01794 - Control Module - Incorrect Chassis (VIN) Number AUDI A5 000 - - - MIL ON
siliko
Palestine
C?ID=302022
Hi
I get this Error code for The ABS and really I couldn't understand how this happen , if there any way to solve this with VCDS please advice
kind regards
Monday,19,October,2020,01:43:24:51043
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ8K39N011708   License Plate: 6054292
Mileage: 202470km-125809mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K39N011708   Mileage: 202470km-125809miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine (------CDHB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 D    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H07 0002
   Revision: A5H07---
   Coding: 0104000C02070120
   Shop #: WSC 00050 726 96790
   ASAM Dataset: EV_ECM18TFS8K1907115D A01003
   ROD: EV_ECM18TFS8K1907115D.rod
   VCID: AF2E4EFAF6DAAFFE3A-80FA
          U1113 00 [047] - -
                    Fault Frequency: 20
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:02:36
                    Engine speed: 820.50 /min
                    Normed load value: 30.6 %
                    Coolant temperature: 101 °C
                    Intake air temperature: 63 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.640 V
          U1113 00 [047] - -
                    Fault Frequency: 20
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:02:36
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [047] - -
          [Diagnostic interface for databus -J533-please read DTC]
                    Fault Frequency: 18
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:02:36
                    Engine speed: 701.50 /min
                    Normed load value: 31.4 %
                    Voltage terminal 30: 13.805 V
4901 - Engine Mount Solenoid Valves (N144/N145)
          P1588 00 [047] - Open Circuit
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:02:36
                    Engine speed: 707.50 /min
                    Normed load value: 27.8 %
                    Voltage terminal 30: 13.711 V
2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [175] - Malfunction / Open Circuit
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:02:36
                    Engine speed: 781.00 /min
                    Normed load value: 28.2 %
                    Voltage terminal 30: 13.688 V
5671 - Boost Pressure Regulation
          P0299 00 [109] - Control Range Not Reached
                    Mileage: 202413 km
                    Date: 2008.05.29
                    Time: 22:10:11
                    Engine speed: 2649.00 /min
                    Normed load value: 75.3 %
                    Vehicle speed: 74 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 13.617 V
Readiness: 0010 0001
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 T    HW: 0AW 927 156 G
   Component: 0AW 18TFSIRdW H01 0009
   Revision: --H01---    Serial number: 0000000335
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: C4C411564F5C3CA6F7-8090
   Part No SW: 8K0 907 379 BH    HW: 8K0 907 379 BH
   Component: ESP8 front    H04 0050
   Coding: 054500
   Shop #: WSC 80093 222 69422
   VCID: 804CDD4613C4E08693-80D4
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 18
                    Reset counter: 46
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 22:03:25
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0014
                    Hex Value: 0x13AB
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
   Component: BCM2 1.1      H71 0134
   Coding: 010200
   Shop #: WSC 02399 823 56573
   VCID: FAB8AFAE7518BA56DD-80AE
   Subsystem 1 - Part No SW: 8T0 959 754 J    HW: 8T0 959 754 J
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0810000090577007
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000026631008
   Part No SW: 8T1 820 043 AB    HW: 8T1 820 043 AB
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C0000000    Serial number: 0118.07.080082
   Coding: 64002000
   Shop #: WSC 06342 000 00000
   VCID: F1AA8882286EF90E6C-80A4
   Part No SW: 8K0 907 063 A    HW: 8K0 907 063 A
   Component: BCM1 1.0      H22 0253
   Revision: 02022001    Serial number: 00000000193417
   Coding: 6900C0B10034A7010001000000005F5F0F14420800000141000000
   Shop #: WSC 06342 123 12345
   VCID: AD1254F2F4D6DDEE08-80F8
   Component: WWS 010808  H06 0070
   Serial number: SWFBIE 0000011
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10210139
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 C    HW: 8K0 941 531 C
