SW:4G5-959-107-C HW:4G5-959-107-A --- Trunk Elect.
Component:HDSG-Modul H02 0049, Coding:111104C020
EV_HDSGAu571,001022,EV_HDSGAu571.rod
Thursday,22,October,2020,16:18:45:58101
Version: Release 20.4.2 (x64) Data version: 20200730 DS317.0
VCID: 323D188AA4A14ECB947-8066
IDE01651-Status of adaptation,active ,1
IDE02023-Opening with trailer detected,not activated ,1
IDE02110-Reversing when opening,activated ,1
IDE02111-Reverse path when opening,50 ,2
IDE02112-Reversing when closing,activated ,1
IDE02113-Reverse path when closing,20 ,2
IDE02114-Stop rear lid movement when changing terminal,not activated ,1
IDE02134-MAS04214-Activation using rear lid remote unlocking switch-Tap function for opening,active ,1
IDE02134-MAS04215-Activation using rear lid remote unlocking switch-Tap function for closing,active ,1
IDE02134-MAS04216-Activation using rear lid remote unlocking switch-Touch function for opening,not active ,1
IDE02134-MAS04217-Activation using rear lid remote unlocking switch-Touch function for closing,active ,1
IDE02136-MAS04214-Activation using rear lid opening button in remote key-Tap function for opening,active ,1
IDE02136-MAS04215-Activation using rear lid opening button in remote key-Tap function for closing,active ,1
IDE02136-MAS04216-Activation using rear lid opening button in remote key-Touch function for opening,not active ,1
IDE02136-MAS04217-Activation using rear lid opening button in remote key-Touch function for closing,active ,1
IDE02143-Rear lid closing button: debounce time,50 ms,2
IDE02145-Rear lid closing button: start activation,100 ms,2
IDE02150-Speed threshold for "vehicle is moving",6.00 km/h,2
IDE02152-Characteristics in production mode,independent ,1
IDE02153-Increment for actuator test open rear lid,15 %,1
IDE02154-Increment for actuator test close rear lid,15 %,1
IDE02155-Reset all counters,not erased ,1
IDE02156-Time window for opening further than programmed opening stop,0.00 s,1
IDE02157-Delete programmed opening stop,erase ,1
IDE02158-Program opening stop,2030 ,2
IDE02160-Pitch of acoustic warning,760 Hz,1
IDE02161-Volume of acoustic warning,activated ,1
IDE02165-Duration of warning signal in automatic operation,0.50 s,1
IDE02166-Duration of warning signal in blocking detection,0.00 s,1
IDE02167-Length of acknowledgement signal when programming opening stop,0.05 s,1
IDE02168-Duration of warn. signal during activation upon cancel function,0.05 s,1
IDE03426-Close using remote control: end when leaving the immediate area,2.00 s,2
IDE03427-Upper end stop: maximum value,2400 ,2
IDE03428-Upper end stop: minimum value,1700 ,2
IDE03434-Detection area lower,1000 ,2
IDE03435-Detection area upper,2400 ,2
IDE03436-Start-stop characteristics,Version 1 ,1
IDE03437-Delay restarting after start-stop,2500 ms,1
IDE03776-Offset for maximum programmable opening stop,10 ,1
IDE03777-Tolerance range for soft stop,50 ,1
IDE03779-Setting the error "Button for closing rear lid. Open circuit",not active ,1
IDE03785-Start of automatic run with manual opening,not active ,1
IDE03786-Start of automatic run with manual closing,active ,1
IDE04563-Delay for rear lid closure,0.00 s,1
IDE04564-Delay for rear lid opening,0.00 s,1
IDE04565-MAS00162-Warning signal when closing with button-automatic,active ,1
IDE04565-MAS01870-Warning signal when closing with button-Button for rear lid unlocking in rear lid,not active ,1
IDE04565-MAS01871-Warning signal when closing with button-Rear lid lock button in luggage compartment,not active ,1
IDE04565-MAS01872-Warning signal when closing with button-Rear lid remote release button,active ,1
IDE04565-MAS01873-Warning signal when closing with button-Rear lid unlock button in remote key,active ,1
IDE04565-MAS01874-Warning signal when closing with button-Central locking button in exterior door handle,not active ,1
IDE04566-MAS00162-Warning signal when opening with button-automatic,active ,1
IDE04566-MAS01870-Warning signal when opening with button-Button for rear lid unlocking in rear lid,not active ,1
IDE04566-MAS01871-Warning signal when opening with button-Rear lid lock button in luggage compartment,not active ,1
IDE04566-MAS01872-Warning signal when opening with button-Rear lid remote release button,not active ,1
IDE04566-MAS01873-Warning signal when opening with button-Rear lid unlock button in remote key,not active ,1
IDE04566-MAS01874-Warning signal when opening with button-Central locking button in exterior door handle,not active ,1
IDE04844-Betätigungszeit Schließen der Heckklappe mit Funkfernbedienung,0 ms,2
ENG105083-Added_offset_to_can_bus_signal_deck_lid_position,15 %,1
ENG105184-Anzahl der Töne für Ton 3,3 ,1
ENG106227-Entwicklungs ID für Entwicklungszwecke freischalten,not activated ,1
ENG106846-ENG98553-Hallsensor_configuration-Direction,1 ,1
ENG106846-ENG110974-Hallsensor_configuration-double_hall,1 ,1
ENG106863-HD_Rueckmeld_Prog_on_CAN,active ,1
ENG124604-Locking_range_offset_upper_stop,10 ,1
ENG108209-Plausibility_limit_suspended_HKIT,60 s,1
ENG122796-Switch_off_ Level_aktiv,Deactivation stage 0 ,1
ENG109307-T1 normal signal break time,0.50 s,1
ENG109310-T2 scaling signal break time,0.10 s,1
ENG109311-T2 scaling signal rate,760 Hz,1
ENG109312-T2 scaling signal start-up time,0.10 s,1
ENG109313-T3 handshaking signal break time,0.05 s,1
ENG109314-ENG101878-T3 handshaking signal rate-T1_signal_rate,1050 Hz,8
ENG109314-ENG103609-T3 handshaking signal rate-T2_signal_rate,1320 Hz,8
ENG109314-ENG104000-T3 handshaking signal rate-T3_signal_rate,1580 Hz,8
ENG109314-ENG102070-T3 handshaking signal rate-T4_signal_rate,0 Hz,8
ENG109314-ENG103240-T3 handshaking signal rate-T5_signal_rate,0 Hz,8
ENG109314-ENG101216-T3 handshaking signal rate-T6_signal_rate,0 Hz,8
ENG109314-ENG100667-T3 handshaking signal rate-T7_signal_rate,0 Hz,8
ENG109314-ENG102428-T3 handshaking signal rate-T8_signal_rate,0 Hz,8
ENG109315-T4 error signal break time,0.05 s,1
ENG109316-T4 error signal number of tones,3 ,1
ENG109317-T4 error signal rate,500 Hz,1
ENG109318-T5 ASD- activate signal number of tones,1 ,1
ENG109319-T5 ASD- active signal break time,0.00 s,1
ENG109320-T5 ASD- active signal rate,2500 Hz,1
Elapsed Time: 00:15
