2017 GTI S DSG faults
aljb320
Long Island
C?ID=174376
Hello hope this MSG finds everyone is safe and healthy,
I have a weird issue on my STOCK with NO TUNES that I'm aware of, 2017 gti S with DSG 22k miles purchased used on a trade in at a mercedes dealer.
key on engine off scan 1 shows 02-Auto Trans -- Status: OK 0000. however Address 02: Auto Trans (J743) indicates a fault see (Scan 1).
then with engine on gear selector moved from D thru gears and back to D initial status indicates OK but Address 02: Auto Trans (J743) see (Scan 2) shows many faults, any thoughts, thanks in advance for your assistance.
SCAN 1
Sunday,18,October,2020,13:36:47:09643
VCDS Version: 20.4.2.0
VIN: 3VW4T7AU5HM064026   License Plate: ALECS GTI
Mileage: 37470km-23282mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU5HM064026   Mileage: 37470km-23282miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 377DE3BD8E682F3EE2-8062
Readiness: 1010 1101
   Part No SW: 0D9 300 042 S    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5007
   Revision: 06454104    Serial number: TFK01702172111
   ROD: EV_TCMDQ250021.rod
   VCID: 295935C548DC89CE64-807C
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51037000000931
   Coding: 01FA6BA1342609708077020280C92980D62C90014001943400435050C009430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 000F48619B26A88613-8054
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   VCID: 4A9BAA49ED9AA2D68D-801E
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86427041700WZ
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 071D537DBE089FBE52-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170225  043 0551
   Serial number: 97022066170311091035
   Serial number: 003GCR07Y1U1
   VCID: 479D937DFE885FBE92-8012
   Occupant Detection:
   Serial number: IBH000000000006YL8C+
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: 35700000000C058DE12R
   Subsystem 3 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: 35800000000A692CA12P
   Subsystem 4 - Part No SW: -----------    HW: 480 402 403 17
   Serial number: 35100019924CEFC4819N
   Subsystem 5 - Part No SW: -----------    HW: 480 401 003 17
   Serial number: 3520001B325187D451A
   Subsystem 6 - Part No SW: -----------    HW: 480 401 603 17
   Serial number: 3550002BD24F3842F09F
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 603 17
   Serial number: 3560002BD24F38458238
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03031708490032
   Coding: 0410
   VCID: 020B4269952ABA9605-8056
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BBD090AA180CF0502086A001000000000000000
   VCID: 2D51C1D57C3495EE88-8078
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5286
   Serial number: 15051700840666
   Coding: 0101000870085900FB0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_GatewNF_VW37.rod
   VCID: 2E53C6D97132EEF6B1-807A
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000025240037036
   Coding: 31FFFF
   Serial number: 280417060509SC
   Coding: 003E03200000020000000000
   VCID: 4385876DCAB0739E4E-8016
   Serial number: 00000000000006220583
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C176C51A76EFCE67F-8058
   Serial number: 290417060501B8
   VCID: 428B8269D5AA7A9645-8016
   Serial number: 00000000000006205316
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW02GFU
          B11CF 53 [009] - Deactivated
                    Reset counter: 56
                    Mileage: 37470 km
                    Date: 2020.10.18
                    Time: 12:44:16
                    Voltage terminal 30: 14.5 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 137 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 170225202192
   VCID: 6BD50FCD82A05BDED6-803E
End-------------------------(Elapsed Time: 03:47)--------------------------
SCAN 2
Sunday,18,October,2020,14:19:51:09643
VIN: 3VW4T7AU5HM064026   License Plate: GTI MK7
   Revision: --H13---
7 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
   Revision: 00001K04
   Occupant Detection:
   Coding: 30305A
   Coding: 0410
   Coding: 31FFFF
   Coding: 011000
   Coding: 8102
   Coding: 091000
                    Reset counter: 56
                    Mileage: 37470 km
                    Date: 2020.10.18
                    Time: 12:44:16
End-------------------------(Elapsed Time: 03:27)--------------------------
aljb320
Long Island
C?ID=174376
Oh I forgot to add that there are no drivability issues.
myounus
Northwest UK
C?ID=321059
It’s a common issue seen with most DSG’s. Doesn’t affect its usage. Just clear the faults and ignore them.
Fault codes that are flagged "Intermittent - Not Confirmed" and not reported to the Gateway ("Status: OK 0000" for that module) are generally not something that should create an immediate concern. They can be an indication of something starting to get wonky, but they can also be a spurious artifact of the diagnostic stack in that module.
aljb320
Long Island
C?ID=174376
Ok thanks guys I'll keep that in mind, appreciate the response.
Maybe not related at all but I also have a dealers appointment for a recall due to a faulty DSG shifter switch that fails and can cause the car to start in any gear. will see if dealer picks up on these faults, thanks again.