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002707081035
                    Fault Status: 01101100
                    Mileage: 202449 km
                    Date: 2008.05.30
                    Time: 01:49:00
01845 - Rear Window Shade Switch (E149)
                    Reset counter: 80
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 21:58:00
Address 10: Park/Steer Assist
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD185BN5
   Coding: 30343434363030303030554A304C384B3053
   VCID: BC3469B637AC44668F-80E8
   Serial number: 6334MSME3E303559F
   Serial number: 6344MSME3D454914H
   Serial number: 6352QSME77083E59U
   Serial number: 6362QSME7F2F3141Q
   Serial number: 63732SME28691B4EB
   Serial number: 63832SME0F063626
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120407000451
   Coding: 000014
   VCID: CFEE2E7A9E1ACFFE5A-809A
   Part No SW: 8K0 920 900     HW: 8K0 920 900
   Component: KOMBIINSTR.   H16 0224
   Revision: 00000000    Serial number: 9DL30LU78
   Coding: 0F02080002000008010000
   Shop #: WSC 00046 000 00000
   VCID: E79EE6DA16AA37BE32-80B2
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G087198285
   Coding: 000303
   VCID: C6C00B5E71600EB6E9-8092
02071 - Local Databus
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:18
01327 - Control Module for Parking Aid (J446)
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:19
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:23
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:23
02252 - Generator
                    Fault Frequency: 20
                    Reset counter: 46
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:38:50
00458 - Control Module for Battery Monitoring (J367)
                    Fault Frequency: 20
                    Reset counter: 46
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:38:50
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007540137
   Coding: 011C02204100410001
   VCID: BFCE1EBA2EBA5F7EAA-80EA
   Revision: 00002001    Serial number: 0111150890
   Coding: 0100062800290504013001
   Subsystem 1 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
7 Faults Found:
00985 - Right Tail Light (M2)
                    Fault Status: 11101100
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:17
02737 - Bulb for Tail/Fog Light; Right
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:17
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:40:00
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 21:49:32
02106 - Rear Window Shade Motor (V91)
                    Mileage: 202409 km
                    Date: 2008.05.29
                    Time: 21:57:32
02615 - Fuel Tank Cap; Lock
                    Mileage: 202435 km
                    Date: 2008.05.29
                    Time: 22:27:57
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101100
                    Reset counter: 84
                    Mileage: 202449 km
                    Date: 2008.05.31
                    Time: 01:30:28
Address 47: Sound System
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007514480
   VCID: BE3063BE29B05676A1-80EA
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000187362
   VCID: B12A4882E8EEB90E2C-80E4
Address 56: Radio (J503)       Labels:. 8Tx-035-152-56.clb
   Part No SW: 8T1 035 152 A    HW: 8T1 035 152 A
   Component: Chorus3       H02 0031
   Revision: 00000001    Serial number: AUZ1Z2H1360857
   Coding: 00000480040100000119070000
   VCID: AE1053FEF9D0A6F631-80FA
   Subsystem 1 - Part No SW: 8T0 919 603     HW: 8T0 919 603
   Component: Display  H09 X017
   Serial number: AUZ1Z2H5094153
00871 - Bass Speaker Front Right (R23)
                    Mileage: 202406 km
                    Date: 2008.05.29
                    Time: 21:37:26
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007493713
   Coding: 010C02204000210001
   VCID: FF4E5EBA6E3A9F7EEA-80AA
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007562842
   VCID: FEB0A3BE69309676E1-80AA
Address 77: Telephone
End----------(Elapsed Time: 01:25, VBatt start/end: 13.7V/13.8V)-----------
Address 03: DTCs cleared
[B][CODE][/B]
South Molton, UK
Have you replaced the ABS module?
If not, what other changes have you made (either hardware or coding/adaptation tweaking)?
siliko
Palestine
C?ID=302022
Hi
The car made an accident and the key is changed and switch for key also has been changed
South Molton, UK
That likely means the VIN stored in the Advanced ID of the ABS, engine ECU, etc. don't match - which needs to be corrected.
