Audi A2 Electric Window Fault
LHSLTD
C?ID=271214
Hi Chaps
Just looking for confirmation that I haven't missed anything.
Audi A2, electric windows worked, then they didn't.
Have scanned it as per attached.
Also went into each of the tests, and the 4 windows are coming up as no communication or similar. basically it cant talk to any of the window regulators, and I cant remember the exact wording, it has temporarily checked out of my brain for a bit.
Anyway, the fuses have been checked by the customer, he has changed the switches and any fuses to be on the safe side, and I have advised him to get another CCM.
Is there anything else I should get them to check and/or change.
Lennie
Saturday,17,October,2020,09:20:57:64069
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WAUZZZ8Z45N000952   License Plate: SN04 BHG
Chassis Type: 8Z (8Z - Audi A2 (2000 > 2005))
Scan: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
   Part No: 036 906 013 F
   Component: MED7.5.11           5130
   Coding: 00051
   Shop #: WSC 00257
   VCID: 1276D1C24D7025CBF47-5160
   WAUZZZ8Z45N000952     AUZ7Z0D2628041
17436 - Intake Manifold Tuning Valve Control Circuit
            P1028 - 35-00 - Open Circuit
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-00 -
16687 - Cylinder 3
            P0303 - 35-00 - Misfire Detected
17441 - Sensor for NOx (G295)
            P1033 - 35-00 - Signal too Low
18043 - Powertrain Data Bus
            P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes        Labels: 8Z0-907-379-MK60.lbl
   Part No: 8Z0 907 379 D
   Coding: 0007183
   Shop #: WSC 02154 785 00200
   VCID: 49C436AE65A6A613C5D-5184
   Part No: 8Z0 820 043 D
   Component: A2-KLIMAVOLLAUTOMAT 0514
   VCID: 37204056065220E3A39-258E
00710 - Defroster Flap Positioning Motor (V107)
            41-10 - Blocked or No Voltage - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01273 - Fresh Air Blower (V2)
            17-10 - Control Difference - Intermittent
Address 15: Airbags        Labels: 8Z0-959-655.lbl
   Part No: 8Z0 959 655 G
   Component: Airbag Front+Seite 0005
   Coding: 00102
   Shop #: WSC 02152
   VCID: 50F21BCA83FC97DB823-513C
Address 17: Instruments        Labels: 8Z0-920-xxx-17.lbl
   Part No: 8Z0 920 950 P
   Component: KOMBI+WEGFAHRS. VDO D04
   Coding: 04442
   Shop #: WSC 00006
   VCID: 4BC80CA66ADAB403F71-5160
            27-00 - Implausible Signal
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8Z0 951 177
   Component: Innenraumueberw.    D04
   Coding: 00001
   VCID: 55FCEADEBC1EF2F3515-5160
Address 46: Central Conv.        Labels:. 8Z0-959-433.lbl
   Part No: 8Z0 959 433 AE
   Component: Komfortgerát T39    1210
   Coding: 06859
   Shop #: WSC 02138
   VCID: 0944F6AE2026E61305D-4B1E
   Subsystem 1 - Part No: 8Z2959802A
   Component: Tõrsteuer.FS BRM 0004
   Subsystem 2 - Part No: 8Z2959801A
   Component: Tõrsteuer.BF BRM 0004
   Subsystem 3 - Part No: 8Z0959801B
   Component: Tõrsteuer.HL BRM 0005
   Subsystem 4 - Part No: 8Z0959802B
   Component: Tõrsteuer.HR BRM 0005
9 Faults Found:
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
00956 - Key 2
            35-10 - - - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
01559 - Drivers Door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
            61-10 - Won't De-Safe - Intermittent
   Part No: 8Z0 035 186 G
   Component: concert II  GRO    0001
   Coding: 00001
   Shop #: WSC 02138
   VCID: 40D22B8A539C675B123-4B1E
End----(Elapsed Time: 03:35, VBatt start/end: 11.2V/11.1V. VIgn 11.1V)-----
MartinsX
Riga, Latvia
C?ID=268515
I'd say replacing of CCM will not help.
Do window lifters are not working from drivers door switch block or from individual door switches, too?
Get the WD, check all power supplies to door control modules first.
LHSLTD
C?ID=271214
Windows do not move from any switches, VCDS does not see any of them either as described above, like it cannot talk to them. He has changed the drivers window switch block, and it still doesn't work. My first thought was a fuse or relay but he has said he has changed these.
MartinsX
Riga, Latvia
C?ID=268515
   Coding: 06859
   Shop #: WSC 02138
This one is 0x46 - CCM
Those are individual door controllers. In this car they shows up as subsystems under CCM and are not accessible directly with VCDS nor any other diagnostic scanner.
LHSLTD
C?ID=271214
   Coding: 06859
   Shop #: WSC 02138
Thanks Martins
Any idea why they would all break at the same time?
I am currently looking for a wiring diagram for the vehicle to see if they have a common feed from something like a 30A relay or Fuse or similar.
Cheers & thanks for the assistance.
Lennie
South Molton, UK
Or do they share a common data bus from the CCM?
Sounds like you definitely need to get a WD - erWin (not the US site since you are in the UK) is the best place IMHO.
MartinsX
Riga, Latvia
C?ID=268515
I disagree - CAN from CCM to all four door controllers is alive - all of them show up in autoscan.
OP can check it in 0x46 MVB 017
Also I'd suggest to check MVB 016 - do the CCM receive 30, 15, S and CAN from car correctly.
And MVB's 011, 012, 014, 015 - do the CCM "see" all window lifter switches.
After those observations are done, we can go further with WD analysis to suggest in what circuit problem may be.
BTW this car has one 30A fuse for front power windows, located in single fuse holder at left A-pillar interconnection point and another one 30A fuse for rear ones symmetrically located at right A-pillar.
So it is possible some other wire/circuit common for all four windows is at fault...
Also I suggest to clear all DTC's in CCM and rescan - maybe some actual DTC's may give us an idea where to look, even if they are not directly related to window lifters/lifter control switches ;)
LHSLTD
C?ID=271214
Thanks guys I have sent the guy a message to ask him what was happening with the vehicle and whether he wanted any assistance to take it further, but he hasn't got back to me. I wish he would, as I hate it when threads die with no conclusion.
Thanks for all the help so far, I did check the fuse in the front right of the cabin, at the base of the A Pillar and it was fine. Didn't know that there was one on the other side. If and when he gets back to me, I'll update the post.
Radiosolutions
C?ID=178437
Check wiring were it runs through drivers door rubber. Very common to break. Also through passenger door
