09 tdi starts then dies, no immobilizer codes
mccrojm1987
Oregon, USA
C?ID=420217
this car has been nothing but issues since i bought it. the water pump impeller spun off the shaft so i replaced the timing belt and components, took it on one long test drive, parked the car and ever since it has started, ran for a second or so then shuts down. the abs and traction control have been on since changing the turbo but both seem to be operating. i was assuming it was an immobilizer issue but there seem to be no faults. this is my first time using vcds so any help is much appreciated. initial scan results posted below. i did pull the upper timing cover and both the cam and injection pump timing locks still slid into place with no issue, assuming if both of those were still lined up the crank should be as well
Saturday,17,October,2020,09:47:42:59245
VIN: 3VWRL71K79M085143   License Plate: 1234
Mileage: 310310km-192817mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K79M085143   Mileage: 310310km-192817miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 J    HW: 03L 906 022 J
   Component: R4 2.0l TDI G001SG  9983
   Revision: 12H01---    Serial number: VWX7Z0HN24A0ZR
   Coding: 0050072
   Shop #: WSC 43401 001 1048576
   VCID: 35372537E94F0073B15-8060
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
                    Mileage: 308418 km
                    Time: 04:34:23
                    RPM: 1771 /min
                    Speed: 28.0 km/h
                    Load: 22.7 %
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 00000000
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
               P0016 - 000 - Incorrect Correlation
                    Mileage: 310314 km
                    Time: 05:57:38
                    RPM: 184 /min
                    Voltage: 9.04 V
                    Temperature: 18.9°C
                    Idle Stabilization: -2.7°KW
                    RPM: 103 /min
                    (no units): 33.0
000257 - Mass Air Flow Sensor (G70)
               P0101 - 003 - Implausible Signal - Intermittent
                    Fault Status: 00100011
                    Mileage: 310315 km
                    Time: 00:03:41
                    Voltage: 11.78 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 1100.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B400D492A00FF880C02E8921C00423000
   Shop #: WSC 35270 001 1048576
   VCID: 76B5E23BB8C94B6B78F-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 195
                    Mileage: 305135 km
                    Count: 4608
                    Count: 125
                    Count: 49424
                    Count: 61412
02781 - ASR/ESP Button (E256)
                    Reset counter: 108
                    Mileage: 310315 km
                    Count: 7
                    Count: 3
                    Count: 4096
                    Count: 156
                    Count: 28160
                    Reset counter: 108
                    Mileage: 310315 km
                    Count: 7
                    Count: 3
                    Count: 4096
                    Count: 128
                    Count: 29184
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EC03BEDD3D1B6A3-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001128330
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 000 00000
   VCID: 323D1E2B1821174B947-8066
   Component: Wischer 101108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Reset counter: 108
                    Mileage: 298808 km
                    Voltage: 14.00 V
                    Reset counter: 148
                    Mileage: 310315 km
                    Voltage: 9.10 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0465949
   Coding: 0000100
   VCID: 33331B2FE73B1E439F1-8066
00003 - Control Module
                    Fault Status: 00101110
                    Reset counter: 12
                    Mileage: 245609 km
                    Time: 00:40:34
                    Reset counter: 148
                    Mileage: 310315 km
                    Time: 23:17:36
                    Voltage: 8.40 V
                    Reset counter: 148
                    Mileage: 310315 km
                    Time: 23:17:06
                    Voltage: 8.10 V
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07KE52
   Coding: 0013889
   VCID: 6C81C053FA8581BB9EB-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3E50207FH
   Subsystem 3 - Serial number: 6342MSME406103781
   Subsystem 4 - Serial number: 6351HSME190E1B3AG
   Subsystem 5 - Serial number: 6361HSME18376C72E
   Subsystem 6 - Serial number: 63727SME190856470
   Subsystem 7 - Serial number: 63827SME190564781
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           057 0101
   Coding: 0002021
   VCID: 045188F3F21569FB76B-8050
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0HN24A0ZR
   Coding: 0023203
   VCID: 392F2907C557E41355D-806C
                    Reset counter: 148
                    Mileage: 310315 km
                    Time: 17:17:48
                    Reset counter: 148
                    Mileage: 310315 km
                    Time: 23:19:13
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 270908F2000658
   Coding: E9807F070013021002
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3JMW04
   Coding: 0000003
   Component: IMMO            3HL 2418
   Shop #: WSC 23071 444 85660
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000803389022
   Coding: 0001205
   VCID: 6FBBD75FCB937AA3BB9-803A
                    Fault Status: 01100101
                    Reset counter: 108
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 145
                    Mileage: 249280 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D064B30F15F8B2C7-807E
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 11.8 V
                        PD
                    Temperature: 29.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 13900F880186281B0904058FB0880F0488DC00
                    Reset counter: 148
                    Mileage: 310315 km
                    Time: 23:17:50
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08081300260302
   Coding: 0001204
   VCID: 70B9D423D6AD655BA23-8024
                    Reset counter: 108
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Frequency: 8
                    Reset counter: 148
                    Fault Status: 00111000
                    Reset counter: 135
                    Mileage: 309901 km
00110 - Right Mirror Turn Signal Lamp (L132)
                    Reset counter: 146
                    Mileage: 285282 km
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2252105
   Coding: 0010401
   VCID: 290FF94735F7549325D-807C
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003624876
   Coding: 0001168
   VCID: 76B5E23BB4C94B6B78F-8022
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003621319
   Coding: 0001168
   VCID: 77ABEF3FB3C33263639-8022
                    Reset counter: 135
                    Mileage: 309078 km
                    Fault Status: 00111100
                    Reset counter: 135
                    Mileage: 309078 km
End----(Elapsed Time: 01:32, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
   Coding: 0050072
               P1698 - 000 -
                    Mileage: 308418 km
                    Time: 04:34:23
                    RPM: 1771 /min
                    Speed: 28.0 km/h
                    Load: 22.7 %
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 00000000
                    Mileage: 310314 km
                    Time: 05:57:38
                    RPM: 184 /min
                    Voltage: 9.04 V
                    Temperature: 18.9°C
                    RPM: 103 /min
                    (no units): 33.0
                    Mileage: 310315 km
                    Time: 00:03:41
                    Voltage: 11.78 V
                    Load: 100.0 %
                    Load: 100.0 %
   Revision: 00H35001
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 108
                    Mileage: 310315 km
                    Voltage: 11.40 V
   Coding: 0000100
                    Reset counter: 12
                    Mileage: 245609 km
                    Time: 00:40:34
   Coding: 0013889
   Coding: 0002021
   Coding: 0023203
   Coding: 0000003
   Coding: 0001205
                    Reset counter: 108
                    Mileage: 310315 km
   Revision: 00H15000
            000 - - - MIL ON
                    Mileage: 310315 km
                    Time: 21:43:39
                    Battery Volts: 11.9 V
                        DD
                    Temperature: 17.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0001204
                    Reset counter: 108
                    Mileage: 310315 km
   Coding: 0010401
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:28, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
Jef
HQ
Thank you for posting the full Auto-Scan.
Are you 100% sure the engine is correctly times up? Because that fault codes says otherwise. Key on, engine off, 01-08-001.3, what is your fuel pressure readings going to when cranking over?
Also, for giggles, I'd pull the Fuel Metering Valve (N290) and verify there is no glitter.
