A6/c6 4f2 diesel 2.0tdi cut off
boreks
C?ID=414516
hi ,
i have a6 c6 diesel 140 hp . switch on 10-15 secondes run and by self switch off . and after switch on again and again 10-15 secundes work and cuts off . i have half a tank fuel, new air, fuel filters. battery as well ok i try on other cars( mercedes e320 and audi a4) working nice .any sugestion ???
here is log :
Tuesday,06,October,2020,13:03:06:03954
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WAUZZZ4FX8N049346   License Plate: xxxxxx
Mileage: 342940km-213093mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53
          56 61 62 72
VIN: WAUZZZ4FX8N049346   Mileage: 342940km-213093miles
   Part No SW: 03G 906 016 MF    HW: 03G 906 016 MF
   Component: R4 2,0L EDC G000CG  1142
   Revision: --H05---    Serial number:
   Coding: 0000076
   Shop #: WSC 66565 257 00032
   VCID: 73B3DB9447B5DFB35F1-8026
006215 - Please check DTC Memory of ABS Controller
               P1847 - 000 -
                    Fault Frequency: 31
                    Mileage: 342942 km
                    Date: 2007.05.22
                    Time: 13:11:35
                    Voltage: 11.78 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000100
Readiness: 0 0 0 1 X
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F9 910 155 B    HW: 01J 927 156 JG
   Component: V30 01J 2.0l PD RdW 0010
   Revision: --H03---    Serial number: 00000000000311
   Coding: 0000001
   Shop #: WSC 02325 758 00200
   VCID: 2A0D06F0D0FFDE7B2C7-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
   Component: ESP8 front      H01 0070
   Coding: 0020856
   VCID: 6597B5CCF9613103C15-8030
                    Fault Status: 01100101
                    Fault Frequency: 19
                    Reset counter: 42
                    Mileage: 342942 km
                    Date: 2007.05.22
                    Time: 14:12:12
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x001E
                    Hex Value: 0x3E90
                    Hex Value: 0x00FF
01486 - System Function Test Activated
                    Fault Frequency: 18
                    Reset counter: 42
                    Mileage: 342942 km
                    Date: 2007.05.22
                    Time: 14:12:55
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0021
                    Hex Value: 0x4190
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500877733
   Coding: 0000019
   Shop #: WSC 02323 758 00200
   VCID: 6393ABD4F7554F332F1-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 769 H    HW: 4F0 035 769 B
   Component: MMI Cockpit     H55 0410
   Revision: C61030BE    Serial number: AUZ6Z3G95230R1
   Coding: 0140002
   Shop #: WSC 00370 210 64492
   VCID: 323D1E90F82F96BB947-8066
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000861162
   Subsystem 3 - Serial number: 0112.09.070000000100010441ÿ
   Subsystem 4 - Serial number: 010441ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000441028
   Coding: 0001044
   VCID: 1C61D0288AAB30CBAEB-8048
   Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
   Component: ILM Fahrer      H18 0250
   Coding: 0000101
   Shop #: WSC 02335 758 00200
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0140002
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0TVUV-
   Coding: 0013381
   VCID: 290FF9FCD5F9D56325D-807C
   Subsystem 1 - Serial number: 6332CSME2E547764A
   Subsystem 2 - Serial number: 6342CSME2E515A234
   Subsystem 3 - Serial number: 6352QSME3B032915B
   Subsystem 4 - Serial number: 6362QSME39543261B
   Subsystem 5 - Serial number: 63734SME362F34371
   Subsystem 6 - Serial number: 63834SME3B13160B
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H02000    Serial number: 90054072320033
   Coding: 0102141
   VCID: 270BFFC4C3EDE313339-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4F0 920 951
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 64714X497
   Coding: 2304458
   Shop #: WSC 80093 222 69422
   VCID: 2019E4D8A6C3142B723-8074
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B078318198
   Coding: E5519E5770220600
   Shop #: WSC 02334 758 00200
   VCID: 2D070DECE111C943C95-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046006    Serial number: AUZ5ZBG3471047
   VCID: 1869CC387E935CEB8A3-804C
Address 37: Navigation        Labels: Redir Fail!
   Coding: 0140002
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0210
   Revision: 00-00000
   Coding: 0002586
   Shop #: WSC 02327 758 00200
   VCID: 2C0100E8DA0BC04BDEB-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H25 0200
   Revision: 02000025    Serial number: 01063816790000
   Coding: 0000251
   VCID: 313F119CFD29ADA3EDD-8064
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
   Component: Amp.-ASK-RD   H07 0250
   Revision: S0900000
   Shop #: WSC 02399 823 56573
   VCID: 2615F2C0C8E7FA1B08F-8072
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000469859
   Coding: 0001104
   VCID: 5EE59A20DC3762DB00F-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0210
   Revision: 00-00000
   Coding: 0002586
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000131
   Shop #: WSC 02324 758 00200
Address 56: Radio        Labels: Redir Fail!
   Coding: 0140002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000135672
   VCID: 2313EBD4B7D50F336F1-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2708080328
   Coding: 344630393135313035432056413032373038303830333238
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0002050
   VCID: 2E050AE0EC17B25BF0F-807A
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0002050
End----(Elapsed Time: 01:36, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Sunday,18,October,2020,16:50:42:03954
VIN: WAUZZZ4FX8N049346   License Plate: RO57LUE
          56 61 62 72
   Coding: 0000076
               P1847 - 000 -
                    Fault Frequency: 12
                    Mileage: 342942 km
                    Date: 2007.06.07
                    Time: 09:31:39
                    Voltage: 12.16 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000100
   Coding: 0000001
   Coding: 0020856
                    Reset counter: 42
                    Mileage: 342942 km
                    Date: 2007.05.16
                    Time: 12:11:07
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x001E
                    Hex Value: 0x3E96
                    Hex Value: 0x00FF
   Coding: 0000019
   Coding: 0140002
   Coding: 0001044
   Coding: 0000101
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0140002
   Coding: 0013381
   Coding: 0102141
   Coding: 2304458
   Coding: 0140002
   Revision: 00-00000
   Coding: 0002586
   Coding: 0000251
   Revision: S0900000
   Coding: 0001104
   Revision: 00-00000
   Coding: 0002586
   Revision: --H04---
   Coding: 0000131
   Coding: 0140002
   Coding: 0002050
   Coding: 0002050
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
boreks
C?ID=414516
no. normal 2.0 tdi (C6 4F2) diesel
MartinsX
Riga, Latvia
C?ID=268515
What engine code is it?
boreks
C?ID=414516
i think is BRE but i can check tomorrow
MartinsX
Riga, Latvia
C?ID=268515
Check the fuel lift pump first.
boreks
C?ID=414516
group 35 in engine 1 or ????
MartinsX
Riga, Latvia
C?ID=268515
No, mechanically. Disconnect feed pipe from fuel filter or from tandem pump and actuate a lift pump relay with VCDS or remove relay and bridge 30 to 87. Do not forget suitable container where fuel will flow from disconnected pipe, if pump is ok :D
boreks
C?ID=414516
where in vcds ?
boreks
C?ID=414516
in newest version (20.4)
Try Basic Settings, Group 035. This should run the the pump for ~30 seconds, same as if you were replacing the fuel filter.
