Here is an Auto-Scan and 'some' controller channel maps for a North America 2021 Audi S8L
Vehicle Identification No. WAU8SAF8XMN002330
Model Audi S8L
Date of production 01.08.2020
Model year 2021
Sales type 4N85SA
Engine Code CWWB
Transmission Code TZU
Axle drive 8A
Exterior color / Paint Code T2 / Z1Y
Auto-Scan
01-Engine
blockmap-01-4N0-907-557-G
adpmap-01-4N0-907-557-G
02-Auto Trans
blockmap-02-4N0-927-158-AN
adpmap-02-4N0-927-158-AN
09-Cent. Elect.
blockmap-09-4N0-907-063-JE
adpmap-09-4N0-907-063-JE
46-Central Conv.
blockmap-46-4N0-907-064-EG
adpmap-46-4N0-907-064-EG
drp
Model Audi S8L
Model year 2021
Sales type 4N85SA
Engine Code CWWB
Axle drive 8A
Auto-Scan
Thursday,15,October,2020,12:21:42:59422
VCDS Version: 20.9.1.0 (x64) HEX-NET2 CB: 0.4530.4
Data version: 20200919 DS322.0
VIN: WAU8SAF8XMN002330 License Plate:
Chassis Type: F8-AU65 (4K1)
Scan: 01 02 03 06 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 52
5F 61 6D 74 75 81 82 84 A5 A9 BA BB BC C4 CA CB CD CF D4 D5
D6 D7 DB DC DD DE E0
VIN: WAU8SAF8XMN002330 Mileage: 74km-45miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
D4-Roll Control 1 -- Status: Malfunction 0010
D5-Roll Control 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
E0-Auxiliary Display 1 -- Status: Malfunction 0010
Address 01: Engine (J623-CWWB) Labels: None
Part No SW: 4N0 907 557 G HW: 0P2 907 309 A
Component: V8 4.0l TFSI H31 0002
Revision: 72H31000
Coding: 0A2A0012256E010E34286000000400000000000000000000
Shop #: WSC 02664 785 00200
ASAM Dataset: EV_ECM40TFS0114N0907557G 001002
ROD: EV_ECM40TFS0114N0907557G.rod
VCID: 3A26590ABCA1183B69F-806E
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4N0 927 158 AN HW: 0D6 927 156 H
Component: 0D6 40TSINAR H05 1001
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002015
ROD: EV_TCMALX52011_VW53.rod
VCID: 0154EEE691F78BE3685-8054
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H02 0810
Serial number: 2007140313
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 4N0 907 379 AQ HW: 4N0 907 379 P
Component: ESP9 Premium H06 0857
Coding: 2CAA569D31A24B9811A14C945B7DD1E6F53989346A8CD28832DA8B67AF9C91
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 0740F0FEBFD3B5D3261-8052
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 D HW: 4M4 959 760 D
Component: MEM-BFS 009 0064
Serial number: 00000414298883
Coding: 011CB2400005BEA148438181A101A10081A100070700878700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
ROD: EV_SCMPasseSideCONTIAU736_AU58.rod
VCID: 3FD0281EA7833D135E1-806A
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ800108072040258802
Coding: BF2F00
Valve block 2 in front seat passenger side:
Subsystem 2 - Part No SW: 4N0 907 182 D HW: 4N0 907 182 D
Component: N478 VB2 BFSv H04 0010
Serial number: SJ800111072011470082
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 JE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0712
Coding: 07500363C0291CDD070E57A81CEF9C2A131BB7511406049381050A00020196000869020200100000000007030047081838021030C003F107000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 017002
ROD: EV_BCM1BOSCHAU651_017.rod
VCID: 7AA6990AFC21D83B29F-802E
Subsystem 1 - Part No SW: 4N1 955 119 HW: 4N1 955 119
Component: WWS651 190705 052 0915
Serial number: 904753F0301918600034
Coding: 7DC727
Serial number: 24940512X81A955555A0
Coding: 02005E
Subsystem 3 - Part No SW: 4N1 941 501 C HW: 4N1 941 501 C
Component: E1 - LTM H09 0086
Serial number: 21S14.07.2000690837
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z014I02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 B HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR117012023311076
Interior Light Module:
Subsystem 6 - Part No SW: 4N0 947 135 CT HW: 4N0 947 135 CT
Component: Dachelektroni H42 0063
Serial number: 00000663050000000000
Coding: 200000
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H07 0200
Serial number: WA141202000081681687
Coding: 0A0700
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BK18436748
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BK18436735
Subsystem 10 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BK18436750
Subsystem 11 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BK18436751
Front windshield washer pump:
Subsystem 12 - Part No SW: 4N0 907 605 B HW: 4N0 907 605
Component: J1100/SWP H21 0015
Serial number: 00000000001931704894
Coding: 020000
Interior Light Module 2:
Subsystem 13 - Part No SW: 4N0 947 111 G HW: 4N0 947 111 G
Component: Dachelektroni H42 0060
Serial number: 00000672870000000000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4N0 907 561 K HW: 4N0 907 561
Component: LRR4 H12 0492
Coding: D5659F5478082C00010360E1000000BE4A1246484481409E25
ASAM Dataset: EV_ACCBOSCHAU65X 002026
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 39244606B9A71323605-806C
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 AC HW: 4N0 959 655 AC
Component: AirbagVW31 H05 2844
Serial number: 0031JM006WRO
Coding: BFFCF0C080C00500A000003FF21D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
ROD: EV_AirbaVW31SMEAU65x.rod
VCID: 7DAC9216ED0FEF030CD-8028
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2020197651900000
Coding: 0A0301
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2020090733000000
Coding: 0A0301
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D20000D3EJX0E
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 001 507 20
Serial number: 357000000009B2DC6A4$
Subsystem 5 - Part No SW: ----------- HW: 480 001 507 20
Serial number: 35800000000D5AEC6A44
Subsystem 6 - Part No SW: ----------- HW: 480 031 307 20
Component: SideSensor_Dr 002 0149
Serial number: 351002C0855645B10D83
Subsystem 7 - Part No SW: ----------- HW: 480 031 307 20
Component: SideSensor_Pr 002 0149
Serial number: 352002C08A0865A05FDI
Subsystem 8 - Part No SW: ----------- HW: 480 031 307 20
Component: FrontSensor_D 002 0149
Serial number: 355002C08321AA613EED
Subsystem 9 - Part No SW: ----------- HW: 480 031 307 20
Component: FrontSensor_P 002 0149
Serial number: 356002C0832A2580385$
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 021 807 20
Component: CentrSensorXY 005 0148
Serial number: I0O0001A2F4ABB90A534
Part No SW: 4N0 907 129 KD HW: 4N0 907 129 KD
Component: Lenks.Modul H03 0009
ROD: EV_SMLSKLOAU736_AU58.rod
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4N0 920 890 E HW: 4N0 920 890 E
Component: FBenUSA------ H24 0022
Coding: 0BEF5DEB7EA8CF050290E3609800430008000000
ASAM Dataset: EV_DashBoardAU65X 002024
ROD: EV_DashBoardAU65X_002_AU58.rod
VCID: 3338742E9BCBE973AA9-8066
Part No SW: 4K1 907 468 M HW: 4K1 907 468 C
Component: Gateway H06 0506
Serial number: F0454940468311
Coding: 02010005000406405496000000590132FC980048D80000000900008E00000000
ASAM Dataset: EV_Gatew31xAU65x 003210
ROD: EV_Gatew31xAU65x_AU58.rod
Subsystem 1 - Part No SW: 4N0 951 523 K HW: 4N0 951 523 K
Component: E221__MFL H06 0010
Subsystem 2 - Part No SW: 4N0 915 181 A HW: 4N0 915 181 A
Serial number: 758854030020070200FA
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 D HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0803
Serial number: 30303030303030
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2F30785E77E3CD93CE1-807A
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 BD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0031
ASAM Dataset: EV_LCMLeftHELLAAU736 001013
ROD: EV_LCMLeftHELLAAU736_AU65.rod
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605028200201207
Coding: 0100
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79A48606F927D323205-802C
Component: MEM-FS 009 0064
Serial number: 00000414298676
Coding: 011C9A400005BEA1480301012101210081A100070700878700000000004000
ROD: EV_SCMDriveSideCONTIAU736_AU38.rod
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H04 0011
Serial number: SJ8001080720402588ED
Coding: BF2F00
Valve block 2 in front seat driver side:
Component: N476 VB2 FSv H04 0010
Serial number: SJ800111072011470205
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001013
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 K HW: 4N0 907 566 A
Component: MRR_HR H14 0486
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001022
ROD: EV_RearRadarS1DelphAU651.rod
VCID: 3E2E551AA089341B557-806A
Part No SW: 4M1 959 953 J HW: 4M1 959 953 C
Component: TSG FS005 0430
Serial number: YE007TFO21152
Coding: 001DCB00520014C2B009A036
VCID: 44DA27F2CE655ECB033-8010
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Coding: E1000101010000
ROD: EV_EPSVWBSAU426_010.rod
VCID: 3236712A64D1E07BA1F-8066
Part No SW: 4N0 907 064 EG HW: 4N0 907 064 G
Component: BCM2 MLBevo H16 0224
Coding: 013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0681010F15
ASAM Dataset: EV_BCM2CONTIAU651 011009
ROD: EV_BCM2CONTIAU651_011.rod
VCID: 78A28302C22DCA2B5FB-802C
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY201502945
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000048483246
left tail lamp 1:
Subsystem 4 - Part No SW: 4N0 945 423 G HW: 4N0 945 423 G
Component: SHL_li1 H02 0110
Serial number: 0130973700000549
Subsystem 5 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14655969
Rear spoiler control module:
left tail lamp 2:
Subsystem 7 - Part No SW: 4N0 945 429 G HW: 4N0 945 429 G
Component: SHL_li2 H02 0110
Serial number: 0131003200000572
Right rear tail lamp 1:
Subsystem 8 - Part No SW: 4N0 945 424 G HW: 4N0 945 424 G
Component: SHL_re1 H02 0110
Serial number: 0130973800000549
Right rear tail lamp 2:
Subsystem 9 - Part No SW: 4N0 945 430 G HW: 4N0 945 430 G
Component: SHL_re2 H02 0110
65605 - Databus
[Brake control module: ESP_21: no signal/communication]
Reset counter: 41
Mileage: 55 km
Date: 2020.10.06
Time: 08:02:26
Supply voltages-Terminal 30 power supply: 12.283 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.297 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.249 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 02 00
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Part No SW: 4M1 959 952 J HW: 4M1 959 952 C
Component: TSG BFS005 0430
Serial number: YE007TEU11562
Coding: 001DCB005E0014C2B009A034
VCID: 43D824EECB6B59F33A9-8016
Part No SW: 4M2 035 092 A HW: 4M2 035 092
Component: MU-TP-NS-US 042 3385
Serial number: GRO-63326.06.20
Coding: 16510010802200000000000000000000000000000000000000
VCID: 2700907E5F1395D3061-8072
No ASAM data for: "Unknown" (AU65)
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4N0 915 105 D HW: 4N0 915 105 D
Component: BMS_48V_LiIon H09 0206
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 2B086C4E43FBB1B3E29-807E
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 8W5 959 107 D HW: 8W5 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C744-8791-2
Coding: 1430
VCID: 47C030FEFF5375D3E61-8012
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4N0 907 777 AQ HW: 4N0 907 777 C
Component: Fahrwerk-SG H52 2135
Serial number: 1407201142
Coding: 756C6853FA52
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002.rod
VCID: 0944F6C6A9C7C3A3305-805C
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130992083
Coding: 303030
Part No SW: 4KE 035 283 A HW: 4KE 035 283 B
Component: CB_H_NAR 039 0236
Serial number: A971G0LS023067
Coding: 01E0E0F9C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4N1 713 041 D HW: 4N1 713 041 C
Component: GSM-LL H10 0081
Revision: 0L0D5012 Serial number: 20063060573368
ASAM Dataset: EV_GSMWaehlZFAU736 001018
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4N1 919 617 C HW: 4N1 919 617 C
Component: HeadupDisplay H15 5951
Coding: 5700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 3720403E8FB30553961-8062
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4N0 907 547 C HW: 4M0 907 547
Component: NV-ECU-Gen3 H13 0107
Serial number: 645975200202028
Coding: 110112
ASAM Dataset: EV_NightVisioG3AUTOLAU651 001008
ROD: EV_NightVisioG3AUTOLAU651.rod
VCID: 353C4A3695BFF74384D-8060
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H07 0007
Serial number: 639589400B2007700729
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4K4 907 117 D HW: 4K4 907 117
Component: zFAS Var C H09 0364
Coding: 02018A000000000000FFD60000F4D50C531F7600000000D8000000000096D401019BA8000000000000000080000000000000000000000000F98040000000000000009CD00080009000800080000000800080400000E0
ASAM Dataset: EV_ZFASAU516 003008
ROD: EV_ZFASAU516_003.rod
VCID: 30327B226ADDD26BD7B-8064
233523 - Parking Sensor(s); Front
B10FC F0 [008] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
Reset counter: 41
Mileage: 53 km
Date: 2020.10.03
Time: 12:33:00
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 4N0 907 159 A HW: 81A 907 159 A
Component: SAS-GEN 2.5 H08 0002
Serial number: 200314202388
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 E HW: 4M0 907 145 B
Component: AEMevo H10 0132
ASAM Dataset: EV_AEMZFAU736 006014
ROD: EV_AEMZFAU736_006.rod
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS004 0430
Serial number: YE007TFJ06426
Coding: 000DCB00000014C2E008A024
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
VCID: 48C233C2F24D7AABEFB-801C
Component: TSG HBFS004 0430
Serial number: YE007TFI23193
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 663 HW: 4K0 959 663
Component: DCDC_GEN_2 H20 0307
Serial number: DC20294000239
ASAM Dataset: EV_DCDC48VFLEXAU581 004001
ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
VCID: 75BC8A36D53FB74344D-8020
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 279050065113
ROD: EV_SunRoofCONTIAU736_009_AU58.rod
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4N0 909 145 K HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0398
Revision: -------- Serial number: CCC_098_B_9056_
Coding: 42244200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
Address CD: Laser Scanner (J1122) Labels: 4N0-907-660.clb
Part No SW: 4N0 907 660 D HW: 4N0 907 660
Component: LASER_SCANNER H36 0304
ASAM Dataset: EV_LaserScannAU651 015020
ROD: EV_LaserScannAU651_015_AU65.rod
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H14 0486
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001022
ROD: EV_RearRadarS2DelphAU651.rod
Address D4: Roll Control 1 (J1152) Labels: None
Part No SW: 4N0 907 483 C HW: 4N0 907 483 C
Component: eABC_Gen1 H14 0021
ASAM Dataset: EV_EABCFrontAU651 003016
ROD: EV_EABCFrontAU651.rod
VCID: 343A77329EC5EE4BB33-8060
8388618 - Databus
[Timeout_Error_Klemmenstatus_01]
Fault Frequency: 12
Reset counter: 41
Mileage: 53 km
Date: 2020.10.03
Time: 11:31:54
Internal DTC: 24
Voltage terminal 30: 11.90 V
Address D5: Roll Control 2 (J1153) Labels: None
Part No SW: 4N0 907 484 C HW: 4N0 907 484 C
ASAM Dataset: EV_EABCRearAU651 003016
8388618 - Databus
Fault Frequency: 12
Reset counter: 41
Mileage: 53 km
Date: 2020.10.03
Time: 11:31:54
Internal DTC: 24
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 AC HW: 7PP 941 592 A
Component: LED1L H09 4004
ROD: EV_LEDModLeftMELCOAU736_VW51.rod
VCID: 1964A68619673323805-804C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H09 4004
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 K HW: 4N0 907 669 A
Component: MRR_VR H14 0485
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
ROD: EV_FrontCorneRadarS1AU651.rod
VCID: 42D621EAD47150FB31F-8016
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H14 0485
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
ROD: EV_FrontCorneRadarS2AU651.rod
Address DD: Sunroof 2 (J392) Labels:* None
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_2 006 0002
Coding: 23B030065114
ASAM Dataset: EV_SunRoof2CONTIPO623 009011
ROD: EV_SunRoof2CONTIPO623_009_AU58.rod
VCID: 76BE8D3AC839BC5B4D7-8022
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 2318846E2B2B79F35A9-8076
Address E0: Auxiliary Display 1 (E857) Labels: None
Part No SW: 4N0 035 705 A HW: 4N0 035 705
Component: E859 H42 0019
Serial number: KE0 MK90044352C
ASAM Dataset: EV_SCC1AU651 001004
ROD: EV_SCC1AU651.rod
1548 - Wireless Control Head
U1364 00 [008] - No Communication
[SCON_no_signal_no_communication]
Reset counter: 41
Mileage: 50 km
Date: 2020.09.29
Time: 00:12:53
Wireless control head: system condition-Terminal 30 power supply: 12.90 V
Wireless control head: system condition-Charging status: not active
Wireless control head: system condition-Auxiliary display/control head: system status: switched on
End----------(Elapsed Time: 02:54, VBatt start/end: 12.3V/12.6V)-----------
01-Engine
;SW:4N0-907-557-G HW:0P2-907-309-A --- Engine
;Component:V8 4.0l TFSI H31 0002, Coding:0A2A0012256E010E34286000000400000000000000000000
;EV_ECM40TFS0114N0907557G,001002,EV_ECM40TFS0114N0907557G.rod
;Thursday,15,October,2020,12:22:26:59422
;VCDS Version: Beta 20.9.1 (x64) Data version: 20200919 DS322.0
;VCID: 3A26590ABCA1183B69F-806E
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WAU8SAF8XMN002330,
IDE00019,Voltage terminal 30,12.480, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,745, /min
IDE00025,Coolant temperature,78, °C
IDE00078,Time since engine start,251, s
IDE00083,Throttle valve position (absolute),12.9, %
IDE00084,Absolute load value,20, %
IDE00085,Normed load value,7.8, %
IDE00086,Accelerator pedal position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,64.4, Nm
IDE00102,Control Module temperature,35.2, °C
IDE00148,Mean injection time,0.6256, ms
IDE00150,Pressure in brake servo unit,42.97, hPa
IDE00151,Oil fill level,76.884, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00159,Ignition timing angle retard cylinder 5,0.0, °
IDE00160,Ignition timing angle retard cylinder 6,0.0, °
IDE00161,Ignition timing angle retard cylinder 7,0.0, °
IDE00162,Ignition timing angle retard cylinder 8,0.0, °
IDE00167,Exhaust temperature 1 bank 1,442.2, °C
IDE00168,Exhaust temperature 1 bank 2,442.2, °C
IDE00172,A/C compressor torque,25.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-22.00, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-21.94, °
IDE00176,Camshaft adjustment: exhaust: bank 2: specified value,-22.00, °
IDE00177,Camshaft adjustment: exhaust: bank 2: actual value,-22.11, °
IDE00178,Camshaft adjustment intake bank 1: specified value,28.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,27.89, °
IDE00180,Camshaft adjustment intake bank 2: specified value,28.00, °
IDE00181,Camshaft adjustment intake bank 2: actual value,27.83, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00183,Camshaft adaptation intake bank 2: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00185,Camshaft adaptation exhaust bank 2: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,399.9, kPa
IDE00187,Coolant temperature at engine start,24.2, °C
IDE00188,Fuel high-pressure: actual value,6.0580, MPa
IDE00190,Charge air pressure: specified value,320.78, hPa
IDE00191,Charge air pressure: actual value,979.69, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,21.0, °C
IDE00194,Coolant temperature at radiator output: specified value,105.0, °C
IDE00196,Engine oil temperature,52.0, °C
IDE00201,High fuel pressure: specified value,5.9440, MPa
IDE00202,Low fuel pressure: specified value,400.0, kPa
IDE00304,Fuel level,36.00, l
IDE00350,Air mass: specified value,19.8, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00356-ENG57549,Cruise Control System (CCS): switch position-Bits 0-7,0,
IDE00357,Fuel temperature,54.8, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,983.48, hPa
IDE00371,Fuel consumption,1.47, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,35.93, %
IDE00381,Coolant fan 2: activation,44.13, %
IDE00392,Accelerator pedal: sensor voltage 1,749.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,374.0, mV
IDE00394,Camshaft position: start of phase window,120.81, °
IDE00395,Camshaft position: end of phase window,152.97, °
IDE00405,Crankshaft speed (RPM),753.5, /min
IDE00406,Camshaft RPM,376.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00408-ENG57549,Engine mount 1-Bits 0-7,1,
IDE00409-ENG57549,Engine mount 2-Bits 0-7,1,
IDE00410-ENG57549,Transmission mount 1-Bits 0-7,1,
IDE00411-ENG57549,Transmission mount 2-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00419,Exhaust gas temperature before particle filter,-0.0, °C
IDE00427,Particle filter: difference pressure,0.00, hPa
IDE00432,Particle filter: time since last regeneration,3.742, H
IDE00434,Particle filter: soot mass calculated,6, mg
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,8.8, Nm
IDE00496-ENG57549,Oil pressure switch valve activation-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,21, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.992 Lambda / -0.031 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.765, V
IDE00565,Current of oxygen sensor bank 2 sensor 1 (broadband sensor),1.005 Lambda / -0.012 mA,
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.775, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00584,Distance driven since erasing DTC memory,23, km
IDE00588,Fuel tank fill level,42.7, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,0.5, Degrees
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 / B2S1 B2S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-10.2, %
IDE00598,Long-term adaptation of mixture formation: B2,-2.3, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,3.9, %
IDE00605,Short term adaptation of mixture formation bank 2,3.1, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,27.5, %
IDE00643,Minimum torque of electric machine,-165.1, Nm
IDE00644,Maximum torque of electric machine,125.8, Nm
IDE00657,Hybrid battery voltage,1023.97, V
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00739,Oxygen sensor test: bank 2: delta lambda,0.00000,
IDE00752,Oxygen sensor control test,Test off,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00950-ENG57549,A/C compressor status-Bits 0-7,1,
IDE00973,Outside temperature,21.0, °C
IDE01028,Air temperature of H-V / hybrid battery,3003.6, °C
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator performance,0, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,3,
IDE01267,Height correction,0.97083,
IDE01378,Fuel high pressure: control deviation,0.0060, MPa
IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Starter activation: status-Bits 0-7,2,
IDE01407,Particle filter: fuel consumption since last regeneration,22.621, l
IDE01590,brake status,Not operated,
IDE01590-ENG127367,brake status-Test_Program_Channel 600,167,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.779, V
IDE01645,O2 sensor B2 voltage behind CAT,0.778, V
IDE01647,Result: O2 Sensor Aging Test B2 Downstream CAT,Test off,
IDE01647-ENG129417,Result: O2 Sensor Aging Test B2 Downstream CAT-Test_Program_Channel 379,235,
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test on,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,234,
IDE01666,Result of test of camshaft adjustment intake bank 2,Test on,
IDE01666-ENG129412,Result of test of camshaft adjustment intake bank 2-Test_Program_Channel 105,234,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test on,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,234,
IDE01668,Result of test of camshaft adjustment outlet bank 2,Test on,
IDE01668-ENG129419,Result of test of camshaft adjustment outlet bank 2-Test_Program_Channel 620,234,
IDE01678,O2 sensor test readiness downstream CAT: B2: result,B2-S2 OK,
IDE01678-ENG129413,O2 sensor test readiness downstream CAT: B2: result-Test_Program_Channel 114,213,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01834,Battery voltage,12440, mV
IDE01869,Long-term fuel trim bank 1 at idle,-1.22, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,4.4714,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,17.3, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,1,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4170.0, mV
IDE01884,Camshaft adjustment intake bank 1: activation,41.504, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Fuel pump adaptation,98.2, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,23.605, %
IDE01899,Load value: corrected specified value,199.41, %
IDE01900,Charge press. ctrl.: spec. value,0.4, %
IDE01901,Lost torque adaptation: idle,0.0, Nm
IDE01902,Lost torque adaptation A/C compressor,17.3, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,20.7, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.95142,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.94849,
IDE01911,Leakage air,6.7, kg/h
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,74, km
IDE01923,Control module distance driven,73630, m
IDE01928,Close cam shaft angle at quantity control valve,24.7, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,0.000, MPa
IDE01932,High pressure pump injection volume,0.20, mm³
IDE01975,Numb.of misfir.: cylinder 1,39,
IDE01976,Numb.of misfir.: cylinder 2,55,
IDE01977,Numb.of misfir.: cylinder 3,105,
IDE01978,Numb.of misfir.: cylinder 4,46,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,222,
IDE02117,Relative load value,19.13, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,279.0, kPa
IDE02756,Number of manual engine starts,58,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,11.24, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,11,
IDE03010-MAS01627,Number of prevented stop processes-Steering,30,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,2,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,62,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,36,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,15,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,2,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,3,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,6,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,32770, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.518, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.482, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.928, V
IDE03279,Charge air pressure 2: actual value,980.47, hPa
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,42,
IDE03364,Numb.of misfir.: cylinder 6,37,
IDE03365,Numb.of misfir.: cylinder 7,63,
IDE03366,Numb.of misfir.: cylinder 8,12,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3534.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.283, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,255,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,225,
IDE03700,Status adaptation dew point end,ADP is OK,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03709,Angle difference actual-specified camshaft adjuster,0.06, °
IDE03711,Mass flow through throttle valve,18.8, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03771,Turbocharger speed sensor 2,0, /min
IDE03794,Long-term fuel trim bank 2 at idle,0.09, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,42.520, %
IDE03796,Camshaft adjustment: exhaust: bank 2: activation,41.281, %
IDE03797,Camshaft adjustment intake bank 2: activation,42.303, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,O2 Sensor B1-S2: Status-Bits 0-7,10,
IDE03808-ENG57549,Oxygen sensor bank 2 sensor 1: status-Bits 0-7,7,
IDE03809-ENG57549,Oxygen sensor bank 2 sensor 2: status-Bits 0-7,10,
IDE03810,Oxygen sensor B2: sensor 2: specified value,1.0000,
IDE03811,Test of oxygen sensors bank 2: Delta-Lambda: result,Test off,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
IDE03816,Exhaust flap bank 1,OFF,
IDE03816-ENG129421,Exhaust flap bank 1-Test_Program_Channel 825,136,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,184.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.1, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,36.960, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,182.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03823,O2 sensor heater B2-S2: activation,Htg.aC.ON,
IDE03823-ENG127297,O2 sensor heater B2-S2: activation-Test_Program_Channel 123,216,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,146.9, Ohm
IDE03825,O2 sensor heater B2-S1: activation,38.046, %
IDE03826,Conversion test B2: measured value,3.9641,
IDE03827,Conversion test Bank 2: result,Test off,
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,235,
IDE03830,Status of adaptation of on-demand fuel pump,ADP is OK,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,2,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03878,Misfires per 1000 revolutions of cylinder 7,0,
IDE03879,Misfires per 1000 revolutions of cylinder 8,0,
IDE03933,Charge pressure actuator: specified value,20.235, %
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.96451,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,1,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04000,Intake air temperature sensor,IAT 11/21:27/30, °C
IDE04002,Charge air pressure control,BP_A act:98 kPa / BP_B act:98 kPa,
IDE04003,Charge air temperature sensor,B1S1:23 °C / B2S1:24 °C,
IDE04010,Engine torque: normalized,8, %
IDE04011,Nominal torque,800, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:6150/6150 kPa,
IDE04085,Throttle valve,THR A cmd/rel:4/3 % / THR B cmd/rel:4/3 %,
IDE04101,Intake pressure,MAP_A:31.75 kPa abs / MAP_B:31.53 kPa abs,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,0.0, mV
IDE04320,Throttle valve position 3,13, %
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04398,Particle filter bank 2: diff pressure,0.00, hPa
IDE04409,Intake manifold pressure: corrected,313.13, hPa
IDE04410,Intake manifold pressure: specified value,320.63, hPa
IDE04414,Cat conv temp: modeled,405, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,0,
IDE04629,AVS operating condition,1,
IDE04637,Engine temperature control actuator,0.00, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,8.9, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,63.7, Nm
IDE04693,Increasing desired torque intervention of ESP,-49414.1, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,940.47, hPa
IDE04872,Brake pedal value sensor: relative value filtered,399.99, %
IDE04873,Braking torque requested by driver,0.0, Nm
IDE04876-ENG57549,Charge map from e-machine/motor torque distribution-Bits 0-7,0,
IDE04882,Operating mode control expanded electrical driving,False result,
IDE04882-ENG127289,Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE,0,
IDE04885,Hybrid batt charge cond act val standardized,45.82, %
IDE04887,Powertrain target torque,32.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,11.0, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04913,Current speed of electric motor,718.0, /min
IDE04933,Number of fill level decreases,10,
IDE04934,Last odometer reading since fill level decrease,48, km
IDE04935,Next to last odometer reading since fill level decrease,18, km
IDE04936,3rd last mileage reading since fill level decrease,12, km
IDE04956,Injection volume of high pressure pump 2,-1.47, mm³
IDE05127,Intake manifold pressure bank 2: corrected,312.81, hPa
IDE05128,Intake air temperature in intake manifold bank 1,23.3, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,316.17, hPa
IDE05141,Intake manifold pressure bank 2 raw value,315.39, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05215,EVAP valve diagnosis result correlation factor,0.00,
IDE05217,Hybrid battery charge current actual value,1023.97, A
IDE05219,Electric drive torque: actual value,0.00, A
IDE05220,Electric drive voltage: actual value,47.00, V
IDE05221,Electric drive torque: actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05242,Phase angle adaptation request,0,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05327,Activation for electrical auxiliary coolant pump in HT circuit,0.00, %
IDE05330,Pulse-controlled inverter temperature: actual value,3003.6, °C
IDE05331,DC/DC converter temperature: actual value,-273.1, °C
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05334,Reset tire pressure monitoring display warnings,2.0, Nm
IDE05335,Electro-mechanical parking brake function test,0.0, Nm
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,2.3, °C
IDE05438,Rear cat conv temp main cat conv model value,406.7, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,407.3, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.0000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.0000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0264, rad
IDE05444,Air filling: specified value,19.27, %
IDE05445,Pressure before throttle valve of pressure sensor,982.50, hPa
IDE05448,Long-term adaptat. of mixture form. bank 2 at partial load,0.97488,
IDE05449,O2 sensor 2: B1: internal resistance limit,2000, Ohm
IDE05450,O2 Sensor 2: B2: Internal Resistance Limit,2000, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00034,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00058,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.30, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,719.80, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05471,Cat converter oxygen storage capacity bank 2,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.05469,
IDE05475,Main cat converter OSC age correction factor bank 2,0.72656,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05477,Cat converter oxygen storage capacity bank 2 measured,0.0, mg
IDE05479,Misfire recognition reference moment,6.987, %
IDE05482,Tank venting adaptation factor,1.559,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,43.2, °C
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05761-ENG121419,Nominal operating condition: partial engine operation-Bhmbs,0,
IDE05762-ENG121418,Engine operating status partial engine operation-Bhmb,0,
IDE05765,Portion of partial engine operation of total operating time,3.906, %
IDE05766,Time in partial engine operation,0.00, s
IDE05767,Number of switch-overs during partial engine operation,55,
IDE05797,Throttle valve adapter: specified value,3.586, %
IDE05928,Fuel consumption since DTC memory last erased,26.773, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,-0.1770401, hPa
IDE05951,Charge pressure control adaptation value 2,0.0186670, hPa
IDE05952,Charge pressure control adaptation value 3,-0.7528698, hPa
IDE05953,Charge pressure control adaptation value 4,0.7112634, hPa
IDE05954,Charge pressure control adaptation value 5,4.0142393, hPa
IDE05955,Charge pressure control adaptation value 6,2.7216238, hPa
IDE05956,Charge pressure control adaptation value 7,-1.5010864, hPa
IDE05957,Charge pressure control adaptation value 8,0.0000000, hPa
IDE06014,Charge pressure control adaptation value 0,-0.0459629, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,27.2, °C
IDE06021,Intake air temperature before throttle valve: raw value,23.5, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,0.0060, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,78.6, °C
IDE06045-ENG57549,Output diagnostic test status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,43, hPa
IDE06056,Electric driving button status,0,
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06062,Throttle valve position 4,13.3, %
IDE06098,Sensor control factor: output value,1.03165,
IDE06112-ENG57549,Test of cylinder deactivation-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0157410, V*ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0182724, V*ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0192093, V*ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0163803, V*ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,160,
IDE06212,Fuel pressure rail 2,6.2780, MPa
IDE06213,Fuel pressure: target value: rail 2,6.2940, MPa
IDE06214,Throttle valve adapter bank 2: target value,4.234, %
IDE06255,Vehicle lateral acceleration,0.04, g
IDE06256,Vehicle lateral acceleration: raw value,0.04, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,14,
IDE06307-MAS00109,Stop prevention history data-Hours,18,
IDE06307-MAS00110,Stop prevention history data-Minutes,28,
IDE06307-MAS00111,Stop prevention history data-Seconds,8,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,CAT heating,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Auxiliary equipment power consumption too high,
IDE06308,Start request history data,Hybrid battery performance too low,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Fuel gelling protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,hood open,
IDE06308,Start request history data,Sporadic function prevention,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Restriction in start system,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Engine protection active,
IDE06391,Oil temperature sensor 2,54.7, °C
IDE06392,Oil temperature sensor 2: raw value,2095.0, mV
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06552,Time since terminal 15 ON,299180, ms
IDE06567,Frequency counter deactivate start/stop function,7,
IDE06568,Stop prevention by driver frequency counter,29,
IDE06569,Frequency counter vehicle standstill,101,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,35.5, °C
IDE06610,Frequency counter vehicle standstill with stop,6,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,49,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06727,Timing deviation after chain replacement: intake bank 2,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.00, °
IDE06729,Timing deviation after chain replacement: exhaust bank 2,0.00, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06731,Timing deviation after other repairs: intake bank 2,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06733,Timing deviation after other repairs: exhaust bank 2,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06735,Timing deviation: current value intake bank 2,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06737,Timing deviation: current value exhaust bank 2,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,0,
IDE06739-ENG57549,Chain elongation: no. of valid initial values: intake bank 2-Bits 0-7,0,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,0,
IDE06741-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 2-Bits 0-7,0,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06743,Chain elongation: initial values valid: intake bank 2,not active,
IDE06743-ENG36870,Chain elongation: initial values valid: intake bank 2-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06745,Chain elongation: initial values valid: exhaust bank 2,not active,
IDE06745-ENG36870,Chain elongation: initial values valid: exhaust bank 2-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,3.6060, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,11.24, %
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,738.0, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06972,High-volt. battery: charge state: abs. value,327.67, %
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE06986,H-V battery charge current: maximum value,1023.97, A
IDE07001,Piston-cooling jets: activation,0,
IDE07002,Exhaust flap: activation,94.99, %
IDE07003,Exhaust flap bank 2: activation,94.99, %
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,124,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,133,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07068,Temperature sensor 2 for charge air cooler,30.6, °C
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07078,AVS result of last switch-over: intake,168,
IDE07079,AVS result of last switch-over: exhaust,168,
IDE07164,Number injections,17286,
IDE07165-ENG57549,Transmission Hybrid control: actual state-Bits 0-7,0,
IDE07170,Clutch K0: torque,3276.7, Nm
IDE07173-ENG57549,Electric drive motor: mode of operation-Bits 0-7,15,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07226-ENG57549,Operational state of the hybrid battery-Bits 0-7,7,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07241-ENG57549,Status transition of transmission control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,11.24, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07286,Electrically driven compressor: current,0, A
IDE07420-ENG57549,Partial engine operation prerequisites-Bits 0-7,15,
IDE07421-ENG57549,Partial engine operation prerequisites 2-Bits 0-7,7,
IDE07422-ENG57549,Partial engine operation prerequisites 3-Bits 0-7,4,
IDE07423-ENG57549,Partial engine operation prerequisites 4-Bits 0-7,15,
IDE07467,High pressure regulation rail 2: adaptation value,0.000, MPa
IDE07468,Fuel high pressure rail 2: regulator output value,-0.0320, MPa
IDE07469,Fuel high pressure rail 2: control deviation,-0.0680, MPa
IDE07571,Engine torque,38.1, Nm
IDE07573,Throttle valve adapter: actual value,5.063, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07660,Minimum permissible torque of e-machine,0.0, Nm
IDE07662,Minimum current permissible torque of e-machine,-165.1, Nm
IDE07663,Maximum current permissible torque of e-machine,131.4, Nm
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4170.0, mV
IDE07666,Spec. torque for electric drive: coordinated output signal,-25.5, Nm
IDE07667,Desired torque of regeneration,-63.1, Nm
IDE07716,Particulate filter input: temp. sensor 1: bank 1: raw value,-0.0, °C
IDE07718,Particulate filter output: temp. sensor 1: bank 1: raw value,-0.0, °C
IDE07724,Coolant temperature at engine outlet: calculated,68.1, °C
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,100.00, %
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,40.41, %
IDE07955,Throttle valve adapter bank 2: actual value,5.805, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08491,Intake air temperature 2 before throttle valve: raw value,24.5, °C
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09311-ENG57549,Pre-ignition counter cylinder 5-Bits 0-7,0,
IDE09312-ENG57549,Pre-ignition counter cylinder 6-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09317-ENG57549,Pre-ignition counter over serv.life cylinder 5-Bits 0-7,0,
IDE09318-ENG57549,Pre-ignition counter over serv.life cylinder 6-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,0,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,2,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,0,
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,0.9895,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09977,Control module temp.: max. value,72.7, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,1,
IDE10041,Intake camshaft B1 active operating state,1,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.0, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10063-ENG06679,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10064-ENG06679,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10065-ENG06679,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10066-ENG06679,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.0, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10067-ENG06679,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.0, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10068-ENG06679,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.0, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10069-ENG06679,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.0, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10070-ENG06679,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.0, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10071-ENG06679,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.0, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10072-ENG06679,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,0, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10122,Chain elongation outlet bank 2: mileage of the last adaptation,0, km
IDE10123,Chain elongation inlet bank 2: mileage of the last adaptation,0, km
IDE10302,Time since engine start,313.5, s
IDE10303,Integrated air masse at first engine start,3.7092, kg
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10580,Engine oil level: test method 1,93.4, %
IDE10581,Engine oil level: test method 2,108.1, %
IDE10582,Engine oil level: test method 3,106.0, %
IDE10630,O2 sensor befor CAT: delay time changeover rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE10671,Oxygen sensor before catalytic converter B. 2: filter const. transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,92, ml/mm
IDE10855-ENG57549,Pre-ignition counter over serv.life cylinder 8-Bits 0-7,0,
IDE10856-ENG57549,Pre-ignition counter over serv.life cylinder 7-Bits 0-7,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,1,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2020,
IDE10989-MAS00107,Immobilizer: historic data-Month,7,
IDE10989-MAS00108,Immobilizer: historic data-Day,28,
IDE10989-MAS00109,Immobilizer: historic data-Hours,15,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,29,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,39,
IDE10989,Immobilizer: historic data,not active,
IDE10989,Immobilizer: historic data,hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11065-ENG57549,Accel. pedal pos. sensor 1-Bits 0-7,102,
IDE11065-ENG57549,Accel. pedal pos. sensor 1-Bits 0-7,2,
IDE11066-ENG57549,Accel. pedal pos. sensor 2-Bits 0-7,51,
IDE11066-ENG57549,Accel. pedal pos. sensor 2-Bits 0-7,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,1,
IDE11203,Oil pressure setpoint,276.0, kPa
IDE11267,Oil level: max. value: relative,-3276.8, %
IDE11268,Oil level: min. value: relative,3276.7, %
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,6.320, l
IDE11302-ENG57549,Engine oil level: test method 1 qualification-Bits 0-7,7,
IDE11303-ENG57549,Engine oil level: test method 3 qualification-Bits 0-7,7,
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,3,
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,86,
IDE11330,Oil press. control valve: activation pulse duty factor,68.11, %
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11492,Disengaging clutch actuator: spec. position,0.00000, mm
IDE11493,Disengaging clutch actuator: act. position,60.29220, mm
IDE11494-MAS03359,Disengaging clutch actuator: status-Text,Initialization,
IDE11495,Disengaging clutch actuator: current,-50.0, A
IDE11496,Disengaging clutch actuator: voltage,0.0, V
IDE11498,Decoupler actuator,-56.00, °C
IDE11499,Camshaft angle adaptation: inlet deviation: bank 2,0.000, °
IDE11531,Starter generator: number of restarts,0,
IDE11533,Starter generator: number of first starts,10,
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11568,Starter generator: status,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11929,I share of PID control of fully variable oil pump,9.41, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00146,
IDE12099-MAS10949,Decoupler actuator: manufacturers code: block A-Manufacturer code 1,0,
IDE12099-MAS10950,Decoupler actuator: manufacturers code: block A-Manufacturer code 2,0,
IDE12100-MAS10951,Decoupler actuator: manufacturers code: block B-Manufacturer code 3,0,
IDE12100-MAS10952,Decoupler actuator: manufacturers code: block B-Manufacturer code 4,0,
IDE12101-MAS10499,Decoupler actuator: actual torque-Torque,3276.7, Nm
IDE12104,Cylinder block coolant valve: pulse duty factor,0.00, %
IDE12106,Temperature sensor for cylinder block,-273.1, °C
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.000,
IDE12356-ENG57549,Pre-ignition counter cylinder 7-Bits 0-7,0,
IDE12357-ENG57549,Pre-ignition counter cylinder 8-Bits 0-7,0,
IDE12551,Camshaft adjustment intake bank 1: adaptation value,-1.82, °
IDE12663,Camshaft adjustment intake bank 2: adaptation value,-1.21, °
IDE12664,Camshaft adjustment outlet bank 1: adaptation value,0.29, °
IDE12665,Camshaft adjustment outlet bank 2: adaptation value,-1.19, °
IDE12688,Catalytic converter temperature bank 2: modeled,405, °C
IDE12748,Oil level: amount added MIN to MAX,2000, ml
IDE12765,Pressure: tank ventilation leads: bank 2,-550.08, hPa
IDE12766,Pressure: tank ventilation leads: bank 1,-571.80, hPa
IDE13010,Bank 1 tank breather system: adaptation factor,1.279,
IDE13011,Bank 2 tank breather system: adaptation factor,1.301,
IDE13012,Tank breather valve: activation duty factor,37.628, %
IDE13013,Bank 2 tank breather valve: activation duty factor,37.628, %
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,2500, mg
IDE13086,Particle filter: maximum soot build-up reached,3500, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.0000,
IDE13089,Particle filter: high soot accumulation ratio,3.0000,
IDE13090,Particle filter: maximum soot loading ratio reached,4.0000,
IDE13091,Particle filter: ash loading ratio,1.0000,
IDE13092,Particle filter: soot accumulation ratio,0.0000,
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,32,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13692,Starter generator: number of positioning operations,0,
IDE13693,Starter generator: engine control module condition state machine,Gen,
IDE13693-ENG39548,Starter generator: engine control module condition state machine-Test_Program_X Ex Chpd eiu Fhob Bys Cica nfrr6 sp UBYTE,4,
IDE13695,Starter generator: thermal load,28, %
IDE13696,Starter generator: actual mode 48V,1,
IDE13697,Starter generator: number of comfort stops,50,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13747,Tank venting system diagnosis: bench 2 results correlation factor,0.00,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14152,Oil level: maximum value: compensated,20.072, mm
IDE14153,Oil level: minimum value: compensated,57.068, mm
IDE14241,Exhaust flap bank 2: position feedback actual value,95.00, %
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14247,Exhaust flap: position feedback actual value,95.00, %
IDE14534,Knock control: error status,2147483648,
IDE14790,Exhaust gas temperature in particulate filter: calculated,-0.0, °C
IDE14818,Reduce ignition advance with global knock control adaptation,0.0, °
IDE15115,Particulate filter input: temp. sensor 1: bank 2: raw value,-0.0, °C
IDE15185,Particulate filter output: temp. sensor 1: bank 2: raw value,-0.0, °C
IDE15249,Valve lift actuator: intake bank 2: target position,False result,
IDE15249-ENG127289,Valve lift actuator: intake bank 2: target position-Test_Program_B TRUE UBYTE,0,
IDE15614,Time since first start of combustion engine,324970, ms
IDE16424-ENG57549,Operating concept for speed control system-Bits 0-7,255,
IDE16425-ENG57549,Drivetrain coordinator: transmission status-Bits 0-7,255,
