Altitude Sensor / Boost Pressure Sensor fault P1592
john1292
C?ID=288294
Hi I need a bit of advise please, Earlier on today I started my car (it was already at working temperature) and straight away the glow plug light was flashing. I started moving to see if it would go out but it didn't, luckily I was in a car park. I switched the car off waited a couple of minutes and turned on again. All was fine. When I got home I plugged in Vagcom and carried out a scan, to find a P1592 fault, among a couple of other faults. what is very strange with this one there is no date and time logged and it is telling me i was doing 255kph. (I was stationary). Any ideas please. Log Below.
Wednesday,21,October,2020,12:34:22:09568
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ4H0FN012370   License Plate: VK
Mileage: 65989km-41003mi   Repair Order:
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 4H0 997 401 E    HW: 4G0 907 401 E
  Component and/or Version: 3.0TDI EDC17  H14 0002
           Software Coding: 0A2A4032052601030800
            Work Shop Code: WSC 56987 001 1048576
              ASAM Dataset: EV_ECM30TDI0114H0997401E 001002 (AU64)
                       ROD: EV_ECM30TDI0114H0997401E.rod
                      VCID: 2F6AC2D076382CFEBA-807A
5168 - Altitude Sensor / Boost Pressure Sensor
          P1592 00 [032] - Implausible Correlation
                    Mileage: 65913 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.920 V
                    Charge air pressure: actual value: 200 hPa
                    Ambient air pressure: 975 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 30 34 36 3B 42 44 46
          47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90 AC
VIN: WAUZZZ4H0FN012370   Mileage: 65989km-41003miles
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 997 401 E    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0002
   Revision: 58H14---
   Shop #: WSC 56987 001 1048576
                    Mileage: 65913 km
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H18 1011
   Revision: --H18---
   VCID: 7CF0259CF7CE07664F-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: 60E5AB8006A7D501E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 43829E60CAB0B89E4E-8016
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0551
   Coding: 05B76F4E000000000000
   VCID: 6ED41FD4B9B265F6F1-803A
   Serial number: 0214000096215008
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000107698895
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 3460CDBC971E0F26C7-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 4 Zonen H20 0210
   Coding: 362100BE300000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B52D6C0422050DE96-807E
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000846087801
   Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
   VCID: 68D869CC9B56BBC6BB-803C
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140322  H36 0090
   Serial number:         140617221752
   Coding: 0045F7
   Serial number: 22835169
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 03 07 2014  00000706
   Component: EVLS-SG  H08 0300
   Serial number: WA108371000007682258
   Coding: 020300
   Serial number: 38584537000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1001JZFD
   Coding: 30333045313430303038554A305234483053
   VCID: 3B72E680B240C05E06-806E
   Serial number: 3575HRB40552LPPK4OFA
   Serial number: 3585HRB40672MSOA586Q
   Serial number: 3515JRB405F2SIIAB0BL
   Serial number: 3525JRB405D2SIIAO0J+
   Serial number: 3554VRB400E52L7E7HLQ
   Serial number: 3564VRB400E52L7EJ1PR
   Revision: --------    Serial number: 01335NG40016P
   Coding: 000034
   VCID: 377AFAB08668E43EE2-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 16 05 2014  E0404115
   Part No SW: 4H0 920 910 P    HW: 4H0 920 910 P
   Component: TDieGB------- H53 0707
   Revision: 37081202    Serial number: 658030714592022
   Coding: 33A708001B412600010000
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 316EC4A8600C3A0EAC-8064
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2140613000158
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001458644
   Coding: C0CD078108
   VCID: 75E630B8D4E4562E30-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 51167757381911393258
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14182003481021200410
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04028B6B74745D545420363E00
   VCID: 67DA6AF09648B4BEB2-8032
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 3878F98C8376EB46EB-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000061133
   Coding: 01010101000000000001000202
   VCID: 64C07DFC677EDFA697-8030
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
          C10C8 00 [008] - -
                    Reset counter: 69
                    Mileage: 65970 km
                    Date: 2020.10.21
                    Time: 10:14:56
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000107699072
   Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA7701XB3D
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377AFAB08E68E43EE2-8062
   Part No SW: 4H0 959 793 S    HW: 4H0 959 793 H
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000099537368
   Coding: 011F12015E01628202083002
   VCID: 499E8C48E09C62CE84-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0027721498
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3362CEA09A10081EDE-8066
   Revision: 00002001    Serial number: 0338055991
   Coding: 011B0E2280B93881B320C784080316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000802314
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93260572
   Revision: CJ007001    Serial number: 00000000116369
   Coding: 030000
   VCID: 1D3608180494AE6E18-8048
   Part No SW: 4H0 959 792 H    HW: 4H0 959 792 H
   Component: TSG BF        H06 0280
   Revision: --------    Serial number: 0000105535178
   VCID: 3D76E898A454CE6E38-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001127612
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D56D8D87C345EEE88-8078
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02F6021022630200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00200
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00200
13706027 - Databus
                    Reset counter: 59
                    Mileage: 61530 km
                    Date: 2020.07.17
                    Time: 15:50:32
13706028 - Databus
                    Reset counter: 59
                    Mileage: 61530 km
                    Date: 2020.07.17
                    Time: 15:50:32
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109G10E7944850
   Coding: 010103010000000001
   VCID: 2D56D8D874345EEE88-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301405001
   Coding: 03000000
   Part No SW: 4H0 035 646 A    HW: 4H0 035 666 N
   Component: H-BN-EU       H47 1034
   Revision: --------    Serial number: 178GZ0EB001334
   Coding: 02010100000BF1EF45908B1E00000003E00001020000000000
   VCID: 254620F82CC466AE40-8070
   Subsystem 1 - Part No: 8R0 060 884 GS
   Component: EUR 2020  3001
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEC901LKWP
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000163688
   Component: CD-Database  5950
                    Fault Status: 00101011
                    Fault Frequency: 11
                    Reset counter: 59
                    Mileage: 63922 km
                    Date: 2020.09.14
                    Time: 14:34:56
                    Voltage: 13.20 V
   Part No SW: 4H0 959 795 E    HW: 4H0 959 795 E
   Component: TSG HL        H06 0280
   Revision: --------    Serial number: 0000105537294
   Coding: 010F12014000628202083002
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 024601010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326CCBA4650A0116D5-8066
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 173401591
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FEA02D0B6B86CFEFA-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000156007
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C27EE06A70D89E6E-8036
   Component: TSG HR        H06 0280
   Revision: --------    Serial number: 0000105536924
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN140531  0086
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C50D5DC472E57E69F-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00016971192901
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00016971189201
   Coding: 272FF2
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 141630386
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 07:10)--------------------------
Bruce
Near Philadelphia, PA, USA
Hi. Did you notice the intermittent status of the error? That means the fault occurred and was not still present at the time of the scan. Looking at the saved data, I'd guess Sun Spot activity! That is, I think this is one of the random faults that occur to confuse the best of us. I would clear the fault and see if it returns. If it does, then maybe more investigation is warranted.
john1292
C?ID=288294
Thanks for the prompt reply Bruce, I am indeed going back out very shortly. hopefully its nothing.
