2019 Golf Sportwagen Highline 4motion TSI CXBB
Max of Millbrook
C?ID=418347
Sunday,18,October,2020,12:49:57:40859
VIN: 3VW117AU9KMXXXXXX   License Plate:
Mileage: 1179km-732mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 2B 3C 42 44 52 5F CA
VIN: 3VW117AU9KM522795   Mileage: 1179km-732miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122466002F1000
   Shop #: WSC 00066 790 00223
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS020_VW37.rod
   VCID: 46D552A0F82E148B28F-8012
23126 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01908260493
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 59EF89DC59908B7375D-800C
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 52769000000087
   Coding: 04FA6AA12022096E807E0309A0C8292056049001C005943416435050D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00088
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 065592A0B8AED48B68F-8052
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0524724012
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D755ACC5281F93215-8010
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 02020024200118000004000012111000
   VCID: 48C95C98F23A02FBDA3-801C
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86415101905G9
   Shop #: WSC 00066 790 00395
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BA3F354F36C9963071-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190817  043 0551
   Serial number: 97022066190830143726
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SBY19M08D18H23M14S24
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300291020190C201159
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 0
                    Mileage: 1113 km
                    Date: 2020.10.14
                    Time: 11:30:23
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3500000101FFC728949C810520400600000000000000000004
   VCID: 44D148A8CE12269B36B-8010
   Serial number: 003GCR0CKT5
   VCID: 47CB5FA4FF240D83D39-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000CDODS7
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 000 309 19
   Serial number: 3570000000070CA8DF3/
   Subsystem 3 - Part No SW: -----------    HW: 480 000 309 19
   Serial number: 358000000004B15CDF3.
   Subsystem 4 - Part No SW: -----------    HW: 480 402 208 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001BEF203243870-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 708 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001C0F08AF843A7H
   Subsystem 6 - Part No SW: -----------    HW: 480 402 409 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF2926C5E51K
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 409 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF2926C699AU
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         251 2700
   Coding: 0BA4101AA588880902886A095000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 270BFF245F64ED83339-8072
   Serial number: 07101900840613
   Coding: 0901000830085900FA0002081C0F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CA00B01EFCCBB0F-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MDM  H18 0052
   Serial number: 33190001486640031439
   Coding: 2CFFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: U13DCAC  H27 0810
   Serial number: 8005908
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00013.08.19
   Coding: 0001
   VCID: 4CC16088E642EEDBFEB-8018
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000228214001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F117C61A0A333EDD-8064
   Serial number: 0525615448
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273D4CADF85753795-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0529010747
   Coding: 010111
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038928302827
   Coding: 003013200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4DC76D8C1D58E7D3E95-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004348252
   Coding: 011000
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 010A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51FF71FC0160C3338DD-8004
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038927402098
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004351160
   Coding: 091000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 97
                    Mileage: 331 km
                    Date: 2020.09.16
                    Time: 10:27:34
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 02731200BE00000041220001001828009F0500D40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E050A00709EBCCBF0F-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  254 8130
   Serial number: VWZ6ZMW3095281
   Coding: 00804073720C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E56CD548CF13715-8020
End----------(Elapsed Time: 01:25, VBatt start/end: 12.1V/12.1V)-----------
