One Touch window operations broken
CineXMike
C?ID=222249
Dear Ross-Tech users,
I am having this issue where my One-Touch window functionality has failed. No fault codes and the ends are learned.
If i run the output tests trough VCDS all operations succeed successfully and aswell I've checked the readings from the window operation buttons which range from Open, Auto Open, Close and Auto Close.
Autoscan:
Thursday,02,July,2020,13:32:07:10011
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ1KZBW183224   License Plate: SJ170T
Mileage: 62670km-38941mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 37 42 44 46 4C 52 56 77
          A5
VIN: WVWZZZ1KZBW183224   Mileage: 62670km-38941miles
Address 01: Engine (J623-CBZA)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 AK    HW: 03F 906 070 B
   Component: SIMOS10.12H03 9673
   Revision: --H03---    Serial number: 00000000000000
   Coding: 002500D6232400080000
   ASAM Dataset: EV_ECM12TFS02103F906070AK 004008
   ROD: EV_ECM12TFS02103F906070AA_004_VW32.rod
   VCID: 6BFB2E2082A2EBDECE-803E
Readiness: 0010 0001
   Part No SW: 0AM 300 050 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9033
   Revision: 00040034    Serial number: CU501011205939
   Shop #: WSC 00191 264 15243
   VCID: 3245F344AD087A16CD-8066
   Revision: 00H31001
   Coding: 113B200D212A00FD880D04E6841D0040150C00
   VCID: 76CD0F54C1E0263621-8022
02186 - Engine <-> ADR Interface
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:52:34
                    Count: 3
                    Count: 14
                    Count: 4608
                    Count: 8206
                    Count: 50944
                    Count: 1
                    Count: 1
                    Count: 94
   Part No SW: 5ND 907 044 E    HW: 5ND 907 044 E
   Component: Climatronic   H03 0404
   Revision: 00001K02
   Coding: 0000000000
   VCID: 44A9A59CCFBCC4A66F-8010
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:54:16
9496613 - Sunlight Photo Sensor
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:54:16
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:54:16
   Part No SW: 1K0 937 086 J    HW: 1K0 937 086 J
   Component: BCM PQ35  M+  103 0615
   Revision: 00103 AD
   Coding: 40180A38C833F390600C0089740081EC47710088736D8D60648060200040
   VCID: 3753C250866A9F3EFA-8062
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 04121  26  0512
   Coding: 009F95
   Component: RLS 161210 05  54  0403
   Coding: 0730AD
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0116
   Revision: --------    Serial number: 13991032216273
   Coding: 10810A
   VCID: 48B1B1ACFB94E0C683-801C
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000546276
   Coding: 0010000
   Shop #: WSC 05311 000 00000
   VCID: 3851C16C4B749046F3-806C
                    Fault Status: 01100101
                    Fault Frequency: 9
                    Reset counter: 245
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:50:08
                    Count: 2
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 245
                    Mileage: 62657 km
                    Date: 2020.07.02
                    Time: 22:01:13
                    Count: 3
                    Reset counter: 246
                    Mileage: 62657 km
                    Date: 2020.07.02
                    Time: 22:01:13
                    Count: 14
                    Reset counter: 30
                    Mileage: 62654 km
                    Date: 2020.07.02
                    Time: 18:57:49
                    Count: 34
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5R01HZL$
   Coding: 00003832
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3147FC48600E410EB4-8064
   Serial number: 3572MSME11636059ZZZO
   Serial number: 3582MSME112D5659ZZZ-
   Serial number: 3512QSME1250780FZZZT
   Serial number: 3522QSME1A2B7920ZZZY
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number: WHRPIÉhtHHHfg
   Coding: 189A100002
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 78D1016CC3F4504633-802C
   Component: E221__MFL-TK6  H07 0022
   Serial number: 50000000000000803283
   Coding: E30000
117028 - Databus
                    Reset counter: 28
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 12:14:33
229211 - Cruise Control Switch
          B1154 13 [008] - Open Circuit
                    Reset counter: 28
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:55:34
267264 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:50:01
   Part No SW: 5K7 920 882 C    HW: 5K7 920 882 C
   Component: KOMBI         H02 1104
   Coding: 111D010000
   Shop #: WSC 00040 040 00011
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3753C2508E6A9F3EFA-8062
12858113 - Implausible Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [008] - -
                    Reset counter: 31