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 FA 02 50 00 00 14 F2 00 00 02 2A 00 21 00 00 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,36.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,384.7, °C
MAS16067,Exhaust gas temperature at the probe before PreCat bank 2: model value,383.4, °C
MAS16074,Temperature in pre-cat bank 1: model value,433.9, °C
MAS16075,Temperature in pre-cat bank 2: model value,434.1, °C
MAS16088,Lambda driver request: specified value,15.9998,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.117,
MAS16098,Tank ventilation relative mixture proportion: actual value,2.95, %
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,Correct result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,Correct result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16537,Bank 2 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,407.24, °C
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,407.43, °C
MAS16713,Exh mss flw bef main cat conv bank 2 filtered,15.3, kg/h
MAS16836,Particle filter: pressure ration to new filter,0.2000,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17033,Radiator shutter 3: actual position,399.99, %
MAS17034,Radiator shutter 4: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.49,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,7.630, V
MAS17042,Heated oxygen sensor 2 bank 2: heat output normalized,0.43,
MAS17044,Heated oxygen sensor 2 bank 2: internal resistance,172, Ohm
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,172, Ohm
MAS17046,Heated oxygen sensor 2 Bank 2: target voltage adequate for rich conditions,0.000, V
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17048,Heated oxygen sensor 2 Bank 2: target voltage adequate for lean conditions,1.000, V
MAS17050,Heated oxygen sensor 1 bank 2: effective heater voltage,7.690, V
MAS17051,Heated oxygen sensor 1 bank 2: identified total time (lean -> rich),0.03, s
MAS17052,Heated oxygen sensor 1 Bank 2: adaptation value for dead time,0.00, s
MAS17054,Heated oxygen sensor 1 bank 2: identified total time (rich -> lean),0.01, s
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.01, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17057,Heated oxygen sensor 1 Bank 2: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17159,Activation radiator shutter 3: result,0.00, %
MAS17160,Activation radiator shutter 4: result,0.00, %
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
MAS20352,Valve lift actuator intake: target position,0,
ENG105012,Abo,0,
ENG105037,Acc Ped trq Des,-9.0, Nm
ENG105054,Act Mod trq Clth,24.1, Nm
ENG119898,Actual_section_of_standard_test,0,
ENG105091,Afmim n,99.6, %
ENG105092,Afmim x,0.0, %
ENG105093,Afnmn,10200, /min
ENG105094,Afnmx,0, /min
ENG105095,AFS dm,28.3, kg/h
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,3.80, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,17.95, kg
ENG106228,Ambient air pressure,983, hPa
ENG106231,Ambient temperature,20.5, °C
ENG105192,APP r,0.00, %
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,1,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG105385,C Eng Us T t,21.2, °C
ENG101413,Calibration Identification,4N0557G 0002BVDB,
ENG99697,Calibration Verification Number,76 F9 F7 53,
ENG08772-ENG57549,Com cntr Bus Knk Out Tmr-Bits 0-7,0,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG106503,Coolant temperature at radiator outlet,21.0, °C
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG105761-ENG57549,DC_DC_transformer_mode_actual_state-Bits 0-7,7,
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,173,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,5,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,1,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,49,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,0,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-50000.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG112935,ElectricEnergyCoordinator_auxilary_systems_idle_speed_request,0.0, /min
ENG106110,ElectricEnergyCoordinator_electric_power_for_auxiliary_system_actual_value,352, W
ENG111593,Emachine_achievable_enginetorque_maximum_value,131.4, Nm
ENG112938,Emachine_achievable_enginetorque_quasistationary_maximum_value,131.4, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,-165.1, Nm
ENG112939,Emachine_achievable_generatortorque_quasistationary_maximum_value,-165.1, Nm
ENG115973,Engine Exhaust Flow Rate,30.2, kg/h
ENG20102,Engine Friction - Percent Torque,6.0, %
ENG112932,Engine_oil_temperature_measured_value,59.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,60.1, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG106223,Engine_torque_limitation_mechanical,3276.7, Nm
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,Correct result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,1,
ENG111568,EngineCoordinator_intervention_request_actual_value,No demand,
ENG111568-ENG36866,EngineCoordinator_intervention_request_actual_value-Test_Program_Co Eng Wp Dmd Req Set COMPU VERB UBYTE,0,
ENG111580,EngineCoordinator_Torque_commanded_value_Emachine,9.1, Nm
ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,56.54, °
ENG121110,Epm Ca S phi Adap Ref Pos O1 mp 1,89.36, °
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,13.000, l
ENG106677,Frm w,1.03836,
ENG106678,Frm2 w,1.02481,
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.54, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.54, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.36, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,0.00, %
ENG112931,Generator_load_from_CAN,0, W
ENG112929,Generator_torque_request,0.0, Nm
ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,0,
ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,0,
ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,0,
ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,0,
ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,0,
ENG121111-ENG57549,Glb Da Max Val 5-Bits 0-7,0,
ENG110577-ENG57549,Glb Da Min Val 0-Bits 0-7,0,
ENG121112-ENG57549,Glb Da Min Val 1-Bits 0-7,0,
ENG123647,Gsl Pfil dst Veh Cyc Rgn VW,73.768, km
ENG13533,Gsl Pfil m Soot Virt Ld Fcd Rgn VW,0.0, mg
ENG111600,HybridBattery_discharging_current_maximum_value,1023.97, A
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,28.4, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 02 00 4C 00 02 00 02 00 02 00 02 00 02 00 02 00 02 00 02 00 04 00 02 00 00 00 00 00 01 00 01 00 02 00 02 00 02 00 02 00 02 00 02 00 02 00 02 00 00 00 00 00 00 00 00,
ENG107236,Knock_sensor_cylinder_5_voltage,0.0182907, V*ms
ENG107237,Knock_sensor_cylinder_6_voltage,0.0236198, V*ms
ENG107238,Knock_sensor_cylinder_7_voltage,0.0264137, V*ms
ENG107239,Knock_sensor_cylinder_8_voltage,0.0181702, V*ms
ENG121113,Kvakb i w,7685, µl
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2020,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,10,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,14,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,18,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,28,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,28,
ENG127734,Life_cycle_data_start_requirement_development,Air Conditioning,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2020,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,10,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,14,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,18,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,15,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,16,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,Motor,
ENG127735,Life_cycle_data_stop_prohibition_development,Air Conditioning,
ENG127735,Life_cycle_data_stop_prohibition_development,12 volt vehicle electrical system,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,9,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,28,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,23,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,44,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,14,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Motor,
ENG111606,Load value: unrestricted commanded value,25.10, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG107621,Milso l w,10.249, %
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-63.0, Nm
ENG111574,Mode_control_enabling_reserved_torque_combustion_engine,False result,
ENG111574-ENG127289,Mode_control_enabling_reserved_torque_combustion_engine-Test_Program_B TRUE UBYTE,0,
ENG111573,Mode_control_enabling_target_torque_combustion_engine,0,
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111570,Mode_control_request_overrun_fuel_cutoff,Correct result,
ENG111570-ENG127289,Mode_control_request_overrun_fuel_cutoff-Test_Program_B TRUE UBYTE,1,
ENG111572,Mode_control_sport_mode_activated,False result,
ENG111572-ENG127289,Mode_control_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG107662-ENG57549,Mode_control_start_mode_commanded_value-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,-5.6, Nm
ENG107664,Mode_control_torque_for_Emaschine_quasistationary_lower_limit,-165.1, Nm
ENG107665,Mode_control_torque_for_Emaschine_quasistationary_upper_limit,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00049,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108178,Pbksi a w,-84.6, kPa
ENG108262,Powertrain_overall_gear_ratio,15.08,
ENG111605,Pressure_before_throttle_valve_actual_value,982.34, hPa
ENG108333,Psini w,982.03, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG27083,Rba Io Sig Rtc st Diag Stop Count er,96,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,1.6, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,10.2, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG26207,Tasrg 2 w,30.95, °C
ENG109344,Tasrg w,27.95, °C
ENG109625,Temperature at air conditioner heat exchanger output,95.0, °C
ENG08688,Thr Vlv u Sens1 B1,0.715, V
ENG27182,Thr Vlv u Sens1 B2,0.736, V
ENG08689,Thr Vlv u Sens2 B1,4.280, V
ENG27183,Thr Vlv u Sens2 B2,4.260, V
ENG01775,Top_speed_limitation,237.000, km/h
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,62.1, Nm
ENG109532,Torque_distribution_Emachine_torque_commanded_value_stationary_distribution,-25.6, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,1.3, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG109626,TS t Clnt Eng Out,70.2, °C
ENG109653,Tumg,20.3, °C
ENG111604,Turbocharger_inlet_pressure_corrected_value,396.17, hPa
ENG27251,UEGO r Lam S1 B2,1.0000,
ENG115976,Vehicle Odometer,74.0, km
ENG109861,Vehicle speed,0.00, km/h
ENG01774,Velocity_limiter_setpoint,511.000, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,257, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,64520, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8635480, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,16129, s
Elapsed Time: 01:36
adpmap-01-4N0-907-557-G
;SW:4N0-907-557-G HW:0P2-907-309-A --- Engine
;Component:V8 4.0l TFSI H31 0002, Coding:0A2A0012256E010E34286000000400000000000000000000
;EV_ECM40TFS0114N0907557G,001002,EV_ECM40TFS0114N0907557G.rod
;Thursday,15,October,2020,12:24:02:59422
;VCDS Version: Beta 20.9.1 (x64) Data version: 20200919 DS322.0
;VCID: 3A26590ABCA1183B69F-806E
IDE04158-Activation of start/stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,0.00 °,2
IDE06727-Timing deviation after chain replacement: intake bank 2,0.00 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,0.00 °,2
IDE06729-Timing deviation after chain replacement: exhaust bank 2,0.00 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06731-Timing deviation after other repairs: intake bank 2,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06733-Timing deviation after other repairs: exhaust bank 2,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,0.00 °,2
IDE06735-Timing deviation: current value intake bank 2,0.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °,2
IDE06737-Timing deviation: current value exhaust bank 2,0.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,0 ,1
IDE06739-Chain elongation: no. of valid initial values: intake bank 2,0 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,0 ,1
IDE06741-Chain elongation: no. of valid initial values: exhaust bank 2,0 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06743-Chain elongation: initial values valid: intake bank 2,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
IDE06745-Chain elongation: initial values valid: exhaust bank 2,not active ,1
Elapsed Time: 00:06
02-Auto Trans
blockmap-02-4N0-927-158-AN
;SW:4N0-927-158-AN HW:0D6-927-156-H --- Auto Trans
;Component:0D6 40TSINAR H05 1001, Coding:100000
;EV_TCMALX52011,002015,EV_TCMALX52011_VW53.rod
;Thursday,15,October,2020,12:24:22:59422
;VCID: 0154EEE691F78BE3685-8054
Group,Description,Actual
IDE00001-ENG07549,Production mode-Adaption Stategy Mode,not active,
IDE00001,Production mode,not active,
IDE00018,Voltage terminal 15,12.3, V
IDE00019,Voltage terminal 30,12.291, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,746, /min
IDE00022,Transmission input speed,724.00, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024,ATF temperature,31, °C
IDE00025,Coolant temperature,68, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00026,Vehicle speed from transmission,valid,
IDE00027-MAS00179,Status of brake signals-Brake lamp switch,Not operated,
IDE00027-MAS00180,Status of brake signals-Brake pressure switch,Not operated,
IDE00027-MAS00181,Status of brake signals-Validity of brake pressure information,valid,
IDE00027-MAS00182,Status of brake signals-Validity of brake pedal information,valid,
IDE00028,Driving resistance index,2,
IDE00031,Torque transmitting function,valid,
IDE00031,Torque transmitting function,15.0,
IDE00085,Normed load value,10.6, %
IDE00086,Accelerator pedal position,15, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00088-MAS00120,Status of vehicle condition influence-Traction control system,not active,
IDE00088-MAS00121,Status of vehicle condition influence-Electronic Differential Lock,not active,
IDE00088-MAS00122,Status of vehicle condition influence-Electronic Stability Program,not active,
IDE00088-MAS00123,Status of vehicle condition influence-Engine torque towing regulation,not active,
IDE00088-MAS00125,Status of vehicle condition influence-Cruise control system,passive,
IDE00088-MAS00126,Status of vehicle condition influence-Kickdown,not active,
IDE00088-MAS00127,Status of vehicle condition influence-brakes,not active,
IDE00089,Driving position,P,
IDE00090,selected gear,without traction,
IDE00091,Status of starter lock,OFF,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00099-MAS00172,Driving mode sensor-Hall sensor A,not active,
IDE00099-MAS00173,Driving mode sensor-Hall sensor B,not active,
IDE00099-MAS00174,Driving mode sensor-Hall sensor C,active,
IDE00099-MAS00175,Driving mode sensor-Hall sensor D,not active,
IDE00100,Engine torque,2, Nm
IDE00101,Engine specified torque during transmission intervention,0, Nm
IDE00102,Control Module temperature,29, °C
IDE00138,Total driving time,0.00, H
IDE00139,Economical driving time portion,0.0, %
IDE00140,Sport driving time portion,0.0, %
IDE00141,Manual driving time portion,0.0, %
IDE00540,Dynamic shift program,0,
IDE00541,Acceleration,0.0, 1/s²
IDE00542,Excessive temperature protection,0,
IDE00543,Deceleration mode / acceleration mode,Coasting,
IDE00544,Factor torque,Factor 2,
IDE00545,maximum permissible engine torque,880, Nm
IDE00546,Voltage supply of regulator valves,12.245, V
IDE00547,Torque converter amplification,1.00,
IDE00548,Converter clutch slip,0, /min
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00820,Activating and deactivating all development messages,not active,
IDE00915-MAS01185,Ambient conditions at heat shut-off-Status of temperature sensors,0,
IDE00915-MAS01186,Ambient conditions at heat shut-off-Shut-off temperature,145, °C
IDE00915-MAS02194,Ambient conditions at heat shut-off-Temperature 1,29, °C
IDE00915-MAS02195,Ambient conditions at heat shut-off-Temperature 2,32, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00920,Front left wheel speed,valid,
IDE00921,Wheel speed: right front,valid,
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00922,Left rear wheel speed,valid,
IDE00923,Right rear wheel speed,valid,
IDE00923,Right rear wheel speed,0.0, km/h
IDE01761,Route data,not active,
IDE02583,Steering wheel Tiptronic switch,active,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Oil temperature too high,not active,
IDE03008-MAS03913,Stop process prevented-Adaptation procedure active,not active,
IDE03008-MAS03914,Stop process prevented-Pressure reservoir filling not completed,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not engaged,not active,
IDE03008-MAS14667,Stop process prevented-Clutch temperature load too high,not active,
IDE03008-MAS16362,Stop process prevented-Hydraulic oil: pressure supply not ensured,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,1,
IDE03010-MAS03912,Number of prevented stop processes-Oil temperature too high,0,
IDE03010-MAS03913,Number of prevented stop processes-Adaptation procedure active,0,
IDE03010-MAS03914,Number of prevented stop processes-Pressure reservoir filling not completed,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not engaged,0,
IDE03010-MAS14667,Number of prevented stop processes-Clutch temperature load too high,0,
IDE03010-MAS16362,Number of prevented stop processes-Hydraulic oil: pressure supply not ensured,0,
IDE03011-MAS03917,Number of requested start processes-Driver's request,0,
IDE03011-MAS06834,Number of requested start processes-Vehicle speed too high,0,
IDE03011-MAS11378,Number of requested start processes-Transmission fluid auxiliary hydraulic pump malfunction,0,
IDE03011-MAS20811,Number of requested start processes-Plausibility check of clutches faulty,0,
IDE04111,Individual gear display,D off/S off,
IDE04347-MAS07468,Expanded freeze frame conditions-selected gear,P,
IDE04347-MAS07469,Expanded freeze frame conditions-Target gear,P,
IDE04347-ENG102069,Expanded freeze frame conditions-Accelerator Pedal Position D,102.0, %
IDE04347-ENG28428,Expanded freeze frame conditions-ASR,not active,
IDE04347-ENG99470,Expanded freeze frame conditions-Automatic transmission input speed,0.00, /min
IDE04347-ENG100451,Expanded freeze frame conditions-Automatic transmission output speed,0.00, /min
IDE04347-ENG101851,Expanded freeze frame conditions-Automatic Transmission shift position,P,
IDE04347-ENG101095,Expanded freeze frame conditions-B008_Average Wheel Speed / Drive Shaft,0, km/h
IDE04347-ENG28285,Expanded freeze frame conditions-Brake,fault,
IDE04347-ENG101831,Expanded freeze frame conditions-C0010_Current Regulator No. 9,0.0, mA
IDE04347-ENG101867,Expanded freeze frame conditions-C009_Current Regulator No. 8,0.0, mA
IDE04347-ENG103259,Expanded freeze frame conditions-Calculated engine preset torque,0, Nm
IDE04347-ENG103274,Expanded freeze frame conditions-CCS,not active,
IDE04347-ENG102274,Expanded freeze frame conditions-Control Module Voltage,12.852, V
IDE04347-ENG101834,Expanded freeze frame conditions-Current N215 Pressure control valve 1,0.0, mA
IDE04347-ENG99930,Expanded freeze frame conditions-Current N216 pressure reg.valve 2,0.0, mA
IDE04347-ENG102208,Expanded freeze frame conditions-Current N217 pressure reg.valve 3,0.0, mA
IDE04347-ENG100408,Expanded freeze frame conditions-Current N218 pressure reg.valve 4,0.0, mA
IDE04347-ENG101543,Expanded freeze frame conditions-Current N233 pressure reg.valve 5,0.0, mA
IDE04347-ENG101463,Expanded freeze frame conditions-Current N371 pressure reg. valve 6 lock-up clutch,0.0, mA
IDE04347-ENG101716,Expanded freeze frame conditions-Current N443 pressure reg.valve 7 main pressure,0.0, mA
IDE04347-ENG102805,Expanded freeze frame conditions-Current solenoid,0.0, mA
IDE04347-ENG98504,Expanded freeze frame conditions-Day,28,
IDE04347-ENG102053,Expanded freeze frame conditions-Desired State Solenoid Out 10,OFF,
IDE04347-ENG104161,Expanded freeze frame conditions-Desired State Solenoid Out 11,OFF,
IDE04347-ENG99231,Expanded freeze frame conditions-Desired State Solenoid Out 12,OFF,
IDE04347-ENG99490,Expanded freeze frame conditions-Desired State Solenoid Out 13,OFF,
IDE04347-ENG100651,Expanded freeze frame conditions-Desired State Solenoid Out 14,OFF,
IDE04347-ENG99228,Expanded freeze frame conditions-Diagnostic Fault Check Code,00 00 6B 5D,
IDE04347-ENG28372,Expanded freeze frame conditions-EDL,not active,
IDE04347-ENG99543,Expanded freeze frame conditions-Engine RPM,16383.8, /min
IDE04347-ENG98585,Expanded freeze frame conditions-Engine torque,0, Nm
IDE04347-ENG98546,Expanded freeze frame conditions-ESP,not active,
IDE04347-ENG102638,Expanded freeze frame conditions-F012_State_TCM_Torque_Engagement,no requirement,
IDE04347-ENG103123,Expanded freeze frame conditions-F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
IDE04347-ENG07546,Expanded freeze frame conditions-F018_Maximum_allowed_Engine_Torque,550, Nm
IDE04347-ENG101750,Expanded freeze frame conditions-G001_TCM Chip Temperature,26, °C
IDE04347-ENG28249,Expanded freeze frame conditions-Hallsensor A,not active,
IDE04347-ENG28250,Expanded freeze frame conditions-Hallsensor B,not active,
IDE04347-ENG28253,Expanded freeze frame conditions-Hallsensor C,active,
IDE04347-ENG28251,Expanded freeze frame conditions-Hallsensor D,not active,
IDE04347-ENG98653,Expanded freeze frame conditions-Hour,15,
IDE04347-ENG99396,Expanded freeze frame conditions-internal error code,178,
IDE04347-ENG99127,Expanded freeze frame conditions-internal error type,0,
IDE04347-ENG28254,Expanded freeze frame conditions-Kickdown,fault,
IDE04347-ENG102357,Expanded freeze frame conditions-M014_Time Since Shift,7650, ms
IDE04347-ENG103371,Expanded freeze frame conditions-M015_Time Normal Mode,321, s
IDE04347-ENG100237,Expanded freeze frame conditions-M018_Time In Afterrun,0, s
IDE04347-ENG104072,Expanded freeze frame conditions-M019_Time Since Reset,7650, ms
IDE04347-ENG103130,Expanded freeze frame conditions-M021_KM Mileage,0,
IDE04347-ENG98739,Expanded freeze frame conditions-Minute,21,
IDE04347-ENG98748,Expanded freeze frame conditions-Month,7,
IDE04347-ENG28445,Expanded freeze frame conditions-MSR,not active,
IDE04347-ENG103297,Expanded freeze frame conditions-OK Byte - Snapshot valid,invalid,
IDE04347-ENG102101,Expanded freeze frame conditions-PIN In0,low,
IDE04347-ENG100393,Expanded freeze frame conditions-PIN In1,low,
IDE04347-ENG101177,Expanded freeze frame conditions-PIN In2,low,
IDE04347-ENG103794,Expanded freeze frame conditions-PIN In3,low,
IDE04347-ENG99856,Expanded freeze frame conditions-PIN KL15,high,
IDE04347-ENG98884,Expanded freeze frame conditions-Seconds,13,
IDE04347-ENG98903,Expanded freeze frame conditions-selected gear,without traction,
IDE04347-ENG102114,Expanded freeze frame conditions-State ATF Temperature Sensor,OK,
IDE04347-ENG104115,Expanded freeze frame conditions-State Brake Signal,not OK.,
IDE04347-ENG100649,Expanded freeze frame conditions-State Chip Temperature Sensor,OK,
IDE04347-ENG103681,Expanded freeze frame conditions-State Driving Direction,OK,
IDE04347-ENG103922,Expanded freeze frame conditions-State Engine Speed,not OK.,
IDE04347-ENG99717,Expanded freeze frame conditions-State Output Shaft Speed,OK,
IDE04347-ENG101631,Expanded freeze frame conditions-State Pedal,not OK.,
IDE04347-ENG101699,Expanded freeze frame conditions-State Plausibility Tolerance,narrow,
IDE04347-ENG100193,Expanded freeze frame conditions-State Position Switch,OK,
IDE04347-ENG100953,Expanded freeze frame conditions-State Torque 1,OK,
IDE04347-ENG102844,Expanded freeze frame conditions-State Turbin Speed,OK,
IDE04347-ENG100622,Expanded freeze frame conditions-State Wheel Speed Front Left,OK,
IDE04347-ENG103645,Expanded freeze frame conditions-State Wheel Speed Front Right,OK,
IDE04347-ENG103415,Expanded freeze frame conditions-State Wheel Speed Rear Left,OK,
IDE04347-ENG100555,Expanded freeze frame conditions-State Wheel Speed Rear Right,OK,
IDE04347-ENG07547,Expanded freeze frame conditions-Status Lock up Clutch,Open,
IDE04347-ENG101226,Expanded freeze frame conditions-Status Terminal 15,On,
IDE04347-ENG28407,Expanded freeze frame conditions-Tiptronic Manual Position,not active,
IDE04347-ENG28364,Expanded freeze frame conditions-Tiptronic Minus,not active,
IDE04347-ENG28283,Expanded freeze frame conditions-Tiptronic Plus,not active,
IDE04347-ENG28470,Expanded freeze frame conditions-Tiptronik Paddle Minus,not active,
IDE04347-ENG28431,Expanded freeze frame conditions-Tiptronik Paddle Plus,not active,
IDE04347-ENG98981,Expanded freeze frame conditions-Transmission fluid temperature,29, °C
IDE04347-ENG99034,Expanded freeze frame conditions-Voltage terminal 15,12.7, V
IDE04347-ENG99063,Expanded freeze frame conditions-Year,2020,
IDE04814,Transmission oil cooler valve,closed,
IDE05965,Driving time slice efficient,0.0, %
IDE06086-ENG117324,Launch control counter-upshift 1-2,0,
IDE06086-ENG117322,Launch control counter-upshift 2-3,0,
IDE06086-ENG117328,Launch control counter-upshift 3-4,0,
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,3,
IDE06307-MAS00109,Stop prevention history data-Hours,11,
IDE06307-MAS00110,Stop prevention history data-Minutes,13,
IDE06307-MAS00111,Stop prevention history data-Seconds,9,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Oil temperature too low,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Vehicle speed too high,
IDE06308,Start request history data,Plausibility check of clutches faulty,
IDE06308,Start request history data,Transmission fluid auxiliary hydraulic pump malfunction,
IDE06308,Start request history data,Driver's request,
IDE06425,Dynamometer mode: functional,not activated,
IDE06425-ENG98891,Dynamometer mode: functional-Reserved,-1,
IDE06919,Torque converter clutch: status,Open,
IDE07063,Start/Stop Function present,activated by motor,
IDE07220,Fast adaptation: cancellation condition,Do not cancel,
IDE07437,Fill pressure: clutch A,0, mbar
IDE07438,Adaptation counter: clutch A,0,
IDE07439,Fast fill time: clutch A,0, ms
IDE07440,Adaptation counter: fast fill time: clutch A,0,
IDE07441,Fill pressure: clutch B,0, mbar
IDE07442,Adaptation counter: clutch B,0,
IDE07443,Fast fill time: clutch B,0, ms
IDE07444,Adaptation counter: fast fill time: clutch B,0,
IDE07445,Fill pressure: clutch C,-120, mbar
IDE07446,Adaptation counter: clutch C,0,
IDE07447,Fast fill time: clutch C,0, ms
IDE07448,Adaptation counter: fast fill time: clutch C,0,
IDE07449,Fill pressure: clutch D,30, mbar
IDE07450,Adaptation counter: clutch D,0,
IDE07451,Fast fill time: clutch D,0, ms
IDE07452,Adaptation counter: fast fill time: clutch D,0,
IDE07453,Fill pressure: clutch E,180, mbar
IDE07454,Adaptation counter: clutch E,0,
IDE07455,Fast fill time: clutch E,-4, ms
IDE07456,Adaptation counter: fast fill time: clutch E,1,
IDE07675,Clutch B: number of adaptations,0,
IDE07676,Fill pressure clutch B during park decoupling,0, mbar
IDE07677,Auto P counter,0,
IDE07678,N holding phase counter,23,
IDE07679,Counter engine off in P,90,
IDE07680,Counter insertion processes P,72,
IDE08728-MAS07468,Shift. process-selected gear,P,
IDE08728-MAS07469,Shift. process-Target gear,P,
IDE09396,Aux. hydraulic pump 1: actual RPM,0.00, /min
IDE10689,Auxiliary hydraulic pump for transmission oil: current,0.00, A
IDE11422-MAS01012,Sail function: activation preventions-Function not available.,No,
IDE11422-MAS02985,Sail function: activation preventions-Value,4294967295,
IDE11422-MAS07649,Sail function: activation preventions-Gas pedal depress.,No,
IDE11422-MAS07650,Sail function: activation preventions-Brake pedal depressed,No,
IDE11422-MAS12738,Sail function: activation preventions-Accel. pedal activated too quickly,No,
IDE11422-MAS12739,Sail function: activation preventions-Trailer hitched,No,
IDE11422-MAS12740,Sail function: activation preventions-Incline/decline excessive,No,
IDE11422-MAS12741,Sail function: activation preventions-Vehicle speed outside permitted range,No,
IDE11422-MAS12742,Sail function: activation preventions-Transmission adaption active,No,
IDE11422-MAS12743,Sail function: activation preventions-Transmission temp. outside permissible range,No,
IDE11422-MAS12744,Sail function: activation preventions-Exterior temperature outside permissible range,No,
IDE11422-MAS12745,Sail function: activation preventions-Event memory entry active,No,
IDE11422-MAS12746,Sail function: activation preventions-Coding of control module for automatic transmission incorrect,No,
IDE11422-MAS12747,Sail function: activation preventions-Engine drag torque control: ABS or ESC control active,No,
IDE11422-MAS12748,Sail function: activation preventions-Button for ASR and ESP activated,No,
IDE11422-MAS12749,Sail function: activation preventions-Activation prevented by engine control module,No,
IDE11422-MAS12750,Sail function: activation preventions-Activation prevented by battery energy management,No,
IDE11422-MAS12752,Sail function: activation preventions-Activation prevented by Climatronic control module,No,
IDE11422-MAS12753,Sail function: activation preventions-Activation prevented by ACC,No,
IDE11422-MAS12754,Sail function: activation preventions-Driving style insufficiently defined,No,
IDE11422-MAS12755,Sail function: activation preventions-Corner driving detected,No,
IDE11422-MAS12756,Sail function: activation preventions-Engine temperature too low/warm-up not finished,No,
IDE11422-MAS12757,Sail function: activation preventions-Deactivation by driver,No,
IDE11422-MAS12758,Sail function: activation preventions-Position of selector lever or drive program incorrect,No,
IDE11894-MAS01458,Auxiliary hydraulic pump transmission oil: operating point default-Operating condition,OFF,
IDE11894-MAS02985,Auxiliary hydraulic pump transmission oil: operating point default-Value,0,
IDE11914,Auxiliary hydraulic pump for transmission oil: supply voltage,12.50, V
IDE11915,Auxiliary hydraulic pump for transmission oil: internal temperature,27, °C
IDE12051-MAS01458,Auxiliary hydraulic pump trans.oil: feedback off operat.point-Operating condition,OFF,
IDE12051-MAS02985,Auxiliary hydraulic pump trans.oil: feedback off operat.point-Value,0,
ENG26447,2MC_communication_status,00,
ENG26448,2MC_reason_for_turning_high_side_switch_off,00 00,
ENG26449,2MC_transmission_output_speed,0, /min
ENG26450,2MC_transmission_output_speed_difference,0, /min
ENG26451,2MC_transmission_output_speed_status,0,
ENG07489,ADA_BFL_GLS_HS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG26460,ADA_BFL_GLS_K1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG26461,ADA_BFL_GLS_K2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07490,ADA_BFL_GLS_RS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07495,ADA_GA,00 00 00 00 00 00,
ENG07496,ADA_GA_CTR,00 00 00 00 00 00,
ENG07469,ADA_GE,00 00 00 00 00 00,
ENG07473,ADA_GLS_DRS_CTR_KF1,00 00 00 00 00 01 00 00 00 00 00 02,
ENG07481,ADA_GLS_DRS_KF1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EC EC 00 00 00 00 00 00 EC EC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 FC FC FF FF 00 00 00 00 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07474,ADA_GLS_HS_CTR_KF1,00 08 00 07 00 09 00 14 00 06 00 09 00 0F,
ENG07475,ADA_GLS_HS_CTR_KF1_KALT,00 08 00 07 00 09 00 14 00 06 00 09 00 0F,
ENG07476,ADA_GLS_HS_CTR_KF2,00 0B 00 0F 00 06 00 09 00 04 00 01 00 00,
ENG07477,ADA_GLS_HS_CTR_KF2_KALT,00 0B 00 0F 00 06 00 09 00 04 00 01 00 00,
ENG07482,ADA_GLS_HS_KF1,00 00 00 00 00 00 00 00 00 F9 FA 01 00 00 00 00 00 F9 FA 00 F9 FA 00 00 00 00 00 FF F9 FA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 F8 FC FC 00 00 00 00 F8 F8 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 FB F9 00 00 00 00 00 00 F9 F9 00 00 FB FB 00 00 00 00 00 00 FB F5 FA 00 00 00 00 00 00 FA FA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF F8 F6 FD 00 00 00 00 FF F2 F3 00 FC FC 00 00 00 FA FD 03 FC FC 00 00 00 FB FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 09 07 00 08 08 00 00 00 07 07 00 08 08 00 03 03 02 02 00 00 00 00 03 03 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE 00 FD FD 02 02 00 FE FC FE 00 00 00 00 00 00 FE FC 01 FF FA FE 00 00 00 FE FE FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 01 01 00 00 00 00 03 08 07 0B 06 FD 00 00 00 05 06 0A 06 FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07483,ADA_GLS_HS_KF1_KALT,00 00 00 00 00 00 00 00 00 F9 FA 01 00 00 00 00 00 F9 FA 00 F9 FA 00 00 00 00 00 FF F9 FA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 F8 FC FC 00 00 00 00 F8 F8 FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 FB F9 00 00 00 00 00 00 F9 F9 00 00 FB FB 00 00 00 00 00 00 FB F5 FA 00 00 00 00 00 00 FA FA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF F8 F6 FD 00 00 00 00 FF F2 F3 00 FC FC 00 00 00 FA FD 03 FC FC 00 00 00 FB FB 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 02 09 07 00 08 08 00 00 00 07 07 00 08 08 00 03 03 02 02 00 00 00 00 03 03 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE FE 00 FD FD 02 02 00 FE FC FE 00 00 00 00 00 00 FE FC 01 FF FA FE 00 00 00 FE FE FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 01 01 00 00 00 00 03 08 07 0B 06 FD 00 00 00 05 06 0A 06 FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07484,ADA_GLS_HS_KF2,00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 03 01 FE 00 00 00 00 00 03 FF FC 00 00 00 00 00 0B 0B FD FD FC FC 00 00 0B 0B FD FD FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F4 E8 F1 FD 00 00 00 00 F4 E8 F1 FD FD FD 00 00 00 00 00 00 FD FC FF 00 00 00 00 00 00 01 01 00 00 00 00 00 00 02 02 00 00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FC FC 00 00 F9 F9 00 00 FC FC 00 00 F6 F6 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC FC 00 00 00 00 00 00 FC FC 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1D 1D 00 00 00 00 00 00 1D 1D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 07 00 00 00 00 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07485,ADA_GLS_HS_KF2_KALT,00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 03 01 FE 00 00 00 00 00 03 FF FC 00 00 00 00 00 0B 0B FD FD FC FC 00 00 0B 0B FD FD FC FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F4 E8 F1 FD 00 00 00 00 F4 E8 F1 FD FD FD 00 00 00 00 00 00 FD FC FF 00 00 00 00 00 00 01 01 00 00 00 00 00 00 02 02 00 00 00 00 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FC FC 00 00 F9 F9 00 00 FC FC 00 00 F6 F6 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC FC 00 00 00 00 00 00 FC FC 00 00 00 00 00 00 00 00 00 00 02 02 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FB FB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1D 1D 00 00 00 00 00 00 1D 1D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 07 00 00 00 00 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07480,ADA_GLS_NRS_CTR_KF1,00 00 00 00 00 00 00 00 00 00,
ENG07488,ADA_GLS_NRS_KF1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07478,ADA_GLS_RS_CTR_KF1,00 00 00 02 00 01 00 07 00 02 00 06 00 09,
ENG07479,ADA_GLS_RS_CTR_KF2,00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07486,ADA_GLS_RS_KF1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC FC 00 00 00 00 00 F9 F5 FC 00 00 00 00 00 F9 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F3 F3 00 00 00 00 00 00 F3 F3 00 00 00 00 00 00 01 01 00 00 00 00 00 00 01 01 FF 01 02 00 00 00 00 00 FF 01 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 F8 00 00 00 00 00 00 F5 F5 00 00 00 00 00 00 FD FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA F9 FF 00 00 00 00 00 F9 F8 FF 00 00 00 00 00 FF FF FA EF EE F9 00 00 00 00 FA EF EE F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 0C 00 00 00 00 00 00 0C 10 0C 08 00 00 00 00 00 04 04 00 FE FE 00 00 00 00 F8 F8 FE FE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07487,ADA_GLS_RS_KF2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07471,ADA_PF,00 00 00 00 FF 82 00 22 00 B7,
ENG07492,ADA_PF_CTR,00 00 00 00 00 00 00 00 00 00,
ENG26462,ADA_PF_CTR_KALT,00 00 00 00 00 00 00 00 00 00,
ENG26463,ADA_PF_KALT,00 00 00 00 00 00 00 00 00 00,
ENG26464,ADA_PF_SCTR,01 2C 00 97 01 BB 00 87 01 13,
ENG26465,ADA_PF_SCTR_KALT,01 2C 00 97 01 BB 00 87 01 13,
ENG07493,ADA_PF_START_CTR,00 04 00 00 00 05 00 06 00 04,
ENG07470,ADA_PF2,00 00,
ENG07491,ADA_PF2_CTR,00 00,
ENG07472,ADA_TSF,00 00 00 00 00 00 00 00 FF FC,
ENG07494,ADA_TSF_CTR,00 00 00 00 00 00 00 00 00 01,
ENG26466,ADA_TSF_SCTR,01 2C 00 97 01 BB 00 87 00 A1,
ENG02482,Adaption_counter_PF_Lockup_clutch,0,
ENG02480,Adaption_counter_TSF_Lockup_clutch,0,
ENG02481-ENG98502,Adaption_inflation_current_PF_Lockup_clutch-Data,0, mA
ENG02479-ENG98502,Adaption_inflation_time_TSF_Lockup_clutch-Data,0.0, ms
ENG37600-MAS00711,Automatic Position Change-Odometer reading,55, km
ENG37600-ENG112386,Automatic Position Change-Event,6,
ENG37601-MAS00711,Automatic Position Change Diagnostic-Odometer reading,0, km
ENG37601-ENG112386,Automatic Position Change Diagnostic-Event,0,
ENG117298,Auxiliary_Oil_Pump_counter_temp_subzero,0,
ENG07468,Auxiliary_Oil_Pump_Error_Status,0,
ENG07466-ENG31833,Auxiliary_Oil_Pump_Hardware_Version-HW Sample,d,
ENG07466-ENG36249,Auxiliary_Oil_Pump_Hardware_Version-HW Sample Level,6,
ENG07466-ENG99001,Auxiliary_Oil_Pump_Hardware_Version-Variant,IEP400.1,
ENG122750,Auxiliary_Oil_Pump_Hours_Operating_Point_0,7, H
ENG122751,Auxiliary_Oil_Pump_Hours_Operating_Point_1,0, H
ENG122752,Auxiliary_Oil_Pump_Hours_Operating_Point_2,0, H
ENG122753,Auxiliary_Oil_Pump_Hours_Operating_Point_3,0, H
ENG07467,Auxiliary_Oil_Pump_ID,956427816,
ENG07465-ENG32008,Auxiliary_Oil_Pump_Software_Version-Main Version,8,
ENG07465-ENG99001,Auxiliary_Oil_Pump_Software_Version-Variant,IEP400.1,
ENG07465-ENG99027,Auxiliary_Oil_Pump_Software_Version-Version,1,
ENG101095,B008_Average Wheel Speed / Drive Shaft,0, km/h
ENG07420-IDE00021,Backup Error Entry 1-Engine RPM,0.00, /min
ENG07420-IDE00022,Backup Error Entry 1-Transmission input speed,0, /min
ENG07420-IDE00023,Backup Error Entry 1-Transmission output speed,0, /min
ENG07420-IDE00024,Backup Error Entry 1-ATF temperature,29, °C
ENG07420-IDE00086,Backup Error Entry 1-Accelerator pedal position,15.2, %
ENG07420-IDE00100,Backup Error Entry 1-Engine torque,0, Nm
ENG07420-IDE00145,Backup Error Entry 1-Clutch status,0,
ENG07420-MAS00106,Backup Error Entry 1-Year,2127,
ENG07420-MAS00107,Backup Error Entry 1-Month,15,
ENG07420-MAS00108,Backup Error Entry 1-Day,31,
ENG07420-MAS00109,Backup Error Entry 1-Hours,31,
ENG07420-MAS00110,Backup Error Entry 1-Minutes,63,
ENG07420-MAS00111,Backup Error Entry 1-Seconds,63,
ENG07420-MAS00468,Backup Error Entry 1-Unlearning counter,255,
ENG07420-MAS00711,Backup Error Entry 1-Odometer reading,16777215, km
ENG07420-MAS00978,Backup Error Entry 1-Priority,2,
ENG07420-MAS00979,Backup Error Entry 1-Malfunction frequency counter,1,
ENG07420,Backup Error Entry 1,00 26,
ENG07420,Backup Error Entry 1,20 96 28 10 34 02 49 10 3B FF 10 3A 00 00 10 33 FF F4 42 33 B0 02 85 83 02 88 01 21 0E 09 70 D1 0D 0D 21 0F 02 03 00 00 40 00 21 11 00 2A 08 05 0A 10 2F 40 10 2E 00 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FE 10 1E 00 21 12 00 03 01 42 10 2C 45 10 80 70 21 15 00 10 12 00 21 2F 33 A0,
ENG07420-ENG101797,Backup Error Entry 1-DTC value,00 00 00,
ENG07420-ENG28457,Backup Error Entry 1-Status Of DTC,00,
ENG07420-ENG28489,Backup Error Entry 1-Status Of DTC Bit 0,passive/sporadic,
ENG07420-ENG28302,Backup Error Entry 1-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07420-ENG28383,Backup Error Entry 1-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07420-ENG28451,Backup Error Entry 1-Status Of DTC Bit 3,Not confirmed,
ENG07420-ENG28462,Backup Error Entry 1-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07420-ENG28409,Backup Error Entry 1-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07420-ENG28336,Backup Error Entry 1-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07420-ENG28301,Backup Error Entry 1-Status Of DTC Bit 7,No warning display on,
ENG07429-IDE00021,Backup Error Entry 10-Engine RPM,16383.75, /min
ENG07429-IDE00022,Backup Error Entry 10-Transmission input speed,0, /min
ENG07429-IDE00023,Backup Error Entry 10-Transmission output speed,0, /min
ENG07429-IDE00024,Backup Error Entry 10-ATF temperature,29, °C
ENG07429-IDE00086,Backup Error Entry 10-Accelerator pedal position,102.0, %
ENG07429-IDE00100,Backup Error Entry 10-Engine torque,0, Nm
ENG07429-IDE00145,Backup Error Entry 10-Clutch status,0,
ENG07429-MAS00106,Backup Error Entry 10-Year,2020,
ENG07429-MAS00107,Backup Error Entry 10-Month,7,
ENG07429-MAS00108,Backup Error Entry 10-Day,28,
ENG07429-MAS00109,Backup Error Entry 10-Hours,15,
ENG07429-MAS00110,Backup Error Entry 10-Minutes,21,
ENG07429-MAS00111,Backup Error Entry 10-Seconds,13,
ENG07429-MAS00468,Backup Error Entry 10-Unlearning counter,255,
ENG07429-MAS00711,Backup Error Entry 10-Odometer reading,0, km
ENG07429-MAS00978,Backup Error Entry 10-Priority,2,
ENG07429-MAS00979,Backup Error Entry 10-Malfunction frequency counter,1,
ENG07429,Backup Error Entry 10,00 BC,
ENG07429,Backup Error Entry 10,20 96 28 10 34 01 41 10 3B FF 10 3A 00 00 10 33 FF F4 42 32 34 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 7F 02 88 01 13 00 90 18 43 C8,
ENG07429-ENG101797,Backup Error Entry 10-DTC value,00 6B 63,
ENG07429-ENG28457,Backup Error Entry 10-Status Of DTC,00,
ENG07429-ENG28489,Backup Error Entry 10-Status Of DTC Bit 0,passive/sporadic,
ENG07429-ENG28302,Backup Error Entry 10-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07429-ENG28383,Backup Error Entry 10-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07429-ENG28451,Backup Error Entry 10-Status Of DTC Bit 3,Not confirmed,
ENG07429-ENG28462,Backup Error Entry 10-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07429-ENG28409,Backup Error Entry 10-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07429-ENG28336,Backup Error Entry 10-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07429-ENG28301,Backup Error Entry 10-Status Of DTC Bit 7,No warning display on,
ENG07421-IDE00021,Backup Error Entry 2-Engine RPM,0.00, /min
ENG07421-IDE00022,Backup Error Entry 2-Transmission input speed,0, /min
ENG07421-IDE00023,Backup Error Entry 2-Transmission output speed,0, /min
ENG07421-IDE00024,Backup Error Entry 2-ATF temperature,36, °C
ENG07421-IDE00086,Backup Error Entry 2-Accelerator pedal position,15.2, %
ENG07421-IDE00100,Backup Error Entry 2-Engine torque,0, Nm
ENG07421-IDE00145,Backup Error Entry 2-Clutch status,0,
ENG07421-MAS00106,Backup Error Entry 2-Year,2020,
ENG07421-MAS00107,Backup Error Entry 2-Month,7,
ENG07421-MAS00108,Backup Error Entry 2-Day,28,
ENG07421-MAS00109,Backup Error Entry 2-Hours,17,
ENG07421-MAS00110,Backup Error Entry 2-Minutes,41,
ENG07421-MAS00111,Backup Error Entry 2-Seconds,15,
ENG07421-MAS00468,Backup Error Entry 2-Unlearning counter,255,
ENG07421-MAS00711,Backup Error Entry 2-Odometer reading,0, km
ENG07421-MAS00978,Backup Error Entry 2-Priority,2,
ENG07421-MAS00979,Backup Error Entry 2-Malfunction frequency counter,1,
ENG07421,Backup Error Entry 2,00 26,
ENG07421,Backup Error Entry 2,20 96 28 10 34 00 3B 10 3B FF 10 3A 00 00 10 33 FF F4 42 38 BC 02 85 90 02 88 01 21 0E 00 70 D1 0D 0D 21 0F 02 03 00 01 C0 00 21 11 00 00 08 05 0A 10 2F 00 10 2E 00 10 31 00 21 13 01 10 05 00 00 21 16 00 00 21 10 FF FE 10 1E 00 21 12 00 03 01 4A 10 2C 4D 10 80 70 21 15 00 10 12 00 21 2F 38 AB,
ENG07421-ENG101797,Backup Error Entry 2-DTC value,00 00 00,
ENG07421-ENG28457,Backup Error Entry 2-Status Of DTC,00,
ENG07421-ENG28489,Backup Error Entry 2-Status Of DTC Bit 0,passive/sporadic,
ENG07421-ENG28302,Backup Error Entry 2-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07421-ENG28383,Backup Error Entry 2-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07421-ENG28451,Backup Error Entry 2-Status Of DTC Bit 3,Not confirmed,
ENG07421-ENG28462,Backup Error Entry 2-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07421-ENG28409,Backup Error Entry 2-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07421-ENG28336,Backup Error Entry 2-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07421-ENG28301,Backup Error Entry 2-Status Of DTC Bit 7,No warning display on,
ENG07422-IDE00021,Backup Error Entry 3-Engine RPM,16383.75, /min
ENG07422-IDE00022,Backup Error Entry 3-Transmission input speed,0, /min
ENG07422-IDE00023,Backup Error Entry 3-Transmission output speed,0, /min
ENG07422-IDE00024,Backup Error Entry 3-ATF temperature,28, °C
ENG07422-IDE00086,Backup Error Entry 3-Accelerator pedal position,102.0, %
ENG07422-IDE00100,Backup Error Entry 3-Engine torque,0, Nm
ENG07422-IDE00145,Backup Error Entry 3-Clutch status,0,
ENG07422-MAS00106,Backup Error Entry 3-Year,2020,
ENG07422-MAS00107,Backup Error Entry 3-Month,7,
ENG07422-MAS00108,Backup Error Entry 3-Day,28,
ENG07422-MAS00109,Backup Error Entry 3-Hours,13,
ENG07422-MAS00110,Backup Error Entry 3-Minutes,57,
ENG07422-MAS00111,Backup Error Entry 3-Seconds,18,
ENG07422-MAS00468,Backup Error Entry 3-Unlearning counter,255,
ENG07422-MAS00711,Backup Error Entry 3-Odometer reading,0, km
ENG07422-MAS00978,Backup Error Entry 3-Priority,2,
ENG07422-MAS00979,Backup Error Entry 3-Malfunction frequency counter,1,
ENG07422,Backup Error Entry 3,20 96 28 10 34 00 07 10 3B EE 10 3A 00 00 10 33 EE F4 42 2D C6 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 73 02 88 01 13 00 90 18 43 88,
ENG07422,Backup Error Entry 3,00 B2,
ENG07422-ENG101797,Backup Error Entry 3-DTC value,00 6B 5D,
ENG07422-ENG28457,Backup Error Entry 3-Status Of DTC,00,
ENG07422-ENG28489,Backup Error Entry 3-Status Of DTC Bit 0,passive/sporadic,
ENG07422-ENG28302,Backup Error Entry 3-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07422-ENG28383,Backup Error Entry 3-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07422-ENG28451,Backup Error Entry 3-Status Of DTC Bit 3,Not confirmed,
ENG07422-ENG28462,Backup Error Entry 3-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07422-ENG28409,Backup Error Entry 3-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07422-ENG28336,Backup Error Entry 3-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07422-ENG28301,Backup Error Entry 3-Status Of DTC Bit 7,No warning display on,
ENG07423-IDE00021,Backup Error Entry 4-Engine RPM,16383.75, /min
ENG07423-IDE00022,Backup Error Entry 4-Transmission input speed,0, /min
ENG07423-IDE00023,Backup Error Entry 4-Transmission output speed,0, /min
ENG07423-IDE00024,Backup Error Entry 4-ATF temperature,28, °C
ENG07423-IDE00086,Backup Error Entry 4-Accelerator pedal position,102.0, %
ENG07423-IDE00100,Backup Error Entry 4-Engine torque,0, Nm
ENG07423-IDE00145,Backup Error Entry 4-Clutch status,0,
ENG07423-MAS00106,Backup Error Entry 4-Year,2020,
ENG07423-MAS00107,Backup Error Entry 4-Month,7,
ENG07423-MAS00108,Backup Error Entry 4-Day,28,
ENG07423-MAS00109,Backup Error Entry 4-Hours,13,
ENG07423-MAS00110,Backup Error Entry 4-Minutes,57,
ENG07423-MAS00111,Backup Error Entry 4-Seconds,18,
ENG07423-MAS00468,Backup Error Entry 4-Unlearning counter,255,
ENG07423-MAS00711,Backup Error Entry 4-Odometer reading,0, km
ENG07423-MAS00978,Backup Error Entry 4-Priority,2,
ENG07423-MAS00979,Backup Error Entry 4-Malfunction frequency counter,1,
ENG07423,Backup Error Entry 4,00 BC,
ENG07423,Backup Error Entry 4,20 96 28 10 34 00 07 10 3B EF 10 3A 00 00 10 33 EF F4 42 2D C8 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 73 02 88 01 13 00 90 18 43 88,
ENG07423-ENG101797,Backup Error Entry 4-DTC value,00 6B 63,
ENG07423-ENG28457,Backup Error Entry 4-Status Of DTC,00,
ENG07423-ENG28489,Backup Error Entry 4-Status Of DTC Bit 0,passive/sporadic,
ENG07423-ENG28302,Backup Error Entry 4-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07423-ENG28383,Backup Error Entry 4-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07423-ENG28451,Backup Error Entry 4-Status Of DTC Bit 3,Not confirmed,
ENG07423-ENG28462,Backup Error Entry 4-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07423-ENG28409,Backup Error Entry 4-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07423-ENG28336,Backup Error Entry 4-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07423-ENG28301,Backup Error Entry 4-Status Of DTC Bit 7,No warning display on,
ENG07424-IDE00021,Backup Error Entry 5-Engine RPM,16383.75, /min
ENG07424-IDE00022,Backup Error Entry 5-Transmission input speed,0, /min
ENG07424-IDE00023,Backup Error Entry 5-Transmission output speed,0, /min
ENG07424-IDE00024,Backup Error Entry 5-ATF temperature,28, °C
ENG07424-IDE00086,Backup Error Entry 5-Accelerator pedal position,102.0, %
ENG07424-IDE00100,Backup Error Entry 5-Engine torque,0, Nm
ENG07424-IDE00145,Backup Error Entry 5-Clutch status,0,
ENG07424-MAS00106,Backup Error Entry 5-Year,2020,
ENG07424-MAS00107,Backup Error Entry 5-Month,7,
ENG07424-MAS00108,Backup Error Entry 5-Day,28,
ENG07424-MAS00109,Backup Error Entry 5-Hours,13,
ENG07424-MAS00110,Backup Error Entry 5-Minutes,57,
ENG07424-MAS00111,Backup Error Entry 5-Seconds,18,
ENG07424-MAS00468,Backup Error Entry 5-Unlearning counter,255,
ENG07424-MAS00711,Backup Error Entry 5-Odometer reading,0, km
ENG07424-MAS00978,Backup Error Entry 5-Priority,2,
ENG07424-MAS00979,Backup Error Entry 5-Malfunction frequency counter,3,
ENG07424,Backup Error Entry 5,00 B4,
ENG07424,Backup Error Entry 5,20 96 28 10 34 00 07 10 3B F5 10 3A 00 00 10 33 F5 F4 42 2D CB 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 74 02 88 01 13 00 90 18 43 88,
ENG07424-ENG101797,Backup Error Entry 5-DTC value,00 6B 5F,
ENG07424-ENG28457,Backup Error Entry 5-Status Of DTC,00,
ENG07424-ENG28489,Backup Error Entry 5-Status Of DTC Bit 0,passive/sporadic,
ENG07424-ENG28302,Backup Error Entry 5-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07424-ENG28383,Backup Error Entry 5-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07424-ENG28451,Backup Error Entry 5-Status Of DTC Bit 3,Not confirmed,
ENG07424-ENG28462,Backup Error Entry 5-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07424-ENG28409,Backup Error Entry 5-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07424-ENG28336,Backup Error Entry 5-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07424-ENG28301,Backup Error Entry 5-Status Of DTC Bit 7,No warning display on,
