make a loud clunk going from park or neutral into drive or reverse and would clunk into gear from a stop. After this happened I had the car shipped back to Virginia to get fixed under the warranty of the third party dealer where they "replaced the clutch". Upon return, the car was driving normally for about a week when the same problem occurred. I learned of the transmission adaptation procedure and this fixed all of my problems for about 2 weeks. Now I have run into the issue of the gears slipping at higher rpms and now the transmission just takes so long to shift into gear. Sometimes if I let the car slip enough it puts me into a limp mode where I can only use gears 2 4 6 and R. Last night I took it for one last drive to get a datalog and an error message popped up that said transmission overheating and then it put me in limp mode again. I will post the autoscan below. PLEASE HELP!!!
Wednesday,14,October,2020,17:09:00:06753
VIN: WAUW2AFC8DN130724 License Plate:
Mileage: 149319km-92782mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 8F 90 A9 BA
VIN: WAUW2AFC8DN130724 Mileage: 149319km-92782miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0009
Revision: NCH62---
Coding: 1A2500326526000E1000
Shop #: WSC 34110 002 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 211FE1D611484C137DD-8074
17875 - Exhaust Pressure Control Valve
P0475 00 [047] - Electrical Malfunction
Mileage: 149307 km
Date: 2020.10.13
Time: 16:07:40
Engine speed: 0.00 /min
Coolant temperature: 57 °C
Intake air temperature: 51 °C
Voltage terminal 30: 11.567 V
Engine status: COENG_READY
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [036] - -
[Transmission control moduleRead out DTC]
Mileage: 149309 km
Date: 2020.10.13
Time: 16:17:53
Engine speed: 2302.50 /min
Normed load value: 9.0 %
Vehicle speed: 32 km/h
Coolant temperature: 69 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.253 V
Engine status: COENG_RUNNING
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [039] - -
Mileage: 149319 km
Date: 2020.10.14
Time: 17:02:08
Engine speed: 2276.50 /min
Normed load value: 7.8 %
Vehicle speed: 31 km/h
Voltage terminal 30: 14.418 V
Readiness: 0010 0001
Part No SW: 4G1 927 156 S HW: 0B5 927 156 J
Component: 0B5 40TFSINAR H01 0009
Revision: --H01---
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 3D273DA68DF008F3795-8068
23682 - Shift Fork 2
P284E 00 [237] - Uncommanded Movement
Mileage: 149309 km
Date: 2020.10.13
Time: 16:17:53
Engine speed: 1369 /min
Transmission input speed: 1369 /min
Transmission output speed: 145 /min
Engine torque: 136 Nm
Transmission fluid temperature: 54 °C
Accelerator position: 23.2 %
Clutch status: Beide Kupplungen können Moment übertragen
Gear selector: gear 1: standardized end position-Data: -9.11 mm
Gear selector: gear 3: standardized end position-Data: 9.26 mm
Current of gear Solen.val. 1-3-Data: 597.2 mA
S001_Svw_S_Gs[G13]-Data: -7.44 mm
U001_Glr_iVentEinsatzNeg[Gs13]-Data: 525.9 mA
U005_Glr_iVentEinsatzPos[Gs13]-Data: 671.4 mA
GssDiag_Ct_EreignEingelVerlass[GANG1]: 2
GssDiag_Ct_EreignEingelVerlass[GANG3]: 0
GssDiag_T_EingelVerlass[GS13]-Data: 2 ms
Gss_Counter_EreignEingelVerlassGesamt[GS13]: 29
Gss_kmStand_EreignEingelVerlassGesamt[GS13]: 149296
24380 - Gear Selector
P187F 00 [108] - Position Deviation
Mileage: 149308 km
Date: 2020.10.13
Time: 16:16:14
Engine speed: 1806 /min
Transmission input speed: 1806 /min
Transmission output speed: 188 /min
Engine torque: 132 Nm
Transmission fluid temperature: 52 °C
Accelerator position: 22.4 %
8018 - Clutch Pressure Adaptation
P1741 00 [032] - Limit Reached
Reset counter: 37
Mileage: 149311 km
Date: 2020.10.13
Time: 16:28:48
Engine speed: 2432 /min
Transmission input speed: 2432 /min
Transmission output speed: 274 /min
Engine torque: 116 Nm
Transmission fluid temperature: 62 °C
Accelerator position: 11.6 %
Clutch status: Kupplung 2 kann Moment übertragen
8963 - Clutch 2
P17D0 00 [096] - Slippage too High
Reset counter: 37
Mileage: 149309 km
Date: 2020.10.13
Time: 16:18:04
Engine speed: 2234 /min
Transmission input speed: 2234 /min
Transmission output speed: 408 /min
Engine torque: 192 Nm
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 65B64F03A66DF2C04B00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 3635228AA8C6DBABB8F-8062
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Coding: 0D8A2006000000000000
VCID: 7BA3F3BED3E4C6C3071-802E
Serial number: 2313000038664014
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0086
Serial number: 12031300040923
Coding: 688320B849
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: 629DAEDA54CE170B247-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001697582
Coding: 0D07A091073E9FE0A90008C7A0003820CF9CD208A2090221800308457B00
VCID: 6FBBD7EE979CAA63BB9-803A
Component: WWS57X 130301 H36 0080
Serial number: 130305021002
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21088086
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 08 03 2013 00001842
Component: USHL4.2 H30 0030
Serial number: 0000002274555R58QY02
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001302080887
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001302080477
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104972000003069377
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 81A8C996000000000001
Subsystem 9 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001302213458
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001302213063
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061307504142
Coding: A8C109
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD1968128BC93ADD-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002VVZ.
