Sticky Alligator attack!! Posting scan and maps easier now!!!*
Sticky
Jef
HQ
Ross-Tech is now testing a simple utility to help get Auto-Scan and channel maps posted. While I came up with this concept, the heavy lifting has been done by Sage so he get 98% of the credit here.
What does Alligator do? VCDS has a function to go into each control module and capture a snapshot of all the live data (channel map). The process generates a file or two for each module and posting all of that data online is a very time consuming task. Alligator bundles up all the files, puts them in order and formats them so all you need to do is copy/paste the results into a forum post.
Why would I want to post maps online? The short answer, to help others. A common question that comes up is "What should the value be for blah blah blah?" There is so much data in these cars over the last +20 years, no one knows what normal or good data is for everything. So by posting maps from known good cars, everyone will have access to this kind of information.
How do I get this Alligator? Alligator is bundled with Seb's Label File updater. Here is the download link:
Run the installer. Unless you speak German, do not have German Label Files installed, leave that box unchecked.
Once the Updater is complete, you will now have 2 new files where VCDS is installed:
  • CMAlligator.exe
  • CMAlligator-ReadMe.txt
How do I create maps of my car?
  • Engine at idle and up to operating temperature.
  • Full charge on your laptop, or have it plugged to the wall.
  • If possible, no fault codes in the modules.
CAN Gateway Diagnostics: Start VCDS, go to [Applications], then [Controller Channel Map] to open the Maps utility in VCDS.
Select "Whole Vehicle (CAN Only)". Pick which function, Measuring values and/or Adaptions. Measuring values are preferred over Adaptations. Have the Output set to Pre-label file. Then click on [Go] to start the processes. VCDS will create and save an Auto-Scan file with this process.
K-Line Diagnostics: Start VCDS, click on [Options] and then set the "Debug Level" to a value of 2.
Now click [Apply]. Now run an Auto-Scan and VCDS will run Measuring Block and Adaptation maps of all control modules. This took about 40 minutes on my 2004 Jetta. If you do this on a 2005 Touareg, set up camp for the night, you gonna be there a while.
Note - Alligator needs to see the VIN through the diagnostic port. This started with vehicles in 2002. 2001 and older cars Alligator will most likely not work.
I've made maps, what do I do to share them? From the first screen of VCDS, click on the tiny white VCDS icon in the upper left corner:
From the drop down menu, select "Open VCDS folder":
Once the VCDS folder opens up, double click on the CMAlligator.exe file to start Alligator:
Click on the [Browse] button for "Autoscan" to open the location where Auto-Scans are saved. Note that files names breaks down as follows:
  • Scan-(VIN)-(DATE)-(TIME)-(km)-(miles).txt
Select the Auto-Scan that was generated during your maps session and open it. By default, Alligator will be set to look for "Measuring Values". Click on [Copy] and you should get a confirmation showing the number of files found and lines copied.
Click [OK] and now you can start a new thread in the Reference Scans and Maps of Non-Broken Cars section. Please title your forum post as follows:
  • (Year) (Model), (Engine Type) (Engine Code)
In the main body where you would type in your post, right click and select [Paste] and you should see a massive wall of text populate the screen. Note this may take several seconds to happen. Once the text is there, you can then post your thread and know you've made the world a better place.
If you did both maps of both Measuring Values AND Adaptations, please post the Measuring Values first. Then in Alligator, select "Adaptations", then [Copy], now reply to your own thread and paste in the wall of text that is Adaptation.
Too much data from the maps? There is a line limit on how much text you can put into a single post. In cases where there is too much data to be copy and pasted, Alligator will break things down into smaller chunks that can be posted. If this happens, you will get this kind of message after you click on [Copy]:
Alligator will now have a number drop down list next to the [Copy] button:
The first section has already been copied, you can paste it and post it in your thread. Then from the drop down menu, select the next number and [Copy] and paste that section of data as a reply to your own thread.
I've replied to this thread showing an example of what the end results look like.
For cars that have UDS type control modules installed, only our current generation of interfaces, the HEX-NET and HEX-V2, can make channel maps on those. If you are using an older generation interface, it is not possible to make channel maps on UDS modules.