ENG07425-IDE00021,Backup Error Entry 6-Engine RPM,16383.75, /min
ENG07425-IDE00022,Backup Error Entry 6-Transmission input speed,0, /min
ENG07425-IDE00023,Backup Error Entry 6-Transmission output speed,0, /min
ENG07425-IDE00024,Backup Error Entry 6-ATF temperature,28, °C
ENG07425-IDE00086,Backup Error Entry 6-Accelerator pedal position,102.0, %
ENG07425-IDE00100,Backup Error Entry 6-Engine torque,0, Nm
ENG07425-IDE00145,Backup Error Entry 6-Clutch status,0,
ENG07425-MAS00106,Backup Error Entry 6-Year,2020,
ENG07425-MAS00107,Backup Error Entry 6-Month,7,
ENG07425-MAS00108,Backup Error Entry 6-Day,28,
ENG07425-MAS00109,Backup Error Entry 6-Hours,4,
ENG07425-MAS00110,Backup Error Entry 6-Minutes,58,
ENG07425-MAS00111,Backup Error Entry 6-Seconds,50,
ENG07425-MAS00468,Backup Error Entry 6-Unlearning counter,255,
ENG07425-MAS00711,Backup Error Entry 6-Odometer reading,0, km
ENG07425-MAS00978,Backup Error Entry 6-Priority,2,
ENG07425-MAS00979,Backup Error Entry 6-Malfunction frequency counter,1,
ENG07425,Backup Error Entry 6,00 B2,
ENG07425,Backup Error Entry 6,20 96 28 10 34 00 59 10 3B FF 10 3A 00 00 10 33 FF F4 42 2D AC 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 73 02 88 01 13 00 90 18 43 88,
ENG07425-ENG101797,Backup Error Entry 6-DTC value,00 6B 5D,
ENG07425-ENG28457,Backup Error Entry 6-Status Of DTC,00,
ENG07425-ENG28489,Backup Error Entry 6-Status Of DTC Bit 0,passive/sporadic,
ENG07425-ENG28302,Backup Error Entry 6-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07425-ENG28383,Backup Error Entry 6-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07425-ENG28451,Backup Error Entry 6-Status Of DTC Bit 3,Not confirmed,
ENG07425-ENG28462,Backup Error Entry 6-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07425-ENG28409,Backup Error Entry 6-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07425-ENG28336,Backup Error Entry 6-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07425-ENG28301,Backup Error Entry 6-Status Of DTC Bit 7,No warning display on,
ENG07426-IDE00021,Backup Error Entry 7-Engine RPM,16383.75, /min
ENG07426-IDE00022,Backup Error Entry 7-Transmission input speed,0, /min
ENG07426-IDE00023,Backup Error Entry 7-Transmission output speed,0, /min
ENG07426-IDE00024,Backup Error Entry 7-ATF temperature,28, °C
ENG07426-IDE00086,Backup Error Entry 7-Accelerator pedal position,102.0, %
ENG07426-IDE00100,Backup Error Entry 7-Engine torque,0, Nm
ENG07426-IDE00145,Backup Error Entry 7-Clutch status,0,
ENG07426-MAS00106,Backup Error Entry 7-Year,2020,
ENG07426-MAS00107,Backup Error Entry 7-Month,7,
ENG07426-MAS00108,Backup Error Entry 7-Day,28,
ENG07426-MAS00109,Backup Error Entry 7-Hours,4,
ENG07426-MAS00110,Backup Error Entry 7-Minutes,58,
ENG07426-MAS00111,Backup Error Entry 7-Seconds,50,
ENG07426-MAS00468,Backup Error Entry 7-Unlearning counter,255,
ENG07426-MAS00711,Backup Error Entry 7-Odometer reading,0, km
ENG07426-MAS00978,Backup Error Entry 7-Priority,2,
ENG07426-MAS00979,Backup Error Entry 7-Malfunction frequency counter,1,
ENG07426,Backup Error Entry 7,00 BC,
ENG07426,Backup Error Entry 7,20 96 28 10 34 00 59 10 3B FF 10 3A 00 00 10 33 FF F4 42 2D AC 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 73 02 88 01 13 00 90 18 43 88,
ENG07426-ENG101797,Backup Error Entry 7-DTC value,00 6B 63,
ENG07426-ENG28457,Backup Error Entry 7-Status Of DTC,00,
ENG07426-ENG28489,Backup Error Entry 7-Status Of DTC Bit 0,passive/sporadic,
ENG07426-ENG28302,Backup Error Entry 7-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07426-ENG28383,Backup Error Entry 7-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07426-ENG28451,Backup Error Entry 7-Status Of DTC Bit 3,Not confirmed,
ENG07426-ENG28462,Backup Error Entry 7-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07426-ENG28409,Backup Error Entry 7-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07426-ENG28336,Backup Error Entry 7-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07426-ENG28301,Backup Error Entry 7-Status Of DTC Bit 7,No warning display on,
ENG07427-IDE00021,Backup Error Entry 8-Engine RPM,16383.75, /min
ENG07427-IDE00022,Backup Error Entry 8-Transmission input speed,0, /min
ENG07427-IDE00023,Backup Error Entry 8-Transmission output speed,0, /min
ENG07427-IDE00024,Backup Error Entry 8-ATF temperature,28, °C
ENG07427-IDE00086,Backup Error Entry 8-Accelerator pedal position,102.0, %
ENG07427-IDE00100,Backup Error Entry 8-Engine torque,0, Nm
ENG07427-IDE00145,Backup Error Entry 8-Clutch status,0,
ENG07427-MAS00106,Backup Error Entry 8-Year,2020,
ENG07427-MAS00107,Backup Error Entry 8-Month,7,
ENG07427-MAS00108,Backup Error Entry 8-Day,28,
ENG07427-MAS00109,Backup Error Entry 8-Hours,4,
ENG07427-MAS00110,Backup Error Entry 8-Minutes,58,
ENG07427-MAS00111,Backup Error Entry 8-Seconds,50,
ENG07427-MAS00468,Backup Error Entry 8-Unlearning counter,255,
ENG07427-MAS00711,Backup Error Entry 8-Odometer reading,0, km
ENG07427-MAS00978,Backup Error Entry 8-Priority,2,
ENG07427-MAS00979,Backup Error Entry 8-Malfunction frequency counter,1,
ENG07427,Backup Error Entry 8,00 81,
ENG07427,Backup Error Entry 8,20 96 28 10 34 00 59 10 3B FF 10 3A 00 00 10 33 FF F4 42 2D AF 10 05 00 00 21 0E 00 70 D1 0D 0D 21 0F 02 10 2E 00 02 88 01 21 0D 00 40 03 01 42 10 24 00 00 10 25 00 00 10 26 00 00 10 27 00 00 10 28 00 00 10 29 00 00 08 05 0E 21 13 01 10 00 00 01 BC 7E 10 2F 00 02 85 73 21 12 00,
ENG07427-ENG101797,Backup Error Entry 8-DTC value,00 6B 2A,
ENG07427-ENG28457,Backup Error Entry 8-Status Of DTC,00,
ENG07427-ENG28489,Backup Error Entry 8-Status Of DTC Bit 0,passive/sporadic,
ENG07427-ENG28302,Backup Error Entry 8-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07427-ENG28383,Backup Error Entry 8-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07427-ENG28451,Backup Error Entry 8-Status Of DTC Bit 3,Not confirmed,
ENG07427-ENG28462,Backup Error Entry 8-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07427-ENG28409,Backup Error Entry 8-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07427-ENG28336,Backup Error Entry 8-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07427-ENG28301,Backup Error Entry 8-Status Of DTC Bit 7,No warning display on,
ENG07428-IDE00021,Backup Error Entry 9-Engine RPM,16383.75, /min
ENG07428-IDE00022,Backup Error Entry 9-Transmission input speed,0, /min
ENG07428-IDE00023,Backup Error Entry 9-Transmission output speed,0, /min
ENG07428-IDE00024,Backup Error Entry 9-ATF temperature,29, °C
ENG07428-IDE00086,Backup Error Entry 9-Accelerator pedal position,102.0, %
ENG07428-IDE00100,Backup Error Entry 9-Engine torque,0, Nm
ENG07428-IDE00145,Backup Error Entry 9-Clutch status,0,
ENG07428-MAS00106,Backup Error Entry 9-Year,2020,
ENG07428-MAS00107,Backup Error Entry 9-Month,7,
ENG07428-MAS00108,Backup Error Entry 9-Day,28,
ENG07428-MAS00109,Backup Error Entry 9-Hours,15,
ENG07428-MAS00110,Backup Error Entry 9-Minutes,21,
ENG07428-MAS00111,Backup Error Entry 9-Seconds,13,
ENG07428-MAS00468,Backup Error Entry 9-Unlearning counter,255,
ENG07428-MAS00711,Backup Error Entry 9-Odometer reading,0, km
ENG07428-MAS00978,Backup Error Entry 9-Priority,2,
ENG07428-MAS00979,Backup Error Entry 9-Malfunction frequency counter,1,
ENG07428,Backup Error Entry 9,20 96 28 10 34 01 41 10 3B FF 10 3A 00 00 10 33 FF F4 42 32 34 10 00 00 01 BC 7E 10 05 00 00 21 0E 00 21 0F 02 70 D1 0D 0D 03 00 03 E8 00 21 11 00 00 08 05 0E 02 85 7F 02 88 01 13 00 90 18 43 C8,
ENG07428,Backup Error Entry 9,00 B2,
ENG07428-ENG101797,Backup Error Entry 9-DTC value,00 6B 5D,
ENG07428-ENG28457,Backup Error Entry 9-Status Of DTC,00,
ENG07428-ENG28489,Backup Error Entry 9-Status Of DTC Bit 0,passive/sporadic,
ENG07428-ENG28302,Backup Error Entry 9-Status Of DTC Bit 1,Malfunction has not occurred in current operating cycle,
ENG07428-ENG28383,Backup Error Entry 9-Status Of DTC Bit 2,Malfunction in current or last driving cycle not detected,
ENG07428-ENG28451,Backup Error Entry 9-Status Of DTC Bit 3,Not confirmed,
ENG07428-ENG28462,Backup Error Entry 9-Status Of DTC Bit 4,Tested since erasing DTC memory,
ENG07428-ENG28409,Backup Error Entry 9-Status Of DTC Bit 5,Malfunction did not occur since erasing DTC memory,
ENG07428-ENG28336,Backup Error Entry 9-Status Of DTC Bit 6,Tested in current operating cycle,
ENG07428-ENG28301,Backup Error Entry 9-Status Of DTC Bit 7,No warning display on,
ENG101867,C009_Current Regulator No. 8,0.0, mA
ENG105392,C010_Current Regulator No. 9,0.0, mA
ENG101413,Calibration Identification,4N0158AN10012 ,
ENG99697,Calibration Verification Number,9B 96 C8 C7,
ENG36558-ENG36666,Clutch_overheating_information-Clutch,none,
ENG36558-ENG98971,Clutch_overheating_information-Temperature,0, °C
ENG101834,Current N215 Pressure control valve 1,850.0, mA
ENG99930,Current N216 pressure reg.valve 2,50.0, mA
ENG102208,Current N217 pressure reg.valve 3,850.0, mA
ENG100408,Current N218 pressure reg.valve 4,318.2, mA
ENG101543,Current N233 pressure reg.valve 5,50.0, mA
ENG101463,Current N371 pressure reg. valve 6 lock-up clutch,50.0, mA
ENG101716,Current N443 pressure reg.valve 7 main pressure,652.9, mA
ENG102805,Current solenoid,0.0, mA
ENG07413,Desired_Torque_Filtered,0, Nm
ENG07412,Desired_Torque_Raw,0, Nm
ENG07416,Dynamic_Torque_Limitation,238, Nm
ENG07430-ENG125631,E Status OUT0-Break,No,
ENG07430-ENG07550,E Status OUT0-communication fault,No,
ENG07430-ENG07552,E Status OUT0-current too high,No,
ENG07430-ENG121961,E Status OUT0-Current too low,No,
ENG07430-ENG108945,E Status OUT0-short to battery,No,
ENG07430-ENG108946,E Status OUT0-short to ground,No,
ENG07430-ENG07551,E Status OUT0-wrong communication,No,
ENG07431-ENG125631,E Status OUT1-Break,No,
ENG07431-ENG07550,E Status OUT1-communication fault,No,
ENG07431-ENG07552,E Status OUT1-current too high,No,
ENG07431-ENG121961,E Status OUT1-Current too low,No,
ENG07431-ENG108945,E Status OUT1-short to battery,No,
ENG07431-ENG108946,E Status OUT1-short to ground,No,
ENG07431-ENG07551,E Status OUT1-wrong communication,No,
ENG07438-ENG125631,E Status OUT10-Break,Yes,
ENG07438-ENG07550,E Status OUT10-communication fault,No,
ENG07438-ENG07552,E Status OUT10-current too high,No,
ENG07438-ENG121961,E Status OUT10-Current too low,No,
ENG07438-ENG108945,E Status OUT10-short to battery,No,
ENG07438-ENG108946,E Status OUT10-short to ground,No,
ENG07438-ENG07551,E Status OUT10-wrong communication,No,
ENG07439-ENG125631,E Status OUT11-Break,No,
ENG07439-ENG07550,E Status OUT11-communication fault,No,
ENG07439-ENG07552,E Status OUT11-current too high,No,
ENG07439-ENG121961,E Status OUT11-Current too low,No,
ENG07439-ENG108945,E Status OUT11-short to battery,No,
ENG07439-ENG108946,E Status OUT11-short to ground,No,
ENG07439-ENG07551,E Status OUT11-wrong communication,No,
ENG07440-ENG125631,E Status OUT12-Break,No,
ENG07440-ENG07550,E Status OUT12-communication fault,No,
ENG07440-ENG07552,E Status OUT12-current too high,No,
ENG07440-ENG121961,E Status OUT12-Current too low,No,
ENG07440-ENG108945,E Status OUT12-short to battery,No,
ENG07440-ENG108946,E Status OUT12-short to ground,No,
ENG07440-ENG07551,E Status OUT12-wrong communication,No,
ENG07441-ENG125631,E Status OUT13-Break,No,
ENG07441-ENG07550,E Status OUT13-communication fault,No,
ENG07441-ENG07552,E Status OUT13-current too high,No,
ENG07441-ENG121961,E Status OUT13-Current too low,No,
ENG07441-ENG108945,E Status OUT13-short to battery,No,
ENG07441-ENG108946,E Status OUT13-short to ground,No,
ENG07441-ENG07551,E Status OUT13-wrong communication,No,
ENG07442-ENG125631,E Status OUT14-Break,No,
ENG07442-ENG07550,E Status OUT14-communication fault,No,
ENG07442-ENG07552,E Status OUT14-current too high,No,
ENG07442-ENG121961,E Status OUT14-Current too low,No,
ENG07442-ENG108945,E Status OUT14-short to battery,No,
ENG07442-ENG108946,E Status OUT14-short to ground,No,
ENG07442-ENG07551,E Status OUT14-wrong communication,No,
ENG07432-ENG125631,E Status OUT2-Break,No,
ENG07432-ENG07550,E Status OUT2-communication fault,No,
ENG07432-ENG07552,E Status OUT2-current too high,No,
ENG07432-ENG121961,E Status OUT2-Current too low,No,
ENG07432-ENG108945,E Status OUT2-short to battery,No,
ENG07432-ENG108946,E Status OUT2-short to ground,No,
ENG07432-ENG07551,E Status OUT2-wrong communication,No,
ENG07433-ENG125631,E Status OUT3-Break,No,
ENG07433-ENG07550,E Status OUT3-communication fault,No,
ENG07433-ENG07552,E Status OUT3-current too high,No,
ENG07433-ENG121961,E Status OUT3-Current too low,No,
ENG07433-ENG108945,E Status OUT3-short to battery,No,
ENG07433-ENG108946,E Status OUT3-short to ground,No,
ENG07433-ENG07551,E Status OUT3-wrong communication,No,
ENG07434-ENG125631,E Status OUT4-Break,No,
ENG07434-ENG07550,E Status OUT4-communication fault,No,
ENG07434-ENG07552,E Status OUT4-current too high,No,
ENG07434-ENG121961,E Status OUT4-Current too low,No,
ENG07434-ENG108945,E Status OUT4-short to battery,No,
ENG07434-ENG108946,E Status OUT4-short to ground,No,
ENG07434-ENG07551,E Status OUT4-wrong communication,No,
ENG07435-ENG125631,E Status OUT5-Break,No,
ENG07435-ENG07550,E Status OUT5-communication fault,No,
ENG07435-ENG07552,E Status OUT5-current too high,No,
ENG07435-ENG121961,E Status OUT5-Current too low,No,
ENG07435-ENG108945,E Status OUT5-short to battery,No,
ENG07435-ENG108946,E Status OUT5-short to ground,No,
ENG07435-ENG07551,E Status OUT5-wrong communication,No,
ENG07436-ENG125631,E Status OUT6-Break,No,
ENG07436-ENG07550,E Status OUT6-communication fault,No,
ENG07436-ENG07552,E Status OUT6-current too high,No,
ENG07436-ENG121961,E Status OUT6-Current too low,No,
ENG07436-ENG108945,E Status OUT6-short to battery,No,
ENG07436-ENG108946,E Status OUT6-short to ground,No,
ENG07436-ENG07551,E Status OUT6-wrong communication,No,
ENG07437-ENG125631,E Status OUT7-Break,No,
ENG07437-ENG07550,E Status OUT7-communication fault,No,
ENG07437-ENG07552,E Status OUT7-current too high,No,
ENG07437-ENG121961,E Status OUT7-Current too low,No,
ENG07437-ENG108945,E Status OUT7-short to battery,No,
ENG07437-ENG108946,E Status OUT7-short to ground,No,
ENG07437-ENG07551,E Status OUT7-wrong communication,No,
ENG07443-ENG07554,E Status UDRMV-Open Pin (Direct Fault Entry),No,
ENG07443-ENG07553,E Status UDRMV-plausi,No,
ENG07443-ENG108945,E Status UDRMV-short to battery,No,
ENG07443-ENG07556,E Status UDRMV-short to battery (Direct Fault Entry),No,
ENG07443-ENG108946,E Status UDRMV-short to ground,No,
ENG07443-ENG07555,E Status UDRMV-short to ground (Direct Fault Entry),No,
ENG125929,ECU_R,48 61 74 74 6F 72 69 00 42 6F 73 63 68 2E 54 43 5F 31 30 37 5F 30 30 30 31 2E 53 77 69 74 63 68 4F 76 65 72 2E 54 43 55 32 2E 56 30 30 31 00 41 50 50 4C 00 0C 20 06 24 06 58 00 20 17 23 03 86 93 01 00,
ENG125930,ECU_ST,01 00,
ENG100152-ENG104003,ECUNAME-ECU,TCM,
ENG100152,ECUNAME,TransmisCtrl,
ENG07457,E-Status CCHIP 1,00,
ENG07458,E-Status CCHIP 2,00,
ENG07456,E-Status CGT,00,
ENG07455,E-Status USENS,00,
ENG07408,F007_Inexact Torque Values Over Bus,OK,
ENG102638,F012_State_TCM_Torque_Engagement,no requirement,
ENG103123,F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
ENG106470,F015_TCM_Drag_Torque,2, Nm
ENG106472,F016_TCM_Torque_Gradient_Limitation,2550, Nm/s
ENG106562,Fixed WH-Position by Errormemory Entry,Automat-Gasse (X),
ENG07414,Friction_Torque,64, Nm
ENG26895,Hold_management_parking_lock_engagement_counter,0,
ENG106956,Immobilizer Snapshot 1,00 00 00 00 00 00,
ENG106957,Immobilizer Snapshot 2,00 00 00 00 00 00,
ENG26899-ENG30226,Intelligent Park Assist-00: Waehlhebel_04 WH_Sensorpos_roh != {X: M: Init: Fehler},No,
ENG26899-ENG30227,Intelligent Park Assist-01: P Taste betätigt,No,
ENG26899-ENG30228,Intelligent Park Assist-02: Tip paddles betätigt,No,
ENG26899-ENG39154,Intelligent Park Assist-03: IPA angelernt,Yes,
ENG26899-ENG30229,Intelligent Park Assist-04: Fahrbereitschaft vorhanden,Yes,
ENG26899-ENG30230,Intelligent Park Assist-05: GSG verfügbar,Yes,
ENG26899-ENG30231,Intelligent Park Assist-06: Parksperre ist richtig eingelegt,Yes,
ENG26899-ENG30232,Intelligent Park Assist-07: Geschwindigkeit < p_v_IPA_PP_Fzg_Stillstand,Yes,
ENG26899-ENG30233,Intelligent Park Assist-08: Geschwindigkeit < p_v_IPA_PP_MA_vmax_Eingriffe_Aktoren,Yes,
ENG26899-ENG30234,Intelligent Park Assist-09: Geschwindigkeit < p_v_IPA_PP_Fahrstufenwechsel,Yes,
ENG26899-ENG30235,Intelligent Park Assist-10: Geschwindigkeit ist intern gebildet,No,
ENG26899-ENG30236,Intelligent Park Assist-11: Geschwindigkeit ist konstanter Ersatzwert,No,
ENG26899-ENG30237,Intelligent Park Assist-14: IPA-relevanter Fehler im GSG vorhanden,No,
ENG26899-ENG30238,Intelligent Park Assist-16: IPA_01 Timeout vorhanden,No,
ENG26899-ENG30239,Intelligent Park Assist-17: IPA_01 BZ oder CRC Fehler vorhanden,No,
ENG26899-ENG30240,Intelligent Park Assist-19: Klemme 15 EIN,Yes,
ENG26899-ENG39155,Intelligent Park Assist-31: SWI_IPA_Verbaut != 0,Yes,
ENG26899-ENG31586,Intelligent Park Assist-GE_Status_GE_IPA,1,
ENG26899-ENG31876,Intelligent Park Assist-IPA_Fahrstufenwunsch,1,
ENG26899-ENG31878,Intelligent Park Assist-IPA_Status_IPA_GE,0,
ENG26899-ENG09848,Intelligent Park Assist-Value,2417492984,
ENG107149,K004_Adaptive Mode,0,
ENG107153,K005_ID Of Current Driving Program,0,
ENG107154,K006_Current Type Of Driver Counter,0,
ENG107156,K007_ID Of the Active Up-shift Prevention,00 00,
ENG107158,K008_ID Of The Active Down-shift Prevention,00 00,
ENG107331-ENG101735,L001_Engine Coding Information-Emission Type,no EOBD: OBD (US),
ENG107331-ENG98541,L001_Engine Coding Information-Engine code,216,
ENG107331-ENG98980,L001_Engine Coding Information-Transmission code,AL552,
ENG106453,Losses lock-up clutch,2, Nm
ENG07407-ENG07538,M001_Reception State Bus Messages-State Anhaenger,not received,
ENG07407-ENG07539,M001_Reception State Bus Messages-State Charisma,received,
ENG07407-ENG07531,M001_Reception State Bus Messages-State Deashboard,received,
ENG07407-ENG07535,M001_Reception State Bus Messages-State ECM,received,
ENG07407-ENG07544,M001_Reception State Bus Messages-State Elektronische Schaltbetätigung,received,
ENG07407-ENG07534,M001_Reception State Bus Messages-State ESP,received,
ENG07407-ENG07530,M001_Reception State Bus Messages-State Gateway,received,
ENG07407-ENG07545,M001_Reception State Bus Messages-State IPA,received,
ENG07407-ENG07540,M001_Reception State Bus Messages-State Klemmestatus,received,
ENG07407-ENG07541,M001_Reception State Bus Messages-State Klima,received,
ENG07407-ENG07536,M001_Reception State Bus Messages-State OBD,received,
ENG07407-ENG07529,M001_Reception State Bus Messages-State Parking Brake,received,
ENG07407-ENG07542,M001_Reception State Bus Messages-State Sara,received,
ENG07407-ENG07533,M001_Reception State Bus Messages-State Steering Angle,received,
ENG07407-ENG07532,M001_Reception State Bus Messages-State Steering Assist,received,
ENG07407-ENG07543,M001_Reception State Bus Messages-State Systeminfo,not received,
ENG07407-ENG07537,M001_Reception State Bus Messages-State TSK,received,
ENG102568-ENG102114,M010_Signal State (TCM)-State ATF Temperature Sensor,OK,
ENG102568-ENG100649,M010_Signal State (TCM)-State Chip Temperature Sensor,OK,
ENG102568-ENG99717,M010_Signal State (TCM)-State Output Shaft Speed,OK,
ENG102568-ENG101699,M010_Signal State (TCM)-State Plausibility Tolerance,wide,
ENG102568-ENG100193,M010_Signal State (TCM)-State Position Switch,OK,
ENG102568-ENG102844,M010_Signal State (TCM)-State Turbin Speed,OK,
ENG102679-ENG103922,M011_Signal State Sig1 (ECU)-State Engine Speed,OK,
ENG102679-ENG101631,M011_Signal State Sig1 (ECU)-State Pedal,OK,
ENG102679-ENG100953,M011_Signal State Sig1 (ECU)-State Torque 1,OK,
ENG07409-ENG104115,M012_Signal State (Brake/Direction)-State Brake Signal,OK,
ENG07409-ENG103681,M012_Signal State (Brake/Direction)-State Driving Direction,OK,
ENG07409-ENG100622,M012_Signal State (Brake/Direction)-State Wheel Speed Front Left,OK,
ENG07409-ENG103645,M012_Signal State (Brake/Direction)-State Wheel Speed Front Right,OK,
ENG07409-ENG103415,M012_Signal State (Brake/Direction)-State Wheel Speed Rear Left,OK,
ENG07409-ENG100555,M012_Signal State (Brake/Direction)-State Wheel Speed Rear Right,OK,
ENG99597-ENG102101,M013_Switch-PIN In0,low,
ENG99597-ENG100393,M013_Switch-PIN In1,low,
ENG99597-ENG101177,M013_Switch-PIN In2,low,
ENG99597-ENG103794,M013_Switch-PIN In3,low,
ENG99597-ENG99856,M013_Switch-PIN KL15,high,
ENG102357,M014_Time Since Shift,7650, ms
ENG103371,M015_Time Normal Mode,409, s
ENG107503,M016_Faultcode + Faulttype Error Memory,00 00 00 00,
ENG107504,M017_Faultcode + Faulttype Backup Memory,00 26 00 00,
ENG100237,M018_Time In Afterrun,0, s
ENG104072,M019_Time Since Reset,7650, ms
ENG102788-MAS00106,M020_Time Stamp-Year,2020,
ENG102788-MAS00107,M020_Time Stamp-Month,10,
ENG102788-MAS00108,M020_Time Stamp-Day,15,
ENG102788-MAS00109,M020_Time Stamp-Hours,12,
ENG102788-MAS00110,M020_Time Stamp-Minutes,25,
ENG102788-MAS00111,M020_Time Stamp-Seconds,0,
ENG103130-MAS00711,M021_KM Mileage-Odometer reading,74, km
ENG106726,Maximum chip temperature,104, °C
ENG107851,Number WH-Resets for Permanen-Reset over Livetime,0,
ENG107852,Number WH-Resets to Permanent-Reset in Driving Cycle,0,
ENG107853,Number WH-Resets to Permanent-Reset over Livetime,0,
ENG27076,Preadaption_counter,0,
ENG38971-ENG26202,Programming history-Operating time,0, H
ENG38971-ENG39133,Programming history-Software,,
ENG108362-ENG102813,Q001_OBD Cycle And MIL State-Driving Cycle,active,
ENG108362-ENG98734,Q001_OBD Cycle And MIL State-mil,not active,
ENG108362-ENG99968,Q001_OBD Cycle And MIL State-WarmUp Cycle,not active,
ENG07417,Reserve_Torque,0, Nm
ENG07411,Sensors Supply Voltage,8.96, V
ENG109074,State GE_Test_Freigabe Bit,1,
ENG109075,State GE_WH_Abschalten Bit,0,
ENG109076,State GE_WH_Initialisierung Bit,0,
ENG109077,State GE_WH_Sperre Bit,0,
ENG109083,State WH_Test_Aktiv Bit,1,
ENG07415,Static_Torque_Limitation,786, Nm
ENG103216-ENG102053,Status electric parking lock holder solenoid-Desired State Solenoid Out 10,OFF,
ENG103216-ENG104161,Status electric parking lock holder solenoid-Desired State Solenoid Out 11,OFF,
ENG103216-ENG99231,Status electric parking lock holder solenoid-Desired State Solenoid Out 12,OFF,
ENG103216-ENG99490,Status electric parking lock holder solenoid-Desired State Solenoid Out 13,On,
ENG103216-ENG100651,Status electric parking lock holder solenoid-Desired State Solenoid Out 14,OFF,
ENG07418,Status_Reserve_Torque,not active,
ENG107872,System Supplier Boot Software Identification (BB),b97d0301,
ENG107872-ENG100456,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (BC),bgjb1902,
ENG107872-ENG113110,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (SB),bh1i0201,
ENG107872-ENG07548,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (SBS),911C0401,
ENG107872-ENG100638,System Supplier Boot Software Identification (BB)-System Supplier ECU Identification,103442028301,
ENG107872-ENG101391,System Supplier Boot Software Identification (BB)-System Supplier HW Identification,production,
ENG107872-ENG101224,System Supplier Boot Software Identification (BB)-System Supplier HW Version,19,
ENG107872-ENG103844,System Supplier Boot Software Identification (BB)-System Supplier Manufacturer Number,0256,
ENG107872-ENG99833,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 1,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG107872-ENG101511,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 2,g@,
ENG107872-ENG100387,System Supplier Boot Software Identification (BB)-System Supplier Production Date,17.07.20,
ENG107872-ENG103393,System Supplier Boot Software Identification (BB)-System Supplier Production Identification,ZFS-005,
ENG107872-ENG99218,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Gearbox,1573639,
ENG107872-ENG101400,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Mechatronics,0127473,
ENG107872-ENG102956,System Supplier Boot Software Identification (BB)-System Supplier Software Version,1001,
ENG107872-ENG100713,System Supplier Boot Software Identification (BB)-System Supplier SW Checksum,F8 31 2D F4 6A 25 DE 5D,
ENG107872-ENG100221,System Supplier Boot Software Identification (BB)-System Supplier SW Identification,4N0ANAN16F1001,
ENG107872-ENG103167,System Supplier Boot Software Identification (BB)-System Supplier Test Stand Number,5111,
ENG27201-ENG36133,Torque_Converter_temperature_range-Range,0, min
ENG27201-ENG36131,Torque_Converter_temperature_range-Range 1,86, min
ENG27201-ENG36132,Torque_Converter_temperature_range-Range 2,31, min
ENG27201-ENG36137,Torque_Converter_temperature_range-Range 4,0, min
ENG27201-ENG36138,Torque_Converter_temperature_range-Range 5,0, min
ENG27201-ENG36139,Torque_Converter_temperature_range-Range 6,0, min
ENG27201-ENG36140,Torque_Converter_temperature_range-Range 7,0, min
ENG27201-ENG36141,Torque_Converter_temperature_range-Range 8,0, min
ENG105259,Transfer speed from ESP,valid,
ENG105259,Transfer speed from ESP,0.00, km/h
ENG116752-ENG02033,Transmission_construction_number_from_factory-Gearbox subnumber (HSL),000000000000001104034027,
ENG116752-ENG02045,Transmission_construction_number_from_factory-Mechatronic subnumber (GSL),000000000000001104128370,
ENG07450,U-Status 1 MCCOMP,00,
ENG07444,U-Status 1 RESSUP,00 00,
ENG07447,U-Status 1 RESZF,00,
ENG07451,U-Status 2 MCCOMP,00 00 00 00,
ENG07445,U-Status 2 RESSUP,00 00 00 00,
ENG07448,U-Status 2 RESZF,00 00,
ENG07446,U-Status 3 RESSUP,00 00 00 00,
ENG07449,U-Status 3 RESZF,00 00,
ENG07453,U-Status EEPROM,00 00,
ENG07454,U-Status EPROM,00 00,
ENG07452,U-Status WDOG,00 00 00 00,
Elapsed Time: 00:44
adpmap-02-4N0-927-158-AN
;SW:4N0-927-158-AN HW:0D6-927-156-H --- Auto Trans
;Component:0D6 40TSINAR H05 1001, Coding:100000
;EV_TCMALX52011,002015,EV_TCMALX52011_VW53.rod
;Thursday,15,October,2020,12:25:06:59422
;VCDS Version: Beta 20.9.1 (x64) Data version: 20200919 DS322.0
;VCID: 0154EEE691F78BE3685-8054
IDE00001-ENG138621-Production mode-Adaption Stategy Mode,not active ,3
IDE00001-ENG98860-Production mode-Production mode,not active ,3
IDE01761-Route data,not active ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE02583-Steering wheel Tiptronic switch,active ,1
IDE04111-Individual gear display,D off/S off ,1
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
ENG125931-ECU_W,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,187
Elapsed Time: 00:03
09-Cent. Elect.
blockmap-09-4N0-907-063-JE
;SW:4N0-907-063-JE HW:4N0-907-063-AE --- Cent. Elect.
;Component:BCM1 MLBevo H10 0712, Coding:07500363C0291CDD070E57A81CEF9C2A131BB7511406049381050A00020196000869020200100000000007030047081838021030C003F107000000000000000000
;EV_BCM1BOSCHAU651,017002,EV_BCM1BOSCHAU651_017.rod
;Thursday,15,October,2020,12:25:22:59422
;VCID: 7AA6990AFC21D83B29F-802E
Group,Description,Actual
IDE00025,Coolant temperature,68.00, °C
IDE00198,Refrigerant pressure,7.40, bar
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00970,Coolant fan activation: actual value,40.50, %
IDE00971,Coolant fan activation: specified value,40.50, %
IDE00972,Idle speed increase,not active,
IDE00983,Inside temperature,21.30, °C
IDE01063,Status of recirculation air,Automatic recirc. deactivated,
IDE01068,Rear blower voltage: actual value,5.40, V
IDE01069,Rear blower voltage: specified value,5.50, V
IDE01076,Time since ignition off,42, min
IDE01164-MAS06614,Parking aid button-Variant,Local data bus: operating unit 2,
IDE01164-MAS07693,Parking aid button-Button Status,Not operated,
IDE01164-MAS07694,Parking aid button-Button status on CAN,Not operated,
IDE01164-MAS07699,Parking aid button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Parking aid button-Indicator lamp activation,OFF,
IDE01227,Blower current,2.00, A
IDE01229,Blower current of rear fresh air blower,1.25, A
IDE01230,Control module for rear fresh air blower: temperature,25, °C
IDE01241,Position sensor in left side vent: voltage,not coded/not installed,
IDE01243,Position sensor in right side vent: voltage,not coded/not installed,
IDE01245,Position sensor in left center vent: voltage,not coded/not installed,
IDE01247,Position sensor in right center vent: voltage,not coded/not installed,
IDE01249,Left rear upper body vent position sensor: voltage,not coded/not installed,
IDE01251,Right rear upper body vent position sensor: voltage,not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,not coded/not installed,
IDE01266-MAS07806,Coolant shut-off valve-Specified status,not coded/not installed,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),not coded/not installed,
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,0,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,Not available,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,valid,
IDE01287,Counter of compressor switch-offs,0,
IDE01309,Recirculation air flap motor: actual value,11066,
IDE01311,Left side vent flap motor: actual value,11481,
IDE01312,Right side vent flap motor: actual value,10000,
IDE01313,Left footwell flap motor: actual value,10000,
IDE01314,Right footwell flap motor: actual value,10000,
IDE01315,Left center vent flap motor: actual value,11006,
IDE01316,Right center vent flap motor: actual value,10667,
IDE01319,Rear temperature flap motor: actual value,10000,
IDE01320,Rear air volume flap motor: actual value,10315,
IDE01321,Defrost flap motor for left side window: actual value,11039,
IDE01322,Defrost flap motor for right side window: actual value,11255,
IDE01323,Left rear upper body vent motor: actual value,11163,
IDE01324,Right rear upper body vent motor: actual value,11082,
IDE01325,Left B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01326,Right B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,Move flap motor,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating condition,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,blockage,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01332-IDE09056,Left footwell flap motor: diagnostic-Last operating state,blockage,
IDE01332-MAS01458,Left footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01333-IDE09056,Right footwell flap motor: diagnostic-Last operating state,blockage,
IDE01333-MAS01458,Right footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01334-IDE09056,Left center vent flap motor: diagnostic-Last operating state,blockage,
IDE01334-MAS01458,Left center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01335-IDE09056,Right center vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01335-MAS01458,Right center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01338-IDE09056,Rear temperature flap motor: diagnosis-Last operating state,blockage,
IDE01338-MAS01458,Rear temperature flap motor: diagnosis-Operating condition,No routine started,
IDE01339-IDE09056,Rear air volume flap motor: diagnosis-Last operating state,Move flap motor,
IDE01339-MAS01458,Rear air volume flap motor: diagnosis-Operating condition,No routine started,
IDE01340-IDE09056,Defrost flap motor for left side window: diagnostic-Last operating state,blockage,
IDE01340-MAS01458,Defrost flap motor for left side window: diagnostic-Operating condition,No routine started,
IDE01341-IDE09056,Defrost flap motor for right side window: diagnostic-Last operating state,blockage,
IDE01341-MAS01458,Defrost flap motor for right side window: diagnostic-Operating condition,No routine started,
IDE01342-IDE09056,Left rear upper body vent motor: diagnostic-Last operating state,Move flap motor,
IDE01342-MAS01458,Left rear upper body vent motor: diagnostic-Operating condition,No routine started,
IDE01343-IDE09056,Right rear upper body vent motor: diagnostic-Last operating state,Move flap motor,
IDE01343-MAS01458,Right rear upper body vent motor: diagnostic-Operating condition,No routine started,
IDE01344-IDE09056,Left B-pillar shut-off flap motor: diagnostic-Last operating state,blockage,
IDE01344-MAS01458,Left B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01345-IDE09056,Right B-pillar shut-off flap motor: diagnostic-Last operating state,blockage,
IDE01345-MAS01458,Right B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01352,Temperature unit,°F,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Compressor active: no shut-off condition is present,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor active: no shut-off condition is present,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10270,
IDE01427,Right temperature flap motor: actual value,10000,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,blockage,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating condition,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,Move flap motor,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,blockage,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01433,Air quality status,Clean air,
IDE01455,Key number,1,
IDE01488-MAS01458,Auxiliary heating retrofit without CAN-Operating condition,not coded/not installed,
IDE01488-MAS05773,Auxiliary heating retrofit without CAN-Voltage of signal line,not coded/not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,not coded/not installed,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,20.30, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,20.00, °C
IDE01540-MAS07052,Left front heated seat-Setting,Not available,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,10.25, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,10.13, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Not available,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.04, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,not coded/not installed,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,19.70, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,19.70, °C
IDE01541-MAS07052,Right front heated seat-Setting,Not available,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,10.35, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,10.36, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Not available,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.01, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-IDE01270,Auxiliary Air Heater-Enabling for auxiliary heater operation,not coded/not installed,
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07913,Auxiliary Air Heater-Heating stage: current value,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01622,Fresh air blower: speed,1700, /min
IDE01687,Rear recirculation flap motor: actual value,10848,
IDE01688-IDE09056,Rear recirculation flap motor: diagnostic-Last operating state,Move flap motor,
IDE01688-MAS01458,Rear recirculation flap motor: diagnostic-Operating condition,No routine started,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Variant,Local data bus: operating unit 2,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,Not operated,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Not operated,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator lamp activation,OFF,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,EE 40 74 0E,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,can be reached,
IDE01992-SFT00041,Installation list: current installations-Left light control,can be reached,
IDE01992-SFT00057,Installation list: current installations-Right light control,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01992-SFT00216,Installation list: current installations-Projection module in left matrix headlamp,not attainable,
IDE01992-SFT00217,Installation list: current installations-Projection module in right matrix headlamp,not attainable,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,not attainable,
IDE01993-SFT00009,Control module reference number-Electronic central electric,Electronic central electric,
IDE01993-SFT00041,Control module reference number-Left light control,Left light control,
IDE01993-SFT00057,Control module reference number-Right light control,Right light control,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01993-SFT00216,Control module reference number-Projection module in left matrix headlamp,Projection module in left matrix headlamp,
IDE01993-SFT00217,Control module reference number-Projection module in right matrix headlamp,Projection module in right matrix headlamp,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,Central control for digital matrix light,
IDE01995-SFT00009,Control module protocol information-Electronic central electric,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Left light control,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Right light control,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE01995-SFT00216,Control module protocol information-Projection module in left matrix headlamp,ISO-TP,
IDE01995-SFT00217,Control module protocol information-Projection module in right matrix headlamp,ISO-TP,
IDE01995-SFT33232,Control module protocol information-Central control for digital matrix light,ISO-TP,
IDE02384-SFT00009,Status of event memory-Electronic central electric,OK,
IDE02384-SFT00041,Status of event memory-Left light control,OK,
IDE02384-SFT00057,Status of event memory-Right light control,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02384-SFT00216,Status of event memory-Projection module in left matrix headlamp,OK,
IDE02384-SFT00217,Status of event memory-Projection module in right matrix headlamp,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02433,Left rear temperature flap motor: actual value,10000,
IDE02434-IDE09056,Left rear temperature flap motor: diagnostic-Last operating state,blockage,
IDE02434-MAS01458,Left rear temperature flap motor: diagnostic-Operating condition,No routine started,
IDE02436,Right rear temperature flap motor: actual value,10000,
IDE02437-IDE09056,Right rear temperature flap motor: diagnostic-Last operating state,blockage,
IDE02437-MAS01458,Right rear temperature flap motor: diagnostic-Operating condition,No routine started,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE02711-MAS09598,Rear wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear wiper-Error status via CAN,No error: no wiper activation,
IDE02834,Fresh air flap motor: actual value,10406,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,Move flap motor,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating condition,No routine started,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01957,Stop process prevented-Outside temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS03902,Stop process prevented-Adaptation A/C comfort stop activation,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,1,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,1,
IDE03010-MAS01957,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,180,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,378,
IDE03010-MAS03902,Number of prevented stop processes-Adaptation A/C comfort stop activation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),10,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),20,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,16,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01957,Number of requested start processes-Outside temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,1,
IDE03011-MAS03902,Number of requested start processes-Adaptation A/C comfort stop activation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03111-MAS06885,Interior lighting-Terminal 30 for interior lighting,95, %
IDE03111-MAS06886,Interior lighting-Dimming for interior lighting,0, %
IDE03111-MAS06986,Interior lighting-Footwell illumination rear,24, %
IDE03111-MAS06987,Interior lighting-Footwell illumination front,95, %
IDE03111-MAS09295,Interior lighting-Ambient lighting channel 1,not coded/not installed,
IDE03111-MAS09297,Interior lighting-Ambient illumination power supply,100, %
IDE03111-MAS12622,Interior lighting-Terminal 30 for interior lighting: current draw (effect. value),1, mA
IDE03111-MAS12623,Interior lighting-Foot well illumination: rear: current draw (effective value),21, mA
IDE03111-MAS12624,Interior lighting-Foot well illumination: front: current draw (effective value),40, mA
IDE03111-MAS12625,Interior lighting-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior lighting-Supply for ambient illumination: current draw (effective value),640, mA
IDE03111-MAS12627,Interior lighting-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03111-MAS12917,Interior lighting-Rear ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12918,Interior lighting-Rear ambient light.chan. 1: current drawn (effective value),not coded/not installed,
IDE03111-MAS12919,Interior lighting-Roof ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12920,Interior lighting-Roof ambient lighting channel 1: current drawn (effect. value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Left light control,Bus sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Right light control,Bus sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03150-SFT00216,Readiness for bus sleep mode-Projection module in left matrix headlamp,active,
IDE03150-SFT00217,Readiness for bus sleep mode-Projection module in right matrix headlamp,active,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,OFF,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,10800, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,Initialization,
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,On,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Bright,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,1920, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03537-MAS01482,Ionizer: status-Hardware version,3,
IDE03537-MAS01483,Ionizer: status-Software version,5,
IDE03537-MAS02829,Ionizer: status-HIGH VOLTAGE!,OFF,
IDE03537-MAS02830,Ionizer: status-Ionizer button,Not operated,
IDE03537-MAS02831,Ionizer: status-Ionizer check light,OFF,
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,No malfunction,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,No malfunction,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,Passive error: error path not traversed,
IDE03602,Left front level control system sensor,Measuring value not available,
IDE03604,Left rear level control system sensor,Measuring value not available,
IDE03620,Front jounce travel,Measuring value not available,
IDE03621,Rear jounce travel,Measuring value not available,
IDE03622,Left headlight beam adjusting motor: status,Measuring value not available,
IDE03623,Right headlight beam adjusting motor: status,Measuring value not available,
IDE03624,Left dynamic AFS light motor: specified value,Measuring value not available,
IDE03625,Right dynamic AFS light motor: specified value,Measuring value not available,
IDE03626,Left dynamic AFS light motor: status,Measuring value not available,
IDE03627,Right dynamic AFS light motor: status,Measuring value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measuring value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measuring value not available,
IDE03630,Left headlight beam adjusting motor: specified value,Measuring value not available,
IDE03631,Right headlight beam adjusting motor: specified value,Measuring value not available,
IDE03632,Left-/right hand driving switch-over,Measuring value not available,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,0.00, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,0.00, %
IDE03640,Dynamic AFS light,OFF,
IDE03662-MAS06614,ASR/ESP button-Variant,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator lamp activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Variant,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator lamp activation,not coded/not installed,
IDE03669,Status of light distribution,Measuring value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,Matrix auto. high beam is available,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,OFF,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,No malfunction,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,No malfunction,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,Not blocked,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,12.67, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,12.55, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,12.64, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,12.29, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,12.59, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,12.59, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,12.63, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,12.53, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,12.61, V
IDE03727,Variable left front lighting specified position,Measuring value not available,
IDE03728,Variable right front lighting specified position,Measuring value not available,
IDE03788,Status of basic headlamp setting,Measuring value not available,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),Measuring value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measuring value not available,
IDE04312-IDE04095,System run time-Engine running time,455, s
IDE04312-MAS00084,System run time-Terminal 15 on,457, s
IDE04343-SFT00009,Bus identification-Electronic central electric,Bus master,
IDE04343-SFT00041,Bus identification-Left light control,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Right light control,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04343-SFT00216,Bus identification-Projection module in left matrix headlamp,AFS/From light data bus,
IDE04343-SFT00217,Bus identification-Projection module in right matrix headlamp,AFS/From light data bus,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,AFS/From light data bus,
IDE04741-MAS06614,Rear window defogger button-Variant,Local data bus: operating unit 1,
IDE04741-MAS07693,Rear window defogger button-Button Status,Not operated,
IDE04741-MAS07694,Rear window defogger button-Button status on CAN,Not operated,
IDE04741-MAS07699,Rear window defogger button-Status indicator light on CAN,OFF,
IDE04741-MAS08062,Rear window defogger button-Indicator lamp activation,OFF,
IDE04806-MAS06614,Driving profile selection button-Variant,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Variant,Local data bus: operating unit 1,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator lamp activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Variant,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator lamp activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,OFF,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),0, mA
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,26.60, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,26.50, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,37.00, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,10.90, °C
IDE06091-MAS07055,Humidity sensor: interior-Response error,not active,
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,23.40, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,51.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,19.50, °C
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,10,
IDE06307-MAS00108,Stop prevention history data-Day,15,
IDE06307-MAS00109,Stop prevention history data-Hours,12,
IDE06307-MAS00110,Stop prevention history data-Minutes,18,
IDE06307-MAS00111,Stop prevention history data-Seconds,9,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Blowout temperature difference to specifications,
IDE06308-MAS00106,Start request history data-Year,2020,
IDE06308-MAS00107,Start request history data-Month,10,
IDE06308-MAS00108,Start request history data-Day,14,
IDE06308-MAS00109,Start request history data-Hours,18,
IDE06308-MAS00110,Start request history data-Minutes,28,
IDE06308-MAS00111,Start request history data-Seconds,27,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Blowout temperature difference to specifications,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Variant,not coded/not installed,
IDE06752-MAS07693,Hill descent control button-Button Status,not coded/not installed,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Initialization/not installed,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator lamp activation,not coded/not installed,
IDE06807,Fresh-air door motor / specified value,10406,
IDE06808,Fresh-air door motor / dynamics,1231,
IDE06809,Left temp. door motor / specified value,10270,
IDE06810,Left temp. door motor / dynamics,1423,
IDE06811,Right temp. door motor: specified value,10000,
IDE06812,Right temp. door motor: dynamics,1414,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1502,
IDE06815,Recirc. air flap motor: spec.value,11066,
IDE06816,Recirc. air flap motor: dynamics,1592,
IDE06817,Rear temp. door motor: specified value,10000,
IDE06818,Rear temp. door motor: dynamics,1596,
IDE06823,Left center vent motor / specified value,11006,
IDE06824,Left center vent motor / dynamics,1006,
IDE06825,Right center vent motor: specified value,10688,
IDE06826,Right center vent motor: dynamics,1027,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07133,Fresh air blower motor: temperature,22, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07246-MAS01447,Left rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07246-MAS01448,Left rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07248-MAS01447,Left rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07248-MAS01448,Left rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07250-MAS01447,Right rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07250-MAS01448,Right rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07252-MAS01447,Right rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07252-MAS01448,Right rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07253-IDE11723,Installation info: rear seat ventilation-Fan 2 for left rear seat backrest,not installed,
IDE07253-IDE11724,Installation info: rear seat ventilation-Fan 2 for left rear seat cushion,not installed,
IDE07253-IDE11725,Installation info: rear seat ventilation-Fan 2 for right rear seat backrest,not installed,
IDE07253-IDE11726,Installation info: rear seat ventilation-Fan 2 for right rear seat cushion,not installed,
IDE07337-MAS01481,Control module for windshield washer pump: temperatures-Temperature in control module,23, °C
