Good evening. Mk60ec1 issues 🤦🏻‍♂️
ED30R
C?ID=70060
After messaging dana on email, it was suggested that I post here 😎
I am aware that the chassis number is encrypted into the abs coding and I’ve managed to work these out previous but for some reason this one seems to be a head scratcher.
The car is a mk5 gti converted to S3 engine and 4wd running gear, I had this complete setup in a seat Leon previously and coded it to the Leon cluster/matching key with an immo off s3 CDLA ecu. The leon was getting rough so ive transferred it all to the mk5 that is really tidy. The leon coding that worked was
163B8012092600FB681101EC902200813C0800
The only things that are different is the golf cluster,key and ecu but they now all match for immo purpose, the can gateway is also different and I think its set to 80 MPV (if that even matters?) there’s no fault codes in the ABS and ive tried various codes but none of them seem to take, I can do all the basic settings on the pump and it accepts them so I guess its not gateway or can related?
My question is could you try provide some coding for me to try? ill include an auto scan of the car, the dsg plug was un plugged on this scan and also theres various faults as ive not got around to fitting it all up or coding out stuff after the roll cage was fitted, I don't think any of them will stop it from accepting the coding, forgive me if im wrong.
The car is 2005 uk, rhd , 345mm front brakes, 310mm rear, dsg, the chassis number is WVWZZZ1KZ5W241886 and matches in the Immobilizer
ED30R
C?ID=70060
 Thursday,15,October,2020,18:43:28:19645
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZ5W241886   License Plate: KD RED ECU KIT
Mileage: 249500km-155032mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 56
VIN: WVWZZZ1KZ5W241886   Mileage: 249500km-155032miles
02-Auto Trans -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2037732
   Coding: 040300031C070160
   Shop #: WSC 00792 210 91867
   VCID: 2404F1E6E79742A657-8070
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus
                    Fault Status: 01100001
                    Temperature: 12.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.859 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
                    Temperature: 12.0°C
                    Temperature: 13.0°C
                    Voltage: 15.113 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -
                    Fault Status: 01101000
                    Mileage: 249503 km
                    Temperature: 12.0°C
                    Temperature: 13.0°C
                    Voltage: 15.621 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Fault Status: 01100010
                    Temperature: 12.0°C
                    Temperature: 13.0°C
                    Voltage: 13.462 V
Readiness: 0110 0100
Address 02: Auto Trans
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Shop #: WSC 06314 123 12345
   VCID: 7AB8EF9EF593E4565D-802E
03306 - Coding Not Valid
                    Reset counter: 10
                    Mileage: 249503 km
                    Count: 3
                    Count: 29184
                    Count: 4161
                    Count: 49664
                    Count: 256
                    Reset counter: 10
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 49152
                    Fault Status: 01100101
                    Reset counter: 10
                    Mileage: 249503 km
                    Count: 3
                    Count: 29184
                    Count: 295
                    Count: 50944
                    Count: 256
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   VCID: 679EA6EA562169BEB2-8032
7 Faults Found:
            013 - Check DTC Memory
00576 - Terminal 15
            001 - Upper Limit Exceeded
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus
00709 - Sunlight Photosensor 2 (G134)
01273 - Fresh Air Blower (V2)
            009 - Open or Short to Ground
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 L    HW: 3C0 937 049 L
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000006166231
   Coding: A1880F0700041A00000A00000F00000000085D435C0000
   Shop #: WSC 05311 123 12345
   VCID: 322807BEAD63DC16D5-8066
   Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.35 V
                    Fault Status: 01111010
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.25 V
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.25 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.25 V
02403 - Terminal 15 for Interior
                    Fault Status: 01101100
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.65 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 10
                    Mileage: 249503 km
                    Voltage: 14.35 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0992ET
   Coding: 0012344
   Shop #: WSC 01269 785 00200
   VCID: 373E36AA4601393EE2-8062
   Subsystem 1 - Serial number: 6332MSME087E451CM
   Subsystem 2 - Serial number: 6342MSME030744752
   Subsystem 3 - Serial number: 635  SME        8
   Subsystem 4 - Serial number: 636  SME        9
11 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01588 - Igniter for Head-Airbag; Drivers Side (N251)
01589 - Igniter for Head-Airbag; Passenger Side (N252)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0001122
   Shop #: WSC 06314 000 00000
   VCID: 46C04B6E31EB50B669-8012
01426 - Controls in Steering Wheel (E221)
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0004403
   Shop #: WSC 00094 210 83586
   VCID: 302C0DB6A36FEE06A3-8064
00438 - Fuel Supply Sensor 2 (G169)
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104715026E
   Coding: BF0F0340070003
   Shop #: WSC 01324 785 00200
   VCID: 291AE0D280B59FCE64-807C
                    Reset counter: 10
                    Mileage: 249503 km
                    Time: 00:17:28
                    Reset counter: 10
                    Mileage: 249503 km
                    Time: 00:17:29
01304 - Radio
                    Reset counter: 10
                    Mileage: 249503 km
                    Time: 00:17:33
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   VCID: 44C4516607D762A677-8010
                    Reset counter: 138
                    Mileage: 249503 km
                    Time: 00:17:28
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0118
   Coding: 0000054
   Shop #: WSC 01279 785 00200
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 234    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 312A08B2A865E70EAC-8064
                    Fault Status: 11100101
                    Mileage: 249503 km
                    Time: 00:17:28
                    Battery Volts: 13.6 V
                        DD
                    Temperature: 19.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No: 1K0 959 433 AJ
   Coding: 01C802087F2D8505485AC69010CC
   Shop #: WSC 00000 785 00200
   VCID: 78BCF5960B9FF6462B-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Component: Tuer-SG         024 2429
   Coding: 0000695
   Shop #: WSC 01287 785 00200
   VCID: 383C35964B1F3646EB-806C
Address 56: Radio
End----------(Elapsed Time: 00:59, VBatt start/end: 13.7V/14.7V)-----------
ghost
C?ID=139898
Try this one:
163B8012092600FB681301EC901F00813C0800
2 Bytes were different
ED30R
C?ID=70060
Dana suggestion was
163B800D092600FB681301EC901F00813C0800
I will hopefully try both on Friday and report back 👍
Thank you
