I'm helping a friend with his 2018 TTRS that stated having issues with his DGG. Here is some background:
The car has had a front Wavetrac installed recently, since the install it has had multiple 10 second drag strip passes, some spirited street use and a test session on a short track. The problem surfaced after running a time attack event where it completed multiple sessions. On the way to the parking lot after the event is when it threw codes. Now the car only shifts 1-3 and this morning it will not go in reverse.
A full scan is posted below. any help or ideas would be appreciated
Saturday,17,October,2020,18:24:07:24295
VIN: WUACSAFV7J1903020 License Plate:
Mileage: 17120km-10637mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
6C
VIN: WUACSAFV7J1903020 Mileage: 17120km-10637miles
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8S0 907 404 G HW: 07K 907 309 E
Component: R5 2.5l TFSI X22 0004
Revision: 53X22000
Coding: 1A250032242600053620
ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
ROD: EV_ECM25TFS0118S0907404G.rod
VCID: 3A2DCE3E4CDA77AB5C7-806E
Readiness: 1110 0101
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2111
Revision: 00H06V07
VCID: 2E05F26E8092AB0BF0F-807A
10726 - Gear Selector 2
P176B 00 [044] - Cannot be Regulated
Mileage: 17120 km
Date: 2020.10.17
Time: 09:10:42
Engine speed: 1078.00 /min
Coolant temperature: 25 °C
Clutch: primary stat: Neutral
selected gear: GANG N
Driving position: P
Engine torque: -20 Nm
Control Module temperature: 25 °C
Accelerator position: 14.4 %
DTC memory status: 110
Part No SW: 8S0 907 379 J HW: 8S0 907 379 J
Component: ESC H42 0050
Revision: 00000000 Serial number: 60828000000306
Coding: 99AAF08D6A9915AC009108668391900635990F56A80010C10960AC
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: 48C9A4F60236153BDA3-801C
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0474836805
Coding: 030C0C1720
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25C22E50F25B8B60F-806A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 18140000009000
Coding: 400050100001041100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C813866760E191B9EB-8038
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 43D0512900PAG0MUFU03
Operating and display unit 1 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number: 00000000000000048472
Operating and display unit 2 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Operating and display unit 3 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Operating and display unit 5 for air conditioning:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Part No SW: 5Q0 937 085 BP HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H36 0253
Serial number: 01001809600282
ROD: EV_BCMBOSCH_018.rod
VCID: 084964F642B6D53B1A3-805C
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 180308 038 0371
Serial number: 00000001803050303274
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 63283032
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 06 01 2018 00000700
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z000202
Coding: 150000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 8S0 959 719 HW: 8S0 959 719
Component: GTO BF H05 0010
Serial number: 20180214065724 00004
Subsystem 6 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000010269146
Valve Block 1 In Driver Side Front Seat:
Subsystem 7 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N475 VB1 FSv H07 0021
Serial number: 7008173235E172403482
Coding: 810500
Valve Block 1 In Passenger Side Front Seat:
Subsystem 8 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N477 VB1 BFSv H07 0021
Serial number: 7008173235E180200489
Coding: 810500
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39361808200181
Coding: 0070150011
VCID: 43D3B3DA3B1036630F1-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 H HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0083
Serial number: 190318004
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 46D5AACE0822034B28F-8012
Part No SW: 5Q0 959 655 R HW: 5Q0 959 655 R
Component: AirbagVW20 010 0830
Serial number: 003M9R009BRM
Coding: BFCCF0C000800000A000001FC24800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4FFB8FEAE758C2039B9-801A
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000000000096M388
Coding: 303333
Subsystem 2 - Part No SW: ----------- HW: 480 000 504 18
Serial number: 35700000000E97885F2/
Subsystem 3 - Part No SW: ----------- HW: 480 000 504 18
Serial number: 35800000000A3539DE2W
Subsystem 4 - Part No SW: ----------- HW: 480 012 203 18
Component: SideSensor_Dr 005 0108
Serial number: 351001A0D2AC42120F4%
Subsystem 5 - Part No SW: ----------- HW: 480 400 503 18
Serial number: 3550002A7256299250C+
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 400 503 18
Component: FrontSensor_P 001 6149
Serial number: 35600029B25325B3615-
Part No SW: 8S0 907 129 AS HW: 8S0 907 129 AS
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335RBQ00162
Coding: 2058
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_009_SE37.rod
VCID: 0B435BFA53C0BE23371-805E
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 890 C HW: 8S0 920 890 C
Component: FBenUSA H42 0325
Coding: 086F10413989CF050222ECC09800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
ROD: EV_DashBoardBOSCHAU33X.rod
Part No SW: 8S0 907 468 G HW: 8S0 907 468 E
Component: GW MQB TT3 022 0323
Serial number: 08031810520404
Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X_013.rod
VCID: 44D1B0C63E1E315B36B-8010
Subsystem 2 - Part No SW: 8S0 951 523 K HW: 8S0 951 523 K
Component: J453 MFL H01 0002
Serial number: 20180321071119 00157
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 1142967004
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00023.02.18
Coding: 0701
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 4DC795E2ED54F013E95-8018
Part No SW: 8S0 907 566 HW: 4H0 907 566 F
Component: SWA Master H08 0060
Serial number: 0474464261
Coding: 030311
ROD: EV_LaneChangAssis_VW51.rod
VCID: 7CA10826066E899B0EB-8028
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8S0 907 568 HW: 4H0 907 568 F
Component: SWA Slave H08 0060
Serial number: 0474649045
Coding: 030311
Component: TSG FS 020 0041
Serial number: 200318ECJ18907
Coding: 001F53225C00040100000402
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 811E0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B23CB3A43E04EA3471-806E
Part No SW: 8S0 035 466 A HW: 8S0 035 466
Component: MIB2_amp_P_TT H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5C00AFW6
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 3431E0066EBE81DB86B-8060
Component: TSG BFS 020 0041
Serial number: 210318ECK27075
Coding: 001F53225E00040100000402
VCID: 42DDB6DE240A3F6B047-8016
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 0362001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 3635DA0E78C293CBB8F-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8S0 035 025 K HW: 8S0 035 025 B
Component: MU-H-LNS-US 054 1173
Serial number: A707C0JS003440
Coding: 013364020000000011220002041A00102F0000E1007000047E
VCID: 3537DD0265C498D3B15-8060
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK102031800010081
Compact Disc Database:
Component: Gracenote2 --- 3012
B11CF 53 [009] - Deactivated
Reset counter: 207
Mileage: 17120 km
Date: 2020.10.17
Time: 09:10:59
Voltage terminal 30: 14.8 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Component: RVC Compact H12 0231
Coding: 0233640102002001000040
VCID: 392FD13249DC7CB355D-806C
End----------(Elapsed Time: 01:29, VBatt start/end: 12.0V/12.0V)-----------
