8S TTRS DSG issues
PeteJ
C?ID=340777
I'm helping a friend with his 2018 TTRS that stated having issues with his DGG. Here is some background:
The car has had a front Wavetrac installed recently, since the install it has had multiple 10 second drag strip passes, some spirited street use and a test session on a short track. The problem surfaced after running a time attack event where it completed multiple sessions. On the way to the parking lot after the event is when it threw codes. Now the car only shifts 1-3 and this morning it will not go in reverse.
A full scan is posted below. any help or ideas would be appreciated
Saturday,17,October,2020,18:24:07:24295
VIN: WUACSAFV7J1903020   License Plate:
Mileage: 17120km-10637mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
          6C
VIN: WUACSAFV7J1903020   Mileage: 17120km-10637miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8S0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  X22 0004
   Revision: 53X22000
   Coding: 1A250032242600053620
   ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
   ROD: EV_ECM25TFS0118S0907404G.rod
   VCID: 3A2DCE3E4CDA77AB5C7-806E
Readiness: 1110 0101
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2111
   Revision: 00H06V07
   VCID: 2E05F26E8092AB0BF0F-807A
10726 - Gear Selector 2
          P176B 00 [044] - Cannot be Regulated
                    Mileage: 17120 km
                    Date: 2020.10.17
                    Time: 09:10:42
                    Engine speed: 1078.00 /min
                    Coolant temperature: 25 °C
                    Clutch: primary stat: Neutral
                    selected gear: GANG N
                    Driving position: P
                    Engine torque: -20 Nm
                    Control Module temperature: 25 °C
                    Accelerator position: 14.4 %
                    DTC memory status: 110
   Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
   Component: ESC           H42 0050
   Revision: 00000000    Serial number: 60828000000306
   Coding: 99AAF08D6A9915AC009108668391900635990F56A80010C10960AC
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 48C9A4F60236153BDA3-801C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0474836805
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C22E50F25B8B60F-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 18140000009000
   Coding: 400050100001041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C813866760E191B9EB-8038
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 43D0512900PAG0MUFU03
   Operating and display unit 1 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000048472
   Operating and display unit 2 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Operating and display unit 3 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Operating and display unit 5 for air conditioning:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H36 0253
   Serial number: 01001809600282
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084964F642B6D53B1A3-805C
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 180308  038 0371
   Serial number: 00000001803050303274
   Coding: 1BC7F7
   Serial number: 63283032
   Coding: 00005D
   Serial number: 06 01 2018  00000700
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z000202
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20180214065724 00004
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000010269146
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0021
   Serial number: 7008173235E172403482
   Coding: 810500
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H07 0021
   Serial number: 7008173235E180200489
   Coding: 810500
   Revision: --------    Serial number: 39361808200181
   Coding: 0070150011
   VCID: 43D3B3DA3B1036630F1-8016
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       190318004
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D5AACE0822034B28F-8012
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Serial number: 003M9R009BRM
   Coding: BFCCF0C000800000A000001FC24800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4FFB8FEAE758C2039B9-801A
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000000000096M388
   Coding: 303333
   Subsystem 2 - Part No SW: -----------    HW: 480 000 504 18
   Serial number: 35700000000E97885F2/
   Subsystem 3 - Part No SW: -----------    HW: 480 000 504 18
   Serial number: 35800000000A3539DE2W
   Subsystem 4 - Part No SW: -----------    HW: 480 012 203 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0D2AC42120F4%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 503 18
   Serial number: 3550002A7256299250C+
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 503 18
   Serial number: 35600029B25325B3615-
   Part No SW: 8S0 907 129 AS    HW: 8S0 907 129 AS
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335RBQ00162
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_009_SE37.rod
   VCID: 0B435BFA53C0BE23371-805E
   Part No SW: 8S0 920 890 C    HW: 8S0 920 890 C
   Component: FBenUSA       H42 0325
   Coding: 086F10413989CF050222ECC09800801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
   ROD: EV_DashBoardBOSCHAU33X.rod
   Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
   Component: GW MQB TT3    022 0323
   Serial number: 08031810520404
   Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013005
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 44D1B0C63E1E315B36B-8010
   Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
   Component: J453 MFL  H01 0002
   Serial number: 20180321071119 00157
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 1142967004
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00023.02.18
   Coding: 0701
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 4DC795E2ED54F013E95-8018
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0474464261
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA10826066E899B0EB-8028
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0474649045
   Coding: 030311
   Serial number: 200318ECJ18907
   Coding: 001F53225C00040100000402
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B23CB3A43E04EA3471-806E
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5C00AFW6
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 3431E0066EBE81DB86B-8060
   Serial number: 210318ECK27075
   Coding: 001F53225E00040100000402
   VCID: 42DDB6DE240A3F6B047-8016
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 0362001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 3635DA0E78C293CBB8F-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 025 K    HW: 8S0 035 025 B
   Component: MU-H-LNS-US   054 1173
   Serial number: A707C0JS003440
   Coding: 013364020000000011220002041A00102F0000E1007000047E
   VCID: 3537DD0265C498D3B15-8060
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK102031800010081
   Compact Disc Database:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 207
                    Mileage: 17120 km
                    Date: 2020.10.17
                    Time: 09:10:59
                    Voltage terminal 30: 14.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Coding: 0233640102002001000040
   VCID: 392FD13249DC7CB355D-806C
End----------(Elapsed Time: 01:29, VBatt start/end: 12.0V/12.0V)-----------
DrPeter
16.4905° S, 151.7375° W
I saw this post the other day, did a little research and did not come up with much and did not post anything.
Today, I see that no one has posted a response, so today I will post a thought I had when I first saw this post, it is a saying I use every so often..
"The light that burns twice as bright, burns half as long...."
And with " multiple 10 second drag strip passes " you have burned so very very brightly .
I would personally drain the transmission fluid and inspect for any concerns, I would also recommend to pull off the cover on the transmission and look for any concerns and/or damage.
Maybe something let go inside, R/R trans and open to inspect? Also have a look at the filter?
Hope this helps,
drpeter
SpoolinFool
WI, USA
C?ID=422106
Thanks PeteJ for the assist and recommendation to purchase VCDS. The Audi he mentions above is mine. Here is a follow up to the issue.
When this code came up I lost access to all even gears as well as reverse.
I cleared this code with VDCS which allowed me to back out of the garage and shift into first gear but as soon as it went into second gear it returned. I cleared the code again and it returned. The mechatronic unit was removed and oil tube seals inspected all of which looked undamaged. The magnets in the transmission were clean as well. Upon reassembly the codes were cleared again and a different code surfaced:
10698 Gear 2
P072D 00 [047] - Not Selectable
After clearing this code, performing a basic transmission alignment, clutch adaptation and fluid flush it went away and hasn't returned. The car now runs and drives just as it did when stock. That being said I don't like it when things fix themselves.
The "best guess" at root cause thus far was possible differential break-in material hanging up or binding the operation of the even gear selector. This debris may have been unseated during the basic alignment or adaptation process. I hate having to make a guess but it's better than being forced into purchasing a new mechatronics and paying Audi to VIN code it ($1800). That being said my circle of Audi mechanics is very very small. Even the most knowledgeable person was unable to diagnose and actually suggested that the car go to Audi for an ODIS scan if the issue resurfaces.
My question for you .... if this does come back again is Audi my only hope? I have a feeling their system will simply recommend a rip and replace of the mech or DSG. Is there a VCDS diagnostic I can run that will actually tell me WHY the code is initiated?