Coding: 303145313131303030314A55304C34473853
VCID: 33331B9EBBB4CE839F1-8066
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y130000RU8V0O
Serial number: 3575HRB401C50EP2GHPO
Serial number: 3585HRB404V1TEI4C19V
Serial number: 3515JRB401I50FFILGKW
Serial number: 3525JRB401G50FSMN1CR
Serial number: 3554VRB401G50DLSGPRR
Serial number: 3564VRB400K50F3C694-
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MC8000X1
Coding: 000434
VCID: 38292CB2A2522DDBAA3-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 12 02 2013 C0195646
Part No SW: 4G8 920 983 R HW: 4G8 920 983 R
Component: TBenUsa Nv H76 0515
Revision: 28460208 Serial number: 658060313596008
Coding: 0BEF01079B43D705020300
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 44D14842EE1A793B36B-8010
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000861700
Coding: 00E1034800
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 7652660103
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 001103130001124
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 270BFFCE7F6CB223339-8072
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0086
Serial number: 14031300040705
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 372B2F8EAFCC22A3A39-8062
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050AEA5096E36BF0F-807A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000053799848
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77ABEF8EEFCCE2A3639-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00D5YO
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0050
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: 3635228AA446DBABB8F-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0050
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F09.03.1300H04000AMS14854ÿ
Subsystem 4 - Serial number: S14854ÿ
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F57025E00628002000412
VCID: 47CB5F4EDFAC5223D39-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0028306262
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1E9A44AEC78B947-8066
Revision: 00002001 Serial number: 0302607333
Coding: 0126023A20FAF08580B00A8002010D000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000136901
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2067031-
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00003091582
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA105554000003088098
02911 - Bulb for Side Marker Light; Rear Left (M37)
Fault Status: 11101100
Reset counter: 188
Mileage: 149307 km
Date: 2020.10.13
Time: 16:07:36
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 189
Mileage: 149313 km
Date: 2020.10.13
Time: 16:32:02
02616 - Fuel Tank Cap; Unlock
Reset counter: 189
Mileage: 149313 km
Date: 2020.10.13
Time: 16:32:23
Part No SW: 4G1 035 465 HW: 4G1 035 465
Component: BO G3 C7 ANC H03 0130
Revision: 09S00000 Serial number: 0011569
Coding: 020101
VCID: 6393ABDE4B541E032F1-8036
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 00103130022871
03405 - Bass Loudspeaker
Reset counter: 189
Voltage: 12.30 V
Temperature: 24.0°C
Bin. Bits: 00000100
Voltage: 12.50 V
Temperature: 26.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Component: TSG BF H03 0507
Coding: 011F57025E00628002000402
VCID: 46D5524AD8A64B2B28F-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000621230
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B0303FE63849643D71-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130318-0002-045
Coding: 12236F601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2D070DE65D909873C95-8078
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156C+0D7704667
Coding: 020007010000000001
VCID: 221DEEDA14CE570B647-8076
Part No SW: 4G0 035 746 D HW: 4G0 035 746 B
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 194C+0D7526861
Coding: 0A0200040203F1EF55128B1E00000003100001000000000000
VCID: 2809FCF272F2BD5B3A3-807C
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD000WFSH
Serial number: 90349PKL000KE
Component: CD-Database 4949
Reset counter: 188
Mileage: 149307 km
Date: 2020.10.13
Time: 16:07:40
Text: KBD_FC7,KBD,A,fa,cc,1
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: 49CF5976C9B8A453C5D-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J32G2FO
Coding: 1080013
VCID: 2615F2CA74E6AB2B08F-8072
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 053300309
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 313F119641A8FC93EDD-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 130219200626
VCID: 2C0100E2668A917BDEB-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804001586204
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 6695B2CAB8E66B2BC8F-8032
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 188
Mileage: 149307 km
Date: 2020.10.13
Time: 16:07:40
End----(Elapsed Time: 02:45, VBatt start/end: 12.2V/11.6V. VIgn 11.7V)-----
