Xenon headlights retro fit
Chrisp4632
Berkshire, UK
C?ID=317266
So a while ago I retro fitted xenon headlights into my 2007 audi a4 b7 8E.
The old bcm module would no accept any changes (8E0 907 279M) so I swopped it out for (8E0 907 279N) as advised on here to do and now everything works .....sort of!
I have just realised my rear fog lights will not work with this control module I can test them via vcds and they work fine but not on the switch?
Swopped back to the old control module and everything works as it should (rear fog lights work to)
I have fitted another bcm with the same code (8E0 907 279N) and its doing the exact same thing no rear fog lights.
Does anyone know what is going on has anyone had this issue
I also have an issue with vin learning on the new unit when typing in 26992 in adaptations its displaying disabled 10.0? anyone know why and how to get around this
Previous thread for reference:
Would you be so kind as to post an Auto-Scan of the car in its current state?
Chrisp4632
Berkshire, UK
C?ID=317266
i posted this before however due to issues with my laptop it had to be sent away for repair,
anyway...
i have retro fitted xenon headlights into my audi 2007 a4 b7 i fitted a new BCM Module (8E0907279N) everything works but i cannot get my rear fog light to work instead my headlights come on ?
when fitting the orginal BCM Module 8E0907279M and standard halogen headlights my rear fogs will work like they should ,however i cannot code this moduel hence why i replaced it with (N).
As you can see theres a fault for the light switch i have replaced it twice but the fault remains this only appears when i fit the 8E0907279N Module not the (M)
Do i need to replace my light switch with a different model ?
if so does any one know what the part number would be or is this something i can sort on vcds as im at a dead end!
Current light switch installed is - 5K7 8E0941531 C 5PR
Thank You.
(auto scan for 8E0907279N Below)
Monday,19,October,2020,14:47:24:00481
VIN: WAUZZZ8E57A095142   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E57A095142   Mileage: 197910km-122975miles
Address 01: Engine        Labels: 03G-906-018-BRD.clb
   Part No SW: 03G 906 018 AQ    HW: 03G 906 018 AQ
   Component: R4 2.0l PPD1.3 G    9973
   Revision: --H33---    Serial number:
   Coding: 0000072
   Shop #: WSC 00067 210 90957
   VCID: 74B1DA3602BB31BB46B-8020
Readiness: N/A
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004405
   Shop #: WSC 06335 000 00000
   VCID: 2C0102569A0B297BDEB-8078
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6B83C14A5A95EE43971-513C
            16-10 - Signal Outside Specifications - Intermittent
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 10021
   Shop #: WSC 06325
   VCID: 3D273F127461B0F3795-4B00
01800 - Light Switch (E1)
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G3G6J5
   Coding: 0031612
   VCID: 3B23310A6F65BEC3471-806E
   Subsystem 1 - Serial number: 6332DRB403D2CD26Y
   Subsystem 2 - Serial number: 6342DRB403D5888F1
   Subsystem 3 - Serial number: 6352ARB4018ABBAD3
   Subsystem 4 - Serial number: 6362ARB4018C65FA/
   Subsystem 5 - Serial number: 63729RB401A1CA7BZ
   Subsystem 6 - Serial number: 63829RB401A1CAA6Y
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02042
   Shop #: WSC 06335
   VCID: 41DF43E20899D4131DD-4B00
01304 - Radio
            49-00 - No Communications
   Part No SW: 8E0 920 951 E    HW: 8E0 920 951 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0006414
   Shop #: WSC 57714 001 104857
   VCID: 2C0102569A1B297BDEB-5184
01304 - Radio
   Coding: 0006414
01304 - Radio
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   Part No: 8E0 959 433 CH
   Component: Komfortgerát T3B    4135
   Coding: 07151
   Shop #: WSC 06335
   VCID: 79AFEB0220C94CD315D-4B00
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802120731
   Coding: 0000114
   VCID: 323D1C2EB80F7F8B947-5184
End----------(Elapsed Time: 05:21, VBatt start/end: 14.1V/14.1V)-----------
(auto scan for 8E0907279M Below)
Wednesday,14,October,2020,10:55:59:00481
          67 69 75 76 77
VIN: WAUZZZ8E57A095142   Mileage: 197760km-122882miles
   Coding: 0000072
Readiness: N/A
   Coding: 0004405
   Coding: 00000
   Part No: 8E0 907 279 M
   Coding: 10001
   Shop #: WSC 06335
   VCID: 3C2132166F7BB9FB4EB-4B00
   Coding: 0031612
   Coding: 02042
   Shop #: WSC 06335
01304 - Radio
   Coding: 0006414
01304 - Radio
   Coding: 0006414
01304 - Radio
   Coding: 00001
   Coding: 07151
   Shop #: WSC 06335
   Coding: 0000114
End----------(Elapsed Time: 05:29, VBatt start/end: 12.3V/12.2V)-----------
Latest two threads merged. Please refrain from opening new threads about the same question in the same car. Please find your previous thread and append to it for context.
Chrisp4632
Berkshire, UK
C?ID=317266
sorry i did try to delete the previous thread as it was posted some time ago and start over fresh how ever i couldn't work out how to do it .
Users cannot delete threads. Starting over fresh is rarely desirable, as it loses the contextual information of what has come before.
Chrisp4632
Berkshire, UK
C?ID=317266
Anyone?
or could this be something i have done wrong or missed when coding the new BCM module?
As far as i was aware all i needed to do was install new BCM Module (8E0907279N) then on VCDS go to 09-central Elec, 10-adaptations 081-component protection -46992 and test then save then go to 07- coding and change the fourth digit from zero to two to activate xenon headlights with drl's coding will be 10021 instead of 10001 am i missing anything else possibly something needs changing in the long coding?
South Molton, UK
Have you checked that the long coding and ALL the adaptation channels in the new BCM are identical to those in the old BCM?
Chrisp4632
Berkshire, UK
C?ID=317266
Adaptation channels yes and there identical ,as for the long coding no as I'm still learning this and not sure how to get into it ,I'm assuming that il need to login (11) first to access the long coding?
Waxing pedantic: These modules ( 8E0-907-279) don't use long coding; they use old-school short coding.
Chrisp4632
Berkshire, UK
C?ID=317266
so could this possibly be a light switch issue then as it's throwing a fault when the module is fitted but not when the old one is ,maybe the BCM module will work correctly with a particular model of light switch?
I'm just throwing ideas now as I'm completely lost on what to do ,I'm now into my third module (two N's & L) and there all doing the same thing!
i know its just a rear fog light so nothing major but I'm OCD and i know it will just annoy me.
if there's a way to get my old module (M) to accept the coding changes that would be great as everything works as it should with that one .
That's what I'm wondering: Is it possible that these two different modules are expecting two different light switches? One would have to take a fairly deep dive into a parts catalog to know for sure.
Chrisp4632
Berkshire, UK
C?ID=317266
so been a few days now and I'm still not any better off i have tried a good handful of light switches all different part numbers and I'm still having the same issue as for the parts catalogue iv had a look around but cant find any useful information.
so my next option is my original BCM unit and getting it to accept the coding change (8E0907279M) as this unit actually works , at the moment when ever i change the coding the page refreshes but the changes don't apply is there a way around this?
if not then I'm going to give up as this is becoming an absolute headache for something that should be a straight forward job.
