Audi A6 C7 RMC to MIB 2
szymek
C?ID=414515
Hi
I am a new user of the forum and i post first autoscan . A few days ago I upgraded the RMC to MIB2 including the cluster plus the back up camera . I have a few faults after that and i don't know if i can be coded. When I delete it they keep coming back.
Saturday,17,October,2020,20:57:11:18224
VIN: WAUZZZ4G5FN062480   License Plate:
Mileage: 199101km-123715mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F 62
          6C 6D 72 AC
VIN: WAUZZZ4G5FN062480   Mileage: 199101km-123715miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FR    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0745
   Revision: 85H23---
   Coding: 12194012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FR 002003
   ROD: EV_ECM20TDI01104L906021FR_002.rod
   VCID: 7AADF6B21C5B2ADB1C7-802E
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A09E41600579829B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB47A647F9CFF36B9-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 03B9704E000000000000
   VCID: 7AADF6B21CDB2ADB1C7-802E
   Serial number: 3215000002866005
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 28011500042277
   Coding: 34220978290000
   VCID: 629DAED294CBC21B247-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00000988120602
   Coding: 0105001440349F6044014080000018000F9D87082F08020100000894E100140200400024030000
   VCID: 71BFD19E41AD6983ADD-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 141212  H37 0080
   Serial number:         141215124157
   Coding: 0045F7
   Serial number: 23684529
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 27 01 2015  00000066
   Serial number: AA280D87000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10031ZYG
   Coding: 30333130313630323639554A305234473053
   VCID: 3B2333B653E1D3D3471-806E
   Serial number: 3575HRB40552RDNQ81O+
   Serial number: 3585HRB400I50SE478G8
   Serial number: 3515JRB405J350J870Q
   Serial number: 3525JRB404V34BHEFHBV
   Serial number: 3554VRB406734GNGNP31
   Serial number: 3564VRB404P3504GJP1L
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OAE000RZ
   Coding: 000015
   VCID: 3B2333B65361D3D3471-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 16 12 2014  E0057271
   Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
   Component: TDieGb        H14 0225
   Revision: 11001108    Serial number: 658140616596056
   Coding: 33AD12000B412600010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 48C95C7A1237884BDA3-801C
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001715362
   Coding: C0CD074418
   VCID: 73B3DB963B315B935F1-8026
   Serial number: 1841145603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1410220000000000063D
5807 - Rear View Camera System Control Module
          U104C 00 [008] - No communication
                    Fault Frequency: 13
                    Reset counter: 76
                    Mileage: 198961 km
                    Date: 2020.10.15
                    Time: 23:24:49
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 23 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 30
                    Mileage: 198961 km
                    Date: 2020.10.15
                    Time: 23:25:36
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 7CA1F0AA16EF14EB0EB-8028
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 02021500040553
   Coding: 22
   VCID: 3D273DAE4DF5DDE3795-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720FE9FD
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331B967BB11B939F1-8066
   Component: TSG FA        H03 0507
   Coding: 011C16015C01620002080002
   VCID: 47CB5F461FA98733D39-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0014616893
   Coding: 101000010001
   Shop #: WSC 60091 001 1048576
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F29BE59DDE1C355D-806C
   Revision: 00002001    Serial number: 0359573835
   Coding: 013B0622A0B930D4C320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST00041HK600000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST00043CWF00000
   Coding: 801E00
   Component: TSG BF        H03 0507
   Coding: 011C16015E01620002080002
   VCID: 46D5524218A39E3B28F-8012
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 72
                    Mileage: 198961 km
                    Date: 2020.10.15
                    Time: 23:25:59
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001343815
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070DEE9D954D63C95-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FE02102A600200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 021 P    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   052 1425
   Serial number: A733I0G7510545
   Coding: 017502010000000013111101000A00122F0006E7F1700100DF
   VCID: 270BFFC6BF696733339-8072
   Subsystem 1 - Part No SW: V03 959 802 TL    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY8061YE
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 710 F    HW: 4G2 919 710 F
   Serial number: 90349NJF000K3
   Compact Disc Database:
   Component: Gracenote2  --- 1013
6678 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Control module for sound system: no communication]
                    Reset counter: 30
                    Mileage: 198961 km
                    Date: 2020.10.15
                    Time: 23:18:09
                    Voltage terminal 30: 12.0 V
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49CF597E09BD7143C5D-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002007000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78A9ECBA225738CB6A3-802C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 016500820
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3635228268C30EBBB8F-8062
   Component: TSG HR        H03 0507
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 143630398
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.3V)-----------
FandaTDI
Czech Republic
C?ID=204559
Hi szymek, good job! I would check coding/adaptations of 6C (maybe GW even if install.list could be ok...) and audio variant coding in 5F, but it looks like searching as I see the label info...
szymek
C?ID=414515
Thank you:thumbs:
Everything works but there are these faults. Any info and help is welcome:)
AINils
Germany (AIB)
As Iam right you use pre-facelift gateway right ? If you use facelift gateway you have to exclude it from most ring as MIB and GW will be master, but you can have only ine master in system
szymek
C?ID=414515
I played a bit of 19 can gateway installation list and in 5F but no results..
My car is facelift model...
szymek
C?ID=414515
Why you asking?
I check gateway list and for me everything fine but i can't dele 2 faults
FandaTDI
Czech Republic
C?ID=204559
It makes sense to bypass gw from MOST ring(post #4) if MIB takes the master of MOST ;-) Maybe for both faults, might also depend od the (communication) settings of control units and the MOST "infrastructure"...
Reminds me I´m dealing with simmilar issue after 3GP retrofit from 2G with many newer units and for example I didn´t find out how to tell (or if it is even possible) the unit of aux.heater that battery management is now in GW(fault no communication with batt.regulation), but the heater works and hopefully in a way as it should...
szymek
C?ID=414515
My bypass loom jus arrived today i will try