IDE07337-MAS11110,Control module for windshield washer pump: temperatures-Outdoor wind chill factor,20, °C
IDE07338,Control module for windshield washer pump: supply voltage,12.50, V
IDE07457,Rear air volume flap motor: spec. value,10315,
IDE07458,Rear air volume flap motor: dynamics,6313,
IDE07459,Left footwell door motor / specified value,10000,
IDE07460,Left footwell door motor: dynamics,950,
IDE07461,Right footwell door motor / specified value,10000,
IDE07462,Right footwell door motor: dynamics,950,
IDE07491,Left rear temp door motor: spec. value,10000,
IDE07492,Left rear temp door motor: dynamics,700,
IDE07493,Right rear temp door motor: spec. value,10000,
IDE07494,Right rear temp door motor: dynamics,708,
IDE07495,Left rear upper body vent motor: spec. value,11163,
IDE07496,Left rear upper body vent motor: dynamics,1473,
IDE07497,Right rear upper body vent motor: spec. value,11082,
IDE07498,Right rear upper body vent motor: dynamics,1483,
IDE07499,Left side vent flap motor: spec.value,11448,
IDE07500,Left side vent flap motor: dynamics,1665,
IDE07501,Right side vent flap motor: spec. value,10000,
IDE07502,Right side vent flap motor: dynamics,1780,
IDE07503,Rear recirc. air flap motor: spec.value,10848,
IDE07504,Rear recirc. air flap motor: dynamics,1697,
IDE07505,Left B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07506,Left B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1032,
IDE07507,Right B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07508,Right B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1062,
IDE07509,Defrost flap motor for left side window: spec. value,11039,
IDE07510,Defrost flap motor for left side window: dynamics,1039,
IDE07511,Defrost flap motor for right side window: spec. value,11255,
IDE07512,Defrost flap motor for right side window: dynamics,1255,
IDE07950-IDE04095,Historical data of motors-Engine running time,0, s
IDE07950-IDE09056,Historical data of motors-Last operating state,Unknown (31),
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,0, s
IDE07950-MAS00106,Historical data of motors-Year,2020,
IDE07950-MAS00107,Historical data of motors-Month,8,
IDE07950-MAS00108,Historical data of motors-Day,1,
IDE07950-MAS00109,Historical data of motors-Hours,10,
IDE07950-MAS00110,Historical data of motors-Minutes,28,
IDE07950-MAS00111,Historical data of motors-Seconds,57,
IDE07950-MAS01458,Historical data of motors-Operating condition,Dynamic calibration,
IDE07950-MAS03118,Historical data of motors-Logic address,127,
IDE07950-MAS03180,Historical data of motors-Local data bus,12,
IDE07950,Historical data of motors,12.00, V
IDE07991-MAS01580,A/C clutch-Activation,100, %
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,2.50, A
IDE07991-MAS12621,A/C clutch-Current draw (effective value),1986, mA
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,Open circuit/short circuit not yet recognized,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,Open circuit/short circuit not yet recognized,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left head area heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left head area heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left head area heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right head area heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right head area heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right head area heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal activation-Terminal 75 status,On,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal activation-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal activation-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,8B 17 63 D9,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,22, °C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,12.70, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,21, °C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,12.60, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,22, °C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,12.70, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,20, °C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,12.60, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,0, %
IDE08364-MAS01448,Left seat backrest fan 1: activation-Target value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Target value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,0, %
IDE08368-MAS01448,Right seat backrest fan 1: activation-Target value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,0, %
IDE08370-MAS01448,Right seat cushion fan 1: activation-Target value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08372,Fresh air blower: target speed,1700, /min
IDE08376-MAS01580,Right Daytime Running Lamp and Parking Light Lamp-Activation,not coded/not installed,
IDE08376-MAS01737,Right Daytime Running Lamp and Parking Light Lamp-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right Daytime Running Lamp and Parking Light Lamp-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and position lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and position lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and position lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right Front Side Marker Light-Activation,not coded/not installed,
IDE08382-MAS01737,Right Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left Front Side Marker Light-Activation,not coded/not installed,
IDE08383-MAS01737,Left Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running light lamp-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running light lamp-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running light lamp-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running light lamp-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,No malfunction,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,No malfunction,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light lamp-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light lamp-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light lamp-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light lamp-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light lamp-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light lamp-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,No malfunction,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),12, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,No malfunction,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),6, mA
IDE08402-IDE05742,Light switch-Light switch position,Not available,
IDE08402-IDE07956,Light switch-redundant signal line,OFF,
IDE08402-MAS03866,Light switch-Head-Up-Display button,Not available,
IDE08402-MAS03868,Light switch-Position of the Eyebox,Not available,
IDE08402-MAS06887,Light switch-Light switch position on CAN,Malfunction,
IDE08402-MAS06888,Light switch-Fog light button,Not available,
IDE08402-MAS06889,Light switch-Rear fog light button,Not available,
IDE08402-MAS06890,Light switch-Night vision system button,Not available,
IDE08402-MAS06891,Light switch-Control for Eyebox position,Not available,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.18, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,21.50, °C
IDE08408,Hood contact,closed,
IDE08408-MAS14040,Hood contact-Voltage ratio,98, %
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,OFF,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,44, %
IDE08502-MAS09777,A/C compressor regulator valve-Target current,412, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),415, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measuring value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,Measuring value not available,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measuring value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measuring value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,00,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,Programming not performed,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,FF,
IDE08543-MAS04184,Garage door opener: last programming-Canceled by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Programming not performed,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,00000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,00,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,Programming not performed,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,FF,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Canceled by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Programming not performed,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,00000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,00,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,Programming not performed,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Canceled by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Programming not performed,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,00000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,12.70, V
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08795-MAS06614,Rear shade button-Variant,not coded/not installed,
IDE08795-MAS07693,Rear shade button-Button Status,not coded/not installed,
IDE08795-MAS07694,Rear shade button-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,Not moving,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,was not local active,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,1261,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,945,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,Not operated,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,Not operated,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,Not operated,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,Not operated,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,Not operated,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),0.00, A
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),0.00, A
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,12.63, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,31.20, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,46.08, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),120, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,operational,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control unit 2 for driving and convenience functions,operational,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Variant,Discreet wire,
IDE08979-MAS07693,Valet parking lock button-Button Status,Not operated,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator lamp activation,OFF,
IDE08980-MAS06614,Button for rear spoiler adjustment-Variant,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator lamp activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Variant,not coded/not installed,
IDE08981-MAS07693,Front display open/close button-Button Status,not coded/not installed,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Initialization/not installed,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Variant,not coded/not installed,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,not coded/not installed,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator lamp activation,not coded/not installed,
IDE08983-MAS06614,Driving profile selection button 2-Variant,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,No malfunction,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),350, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,No malfunction,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),165, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special vehicle control module-Variant,not coded/not installed,
IDE09920-MAS06992,Special vehicle control module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special vehicle control module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special vehicle control module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special vehicle control module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special vehicle control module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special vehicle control module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special vehicle control module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special vehicle control module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special vehicle control module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special vehicle control module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special vehicle control module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special vehicle control module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special vehicle control module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special vehicle control module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special vehicle control module-Suppression of interior illumination request,not coded/not installed,
IDE09922-MAS01448,Static headlamp range control-Target value,not coded/not installed,
IDE09922-MAS09527,Static headlamp range control-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlamp range control-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlamp range control-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlamp range control-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Automatic dimming interior mirror-Button Status,Not operated,
IDE09955-MAS09651,Automatic dimming interior mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Automatic dimming interior mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Automatic dimming interior mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,55, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,159,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,Not available,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,55.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,No malfunction,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,55.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,No malfunction,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),Not available,
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),Not available,
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),not coded/not installed,
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,50, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,55, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),23, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),72, mA
IDE10124-MAS07052,Front left seat heating-Setting,OFF,
IDE10124-MAS07921,Front left seat heating-Balance setting,Neutral,
IDE10124-MAS07951,Front left seat heating-Automatic down-shift,not active,
IDE10124-MAS15417,Front left seat heating-Area heating adjustment,OFF,
IDE10125-MAS07052,Front right seat heating-Setting,OFF,
IDE10125-MAS07921,Front right seat heating-Balance setting,Neutral,
IDE10125-MAS07951,Front right seat heating-Automatic down-shift,not active,
IDE10125-MAS15417,Front right seat heating-Area heating adjustment,OFF,
IDE10126-MAS07052,Rear left seat heating-Setting,OFF,
IDE10126-MAS07921,Rear left seat heating-Balance setting,Neutral,
IDE10126-MAS07951,Rear left seat heating-Automatic down-shift,not active,
IDE10126-MAS15417,Rear left seat heating-Area heating adjustment,OFF,
IDE10127-MAS07052,Rear right seat heating-Setting,OFF,
IDE10127-MAS07921,Rear right seat heating-Balance setting,Neutral,
IDE10127-MAS07951,Rear right seat heating-Automatic down-shift,not active,
IDE10127-MAS15417,Rear right seat heating-Area heating adjustment,OFF,
IDE10128-MAS01632,Front left seat cushion heating-Status,not active,
IDE10128-MAS05945,Front left seat cushion heating-Target temperature,OFF,
IDE10128-MAS05946,Front left seat cushion heating-Actual temp.,19.00, °C
IDE10128-MAS07929,Front left seat cushion heating-Power quota setting by energy management,0,
IDE10128-MAS12066,Front left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10128-MAS14067,Front left seat cushion heating-Actuation specified value,0, %
IDE10129-MAS01632,Seat backrest heater: left front-Status,not active,
IDE10129-MAS05945,Seat backrest heater: left front-Target temperature,OFF,
IDE10129-MAS05946,Seat backrest heater: left front-Actual temp.,20.00, °C
IDE10129-MAS07929,Seat backrest heater: left front-Power quota setting by energy management,0,
IDE10129-MAS12066,Seat backrest heater: left front-Cancellation status,Heating process interrupted,
IDE10129-MAS14067,Seat backrest heater: left front-Actuation specified value,0, %
IDE10130-MAS01632,Front right seat cushion heating-Status,not active,
IDE10130-MAS05945,Front right seat cushion heating-Target temperature,OFF,
IDE10130-MAS05946,Front right seat cushion heating-Actual temp.,19.00, °C
IDE10130-MAS07929,Front right seat cushion heating-Power quota setting by energy management,0,
IDE10130-MAS12066,Front right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10130-MAS14067,Front right seat cushion heating-Actuation specified value,0, %
IDE10131-MAS01632,Seat backrest heater: right front-Status,not active,
IDE10131-MAS05945,Seat backrest heater: right front-Target temperature,OFF,
IDE10131-MAS05946,Seat backrest heater: right front-Actual temp.,19.00, °C
IDE10131-MAS07929,Seat backrest heater: right front-Power quota setting by energy management,0,
IDE10131-MAS12066,Seat backrest heater: right front-Cancellation status,Heating process interrupted,
IDE10131-MAS14067,Seat backrest heater: right front-Actuation specified value,0, %
IDE10132-MAS01632,Rear left seat cushion heating-Status,not active,
IDE10132-MAS05945,Rear left seat cushion heating-Target temperature,OFF,
IDE10132-MAS05946,Rear left seat cushion heating-Actual temp.,22.00, °C
IDE10132-MAS07929,Rear left seat cushion heating-Power quota setting by energy management,0,
IDE10132-MAS12066,Rear left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10132-MAS14067,Rear left seat cushion heating-Actuation specified value,0, %
IDE10133-MAS01632,Seat backrest heater: left rear-Status,not active,
IDE10133-MAS05945,Seat backrest heater: left rear-Target temperature,OFF,
IDE10133-MAS05946,Seat backrest heater: left rear-Actual temp.,22.00, °C
IDE10133-MAS07929,Seat backrest heater: left rear-Power quota setting by energy management,0,
IDE10133-MAS12066,Seat backrest heater: left rear-Cancellation status,Heating process interrupted,
IDE10133-MAS14067,Seat backrest heater: left rear-Actuation specified value,0, %
IDE10134-MAS01632,Rear right seat cushion heating-Status,not active,
IDE10134-MAS05945,Rear right seat cushion heating-Target temperature,OFF,
IDE10134-MAS05946,Rear right seat cushion heating-Actual temp.,21.00, °C
IDE10134-MAS07929,Rear right seat cushion heating-Power quota setting by energy management,0,
IDE10134-MAS12066,Rear right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10134-MAS14067,Rear right seat cushion heating-Actuation specified value,0, %
IDE10135-MAS01632,Seat backrest heater: right rear-Status,not active,
IDE10135-MAS05945,Seat backrest heater: right rear-Target temperature,OFF,
IDE10135-MAS05946,Seat backrest heater: right rear-Actual temp.,22.00, °C
IDE10135-MAS07929,Seat backrest heater: right rear-Power quota setting by energy management,0,
IDE10135-MAS12066,Seat backrest heater: right rear-Cancellation status,Heating process interrupted,
IDE10135-MAS14067,Seat backrest heater: right rear-Actuation specified value,0, %
IDE10136-MAS01632,Front left door area heating-Status,not coded/not installed,
IDE10136-MAS05945,Front left door area heating-Target temperature,not coded/not installed,
IDE10136-MAS05946,Front left door area heating-Actual temp.,not coded/not installed,
IDE10136-MAS07929,Front left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10136-MAS12066,Front left door area heating-Cancellation status,not coded/not installed,
IDE10136-MAS14067,Front left door area heating-Actuation specified value,not coded/not installed,
IDE10138-MAS01632,Front right door area heating-Status,not coded/not installed,
IDE10138-MAS05945,Front right door area heating-Target temperature,not coded/not installed,
IDE10138-MAS05946,Front right door area heating-Actual temp.,not coded/not installed,
IDE10138-MAS07929,Front right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10138-MAS12066,Front right door area heating-Cancellation status,not coded/not installed,
IDE10138-MAS14067,Front right door area heating-Actuation specified value,not coded/not installed,
IDE10140-MAS01632,Rear left door area heating-Status,not coded/not installed,
IDE10140-MAS05945,Rear left door area heating-Target temperature,not coded/not installed,
IDE10140-MAS05946,Rear left door area heating-Actual temp.,not coded/not installed,
IDE10140-MAS07929,Rear left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10140-MAS12066,Rear left door area heating-Cancellation status,not coded/not installed,
IDE10140-MAS14067,Rear left door area heating-Actuation specified value,not coded/not installed,
IDE10142-MAS01632,Rear right door area heating-Status,not coded/not installed,
IDE10142-MAS05945,Rear right door area heating-Target temperature,not coded/not installed,
IDE10142-MAS05946,Rear right door area heating-Actual temp.,not coded/not installed,
IDE10142-MAS07929,Rear right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10142-MAS12066,Rear right door area heating-Cancellation status,not coded/not installed,
IDE10142-MAS14067,Rear right door area heating-Actuation specified value,not coded/not installed,
IDE10144-MAS01632,Front center arm rest heating-Status,not active,
IDE10144-MAS05945,Front center arm rest heating-Target temperature,OFF,
IDE10144-MAS05946,Front center arm rest heating-Actual temp.,23.00, °C
IDE10144-MAS07929,Front center arm rest heating-Power quota setting by energy management,0,
IDE10144-MAS12066,Front center arm rest heating-Cancellation status,Heating process interrupted,
IDE10144-MAS14067,Front center arm rest heating-Actuation specified value,0, %
IDE10145-MAS01632,Rear center arm rest heating-Status,not coded/not installed,
IDE10145-MAS05945,Rear center arm rest heating-Target temperature,not coded/not installed,
IDE10145-MAS05946,Rear center arm rest heating-Actual temp.,not coded/not installed,
IDE10145-MAS07929,Rear center arm rest heating-Power quota setting by energy management,not coded/not installed,
IDE10145-MAS12066,Rear center arm rest heating-Cancellation status,not coded/not installed,
IDE10145-MAS14067,Rear center arm rest heating-Actuation specified value,not coded/not installed,
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Target value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cup holder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cup holder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cup holder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cup holder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cup holder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cup holder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cup holder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cup holder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cup holder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cup holder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cup holder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,Measuring value not available,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,Measuring value not available,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,12.50, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,24, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,71, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10434,Roof electronics control module: dim. value-Indicator lamps,22, %
IDE10343-MAS10497,Roof electronics control module: dim. value-Ceiling contour lights: dim. value,0, %
IDE10343-MAS10498,Roof electronics control module: dim. value-Ceiling contour lights: diagnosis,Unknown (0),
IDE10343-MAS14264,Roof electronics control module: dim. value-Front search illumination,54, %
IDE10343-MAS14268,Roof electronics control module: dim. value-Left rear interior lamp: dimming value,0, %
IDE10343-MAS14269,Roof electronics control module: dim. value-Left rear interior light: diagnostics,No malfunction,
IDE10343-MAS14270,Roof electronics control module: dim. value-Right rear interior lamp: dimming value,0, %
IDE10343-MAS14271,Roof electronics control module: dim. value-Right rear interior lamp: diagnostics,No malfunction,
IDE10343-MAS15403,Roof electronics control module: dim. value-Front passenger airbag indicator lamp,29, %
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-IDE01097,Roof electronics control module: indicator lights-Front passenger airbag -disabled- indicator lamp,On,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,OFF,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10346-MAS14279,Roof electronics control module: indicator lights-Indicator lamp for emergency call: green,On,
IDE10346-MAS14280,Roof electronics control module: indicator lights-Indicator lamp for emergency call: red,OFF,
IDE10346-MAS15376,Roof electronics control module: indicator lights-Front passenger airbag indicator lamp on,OFF,
IDE10346-MAS15377,Roof electronics control module: indicator lights-Front passenger airbag lettering,On,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,7.47, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.22, kOhm
IDE10361-MAS07003,Driver information sensor-Engine Coolant Level Sensor 2,not coded/not installed,
IDE10482-MAS01632,Activation for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Activation for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Activation for external systems-Installation info.: external system,no system,
IDE10602-MAS01632,Reclining seat: lower leg support heating-Status,not coded/not installed,
IDE10602-MAS05945,Reclining seat: lower leg support heating-Target temperature,not coded/not installed,
IDE10602-MAS05946,Reclining seat: lower leg support heating-Actual temp.,not coded/not installed,
IDE10602-MAS07929,Reclining seat: lower leg support heating-Power quota setting by energy management,not coded/not installed,
IDE10602-MAS12066,Reclining seat: lower leg support heating-Cancellation status,not coded/not installed,
IDE10602-MAS14067,Reclining seat: lower leg support heating-Actuation specified value,not coded/not installed,
IDE10603-MAS01632,Reclining seat: foot sole heating-Status,not coded/not installed,
IDE10603-MAS05945,Reclining seat: foot sole heating-Target temperature,not coded/not installed,
IDE10603-MAS05946,Reclining seat: foot sole heating-Actual temp.,not coded/not installed,
IDE10603-MAS07929,Reclining seat: foot sole heating-Power quota setting by energy management,not coded/not installed,
IDE10603-MAS12066,Reclining seat: foot sole heating-Cancellation status,not coded/not installed,
IDE10603-MAS14067,Reclining seat: foot sole heating-Actuation specified value,not coded/not installed,
IDE10662-MAS00530,Light switch (button module)-Rear fog light indicator lamp,OFF,
IDE10662-MAS01632,Light switch (button module)-Status,operational,
IDE10662-MAS05451,Light switch (button module)-Low beam indicator lamp,OFF,
IDE10662-MAS06614,Light switch (button module)-Variant,Variant 1,
IDE10662-MAS06732,Light switch (button module)-Status local activity,not active,
IDE10662-MAS06888,Light switch (button module)-Fog light button,Not operated,
IDE10662-MAS06889,Light switch (button module)-Rear fog light button,Not operated,
IDE10662-MAS07055,Light switch (button module)-Response error,not active,
IDE10662-MAS07376,Light switch (button module)-Terminal 58xd,165,
IDE10662-MAS09817,Light switch (button module)-Terminal 58xs,55, %
IDE10662-MAS09820,Light switch (button module)-Terminal 58xt,55, %
IDE10662-MAS12385,Light switch (button module)-Automatic driving light control indicator lamp,OFF,
IDE10662-MAS12415,Light switch (button module)-Parking lamp indicator lamp,OFF,
IDE10662-MAS12416,Light switch (button module)-Daytime running lamp indicator lamp,OFF,
IDE10662-MAS12417,Light switch (button module)-Fog lights indicator lights,OFF,
IDE10662-MAS12419,Light switch (button module)-Side light button,not installed,
IDE10662-MAS12420,Light switch (button module)-Low-beam light button,not installed,
IDE10662-MAS12421,Light switch (button module)-Proximity sensor,no approach,
IDE10662-MAS14302,Light switch (button module)-Automatic high beam button/exterior lighting button,Not operated,
IDE10808-MAS06614,Directional stabilization assistance button-Variant,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator lamp activation,not coded/not installed,
IDE10809-MAS06993,Driver assistance systems control module-Request signal horn,not coded/not installed,
IDE10809-MAS13254,Driver assistance systems control module-Active parking function,not coded/not installed,
IDE10810-MAS06614,Button for side view camera-Variant,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE10945-MAS01580,Shut-off valve 1 for refrigerant-Activation,not coded/not installed,
IDE10945-MAS12621,Shut-off valve 1 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10946-MAS01580,Shut-off valve 2 for refrigerant-Activation,not coded/not installed,
IDE10946-MAS12621,Shut-off valve 2 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10964-MAS06614,Button for instrument panel vents-Variant,not coded/not installed,
IDE10964-MAS07693,Button for instrument panel vents-Button Status,not coded/not installed,
IDE10964-MAS07694,Button for instrument panel vents-Button status on CAN,Initialization/not installed,
IDE10964-MAS07699,Button for instrument panel vents-Status indicator light on CAN,OFF,
IDE10964-MAS08062,Button for instrument panel vents-Indicator lamp activation,not coded/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11348,Variable left front lighting: actual position,Measuring value not available,
IDE11349,Variable right front lighting: actual position,Measuring value not available,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,70, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,70, W/m²
IDE11361-MAS06732,Control unit for windshield washer pump-Status local activity,not active,
IDE11361-MAS12606,Control unit for windshield washer pump-Status of windshield wiper pump,not active,
IDE11361-MAS12607,Control unit for windshield washer pump-Status of wiper arm heater,not active,
IDE11361-MAS12608,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of upper change pos.,0, %
IDE11361-MAS12609,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of lower change pos.,0, %
IDE11361-MAS12610,Control unit for windshield washer pump-Activation of wiper arm heater,0, %
IDE11551-IDE01078,Status of identification data query on LIN-Bus-Fresh air blower: front,Data complete but not secured,
IDE11551-IDE06163,Status of identification data query on LIN-Bus-Humidity sensor: exterior,Data complete but not secured,
IDE11551-IDE11361,Status of identification data query on LIN-Bus-Control unit for windshield washer pump,Data complete but not secured,
IDE11551-IDE11719,Status of identification data query on LIN-Bus-Fan 1 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11720,Status of identification data query on LIN-Bus-Fan 1 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11721,Status of identification data query on LIN-Bus-Fan 1 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11722,Status of identification data query on LIN-Bus-Fan 1 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11723,Status of identification data query on LIN-Bus-Fan 2 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11724,Status of identification data query on LIN-Bus-Fan 2 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11725,Status of identification data query on LIN-Bus-Fan 2 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11726,Status of identification data query on LIN-Bus-Fan 2 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11794,Status of identification data query on LIN-Bus-Fragrance diffuser system control module,not coded/not installed,
IDE11551-IDE12358,Status of identification data query on LIN-Bus-Roof electronics control module 2,Data complete but not secured,
IDE11551-MAS00746,Status of identification data query on LIN-Bus-Wiper motor control module,Data complete but not secured,
IDE11551-MAS00747,Status of identification data query on LIN-Bus-Rain/Light Recognition Sensor,Data complete but not secured,
IDE11551-MAS00748,Status of identification data query on LIN-Bus-Light switch,Data complete but not secured,
IDE11551-MAS00749,Status of identification data query on LIN-Bus-Garage door opener control module,Data complete but not secured,
IDE11551-MAS00750,Status of identification data query on LIN-Bus-Garage door opener control head,not coded/not installed,
IDE11551-MAS00762,Status of identification data query on LIN-Bus-Automatic dimming interior mirror,Data complete but not secured,
IDE11551-MAS01562,Status of identification data query on LIN-Bus-Air quality sensor,not coded/not installed,
IDE11551-MAS08026,Status of identification data query on LIN-Bus-Control head for driving and comfort functions,Data complete but not secured,
IDE11551-MAS08027,Status of identification data query on LIN-Bus-Control unit 2 for driving and convenience functions,Data complete but not secured,
IDE11551-MAS10760,Status of identification data query on LIN-Bus-Coolant expansion valve: A/C,not coded/not installed,
IDE11551-MAS12901,Status of identification data query on LIN-Bus-Roof electronics control module,Data complete but not secured,
IDE11551-MAS12902,Status of identification data query on LIN-Bus-Adjustable Steering Column Control Module,Data complete but not secured,
IDE11551-MAS12903,Status of identification data query on LIN-Bus-Right Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12904,Status of identification data query on LIN-Bus-Left Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12905,Status of identification data query on LIN-Bus-Blower 1 for left front backrest,Data complete but not secured,
IDE11551-MAS12906,Status of identification data query on LIN-Bus-Blower 2 for left front backrest,not coded/not installed,
IDE11551-MAS12907,Status of identification data query on LIN-Bus-Blower 1 for left front seat cushion,Data complete but not secured,
IDE11551-MAS12908,Status of identification data query on LIN-Bus-Blower 2 for left front seat cushion,not coded/not installed,
IDE11551-MAS12909,Status of identification data query on LIN-Bus-Blower 1 for right front backrest,Data complete but not secured,
IDE11551-MAS12910,Status of identification data query on LIN-Bus-Blower 2 for right front backrest,not coded/not installed,
IDE11551-MAS12911,Status of identification data query on LIN-Bus-Blower 1 for right front seat cushion,Data complete but not secured,
IDE11551-MAS12912,Status of identification data query on LIN-Bus-Blower 2 for right front seat cushion,not coded/not installed,
IDE11551-MAS12913,Status of identification data query on LIN-Bus-Valve block 1 in front seat driver side,not coded/not installed,
IDE11551-MAS12914,Status of identification data query on LIN-Bus-Valve block 1 in front seat passenger side,not coded/not installed,
IDE11551-MAS12915,Status of identification data query on LIN-Bus-Cup holder with heating and cooling element,not coded/not installed,
IDE11551-MAS12916,Status of identification data query on LIN-Bus-Humidity sensor: interior,not coded/not installed,
IDE11551-MAS14926,Status of identification data query on LIN-Bus-Sensor for carbon dioxide content in the interior,not coded/not installed,
IDE11551-MAS14927,Status of identification data query on LIN-Bus-Rear A/C control and display head,not coded/not installed,
IDE11551-MAS15174,Status of identification data query on LIN-Bus-Front A/C display control head,not coded/not installed,
IDE11551-MAS15185,Status of identification data query on LIN-Bus-Sensor for particulate matter content in the A/C,not coded/not installed,
IDE11551-MAS16271,Status of identification data query on LIN-Bus-Sensor for visibility distance measurement,not coded/not installed,
IDE11551-SFT09759,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor,not coded/not installed,
IDE11551-SFT09776,Status of identification data query on LIN-Bus-Ionization,Data complete but not secured,
IDE11551-SFT09878,Status of identification data query on LIN-Bus-Rear A/C Control Head 6,Data complete but not secured,
IDE11551-SFT09902,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 2,not coded/not installed,
IDE11551-SFT09903,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 3,not coded/not installed,
IDE11551-SFT09929,Status of identification data query on LIN-Bus-Rear A/C Control Head 1,Data complete but not secured,
IDE11551-SFT09930,Status of identification data query on LIN-Bus-Rear A/C Control Head 2,Data complete but not secured,
IDE11551-SFT09931,Status of identification data query on LIN-Bus-Rear A/C Control Head 3,Data complete but not secured,
IDE11551-SFT09932,Status of identification data query on LIN-Bus-Rear A/C Control Head 4,Data complete but not secured,
IDE11551-SFT09933,Status of identification data query on LIN-Bus-Rear A/C Control Head 5,Data complete but not secured,
IDE11551-SFT10027,Status of identification data query on LIN-Bus-Control module for heating element 1,Data complete but not secured,
IDE11551-SFT10028,Status of identification data query on LIN-Bus-Control module for heating element 2,Data complete but not secured,
IDE11551-SFT10029,Status of identification data query on LIN-Bus-Control module for heating element 3,not coded/not installed,
IDE11551-SFT10030,Status of identification data query on LIN-Bus-Control module for heating element 4,not coded/not installed,
IDE11619-MAS13023,Photo sensors for solar radiation (discrete)-Front left sunlight intensity,not coded/not installed,
IDE11619-MAS13024,Photo sensors for solar radiation (discrete)-Front right sunlight intensity,not coded/not installed,
IDE11619-MAS13025,Photo sensors for solar radiation (discrete)-Rear left sunlight intensity,20, W/m²
IDE11619-MAS13026,Photo sensors for solar radiation (discrete)-Rear right sunlight intensity,not coded/not installed,
IDE11619-MAS13077,Photo sensors for solar radiation (discrete)-Sunlight photo sensor,not coded/not installed,
IDE11619-MAS13078,Photo sensors for solar radiation (discrete)-Sunlight photo sensor 2,not coded/not installed,
IDE11619-MAS13079,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor,0.37, V
IDE11619-MAS13080,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor 2,not coded/not installed,
IDE11637,Outside air temperature internally calculated: climate,20.81, °C
IDE11641-MAS01632,Supply voltage for A/C actuators-Status,On,
IDE11641-MAS12621,Supply voltage for A/C actuators-Current draw (effective value),226, mA
IDE11642-MAS01632,Supply voltage 2 for A/C actuators-Status,On,
IDE11642-MAS12621,Supply voltage 2 for A/C actuators-Current draw (effective value),496, mA
IDE11643-MAS01632,Voltage supply for climate sensor system-Status,On,
IDE11643-MAS04121,Voltage supply for climate sensor system-Voltage,4.99, V
IDE11654-MAS05030,Evaporator temperature sensor-Resistance,7.55, kOhm
IDE11654-MAS13081,Evaporator temperature sensor-Air temperature downstream of evaporator,4.06, °C
IDE11655-MAS05030,Left footwell vent temperature sensor-Resistance,12.73, kOhm
IDE11655-MAS13082,Left footwell vent temperature sensor-Left footwell vent temperature,19.19, °C
IDE11656-MAS05030,Right footwell vent temperature sensor-Resistance,12.78, kOhm
IDE11656-MAS13083,Right footwell vent temperature sensor-Right footwell vent temperature,19.00, °C
IDE11657-MAS05030,Left rear upper body vent temperature sensor-Resistance,15.38, kOhm
IDE11657-MAS13084,Left rear upper body vent temperature sensor-Left rear vent temperature,14.06, °C
IDE11658-MAS05030,Right rear upper body vent temperature sensor-Resistance,15.24, kOhm
IDE11658-MAS13085,Right rear upper body vent temperature sensor-Right rear vent temperature,14.31, °C
IDE11659-MAS05030,Left rear footwell vent temperature sensor-Resistance,12.72, kOhm
IDE11659-MAS13086,Left rear footwell vent temperature sensor-Left rear footwell vent temperature,19.31, °C
IDE11660-MAS05030,Right rear footwell vent temperature sensor-Resistance,12.69, kOhm
IDE11660-MAS13087,Right rear footwell vent temperature sensor-Right rear footwell vent temperature,19.38, °C
IDE11692-MAS00359,Temperature sensor after heat exchanger-Coolant temperature,not coded/not installed,
IDE11692-MAS05030,Temperature sensor after heat exchanger-Resistance,not coded/not installed,
IDE11693-MAS05030,Left side air outlet temperature sensor-Resistance,18.05, kOhm
IDE11693-MAS13110,Left side air outlet temperature sensor-Left side air outlet temperature,10.63, °C
IDE11694-MAS05030,Right side air outlet temperature sensor-Resistance,12.58, kOhm
IDE11694-MAS13111,Right side air outlet temperature sensor-Right side air outlet temperature,19.56, °C
IDE11695-MAS05030,Left central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11695-MAS13112,Left central air outlet temperature sensor-Left center air outlet temperature,not coded/not installed,
IDE11696-MAS05030,Right central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11696-MAS13113,Right central air outlet temperature sensor-Right center air outlet temperature,not coded/not installed,
IDE11697-MAS05030,Front defrost flap air outlet temperature sensor-Resistance,not coded/not installed,
IDE11697-MAS13114,Front defrost flap air outlet temperature sensor-Defrosting air outlet temperature,not coded/not installed,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,not coded/not installed,
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded/not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,20.88, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,11.76, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,21.00, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,11.68, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,20.94, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,11.72, kOhm
IDE11774-IDE01290,Assembly position of users at local data bus 9-Recirculation flap motor,15,
IDE11774-IDE01292,Assembly position of users at local data bus 9-Left side vent motor,4,
IDE11774-IDE01293,Assembly position of users at local data bus 9-Right side vent motor,10,
IDE11774-IDE01294,Assembly position of users at local data bus 9-Left footwell flap motor,1,
IDE11774-IDE01295,Assembly position of users at local data bus 9-Right footwell flap motor,11,
IDE11774-IDE01296,Assembly position of users at local data bus 9-Left center vent motor,6,
IDE11774-IDE01297,Assembly position of users at local data bus 9-Right center vent motor,8,
IDE11774-IDE01300,Assembly position of users at local data bus 9-Rear temperature door motor,3,
IDE11774-IDE01301,Assembly position of users at local data bus 9-Rear air quantity motor,12,
IDE11774-IDE01304,Assembly position of users at local data bus 9-Left Rear Upper Body Vent Motor,0,
IDE11774-IDE01305,Assembly position of users at local data bus 9-Right Rear Upper Body Vent Motor,0,
IDE11774-IDE01422,Assembly position of users at local data bus 9-Defroster flap motor,7,
IDE11774-IDE01423,Assembly position of users at local data bus 9-Left temperature flap positioning motor,5,
IDE11774-IDE01424,Assembly position of users at local data bus 9-Right temperature flap positioning motor,13,
IDE11774-IDE02432,Assembly position of users at local data bus 9-Left rear temperature door motor,0,
IDE11774-IDE02435,Assembly position of users at local data bus 9-Right rear temperature door motor,0,
IDE11774-IDE02753,Assembly position of users at local data bus 9-Temperature flap motor,0,
IDE11774-IDE02833,Assembly position of users at local data bus 9-Fresh air door motor,14,
IDE11774-IDE07267,Assembly position of users at local data bus 9-Rear left air distribution servomotor,0,
IDE11774-IDE07268,Assembly position of users at local data bus 9-Rear right air distribution servomotor,0,
IDE11774-MAS07679,Assembly position of users at local data bus 9-Air distribution door motor,0,
IDE11774-MAS07681,Assembly position of users at local data bus 9-Left footwell temperature door motor,0,
IDE11774-MAS07682,Assembly position of users at local data bus 9-Right footwell temperature door motor,0,
IDE11774-MAS07683,Assembly position of users at local data bus 9-Left side window defroster door motor,0,
IDE11774-MAS07684,Assembly position of users at local data bus 9-Right side window defroster door motor,0,
IDE11774-MAS07685,Assembly position of users at local data bus 9-Rear air distribution door motor,0,
IDE11774-MAS07686,Assembly position of users at local data bus 9-Left B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07687,Assembly position of users at local data bus 9-Right B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07688,Assembly position of users at local data bus 9-Rear recirc. flap motor,0,
IDE11774-MAS11831,Assembly position of users at local data bus 9-Ctrl. motor for instrument panel vents,0,
IDE11775-IDE01290,Assembly position of users at local data bus 10-Recirculation flap motor,0,
IDE11775-IDE01292,Assembly position of users at local data bus 10-Left side vent motor,0,
IDE11775-IDE01293,Assembly position of users at local data bus 10-Right side vent motor,0,
IDE11775-IDE01294,Assembly position of users at local data bus 10-Left footwell flap motor,0,
IDE11775-IDE01295,Assembly position of users at local data bus 10-Right footwell flap motor,0,
IDE11775-IDE01296,Assembly position of users at local data bus 10-Left center vent motor,0,
IDE11775-IDE01297,Assembly position of users at local data bus 10-Right center vent motor,0,
IDE11775-IDE01300,Assembly position of users at local data bus 10-Rear temperature door motor,0,
IDE11775-IDE01301,Assembly position of users at local data bus 10-Rear air quantity motor,0,
IDE11775-IDE01304,Assembly position of users at local data bus 10-Left Rear Upper Body Vent Motor,0,
IDE11775-IDE01305,Assembly position of users at local data bus 10-Right Rear Upper Body Vent Motor,0,
IDE11775-IDE01422,Assembly position of users at local data bus 10-Defroster flap motor,0,
IDE11775-IDE01423,Assembly position of users at local data bus 10-Left temperature flap positioning motor,0,
IDE11775-IDE01424,Assembly position of users at local data bus 10-Right temperature flap positioning motor,0,
IDE11775-IDE02432,Assembly position of users at local data bus 10-Left rear temperature door motor,0,
IDE11775-IDE02435,Assembly position of users at local data bus 10-Right rear temperature door motor,0,
IDE11775-IDE02753,Assembly position of users at local data bus 10-Temperature flap motor,0,
IDE11775-IDE02833,Assembly position of users at local data bus 10-Fresh air door motor,0,
IDE11775-IDE07267,Assembly position of users at local data bus 10-Rear left air distribution servomotor,0,
IDE11775-IDE07268,Assembly position of users at local data bus 10-Rear right air distribution servomotor,0,
IDE11775-MAS07679,Assembly position of users at local data bus 10-Air distribution door motor,0,
IDE11775-MAS07681,Assembly position of users at local data bus 10-Left footwell temperature door motor,0,
IDE11775-MAS07682,Assembly position of users at local data bus 10-Right footwell temperature door motor,0,
IDE11775-MAS07683,Assembly position of users at local data bus 10-Left side window defroster door motor,0,
IDE11775-MAS07684,Assembly position of users at local data bus 10-Right side window defroster door motor,0,
IDE11775-MAS07685,Assembly position of users at local data bus 10-Rear air distribution door motor,0,
IDE11775-MAS07686,Assembly position of users at local data bus 10-Left B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07687,Assembly position of users at local data bus 10-Right B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07688,Assembly position of users at local data bus 10-Rear recirc. flap motor,0,
IDE11775-MAS11831,Assembly position of users at local data bus 10-Ctrl. motor for instrument panel vents,0,
IDE11776-IDE01290,Assembly position of users at local data bus 11-Recirculation flap motor,0,
IDE11776-IDE01292,Assembly position of users at local data bus 11-Left side vent motor,0,
IDE11776-IDE01293,Assembly position of users at local data bus 11-Right side vent motor,0,
IDE11776-IDE01294,Assembly position of users at local data bus 11-Left footwell flap motor,0,
IDE11776-IDE01295,Assembly position of users at local data bus 11-Right footwell flap motor,0,
IDE11776-IDE01296,Assembly position of users at local data bus 11-Left center vent motor,0,
IDE11776-IDE01297,Assembly position of users at local data bus 11-Right center vent motor,0,
IDE11776-IDE01300,Assembly position of users at local data bus 11-Rear temperature door motor,0,
IDE11776-IDE01301,Assembly position of users at local data bus 11-Rear air quantity motor,0,
IDE11776-IDE01304,Assembly position of users at local data bus 11-Left Rear Upper Body Vent Motor,5,
IDE11776-IDE01305,Assembly position of users at local data bus 11-Right Rear Upper Body Vent Motor,2,
IDE11776-IDE01422,Assembly position of users at local data bus 11-Defroster flap motor,0,
IDE11776-IDE01423,Assembly position of users at local data bus 11-Left temperature flap positioning motor,0,
IDE11776-IDE01424,Assembly position of users at local data bus 11-Right temperature flap positioning motor,0,
IDE11776-IDE02432,Assembly position of users at local data bus 11-Left rear temperature door motor,6,
IDE11776-IDE02435,Assembly position of users at local data bus 11-Right rear temperature door motor,1,
IDE11776-IDE02753,Assembly position of users at local data bus 11-Temperature flap motor,0,
IDE11776-IDE02833,Assembly position of users at local data bus 11-Fresh air door motor,0,