Jef
HQ
AutoScan: 3VW6T7AU8LM010575
VCDS Version: 20.4.1.0 (x64)  HEX-NET2 CB: 0.4523.4
VIN: 3VW6T7AU8LM010575   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F
          75 A9 BB BC D6 D7
VIN: 3VW6T7AU8LM010575   Mileage: 38km-23miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 092500124424012F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: BC2ADFBAE6E8BEBBCF3-80E8
Readiness: 0010 0101
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V10
   ROD: EV_TCMDQ381061.rod
   VCID: A61E1DD20864146B897-80F2
   Part No SW: 5Q0 614 517 DJ    HW: 5Q0 614 517 BM
   Component: ESC           H45 0113
   Revision: 00000000    Serial number: 50070000000424
   Coding: 01FA6BA15021216C807C020760C86880D60A84014006167610415051D0894B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: FCAA1FBAA6687EBB8F3-80A8
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0536436457
   Coding: 132C0C0723
   Shop #: WSC 00066 790 00088
   ROD: EV_KessyHellaMQBAB.rod
   VCID: C5DCBA5E9522FF73A0D-8090
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110001000000000010004
   VCID: CCCA8F7AB6480E3B7F3-8098
   Part No SW: 5Q0 937 087 BG    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: C864080220014O
   Shop #: WSC 00066 790 00248
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 81546E4EC18A1353DC5-80D4
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    191203  043  0551
   Serial number: 97022066191211134934
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051  0206
   Serial number: S4Y19M12D05H05M28S28
   Coding: 0008DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07  0170
   Serial number: 03691611121510191419
   Coding: 181803
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0300310120200C201572
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Coding: 3500008101FFC728949C810500401600000000000000000014
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
   VCID: C6DEBD52A824F46BA97-8092
   Component: AirbagVW20    012 0830
   Serial number: 003GCR0H2U6R
   VCID: C7C0B056AF2EED63521-8092
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000CKSTY/
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 611 19
   Serial number: 35700000000D3369334G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 812 19
   Serial number: 35800000000C9405534F
   Subsystem 4 - Part No SW: -----------    HW: 480 401 212 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011C62EFE930279
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001ACF1F5753D74M
   Subsystem 6 - Part No SW: -----------    HW: 480 400 801 20
   Component: FrontSensor_D  003 6149
   Serial number: 3550001C73225343561O
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 801 20
   Component: FrontSensor_P  004 6149
   Serial number: 35600010462F15A214F.
   Part No SW: 5G1 920 856 E    HW: 5G1 920 856 E
   Component: KOMBI         343 6700
   Coding: 0BAD091AA988CF0502886B0950000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   VCID: B032FB8A3AA04ADB63B-80E4
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 16012000841306
   Coding: 030100047F085900FB00006B1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: F0B23B8AFA200ADB23B-80A4
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001764170089311
   Coding: 29FFFF
   Serial number: 7720697100
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH09 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000347189005
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: B134FE8E31AA43D36C5-80E4
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00014.11.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: D2F69102546C58CB35F-8086
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0534469036
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BD2CD2BEFDF2B7B3F8D-80E8
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0533085033
   Coding: 010111
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 12058002604346
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: CDCC827E4D52073368D-8098
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000005231163
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: D1F49E0E516A23D30C5-8084
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 09012000840194
   Coding: 000000050900214A01110300040000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: B720C096DFCE9DE3221-80E2
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 13058004000662
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000005218577
   Coding: 091000
   Part No SW: 2GM 035 844 A    HW: 2GM 035 844 A
   Component: MU-S-S-US     725 0520
   Coding: 02731000BE00000041220001001808009F0503D40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: BFD0A8B6F7FEA5A3EA1-80EA
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  261 8214
   Serial number: VWZ6ZMX0405485
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000911NVZC6
   Coding: 0237002019682C008005461160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW37.rod
   VCID: 82566142C48C084BC5F-80D6
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 190710202672
   VCID: B236F18234AC78CB15F-80E6
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: B924C6AEE9DA8B93D45-80EC
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 13.4V/14.3V)-----------
blockmap-01-5G0-906-259-Q_3VW6T7AU8LM010575-20200618-1047.CSV
;Component:R4 2.0l TFSI  H13 0005, Coding:092500124424012F1000
;EV_ECM20TFS0205G0906259Q,001006,EV_ECM20TFS0205G0906259Q.rod
;Thursday,18,June,2020,10:47:35:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: BC2ADFBAE6E8BEBBCF3-80E8
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VW6T7AU8LM01057,
IDE00018,Voltage terminal 15,14.238, V
IDE00019,Voltage terminal 30,14.414, V
IDE00021,Engine speed,810, /min
IDE00025,Coolant temperature,51, °C
IDE00078,Time since engine start,83, s
IDE00083,Throttle valve position (absolute),12.5, %
IDE00084,Absolute load value,27, %
IDE00085,Normed load value,13.7, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,35.0, °C
IDE00148,Median injection timing,0.7, ms
IDE00149,Ignition angle of current cylinder: actual value,-0.75, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,69, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,389.6, °C
IDE00172,A/C compressor torque,-11.41, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,6.5, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,6.3, °