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 12:07:17
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1642
   Revision:   H51       Serial number: 18011400F13614
   Coding: 35040A
   VCID: 7CD91D7CFFCC7C6657-8028
                    Fault Status: 00110100
                    Reset counter: 21
                    Mileage: 62486 km
                    Date: 2020.06.29
                    Time: 14:35:46
                    Mileage: 58778 km
                    Date: 2020.05.01
                    Time: 21:26:51
03395 - Control Module for High Beam Assistant
                    Fault Status: 01110100
                    Reset counter: 87
                    Mileage: 58778 km
                    Date: 2020.05.01
                    Time: 21:26:55
   Component: IMMO          H02 1104
   VCID: 6AF52B248D58F2D6B5-803E
Address 37: Navigation
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2119
   Coding: 0012598
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3449F55C571C7426DF-8060
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2151
   Coding: 0012598
   VCID: 354FC8585C666D2EE8-8060
Address 56: Radio
Address 77: Telephone
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0194497322
   Coding: 01010100010202110001000000000000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 3957C468B87E894E0C-806C
2621440 - Databus
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:56:14
2686976 - Databus
                    Reset counter: 243
                    Mileage: 62632 km
                    Date: 2020.07.02
                    Time: 11:56:14
End-------------------------(Elapsed Time: 01:59)--------------------------
Does someone have any idea on how this function could be restored?
Greetings,
Mike
Jef
HQ
Have engine at idle. Roll windows up all the way, for for each window do the following 3 steps:
  1. Pull up on window switch and hold it that way for 3 seconds, then release.
  2. Pull up on window switch and hold it that way for 3 seconds, then release.
  3. Pull up on window switch and hold it that way for 3 seconds, then release.
:) Now test the one touch operation.
CineXMike
C?ID=222249
Up every time? Just 3 times the same step.
Ive already done allot of that combinations.
Jef
HQ
The window will already be rolled up, so when you pull up on the switch and hold it for 3 seconds (3x times), the window has no where to go.
As I understand it... the door module is counting pulses from the motor that moves the window. Full travel of the window is [XYZ] pulses. The door module also is monitoring the amp draw of the motor. So when you have the window rolled up all the way, it can't move any further and you then pull up on the switch, causing a big amp spike from the motor, but no movement. 3 times in a row and the door module learns that is top of travel.
From that, as the window rolls up or down, it counts pulses from the motor and knows where the window is in space. When rolling up, the motor draws maybe 2.5A, normal. If little Bllly gets he head in the way as the window rolls up, the motor starts to bind up since the window is blocked and the amp load shoots up, but the pulse counts says the window isn't all the way up, so reverse direction so stupid little Billy doesn't get harmed. It is crap like this why there are so many stupid people around these days, we aren't weeding them out like we use to.
Without knowing where top of travel is, it can't correctly do pinch protection, so one touch up is disabled. Also, in most cases, if pinch protection is triggered, you have to also relearn the top of travel.
Mari
C?ID=150535
If window is closed, roll down and hold 3 seconds, then roll up and hold 3 seconds... one touch should work again after that!
[dutch on]
Wanneer raam gesloten is, raam geheel openen en de knop 3 seconden langer ingedrukt houden, raam geheel sluiten en wederom knop 3 seconden langer ingedrukt houden. Raam zou weer moeten open gaan/sluiten met 1 druk op de knop... Althans zo werkte het bij mijn Golf 5 en mijn huidiige Golf 7.
[dutch off]
CineXMike
C?ID=222249
None of the above steps fixed it. I've already tried allot of this combinations. It's just insane all signals are there and output tests does the job fine.
South Molton, UK
I seem to remember reading someone that on MQB platform vehicles you might need to do the "operate switch when window at end stop" FIVE times to reset one-touch operation?
CineXMike
C?ID=222249
This still did not provide any results. The weird thing is it happened to both doors. Seperate modules and both failed simultaneously.
Fred's Imports
Vermont, USA
C?ID=16454
Does the window switch in the driver's door feel normal like two steps?
CineXMike
C?ID=222249
Yes it does. Measurements blocks also show the switches operate normally. I can’t think of any other then the modules died but both?