IDE11776-IDE07267,Assembly position of users at local data bus 11-Rear left air distribution servomotor,0,
IDE11776-IDE07268,Assembly position of users at local data bus 11-Rear right air distribution servomotor,0,
IDE11776-MAS07679,Assembly position of users at local data bus 11-Air distribution door motor,0,
IDE11776-MAS07681,Assembly position of users at local data bus 11-Left footwell temperature door motor,0,
IDE11776-MAS07682,Assembly position of users at local data bus 11-Right footwell temperature door motor,0,
IDE11776-MAS07683,Assembly position of users at local data bus 11-Left side window defroster door motor,0,
IDE11776-MAS07684,Assembly position of users at local data bus 11-Right side window defroster door motor,0,
IDE11776-MAS07685,Assembly position of users at local data bus 11-Rear air distribution door motor,0,
IDE11776-MAS07686,Assembly position of users at local data bus 11-Left B-pillar/footwell shut-off flap motor,4,
IDE11776-MAS07687,Assembly position of users at local data bus 11-Right B-pillar/footwell shut-off flap motor,3,
IDE11776-MAS07688,Assembly position of users at local data bus 11-Rear recirc. flap motor,7,
IDE11776-MAS11831,Assembly position of users at local data bus 11-Ctrl. motor for instrument panel vents,0,
IDE11777-IDE01290,Assembly position of users at local data bus 12-Recirculation flap motor,0,
IDE11777-IDE01292,Assembly position of users at local data bus 12-Left side vent motor,0,
IDE11777-IDE01293,Assembly position of users at local data bus 12-Right side vent motor,0,
IDE11777-IDE01294,Assembly position of users at local data bus 12-Left footwell flap motor,0,
IDE11777-IDE01295,Assembly position of users at local data bus 12-Right footwell flap motor,0,
IDE11777-IDE01296,Assembly position of users at local data bus 12-Left center vent motor,0,
IDE11777-IDE01297,Assembly position of users at local data bus 12-Right center vent motor,0,
IDE11777-IDE01300,Assembly position of users at local data bus 12-Rear temperature door motor,0,
IDE11777-IDE01301,Assembly position of users at local data bus 12-Rear air quantity motor,0,
IDE11777-IDE01304,Assembly position of users at local data bus 12-Left Rear Upper Body Vent Motor,0,
IDE11777-IDE01305,Assembly position of users at local data bus 12-Right Rear Upper Body Vent Motor,0,
IDE11777-IDE01422,Assembly position of users at local data bus 12-Defroster flap motor,0,
IDE11777-IDE01423,Assembly position of users at local data bus 12-Left temperature flap positioning motor,0,
IDE11777-IDE01424,Assembly position of users at local data bus 12-Right temperature flap positioning motor,0,
IDE11777-IDE02432,Assembly position of users at local data bus 12-Left rear temperature door motor,0,
IDE11777-IDE02435,Assembly position of users at local data bus 12-Right rear temperature door motor,0,
IDE11777-IDE02753,Assembly position of users at local data bus 12-Temperature flap motor,0,
IDE11777-IDE02833,Assembly position of users at local data bus 12-Fresh air door motor,0,
IDE11777-IDE07267,Assembly position of users at local data bus 12-Rear left air distribution servomotor,0,
IDE11777-IDE07268,Assembly position of users at local data bus 12-Rear right air distribution servomotor,0,
IDE11777-MAS07679,Assembly position of users at local data bus 12-Air distribution door motor,0,
IDE11777-MAS07681,Assembly position of users at local data bus 12-Left footwell temperature door motor,0,
IDE11777-MAS07682,Assembly position of users at local data bus 12-Right footwell temperature door motor,0,
IDE11777-MAS07683,Assembly position of users at local data bus 12-Left side window defroster door motor,1,
IDE11777-MAS07684,Assembly position of users at local data bus 12-Right side window defroster door motor,5,
IDE11777-MAS07685,Assembly position of users at local data bus 12-Rear air distribution door motor,0,
IDE11777-MAS07686,Assembly position of users at local data bus 12-Left B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07687,Assembly position of users at local data bus 12-Right B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07688,Assembly position of users at local data bus 12-Rear recirc. flap motor,0,
IDE11777-MAS11831,Assembly position of users at local data bus 12-Ctrl. motor for instrument panel vents,0,
IDE11789-MAS11878,Air quality in the interior-Degree of contamination,Unknown (255),
IDE11790,Carbon dioxide content in the interior,Initialization,
IDE11794-IDE00348,Fragrance diffuser system control module-Intake air temperature,20.00, °C
IDE11794-MAS09106,Fragrance diffuser system control module-Operating Hours,0,
IDE11794-MAS13243,Fragrance diffuser system control module-Pump,not active,
IDE11794-MAS13244,Fragrance diffuser system control module-Blower,0, %
IDE11794-MAS13245,Fragrance diffuser system control module-Aroma fill level 1,100, %
IDE11794-MAS13246,Fragrance diffuser system control module-Aroma fill level 2,100, %
IDE11794-MAS14233,Fragrance diffuser system control module-Active cartridge,0,
IDE11794-MAS15168,Fragrance diffuser system control module-Status of cartridge 1,closed,
IDE11794-MAS15169,Fragrance diffuser system control module-Status of cartridge 2,closed,
IDE11794-MAS15173,Fragrance diffuser system control module-Aroma temperature,107.00, °C
IDE11936-MAS06614,Button for defrost function-Variant,Local data bus: operating unit 1,
IDE11936-MAS07693,Button for defrost function-Button Status,Not operated,
IDE11936-MAS07694,Button for defrost function-Button status on CAN,Not operated,
IDE11936-MAS07699,Button for defrost function-Status indicator light on CAN,OFF,
IDE11936-MAS08062,Button for defrost function-Indicator lamp activation,OFF,
IDE11939-MAS06614,Button for auxiliary water heater-Variant,not coded/not installed,
IDE11939-MAS07693,Button for auxiliary water heater-Button Status,not coded/not installed,
IDE11939-MAS07694,Button for auxiliary water heater-Button status on CAN,Not operated,
IDE11939-MAS14852,Button for auxiliary water heater-Auxiliary coolant heater indicator lamp activation,not coded/not installed,
IDE11939-MAS14853,Button for auxiliary water heater-Activation of indicator lamp for auxiliary coolant heater timer,not coded/not installed,
IDE11939-MAS14854,Button for auxiliary water heater-Status off indicator lamp for auxiliary coolant heater on CAN,OFF,
IDE12151-MAS01580,Left LED headlamp power output module: supply-Activation,not coded/not installed,
IDE12151-MAS01737,Left LED headlamp power output module: supply-Diagnosis,not coded/not installed,
IDE12151-MAS12621,Left LED headlamp power output module: supply-Current draw (effective value),not coded/not installed,
IDE12152-MAS01580,Right LED headlamp power output module: supply-Activation,not coded/not installed,
IDE12152-MAS01737,Right LED headlamp power output module: supply-Diagnosis,not coded/not installed,
IDE12152-MAS12621,Right LED headlamp power output module: supply-Current draw (effective value),not coded/not installed,
IDE12284-MAS14215,Front A/C display control head 1: pin coding-Coding pin 1: specified value,Open,
IDE12284-MAS14216,Front A/C display control head 1: pin coding-Coding pin 2: specified value,Open,
IDE12284-MAS14217,Front A/C display control head 1: pin coding-Coding pin 3: specified value,Open,
IDE12284-MAS14218,Front A/C display control head 1: pin coding-Coding pin 1: actual value,Open,
IDE12284-MAS14219,Front A/C display control head 1: pin coding-Coding pin 2: actual value,Open,
IDE12284-MAS14220,Front A/C display control head 1: pin coding-Coding pin 3: actual value,Open,
IDE12286-MAS14215,Front A/C display control head 2: pin coding-Coding pin 1: specified value,Open,
IDE12286-MAS14216,Front A/C display control head 2: pin coding-Coding pin 2: specified value,Open,
IDE12286-MAS14217,Front A/C display control head 2: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12286-MAS14218,Front A/C display control head 2: pin coding-Coding pin 1: actual value,Open,
IDE12286-MAS14219,Front A/C display control head 2: pin coding-Coding pin 2: actual value,Open,
IDE12286-MAS14220,Front A/C display control head 2: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12287-MAS14215,Front A/C display control head 3: pin coding-Coding pin 1: specified value,Open,
IDE12287-MAS14216,Front A/C display control head 3: pin coding-Coding pin 2: specified value,Ground (GND),
IDE12287-MAS14217,Front A/C display control head 3: pin coding-Coding pin 3: specified value,Open,
IDE12287-MAS14218,Front A/C display control head 3: pin coding-Coding pin 1: actual value,Open,
IDE12287-MAS14219,Front A/C display control head 3: pin coding-Coding pin 2: actual value,Ground (GND),
IDE12287-MAS14220,Front A/C display control head 3: pin coding-Coding pin 3: actual value,Open,
IDE12288-MAS14215,Front A/C display control head 4: pin coding-Coding pin 1: specified value,Open,
IDE12288-MAS14216,Front A/C display control head 4: pin coding-Coding pin 2: specified value,Ground (GND),
IDE12288-MAS14217,Front A/C display control head 4: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12288-MAS14218,Front A/C display control head 4: pin coding-Coding pin 1: actual value,Open,
IDE12288-MAS14219,Front A/C display control head 4: pin coding-Coding pin 2: actual value,Ground (GND),
IDE12288-MAS14220,Front A/C display control head 4: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12289-MAS14215,Front A/C display control head 5: pin coding-Coding pin 1: specified value,Ground (GND),
IDE12289-MAS14216,Front A/C display control head 5: pin coding-Coding pin 2: specified value,Open,
IDE12289-MAS14217,Front A/C display control head 5: pin coding-Coding pin 3: specified value,Open,
IDE12289-MAS14218,Front A/C display control head 5: pin coding-Coding pin 1: actual value,Ground (GND),
IDE12289-MAS14219,Front A/C display control head 5: pin coding-Coding pin 2: actual value,Open,
IDE12289-MAS14220,Front A/C display control head 5: pin coding-Coding pin 3: actual value,Open,
IDE12290-MAS14215,Front A/C display control head 6: pin coding-Coding pin 1: specified value,Ground (GND),
IDE12290-MAS14216,Front A/C display control head 6: pin coding-Coding pin 2: specified value,Open,
IDE12290-MAS14217,Front A/C display control head 6: pin coding-Coding pin 3: specified value,Ground (GND),
IDE12290-MAS14218,Front A/C display control head 6: pin coding-Coding pin 1: actual value,Ground (GND),
IDE12290-MAS14219,Front A/C display control head 6: pin coding-Coding pin 2: actual value,Open,
IDE12290-MAS14220,Front A/C display control head 6: pin coding-Coding pin 3: actual value,Ground (GND),
IDE12292-MAS14221,Front A/C display control head 1: status-Button for air outlet: close,Not operated,
IDE12292-MAS14222,Front A/C display control head 1: status-Button for air outlet: open,Not operated,
IDE12292-MAS14223,Front A/C display control head 1: status-Setting for air outlet,Not operated,
IDE12292-MAS14224,Front A/C display control head 1: status-Air outlet specified value,100, %
IDE12292-MAS14225,Front A/C display control head 1: status-Air outlet specified level,4,
IDE12292-MAS14229,Front A/C display control head 1: status-Proximity sensor,not installed,
IDE12293-MAS14221,Front A/C display control head 2: status-Button for air outlet: close,Not operated,
IDE12293-MAS14222,Front A/C display control head 2: status-Button for air outlet: open,Not operated,
IDE12293-MAS14223,Front A/C display control head 2: status-Setting for air outlet,Not operated,
IDE12293-MAS14224,Front A/C display control head 2: status-Air outlet specified value,100, %
IDE12293-MAS14225,Front A/C display control head 2: status-Air outlet specified level,4,
IDE12293-MAS14229,Front A/C display control head 2: status-Proximity sensor,not installed,
IDE12294-MAS14221,Front A/C display control head 3: status-Button for air outlet: close,Not operated,
IDE12294-MAS14222,Front A/C display control head 3: status-Button for air outlet: open,Not operated,
IDE12294-MAS14223,Front A/C display control head 3: status-Setting for air outlet,Not operated,
IDE12294-MAS14224,Front A/C display control head 3: status-Air outlet specified value,100, %
IDE12294-MAS14225,Front A/C display control head 3: status-Air outlet specified level,4,
IDE12294-MAS14229,Front A/C display control head 3: status-Proximity sensor,not installed,
IDE12295-MAS14221,Front A/C display control head 4: status-Button for air outlet: close,Not operated,
IDE12295-MAS14222,Front A/C display control head 4: status-Button for air outlet: open,Not operated,
IDE12295-MAS14223,Front A/C display control head 4: status-Setting for air outlet,Not operated,
IDE12295-MAS14224,Front A/C display control head 4: status-Air outlet specified value,0, %
IDE12295-MAS14225,Front A/C display control head 4: status-Air outlet specified level,0,
IDE12295-MAS14229,Front A/C display control head 4: status-Proximity sensor,not installed,
IDE12296-MAS14221,Front A/C display control head 5: status-Button for air outlet: close,Not operated,
IDE12296-MAS14222,Front A/C display control head 5: status-Button for air outlet: open,Not operated,
IDE12296-MAS14223,Front A/C display control head 5: status-Setting for air outlet,Not operated,
IDE12296-MAS14224,Front A/C display control head 5: status-Air outlet specified value,100, %
IDE12296-MAS14225,Front A/C display control head 5: status-Air outlet specified level,4,
IDE12296-MAS14229,Front A/C display control head 5: status-Proximity sensor,not installed,
IDE12297-MAS14221,Front A/C display control head 6: status-Button for air outlet: close,Not operated,
IDE12297-MAS14222,Front A/C display control head 6: status-Button for air outlet: open,Not operated,
IDE12297-MAS14223,Front A/C display control head 6: status-Setting for air outlet,Not operated,
IDE12297-MAS14224,Front A/C display control head 6: status-Air outlet specified value,100, %
IDE12297-MAS14225,Front A/C display control head 6: status-Air outlet specified level,4,
IDE12297-MAS14229,Front A/C display control head 6: status-Proximity sensor,not installed,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12340-MAS10485,Roof electronics control module: reading lights left-Left front reading lamp: dim. value,0, %
IDE12340-MAS10489,Roof electronics control module: reading lights left-Left rear reading lamp: dim. value,0, %
IDE12340-MAS10490,Roof electronics control module: reading lights left-Left rear reading lamp: diagnosis,Unknown (0),
IDE12340-MAS10493,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: dim. value,0, %
IDE12340-MAS10494,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE12340-MAS14272,Roof electronics control module: reading lights left-Left rear reading lamp 2: dimming value,0, %
IDE12340-MAS14273,Roof electronics control module: reading lights left-Left rear reading lamp 2: diagnostic,No malfunction,
IDE12341-MAS10487,Roof electronics control module: reading lights right-Right front reading lamp: dim. value,0, %
IDE12341-MAS10491,Roof electronics control module: reading lights right-Right rear reading lamp: dim. value,0, %
IDE12341-MAS10492,Roof electronics control module: reading lights right-Right rear reading lamp: diagnosis,Unknown (0),
IDE12341-MAS10495,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: dim. value,0, %
IDE12341-MAS10496,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE12341-MAS14274,Roof electronics control module: reading lights right-Right rear reading lamp 2: dim. value,0, %
IDE12341-MAS14276,Roof electronics control module: reading lights right-Right rear reading lamp 2: diagnosis,No malfunction,
IDE12342-MAS06614,Button engine sound generation-Variant,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,OFF,
IDE12342-MAS08062,Button engine sound generation-Indicator lamp activation,not coded/not installed,
IDE12343-MAS07693,Automated driving button-Button Status,not coded/not installed,
IDE12343-MAS07694,Automated driving button-Button status on CAN,Initialization/not installed,
IDE12343-MAS14277,Automated driving button-Indicator lamp activation: color,not coded/not installed,
IDE12343-MAS14278,Automated driving button-Indicator lamp activation: mode,normal,
IDE12358-IDE00104,Roof electronics control module 2-DTC,0,
IDE12358-MAS01634,Roof electronics control module 2-Supply voltage,12.50, V
IDE12358-MAS02832,Roof electronics control module 2-Malfunction status,not faulty,
IDE12358-MAS05946,Roof electronics control module 2-Actual temp.,26, °C
IDE12358-MAS09113,Roof electronics control module 2-Maximum temperature,72, °C
IDE12399-MAS10434,Roof electronics control module 2: indicator lights/dimming value-Indicator lamps,28, %
IDE12399-MAS10489,Roof electronics control module 2: indicator lights/dimming value-Left rear reading lamp: dim. value,0, %
IDE12399-MAS10491,Roof electronics control module 2: indicator lights/dimming value-Right rear reading lamp: dim. value,0, %
IDE12399-MAS12701,Roof electronics control module 2: indicator lights/dimming value-Background lighting,54, %
IDE12399-MAS14266,Roof electronics control module 2: indicator lights/dimming value-Rear interior lamp: dimming value,0, %
IDE12399-MAS14305,Roof electronics control module 2: indicator lights/dimming value-Rear interior lamp rear indicator lamp,OFF,
IDE12400-MAS10421,Roof electronics control module 2: button-Left rear reading lamp switch,Not operated,
IDE12400-MAS10422,Roof electronics control module 2: button-Right rear reading lamp button,Not operated,
IDE12400-MAS14281,Roof electronics control module 2: button-Rear button for rear interior light,Not operated,
IDE12556,Left air vent cover motor: actual value,12867,
IDE12557,Left air vent cover motor: specified value,12867,
IDE12558,Left air vent cover motor: dynamics,2867,
IDE12561,Right air vent cover motor: actual value,10000,
IDE12562,Right air vent cover motor: specified value,10000,
IDE12563,Right air vent cover motor: dynamics,2907,
IDE12566,Center air vent cover motor: actual value,12861,
IDE12567,Center air vent cover motor: specified value,12861,
IDE12568,Center air vent cover motor: dynamics,2861,
IDE12571-IDE09056,Left air vent cover motor: diagnostic-Last operating state,blockage,
IDE12571-MAS01458,Left air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12572-IDE09056,Right air vent cover motor: diagnostic-Last operating state,Initialization,
IDE12572-MAS01458,Right air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12573-IDE09056,Center air vent cover motor: diagnostic-Last operating state,blockage,
IDE12573-MAS01458,Center air vent cover motor: diagnostic-Operating condition,No routine started,
IDE12605-MAS14822,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 1,0, %
IDE12605-MAS14823,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 2,0, %
IDE12605-MAS14824,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 3,0, %
IDE12605-MAS14825,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 4,0, %
IDE12605-MAS14826,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 5,0, %
IDE12605-MAS14827,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 6,0, %
IDE12605-MAS14828,Roof electronics control module 2: Dimming value matrix reading lights-Left reading lamp: segment 7,0, %
IDE12605-MAS14829,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 1,0, %
IDE12605-MAS14830,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 2,0, %
IDE12605-MAS14831,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 3,0, %
IDE12605-MAS14832,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 4,0, %
IDE12605-MAS14833,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 5,0, %
IDE12605-MAS14834,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 6,0, %
IDE12605-MAS14835,Roof electronics control module 2: Dimming value matrix reading lights-Right reading light: segment 7,0, %
IDE12606-MAS06526,Installation information multicolor ambient and contour lighting 2-Local data bus 5,B0 B1 A0 B2 B3 A2 B4 B5 A4 A5 B6 B7 A6 A7 FF FF,
IDE12606-MAS06527,Installation information multicolor ambient and contour lighting 2-Local data bus 6,40 41 42 FF FF FF FF FF FF FF FF C0 C1 C2 C3 FF,
IDE12606-MAS14771,Installation information multicolor ambient and contour lighting 2-Local data bus 7,20 21 22 23 30 31 32 33 50 51 52 FA FB F8 F9 FF,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Variant,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE12945-MAS01632,Door surface heating 2: left front-Status,not active,
IDE12945-MAS05945,Door surface heating 2: left front-Target temperature,OFF,
IDE12945-MAS05946,Door surface heating 2: left front-Actual temp.,22.00, °C
IDE12945-MAS07929,Door surface heating 2: left front-Power quota setting by energy management,0,
IDE12945-MAS12066,Door surface heating 2: left front-Cancellation status,Heating process interrupted,
IDE12945-MAS14067,Door surface heating 2: left front-Actuation specified value,0, %
IDE12946-MAS01632,Door surface heater 2: right front-Status,not active,
IDE12946-MAS05945,Door surface heater 2: right front-Target temperature,OFF,
IDE12946-MAS05946,Door surface heater 2: right front-Actual temp.,21.00, °C
IDE12946-MAS07929,Door surface heater 2: right front-Power quota setting by energy management,0,
IDE12946-MAS12066,Door surface heater 2: right front-Cancellation status,Heating process interrupted,
IDE12946-MAS14067,Door surface heater 2: right front-Actuation specified value,0, %
IDE12947-MAS01632,Door surface heater 2: left rear-Status,not coded/not installed,
IDE12947-MAS05945,Door surface heater 2: left rear-Target temperature,not coded/not installed,
IDE12947-MAS05946,Door surface heater 2: left rear-Actual temp.,not coded/not installed,
IDE12947-MAS07929,Door surface heater 2: left rear-Power quota setting by energy management,not coded/not installed,
IDE12947-MAS12066,Door surface heater 2: left rear-Cancellation status,not coded/not installed,
IDE12947-MAS14067,Door surface heater 2: left rear-Actuation specified value,not coded/not installed,
IDE12948-MAS01632,Door surface heater 2: right rear-Status,not coded/not installed,
IDE12948-MAS05945,Door surface heater 2: right rear-Target temperature,not coded/not installed,
IDE12948-MAS05946,Door surface heater 2: right rear-Actual temp.,not coded/not installed,
IDE12948-MAS07929,Door surface heater 2: right rear-Power quota setting by energy management,not coded/not installed,
IDE12948-MAS12066,Door surface heater 2: right rear-Cancellation status,not coded/not installed,
IDE12948-MAS14067,Door surface heater 2: right rear-Actuation specified value,not coded/not installed,
IDE12950-MAS07052,Foot level heating-Setting,not coded/not installed,
IDE14245-MAS19730,Component protection configuration-Configuration bit 1,not configured,
IDE14245-MAS19731,Component protection configuration-Configuration bit 0,not activated,
IDE14245-MAS19732,Component protection configuration-Configuration bit 2,not configured,
IDE14245-MAS19733,Component protection configuration-Configuration bit 3,not configured,
IDE14245-MAS19734,Component protection configuration-Configuration bit 4,not configured,
IDE14245-MAS19735,Component protection configuration-Configuration bit 5,not configured,
IDE14245-MAS19736,Component protection configuration-Configuration bit 6,not configured,
IDE14245-MAS19737,Component protection configuration-Configuration bit 7,not configured,
IDE14245-MAS19738,Component protection configuration-Configuration bit 8,not configured,
IDE14245-MAS19739,Component protection configuration-Configuration bit 9,not configured,
IDE14245-MAS19740,Component protection configuration-Configuration bit 10,not configured,
IDE14245-MAS19741,Component protection configuration-Configuration bit 11,not configured,
IDE14245-MAS19742,Component protection configuration-Configuration bit 12,not configured,
IDE14245-MAS19743,Component protection configuration-Configuration bit 13,not configured,
IDE14245-MAS19744,Component protection configuration-Configuration bit 14,not configured,
IDE14245-MAS19745,Component protection configuration-Configuration bit 15,not configured,
IDE14648-IDE06260,Integrated toll charge module-ID number,KYMT7EMMH,
IDE14694-MAS01580,Projection module in left matrix headlamp: supply-Activation,not coded/not installed,
IDE14694-MAS01737,Projection module in left matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14694-MAS12621,Projection module in left matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE14695-MAS01580,Projection module in right matrix headlamp: supply-Activation,not coded/not installed,
IDE14695-MAS01737,Projection module in right matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14695-MAS12621,Projection module in right matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Inside temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
MAS02311-MAS06614,Steering wheel heating button-Variant,not coded/not installed,
MAS02311-MAS07693,Steering wheel heating button-Button Status,not coded/not installed,
MAS02311-MAS07694,Steering wheel heating button-Button status on CAN,Initialization/not installed,
MAS02311-MAS07699,Steering wheel heating button-Status indicator light on CAN,OFF,
MAS02311-MAS08062,Steering wheel heating button-Indicator lamp activation,not coded/not installed,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0B 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,7,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
SFT00032-MAS01632,High beam assistant-Status,not coded/not installed,
SFT00032-MAS02832,High beam assistant-Malfunction status,not coded/not installed,
SFT00032-MAS09580,High beam assistant-Sensor status,not coded/not installed,
SFT00032-MAS09581,High beam assistant-PWM specs.,not coded/not installed,
SFT00032-MAS09582,High beam assistant-Status on combi,not coded/not installed,
SFT00032-MAS09583,High beam assistant-error status on combi,not coded/not installed,
SFT00032-MAS09584,High beam assistant-Sensor status on combi,not coded/not installed,
SFT00032-MAS09585,High beam assistant-Turn up headlights request,not coded/not installed,
ENG26452,AAU_adress_content,0,
ENG26468-ENG30676,Aftermarket_auxiliary_heater-Counter_of_activation_of_child_lock,0,
ENG26468-ENG32740,Aftermarket_auxiliary_heater-State_of_child_lock,Unknown (255),
ENG02609,average_Voltage_terminals,12.50, V
ENG128341-ENG110385,Climate_OBD-Channel,0,
ENG128341-ENG02514,Climate_OBD-Comma,not active,
ENG128341-ENG99000,Climate_OBD-Value,-9999,
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,DF34,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,DF72,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,DF72,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,DF42,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,DF55,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,DF57,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,DF44,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,DF47,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,DF31,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,DF33,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,DF33,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,1.14F,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,08.13.00F,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,08.13.00F,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,08.13.00F,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,08.11.00F,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,08.13.00F,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,08.11.01F,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,08.12.00F,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,08.13.00F,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,08.07.00F,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,08.07.00F,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,08.08.00F,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,08.13.00F,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,08.11.00F,
ENG02611-ENG02852,EVLS-block_counter_axial_in,12,
ENG02611-ENG02851,EVLS-block_counter_axial_out,18,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,18,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,12,
ENG02611-ENG02847,EVLS-drivers_door_open,Open,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not active,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not active,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not active,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not active,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,00000000 00000000 ,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,No malfunction,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,00000001 ,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,00000000 11000001 ,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,00000000 11000001 ,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,no_global_break_off,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,no_assignation,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,no_storage,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,no_button_mode,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,no_tip_mode,
ENG02611-ENG02846,EVLS-LSV_EE_switch,operated,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not active,
ENG48509-MAS17268,FoD_slave_operating_state-Functions which can be activated: connection error counter,02,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0B 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,available.,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition not met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,7,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG101323,Headlight leveling control state,Measuring value not available,
ENG02610,interior_temperature,21.00, °C
ENG116001-ENG116135,itm_toll_modul-itm_event_acknowledge,no_event,
ENG116001-ENG116125,itm_toll_modul-ITM_number_of_occupants,single_driver,
ENG116001-ENG116101,itm_toll_modul-itm_on_off,itm_off,
ENG107365,Left dynamic cornering light value,Measuring value not available,
ENG107366,Left headlight leveling motor position,Measuring value not available,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,not active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,805, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,416, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,258, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,0,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,127,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,159,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,140,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,140,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,0,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,0,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,0,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,23224,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,662,
ENG108468,Right dynamic cornering light value,Measuring value not available,
ENG108469,Right headlight leveling motor position,Measuring value not available,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,0,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG27168-ENG32809,sw_history-sw_version_1,----,
ENG27168-ENG32810,sw_history-sw_version_2,----,
ENG27168-ENG32811,sw_history-sw_version_3,----,
ENG27168-ENG32812,sw_history-sw_version_4,----,
ENG27168-ENG32813,sw_history-sw_version_5,----,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I688,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,l700,
ENG03703-ENG109174,sw_version_integration_ara-SW_VERSION,A688,
ENG03703-ENG32814,sw_version_integration_ara-sw_version_camera,A708,
ENG27169-ENG32815,sw_version_integration_klima-sw_version_climate_control,7088,
ENG27169-ENG32816,sw_version_integration_klima-sw_version_preh_uif,0000,
ENG27169-ENG32817,sw_version_integration_klima-sw_version_psd,P688,
ENG27169-ENG32818,sw_version_integration_klima-sw_version_ssb,0000,
ENG27170-ENG109174,sw_version_integration_sufk-SW_VERSION,H680,
ENG116032-ENG116128,tki_runtime-tki_runtime_100ms_max_1,2456, µs
ENG116032-ENG116113,tki_runtime-tki_runtime_100ms_max_2,4659, µs
ENG116032-ENG121530,tki_runtime-tki_runtime_100ms_max_3,1930, µs
ENG116032-ENG116119,tki_runtime-tki_runtime_10ms_max_1,2318, µs
ENG116032-ENG116133,tki_runtime-tki_runtime_10ms_max_2,1421, µs
ENG116032-ENG116089,tki_runtime-tki_runtime_20ms_max_1,3973, µs
ENG116032-ENG116141,tki_runtime-tki_runtime_overruns,0, µs
ENG116032-ENG116118,tki_runtime-tki_runtime_s0,6715, µs
ENG116032-ENG116110,tki_runtime-tki_runtime_s1,3184, µs
ENG116032-ENG116093,tki_runtime-tki_runtime_s2,6679, µs
ENG116032-ENG116122,tki_runtime-tki_runtime_s3,5391, µs
ENG116032-ENG116095,tki_runtime-tki_runtime_s4,6773, µs
ENG116032-ENG116121,tki_runtime-tki_runtime_s5,7743, µs
ENG116032-ENG116084,tki_runtime-tki_runtime_s6,6667, µs
ENG116032-ENG116117,tki_runtime-tki_runtime_s7,4869, µs
ENG116032-ENG116090,tki_runtime-tki_runtime_s8,6793, µs
ENG116032-ENG116102,tki_runtime-tki_runtime_s9,3302, µs
ENG116032-ENG116127,tki_runtime-tki_runtime_slotcycle_max,54198, µs
ENG121359-ENG127696,Washer_counter_pump1-Counter_1,1,
ENG121359-ENG127697,Washer_counter_pump1-Counter_2,3,
ENG121359-ENG127700,Washer_counter_pump1-Counter_3,0,
ENG121359-ENG127699,Washer_counter_pump1-Counter_4,4,
ENG121359-ENG127698,Washer_counter_pump1-Counter_5,6,
ENG121359-ENG127701,Washer_counter_pump1-Counter_6,10.50, s
ENG121360-ENG127696,Washer_counter_sra-Counter_1,0,
ENG121360-ENG127697,Washer_counter_sra-Counter_2,2,
ENG121360-ENG127700,Washer_counter_sra-Counter_3,0,
ENG121360-ENG127699,Washer_counter_sra-Counter_4,2,
ENG121360-ENG127698,Washer_counter_sra-Counter_5,0,
ENG121360-ENG127701,Washer_counter_sra-Counter_6,1.80, s
Elapsed Time: 03:54
;SW:4N0-907-063-JE HW:4N0-907-063-AE --- Cent. Elect.
;Component:BCM1 MLBevo H10 0712, Coding:07500363C0291CDD070E57A81CEF9C2A131BB7511406049381050A00020196000869020200100000000007030047081838021030C003F107000000000000000000
;EV_BCM1BOSCHAU651,017002,EV_BCM1BOSCHAU651_017.rod
;Thursday,15,October,2020,12:29:17:59422
;VCDS Version: Beta 20.9.1 (x64) Data version: 20200919 DS322.0
;VCID: 7AA6990AFC21D83B29F-802E
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00001-MAS15400-Production mode-Continuation of basic settings without tester,not active ,3
IDE00001-MAS15622-Production mode-Cleaning of rearview camera: changed actuation time,not active ,3
IDE00001-MAS16746-Production mode-Deactivate air recirculation door,not active ,3
IDE01476-Store air recirculation setting with terminal 15 OFF,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,-35 °C,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01501-Air leak to footwell,automatic ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE01550-Service position,155.00 ,2
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,installed ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE01996-SFT00216-Installation list: specified installations-Projection module in left matrix headlamp,not installed ,1
IDE01996-SFT00217-Installation list: specified installations-Projection module in right matrix headlamp,not installed ,1
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,not installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE05318-Retrofitted components installed,Default ,1
IDE05569-Compressor control in efficiency mode,Comfort mode ,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Air recirculation for production routines,Recirculating air ,1
IDE06769-Blower regulator for production routines,3 ,1
IDE07356-Position during interval mode,12.00 ,2
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE10118-Fan speed reduction for telephony,Not available ,1
IDE10119-Blower reduction during voice control,available. ,1
IDE10296-upper turn position,155.00 ,2
IDE10297-lower turn position,15.20 ,2
IDE10298-Alternating park position 1,6.79 ,2
IDE10299-Alternating park position 2,10.00 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 °C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,60 °C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,0 %,2
IDE10332-Roof electronics control module: child-safety dependent,independent ,1
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10362-MAS10458-Electrically adjustable steering column: adjustment speed-axial,47 1/s,2
IDE10362-MAS10462-Electrically adjustable steering column: adjustment speed-vertical,47 1/s,2
IDE10363-Electrically adjust. steering column: entry assist.,56 1/s,1
IDE10364-Electrically adjust. steering column: soft stop,3 ,1
IDE10661-Deactivation of start-stop function (climate control),not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE10914-Seat occupancy-depending A/C,Matching coding ,1
IDE11217-Show parking space,not activated ,1
IDE11549-Automatic query of the identification data on LIN-Bus,activated: no backup ,1
IDE11613-MAS01364-Rear seat ventilation: micro adjustment-Stage 1,0 %,3
IDE11613-MAS01365-Rear seat ventilation: micro adjustment-Stage 2,0 %,3
IDE11613-MAS01366-Rear seat ventilation: micro adjustment-Stage 3,0 %,3
IDE11794-MAS13241-Fragrance diffuser system control module-Aroma 1,0 ,2
IDE11794-MAS13242-Fragrance diffuser system control module-Aroma 2,1 ,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12291-A/C control and display heads: dimming,Dimming: no dimming when approaching ,1
IDE12360-MAS02201-Roof electronics control module 2: temperature-related dim.-Temperature,60 °C,2
IDE12360-MAS10404-Roof electronics control module 2: temperature-related dim.-max. brightness,0 %,2
IDE12361-Roof electronics control module 2: child-safety dependent,independent ,1
IDE13059-Cleaning of rearview camera: actuation time in production mode,2500 ms,2
MAS12843-Maneuvering brake function,activated ,1
MAS15621-Restart information,activated ,1
ENG264023-ENG264129-evls_pso_data_1-Axialposition,48 ,2
ENG264023-ENG264281-evls_pso_data_1-Vertikalposition,77 ,2
ENG264024-ENG264129-evls_pso_data_2-Axialposition,100 ,2
ENG264024-ENG264281-evls_pso_data_2-Vertikalposition,100 ,2
ENG264034-ENG264129-evls_pso_data_3-Axialposition,100 ,2
ENG264034-ENG264281-evls_pso_data_3-Vertikalposition,100 ,2
ENG264031-ENG264129-evls_pso_data_4-Axialposition,100 ,2
ENG264031-ENG264281-evls_pso_data_4-Vertikalposition,100 ,2
ENG264020-ENG264129-evls_pso_data_5-Axialposition,100 ,2
ENG264020-ENG264281-evls_pso_data_5-Vertikalposition,100 ,2
ENG264019-ENG264129-evls_pso_data_6-Axialposition,100 ,2
ENG264019-ENG264281-evls_pso_data_6-Vertikalposition,100 ,2
ENG264026-ENG264129-evls_pso_data_7-Axialposition,100 ,2
ENG264026-ENG264281-evls_pso_data_7-Vertikalposition,100 ,2
ENG116833-Fehlermaske,00 00 ,2
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
Elapsed Time: 01:42
46-Central Conv.
blockmap-46-4N0-907-064-EG
;SW:4N0-907-064-EG HW:4N0-907-064-G --- Central Conv.
;Component:BCM2 MLBevo H16 0224, Coding:013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0681010F15
;EV_BCM2CONTIAU651,011009,EV_BCM2CONTIAU651_011.rod
;Thursday,15,October,2020,12:31:11:59422
;VCID: 78A28302C22DCA2B5FB-802C
Group,Description,Actual
IDE00027-MAS04423,Status of brake signals-Automatic braking signal via CAN,not active,
IDE00027-MAS04424,Status of brake signals-Driver brakes signal via CAN,not active,
IDE00027-MAS06469,Status of brake signals-Brake light signal,not active,
IDE00027-MAS06470,Status of brake signals-Brake light signal via CAN,not active,
IDE00027-MAS06471,Status of brake signals-Request emergency brake display,OFF,
IDE00027-MAS15241,Status of brake signals-Brake light signal from brake booster control module,Not available,
IDE00096-MAS00364,Selector lever position-Shift lever / selector lever position,Selector lever in position P,
IDE00096-MAS06480,Selector lever position-Transmission park selector switch,not coded/not installed,
IDE00306-MAS02227,Fuel Level Sensor 1-Quality,10,
IDE00306-MAS06614,Fuel Level Sensor 1-Variant,Two-wire sensor,
IDE00306-MAS06615,Fuel Level Sensor 1-Soiling resistance,not coded/not installed,
IDE00306-MAS06621,Fuel Level Sensor 1-Raw value 1,03 26,
IDE00306-MAS06622,Fuel Level Sensor 1-Raw value 2,not coded/not installed,
IDE00306-MAS06623,Fuel Level Sensor 1-Sensor including soiling resistance,not coded/not installed,
IDE00306-MAS06624,Fuel Level Sensor 1-Sensor without soiling resistance,60,
IDE00306-MAS06643,Fuel Level Sensor 1-Resistance 1: measurable value,60,
IDE00306-MAS06644,Fuel Level Sensor 1-Resistance 2: measurable value,not coded/not installed,
IDE00307-MAS02227,Fuel Level Sensor 2-Quality,10,
IDE00307-MAS06614,Fuel Level Sensor 2-Variant,Two-wire sensor,
IDE00307-MAS06615,Fuel Level Sensor 2-Soiling resistance,not coded/not installed,
IDE00307-MAS06621,Fuel Level Sensor 2-Raw value 1,07 4F,
IDE00307-MAS06622,Fuel Level Sensor 2-Raw value 2,not coded/not installed,
IDE00307-MAS06623,Fuel Level Sensor 2-Sensor including soiling resistance,not coded/not installed,
IDE00307-MAS06624,Fuel Level Sensor 2-Sensor without soiling resistance,233,
IDE00307-MAS06643,Fuel Level Sensor 2-Resistance 1: measurable value,233,
IDE00307-MAS06644,Fuel Level Sensor 2-Resistance 2: measurable value,not coded/not installed,
IDE00308-MAS02227,Fuel Level Sensor 3-Quality,not coded/not installed,
IDE00308-MAS06614,Fuel Level Sensor 3-Variant,not coded/not installed,
IDE00308-MAS06615,Fuel Level Sensor 3-Soiling resistance,not coded/not installed,
IDE00308-MAS06621,Fuel Level Sensor 3-Raw value 1,not coded/not installed,
IDE00308-MAS06622,Fuel Level Sensor 3-Raw value 2,not coded/not installed,
IDE00308-MAS06623,Fuel Level Sensor 3-Sensor including soiling resistance,not coded/not installed,
IDE00308-MAS06624,Fuel Level Sensor 3-Sensor without soiling resistance,not coded/not installed,
IDE00308-MAS06643,Fuel Level Sensor 3-Resistance 1: measurable value,not coded/not installed,
IDE00308-MAS06644,Fuel Level Sensor 3-Resistance 2: measurable value,not coded/not installed,
IDE00309-MAS02227,Fuel Level Sensor 4-Quality,10,
IDE00309-MAS06614,Fuel Level Sensor 4-Variant,Two-wire sensor,
IDE00309-MAS06615,Fuel Level Sensor 4-Soiling resistance,not coded/not installed,
IDE00309-MAS06621,Fuel Level Sensor 4-Raw value 1,07 B9,
IDE00309-MAS06622,Fuel Level Sensor 4-Raw value 2,not coded/not installed,
IDE00309-MAS06623,Fuel Level Sensor 4-Sensor including soiling resistance,not coded/not installed,
IDE00309-MAS06624,Fuel Level Sensor 4-Sensor without soiling resistance,264,
IDE00309-MAS06643,Fuel Level Sensor 4-Resistance 1: measurable value,264,
IDE00309-MAS06644,Fuel Level Sensor 4-Resistance 2: measurable value,not coded/not installed,
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,2,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,OFF,
IDE01464-MAS06528,Rear window defogger-Release status,No enabling,
IDE01464-MAS06996,Rear window defogger-Validity of filtered outside temperature,valid,
IDE01464-MAS06997,Rear window defogger-Outside temperature: filtered,20.5, °C
IDE01464-MAS09460,Rear window defogger-Release status: convert. top ctrl. mod.,Not available,
IDE01464-MAS13453,Rear window defogger-Load requirement of 12 V energy management,no request,
IDE01537-MAS01581,Front windshield heater-Power consumption,not coded/not installed,
IDE01537-MAS01737,Front windshield heater-Diagnosis,not coded/not installed,
IDE01537-MAS04737,Front windshield heater-Indicator lamp,not coded/not installed,
IDE01537-MAS05030,Front windshield heater-Resistance,not coded/not installed,
IDE01537-MAS05851,Front windshield heater-Current power consumption,not coded/not installed,
IDE01537-MAS06535,Front windshield heater-Resistance: lower limit value,not coded/not installed,
IDE01537-MAS06536,Front windshield heater-Resistance: upper limit value,not coded/not installed,
IDE01537-MAS06537,Front windshield heater-Power consumption: target value,not coded/not installed,
IDE01537-MAS06726,Front windshield heater-Hardware / software version,not coded/not installed,
IDE01537-MAS06732,Front windshield heater-Status local activity,not coded/not installed,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,For,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,For,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02711-MAS01580,Rear wiper-Activation,not coded/not installed,
IDE02711-MAS07731,Rear wiper-No. of wisher cycles,not coded/not installed,
IDE02711-MAS07732,Rear wiper-Number of recognized blockings,not coded/not installed,
IDE02711-MAS07733,Rear wiper-Requirements rear window wiper,not coded/not installed,
IDE02711-MAS07939,Rear wiper-Rear window wiper motor diagnostic,not coded/not installed,
IDE02711-MAS07940,Rear wiper-Contact switch for rear window wiper end shelf,not coded/not installed,
IDE02711-MAS07965,Rear wiper-Contact switch for rear window wiper end shelf diagnostic,not coded/not installed,
IDE03008-MAS09566,Stop process prevented-Key not in vehicle,not active,
IDE03010-MAS09566,Number of prevented stop processes-Key not in vehicle,0,
IDE03527-MAS12075,CAN signals-Keyless entry and start authorization: driver info,0,
IDE03659-MAS03834,Roller test bench mode-Emergency signal flashing,not active,
IDE03659-MAS06320,Roller test bench mode-Status rolling mode,not active,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,12.666, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,12.680, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,12.638, V
IDE04254-MAS00215,Play protection for central locking-Fuel filler lid,not active,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking system,not active,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,Implausible,
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,34.5, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,Implausible,
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.0, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS00976,DWA History data for alarm triggering-Counter,6,
IDE05828-MAS02545,DWA History data for alarm triggering-Last,Activation by external system,
IDE05828-MAS02546,DWA History data for alarm triggering-Second to last,Activation by external system,
IDE05828-MAS02547,DWA History data for alarm triggering-Third to last,Activation by external system,
IDE05828-MAS02548,DWA History data for alarm triggering-Fourth to last,Activation by external system,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,0,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Key not in vehicle,
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded/not installed,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS04968,Vehicle positioning system-Vehicle positioning alarm,not coded/not installed,
IDE06926-MAS00106,History memory: reset counter-Year,2000,
IDE06926-MAS00107,History memory: reset counter-Month,0,
IDE06926-MAS00108,History memory: reset counter-Day,0,
IDE06926-MAS00109,History memory: reset counter-Hours,0,
IDE06926-MAS00110,History memory: reset counter-Minutes,0,
IDE06926-MAS00111,History memory: reset counter-Seconds,0,
IDE06926,History memory: reset counter,Watchdog Reset,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07159-MAS01155,Control module switch-off: counter-Control module,1,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,not coded/not installed,
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,not coded/not installed,
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,not coded/not installed,
IDE07293-IDE00500,History data of panic alarm-Hour,10,
IDE07293-IDE00501,History data of panic alarm-Minute,42,
IDE07293-MAS00107,History data of panic alarm-Month,10,
IDE07293-MAS00108,History data of panic alarm-Day,5,
IDE07293-MAS04478,History data of panic alarm-Cause for alarm activation,Panic button,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,Open,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08176,History data doors,11100001 ,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,Open,
IDE08177-MAS09895,Central locking system-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking system-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,unlocked,
IDE08177-MAS16237,Central locking system-Outside door handles,Initialization,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,Not operated,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,OFF,
IDE08180-IDE00500,History data central locking: last event-Hour,18,
IDE08180-IDE00501,History data central locking: last event-Minute,34,
IDE08180-MAS00106,History data central locking: last event-Year,not known,
IDE08180-MAS00107,History data central locking: last event-Month,10,
IDE08180-MAS00108,History data central locking: last event-Day,14,
IDE08180-MAS00111,History data central locking: last event-Seconds,0,
IDE08180-MAS01551,History data central locking: last event-Key number,1,
IDE08180-MAS06441,History data central locking: last event-Control-section / cause,Remote control,
IDE08181-IDE00500,History data central locking: second-to-last event-Hour,18,
IDE08181-IDE00501,History data central locking: second-to-last event-Minute,34,
IDE08181-MAS00106,History data central locking: second-to-last event-Year,not known,
IDE08181-MAS00107,History data central locking: second-to-last event-Month,10,
IDE08181-MAS00108,History data central locking: second-to-last event-Day,14,
IDE08181-MAS00111,History data central locking: second-to-last event-Seconds,0,
IDE08181-MAS01551,History data central locking: second-to-last event-Key number,1,
IDE08181-MAS06441,History data central locking: second-to-last event-Control-section / cause,Remote control,
IDE08182-IDE00500,History data central locking: third-to-last event-Hour,18,
IDE08182-IDE00501,History data central locking: third-to-last event-Minute,34,
IDE08182-MAS00106,History data central locking: third-to-last event-Year,not known,
IDE08182-MAS00107,History data central locking: third-to-last event-Month,10,
IDE08182-MAS00108,History data central locking: third-to-last event-Day,14,
IDE08182-MAS00111,History data central locking: third-to-last event-Seconds,0,
IDE08182-MAS01551,History data central locking: third-to-last event-Key number,1,
IDE08182-MAS06441,History data central locking: third-to-last event-Control-section / cause,Remote control,