IDE00178,Camshaft adjustment intake bank 1: specified value,5.5, °
IDE00179,Camshaft adjustment intake bank 1: actual value,8.2, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-3.0, °
IDE00186,Fuel low pressure: actual value,6.666, bar
IDE00187,Coolant temperature at engine start,18.7, °C
IDE00188,Fuel high pressure: actual value,115.5, bar
IDE00189,Activation of fuel pump electronics,50.45, %
IDE00190,Charge air pressure specified value,0.989, bar
IDE00191,Charge air pressure: actual value,0.986, bar
IDE00192,Coolant temperature at radiator outlet: actual value,20.4, °C
IDE00193,Coolant temperature at engine outlet: specified value,51.0, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,30.7, °C
IDE00196,Engine oil temperature,20.0, °C
IDE00199,Mean engine air mass,15, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,113.5, bar
IDE00202,Low fuel pressure: specified value,5.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,48, l
IDE00348,Intake air temperature,26, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,14, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,20.2, °C
IDE00358,Limitation: torque,257.3, Nm
IDE00371,Fuel consumption,2.35, l/h
IDE00375,Generator: load signal,45.18, %
IDE00380,Coolant fan 1: activation,32.03, %
IDE00381,Coolant fan 2: activation,31.64, %
IDE00392,Accelerator pedal: sensor voltage 1,0.747, V
IDE00393,Accelerator pedal: sensor voltage 2,0.376, V
IDE00396,Charge Pressure Actuator: acknowledgment,3.521, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,16.20, %
IDE00405,Crankshaft speed (RPM),818, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00432,Particle filter: time since last regeneration,176, min
IDE00434,Particle filter: soot mass calculated,0.00, g
IDE00436,Particle filter: kilometers since last regeneration,38.7,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,10, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,31.46, %
IDE00477,Torque request: sum of auxiliary aggregate,26.6, Nm
IDE00478,Engine-drag torque,20.6, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,20.0, °C
IDE00496,Activation of oil pressure switch valve,High pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,closed,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,25, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.009 Lambda / 0.012 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.825, V
IDE00582,Equivalence ratio target value,1.003, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,26, km
IDE00588,Fuel tank fill level,98.8, %
IDE00589,Fuel pressure,11620, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-1.5, Degrees
IDE00594,Absolute intake pressure,37, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,-0.8, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,5.9, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,0, min
IDE01076-MAS00111,Time since ignition off-Seconds,0, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,3.0, °
IDE01378,High fuel pressure: control deviation,0.9, bar
IDE01385,Wear index,0.00000108,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,6.53, l
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.821, V
IDE01649,Throttle valve position 1,0.645, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,34.22, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,1.5, Nm
IDE01905,Average of ignition timing angle delay adjustment,12.00, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,-4.12, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,38, km
IDE01923,Control module distance driven,39, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,42.8, °
IDE01929,Open cam shaft angle at quantity control valve,2.9, °
IDE01931,High pressure pump injection volume control deviation,11, mg/stroke
IDE01932,High pressure pump injection volume,25, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,0,
IDE01977,Numb.of misfir.: cylinder 3,1,
IDE01978,Numb.of misfir.: cylinder 4,1,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,360.4, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.8, %
IDE02229,Exh.gas temp.sen 1,1110.0, °C
IDE02756,Number of manual engine starts,66,
IDE02757,Number of automatic engine starts,2,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,2,
IDE03010-MAS01627,Number of prevented stop processes-Steering,2,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,1,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,3,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,6,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,11,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,6,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.492, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.815, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.175, V
IDE03267,Intake air temperature: unconditioned voltage,2.080, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.597, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.760, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,42.9, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,1,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.518, V
IDE03582,Temperature sensor for engine temperature management,-48.0, °C
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control not complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,12, kg/h
IDE03767,Engine status,Idling,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,35.18, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,401, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,48.05, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,28.52, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,2.188, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Initializing,
IDE03921,Mixture adaptation factor at partial load,0.42, %
IDE03922,Mixture adaptation factor at idle speed,-1.94, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,-0.00010,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Adaptation procedure active,
IDE03931,Charge pressure actuator: actual position,0.19, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.521, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.521, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.48, %
