Skoda Octavia Mib2 retrofit
vagcodinguk
C?ID=403194
hi guys, I have done a retrofit today on a Octavia VRS 2015 which originally came with a Mib1 5E0035874A. I fitted a Mib2 5Q0035874C. I just copied/pasted long coding from Mib1 into Mib2 after fitting then only changed the USB functionality in coding and the Media Command function disappeared from the Mib2 menu with the Wlan option from the Settings. I had a look on the long coding trying to figure out which Byte/Bit changes them but had no luck so far. Any help will be appreciated. Thanks
Long Coding from original Mib1: 03735101FF0000001111120100A800002F0001860100010046
Long Coding that came with the new Mib2: 03730201FF00000051111201008800002F0208C601200500CF
Long Coding from Mib1 pasted on Mib2 with USB Function changed: 03735101FF0000001111120100A800002F0001C60100010046
@vagcodinguk: hi. If I understand the problem correctly (not sure that I do) - I note that Byte24 in the changed long-code string for the new MIB has the value hex46, or Binary 0100 0110. This means that Bit 3 is not set (the highlighted Bit in the Binary value).
According to my database, the software switch for Byte24, Bit3 activates the MIB's internal WLAN module. Try flipping this switch - perhaps?
vagcodinguk
C?ID=403194
That worked, thanks a lot! Is this database which says what each bit does available to download from anywhere?
Also any advice regarding the only 2 left errors on the 5f?
thanks
Wednesday,21,October,2020,15:35:20:43136
VIN: TMBBE7NE6F0220369   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TMBBE7NE6F0220369   Mileage: 76078km-47272miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0010
   Revision: --H13---
   Coding: 0C1D00322424010B0000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001014
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6B83C28AC30F7853971-803E
Readiness: 0010 0001
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01503110589
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 290FF8820973AA4325D-807C
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 60825000002155
   Coding: 1A0793915422296C007A060641CC2958C92A9400608294F600410070C009
   VCID: 47CB5E3ABF277C33D39-8012
   Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01110004000100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2D070C923D9BB663C95-8078
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011507802765
   Coding: 0F101A42C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00598526DA898B0B523-8054
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150314  041 0570
   Serial number:         150319071407
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S5Y15M03D30H00M57S08
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1430221MP
   Serial number: 00000000000031702507
   Sun Roof:
   Subsystem 5 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serial number: 0000FST0006LKOZ00000
   Coding: 981803
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231507102934
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3A2D37CEFCD511DB5C7-806E
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4P59CYL9
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00157
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B06DAA777F4F32B9-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 603 15
   Serial number: 3576U0000004B64D331A
   Subsystem 2 - Part No SW: -----------    HW: 454 001 503 15
   Serial number: 3586U00000067D39A31I
   Subsystem 3 - Part No SW: -----------    HW: 454 802 003 15
   Serial number: 3516R12A83706000000-
   Subsystem 4 - Part No SW: -----------    HW: 454 802 003 15
   Serial number: 3526R4EA93706000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 402 15
   Serial number: 3556V74A59A05000000E
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 20031508490736
   Coding: 1410
   VCID: 7DA7FCD2AD7BE6E3395-8028
   Part No SW: 5E0 920 956     HW: 5E0 920 956
   Component: KOMBI         304 4311
   Coding: 27A501086980A60001086A021000000000000000
   VCID: 698FB882C9F36A43E5D-803C
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003307053
   Coding: 030100042F085900EF00026A1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72BDDFEEE425A99B547-8026
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000D1816090315
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 62069824134291673514
   Part No SW: 5Q4 959 393 C    HW: 5Q4 959 393 B
   Component: TSG FS        009 0015
   Serial number: 0000142861300
   Coding: 001C00208001040000001100
   VCID: 43D34A2A8B1F50130F1-8016
   Serial number: 00000000000005568406
   Coding: 1D0200
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9103
   VCID: 372B2EFACFC70CB3A39-8062
   Part No SW: 5Q4 959 392 C    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0015
   Serial number: 0000142710714
   VCID: 42DD4F2E9405591B047-8016
   Serial number: 00000000000004927985
   Coding: 050200
   Coding: 03DE00003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40D945269A094B0B123-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0478
   Serial number: SKZAZ2U0751955
   Coding: 03735101FF0000001111120100A800002F0001C60100010046
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 343119F6DEB1E7AB86B-8060
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHV1222859
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 130
                    Mileage: 76078 km
                    Date: 2020.10.21
                    Time: 15:30:00
                    Voltage terminal 30: 11.4 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 130
                    Mileage: 76078 km
                    Date: 2020.10.21
                    Time: 15:30:00
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000327797
   Coding: 0100000001030304000400000000010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B2332CAF3EF28D3471-806E
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150307201232
End----------(Elapsed Time: 01:48, VBatt start/end: 11.5V/13.5V)-----------
downtime
Finland
C?ID=280813
Check the adaptations. You have most likely ACC and brake assist activated in BAP channels. Change them to not activated and the errors should be gone.