IDE08183-IDE00500,History data central locking: fourth-to-last event-Hour,18,
IDE08183-IDE00501,History data central locking: fourth-to-last event-Minute,34,
IDE08183-MAS00106,History data central locking: fourth-to-last event-Year,not known,
IDE08183-MAS00107,History data central locking: fourth-to-last event-Month,10,
IDE08183-MAS00108,History data central locking: fourth-to-last event-Day,14,
IDE08183-MAS00111,History data central locking: fourth-to-last event-Seconds,0,
IDE08183-MAS01551,History data central locking: fourth-to-last event-Key number,1,
IDE08183-MAS06441,History data central locking: fourth-to-last event-Control-section / cause,Remote control,
IDE08184-IDE00500,History data central locking: fifth-to-last event-Hour,18,
IDE08184-IDE00501,History data central locking: fifth-to-last event-Minute,32,
IDE08184-MAS00106,History data central locking: fifth-to-last event-Year,not known,
IDE08184-MAS00107,History data central locking: fifth-to-last event-Month,10,
IDE08184-MAS00108,History data central locking: fifth-to-last event-Day,14,
IDE08184-MAS00111,History data central locking: fifth-to-last event-Seconds,30,
IDE08184-MAS01551,History data central locking: fifth-to-last event-Key number,1,
IDE08184-MAS06441,History data central locking: fifth-to-last event-Control-section / cause,Remote control,
IDE08187-MAS02362,Request direction flashing-Flashing: right,not active,
IDE08187-MAS02363,Request direction flashing-Flashing: left,not active,
IDE08189-MAS04309,Malfunction status flasher-Turn signal front left,No malfunction,
IDE08189-MAS04310,Malfunction status flasher-Turn signal front right,No malfunction,
IDE08189-MAS04311,Malfunction status flasher-Left rear turn signal,No malfunction,
IDE08189-MAS04312,Malfunction status flasher-Turn signal rear right,No malfunction,
IDE08190-MAS01281,Request exterior illumination-Back-up lamp,OFF,
IDE08190-MAS03836,Request exterior illumination-Rear fog lamp,OFF,
IDE08190-MAS06466,Request exterior illumination-Parking light left,OFF,
IDE08190-MAS06467,Request exterior illumination-Parking light right,OFF,
IDE08190-MAS06468,Request exterior illumination-Tail lamp,On,
IDE08194-MAS06982,Signals vehicle electrical system control module-Terminal 15 status signal,On,
IDE08194-MAS07716,Signals vehicle electrical system control module-Last status: terminal 15,On,
IDE08195-MAS06483,Access/Start Authorization Button-Access/start authorization button: contact 1,Not operated,
IDE08195-MAS06484,Access/Start Authorization Button-Access/start authorization button: contact 2,Not operated,
IDE08195-MAS06485,Access/Start Authorization Button-Access/start authorization button: contact 3,Not operated,
IDE08195-MAS06486,Access/Start Authorization Button-Access/start authorization button: contact 4,Not operated,
IDE08196-IDE12848,Terminal activation-Remote start relay or preconditioning,not active,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,active,
IDE08196-MAS07383,Terminal activation-Terminal 15 on CAN,active,
IDE08196-MAS07386,Terminal activation-Terminal 50 on CAN,not active,
IDE08196-MAS07715,Terminal activation-Activation: terminal 15,active,
IDE08196-MAS07716,Terminal activation-Last status: terminal 15,active,
IDE08196-MAS07719,Terminal activation-Terminal 50 status,not active,
IDE08197-IDE02666,Alarm horn for anti-theft warning system-Convertible top status,not coded/not installed,
IDE08197-MAS06495,Alarm horn for anti-theft warning system-Engine hood contact switch,closed,
IDE08197-MAS06507,Alarm horn for anti-theft warning system-Trailer disconnected,not coded/not installed,
IDE08197-MAS07350,Alarm horn for anti-theft warning system-Left headlamp,not coded/not installed,
IDE08197-MAS07351,Alarm horn for anti-theft warning system-Right headlamp,not coded/not installed,
IDE08197-MAS11121,Alarm horn for anti-theft warning system-Glass breakage sensor or glove box,not coded/not installed,
IDE08199-IDE00500,History data anti-theft protection: last event-Hour,0,
IDE08199-IDE00501,History data anti-theft protection: last event-Minute,0,
IDE08199-MAS00106,History data anti-theft protection: last event-Year,2000,
IDE08199-MAS00107,History data anti-theft protection: last event-Month,0,
IDE08199-MAS00108,History data anti-theft protection: last event-Day,0,
IDE08199-MAS04478,History data anti-theft protection: last event-Cause for alarm activation,No alarm,
IDE08200-IDE00500,History data anti-theft protection: second-to-last event-Hour,0,
IDE08200-IDE00501,History data anti-theft protection: second-to-last event-Minute,0,
IDE08200-MAS00106,History data anti-theft protection: second-to-last event-Year,2000,
IDE08200-MAS00107,History data anti-theft protection: second-to-last event-Month,0,
IDE08200-MAS00108,History data anti-theft protection: second-to-last event-Day,0,
IDE08200-MAS04478,History data anti-theft protection: second-to-last event-Cause for alarm activation,No alarm,
IDE08201-IDE00500,History data anti-theft protection: third-to-last event-Hour,0,
IDE08201-IDE00501,History data anti-theft protection: third-to-last event-Minute,0,
IDE08201-MAS00106,History data anti-theft protection: third-to-last event-Year,2000,
IDE08201-MAS00107,History data anti-theft protection: third-to-last event-Month,0,
IDE08201-MAS00108,History data anti-theft protection: third-to-last event-Day,0,
IDE08201-MAS04478,History data anti-theft protection: third-to-last event-Cause for alarm activation,No alarm,
IDE08202-IDE00500,History data anti-theft protection: fourth-to-last event-Hour,0,
IDE08202-IDE00501,History data anti-theft protection: fourth-to-last event-Minute,0,
IDE08202-MAS00106,History data anti-theft protection: fourth-to-last event-Year,2000,
IDE08202-MAS00107,History data anti-theft protection: fourth-to-last event-Month,0,
IDE08202-MAS00108,History data anti-theft protection: fourth-to-last event-Day,0,
IDE08202-MAS04478,History data anti-theft protection: fourth-to-last event-Cause for alarm activation,No alarm,
IDE08203-MAS05851,Rear shades-Current power consumption,0.00, A
IDE08203-MAS06258,Rear shades-Left child safety,not active,
IDE08203-MAS06259,Rear shades-Right child safety,active,
IDE08203-MAS06513,Rear shades-Driver side rear window shade button,Not operated,
IDE08203-MAS06514,Rear shades-assenger side rear window shade button,Not operated,
IDE08203-MAS06515,Rear shades-Rear shade button,NOT-DEFINED,
IDE08203-MAS06516,Rear shades-Rear window shade status,extended,
IDE08203-MAS06517,Rear shades-Rear spoiler counter,0,
IDE08204-MAS06520,Rear Lid Closed Sensor-Rear lid -closed- sensor 1,not coded/not installed,
IDE08204-MAS06521,Rear Lid Closed Sensor-Rear lid -closed- sensor 2,not coded/not installed,
IDE08204-MAS06522,Rear Lid Closed Sensor-Rear lid: Status,not coded/not installed,
IDE08206-MAS06714,Local data bus: bus level malfunction-Local data bus: malfunction status,No malfunction,
IDE08206-MAS06715,Local data bus: bus level malfunction-Local data bus 2: malfunction status,No malfunction,
IDE08206-MAS06716,Local data bus: bus level malfunction-Local data bus 3: malfunction status,No malfunction,
IDE08206-MAS06717,Local data bus: bus level malfunction-Local data bus 4: malfunction status,not coded/not installed,
IDE08206-MAS06718,Local data bus: bus level malfunction-Local data bus 5: malfunction status,not coded/not installed,
IDE08206-MAS06719,Local data bus: bus level malfunction-Local data bus 6: malfunction status,not coded/not installed,
IDE08206-MAS06720,Local data bus: bus level malfunction-Local data bus: malfunction counter,0,
IDE08206-MAS06721,Local data bus: bus level malfunction-Local data bus 2: malfunction counter,0,
IDE08206-MAS06722,Local data bus: bus level malfunction-Local data bus 3: malfunction counter,0,
IDE08206-MAS06723,Local data bus: bus level malfunction-Local data bus 4: malfunction counter,not coded/not installed,
IDE08206-MAS06724,Local data bus: bus level malfunction-Local data bus 5: malfunction counter,not coded/not installed,
IDE08206-MAS06725,Local data bus: bus level malfunction-Local data bus 6: malfunction counter,not coded/not installed,
IDE08208-MAS06528,Rear lid opener control module-Release status,No enabling,
IDE08208-MAS06529,Rear lid opener control module-Trailer recognition,no approach,
IDE08208-MAS06532,Rear lid opener control module-Foot gestic recognition,No foot gestic,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,No,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,No,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,00000000 ,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,00000000 ,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,00000000 ,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,00000000 ,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,00000000 ,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,00000000 ,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,00000000 ,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,20 97 9E 96,
IDE08240,Transponder ID Key 2,20 8E 8B D4,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,02 58 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,20 54 69 66,
IDE08343,Immobilizer Challenge,F9 54 C8 2C,
IDE08479,Signal type,no flashing function active,
IDE08631,Received Signal Strength Indicator (RSSI),133,
IDE09133-MAS01580,Output 1 for exterior lighting-Activation,0.0, %
IDE09133-MAS05851,Output 1 for exterior lighting-Current power consumption,0, mA
IDE09133-MAS08347,Output 1 for exterior lighting-Assigned event code,B133600,
IDE09133-MAS08349,Output 1 for exterior lighting-Type of connected lamp,LED,
IDE09134-MAS01580,Output 2 for exterior lighting-Activation,0.0, %
IDE09134-MAS05851,Output 2 for exterior lighting-Current power consumption,0, mA
IDE09134-MAS08347,Output 2 for exterior lighting-Assigned event code,B12CB00,
IDE09134-MAS08349,Output 2 for exterior lighting-Type of connected lamp,LED,
IDE09135-MAS01580,Output 3 for exterior lighting-Activation,0.0, %
IDE09135-MAS05851,Output 3 for exterior lighting-Current power consumption,0, mA
IDE09135-MAS08347,Output 3 for exterior lighting-Assigned event code,B143400,
IDE09135-MAS08349,Output 3 for exterior lighting-Type of connected lamp,LED,
IDE09136-MAS01580,Output 4 for exterior lighting-Activation,0.0, %
IDE09136-MAS05851,Output 4 for exterior lighting-Current power consumption,0, mA
IDE09136-MAS08347,Output 4 for exterior lighting-Assigned event code,B143600,
IDE09136-MAS08349,Output 4 for exterior lighting-Type of connected lamp,LED,
IDE09137-MAS01580,Output 5 for exterior lighting-Activation,100.0, %
IDE09137-MAS05851,Output 5 for exterior lighting-Current power consumption,360, mA
IDE09137-MAS08347,Output 5 for exterior lighting-Assigned event code,B16D600,
IDE09137-MAS08349,Output 5 for exterior lighting-Type of connected lamp,LED,
IDE09138-MAS01580,Output 6 for exterior lighting-Activation,100.0, %
IDE09138-MAS05851,Output 6 for exterior lighting-Current power consumption,634, mA
IDE09138-MAS08347,Output 6 for exterior lighting-Assigned event code,B16D700,
IDE09138-MAS08349,Output 6 for exterior lighting-Type of connected lamp,LED,
IDE09139-MAS01580,Output 7 for exterior lighting-Activation,Output not used,
IDE09139-MAS05851,Output 7 for exterior lighting-Current power consumption,Output not used,
IDE09139-MAS08347,Output 7 for exterior lighting-Assigned event code,Unknown (0),
IDE09139-MAS08349,Output 7 for exterior lighting-Type of connected lamp,Output not used,
IDE09140-MAS01580,Output 8 for exterior lighting-Activation,0.0, %
IDE09140-MAS05851,Output 8 for exterior lighting-Current power consumption,0, mA
IDE09140-MAS08347,Output 8 for exterior lighting-Assigned event code,B12C700,
IDE09140-MAS08349,Output 8 for exterior lighting-Type of connected lamp,LED,
IDE09141-MAS01580,Output 9 for exterior lighting-Activation,0.0, %
IDE09141-MAS05851,Output 9 for exterior lighting-Current power consumption,0, mA
IDE09141-MAS08347,Output 9 for exterior lighting-Assigned event code,B12CC00,
IDE09141-MAS08349,Output 9 for exterior lighting-Type of connected lamp,LED,
IDE09142-MAS01580,Output 10 for exterior lighting-Activation,0.0, %
IDE09142-MAS05851,Output 10 for exterior lighting-Current power consumption,0, mA
IDE09142-MAS08347,Output 10 for exterior lighting-Assigned event code,B143500,
IDE09142-MAS08349,Output 10 for exterior lighting-Type of connected lamp,LED,
IDE09143-MAS01580,Output 11 for exterior lighting-Activation,100.0, %
IDE09143-MAS05851,Output 11 for exterior lighting-Current power consumption,623, mA
IDE09143-MAS08347,Output 11 for exterior lighting-Assigned event code,B16D500,
IDE09143-MAS08349,Output 11 for exterior lighting-Type of connected lamp,LED,
IDE09144-MAS01580,Output 12 for exterior lighting-Activation,0.0, %
IDE09144-MAS05851,Output 12 for exterior lighting-Current power consumption,0, mA
IDE09144-MAS08347,Output 12 for exterior lighting-Assigned event code,B133500,
IDE09144-MAS08349,Output 12 for exterior lighting-Type of connected lamp,LED,
IDE09145-MAS01580,Output 13 for exterior lighting-Activation,0.0, %
IDE09145-MAS05851,Output 13 for exterior lighting-Current power consumption,0, mA
IDE09145-MAS08347,Output 13 for exterior lighting-Assigned event code,B121500,
IDE09145-MAS08349,Output 13 for exterior lighting-Type of connected lamp,LED,
IDE09146-MAS01580,Output 14 for exterior lighting-Activation,0.0, %
IDE09146-MAS05851,Output 14 for exterior lighting-Current power consumption,0, mA
IDE09146-MAS08347,Output 14 for exterior lighting-Assigned event code,B143700,
IDE09146-MAS08349,Output 14 for exterior lighting-Type of connected lamp,LED,
IDE09147-MAS01580,Output 15 for exterior lighting-Activation,100.0, %
IDE09147-MAS05851,Output 15 for exterior lighting-Current power consumption,330, mA
IDE09147-MAS08347,Output 15 for exterior lighting-Assigned event code,B16D400,
IDE09147-MAS08349,Output 15 for exterior lighting-Type of connected lamp,LED,
IDE09148-MAS01580,Output 16 for exterior lighting-Activation,0.0, %
IDE09148-MAS05851,Output 16 for exterior lighting-Current power consumption,0, mA
IDE09148-MAS08347,Output 16 for exterior lighting-Assigned event code,B12C800,
IDE09148-MAS08349,Output 16 for exterior lighting-Type of connected lamp,LED,
IDE09149-MAS01580,Output 17 for exterior lighting-Activation,0.0, %
IDE09149-MAS05851,Output 17 for exterior lighting-Current power consumption,0, mA
IDE09149-MAS08347,Output 17 for exterior lighting-Assigned event code,B12C600,
IDE09149-MAS08349,Output 17 for exterior lighting-Type of connected lamp,LED,
IDE09150-MAS01580,Output 18 for exterior lighting-Activation,0.0, %
IDE09150-MAS05851,Output 18 for exterior lighting-Current power consumption,0, mA
IDE09150-MAS08347,Output 18 for exterior lighting-Assigned event code,B133300,
IDE09150-MAS08349,Output 18 for exterior lighting-Type of connected lamp,LED,
IDE09151-MAS01580,Output 19 for exterior lighting-Activation,0.0, %
IDE09151-MAS05851,Output 19 for exterior lighting-Current power consumption,0, mA
IDE09151-MAS08347,Output 19 for exterior lighting-Assigned event code,B133400,
IDE09151-MAS08349,Output 19 for exterior lighting-Type of connected lamp,LED,
IDE09153-MAS01580,Output 20 for exterior lighting-Activation,Output not used,
IDE09153-MAS05851,Output 20 for exterior lighting-Current power consumption,Output not used,
IDE09153-MAS08347,Output 20 for exterior lighting-Assigned event code,Unknown (0),
IDE09153-MAS08349,Output 20 for exterior lighting-Type of connected lamp,Output not used,
IDE09157-MAS01580,Output 21 for exterior lighting-Activation,Output not used,
IDE09157-MAS05851,Output 21 for exterior lighting-Current power consumption,Output not used,
IDE09157-MAS08347,Output 21 for exterior lighting-Assigned event code,Unknown (0),
IDE09157-MAS08349,Output 21 for exterior lighting-Type of connected lamp,Output not used,
IDE09218-MAS06793,Key information-Number of adapted keys,2,
IDE09218-MAS07008,Key information-Number of keys to be adapted,2,
IDE09218-MAS08428,Key information-Number of the active key,1,
IDE09220-MAS01551,Information of last change code error-Key number,255,
IDE09220-MAS08433,Information of last change code error-Last OK counter status control module,FF FF FF FF,
IDE09220-MAS08434,Information of last change code error-Last OK counter status control module: redundant,FF FF FF FF,
IDE09220-MAS08435,Information of last change code error-Last OK counter status key,FF FF FF FF,
IDE09220-MAS08436,Information of last change code error-Counter status control module at error event,FF FF FF FF,
IDE09220-MAS08437,Information of last change code error-Counter status control module at error event: redundant,FF FF FF FF,
IDE09220-MAS08438,Information of last change code error-Counter status key at error event,FF FF FF FF,
IDE09220-MAS08460,Information of last change code error-Time between last OK recognition and error event,6553.500, s
IDE09221-MAS03692,Change code counter status-Key 1,00 00 0C 1D,
IDE09221-MAS03693,Change code counter status-Key 2,00 00 01 88,
IDE09221-MAS03694,Change code counter status-Key 3,Not adapted,
IDE09221-MAS03695,Change code counter status-Key 4,Not adapted,
IDE09221-MAS03696,Change code counter status-Key 5,Not adapted,
IDE09221-MAS03697,Change code counter status-Key 6,Not adapted,
IDE09221-MAS03698,Change code counter status-Key 7,Not adapted,
IDE09221-MAS03699,Change code counter status-Key 8,Not adapted,
IDE09250-MAS08462,Key search in vehicle interior-Authenticated key in search area,00000001 ,
IDE09250-MAS08463,Key search in vehicle interior-Authenticated key,00000001 ,
IDE09250-MAS08464,Key search in vehicle interior-Recognized key,00000001 ,
IDE09252-MAS08462,Key search in luggage compartment-Authenticated key in search area,00000001 ,
IDE09252-MAS08463,Key search in luggage compartment-Authenticated key,00000001 ,
IDE09252-MAS08464,Key search in luggage compartment-Recognized key,00000001 ,
IDE09253-MAS08462,Key search in left area-Authenticated key in search area,00000000 ,
IDE09253-MAS08463,Key search in left area-Authenticated key,00000001 ,
IDE09253-MAS08464,Key search in left area-Recognized key,00000001 ,
IDE09254-MAS08462,Key search in right area-Authenticated key in search area,00000000 ,
IDE09254-MAS08463,Key search in right area-Authenticated key,00000001 ,
IDE09254-MAS08464,Key search in right area-Recognized key,00000001 ,
IDE09255-MAS08462,Key search in rear area-Authenticated key in search area,00000000 ,
IDE09255-MAS08463,Key search in rear area-Authenticated key,00000000 ,
IDE09255-MAS08464,Key search in rear area-Recognized key,00000000 ,
IDE09401-IDE00500,History data central locking: sixth-to-last event-Hour,18,
IDE09401-IDE00501,History data central locking: sixth-to-last event-Minute,32,
IDE09401-MAS00106,History data central locking: sixth-to-last event-Year,not known,
IDE09401-MAS00107,History data central locking: sixth-to-last event-Month,10,
IDE09401-MAS00108,History data central locking: sixth-to-last event-Day,14,
IDE09401-MAS00111,History data central locking: sixth-to-last event-Seconds,0,
IDE09401-MAS01551,History data central locking: sixth-to-last event-Key number,1,
IDE09401-MAS06441,History data central locking: sixth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09402-IDE00500,History data central locking: seventh-to-last event-Hour,18,
IDE09402-IDE00501,History data central locking: seventh-to-last event-Minute,14,
IDE09402-MAS00106,History data central locking: seventh-to-last event-Year,not known,
IDE09402-MAS00107,History data central locking: seventh-to-last event-Month,10,
IDE09402-MAS00108,History data central locking: seventh-to-last event-Day,14,
IDE09402-MAS00111,History data central locking: seventh-to-last event-Seconds,30,
IDE09402-MAS01551,History data central locking: seventh-to-last event-Key number,1,
IDE09402-MAS06441,History data central locking: seventh-to-last event-Control-section / cause,Auto lock,
IDE09403-IDE00500,History data central locking: eighth-to-last event-Hour,18,
IDE09403-IDE00501,History data central locking: eighth-to-last event-Minute,13,
IDE09403-MAS00106,History data central locking: eighth-to-last event-Year,not known,
IDE09403-MAS00107,History data central locking: eighth-to-last event-Month,10,
IDE09403-MAS00108,History data central locking: eighth-to-last event-Day,14,
IDE09403-MAS00111,History data central locking: eighth-to-last event-Seconds,30,
IDE09403-MAS01551,History data central locking: eighth-to-last event-Key number,1,
IDE09403-MAS06441,History data central locking: eighth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09404-IDE00500,History data central locking: ninth-to-last event-Hour,11,
IDE09404-IDE00501,History data central locking: ninth-to-last event-Minute,21,
IDE09404-MAS00106,History data central locking: ninth-to-last event-Year,not known,
IDE09404-MAS00107,History data central locking: ninth-to-last event-Month,10,
IDE09404-MAS00108,History data central locking: ninth-to-last event-Day,14,
IDE09404-MAS00111,History data central locking: ninth-to-last event-Seconds,30,
IDE09404-MAS01551,History data central locking: ninth-to-last event-Key number,1,
IDE09404-MAS06441,History data central locking: ninth-to-last event-Control-section / cause,Remote control,
IDE09405-IDE00500,History data central locking: tenth-to-last event-Hour,11,
IDE09405-IDE00501,History data central locking: tenth-to-last event-Minute,7,
IDE09405-MAS00106,History data central locking: tenth-to-last event-Year,not known,
IDE09405-MAS00107,History data central locking: tenth-to-last event-Month,10,
IDE09405-MAS00108,History data central locking: tenth-to-last event-Day,14,
IDE09405-MAS00111,History data central locking: tenth-to-last event-Seconds,0,
IDE09405-MAS01551,History data central locking: tenth-to-last event-Key number,1,
IDE09405-MAS06441,History data central locking: tenth-to-last event-Control-section / cause,Remote control,
IDE09406-IDE00500,History data central locking: eleventh-to-last event-Hour,8,
IDE09406-IDE00501,History data central locking: eleventh-to-last event-Minute,2,
IDE09406-MAS00106,History data central locking: eleventh-to-last event-Year,not known,
IDE09406-MAS00107,History data central locking: eleventh-to-last event-Month,10,
IDE09406-MAS00108,History data central locking: eleventh-to-last event-Day,6,
IDE09406-MAS00111,History data central locking: eleventh-to-last event-Seconds,45,
IDE09406-MAS01551,History data central locking: eleventh-to-last event-Key number,1,
IDE09406-MAS06441,History data central locking: eleventh-to-last event-Control-section / cause,Remote control,
IDE09407-IDE00500,History data central locking: twelfth-to-last event-Hour,8,
IDE09407-IDE00501,History data central locking: twelfth-to-last event-Minute,2,
IDE09407-MAS00106,History data central locking: twelfth-to-last event-Year,not known,
IDE09407-MAS00107,History data central locking: twelfth-to-last event-Month,10,
IDE09407-MAS00108,History data central locking: twelfth-to-last event-Day,6,
IDE09407-MAS00111,History data central locking: twelfth-to-last event-Seconds,15,
IDE09407-MAS01551,History data central locking: twelfth-to-last event-Key number,1,
IDE09407-MAS06441,History data central locking: twelfth-to-last event-Control-section / cause,Remote control,
IDE09408-IDE00500,History data central locking: thirteenth-to-last event-Hour,8,
IDE09408-IDE00501,History data central locking: thirteenth-to-last event-Minute,2,
IDE09408-MAS00106,History data central locking: thirteenth-to-last event-Year,not known,
IDE09408-MAS00107,History data central locking: thirteenth-to-last event-Month,10,
IDE09408-MAS00108,History data central locking: thirteenth-to-last event-Day,6,
IDE09408-MAS00111,History data central locking: thirteenth-to-last event-Seconds,15,
IDE09408-MAS01551,History data central locking: thirteenth-to-last event-Key number,1,
IDE09408-MAS06441,History data central locking: thirteenth-to-last event-Control-section / cause,Remote control,
IDE09409-IDE00500,History data central locking: fourteenth-to-last event-Hour,8,
IDE09409-IDE00501,History data central locking: fourteenth-to-last event-Minute,0,
IDE09409-MAS00106,History data central locking: fourteenth-to-last event-Year,not known,
IDE09409-MAS00107,History data central locking: fourteenth-to-last event-Month,10,
IDE09409-MAS00108,History data central locking: fourteenth-to-last event-Day,6,
IDE09409-MAS00111,History data central locking: fourteenth-to-last event-Seconds,45,
IDE09409-MAS01551,History data central locking: fourteenth-to-last event-Key number,1,
IDE09409-MAS06441,History data central locking: fourteenth-to-last event-Control-section / cause,Auto lock,
IDE09410-IDE00500,History data central locking: fifteenth-to-last event-Hour,8,
IDE09410-IDE00501,History data central locking: fifteenth-to-last event-Minute,0,
IDE09410-MAS00106,History data central locking: fifteenth-to-last event-Year,not known,
IDE09410-MAS00107,History data central locking: fifteenth-to-last event-Month,10,
IDE09410-MAS00108,History data central locking: fifteenth-to-last event-Day,6,
IDE09410-MAS00111,History data central locking: fifteenth-to-last event-Seconds,45,
IDE09410-MAS01551,History data central locking: fifteenth-to-last event-Key number,1,
IDE09410-MAS06441,History data central locking: fifteenth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09411-IDE00500,History data central locking: sixteenth-to-last event-Hour,7,
IDE09411-IDE00501,History data central locking: sixteenth-to-last event-Minute,59,
IDE09411-MAS00106,History data central locking: sixteenth-to-last event-Year,not known,
IDE09411-MAS00107,History data central locking: sixteenth-to-last event-Month,10,
IDE09411-MAS00108,History data central locking: sixteenth-to-last event-Day,6,
IDE09411-MAS00111,History data central locking: sixteenth-to-last event-Seconds,45,
IDE09411-MAS01551,History data central locking: sixteenth-to-last event-Key number,1,
IDE09411-MAS06441,History data central locking: sixteenth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09412-IDE00500,History data central locking: seventeenth-to-last event-Hour,7,
IDE09412-IDE00501,History data central locking: seventeenth-to-last event-Minute,56,
IDE09412-MAS00106,History data central locking: seventeenth-to-last event-Year,not known,
IDE09412-MAS00107,History data central locking: seventeenth-to-last event-Month,10,
IDE09412-MAS00108,History data central locking: seventeenth-to-last event-Day,6,
IDE09412-MAS00111,History data central locking: seventeenth-to-last event-Seconds,45,
IDE09412-MAS01551,History data central locking: seventeenth-to-last event-Key number,1,
IDE09412-MAS06441,History data central locking: seventeenth-to-last event-Control-section / cause,Auto lock rear lid,
IDE09413-IDE00500,History data central locking: eighteenth-to-last event-Hour,10,
IDE09413-IDE00501,History data central locking: eighteenth-to-last event-Minute,43,
IDE09413-MAS00106,History data central locking: eighteenth-to-last event-Year,not known,
IDE09413-MAS00107,History data central locking: eighteenth-to-last event-Month,10,
IDE09413-MAS00108,History data central locking: eighteenth-to-last event-Day,5,
IDE09413-MAS00111,History data central locking: eighteenth-to-last event-Seconds,45,
IDE09413-MAS01551,History data central locking: eighteenth-to-last event-Key number,1,
IDE09413-MAS06441,History data central locking: eighteenth-to-last event-Control-section / cause,Remote control,
IDE09414-IDE00500,History data central locking: nineteenth-to-last event-Hour,10,
IDE09414-IDE00501,History data central locking: nineteenth-to-last event-Minute,43,
IDE09414-MAS00106,History data central locking: nineteenth-to-last event-Year,not known,
IDE09414-MAS00107,History data central locking: nineteenth-to-last event-Month,10,
IDE09414-MAS00108,History data central locking: nineteenth-to-last event-Day,5,
IDE09414-MAS00111,History data central locking: nineteenth-to-last event-Seconds,15,
IDE09414-MAS01551,History data central locking: nineteenth-to-last event-Key number,1,
IDE09414-MAS06441,History data central locking: nineteenth-to-last event-Control-section / cause,Remote control,
IDE09415-IDE00500,History data central locking: twentieth-to-last event-Hour,10,
IDE09415-IDE00501,History data central locking: twentieth-to-last event-Minute,43,
IDE09415-MAS00106,History data central locking: twentieth-to-last event-Year,not known,
IDE09415-MAS00107,History data central locking: twentieth-to-last event-Month,10,
IDE09415-MAS00108,History data central locking: twentieth-to-last event-Day,5,
IDE09415-MAS00111,History data central locking: twentieth-to-last event-Seconds,15,
IDE09415-MAS01551,History data central locking: twentieth-to-last event-Key number,1,
IDE09415-MAS06441,History data central locking: twentieth-to-last event-Control-section / cause,Remote control,
IDE09416,Control line for dynamic turn signal,not active,
IDE09840-MAS09380,CU for tailgate opener: counter readings-proximity detected,00 22,
IDE09840-MAS09381,CU for tailgate opener: counter readings-Foot gestic detected,00 22,
IDE09840-MAS09382,CU for tailgate opener: counter readings-De-activation,00 7B,
IDE09840-MAS09383,CU for tailgate opener: counter readings-Play protection activation,00 00,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE09841-MAS09386,CU for tailgate opener: sensor status-Sensor module connected,No,
IDE09917-MAS03692,Last change code counter status-Key 1,00 00 0C 08,
IDE09917-MAS03693,Last change code counter status-Key 2,00 00 01 86,
IDE09917-MAS03694,Last change code counter status-Key 3,Not adapted,
IDE09917-MAS03695,Last change code counter status-Key 4,Not adapted,
IDE09917-MAS03696,Last change code counter status-Key 5,Not adapted,
IDE09917-MAS03697,Last change code counter status-Key 6,Not adapted,
IDE09917-MAS03698,Last change code counter status-Key 7,Not adapted,
IDE09917-MAS03699,Last change code counter status-Key 8,Not adapted,
IDE10096-MAS01551,Radio remote control: last radio shot-Key number,1,
IDE10096-MAS06879,Radio remote control: last radio shot-Checksum,OK,
IDE10096-MAS08411,Radio remote control: last radio shot-Button for vehicle locking,Not operated,
IDE10096-MAS08412,Radio remote control: last radio shot-Button for vehicle unlocking,operated,
IDE10096-MAS08413,Radio remote control: last radio shot-Button for luggage compartment unlocking,Not operated,
IDE10096-MAS08414,Radio remote control: last radio shot-Panic button,Not operated,
IDE10096-MAS08415,Radio remote control: last radio shot-Battery status,New,
IDE10096-MAS08419,Radio remote control: last radio shot-Key condition,OK,
IDE10096-MAS08421,Radio remote control: last radio shot-Transponder ID: Byte 1,9E,
IDE10096-MAS08422,Radio remote control: last radio shot-Cryptography,OK,
IDE10096-MAS08423,Radio remote control: last radio shot-Rolling code information,Detection area 1,
IDE10096-MAS08427,Radio remote control: last radio shot-Time since last radio shot,255, s
IDE10096-MAS13216,Radio remote control: last radio shot-Front windshield remote unlocking button,Not operated,
IDE10096-MAS13230,Radio remote control: last radio shot-Freely assignable button,Not operated,
IDE10097-IDE01442,Comfort closing convert. top/rear lid-Pressing a button,no key actuated,
IDE10097-MAS06528,Comfort closing convert. top/rear lid-Release status,not enabled,
IDE10097-MAS08432,Comfort closing convert. top/rear lid-Requirement,No,
IDE10097-MAS09907,Comfort closing convert. top/rear lid-Key search,not active,
IDE10097-MAS09908,Comfort closing convert. top/rear lid-Key within reach,No,
IDE10097-MAS09909,Comfort closing convert. top/rear lid-Number of key searches,0,
IDE10097-MAS09910,Comfort closing convert. top/rear lid-Number of key responses,0,
IDE10098-MAS09911,Zone and area information key 1 - 4-Key 1: Zone information,not installed,
IDE10098-MAS09912,Zone and area information key 1 - 4-Key 1: Area information,not installed,
IDE10098-MAS09913,Zone and area information key 1 - 4-Key 2: Zone information,not installed,
IDE10098-MAS09914,Zone and area information key 1 - 4-Key 2: Area information,not installed,
IDE10098-MAS09915,Zone and area information key 1 - 4-Key 3: Zone information,Not adapted,
IDE10098-MAS09916,Zone and area information key 1 - 4-Key 3: Area information,Not adapted,
IDE10098-MAS09917,Zone and area information key 1 - 4-Key 4: Zone information,Not adapted,
IDE10098-MAS09918,Zone and area information key 1 - 4-Key 4: Area information,Not adapted,
IDE10099-MAS09919,Zone and area information key 5 - 8-Key 5: Zone information,Not adapted,
IDE10099-MAS09920,Zone and area information key 5 - 8-Key 5: Area information,Not adapted,
IDE10099-MAS09921,Zone and area information key 5 - 8-Key 6: Zone information,Not adapted,
IDE10099-MAS09922,Zone and area information key 5 - 8-Key 6: Area information,Not adapted,
IDE10099-MAS09923,Zone and area information key 5 - 8-Key 7: Zone information,Not adapted,
IDE10099-MAS09924,Zone and area information key 5 - 8-Key 7: Area information,Not adapted,
IDE10099-MAS09925,Zone and area information key 5 - 8-Key 8: Zone information,Not adapted,
IDE10099-MAS09926,Zone and area information key 5 - 8-Key 8: Area information,Not adapted,
IDE10100-MAS09931,Individual activation of antennae for access and start system-Access/start system antenna 1 in vehicle interior,136,
IDE10100-MAS09932,Individual activation of antennae for access and start system-Access/start system antenna in luggage compartment,136,
IDE10100-MAS09933,Individual activation of antennae for access and start system-Left Access/Start Authorization Antenna,132,
IDE10100-MAS09934,Individual activation of antennae for access and start system-Right Access/Start Authorization Antenna,120,
IDE10100-MAS09935,Individual activation of antennae for access and start system-Access/start system antenna 2 in vehicle interior,254,
IDE10159-MAS09936,Outside door handle sens.: frt. left-Unlocking sensor: proximity detected,No,
IDE10159-MAS09937,Outside door handle sens.: frt. left-Locking sensor: proximity detected,No,
IDE10159-MAS09938,Outside door handle sens.: frt. left-Unlocking sensor: activation detected,No,
IDE10159-MAS09939,Outside door handle sens.: frt. left-Locking sensor: activation detected,No,
IDE10159-MAS09951,Outside door handle sens.: frt. left-Receiving wakeup signal,No,
IDE10160-MAS09936,Outside door handle sens.: frt. right-Unlocking sensor: proximity detected,No,
IDE10160-MAS09937,Outside door handle sens.: frt. right-Locking sensor: proximity detected,No,
IDE10160-MAS09938,Outside door handle sens.: frt. right-Unlocking sensor: activation detected,No,
IDE10160-MAS09939,Outside door handle sens.: frt. right-Locking sensor: activation detected,No,
IDE10160-MAS09951,Outside door handle sens.: frt. right-Receiving wakeup signal,No,
IDE10161-MAS09936,Outside door handle sens.: left rear-Unlocking sensor: proximity detected,No,
IDE10161-MAS09937,Outside door handle sens.: left rear-Locking sensor: proximity detected,No,
IDE10161-MAS09938,Outside door handle sens.: left rear-Unlocking sensor: activation detected,No,
IDE10161-MAS09939,Outside door handle sens.: left rear-Locking sensor: activation detected,No,
IDE10161-MAS09951,Outside door handle sens.: left rear-Receiving wakeup signal,No,
IDE10162-MAS09936,Outside door handle sens.: right rear-Unlocking sensor: proximity detected,No,
IDE10162-MAS09937,Outside door handle sens.: right rear-Locking sensor: proximity detected,No,
IDE10162-MAS09938,Outside door handle sens.: right rear-Unlocking sensor: activation detected,No,
IDE10162-MAS09939,Outside door handle sens.: right rear-Locking sensor: activation detected,No,
IDE10162-MAS09951,Outside door handle sens.: right rear-Receiving wakeup signal,No,
IDE10190-MAS02040,Left front outside door handle sens.: status-Anti-play protection,not active,
IDE10190-MAS06517,Left front outside door handle sens.: status-Rear spoiler counter,0,
IDE10190-MAS08440,Left front outside door handle sens.: status-Activity,active,
IDE10191-MAS02040,Right front outside door handle sens.: status-Anti-play protection,not active,
IDE10191-MAS06517,Right front outside door handle sens.: status-Rear spoiler counter,0,
IDE10191-MAS08440,Right front outside door handle sens.: status-Activity,active,
IDE10192-MAS02040,Left rear outside door handle sens.: status-Anti-play protection,not active,
IDE10192-MAS06517,Left rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10192-MAS08440,Left rear outside door handle sens.: status-Activity,active,
IDE10193-MAS02040,Right rear outside door handle sens.: status-Anti-play protection,not active,
IDE10193-MAS06517,Right rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10193-MAS08440,Right rear outside door handle sens.: status-Activity,active,
IDE10262-MAS08462,Key search in vehicle interior (scan)-Authenticated key in search area,00000001 ,
IDE10262-MAS08463,Key search in vehicle interior (scan)-Authenticated key,00000001 ,
IDE10262-MAS08464,Key search in vehicle interior (scan)-Recognized key,00000001 ,
IDE10263-MAS03692,Transponder IDs found during last key search-Key 1,FF FF FF FF,
IDE10263-MAS03693,Transponder IDs found during last key search-Key 2,FF FF FF FF,
IDE10263-MAS03694,Transponder IDs found during last key search-Key 3,FF FF FF FF,
IDE10263-MAS03695,Transponder IDs found during last key search-Key 4,FF FF FF FF,
IDE10263-MAS03696,Transponder IDs found during last key search-Key 5,FF FF FF FF,
IDE10263-MAS03697,Transponder IDs found during last key search-Key 6,FF FF FF FF,
IDE10263-MAS03698,Transponder IDs found during last key search-Key 7,FF FF FF FF,
IDE10263-MAS03699,Transponder IDs found during last key search-Key 8,FF FF FF FF,
IDE10263-MAS10077,Transponder IDs found during last key search-Number of repeated searches,00,
IDE10263-MAS10078,Transponder IDs found during last key search-Number of keys found,00,
IDE10284-MAS03692,Number of "Key battery dead" recognitions-Key 1,0,
IDE10284-MAS03693,Number of "Key battery dead" recognitions-Key 2,0,
IDE10284-MAS03694,Number of "Key battery dead" recognitions-Key 3,Not adapted,
IDE10284-MAS03695,Number of "Key battery dead" recognitions-Key 4,Not adapted,
IDE10284-MAS03696,Number of "Key battery dead" recognitions-Key 5,Not adapted,
IDE10284-MAS03697,Number of "Key battery dead" recognitions-Key 6,Not adapted,
IDE10284-MAS03698,Number of "Key battery dead" recognitions-Key 7,Not adapted,
IDE10284-MAS03699,Number of "Key battery dead" recognitions-Key 8,Not adapted,
IDE10306-MAS10178,Rear window heater test: measures voltage differences-Pulse 1,0.174, V
IDE10306-MAS10179,Rear window heater test: measures voltage differences-Pulse 2,0.348, V
IDE10306-MAS10180,Rear window heater test: measures voltage differences-Pulse 3,0.202, V
IDE10306-MAS10181,Rear window heater test: measures voltage differences-Pulse 4,0.397, V
IDE10306-MAS10182,Rear window heater test: measures voltage differences-Pulse 5,0.425, V
IDE10306-MAS10183,Rear window heater test: measures voltage differences-Pulse 6,0.404, V
IDE10306-MAS10184,Rear window heater test: measures voltage differences-Pulse 7,0.000, V
IDE10306-MAS10185,Rear window heater test: measures voltage differences-Pulse 8,0.000, V
IDE10306-MAS10186,Rear window heater test: measures voltage differences-Pulse 9,0.000, V
IDE10306-MAS10187,Rear window heater test: measures voltage differences-Pulse 10,0.000, V
IDE10306-MAS10188,Rear window heater test: measures voltage differences-Pulse 11,0.000, V
IDE10306-MAS10189,Rear window heater test: measures voltage differences-Pulse 12,0.000, V
IDE10306-MAS10190,Rear window heater test: measures voltage differences-Pulse 13,0.000, V
IDE10306-MAS10191,Rear window heater test: measures voltage differences-Pulse 14,0.000, V
IDE10306-MAS10192,Rear window heater test: measures voltage differences-Pulse 15,0.000, V
IDE10306-MAS10193,Rear window heater test: measures voltage differences-Mean value,0.000, V
IDE10348,Trip distance data,31 00 00 00 00 00 00 00 00 00 46 14 00 00 01 57 41 55 38 53 41 46 38 58 4D 4E 30 30 32 33 33 30 FC 21 9B E0 5E 02 9E E4 00 C0 00 01 00 00 00 00 FF FF FF FF FF 04 00 00 00 51 FE 97 F6 3C 00 00 00 52 9D 24 93 49 00 00 00 52 9D 27 2B 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 02 73 3C 00 B5 3A 00 52 9D 27 E9 01 C1 01 00 A2 01 00 51 F9 2D 1E,
IDE10681,Blocked keys,00,
IDE10682-MAS00106,Historical data blocked keys-Year,2020,
IDE10682-MAS00107,Historical data blocked keys-Month,9,
IDE10682-MAS00108,Historical data blocked keys-Day,30,
IDE10682-MAS00109,Historical data blocked keys-Hours,14,
IDE10682-MAS00110,Historical data blocked keys-Minutes,47,
IDE10682-MAS00111,Historical data blocked keys-Seconds,0,
IDE10682-MAS01551,Historical data blocked keys-Key number,2,
IDE10682-MAS11095,Historical data blocked keys-Cause,0,
IDE10683-IDE00500,Historical data unsuccessful automatic cut-off terminal 15-Hour,0,
IDE10683-IDE00501,Historical data unsuccessful automatic cut-off terminal 15-Minute,4,
IDE10683-MAS00107,Historical data unsuccessful automatic cut-off terminal 15-Month,9,
IDE10683-MAS00108,Historical data unsuccessful automatic cut-off terminal 15-Day,29,
IDE10683-MAS08075,Historical data unsuccessful automatic cut-off terminal 15-Reason for shut-off attempt,Locking the vehicle,
IDE10683-MAS08080,Historical data unsuccessful automatic cut-off terminal 15-Failure reason,255,
IDE10683-MAS08081,Historical data unsuccessful automatic cut-off terminal 15-Reason for timer stop,11110111 ,
IDE10684-IDE00500,Historical data unsuccessful switch-on attempt term 15-Hour,0,
IDE10684-IDE00501,Historical data unsuccessful switch-on attempt term 15-Minute,0,
IDE10684-MAS00107,Historical data unsuccessful switch-on attempt term 15-Month,0,
IDE10684-MAS00108,Historical data unsuccessful switch-on attempt term 15-Day,0,
IDE10684-MAS08080,Historical data unsuccessful switch-on attempt term 15-Failure reason,255,
IDE10685-IDE00500,Historical data automatic cut-off terminal 15-Hour,0,
IDE10685-IDE00501,Historical data automatic cut-off terminal 15-Minute,3,
IDE10685-IDE04105,Historical data automatic cut-off terminal 15-Freeze frame conditions,00000000 00000000 ,
IDE10685-MAS00107,Historical data automatic cut-off terminal 15-Month,9,
IDE10685-MAS00108,Historical data automatic cut-off terminal 15-Day,29,
IDE10685-MAS08082,Historical data automatic cut-off terminal 15-Reason for shut-off,Diagnosis,
IDE10685-MAS08087,Historical data automatic cut-off terminal 15-Shut-off due to locking of vehicle: control section,Remote control,
IDE10685-MAS08091,Historical data automatic cut-off terminal 15-State before shut-off,00001111 ,
IDE10686-IDE00500,Historical data switch-on source terminal 15-Hour,12,
IDE10686-IDE00501,Historical data switch-on source terminal 15-Minute,18,
IDE10686-MAS00107,Historical data switch-on source terminal 15-Month,10,
IDE10686-MAS00108,Historical data switch-on source terminal 15-Day,15,
IDE10686-MAS11095,Historical data switch-on source terminal 15-Cause,Actuation of button for access and start authorization,
IDE10696-IDE00500,Histor.data switch-off terminal 15 by means of actuat. button-Hour,18,
IDE10696-IDE00501,Histor.data switch-off terminal 15 by means of actuat. button-Minute,31,
IDE10696-IDE04105,Histor.data switch-off terminal 15 by means of actuat. button-Freeze frame conditions,00000000 00000000 ,
IDE10696-MAS00107,Histor.data switch-off terminal 15 by means of actuat. button-Month,10,
IDE10696-MAS00108,Histor.data switch-off terminal 15 by means of actuat. button-Day,14,
IDE10696-MAS08082,Histor.data switch-off terminal 15 by means of actuat. button-Reason for shut-off,Normal shut-off,
IDE10696-MAS08091,Histor.data switch-off terminal 15 by means of actuat. button-State before shut-off,01001111 ,
IDE10750,Anti-theft warn. interior monitoring: version of parameter set,21 41,
IDE11484,Rear spoiler: position,not coded/not installed,
IDE11487-MAS12819,Trunk emergency release-Button for trunk emergency unlocking system,not coded/not installed,
IDE11487-MAS12820,Trunk emergency release-Luggage compartment emergency release button,not coded/not installed,
IDE11487-MAS12821,Trunk emergency release-Button for unlocking hood,not coded/not installed,
IDE11487-MAS12822,Trunk emergency release-Hood release motor,not coded/not installed,
IDE11487-MAS12823,Trunk emergency release-Enabling trunk emergency unlocking,not coded/not installed,
IDE11487-MAS12824,Trunk emergency release-Enabling trunk emerg. unlocking: reversed,Unknown (3),
IDE11487-MAS12825,Trunk emergency release-Error display in instrument panel cluster,not coded/not installed,
IDE11487-MAS17287,Trunk emergency release-Indicator lamp for luggage compartment emergency release,NOT-DEFINED,
IDE11487-MAS19653,Trunk emergency release-Indicator lamp for trunk emergency unlock: front,NOT-DEFINED,
IDE11778-MAS09936,Engine hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09937,Engine hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09938,Engine hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11778-MAS09939,Engine hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11778-MAS09951,Engine hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11779-MAS02040,Engine hood unlocking mechanism sensor: status-Anti-play protection,not coded/not installed,
IDE11779-MAS06517,Engine hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11779-MAS08440,Engine hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11780-MAS09936,Rear hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09937,Rear hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09938,Rear hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11780-MAS09939,Rear hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11780-MAS09951,Rear hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11781-MAS02040,Rear hood unlocking mechanism sensor: status-Anti-play protection,not coded/not installed,
IDE11781-MAS06517,Rear hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11781-MAS08440,Rear hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11917-MAS08462,Searching for key outside of vehicle-Authenticated key in search area,00000000 ,
IDE11917-MAS08463,Searching for key outside of vehicle-Authenticated key,00000001 ,
IDE11917-MAS08464,Searching for key outside of vehicle-Recognized key,00000001 ,
IDE11938-IDE02021,Piloted parking and vehicle stopping function-Comfort closing,not coded/not installed,
IDE11938-MAS00829,Piloted parking and vehicle stopping function-Access/start authorization,Not available,
IDE11938-MAS02362,Piloted parking and vehicle stopping function-Flashing: right,not coded/not installed,
IDE11938-MAS02363,Piloted parking and vehicle stopping function-Flashing: left,not coded/not installed,
IDE11938-MAS02444,Piloted parking and vehicle stopping function-Central locking system,not coded/not installed,
IDE11938-MAS09388,Piloted parking and vehicle stopping function-Engine run,no request,
IDE11938-MAS09907,Piloted parking and vehicle stopping function-Key search,Not available,
IDE11938-MAS13254,Piloted parking and vehicle stopping function-Active parking function,not coded/not installed,
IDE11938-MAS13454,Piloted parking and vehicle stopping function-Comfort closing: convertible top,not coded/not installed,
IDE11938-MAS13462,Piloted parking and vehicle stopping function-Hazard lights of emergency assistant,OFF,
IDE11938-MAS13469,Piloted parking and vehicle stopping function-Vehicle stopping function,not coded/not installed,
IDE11938-MAS14248,Piloted parking and vehicle stopping function-Unlocking by vehicle halt function,no request,
IDE11938-MAS14250,Piloted parking and vehicle stopping function-Radio key LED,Not available,
IDE11938-MAS14251,Piloted parking and vehicle stopping function-Driver information,Not available,
IDE11938-MAS14253,Piloted parking and vehicle stopping function-Confirmation flashing,not coded/not installed,
IDE11980-MAS01156,Windshield defroster relay-Communication status,not coded/not installed,
IDE11980-MAS01478,Windshield defroster relay-insufficient voltage,not coded/not installed,
IDE11980-MAS01479,Windshield defroster relay-Excessive voltage,not coded/not installed,
IDE11980-MAS01580,Windshield defroster relay-Activation,not coded/not installed,
IDE11980-MAS08432,Windshield defroster relay-Requirement,not coded/not installed,
IDE11980-MAS13674,Windshield defroster relay-Windshield defogger button,not coded/not installed,
IDE11980-MAS13675,Windshield defroster relay-Windshield defogger indicator lamp,not coded/not installed,
IDE11980-MAS13676,Windshield defroster relay-Power quota,not coded/not installed,
IDE11980-MAS13720,Windshield defroster relay-Error qualification,not coded/not installed,
IDE11980-MAS13724,Windshield defroster relay-Status of self-monitoring,not coded/not installed,
IDE11984-MAS10178,Result of checking relay for heated windshield-Pulse 1,0.000, V
IDE11984-MAS10179,Result of checking relay for heated windshield-Pulse 2,0.000, V
IDE11984-MAS10180,Result of checking relay for heated windshield-Pulse 3,0.000, V
IDE11984-MAS10181,Result of checking relay for heated windshield-Pulse 4,0.000, V
IDE11984-MAS10182,Result of checking relay for heated windshield-Pulse 5,0.000, V
IDE11984-MAS10183,Result of checking relay for heated windshield-Pulse 6,0.000, V
IDE11984-MAS10184,Result of checking relay for heated windshield-Pulse 7,0.000, V
IDE11984-MAS10185,Result of checking relay for heated windshield-Pulse 8,0.000, V
IDE11984-MAS10186,Result of checking relay for heated windshield-Pulse 9,0.000, V
IDE11984-MAS10187,Result of checking relay for heated windshield-Pulse 10,0.000, V
IDE11984-MAS10188,Result of checking relay for heated windshield-Pulse 11,0.000, V
IDE11984-MAS10189,Result of checking relay for heated windshield-Pulse 12,0.000, V
IDE11984-MAS10190,Result of checking relay for heated windshield-Pulse 13,0.000, V
IDE11984-MAS10191,Result of checking relay for heated windshield-Pulse 14,0.000, V
IDE11984-MAS10192,Result of checking relay for heated windshield-Pulse 15,0.000, V
IDE11984-MAS10193,Result of checking relay for heated windshield-Mean value,0.000, V
