Hi ,just thought it would be polite to post a update , today i recieved a used window motor(with module) the exact same part number as mine ..
I replaced exsisting damaged motor with the donor motor plugged in checked coding to make sure original code was showing and it was .I then tested the donor motor all windows worked along with roof ,the only issue i have (had) was drivers window would not work with one touch either up or down ,neither did it go down when it hit the all windows down button and the roof ..I tried the reset but nothing ,only way it works is when i put my module in the motor and then one touch reset worked ..I presume it must be a code somewere ,would be nice to know if it could be sorted ..
