Key transponder not recognised by immobiliser - Golf VR6
Bigtinks
Walton-on-Thames, UK
C?ID=11191
My first post.
I have a 1996 Golf VR6 euro spec so with the separate immobiliser and transponder keys. The key barrel in the ignition lock has failed and it isn’t possible to order a new lock to the original key code from VAG (as they are obsolete) nor can the barrels be dismantled without irreversible damage. I was lucky enough to purchase a NOS VAG lock with two keys both of which are fitted with the transponder chips. The only problem is that the immobiliser won’t recognise the chips (Immobiliser module/measuring blocks-08/Group 001/third field) and returns a ’0’ rather than a ‘1’. It recognises the old keys. Assume you don’t need to enter the SKC to recognise the new keys as this isn’t how it is explained in the key matching ‘how to’ at http://wiki.ross-tech.com/wiki/index.php/Immobilizer_I_Key_Matching_(Separate). Are there differing styles of transponder keys. The old and the new are both stamped AH and WFO and look identical.
I appreciate that I could carefully remove the old transponders and swap them into the new keys but would rather prefer to work out what the issue is. Then on to the door, boot and glove compartment locks...
Any ideas are appreciated.
Bigtinks
C?ID=11191
Forgot to say I have the SKC from the original key labelling.
Bigtinks
C?ID=11191
Please can an administrator move this post to the General VW/Audi Repair section. Apologies for my error.
If you'll post an Auto-Scan, I'm fine with moving it to the real Car Repair Support section.
I'm not that familiar with these old, separate immobilizer systems, but I wouldn't think you should need a PIN code to check whether the Immo "sees" the keys.
HMC
C?ID=28246
Why don't you swop the old transponders to the new keys?
Regards HMC
Bigtinks
C?ID=11191
And thanks HMC but swapping the transponders is accepting defeat so I would like understand why the immobiliser can’t ‘see’ the keys before I go down that route.
Neil
Bigtinks
C?ID=11191
Auto-Scan as below. No immo fault with the old key near the reader.
Thursday,22,October,2020,19:33:23:26528
VCDS Version: 20.4.2.0 (x64)
Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)
Scan: 01 02 03 08 12 15 25 41 56
Address 01: Engine Labels: 021-906-256.lbl
Part No: 021 906 256
Component: MOTRONIC M3.8.1 HS V02
Coding: 00000
Shop #: WSC 01268
   VCID: 4FA7164E8DBA8CFEDA-4B18
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00158
   VCID: 28559DD2C894BBC67B-4AB4
            35-00 - -
Address 15: Airbags Labels: 6N0-909-60x-VW2.lbl
Part No: 6N0 909 603 E
Component: AIRBAG VW2 V00
Coding: 00069
Shop #: WSC 01268
   VCID: 346D79A2045CCF26C7-4B96
Address 25: Immobilizer Labels: 1H0-953-257.lbl
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0S2273192 V00
Coding: 09600
   VCID: 2A5167DAD69889D66D-4B32
End-------------------------(Elapsed Time: 02:05)--------------------------
/CODE]
Bigtinks
C?ID=11191
Starting with the new un-coded key:
Coding: 09600
VCID: 2A5167DAD69889D66D-4B18
01176 - Key
65-10 - Unauthorized - Intermittent
What do you seen in the Immo itself, MVB 001. Field 3 should show you something about the status of the key.
Bigtinks
C?ID=11191
Immobiliser module/measuring blocks-08/Group 001/third field is ‘0’ for the new keys but ‘1‘ for the old keys. Needs to show ‘1’ to indicate the Immo is recognising the transponder. The only thing I can think is that there are differing types of transponder although the keys are both from the same period of production.
Sounds like it. I believe there are highly specialized locksmith tools that can identify and test transponders, but I'm not sure...
Bigtinks
C?ID=11191
Thanks Uwe. I'll pop down to my automotive locksmith and see if they can read the transponders. Otherwise it will be a transponder swap with regretted defeat...
Neil