IDE11996-MAS13729,Sunshade 2-Button for rear sunshade in operat. and numb. for A/C sys:rear,not coded/not installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,Yes,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12262-MAS18563,Virtual radio key: status-Smartcard active,No,
IDE12263,Virtual radio key: vehicle ID,2E 63 D6 FA 9C C4 87 11 1E 5A 20 43 72 88 C1 38,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 64 5A 02 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,00 00 00 00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,39 54 3E 98,
IDE12304-IDE00500,Separation monitoring radio key to rear lid: history-Hour,16,
IDE12304-IDE00501,Separation monitoring radio key to rear lid: history-Minute,26,
IDE12304-MAS00111,Separation monitoring radio key to rear lid: history-Seconds,7,
IDE12304-MAS14238,Separation monitoring radio key to rear lid: history-Key found in Zone 1,00000000 ,
IDE12304-MAS14239,Separation monitoring radio key to rear lid: history-Key found in Zone 2,00000000 ,
IDE12304-MAS14240,Separation monitoring radio key to rear lid: history-Key found in Zone 3,00000000 ,
IDE12304-MAS14241,Separation monitoring radio key to rear lid: history-Key found in Zone 4,00000000 ,
IDE12304-MAS15180,Separation monitoring radio key to rear lid: history-Part function carried out,00000101 ,
IDE12304-MAS15181,Separation monitoring radio key to rear lid: history-Cause of cancellation:,00000100 ,
IDE12466-IDE00500,Unlocking central locking system history data-Hour,18,
IDE12466-IDE00501,Unlocking central locking system history data-Minute,34,
IDE12466-MAS00106,Unlocking central locking system history data-Year,2020,
IDE12466-MAS00107,Unlocking central locking system history data-Month,10,
IDE12466-MAS00108,Unlocking central locking system history data-Day,14,
IDE12466-MAS00111,Unlocking central locking system history data-Seconds,19,
IDE12466-MAS01551,Unlocking central locking system history data-Key number,1,
IDE12466-MAS06441,Unlocking central locking system history data-Control-section / cause,Unlocking button of the radio key,
IDE12549-IDE00500,History data NFC authentication-Hour,not known,
IDE12549-IDE00501,History data NFC authentication-Minute,not known,
IDE12549-MAS00106,History data NFC authentication-Year,not known,
IDE12549-MAS00107,History data NFC authentication-Month,not known,
IDE12549-MAS00108,History data NFC authentication-Day,not known,
IDE12549-MAS00111,History data NFC authentication-Seconds,not known,
IDE12549-MAS14763,History data NFC authentication-Authentication type,FF,
IDE12549-MAS14764,History data NFC authentication-Authentication event,FF,
IDE12549-MAS14765,History data NFC authentication-Key number of NFC device,255,
IDE12549-MAS14766,History data NFC authentication-Authentication location,15,
IDE12834-MAS07359,Relay for preconditioning-via discreet wire,not coded/not installed,
IDE12834-MAS07360,Relay for preconditioning-via data bus,not coded/not installed,
IDE12834-MAS15268,Relay for preconditioning-Requirement from Climatronic control module,not coded/not installed,
IDE13319-MAS01634,Left tail light 1-Supply voltage,12.6, V
IDE13319-MAS02194,Left tail light 1-Temperature 1,29.7, °C
IDE13319-MAS02195,Left tail light 1-Temperature 2,28.5, °C
IDE13319-MAS16150,Left tail light 1-maximum forwards voltage,7.1, V
IDE13319-MAS16676,Left tail light 1-Counter for overtemperature shut-down,0,
IDE13320-MAS01634,Left tail light 2-Supply voltage,12.4, V
IDE13320-MAS02194,Left tail light 2-Temperature 1,29.2, °C
IDE13320-MAS02195,Left tail light 2-Temperature 2,28.8, °C
IDE13320-MAS16150,Left tail light 2-maximum forwards voltage,7.2, V
IDE13320-MAS16676,Left tail light 2-Counter for overtemperature shut-down,0,
IDE13321-MAS01634,Right rear tail lamp 1-Supply voltage,12.4, V
IDE13321-MAS02194,Right rear tail lamp 1-Temperature 1,28.6, °C
IDE13321-MAS02195,Right rear tail lamp 1-Temperature 2,28.2, °C
IDE13321-MAS16150,Right rear tail lamp 1-maximum forwards voltage,7.1, V
IDE13321-MAS16676,Right rear tail lamp 1-Counter for overtemperature shut-down,0,
IDE13322-MAS01634,Right rear tail lamp 2-Supply voltage,12.5, V
IDE13322-MAS02194,Right rear tail lamp 2-Temperature 1,29.4, °C
IDE13322-MAS02195,Right rear tail lamp 2-Temperature 2,28.8, °C
IDE13322-MAS16150,Right rear tail lamp 2-maximum forwards voltage,7.2, V
IDE13322-MAS16676,Right rear tail lamp 2-Counter for overtemperature shut-down,0,
IDE13345-MAS16268,Current Secure Element-Secure Element,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-MAS16269,Current Secure Element-Secure Element is contained in ticket table,No,
IDE13345-MAS16270,Current Secure Element-Secure element is authenticated,No,
IDE13403-IDE08980,Rear spoiler control module: input signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13403-IDE13404,Rear spoiler control module: input signals-Locking by keyless access authorization: driver door,not coded/not installed,
IDE13403-MAS00370,Rear spoiler control module: input signals-Vehicle speed,not coded/not installed,
IDE13403-MAS01443,Rear spoiler control module: input signals-Request by Engine Control Module,not coded/not installed,
IDE13403-MAS01468,Rear spoiler control module: input signals-Terminal 15,not coded/not installed,
IDE13403-MAS06253,Rear spoiler control module: input signals-Static current measuring mode,not coded/not installed,
IDE13403-MAS06429,Rear spoiler control module: input signals-Transport protection,not coded/not installed,
IDE13403-MAS16413,Rear spoiler control module: input signals-Unlock driver lock cylinder contact switch,not coded/not installed,
IDE13403-MAS16414,Rear spoiler control module: input signals-Lock driver lock cylinder contact switch,not coded/not installed,
IDE13405-IDE08980,Rear spoiler control module: output signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13405-MAS01478,Rear spoiler control module: output signals-insufficient voltage,not coded/not installed,
IDE13405-MAS01479,Rear spoiler control module: output signals-Excessive voltage,not coded/not installed,
IDE13405-MAS02040,Rear spoiler control module: output signals-Anti-play protection,not coded/not installed,
IDE13405-MAS02590,Rear spoiler control module: output signals-Red warning light,not coded/not installed,
IDE13405-MAS02591,Rear spoiler control module: output signals-Yellow warning light,not coded/not installed,
IDE13405-MAS04737,Rear spoiler control module: output signals-Indicator lamp,not coded/not installed,
IDE13405-MAS16466,Rear spoiler control module: output signals-Rear spoiler positioning button: status,not coded/not installed,
IDE13405-MAS16467,Rear spoiler control module: output signals-Stop position retracted,not coded/not installed,
IDE13405-MAS16470,Rear spoiler control module: output signals-Stop position extended,not coded/not installed,
IDE13405-MAS16471,Rear spoiler control module: output signals-Rear spoiler positioning: status,not coded/not installed,
IDE13405-MAS16472,Rear spoiler control module: output signals-Rear spoiler positioning motor: status,not coded/not installed,
IDE13405-MAS16473,Rear spoiler control module: output signals-Rear spoiler: malfunction status,not coded/not installed,
IDE13405-MAS16474,Rear spoiler control module: output signals-Manual operation blocked,not coded/not installed,
IDE13405-MAS16475,Rear spoiler control module: output signals-BAP signals,not coded/not installed,
IDE13870-MAS08462,Key search at charging socket 1-Authenticated key in search area,00000001 ,
IDE13870-MAS08463,Key search at charging socket 1-Authenticated key,00000001 ,
IDE13870-MAS08464,Key search at charging socket 1-Recognized key,00000001 ,
IDE13871-MAS08462,Key search at charging socket 2-Authenticated key in search area,00000001 ,
IDE13871-MAS08463,Key search at charging socket 2-Authenticated key,00000001 ,
IDE13871-MAS08464,Key search at charging socket 2-Recognized key,00000001 ,
IDE14063-MAS17372,Short circuit counter-Short circuits on rear window shade,0,
IDE14063-MAS17373,Short circuit counter-Short circuits on rear window wiper,0,
IDE14063-MAS17374,Short circuit counter-Short circuits on the alarm horn,0,
IDE14063-MAS17375,Short circuit counter-Maximum number of short circuits on rear window shade,1056,
IDE14063-MAS17376,Short circuit counter-Maximum number of short circuits on rear window wiper,62992,
IDE14063-MAS17377,Short circuit counter-Maximum number of short circuits on the alarm horn,74000,
IDE14063-MAS17378,Short circuit counter-Status of rear window shade,OK,
IDE14063-MAS17379,Short circuit counter-Status of rear window wiper,OK,
IDE14063-MAS17380,Short circuit counter-Status of alarm horn,OK,
IDE14071-MAS04361,Central locking system actuation counter-Counter 1,0,
IDE14071-MAS04362,Central locking system actuation counter-Counter 2,0,
IDE14071-MAS04363,Central locking system actuation counter-Counter 3,0,
IDE14071-MAS04364,Central locking system actuation counter-Counter 4,0,
IDE14071-MAS17381,Central locking system actuation counter-Interface 1: counter 1,0,
IDE14071-MAS17382,Central locking system actuation counter-Interface 2: counter 1,0,
IDE14071-MAS17383,Central locking system actuation counter-Interface 3: counter 1,0,
IDE14071-MAS17384,Central locking system actuation counter-Interface 1: counter 2,0,
IDE14071-MAS17385,Central locking system actuation counter-Interface 2: counter 2,0,
IDE14071-MAS17386,Central locking system actuation counter-Interface 3: counter 2,0,
IDE14071-MAS17387,Central locking system actuation counter-Interface 1: counter 3,0,
IDE14071-MAS17388,Central locking system actuation counter-Interface 2: counter 3,0,
IDE14071-MAS17389,Central locking system actuation counter-Interface 3: counter 3,0,
IDE14071-MAS17390,Central locking system actuation counter-Interface 1: counter 4,0,
IDE14071-MAS17391,Central locking system actuation counter-Interface 2: counter 4,0,
IDE14071-MAS17392,Central locking system actuation counter-Interface 3: counter 4,0,
IDE14245-MAS19730,Component protection configuration-Configuration bit 1,not configured,
IDE14245-MAS19731,Component protection configuration-Configuration bit 0,not activated,
IDE14245-MAS19732,Component protection configuration-Configuration bit 2,not configured,
IDE14245-MAS19733,Component protection configuration-Configuration bit 3,not configured,
IDE14245-MAS19734,Component protection configuration-Configuration bit 4,not configured,
IDE14245-MAS19735,Component protection configuration-Configuration bit 5,not configured,
IDE14245-MAS19736,Component protection configuration-Configuration bit 6,not configured,
IDE14245-MAS19737,Component protection configuration-Configuration bit 7,not configured,
IDE14245-MAS19738,Component protection configuration-Configuration bit 8,not configured,
IDE14245-MAS19739,Component protection configuration-Configuration bit 9,not configured,
IDE14245-MAS19740,Component protection configuration-Configuration bit 10,not configured,
IDE14245-MAS19741,Component protection configuration-Configuration bit 11,not configured,
IDE14245-MAS19742,Component protection configuration-Configuration bit 12,not configured,
IDE14245-MAS19743,Component protection configuration-Configuration bit 13,not configured,
IDE14245-MAS19744,Component protection configuration-Configuration bit 14,not configured,
IDE14245-MAS19745,Component protection configuration-Configuration bit 15,not configured,
IDE14551-MAS01580,Output 22 for exterior lighting-Activation,0.0, %
IDE14551-MAS05851,Output 22 for exterior lighting-Current power consumption,0, mA
IDE14551-MAS08347,Output 22 for exterior lighting-Assigned event code,Unknown (0),
IDE14551-MAS08349,Output 22 for exterior lighting-Type of connected lamp,LED,
IDE14552-MAS01580,Output 23 for exterior lighting-Activation,0.0, %
IDE14552-MAS05851,Output 23 for exterior lighting-Current power consumption,0, mA
IDE14552-MAS08347,Output 23 for exterior lighting-Assigned event code,Unknown (0),
IDE14552-MAS08349,Output 23 for exterior lighting-Type of connected lamp,LED,
IDE15163-MAS08462,Key search in the luggage compartment: front-Authenticated key in search area,00000001 ,
IDE15163-MAS08463,Key search in the luggage compartment: front-Authenticated key,00000001 ,
IDE15163-MAS08464,Key search in the luggage compartment: front-Recognized key,00000001 ,
IDE80001-MAS01483,Analysis 1-Software version,M165,
IDE80001-MAS06973,Analysis 1-Target hardware version BCM2, ,
IDE80001-MAS06974,Analysis 1-HF building block: hardware version,0023,
IDE80001-MAS06975,Analysis 1-HF building block: firmware version,0000,
IDE80001-MAS06976,Analysis 1-LF building block: hardware version,0034,
IDE80001-MAS06977,Analysis 1-LF building block: firmware version,2407,
IDE80001-MAS06978,Analysis 1-LF building block: version configuration data,0000,
IDE80001-MAS06979,Analysis 1-Version CDD_LF,0024,
IDE80001-MAS06980,Analysis 1-Version CDD_RF,0021,
MAS00077-MAS02345,Immobilizer-Current condition,Adapted,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,96,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-MAS10132,Immobilizer-Configuration Kessy coded,Yes,
MAS00077-MAS10133,Immobilizer-Configuration E vehicle,No,
MAS00077-MAS10134,Immobilizer-Configuration SHE,Yes,
MAS00077-MAS14181,Immobilizer-Configuration of virtual radio key ready,Yes,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 00 00 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Not available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,Yes,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,0,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG98397-ENG13709,Airbag-seat_belt_lock_driver_side,2,
ENG98397-ENG46648,Airbag-seat_occupied_driver_side,0,
ENG12918,antenna_freeze_frame,01010010 00000000 00000010 01000010 ,
ENG12884-ENG13852,Breaking_light_operating_mode-Intern_operating_mode,Driving_mode,
ENG12884-ENG13853,Breaking_light_operating_mode-Transition_operating_mode,00,
ENG12916,can_lin_communication_freeze_frame,00000001 00000000 00000010 01000010 ,
ENG12857-MAS06439,central_locking_crash_status-Crash status,not active,
ENG12857-MAS06440,central_locking_crash_status-Precrash status,Not available,
ENG12860-MAS00314,clutch_pedal_status-Clutch Pedal Switch,not coded/not installed,
ENG12860-MAS00363,clutch_pedal_status-Clutch pedal position,numerical value: no text,
ENG12860-MAS06475,clutch_pedal_status-Clutch Pedal Switch for Engine Start,not coded/not installed,
ENG12886-IDE01442,Comfort_close_convertible_top_and_trunk_lid-Pressing a button,no key actuated,
ENG12886-ENG13854,Comfort_close_convertible_top_and_trunk_lid-Key_search,No,
ENG12886-ENG13855,Comfort_close_convertible_top_and_trunk_lid-Key_within_reach,No,
ENG12886-ENG13857,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_responses,0,
ENG12886-ENG13856,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_searches,0,
ENG12905-ENG14003,communication_state_fbs-latest_job_number,52,
ENG12905-ENG14002,communication_state_fbs-latest_job_request_confirmation,00,
ENG12905-ENG14001,communication_state_fbs-latest_job_request_job_number,52,
ENG12905-ENG14004,communication_state_fbs-latest_job_result,00,
ENG12905-ENG14007,communication_state_fbs-latest_key_info_authentication,01,
ENG12905-ENG14005,communication_state_fbs-latest_key_info_job_number,52,
ENG12905-ENG14006,communication_state_fbs-latest_key_info_key_line,00,
ENG12905-ENG14008,communication_state_fbs-latest_key_info_position,00,
ENG12847-MAS04188,cutoff_levels-Transport mode,not active,
ENG12847-MAS06253,cutoff_levels-Static current measuring mode,not active,
ENG12847-MAS06428,cutoff_levels-Static current shut-off stage,Deactivation stage 0,
ENG12847-MAS06429,cutoff_levels-Transport protection,not active,
ENG114468-ENG109174,Cycle_data_flash_history-SW_VERSION,0224,
ENG12904-ENG13995,debug_fbs-debug_1,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13996,debug_fbs-debug_2,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13997,debug_fbs-debug_3,11111111 11111111 11110100 10010010 ,
ENG12904-ENG13998,debug_fbs-debug_4,11111111 11111111 11111001 00100011 ,
ENG12904-ENG13999,debug_fbs-debug_5,11111111 11111111 11111111 11111111 ,
ENG12904-ENG14000,debug_fbs-debug_6,00000000 00000000 00000000 00000000 ,
ENG12917,defect_fusi_voltage_error_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12903-ENG98504,diagnose_01_message-Day,15,
ENG12903-ENG98653,diagnose_01_message-Hour,12,
ENG12903-ENG98667,diagnose_01_message-Kilometers,74,
ENG12903-ENG98739,diagnose_01_message-Minute,31,
ENG12903-ENG98748,diagnose_01_message-Month,10,
ENG12903-ENG102365,diagnose_01_message-Second,55,
ENG12903-ENG99063,diagnose_01_message-Year,2020,
ENG12881-MAS11095,Diagnosis_data_sbc-Cause,0,
ENG12861-ENG13706,elv_01-elv_clamp_enabling,not coded/not installed,
ENG12861-ENG13707,elv_01-elv_interruption_request_clamp_enabling,not coded/not installed,
ENG12861-ENG13704,elv_01-elv_locked,not coded/not installed,
ENG12861-ENG13705,elv_01-elv_unlocked,not coded/not installed,
ENG12843-MAS00371,Engine_status-Engine RPM,752.00, /min
ENG12843-MAS04447,Engine_status-Engine running status,Engine running,
ENG12843-MAS06149,Engine_status-Terminal 75,active,
ENG12843-MAS06150,Engine_status-Terminal 50,not active,
ENG12843-MAS06712,Engine_status-Status drive readiness hybrid,ready,
ENG12843-ENG13701,Engine_status-restart_lock,not active,
ENG12843-ENG13702,Engine_status-start_from_msg,2,
ENG12843-ENG13700,Engine_status-start_stop_driver_command,Stopp_prohibition,
ENG12843-ENG13699,Engine_status-start_stop_engine_stop,not active,
ENG12843-ENG114851,Engine_status-Start_Stop_Restart,not active,
ENG12843-ENG121476,Engine_status-Start_Stop_status,system_active_not_enabled_by_start_stop_coordinator,
ENG122522-ENG99298,EPB_01-State,0,
ENG12890-ENG13891,Error_counter_keyless-lf_antenna_error,31,
ENG12890-ENG13893,Error_counter_keyless-Retries,0,
ENG12890-ENG13892,Error_counter_keyless-unsuccessfully_entry_exit_activities,163,
ENG12888-ENG13882,Error_counter_lf_hf_communication-Checksum_error_hf,17,
ENG12888-ENG13884,Error_counter_lf_hf_communication-cryptology_error,3,
ENG12888-ENG13883,Error_counter_lf_hf_communication-Data_error_hf,209,
ENG12919,exterior_handle_sensor_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12882-ENG13849,External_light_defect_reasons-Break_light,00000000 ,
ENG12882-ENG13851,External_light_defect_reasons-Other_reasons,00000000 00000000 ,
ENG12882-ENG13659,External_light_defect_reasons-Tail_light,00000000 ,
ENG12882-ENG13850,External_light_defect_reasons-Turn_signal_light,00000000 00000000 ,
ENG48509-ENG49940,FoD_slave_operating_state-FoD_slave_state,02,
ENG12920,fuel_sender_freeze_frame,00000010 00000000 00000000 00000000 ,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,00 00 00 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,Not available,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,not OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,Yes,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition not met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,0,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG12911-ENG14036,general_additional_freeze_frame-Ambient_temperature_not_filtered,22.0, °C
ENG12911-ENG14040,general_additional_freeze_frame-coprocessor_spi_status,00000000 ,
ENG12911-ENG14039,general_additional_freeze_frame-dataflash_status,00000000 ,
ENG12911-ENG02610,general_additional_freeze_frame-interior_temperature,20.5, °C
ENG12911-ENG13636,general_additional_freeze_frame-Operating_Status,00000000 00011101 ,
ENG12911-ENG104256,general_additional_freeze_frame-production_mode,not active,
ENG12911-ENG14038,general_additional_freeze_frame-reset_cause,00001001 ,
ENG12911-ENG108452,general_additional_freeze_frame-Reset_counter,17,
ENG12911-ENG13694,general_additional_freeze_frame-Stall_current_cutoff_level,Deactivation stage 0,
ENG12911-ENG13635,general_additional_freeze_frame-Stall_Current_Measuring_Mode,not active,
ENG12911-ENG14037,general_additional_freeze_frame-subnetwork_status,00000001 00000001 ,
ENG12911-ENG14035,general_additional_freeze_frame-terminal_control_intern_status,1B 02 5A 90 02 60,
ENG12911-ENG111086,general_additional_freeze_frame-Transport_Mode,not active,
ENG12911-ENG99010,general_additional_freeze_frame-Vehicle speed,0.00, km/h
ENG12859,hazard_warning_switch,Not operated,
ENG12858,hdsg_opening_acknowledge,not active,
ENG12910-ENG127696,HF_LF_Counters-Counter_1,0,
ENG12910-ENG14012,HF_LF_Counters-Counter_10,0,
ENG12910-ENG14013,HF_LF_Counters-Counter_11,0,
ENG12910-ENG14014,HF_LF_Counters-Counter_12,0,
ENG12910-ENG14015,HF_LF_Counters-Counter_13,0,
ENG12910-ENG14016,HF_LF_Counters-Counter_14,0,
ENG12910-ENG14017,HF_LF_Counters-Counter_15,0,
ENG12910-ENG14018,HF_LF_Counters-Counter_16,0,
ENG12910-ENG14019,HF_LF_Counters-Counter_17,0,
ENG12910-ENG14020,HF_LF_Counters-Counter_18,0,
ENG12910-ENG14021,HF_LF_Counters-Counter_19,0,
ENG12910-ENG127697,HF_LF_Counters-Counter_2,0,
ENG12910-ENG14022,HF_LF_Counters-Counter_20,0,
ENG12910-ENG14023,HF_LF_Counters-Counter_21,255,
ENG12910-ENG14024,HF_LF_Counters-Counter_22,255,
ENG12910-ENG14025,HF_LF_Counters-Counter_23,255,
ENG12910-ENG14026,HF_LF_Counters-Counter_24,255,
ENG12910-ENG14027,HF_LF_Counters-Counter_25,255,
ENG12910-ENG14028,HF_LF_Counters-Counter_26,255,
ENG12910-ENG14029,HF_LF_Counters-Counter_27,255,
ENG12910-ENG14030,HF_LF_Counters-Counter_28,255,
ENG12910-ENG14031,HF_LF_Counters-Counter_29,255,
ENG12910-ENG127700,HF_LF_Counters-Counter_3,0,
ENG12910-ENG14032,HF_LF_Counters-Counter_30,255,
ENG12910-ENG14033,HF_LF_Counters-Counter_31,0,
ENG12910-ENG14034,HF_LF_Counters-Counter_32,0,
ENG12910-ENG127699,HF_LF_Counters-Counter_4,0,
ENG12910-ENG127698,HF_LF_Counters-Counter_5,0,
ENG12910-ENG127701,HF_LF_Counters-Counter_6,0,
ENG12910-ENG14009,HF_LF_Counters-Counter_7,0,
ENG12910-ENG14010,HF_LF_Counters-Counter_8,0,
ENG12910-ENG14011,HF_LF_Counters-Counter_9,0,
ENG12883-ENG98842,ignition_switch_pag-Position,not coded/not installed,
ENG12921,Immobilizer_freeze_frame_1,00000000 00000000 00000000 00000000 ,
ENG12930,Immobilizer_freeze_frame_10,00000000 00000000 00000000 00000000 ,
ENG12931,Immobilizer_freeze_frame_11,00000000 00000000 00000000 00000000 ,
ENG12932,Immobilizer_freeze_frame_12,00000000 00000000 00000000 00000000 ,
ENG12933,Immobilizer_freeze_frame_13,00000000 00000000 00000000 00000000 ,
ENG12934,Immobilizer_freeze_frame_14,00000000 00000000 00000000 00000000 ,
ENG13201,Immobilizer_freeze_frame_15,00000000 00000000 00000000 00000000 ,
ENG12922,Immobilizer_freeze_frame_2,00000000 00000000 00000000 00000000 ,
ENG12923,Immobilizer_freeze_frame_3,00000000 00000000 00000000 00000000 ,
ENG12924,Immobilizer_freeze_frame_4,00000000 00000000 00000000 00000000 ,
ENG12925,Immobilizer_freeze_frame_5,00000000 00000000 00000000 00000000 ,
ENG12926,Immobilizer_freeze_frame_6,00000000 00000000 00000000 00000000 ,
ENG12927,Immobilizer_freeze_frame_7,00000000 00000000 00000000 00000000 ,
ENG12928,Immobilizer_freeze_frame_8,00000000 00000000 00000000 00000000 ,
ENG13196-ENG14609,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte1,00000000 00000000 ,
ENG13196-ENG14610,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte2,00111111 00000000 ,
ENG13196-ENG14611,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte3,00000000 00000000 ,
ENG13196-ENG14612,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte4,00000000 00000000 ,
ENG13196-ENG14613,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte5,00000000 00000000 ,
ENG13196-ENG14614,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte6,00001000 00000000 ,
ENG13196-ENG14615,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte7,00000010 00000000 ,
ENG13196-ENG14616,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte8,00000000 00000000 ,
ENG13196-ENG14617,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte1,00000000 00000000 ,
ENG13196-ENG14618,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte2,00000000 00000000 ,
ENG13196-ENG14619,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte3,00000000 00000000 ,
ENG13196-ENG14620,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte4,00000000 00000000 ,
ENG13196-ENG14621,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte5,00000000 00000000 ,
ENG13196-ENG14622,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte6,00000000 00000000 ,
ENG13196-ENG14623,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte7,00000000 00000000 ,
ENG13196-ENG14624,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte8,00000000 00000000 ,
ENG13196-ENG14625,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte1,00000000 00000000 ,
ENG13196-ENG14626,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte2,00000000 00000000 ,
ENG13196-ENG14627,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte3,00000000 00000000 ,
ENG13196-ENG14628,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte4,00000000 00000000 ,
ENG13196-ENG14629,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte5,00000000 00000000 ,
ENG13196-ENG14630,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte6,00000000 00000000 ,
ENG13196-ENG14631,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte7,00000000 00000000 ,
ENG13196-ENG14632,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte8,00000000 00000000 ,
ENG13196-ENG14633,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte1,00000000 00000000 ,
ENG13196-ENG14634,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte2,00000000 00000000 ,
ENG13196-ENG14635,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte3,00000000 00000000 ,
ENG13196-ENG14636,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte4,00000000 00000000 ,
ENG13196-ENG14637,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte5,00000000 00000000 ,
ENG13196-ENG14638,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte6,00000000 00000000 ,
ENG13196-ENG14639,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte7,00000000 00000000 ,
ENG13196-ENG14640,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte8,00000000 00000000 ,
ENG13196-ENG14641,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte1,00000000 00000000 ,
ENG13196-ENG14642,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte2,00000000 00000000 ,
ENG13196-ENG14643,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte3,00000000 00000000 ,
ENG13196-ENG14644,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte4,00000000 00000000 ,
ENG13196-ENG14645,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte5,00000000 00000000 ,
ENG13196-ENG14646,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte6,00000000 00000000 ,
ENG13196-ENG14647,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte7,00000000 00000000 ,
ENG13196-ENG14648,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte8,00000000 00000000 ,
ENG12889-ENG13886,Intern_conditions_advanced_key-Active_advanced_key_priority,254,
ENG12889-ENG13885,Intern_conditions_advanced_key-Aktive_activity,5E,
ENG12889-ENG13889,Intern_conditions_advanced_key-IDG_line_Luki,0,
ENG12889-ENG13890,Intern_conditions_advanced_key-IDG_line_VLuki,1,
ENG12889-ENG13887,Intern_conditions_advanced_key-Next_advanced_key_Activity,5E,
ENG12889-ENG13888,Intern_conditions_advanced_key-Next_advanced_key_priority,254,
ENG26920-ENG30365,IRUE_NGS_deactivation_via_mmi-ASG_Aktivation_State,3,
ENG26920-ENG31533,IRUE_NGS_deactivation_via_mmi-FSG_Aktivation_State,3,
ENG12912,key_error_freeze_frame,11001100 11111111 11111111 11111111 ,
ENG12909-MAS00106,Life_cycle_data_failed_keyless_search-Year,2020,
ENG12909-MAS00107,Life_cycle_data_failed_keyless_search-Month,10,
ENG12909-MAS00108,Life_cycle_data_failed_keyless_search-Day,6,
ENG12909-MAS00109,Life_cycle_data_failed_keyless_search-Hours,8,
ENG12909-MAS00110,Life_cycle_data_failed_keyless_search-Minutes,4,
ENG12909-MAS00111,Life_cycle_data_failed_keyless_search-Seconds,25,
ENG12909-ENG28817,Life_cycle_data_failed_keyless_search-Error_description,00000000 ,
ENG12909-ENG13626,Life_cycle_data_failed_keyless_search-Trigger,37,
ENG12907-MAS00106,Life_cycle_data_keyless_entry_exit_search-Year,2020,
ENG12907-MAS00107,Life_cycle_data_keyless_entry_exit_search-Month,10,
ENG12907-MAS00108,Life_cycle_data_keyless_entry_exit_search-Day,15,
ENG12907-MAS00109,Life_cycle_data_keyless_entry_exit_search-Hours,12,
ENG12907-MAS00110,Life_cycle_data_keyless_entry_exit_search-Minutes,18,
ENG12907-MAS00111,Life_cycle_data_keyless_entry_exit_search-Seconds,1,
ENG12907-ENG28815,Life_cycle_data_keyless_entry_exit_search-Operating_point,00001000 ,
ENG12907-ENG28814,Life_cycle_data_keyless_entry_exit_search-Search_result,00001000 ,
ENG12908-MAS00106,Life_cycle_data_keyless_event_search-Year,2020,
ENG12908-MAS00107,Life_cycle_data_keyless_event_search-Month,10,
ENG12908-MAS00108,Life_cycle_data_keyless_event_search-Day,15,
ENG12908-MAS00109,Life_cycle_data_keyless_event_search-Hours,12,
ENG12908-MAS00110,Life_cycle_data_keyless_event_search-Minutes,18,
ENG12908-MAS00111,Life_cycle_data_keyless_event_search-Seconds,51,
ENG12908-MAS00370,Life_cycle_data_keyless_event_search-Vehicle speed,0, km/h
ENG12908-ENG28816,Life_cycle_data_keyless_event_search-Search_cycle,00000000 ,
ENG12908-ENG28814,Life_cycle_data_keyless_event_search-Search_result,00000001 ,
ENG12908-ENG13626,Life_cycle_data_keyless_event_search-Trigger,9,
ENG12906-MAS00106,Life_cycle_data_keyless_go_search-Year,2020,
ENG12906-MAS00107,Life_cycle_data_keyless_go_search-Month,10,
ENG12906-MAS00108,Life_cycle_data_keyless_go_search-Day,15,
ENG12906-MAS00109,Life_cycle_data_keyless_go_search-Hours,12,
ENG12906-MAS00110,Life_cycle_data_keyless_go_search-Minutes,18,
ENG12906-MAS00111,Life_cycle_data_keyless_go_search-Seconds,9,
ENG12906-ENG28814,Life_cycle_data_keyless_go_search-Search_result,00001000 ,
ENG12906-ENG13626,Life_cycle_data_keyless_go_search-Trigger,00010000 ,
ENG12877-MAS00106,Life_cycle_data_reset_reasons_coprocessor-Year,2020,
ENG12877-MAS00107,Life_cycle_data_reset_reasons_coprocessor-Month,7,
ENG12877-MAS00108,Life_cycle_data_reset_reasons_coprocessor-Day,28,
ENG12877-MAS00109,Life_cycle_data_reset_reasons_coprocessor-Hours,19,
ENG12877-MAS00110,Life_cycle_data_reset_reasons_coprocessor-Minutes,14,
ENG12877-MAS00111,Life_cycle_data_reset_reasons_coprocessor-Seconds,38,
ENG12877-MAS11095,Life_cycle_data_reset_reasons_coprocessor-Cause,8,
ENG26927-MAS00106,Life_cycle_data_reset_reasons_main_processor_conti-Year,2020,
ENG26927-MAS00107,Life_cycle_data_reset_reasons_main_processor_conti-Month,7,
ENG26927-MAS00108,Life_cycle_data_reset_reasons_main_processor_conti-Day,28,
ENG26927-MAS00109,Life_cycle_data_reset_reasons_main_processor_conti-Hours,19,
ENG26927-MAS00110,Life_cycle_data_reset_reasons_main_processor_conti-Minutes,14,
ENG26927-MAS00111,Life_cycle_data_reset_reasons_main_processor_conti-Seconds,38,
ENG26927-MAS11095,Life_cycle_data_reset_reasons_main_processor_conti-Cause,14,
ENG26927-ENG32440,Life_cycle_data_reset_reasons_main_processor_conti-Register_EIIC,00 00 00 00,
ENG26927-ENG32441,Life_cycle_data_reset_reasons_main_processor_conti-Register_EIPC,00 0B 11 50,
ENG26927-ENG32442,Life_cycle_data_reset_reasons_main_processor_conti-Register_FEPC,65 B6 5C 23,
ENG12914,light_freeze_frame,00000000 00000000 01000100 00110000 ,
ENG117002-ENG13752,MFG-mfg_signals_CAN,not coded/not installed,
ENG12863-ENG13712,NVEM-request_kl15_deactivation,0,
ENG12874-ENG13836,Outputs_for_exterior_lighting-Output_1,not active,
ENG12874-ENG120566,Outputs_for_exterior_lighting-Output_10,not active,
ENG12874-ENG120567,Outputs_for_exterior_lighting-Output_11,active,
ENG12874-ENG120568,Outputs_for_exterior_lighting-Output_12,not active,
ENG12874-ENG120561,Outputs_for_exterior_lighting-Output_13,not active,
ENG12874-ENG120562,Outputs_for_exterior_lighting-Output_14,not active,
ENG12874-ENG120563,Outputs_for_exterior_lighting-Output_15,active,
ENG12874-ENG120564,Outputs_for_exterior_lighting-Output_16,not active,
ENG12874-ENG120557,Outputs_for_exterior_lighting-Output_17,not active,
ENG12874-ENG120558,Outputs_for_exterior_lighting-Output_18,not active,
ENG12874-ENG120559,Outputs_for_exterior_lighting-Output_19,not active,
ENG12874-ENG13837,Outputs_for_exterior_lighting-Output_2,not active,
ENG12874-ENG120560,Outputs_for_exterior_lighting-Output_20,Output not used,
ENG12874-ENG120553,Outputs_for_exterior_lighting-Output_21,Output not used,
ENG12874-ENG13838,Outputs_for_exterior_lighting-Output_3,not active,
ENG12874-ENG13839,Outputs_for_exterior_lighting-Output_4,not active,
ENG12874-ENG13840,Outputs_for_exterior_lighting-Output_5,active,
ENG12874-ENG13841,Outputs_for_exterior_lighting-Output_6,active,
ENG12874-ENG13842,Outputs_for_exterior_lighting-Output_7,Output not used,
ENG12874-ENG13843,Outputs_for_exterior_lighting-Output_8,not active,
ENG12874-ENG13844,Outputs_for_exterior_lighting-Output_9,not active,
ENG12869-ENG13749,park_heating_and_air_conditioning-auxiliary_ventilation_CAN,not active,
ENG12869-ENG02610,park_heating_and_air_conditioning-interior_temperature,20.5, °C
ENG12869-ENG13748,park_heating_and_air_conditioning-park_heating_CAN,not active,
ENG12869-ENG13750,park_heating_and_air_conditioning-solar_fan_CAN,not active,
ENG126653-IDE00500,Personalized_Account_Key_History-Hour,9,
ENG126653-IDE00501,Personalized_Account_Key_History-Minute,50,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,10,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,2,
ENG126653-MAS00111,Personalized_Account_Key_History-Seconds,3,
ENG126653-ENG29120,Personalized_Account_Key_History-Account_number,1,
ENG126653-ENG29858,Personalized_Account_Key_History-Device_number,1,
ENG12943-MAS03692,Personalized_key_setting-Key 1,0,
ENG12943-MAS03693,Personalized_key_setting-Key 2,0,
ENG12943-MAS03694,Personalized_key_setting-Key 3,0,
ENG12943-MAS03695,Personalized_key_setting-Key 4,0,
ENG12943-MAS03696,Personalized_key_setting-Key 5,0,
ENG12943-MAS03697,Personalized_key_setting-Key 6,0,
ENG12943-MAS03698,Personalized_key_setting-Key 7,0,
ENG12943-MAS03699,Personalized_key_setting-Key 8,0,
ENG126654-IDE00500,Personalized_Signals-Hour,18,
ENG126654-IDE00501,Personalized_Signals-Minute,34,
ENG126654-MAS00107,Personalized_Signals-Month,9,
ENG126654-MAS00108,Personalized_Signals-Day,28,
ENG126654-MAS00111,Personalized_Signals-Seconds,18,
ENG126654-ENG29120,Personalized_Signals-Account_number,1,
ENG126654-ENG98351,Personalized_Signals-active,active,
ENG126654-ENG29121,Personalized_Signals-Contol_mode,0,
ENG126654-ENG29122,Personalized_Signals-Control_parameter,0,
ENG126654-ENG29124,Personalized_Signals-Enabling_adjustment,Release,
ENG126654-ENG29123,Personalized_Signals-Position_of_actuation,Initialization,
ENG126654-ENG99298,Personalized_Signals-State,not active,
ENG13195-ENG14593,Personalized_smart_device_setting-Smart_device_1,0,
ENG13195-ENG14602,Personalized_smart_device_setting-Smart_device_10,0,
ENG13195-ENG14603,Personalized_smart_device_setting-Smart_device_11,0,
ENG13195-ENG14604,Personalized_smart_device_setting-Smart_device_12,0,
ENG13195-ENG14605,Personalized_smart_device_setting-Smart_device_13,0,
ENG13195-ENG14606,Personalized_smart_device_setting-Smart_device_14,0,
ENG13195-ENG14607,Personalized_smart_device_setting-Smart_device_15,0,
ENG13195-ENG14608,Personalized_smart_device_setting-Smart_device_16,0,
ENG13195-ENG14594,Personalized_smart_device_setting-Smart_device_2,0,
ENG13195-ENG14595,Personalized_smart_device_setting-Smart_device_3,0,
ENG13195-ENG14596,Personalized_smart_device_setting-Smart_device_4,0,
ENG13195-ENG14597,Personalized_smart_device_setting-Smart_device_5,0,
ENG13195-ENG14598,Personalized_smart_device_setting-Smart_device_6,0,
ENG13195-ENG14599,Personalized_smart_device_setting-Smart_device_7,0,
ENG13195-ENG14600,Personalized_smart_device_setting-Smart_device_8,0,
ENG13195-ENG14601,Personalized_smart_device_setting-Smart_device_9,0,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,01,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,22,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,22,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,22,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,01,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,10,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,22,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,22,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,10,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,10,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,10,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,70,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,10,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,01,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,10,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,01,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,10,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,01,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,22,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,70,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,09 10,
ENG114633-ENG108452,Reset_counter_coprocessor_conti-Reset_counter,02 07 00 00 00 04 00 01 00 00 00 0E,
ENG27088-ENG108452,Reset_counter_main_processor_conti-Reset_counter,01 00 00 00 00 00 00 00 02 0D 00 00 00 01 00 00 00 00,
ENG12897-ENG13902,service_key_counter_datagroup-datagroup_1,24,
ENG12897-ENG13903,service_key_counter_datagroup-datagroup_2,57,
ENG12897-ENG13904,service_key_counter_datagroup-datagroup_3,16,
ENG12897-ENG13905,service_key_counter_datagroup-datagroup_4,83,
ENG12899-ENG13914,service_key_intern_conditions-conditions,00000011 ,
ENG12899-ENG13916,service_key_intern_conditions-mq_states,00,
ENG12899-ENG13918,service_key_intern_conditions-obdc_changed_datagroup,00 00,
ENG12899-ENG13915,service_key_intern_conditions-obdc_interface_states,00000010 ,
ENG12899-ENG13917,service_key_intern_conditions-obdc_request_timeout_counter,30,
ENG12899-ENG13626,service_key_intern_conditions-Trigger,00000001 ,
ENG12901-ENG13983,service_key_key_store_counter-all_key_counter,271,
ENG12901-ENG13894,service_key_key_store_counter-key1_counter,158,
ENG12901-ENG13895,service_key_key_store_counter-key2_counter,109,
ENG12901-ENG13896,service_key_key_store_counter-key3_counter,Not adapted,
ENG12901-ENG13897,service_key_key_store_counter-key4_counter,Not adapted,
ENG12901-ENG13898,service_key_key_store_counter-key5_counter,Not adapted,
ENG12901-ENG13899,service_key_key_store_counter-key6_counter,Not adapted,
ENG12901-ENG13900,service_key_key_store_counter-key7_counter,Not adapted,
ENG12901-ENG13901,service_key_key_store_counter-key8_counter,Not adapted,
ENG12902-ENG13894,service_key_key_store_counter_per_day-key1_counter,13,
ENG12902-ENG13895,service_key_key_store_counter_per_day-key2_counter,6,
ENG12902-ENG13896,service_key_key_store_counter_per_day-key3_counter,Not adapted,
ENG12902-ENG13897,service_key_key_store_counter_per_day-key4_counter,Not adapted,
ENG12902-ENG13898,service_key_key_store_counter_per_day-key5_counter,Not adapted,
ENG12902-ENG13899,service_key_key_store_counter_per_day-key6_counter,Not adapted,
ENG12902-ENG13900,service_key_key_store_counter_per_day-key7_counter,Not adapted,
ENG12902-ENG13901,service_key_key_store_counter_per_day-key8_counter,Not adapted,
ENG12898-ENG13913,service_key_store_conditions-debounce_kilometer,15,
ENG12898-ENG13621,service_key_store_conditions-Distance,20,
ENG12898-ENG13911,service_key_store_conditions-hazard_warning_switch_delay_time,10,
ENG12898-ENG13908,service_key_store_conditions-retry_request_obdc,3,
ENG12898-ENG13906,service_key_store_conditions-service_key_coded,Yes,
ENG12898-ENG13907,service_key_store_conditions-timeout_request_obdc,30,
ENG12898-ENG13912,service_key_store_conditions-write_data_delay_time,40,
ENG12898-ENG13910,service_key_store_conditions-write_delay_speed,20,
ENG12898-ENG13909,service_key_store_conditions-write_delay_time,20,
ENG12900-ENG13920,service_key_store_time-key1_day,14,
ENG12900-ENG13919,service_key_store_time-key1_kilometer,73,
ENG12900-ENG13921,service_key_store_time-key1_month,10,
ENG12900-ENG13922,service_key_store_time-key1_year,2020,
ENG12900-ENG13924,service_key_store_time-key2_day,28,
ENG12900-ENG13923,service_key_store_time-key2_kilometer,52,
ENG12900-ENG13925,service_key_store_time-key2_month,9,
ENG12900-ENG13926,service_key_store_time-key2_year,2020,
ENG12900-ENG13928,service_key_store_time-key3_day,Not adapted,
ENG12900-ENG13927,service_key_store_time-key3_kilometer,Not adapted,
ENG12900-ENG13929,service_key_store_time-key3_month,Not adapted,
ENG12900-ENG13930,service_key_store_time-key3_year,Not adapted,
ENG12900-ENG13932,service_key_store_time-key4_day,Not adapted,
ENG12900-ENG13931,service_key_store_time-key4_kilometer,Not adapted,
ENG12900-ENG13933,service_key_store_time-key4_month,Not adapted,
ENG12900-ENG13934,service_key_store_time-key4_year,Not adapted,
ENG12900-ENG13936,service_key_store_time-key5_day,Not adapted,
ENG12900-ENG13935,service_key_store_time-key5_kilometer,Not adapted,
ENG12900-ENG13937,service_key_store_time-key5_month,Not adapted,
ENG12900-ENG13938,service_key_store_time-key5_year,Not adapted,
ENG12900-ENG13940,service_key_store_time-key6_day,Not adapted,
ENG12900-ENG13939,service_key_store_time-key6_kilometer,Not adapted,
ENG12900-ENG13941,service_key_store_time-key6_month,Not adapted,
ENG12900-ENG13942,service_key_store_time-key6_year,Not adapted,
ENG12900-ENG13944,service_key_store_time-key7_day,Not adapted,
ENG12900-ENG13943,service_key_store_time-key7_kilometer,Not adapted,
ENG12900-ENG13945,service_key_store_time-key7_month,Not adapted,
ENG12900-ENG13946,service_key_store_time-key7_year,Not adapted,
ENG12900-ENG13948,service_key_store_time-key8_day,Not adapted,
ENG12900-ENG13947,service_key_store_time-key8_kilometer,Not adapted,
ENG12900-ENG13949,service_key_store_time-key8_month,Not adapted,
ENG12900-ENG13950,service_key_store_time-key8_year,Not adapted,
ENG36577,short_circuit_counter_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12885,Software_version_fbs,M310805:SW_C2.6.M165_MLB_EVO_FBS,
ENG12856-MAS06262,sun_blind_power_limit_status-Roof blind 1,not active,
ENG12856-MAS06263,sun_blind_power_limit_status-Roof Blind 2,not active,
ENG12850-MAS06262,sun_blind_standardization_status-Roof blind 1,standardized,
ENG12850-MAS06263,sun_blind_standardization_status-Roof Blind 2,standardized,
ENG12853-MAS06262,sun_blind_thermal_protection_status-Roof blind 1,not active,
ENG12853-MAS06263,sun_blind_thermal_protection_status-Roof Blind 2,not active,
ENG12942-ENG14150,sun_roof_position-MD1_position,0, %
ENG12942-ENG14151,sun_roof_position-MD3_position,0, %
ENG12942-ENG14152,sun_roof_position-Sun_roof_2_position,not coded/not installed,
ENG12855-MAS06260,sun_roof_power_limit_status-Sunroof 1,not active,
ENG12855-MAS06261,sun_roof_power_limit_status-Sunroof 2,not coded/not installed,
ENG12870-ENG13754,sunroof_control_unit-sunroof_control_unit_signals_CAN,not coded/not installed,
ENG12849-MAS06260,sunroof_standardization_status-Sunroof 1,standardized,
ENG12849-MAS06261,sunroof_standardization_status-Sunroof 2,not coded/not installed,
ENG12852-MAS06260,sunroof_thermal_protection_status-Sunroof 1,not active,
ENG12852-MAS06261,sunroof_thermal_protection_status-Sunroof 2,not coded/not installed,
ENG12875-ENG13846,sw_version_in_house_development-Software_version_central_locking,15 1D 01 00,
ENG12875-ENG13845,sw_version_in_house_development-Software_version_clamp_control,10 04 01 1F,
ENG12875-ENG13847,sw_version_in_house_development-Software_version_reserve_1,,
ENG12875-ENG13848,sw_version_in_house_development-Software_version_reserve_2,,
ENG12876,System_load,4E,
ENG12862-ENG13711,systeminfo_01-diagnostics_active,active,
ENG12913,terminal_control_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12864-ENG13717,terminal_control_intern_conditions-restart_information,no_restart_detected,
ENG12864-ENG13716,terminal_control_intern_conditions-start_stop_information,engine_Start_and_engine_speed_detected,
ENG12864-ENG13714,terminal_control_intern_conditions-terminal_control_status,state_S4,
ENG12864-ENG13715,terminal_control_intern_conditions-terminal_control_status_terminals,00000011 ,
ENG12867-ENG13743,terminal_control_intern_signals-customer_request,00000000 ,
ENG12867-ENG13738,terminal_control_intern_signals-diagnostic_routine_kl15,00000000 ,
ENG12867-ENG13740,terminal_control_intern_signals-elv,00000010 ,
ENG12867-ENG13736,terminal_control_intern_signals-engine_brake_gearshift,00000011 ,
ENG12867-ENG13745,terminal_control_intern_signals-kl15_counter,141,
ENG12867-ENG13742,terminal_control_intern_signals-kl15_shut_off,00010101 ,
ENG12867-ENG13741,terminal_control_intern_signals-leave_concept,00000101 ,
ENG12867-ENG13739,terminal_control_intern_signals-p_mode,00000000 ,
ENG12867-ENG13737,terminal_control_intern_signals-sst,00000000 ,
ENG12867-ENG13744,terminal_control_intern_signals-start_trials,0,
ENG12865-ENG13719,terminal_control_klemmen_status_01-bz,2,
ENG12865-ENG13718,terminal_control_klemmen_status_01-crc,222,
ENG12865-ENG13723,terminal_control_klemmen_status_01-kst_driver_note_1,not active,
ENG12865-ENG13724,terminal_control_klemmen_status_01-kst_driver_note_2,not active,
ENG12865-ENG13725,terminal_control_klemmen_status_01-kst_driver_note_3,not active,
ENG12865-ENG13726,terminal_control_klemmen_status_01-kst_driver_note_4,not active,
ENG12865-ENG13727,terminal_control_klemmen_status_01-kst_driver_note_5,not active,
ENG12865-ENG13728,terminal_control_klemmen_status_01-kst_driver_note_6,not active,
ENG12865-ENG13721,terminal_control_klemmen_status_01-kst_warn_p1_zst_def,No malfunction,
ENG12865-ENG13722,terminal_control_klemmen_status_01-kst_warn_p2_zst_def,No malfunction,
ENG12865-ENG09864,terminal_control_klemmen_status_01-remote_start,not active,
ENG12865-ENG13627,terminal_control_klemmen_status_01-terminal_15,active,
ENG12865-ENG13629,terminal_control_klemmen_status_01-terminal_50,not active,
ENG12865-ENG13720,terminal_control_klemmen_status_01-terminal_infotainment,active,
ENG12865-ENG13628,terminal_control_klemmen_status_01-terminal_S,active,
ENG12865-ENG13637,terminal_control_klemmen_status_01-terminal_x,not active,
ENG12866-ENG13719,terminal_control_klemmen_steuerung_01-bz,6,
ENG12866-ENG13718,terminal_control_klemmen_steuerung_01-crc,47,
ENG12866-ENG13731,terminal_control_klemmen_steuerung_01-kst_anf_klemmenfreigabe_elv,not_requested,
ENG12866-ENG13735,terminal_control_klemmen_steuerung_01-kst_aut_abschaltung_zuendung,not active,
ENG12866-ENG13732,terminal_control_klemmen_steuerung_01-kst_elv_trigger_entriegelung,not_requested,
ENG12866-ENG13729,terminal_control_klemmen_steuerung_01-kst_txt_p_gang,OFF,
ENG12866-ENG13730,terminal_control_klemmen_steuerung_01-kst_txt_panikabschaltung,OFF,
ENG12866-ENG13734,terminal_control_klemmen_steuerung_01-kst_unterdr_zuendungsmeldung,not active,
ENG12866-ENG13733,terminal_control_klemmen_steuerung_01-kst_zat_betaetigt,Not operated,
ENG12868-ENG13746,terminal_control_task_state-clamp_state_1,10100111 ,
ENG12868-ENG13747,terminal_control_task_state-clamp_state_2,00000000 ,
ENG100973-MAS00370,Vehicle_speed-Vehicle speed,0.00, km/h
ENG100973-MAS05849,Vehicle_speed-Vehicle speed validity from bus,valid,
ENG12871-ENG13756,virtual_pedal_signals_LIN-vipe_01_byte1,00000000 00000000 ,
ENG12871-ENG13757,virtual_pedal_signals_LIN-vipe_01_byte2,00000000 00000000 ,
ENG12871-ENG13758,virtual_pedal_signals_LIN-vipe_01_byte3,00000000 00000000 ,
ENG12871-ENG13759,virtual_pedal_signals_LIN-vipe_01_byte4,0, %
ENG12871-ENG13760,virtual_pedal_signals_LIN-vipe_01_byte5,0,
ENG12871-ENG13761,virtual_pedal_signals_LIN-vipe_01_byte6,00000000 00000000 ,
ENG12871-ENG13762,virtual_pedal_signals_LIN-vipe_01_byte7,00000000 00000000 ,
ENG12871-ENG13763,virtual_pedal_signals_LIN-vipe_01_byte8,00000000 00000000 ,
ENG12871-ENG13764,virtual_pedal_signals_LIN-vips_01_byte1,00000000 00000000 ,
ENG12871-ENG13765,virtual_pedal_signals_LIN-vips_01_byte2,00000000 00000000 ,
ENG12871-ENG13766,virtual_pedal_signals_LIN-vips_01_byte3,00000000 00000000 ,
ENG12871-ENG13767,virtual_pedal_signals_LIN-vips_01_byte4,0,
ENG12871-ENG13768,virtual_pedal_signals_LIN-vips_01_byte5,00000000 00000000 ,
ENG12871-ENG13769,virtual_pedal_signals_LIN-vips_01_byte6,00000000 00000000 ,
ENG12871-ENG13770,virtual_pedal_signals_LIN-vips_01_byte7,00000000 00000000 ,
ENG12871-ENG13771,virtual_pedal_signals_LIN-vips_01_byte8,00000000 00000000 ,
ENG12887-ENG13880,wakepattern-Active_wakepattern,1E 1B B7 2F,
ENG12887-ENG13881,wakepattern-Next_wakepattern,FF FF FF FF,
ENG12891-ENG13894,wcs_counter-key1_counter,10,
ENG12891-ENG13895,wcs_counter-key2_counter,10,
ENG12891-ENG13896,wcs_counter-key3_counter,255,
ENG12891-ENG13897,wcs_counter-key4_counter,255,
ENG12891-ENG13898,wcs_counter-key5_counter,255,
ENG12891-ENG13899,wcs_counter-key6_counter,255,
ENG12891-ENG13900,wcs_counter-key7_counter,255,
ENG12891-ENG13901,wcs_counter-key8_counter,255,
ENG12854-MAS00218,window_lift_power_limit_status-Driver door,not active,
ENG12854-MAS00219,window_lift_power_limit_status-Front Passenger Door,not active,
ENG12854-MAS02555,window_lift_power_limit_status-driver side rear,not active,
ENG12854-MAS02556,window_lift_power_limit_status-passenger side rear,not active,
ENG12848-MAS00218,window_lift_standardization_status-Driver door,standardized,
ENG12848-MAS00219,window_lift_standardization_status-Front Passenger Door,standardized,
ENG12848-MAS02555,window_lift_standardization_status-driver side rear,standardized,
ENG12848-MAS02556,window_lift_standardization_status-passenger side rear,standardized,
ENG12851-MAS00218,window_lift_thermal_protection_status-Driver door,not active,
ENG12851-MAS00219,window_lift_thermal_protection_status-Front Passenger Door,not active,
ENG12851-MAS02555,window_lift_thermal_protection_status-driver side rear,not active,
ENG12851-MAS02556,window_lift_thermal_protection_status-passenger side rear,not active,
ENG110126-MAS00218,Window_Lifter_Position-Driver door,95.0, %
ENG110126-MAS00219,Window_Lifter_Position-Front Passenger Door,0.0, %
ENG110126-MAS02555,Window_Lifter_Position-driver side rear,0.0, %
ENG110126-MAS02556,Window_Lifter_Position-passenger side rear,0.0, %
ENG12915,zv_engine_lwr_rear_wiper_freeze_frame,10111110 00000000 00000000 00000000 ,
Elapsed Time: 01:18
;SW:4N0-907-064-EG HW:4N0-907-064-G --- Central Conv.
