1.9 sdi caddy 2002 glow plugs not working
adfow_uk
C?ID=136053
Hi, Ive got a VW Caddy 1.9 SDI with the glow plug relay not activating. Relay works correctly in output tests and with coolant temp sensor disconnected. Coolant temp is currently reading 15 degrees which I know is not very low but would still expect activation. Runs lumpy fromcold for 30 secs or so, but ok with sensor disconnected. Sensor is good, wiring from sensor to ECU good, relay good and glow plugs good. Scan below
Wednesday,21,October,2020,14:54:44:64999
VCDS Version: 20.4.2.0
VIN: XXXXXXXXXXXXXXXXX   License Plate:
Chassis Type: XX (9K - VW Caddy Kombi (1996 > 2003))
Scan: 01 03 15 25 41 56
   Part No: 038 906 013 AN
   Component: 1,9l R4 EDC 0000SG  2171
   Coding: 00002
   Shop #: WSC 06402
   VCID: 5DBA8439D7CC696E58-4AB4
Readiness: N/A
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 603 AE
   Component: AIRBAG VW3 -        V04
   Coding: 16709
   Shop #: WSC 06402
   VCID: 6CDCD9FD1C7610E6DF-4AE6
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
   Part No: 6X0 953 257
   Component: IMMO                0008
   Coding: 00001
   Shop #: WSC 00050
   VCID: 7DFAE4B9770C896E78-4A9C
   XXXXXXXXXXXXXXXXX     VWZ1Z0B2110335
01176 - Key
            65-10 - Unauthorized - Intermittent
End-------------------------(Elapsed Time: 01:24)--------------------------
