- May 22, 2014
- 26
- 7
- ROCKY MOUNT N.C.
- C?ID=7
have a Jetta 2.5 might start and run for about a minute or less than cuts off and will not restart. when this happens cooling fan runs.scan and see have no communication with the ECM
might have to sit for a day before will start again .. do these know for bad ECM shutting communication down.all power and grounds should be good if it will crank and run for a while until what is short out can lines.
Thursday,22,October,2020,13:08:26:48017
VCDS Version: 20.4.1.0
Dealer/Shop Name: Flowers Automotive
Workshop Code: 000 00001 000000
VIN: 3VWDP7AJ3CM470874 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
01-Engine -- Status: Malfunction 1110
Address 01: Engine
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2246
Revision: 00H97000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: 8005C140D3B812868B-80D4
Fault Status: 11100100
Reset counter: 44
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492908FA8D1302EB921D1061A71000
VCID: FDFBB8B4644A7F6EE0-80A8
02846 - Button for Tire Pressure Monitoring Display (E492)
Reset counter: 91
Mileage: 65802 km
Date: 2027.14.02
Time: 04:13:17
Count: 16391
Count: 12
Count: 16896
Count: 157
Count: 41216
Count: 2
Count: 512
Fault Status: 00101101
Reset counter: 91
Mileage: 65801 km
Date: 2027.14.02
Time: 03:59:21
Count: 2
Count: 32768
Count: 12288
Count: 8193
Count: 45314
Count: 2
Count: 249
02757 - Learning Tire Pressures
Reset counter: 104
Mileage: 34728 km
Date: 2044.14.19
Time: 13:58:21
Count: 2
Count: 12
Count: 12288
Count: 16399
Count: 35072
Count: 62465
Count: 252
Reset counter: 51
Mileage: 65785 km
Date: 2026.14.31
Time: 08:54:44
Count: 12
Count: 4608
Count: 8194
Count: 39168
Count: 1
Count: 508
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000001011834
VCID: EFE792FCFE261DFE62-80BA
Reset counter: 78
Mileage: 65490 km
Date: 2026.14.23
Time: 08:17:28
Fault Frequency: 20
Reset counter: 51
Mileage: 65785 km
Date: 2026.14.31
Time: 08:55:01
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Mileage: 167 km
Date: 2012.14.01
Time: 00:00:10
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371158120439
Coding: 7B994B9A08AB0B0008382000240884C500C2502E60000000300000000000
VCID: AF6752FCFEA65DFE22-80FA
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: ÿÿÿÿÿÿÿÿÿÿ HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH0005785
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0288155
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
03303 - Response Closing Status of Rear Left Door
Reset counter: 90
Mileage: 65102 km
Date: 2026.14.11
Time: 14:04:49
Reset counter: 22
Mileage: 167 km
Date: 2012.14.01
Time: 00:00:04
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM06L4Y6
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: B46D5D901F807E265F-80E0
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000FSE10S
Coding: 303036
Serial number: 3572MSME3323236EZZZT
Serial number: 3582MSME2F11216FZZZ.
Serial number: 3516KSME290E521BZZZX
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0A692E1BZZZ0
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME1C6A0518ZZZ.
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME135A6417ZZZW
11 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [136] - Resistance Too High
Mileage: 166 km
Date: 2011.14.22
Time: 19:02:56
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 149 km
Date: 2003.14.00
Time: 15:13:47
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 149 km
Date: 2003.14.00
Time: 15:13:47
B1006 1B [137] - Resistance Too High
Mileage: 149 km
Date: 2003.14.00
Time: 15:13:47
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 149 km
Date: 2003.14.00
Time: 15:13:47
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 201 km
Date: 2012.14.12
Time: 00:33:55
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 166 km
Date: 2011.14.22
Time: 19:02:56
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [136] - Open or Short to Plus
Mileage: 166 km
Date: 2011.14.30
Time: 18:50:03
9444885 - Driver's seat position sensor
B101E 15 [136] - Open or Short to Plus
Mileage: 166 km
Date: 2011.14.22
Time: 18:49:25
9445141 - Passenger's seat position sensor
B101F 15 [136] - Open or Short to Plus
Mileage: 166 km
Date: 2011.14.22
Time: 18:49:25
9450752 - Crash data stored; passenger side
B1035 00 [137] - -
Mileage: 149 km
Date: 2003.14.00
Time: 15:13:42
Address 17: Instruments
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: F0E59180231802067B-80A4
Fault Frequency: 49
Reset counter: 51
Mileage: 65785 km
Date: 2026.14.31
Time: 08:54:44
01304 - Radio
Reset counter: 90
Mileage: 57289 km
Date: 2019.14.25
Time: 17:15:52
Component: IMMO H04 0604
VCID: EAD183E80DC4F8D635-80BE
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662364175
VCID: A953BCE4C04233CEFC-80FC
01304 - Radio
Reset counter: 90
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3313132
Coding: 01000400020006
VCID: E3CFEECCE2EEA99EF6-80B6
Fault Frequency: 25
Reset counter: 51
Mileage: 149 km
Date: 2005.14.03
Time: 16:16:06
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662489289
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: A757BADCDE5605BEEA-80F2
0022 - Radio
U1066 00 [008] - No Communication
Reset counter: 90
Mileage: 57289 km
Date: 2083.14.27
Time: 18:23:39
End-------------------------(Elapsed Time: 03:01)--------------------------