;Component:BCM2 MLBevo H16 0224, Coding:013400004FB000C0650FA0046C05090E0B004000810426502F0400200F04823F001E0681010F15
;EV_BCM2CONTIAU651,011009,EV_BCM2CONTIAU651_011.rod
;Thursday,15,October,2020,12:32:29:59422
;VCDS Version: Beta 20.9.1 (x64) Data version: 20200919 DS322.0
;VCID: 78A28302C22DCA2B5FB-802C
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10851-Production mode-Deactivate engine start,not active ,3
IDE00001-MAS10853-Production mode-Deactivate sensor-controlled rear lid opening,not active ,3
IDE00001-MAS10854-Production mode-Deactivate central locking: function lock,not active ,3
IDE00001-MAS10855-Production mode-Deactivate ignition switch-off when vehicle has been left,not active ,3
IDE00001-MAS12009-Production mode-Deactivate lighting,not active ,3
IDE00001-MAS12010-Production mode-Deactivate automatic unlocking,not active ,3
IDE00001-MAS17290-Production mode-Suppress further signal sources for “Terminal 15 on”,not active ,3
IDE00001-MAS21865-Production mode-Hood and rear lid release,not active ,3
IDE00001-MAS22198-Production mode-Inside button for front/read lid inactive,not active ,3
IDE00820-Activating and deactivating all development messages,00 ,1
IDE01464-MAS01167-Rear window defogger-Actuation time,600 s,2
IDE01464-MAS01186-Rear window defogger-Shut-off temperature,35.0 °C,2
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE04923-MAS08465-Turn signal control-Freeway flashing: flashing cycles,3 ,4
IDE04923-MAS08466-Turn signal control-Confirmation flashing unlocking central locking:flashing cycles,2 ,4
IDE04923-MAS08467-Turn signal control-Confirmation flashing locking central locking: flashing cycles,1 ,4
IDE04923-MAS10114-Turn signal control-Turn signal with relocking,On ,4
IDE04923-MAS10115-Turn signal control-Anti-theft blinkers by inter. door handle activ.,On ,4
IDE04923-MAS13291-Turn signal control-Motorway flashing cancel by counter tap,On ,4
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A 78 01 14 0A 03 81 33 0C FF 00 00 01 DE D6 06 00 0F 1E 00 85 0E 39 F7 63 23 65 42 57 9B 25 44 3F 3A 69 58 85 2E 0A A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 68 0F A3 42 87 9B 05 34 3A 3A 69 25 03 0A 0A A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 9B 05 24 3F 3A 69 47 03 0A 0A A3 04 23 15 4A 16 0A 16 1F 89 0B 28 51 32 0C 61 31 5B 94 05 24 8F FD 57 45 02 14 06 A2 05 61 06 03 17 0C 11 1A 87 02 23 33 69 23 65 42 57 9B 25 24 0C FA 0A 35 85 2D 0A A3 21 03 00 02 02 02 02 02 02 B1 21 41 28 8B ,172
IDE07279-Anti-theft warning system: monitoring diagnostics connection,On ,1
IDE07392-Terminal 15,Default ,1
IDE08221-MAS02444-Personalization settings key 1-Central locking system,Individual door opening ,3
IDE08221-MAS06456-Personalization settings key 1-Auto lock,On ,3
IDE08221-MAS06457-Personalization settings key 1-Auto unlock,On ,3
IDE08221-MAS06696-Personalization settings key 1-Comfort opening sunroof,OFF ,3
IDE08221-MAS06697-Personalization settings key 1-Acoustic confirmation signal,On ,3
IDE08221-MAS06698-Personalization settings key 1-Highway blinking,On ,3
IDE08221-MAS06740-Personalization settings key 1-Release button in rear lid handle locked,OFF ,3
IDE08221-MAS06756-Personalization settings key 1-Rear shade automatic,OFF ,3
IDE08221-MAS06880-Personalization settings key 1-Mirror fold-in (Audi),OFF ,3
IDE08221-MAS10221-Personalization settings key 1-Rear lid release via rear lid open sensors,On ,3
IDE08221-MAS10228-Personalization settings key 1-Comfort opening window: driver side,OFF ,3
IDE08221-MAS10229-Personalization settings key 1-Comfort opening window: frt. pass. side,OFF ,3
IDE08221-MAS10230-Personalization settings key 1-Comfort opening rear window: driver side,OFF ,3
IDE08221-MAS10231-Personalization settings key 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08222-MAS02444-Personalization settings key 2-Central locking system,Individual door opening ,3
IDE08222-MAS06456-Personalization settings key 2-Auto lock,On ,3
IDE08222-MAS06457-Personalization settings key 2-Auto unlock,On ,3
IDE08222-MAS06696-Personalization settings key 2-Comfort opening sunroof,OFF ,3
IDE08222-MAS06697-Personalization settings key 2-Acoustic confirmation signal,On ,3
IDE08222-MAS06698-Personalization settings key 2-Highway blinking,On ,3
IDE08222-MAS06740-Personalization settings key 2-Release button in rear lid handle locked,OFF ,3
IDE08222-MAS06756-Personalization settings key 2-Rear shade automatic,OFF ,3
IDE08222-MAS06880-Personalization settings key 2-Mirror fold-in (Audi),OFF ,3
IDE08222-MAS10221-Personalization settings key 2-Rear lid release via rear lid open sensors,On ,3
IDE08222-MAS10228-Personalization settings key 2-Comfort opening window: driver side,OFF ,3
IDE08222-MAS10229-Personalization settings key 2-Comfort opening window: frt. pass. side,OFF ,3
IDE08222-MAS10230-Personalization settings key 2-Comfort opening rear window: driver side,OFF ,3
IDE08222-MAS10231-Personalization settings key 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08223-MAS02444-Personalization settings key 3-Central locking system,Individual door opening ,3
IDE08223-MAS06456-Personalization settings key 3-Auto lock,On ,3
IDE08223-MAS06457-Personalization settings key 3-Auto unlock,On ,3
IDE08223-MAS06696-Personalization settings key 3-Comfort opening sunroof,OFF ,3
IDE08223-MAS06697-Personalization settings key 3-Acoustic confirmation signal,On ,3
IDE08223-MAS06698-Personalization settings key 3-Highway blinking,On ,3
IDE08223-MAS06740-Personalization settings key 3-Release button in rear lid handle locked,OFF ,3
IDE08223-MAS06756-Personalization settings key 3-Rear shade automatic,OFF ,3
IDE08223-MAS06880-Personalization settings key 3-Mirror fold-in (Audi),OFF ,3
IDE08223-MAS10221-Personalization settings key 3-Rear lid release via rear lid open sensors,On ,3
IDE08223-MAS10228-Personalization settings key 3-Comfort opening window: driver side,OFF ,3
IDE08223-MAS10229-Personalization settings key 3-Comfort opening window: frt. pass. side,OFF ,3
IDE08223-MAS10230-Personalization settings key 3-Comfort opening rear window: driver side,OFF ,3
IDE08223-MAS10231-Personalization settings key 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08224-MAS02444-Personalization settings key 4-Central locking system,Individual door opening ,3
IDE08224-MAS06456-Personalization settings key 4-Auto lock,On ,3
IDE08224-MAS06457-Personalization settings key 4-Auto unlock,On ,3
IDE08224-MAS06696-Personalization settings key 4-Comfort opening sunroof,OFF ,3
IDE08224-MAS06697-Personalization settings key 4-Acoustic confirmation signal,On ,3
IDE08224-MAS06698-Personalization settings key 4-Highway blinking,On ,3
IDE08224-MAS06740-Personalization settings key 4-Release button in rear lid handle locked,OFF ,3
IDE08224-MAS06756-Personalization settings key 4-Rear shade automatic,OFF ,3
IDE08224-MAS06880-Personalization settings key 4-Mirror fold-in (Audi),OFF ,3
IDE08224-MAS10221-Personalization settings key 4-Rear lid release via rear lid open sensors,On ,3
IDE08224-MAS10228-Personalization settings key 4-Comfort opening window: driver side,OFF ,3
IDE08224-MAS10229-Personalization settings key 4-Comfort opening window: frt. pass. side,OFF ,3
IDE08224-MAS10230-Personalization settings key 4-Comfort opening rear window: driver side,OFF ,3
IDE08224-MAS10231-Personalization settings key 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS02444-Personalization settings vehicle-Central locking system,Individual door opening ,3
IDE08225-MAS06456-Personalization settings vehicle-Auto lock,On ,3
IDE08225-MAS06457-Personalization settings vehicle-Auto unlock,On ,3
IDE08225-MAS06696-Personalization settings vehicle-Comfort opening sunroof,OFF ,3
IDE08225-MAS06697-Personalization settings vehicle-Acoustic confirmation signal,On ,3
IDE08225-MAS06698-Personalization settings vehicle-Highway blinking,On ,3
IDE08225-MAS06740-Personalization settings vehicle-Release button in rear lid handle locked,OFF ,3
IDE08225-MAS06756-Personalization settings vehicle-Rear shade automatic,OFF ,3
IDE08225-MAS06880-Personalization settings vehicle-Mirror fold-in (Audi),OFF ,3
IDE08225-MAS10221-Personalization settings vehicle-Rear lid release via rear lid open sensors,On ,3
IDE08225-MAS10228-Personalization settings vehicle-Comfort opening window: driver side,OFF ,3
IDE08225-MAS10229-Personalization settings vehicle-Comfort opening window: frt. pass. side,OFF ,3
IDE08225-MAS10230-Personalization settings vehicle-Comfort opening rear window: driver side,OFF ,3
IDE08225-MAS10231-Personalization settings vehicle-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS16238-Personalization settings vehicle-Keyless access authorization,On ,3
IDE08225-MAS20619-Personalization settings vehicle-Keyless access authorization: automatic opening,not active ,3
IDE08226-Use of personalization settings,Key ,1
IDE08398-Delay time alarm triggering,0 s,1
IDE08399-Delay time crash unlocking,5.0 s,1
IDE08400-Actuation time to open rear lid with remote control,800 ms,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,45 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,20 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,20 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,20 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,20 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,02 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,1F ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,02 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,1F ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,00 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,AA ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,00 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,09 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,C1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,00 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0B ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,AA ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,A6 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,CC ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,0D ,1
IDE09755-CU tailgate opener: sensor 1: burst length,10 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,10 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,02 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,1F ,1
IDE09759-CU for tailgate opener: reset all counters,E0 ,1
IDE09760-CU for tailgate opener: check sum,AA ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,02 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,1F ,1
IDE09831-CU for tailgate opener: play protection increments,06 ,1
IDE09832-CU for tailgate opener: play protection decrements,19 ,1
IDE09833-CU for tailgate opener: play protection threshold active,FF ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,05 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,3C ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,10 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,10 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,00 ,1
IDE09839-CU for tailgate opener: parameter set version,00 00 ,2
IDE10086-IDE02262-Personal settings of key 1: Part 2-synchronous mirror adjustment,OFF ,1
IDE10086-IDE03946-Personal settings of key 1: Part 2-Mirror dimming,OFF ,1
IDE10086-MAS05213-Personal settings of key 1: Part 2-Mirror heater,OFF ,1
IDE10086-MAS06870-Personal settings of key 1: Part 2-Mirror lowering in reverse,OFF ,1
IDE10086-MAS06881-Personal settings of key 1: Part 2-Mirror fold-in (VW),OFF ,1
IDE10087-IDE02262-Personal settings of key 2: Part 2-synchronous mirror adjustment,OFF ,1
IDE10087-IDE03946-Personal settings of key 2: Part 2-Mirror dimming,OFF ,1
IDE10087-MAS05213-Personal settings of key 2: Part 2-Mirror heater,OFF ,1
IDE10087-MAS06870-Personal settings of key 2: Part 2-Mirror lowering in reverse,OFF ,1
IDE10087-MAS06881-Personal settings of key 2: Part 2-Mirror fold-in (VW),OFF ,1
IDE10088-IDE02262-Personal settings of key 3: Part 2-synchronous mirror adjustment,OFF ,1
IDE10088-IDE03946-Personal settings of key 3: Part 2-Mirror dimming,OFF ,1
IDE10088-MAS05213-Personal settings of key 3: Part 2-Mirror heater,OFF ,1
IDE10088-MAS06870-Personal settings of key 3: Part 2-Mirror lowering in reverse,OFF ,1
IDE10088-MAS06881-Personal settings of key 3: Part 2-Mirror fold-in (VW),OFF ,1
IDE10089-IDE02262-Personal settings of key 4: Part 2-synchronous mirror adjustment,OFF ,1
IDE10089-IDE03946-Personal settings of key 4: Part 2-Mirror dimming,OFF ,1
IDE10089-MAS05213-Personal settings of key 4: Part 2-Mirror heater,OFF ,1
IDE10089-MAS06870-Personal settings of key 4: Part 2-Mirror lowering in reverse,OFF ,1
IDE10089-MAS06881-Personal settings of key 4: Part 2-Mirror fold-in (VW),OFF ,1
IDE10090-IDE02262-Personal settings of vehicle: Part 2-synchronous mirror adjustment,OFF ,1
IDE10090-IDE03946-Personal settings of vehicle: Part 2-Mirror dimming,OFF ,1
IDE10090-MAS05213-Personal settings of vehicle: Part 2-Mirror heater,OFF ,1
IDE10090-MAS06870-Personal settings of vehicle: Part 2-Mirror lowering in reverse,OFF ,1
IDE10090-MAS06881-Personal settings of vehicle: Part 2-Mirror fold-in (VW),OFF ,1
IDE10283-Key identification: transponder ID,FF FF FF FF ,4
IDE10318-Sunshade activation,can be activated ,1
IDE10347-Trip distance challenge,00 00 00 00 00 00 00 00 ,8
IDE10836-Enable code for vehicle positioning system,18477 ,2
IDE10858-Number of simultaneously adapting key,0 ,1
IDE10913-MAS10979-Setting the key data-Start page,46 00 ,3
IDE10913-MAS10980-Setting the key data-No. of pages,04 ,3
IDE10913-MAS11635-Setting the key data-Data security,encrypted ,3
IDE11476-Ignition lock: variant,Audi ,1
IDE11487-Trunk emergency release,OFF ,1
IDE11798-Speed-dependent activation of the back window heater,activated ,1
IDE11935-MAS13456-Personalization-Automatic key assignment,activated ,1
IDE11935-MAS13457-Personalization-Status of personalization,activated ,1
IDE12303-MAS14243-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid for activation,3 %,6
IDE12303-MAS14244-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid to reverse,0 %,6
IDE12303-MAS14245-Separation monitoring radio key to rear lid-Lock vehicle after closing,Unknown (4),6
IDE12303-MAS14246-Separation monitoring radio key to rear lid-Monitoring time for rear lid restart,8 %,6
IDE12303-MAS14247-Separation monitoring radio key to rear lid-Monitoring time for rear lid closing,0 %,6
IDE12465-Rear lid opener control module: response in trailer mode,not activated ,2
IDE12481-MAS06700-Horn and flasher via smartphone app-Speed threshold,0 km/h,5
IDE12481-MAS14561-Horn and flasher via smartphone app-Division factor of horn frequency,0 ,5
IDE12481-MAS14562-Horn and flasher via smartphone app-Maximum execution duration,45 s,5
IDE12548-MAS14750-NFC communication: settings-Command category for single-sided NFC authentication,00 ,27
IDE12548-MAS14751-NFC communication: settings-Command for one-sided NFC authentication,10 ,27
IDE12548-MAS14752-NFC communication: settings-Parameter 1 for one-sided NFC authentication,00 ,27
IDE12548-MAS14753-NFC communication: settings-Parameter 2 for one-sided NFC authentication,00 ,27
IDE12548-MAS14754-NFC communication: settings-Command category for two-sided NFC authentication,00 ,27
IDE12548-MAS14755-NFC communication: settings-Command for two-sided NFC authentication,10 ,27
IDE12548-MAS14756-NFC communication: settings-Parameter 1 for two-sided NFC authentication,10 ,27
IDE12548-MAS14757-NFC communication: settings-Parameter 2 for two-sided NFC authentication,00 01 02 ,27
IDE12548-MAS14758-NFC communication: settings-Time point for NFC advance authentication,Last door closed ,27
IDE12548-MAS14761-NFC communication: settings-Block NFC device in the interior,not activated ,27
IDE12548-MAS14762-NFC communication: settings-NFC event search,activated ,27
IDE12548-MAS15378-NFC communication: settings-Command category to trigger an event,00 ,27
IDE12548-MAS15379-NFC communication: settings-Command to trigger an event,10 ,27
IDE12548-MAS15380-NFC communication: settings-Parameter 1 to trigger an event,20 ,27
IDE12548-MAS15381-NFC communication: settings-Parameter 2 to trigger an event,00 ,27
IDE12548-MAS15382-NFC communication: settings-Command category for vehicle data,00 ,27
IDE12548-MAS15383-NFC communication: settings-Command for vehicle data,10 ,27
IDE12548-MAS15384-NFC communication: settings-Parameter 1 for vehicle data,90 ,27
IDE12548-MAS15385-NFC communication: settings-Parameter 2 for vehicle data,01 ,27
IDE12548-MAS15386-NFC communication: settings-Command category for event data,00 ,27
IDE12548-MAS15387-NFC communication: settings-Command for event data,10 ,27
IDE12548-MAS15388-NFC communication: settings-Parameter 1 for event data,90 ,27
IDE12548-MAS15389-NFC communication: settings-Parameter 2 for event data,00 ,27
IDE12548-MAS16723-NFC communication: settings-Expected length of triggering event,00 ,27
IDE12548-MAS16724-NFC communication: settings-Expected length of vehicle data,00 ,27
IDE12548-MAS16725-NFC communication: settings-Expected length of event data,00 ,27
IDE12548-MAS18680-NFC communication: settings-Mobile device charger: duration of charge interruption,2540 ms,27
IDE12792-MAS02444-Personalization of user account 1-Central locking system,global opening ,3
IDE12792-MAS06456-Personalization of user account 1-Auto lock,On ,3
IDE12792-MAS06457-Personalization of user account 1-Auto unlock,On ,3
IDE12792-MAS06696-Personalization of user account 1-Comfort opening sunroof,On ,3
IDE12792-MAS06697-Personalization of user account 1-Acoustic confirmation signal,On ,3
IDE12792-MAS06698-Personalization of user account 1-Highway blinking,On ,3
IDE12792-MAS06740-Personalization of user account 1-Release button in rear lid handle locked,OFF ,3
IDE12792-MAS06756-Personalization of user account 1-Rear shade automatic,OFF ,3
IDE12792-MAS06880-Personalization of user account 1-Mirror fold-in (Audi),On ,3
IDE12792-MAS10221-Personalization of user account 1-Rear lid release via rear lid open sensors,On ,3
IDE12792-MAS10228-Personalization of user account 1-Comfort opening window: driver side,On ,3
IDE12792-MAS10229-Personalization of user account 1-Comfort opening window: frt. pass. side,On ,3
IDE12792-MAS10230-Personalization of user account 1-Comfort opening rear window: driver side,On ,3
IDE12792-MAS10231-Personalization of user account 1-Comfort opening rear window: frt. pass. side,On ,3
IDE12792-MAS20789-Personalization of user account 1-Signature for tail light,0 ,3
IDE12793-IDE02262-Personalization of user account 1: part 2-synchronous mirror adjustment,OFF ,1
IDE12793-IDE03946-Personalization of user account 1: part 2-Mirror dimming,OFF ,1
IDE12793-MAS05213-Personalization of user account 1: part 2-Mirror heater,OFF ,1
IDE12793-MAS06870-Personalization of user account 1: part 2-Mirror lowering in reverse,OFF ,1
IDE12793-MAS06881-Personalization of user account 1: part 2-Mirror fold-in (VW),OFF ,1
IDE12794-MAS02444-Personalization of user account 2-Central locking system,Individual door opening ,3
IDE12794-MAS06456-Personalization of user account 2-Auto lock,On ,3
IDE12794-MAS06457-Personalization of user account 2-Auto unlock,On ,3
IDE12794-MAS06696-Personalization of user account 2-Comfort opening sunroof,OFF ,3
IDE12794-MAS06697-Personalization of user account 2-Acoustic confirmation signal,On ,3
IDE12794-MAS06698-Personalization of user account 2-Highway blinking,On ,3
IDE12794-MAS06740-Personalization of user account 2-Release button in rear lid handle locked,OFF ,3
IDE12794-MAS06756-Personalization of user account 2-Rear shade automatic,OFF ,3
IDE12794-MAS06880-Personalization of user account 2-Mirror fold-in (Audi),OFF ,3
IDE12794-MAS10221-Personalization of user account 2-Rear lid release via rear lid open sensors,On ,3
IDE12794-MAS10228-Personalization of user account 2-Comfort opening window: driver side,OFF ,3
IDE12794-MAS10229-Personalization of user account 2-Comfort opening window: frt. pass. side,OFF ,3
IDE12794-MAS10230-Personalization of user account 2-Comfort opening rear window: driver side,OFF ,3
IDE12794-MAS10231-Personalization of user account 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12794-MAS20789-Personalization of user account 2-Signature for tail light,0 ,3
IDE12795-IDE02262-Personalization of user account 2: part 2-synchronous mirror adjustment,OFF ,1
IDE12795-IDE03946-Personalization of user account 2: part 2-Mirror dimming,OFF ,1
IDE12795-MAS05213-Personalization of user account 2: part 2-Mirror heater,OFF ,1
IDE12795-MAS06870-Personalization of user account 2: part 2-Mirror lowering in reverse,OFF ,1
IDE12795-MAS06881-Personalization of user account 2: part 2-Mirror fold-in (VW),OFF ,1
IDE12796-MAS02444-Personalization of user account 3-Central locking system,Individual door opening ,3
IDE12796-MAS06456-Personalization of user account 3-Auto lock,On ,3
IDE12796-MAS06457-Personalization of user account 3-Auto unlock,On ,3
IDE12796-MAS06696-Personalization of user account 3-Comfort opening sunroof,OFF ,3
IDE12796-MAS06697-Personalization of user account 3-Acoustic confirmation signal,On ,3
IDE12796-MAS06698-Personalization of user account 3-Highway blinking,On ,3
IDE12796-MAS06740-Personalization of user account 3-Release button in rear lid handle locked,OFF ,3
IDE12796-MAS06756-Personalization of user account 3-Rear shade automatic,OFF ,3
IDE12796-MAS06880-Personalization of user account 3-Mirror fold-in (Audi),OFF ,3
IDE12796-MAS10221-Personalization of user account 3-Rear lid release via rear lid open sensors,On ,3
IDE12796-MAS10228-Personalization of user account 3-Comfort opening window: driver side,OFF ,3
IDE12796-MAS10229-Personalization of user account 3-Comfort opening window: frt. pass. side,OFF ,3
IDE12796-MAS10230-Personalization of user account 3-Comfort opening rear window: driver side,OFF ,3
IDE12796-MAS10231-Personalization of user account 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12796-MAS20789-Personalization of user account 3-Signature for tail light,0 ,3
IDE12797-IDE02262-Personalization of user account 3: part 2-synchronous mirror adjustment,OFF ,1
IDE12797-IDE03946-Personalization of user account 3: part 2-Mirror dimming,OFF ,1
IDE12797-MAS05213-Personalization of user account 3: part 2-Mirror heater,OFF ,1
IDE12797-MAS06870-Personalization of user account 3: part 2-Mirror lowering in reverse,OFF ,1
IDE12797-MAS06881-Personalization of user account 3: part 2-Mirror fold-in (VW),OFF ,1
IDE12798-MAS02444-Personalization of user account 4-Central locking system,Individual door opening ,3
IDE12798-MAS06456-Personalization of user account 4-Auto lock,On ,3
IDE12798-MAS06457-Personalization of user account 4-Auto unlock,On ,3
IDE12798-MAS06696-Personalization of user account 4-Comfort opening sunroof,OFF ,3
IDE12798-MAS06697-Personalization of user account 4-Acoustic confirmation signal,On ,3
IDE12798-MAS06698-Personalization of user account 4-Highway blinking,On ,3
IDE12798-MAS06740-Personalization of user account 4-Release button in rear lid handle locked,OFF ,3
IDE12798-MAS06756-Personalization of user account 4-Rear shade automatic,OFF ,3
IDE12798-MAS06880-Personalization of user account 4-Mirror fold-in (Audi),OFF ,3
IDE12798-MAS10221-Personalization of user account 4-Rear lid release via rear lid open sensors,On ,3
IDE12798-MAS10228-Personalization of user account 4-Comfort opening window: driver side,OFF ,3
IDE12798-MAS10229-Personalization of user account 4-Comfort opening window: frt. pass. side,OFF ,3
IDE12798-MAS10230-Personalization of user account 4-Comfort opening rear window: driver side,OFF ,3
IDE12798-MAS10231-Personalization of user account 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12798-MAS20789-Personalization of user account 4-Signature for tail light,0 ,3
IDE12799-IDE02262-Personalization of user account 4: part 2-synchronous mirror adjustment,OFF ,1
IDE12799-IDE03946-Personalization of user account 4: part 2-Mirror dimming,OFF ,1
IDE12799-MAS05213-Personalization of user account 4: part 2-Mirror heater,OFF ,1
IDE12799-MAS06870-Personalization of user account 4: part 2-Mirror lowering in reverse,OFF ,1
IDE12799-MAS06881-Personalization of user account 4: part 2-Mirror fold-in (VW),OFF ,1
IDE12800-MAS02444-Personalization of user account 5-Central locking system,Individual door opening ,3
IDE12800-MAS06456-Personalization of user account 5-Auto lock,On ,3
IDE12800-MAS06457-Personalization of user account 5-Auto unlock,On ,3
IDE12800-MAS06696-Personalization of user account 5-Comfort opening sunroof,OFF ,3
IDE12800-MAS06697-Personalization of user account 5-Acoustic confirmation signal,On ,3
IDE12800-MAS06698-Personalization of user account 5-Highway blinking,On ,3
IDE12800-MAS06740-Personalization of user account 5-Release button in rear lid handle locked,OFF ,3
IDE12800-MAS06756-Personalization of user account 5-Rear shade automatic,OFF ,3
IDE12800-MAS06880-Personalization of user account 5-Mirror fold-in (Audi),OFF ,3
IDE12800-MAS10221-Personalization of user account 5-Rear lid release via rear lid open sensors,On ,3
IDE12800-MAS10228-Personalization of user account 5-Comfort opening window: driver side,OFF ,3
IDE12800-MAS10229-Personalization of user account 5-Comfort opening window: frt. pass. side,OFF ,3
IDE12800-MAS10230-Personalization of user account 5-Comfort opening rear window: driver side,OFF ,3
IDE12800-MAS10231-Personalization of user account 5-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12800-MAS20789-Personalization of user account 5-Signature for tail light,0 ,3
IDE12801-IDE02262-Personalization of user account 5: part 2-synchronous mirror adjustment,OFF ,1
IDE12801-IDE03946-Personalization of user account 5: part 2-Mirror dimming,OFF ,1
IDE12801-MAS05213-Personalization of user account 5: part 2-Mirror heater,OFF ,1
IDE12801-MAS06870-Personalization of user account 5: part 2-Mirror lowering in reverse,OFF ,1
IDE12801-MAS06881-Personalization of user account 5: part 2-Mirror fold-in (VW),OFF ,1
IDE12802-MAS02444-Personalization of user account 6-Central locking system,Individual door opening ,3
IDE12802-MAS06456-Personalization of user account 6-Auto lock,On ,3
IDE12802-MAS06457-Personalization of user account 6-Auto unlock,On ,3
IDE12802-MAS06696-Personalization of user account 6-Comfort opening sunroof,OFF ,3
IDE12802-MAS06697-Personalization of user account 6-Acoustic confirmation signal,On ,3
IDE12802-MAS06698-Personalization of user account 6-Highway blinking,On ,3
IDE12802-MAS06740-Personalization of user account 6-Release button in rear lid handle locked,OFF ,3
IDE12802-MAS06756-Personalization of user account 6-Rear shade automatic,OFF ,3
IDE12802-MAS06880-Personalization of user account 6-Mirror fold-in (Audi),OFF ,3
IDE12802-MAS10221-Personalization of user account 6-Rear lid release via rear lid open sensors,On ,3
IDE12802-MAS10228-Personalization of user account 6-Comfort opening window: driver side,OFF ,3
IDE12802-MAS10229-Personalization of user account 6-Comfort opening window: frt. pass. side,OFF ,3
IDE12802-MAS10230-Personalization of user account 6-Comfort opening rear window: driver side,OFF ,3
IDE12802-MAS10231-Personalization of user account 6-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12802-MAS20789-Personalization of user account 6-Signature for tail light,0 ,3
IDE12803-IDE02262-Personalization of user account 6: part 2-synchronous mirror adjustment,OFF ,1
IDE12803-IDE03946-Personalization of user account 6: part 2-Mirror dimming,OFF ,1
IDE12803-MAS05213-Personalization of user account 6: part 2-Mirror heater,OFF ,1
IDE12803-MAS06870-Personalization of user account 6: part 2-Mirror lowering in reverse,OFF ,1
IDE12803-MAS06881-Personalization of user account 6: part 2-Mirror fold-in (VW),OFF ,1
IDE12804-MAS02444-Personalization of user account 7-Central locking system,Individual door opening ,3
IDE12804-MAS06456-Personalization of user account 7-Auto lock,On ,3
IDE12804-MAS06457-Personalization of user account 7-Auto unlock,On ,3
IDE12804-MAS06696-Personalization of user account 7-Comfort opening sunroof,OFF ,3
IDE12804-MAS06697-Personalization of user account 7-Acoustic confirmation signal,On ,3
IDE12804-MAS06698-Personalization of user account 7-Highway blinking,On ,3
IDE12804-MAS06740-Personalization of user account 7-Release button in rear lid handle locked,OFF ,3
IDE12804-MAS06756-Personalization of user account 7-Rear shade automatic,OFF ,3
IDE12804-MAS06880-Personalization of user account 7-Mirror fold-in (Audi),OFF ,3
IDE12804-MAS10221-Personalization of user account 7-Rear lid release via rear lid open sensors,On ,3
IDE12804-MAS10228-Personalization of user account 7-Comfort opening window: driver side,OFF ,3
IDE12804-MAS10229-Personalization of user account 7-Comfort opening window: frt. pass. side,OFF ,3
IDE12804-MAS10230-Personalization of user account 7-Comfort opening rear window: driver side,OFF ,3
IDE12804-MAS10231-Personalization of user account 7-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12804-MAS20789-Personalization of user account 7-Signature for tail light,0 ,3
IDE12805-IDE02262-Personalization of user account 7: part 2-synchronous mirror adjustment,OFF ,1
IDE12805-IDE03946-Personalization of user account 7: part 2-Mirror dimming,OFF ,1
IDE12805-MAS05213-Personalization of user account 7: part 2-Mirror heater,OFF ,1
IDE12805-MAS06870-Personalization of user account 7: part 2-Mirror lowering in reverse,OFF ,1
IDE12805-MAS06881-Personalization of user account 7: part 2-Mirror fold-in (VW),OFF ,1
IDE12808-Personalization of user account 1: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12809-Personalization of user account 2: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12810-Personalization of user account 3: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12811-Personalization of user account 4: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12812-Personalization of user account 5: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12813-Personalization of user account 6: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12814-Personalization of user account 7: name,47 61 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12815-MAS15187-User accounts for the NFC devices-User account of NFC device 1,0 ,8
IDE12815-MAS15188-User accounts for the NFC devices-User account of NFC device 2,0 ,8
IDE12815-MAS15189-User accounts for the NFC devices-User account of NFC device 3,0 ,8
IDE12815-MAS15190-User accounts for the NFC devices-User account of NFC device 4,0 ,8
IDE12815-MAS15191-User accounts for the NFC devices-User account of NFC device 5,0 ,8
IDE12815-MAS15192-User accounts for the NFC devices-User account of NFC device 6,0 ,8
IDE12815-MAS15193-User accounts for the NFC devices-User account of NFC device 7,0 ,8
IDE12815-MAS15194-User accounts for the NFC devices-User account of NFC device 8,0 ,8
IDE12815-MAS15195-User accounts for the NFC devices-User account of NFC device 9,0 ,8
IDE12815-MAS15196-User accounts for the NFC devices-User account of NFC device 10,0 ,8
IDE12815-MAS15197-User accounts for the NFC devices-User account of NFC device 11,0 ,8
IDE12815-MAS15198-User accounts for the NFC devices-User account of NFC device 12,0 ,8
IDE12815-MAS15199-User accounts for the NFC devices-User account of NFC device 13,0 ,8
IDE12815-MAS15200-User accounts for the NFC devices-User account of NFC device 14,0 ,8
IDE12815-MAS15201-User accounts for the NFC devices-User account of NFC device 15,0 ,8
IDE12815-MAS15202-User accounts for the NFC devices-User account of NFC device 16,0 ,8
IDE12938-MAS15390-NFC communication 2: settings-Command category for SELECT,00 ,22
IDE12938-MAS15391-NFC communication 2: settings-Command for SELECT,A4 ,22
IDE12938-MAS15392-NFC communication 2: settings-Parameter 1 for SELECT,04 ,22
IDE12938-MAS15393-NFC communication 2: settings-Parameter 2 for SELECT,00 ,22
IDE12938-MAS15394-NFC communication 2: settings-Utility data length for SELECT,0F ,22
IDE12938-MAS15395-NFC communication 2: settings-Application ID for SELECT,A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 ,22
IDE12938-MAS15396-NFC communication 2: settings-Expected length for SELECT,10 ,22
IDE13065-Left tail lamp 1: parameter set,55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
IDE13066-Left tail lamp 2: parameter set,55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
IDE13067-Right tail lamp 1: parameter set,55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
IDE13068-Right tail lamp 2: parameter set,55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
IDE13253-MAS16009-Convertible top convenience operation-Convenience closure with radio key,On ,2
IDE13253-MAS16010-Convertible top convenience operation-Convenience opening with lock cylinder,On ,2
IDE13253-MAS16011-Convertible top convenience operation-Convenience closing with exterior door handle touch sensor,On ,2
IDE13253-MAS16012-Convertible top convenience operation-Convenience opening with radio key,On ,2
IDE13253-MAS16013-Convertible top convenience operation-Convenient opening with lock cylinder,On ,2
IDE13254-MAS16014-Convenience opening: control points-Convenience opening of the window regulator with radio key,On ,2
IDE13254-MAS16015-Convenience opening: control points-Convenience opening of the window regulator with lock cylinder,On ,2
IDE13254-MAS16016-Convenience opening: control points-Convenience opening of the window regulator with window regulator button,On ,2
IDE13254-MAS16017-Convenience opening: control points-Convenience opening of the roof shade with the radio key,On ,2
IDE13254-MAS16018-Convenience opening: control points-Convenience opening of the roof shade with lock cylinder,On ,2
IDE13254-MAS16019-Convenience opening: control points-Convenience opening of the roof shade with window regulator button,On ,2
IDE13254-MAS16020-Convenience opening: control points-Comfort opening only for driver door,OFF ,2
IDE13254-MAS16029-Convenience opening: control points-Convenience opening of the sunroof with radio key,On ,2
IDE13254-MAS16030-Convenience opening: control points-Convenience opening of the sunroof with lock cylinder,On ,2
IDE13254-MAS16031-Convenience opening: control points-Convenience opening of the sun roof with window regulator button,On ,2
IDE13254-MAS16032-Convenience opening: control points-Convenience opening of rear sun roof with radio key,On ,2
IDE13254-MAS16033-Convenience opening: control points-Convenience opening of rear sun roof with lock cylinder,On ,2
IDE13254-MAS16034-Convenience opening: control points-Comfort opening of the rear sunroof with window regulator button,On ,2
IDE13255-MAS16021-Convenience closing: control points-Convenience closure of the window regulator with radio key,On ,2
IDE13255-MAS16022-Convenience closing: control points-Convenience closure of the window regulator with lock cylinder,On ,2
IDE13255-MAS16023-Convenience closing: control points-Convenience closure of the window regulator with window regulator button,On ,2
IDE13255-MAS16024-Convenience closing: control points-Convenience closure of window regulator with outside door handle sensor,On ,2
IDE13255-MAS16025-Convenience closing: control points-Convenience closing of the roof shade with the radio key,On ,2
IDE13255-MAS16026-Convenience closing: control points-Convenience closure of the roof shade with lock cylinder,On ,2
IDE13255-MAS16027-Convenience closing: control points-Convenience closure of the roof shade with window regulator button,On ,2
IDE13255-MAS16028-Convenience closing: control points-Convenience closure of roof shade with outside door handle,On ,2
IDE13255-MAS16035-Convenience closing: control points-Convenience closure of sun roof with radio key,On ,2
IDE13255-MAS16036-Convenience closing: control points-Convenience closing of the sunroof with lock cylinder,On ,2
IDE13255-MAS16037-Convenience closing: control points-Convenience closure of the sun roof with window regulator button,On ,2
IDE13255-MAS16038-Convenience closing: control points-Convenience closure of sunroof with outside door handle sensor,On ,2
IDE13255-MAS16039-Convenience closing: control points-Convenience closure of rear sun roof with radio key,On ,2
IDE13255-MAS16040-Convenience closing: control points-Convenience closure of rear sun roof with lock cylinder,On ,2
IDE13255-MAS16041-Convenience closing: control points-Convenience closure of the rear sun roof with window regulator button,On ,2
IDE13255-MAS16042-Convenience closing: control points-Convenience closure of rear sunroof with outside door handle sensor,On ,2
IDE14072-MAS17381-Central locking system actuation counter: configuration-Interface 1: counter 1,0 ,12
IDE14072-MAS17382-Central locking system actuation counter: configuration-Interface 2: counter 1,0 ,12
IDE14072-MAS17383-Central locking system actuation counter: configuration-Interface 3: counter 1,0 ,12
IDE14072-MAS17384-Central locking system actuation counter: configuration-Interface 1: counter 2,0 ,12
IDE14072-MAS17385-Central locking system actuation counter: configuration-Interface 2: counter 2,0 ,12
IDE14072-MAS17386-Central locking system actuation counter: configuration-Interface 3: counter 2,0 ,12
IDE14072-MAS17387-Central locking system actuation counter: configuration-Interface 1: counter 3,0 ,12
IDE14072-MAS17388-Central locking system actuation counter: configuration-Interface 2: counter 3,0 ,12
IDE14072-MAS17389-Central locking system actuation counter: configuration-Interface 3: counter 3,0 ,12
IDE14072-MAS17390-Central locking system actuation counter: configuration-Interface 1: counter 4,0 ,12
IDE14072-MAS17391-Central locking system actuation counter: configuration-Interface 2: counter 4,0 ,12
IDE14072-MAS17392-Central locking system actuation counter: configuration-Interface 3: counter 4,0 ,12
IDE14661-MAS18674-NFC communication 3: settings-Trigger event waiting time,0 ms,8
IDE14661-MAS18675-NFC communication 3: settings-Waiting time for sending event data,0 ms,8
IDE14661-MAS18676-NFC communication 3: settings-Waiting time for sending vehicle health data,300 ms,8
IDE14661-MAS18677-NFC communication 3: settings-Trigger NFC event,activated ,8
IDE14661-MAS18678-NFC communication 3: settings-Send NFC event data,activated ,8
IDE14661-MAS18679-NFC communication 3: settings-Send NFC vehicle health data,activated ,8
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,0 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,1 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,32 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,32 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,32 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,32 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,0 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,9 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,static ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,6 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,38 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,13 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS19655-MAS19656-Open rear lid by pushing remote control twice-Actuation time 1 for double-actuation,5100 ms,4
MAS19655-MAS19657-Open rear lid by pushing remote control twice-Actuation time 2 for double-actuation,5100 ms,4
MAS19655-MAS19658-Open rear lid by pushing remote control twice-Time window for double-actuation,1.40 s,4
ENG146368-ENG146489-central_locking_system-autolock_rear,On ,2
ENG146368-ENG146488-central_locking_system-beep_at_opening,OFF ,2
ENG146368-ENG146490-central_locking_system-global_unlocking_via_kessy_double_puls,OFF ,2
ENG146368-ENG146491-central_locking_system-unlocking_rear_via_vip_at_s_contact_active,OFF ,2
ENG153792-Conti_debug_switch,FF FF ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG146414-ffb_kessy_active_for_piloted_parking,Kessy_and_ffb_at_kl15_on_and_piloted_parking_event_active ,1
ENG146373-headlamp_range_adjustment,OFF ,1
ENG146406-ENG146575-Heated_front_window_lin_relais-Off_delay,0.50 s,14
ENG146406-ENG146574-Heated_front_window_lin_relais-On_delay,0.50 s,14
ENG146406-ENG146571-Heated_front_window_lin_relais-Threshold_driver_side_off,150 W,14
ENG146406-ENG146570-Heated_front_window_lin_relais-Threshold_driver_side_on,300 W,14
ENG146406-ENG146573-Heated_front_window_lin_relais-Threshold_passenger_side_off,350 W,14
ENG146406-ENG146572-Heated_front_window_lin_relais-Threshold_passenger_side_on,500 W,14
ENG146406-ENG146576-Heated_front_window_lin_relais-Two_Relais_installed,1 ,14
ENG146400-ENG146554-Heated_rear_window_with_extension-Default_activation_time,10 min,16
ENG146400-ENG155020-Heated_rear_window_with_extension-Delay_time_deactivate_heated_rear_window,1.00 ,16
ENG146400-ENG146546-Heated_rear_window_with_extension-Interval_1,5 min,16
ENG146400-ENG146547-Heated_rear_window_with_extension-Interval_2,7 min,16
ENG146400-ENG146548-Heated_rear_window_with_extension-Interval_3,15 min,16
ENG146400-ENG146549-Heated_rear_window_with_extension-Interval_4,20 min,16
ENG146400-ENG146550-Heated_rear_window_with_extension-Renewal_interval_1,0 min,16
ENG146400-ENG146551-Heated_rear_window_with_extension-Renewal_interval_2,3 min,16
ENG146400-ENG146552-Heated_rear_window_with_extension-Renewal_interval_3,5 min,16
ENG146400-ENG146553-Heated_rear_window_with_extension-Renewal_interval_4,0 min,16
ENG146400-ENG146555-Heated_rear_window_with_extension-Speed_theshold,50 ,16
ENG146400-ENG145114-Heated_rear_window_with_extension-Temperature_1,132 ,16
ENG146400-ENG145115-Heated_rear_window_with_extension-Temperature_2,124 ,16
ENG146400-ENG146545-Heated_rear_window_with_extension-Temperature_3,116 ,16
ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close,2 ,2
ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open,1 ,2
ENG153896-ENG146539-Mobile_Key-idle_time_state_S1,60 ,4
ENG153896-ENG155141-Mobile_Key-idle_time_state_S2,20 ,4
ENG153896-ENG155142-Mobile_Key-idle_time_vtan_state_S1,60 ,4
ENG153896-ENG155143-Mobile_Key-idle_time_vtan_state_S2,20 ,4
ENG146397-ENG146535-mq_ewi_activation-ewi_mode,On ,4
ENG146397-ENG146534-mq_ewi_activation-ewi_trace,On ,4
ENG146397-ENG146536-mq_ewi_activation-ewi_trace_messages,FF FF FF ,4
ENG247341-Personalisation_2_0_ew,150 ms,5
ENG146405-ENG146480-Personalisation_ew-Delay_Time,0.60 s,8
ENG146405-ENG146558-Personalisation_ew-FSG_Setup2_Bit1,0 ,8
ENG146405-ENG146559-Personalisation_ew-FSG_Setup2_Bit2,0 ,8
ENG146405-ENG146560-Personalisation_ew-FSG_Setup2_Bit3,1 ,8
ENG146405-ENG146561-Personalisation_ew-FSG_Setup2_Bit4,0 ,8
ENG146405-ENG146562-Personalisation_ew-FSG_Setup2_Bit5,0 ,8
ENG146405-ENG146563-Personalisation_ew-FSG_Setup2_Bit6,1 ,8
ENG146405-ENG146564-Personalisation_ew-FSG_Setup2_Bit7,1 ,8
ENG146405-ENG146569-Personalisation_ew-Minimum_display_duration,1 ,8
ENG146405-ENG146566-Personalisation_ew-Number_of_accounts,7 ,8
ENG146405-ENG146577-Personalisation_ew-Prioritization_device,1 ,8
ENG146405-ENG146567-Personalisation_ew-Time_slot_driver_door_opening,0.30 s,8
ENG146405-ENG146565-Personalisation_ew-Time_slot_key_identification,5 ,8
ENG146405-ENG146568-Personalisation_ew-Timeout_drive_active,60 ,8
ENG146375-ENG146520-pwm_levels_hl_1-pwm_high_1,100 ,3
ENG146375-ENG146521-pwm_levels_hl_1-pwm_high_2,0 ,3
ENG146375-ENG146519-pwm_levels_hl_1-pwm_low,0 ,3
ENG146384-ENG146520-pwm_levels_hl_10-pwm_high_1,100 ,3
ENG146384-ENG146521-pwm_levels_hl_10-pwm_high_2,0 ,3
ENG146384-ENG146519-pwm_levels_hl_10-pwm_low,0 ,3
ENG146385-ENG146520-pwm_levels_hl_11-pwm_high_1,100 ,3
ENG146385-ENG146521-pwm_levels_hl_11-pwm_high_2,100 ,3
ENG146385-ENG146519-pwm_levels_hl_11-pwm_low,100 ,3
ENG146386-ENG146520-pwm_levels_hl_12-pwm_high_1,100 ,3
ENG146386-ENG146521-pwm_levels_hl_12-pwm_high_2,0 ,3
ENG146386-ENG146519-pwm_levels_hl_12-pwm_low,0 ,3
ENG146387-ENG146520-pwm_levels_hl_13-pwm_high_1,100 ,3
ENG146387-ENG146521-pwm_levels_hl_13-pwm_high_2,100 ,3
ENG146387-ENG146519-pwm_levels_hl_13-pwm_low,100 ,3
ENG146388-ENG146520-pwm_levels_hl_14-pwm_high_1,100 ,3
ENG146388-ENG146521-pwm_levels_hl_14-pwm_high_2,0 ,3
ENG146388-ENG146519-pwm_levels_hl_14-pwm_low,0 ,3
ENG146389-ENG146520-pwm_levels_hl_15-pwm_high_1,100 ,3
ENG146389-ENG146521-pwm_levels_hl_15-pwm_high_2,100 ,3
ENG146389-ENG146519-pwm_levels_hl_15-pwm_low,100 ,3
ENG146390-ENG146520-pwm_levels_hl_16-pwm_high_1,0 ,3
ENG146390-ENG146521-pwm_levels_hl_16-pwm_high_2,100 ,3
ENG146390-ENG146519-pwm_levels_hl_16-pwm_low,0 ,3
ENG146391-ENG146520-pwm_levels_hl_17-pwm_high_1,100 ,3
ENG146391-ENG146521-pwm_levels_hl_17-pwm_high_2,100 ,3
ENG146391-ENG146519-pwm_levels_hl_17-pwm_low,100 ,3
ENG146392-ENG146520-pwm_levels_hl_18-pwm_high_1,100 ,3
ENG146392-ENG146521-pwm_levels_hl_18-pwm_high_2,100 ,3
ENG146392-ENG146519-pwm_levels_hl_18-pwm_low,0 ,3
ENG146393-ENG146520-pwm_levels_hl_19-pwm_high_1,100 ,3
ENG146393-ENG146521-pwm_levels_hl_19-pwm_high_2,100 ,3
ENG146393-ENG146519-pwm_levels_hl_19-pwm_low,0 ,3
ENG146376-ENG146520-pwm_levels_hl_2-pwm_high_1,100 ,3
ENG146376-ENG146521-pwm_levels_hl_2-pwm_high_2,0 ,3
ENG146376-ENG146519-pwm_levels_hl_2-pwm_low,0 ,3
ENG146394-ENG146520-pwm_levels_hl_20-pwm_high_1,100 ,3
ENG146394-ENG146521-pwm_levels_hl_20-pwm_high_2,100 ,3
ENG146394-ENG146519-pwm_levels_hl_20-pwm_low,100 ,3
ENG146395-ENG146520-pwm_levels_hl_21-pwm_high_1,100 ,3
ENG146395-ENG146521-pwm_levels_hl_21-pwm_high_2,100 ,3
ENG146395-ENG146519-pwm_levels_hl_21-pwm_low,100 ,3
ENG146377-ENG146520-pwm_levels_hl_3-pwm_high_1,100 ,3
ENG146377-ENG146521-pwm_levels_hl_3-pwm_high_2,0 ,3
ENG146377-ENG146519-pwm_levels_hl_3-pwm_low,0 ,3
ENG146378-ENG146520-pwm_levels_hl_4-pwm_high_1,100 ,3
ENG146378-ENG146521-pwm_levels_hl_4-pwm_high_2,0 ,3
ENG146378-ENG146519-pwm_levels_hl_4-pwm_low,0 ,3
ENG146379-ENG146520-pwm_levels_hl_5-pwm_high_1,100 ,3
ENG146379-ENG146521-pwm_levels_hl_5-pwm_high_2,100 ,3
ENG146379-ENG146519-pwm_levels_hl_5-pwm_low,100 ,3
ENG146380-ENG146520-pwm_levels_hl_6-pwm_high_1,100 ,3
ENG146380-ENG146521-pwm_levels_hl_6-pwm_high_2,100 ,3
ENG146380-ENG146519-pwm_levels_hl_6-pwm_low,100 ,3
ENG146381-ENG146520-pwm_levels_hl_7-pwm_high_1,100 ,3
ENG146381-ENG146521-pwm_levels_hl_7-pwm_high_2,100 ,3
ENG146381-ENG146519-pwm_levels_hl_7-pwm_low,100 ,3
ENG146382-ENG146520-pwm_levels_hl_8-pwm_high_1,100 ,3
ENG146382-ENG146521-pwm_levels_hl_8-pwm_high_2,100 ,3
ENG146382-ENG146519-pwm_levels_hl_8-pwm_low,0 ,3
ENG146383-ENG146520-pwm_levels_hl_9-pwm_high_1,100 ,3
ENG146383-ENG146521-pwm_levels_hl_9-pwm_high_2,0 ,3
ENG146383-ENG146519-pwm_levels_hl_9-pwm_low,0 ,3
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep,500 ,8
ENG146399-ENG146544-remote_functions-idle_time_state_S0,1 ,8
ENG146399-ENG146539-remote_functions-idle_time_state_S1,60 ,8
ENG146399-ENG146540-remote_functions-idle_time_state_S3,2000 ,8
ENG146399-ENG146537-remote_functions-Rear_lid_handle_release_button_activation_time,30 ,8
ENG146399-ENG146538-remote_functions-Rear_lid_handle_release_button_active,active ,8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high,100 ,8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low,900 ,8
ENG146403-ENG114991-RF_adjustment-channel_1,00 ,3
ENG146403-ENG114992-RF_adjustment-channel_2,00 ,3
ENG146403-ENG114993-RF_adjustment-channel_3,00 ,3
ENG146402-ENG114991-RF_calibration-channel_1,01 0A C7 ,9
ENG146402-ENG114992-RF_calibration-channel_2,01 1D 67 ,9
ENG146402-ENG114993-RF_calibration-channel_3,01 30 08 ,9
ENG129054-ENG144985-SERVICE_KEY-debounce_kilometer,15 km,9
ENG129054-ENG144693-SERVICE_KEY-Distance,20 km,9
ENG129054-ENG144983-SERVICE_KEY-hazard_warning_switch_delay_time,10 s,9
ENG129054-ENG144980-SERVICE_KEY-retry_request_obdc,3 ,9
ENG129054-ENG144979-SERVICE_KEY-timeout_request_obdc,30 s,9
ENG129054-ENG146532-SERVICE_KEY-write_cycles_per_key_and_day,20 ,9
ENG129054-ENG144984-SERVICE_KEY-write_data_delay_time,40 s,9
ENG129054-ENG144982-SERVICE_KEY-write_delay_speed,20 km/h,9
ENG129054-ENG144981-SERVICE_KEY-write_delay_time,20 s,9
ENG146371-ENG146510-sounder_settings-beeptime,10_ms ,2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking,single_beep ,2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking,double_beep ,2
ENG146371-ENG247388-sounder_settings-beeptime_reunlock,60_ms ,2
ENG146371-ENG146512-sounder_settings-sounder_sound,frequency_modulated ,2
ENG146364-ENG146516-Terminal_Control-deactivation_time_kl15,30 min,3
ENG146364-ENG146517-Terminal_Control-delay_time_leave_concept,200 ms,3
ENG146398-wiping_indicator,00010111 ,1
ENG146401-Write_key_content,17 00 01 0A 28 14 0F 14 FF 05 00 0A 32 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,98
Elapsed Time: 00:53
drp