IDE03957,Throttle valve angle: specified value,3.1, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,99.61, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04010,Engine torque: normalized,13, %
IDE04011,Nominal torque,350, Nm
IDE04110,Additional inputs and outputs,,
IDE04405,Mixture deviation in adapted partial load range 1,0.48, %
IDE04409,Intake manifold pressure: corrected,0.374, bar
IDE04410,Intake manifold pressure: target value,0.381, bar
IDE04412,Pressure before throttle valve: corrected,0.986, bar
IDE04415,Oxygen ctrl factor with precontrol correction,-4.33, %
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04629,AVS operating condition,Test is running,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,100,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.978, V
IDE04713,Active brake system status,operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.385, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.19, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.5205, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5205, V
IDE05316,Charge air pressure control valve voltage: position open,0.5206, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.983, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,30,
IDE06006,Idle speed specified value,800, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06192,Knock sensor: cylinder 2: voltage,0.336, V
IDE06193,Knock sensor: cylinder 3: voltage,0.360, V
IDE06194,Knock sensor: cylinder 4: voltage,0.384, V
IDE06195,Knock sensor: cylinder 1: voltage,0.335, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000001 ,
IDE06307-MAS00106,Stop prevention history data-Year,2011,
IDE06307-MAS00107,Stop prevention history data-Month,4,
IDE06307-MAS00108,Stop prevention history data-Day,24,
IDE06307-MAS00109,Stop prevention history data-Hours,1,
IDE06307-MAS00110,Stop prevention history data-Minutes,6,
IDE06307-MAS00111,Stop prevention history data-Seconds,24,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06307,Stop prevention history data,Engine temperature,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,129, mm
IDE06387,Oil level: last valid dynamic value,129, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,-127, mm
IDE06390,Oil level: minimum value,385, mm
IDE06391,Oil temperature sensor 2,21.0, °C
IDE06392,Oil temperature sensor 2: raw value,21.000, V
IDE06393,Oil level: dynamic average value,144, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.432, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,2.078, V
IDE06397,Temperature sensor for engine temp. management: target value,106.5, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,2.078, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.854, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.953, V
IDE06567,Start-stop function deactivation frequency counter,0,
IDE06568,Stop prevention by driver frequency counter,40,
IDE06569,Vehicle stopped frequency counter,82,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,3,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,Yes,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-4.25, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,0,
IDE07011,Tank leak: number communication errors to engine control,0,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,367386,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,7e+006, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,141.25, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,141.48, °
IDE07550,Engine temp. management actuator: raw value,2246,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Start,
IDE07553,Engine temperature management actuator: after-run stop,3948,
IDE07554,Engine temperature management actuator: stop open,145,
IDE07564,Required torque adjustment by idling regulator,-3.3, Nm
IDE07571,Engine torque,24.8, Nm
IDE07572,High pressure regulation: adaptation value,2.61, mg
IDE07574,Long-term fuel trim bank 1 at idle,-0.19, mg/stroke
IDE07575,Driver request torque,-1.3, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,-3.7, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,not activated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,not activated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,No,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,Yes,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,1,
IDE07905-ENG118117,Brake light switch status-actuated__activated,operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,1,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,not completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,not completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,not completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.233, counts
IDE08806,EVAP valve diag. activation condition at maximum load,608, mbar
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.597, V
IDE10380,Knock sensor average voltage bank 1,0.313, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,48.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12210,Particle filter: water mass,0.0, g
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,6.40, g
IDE13086,Particle filter: maximum soot build-up reached,8.00, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,3.000, counts
IDE13090,Particle filter: maximum soot loading ratio reached,4.000, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.000, counts
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.43826,
ENG103474,Activation of oil pressure switching valve,00000000 ,
ENG121286-ENG121430,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Engine Warm-up Timer (Lifetime),1409286155, s
ENG121286-ENG121431,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Engine Warm-up Timer (Recent),16777226, s
ENG121286-ENG121463,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Transmission Warm-up Timer (Lifetime),4294967295, s
ENG121286-ENG121464,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Transmission Warm-up Timer (Recent),2852126719, s
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,11.97, kg/h
ENG104264,Alternator load,1200, W
ENG103910,Ambient temperature,24.00, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0045, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.5, V
ENG07601,Bypasstool_a2l_name,ORIGINAL A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,5G0259Q 0005BXA,
ENG99697,Calibration Verification Number,01 26 20 F7,
ENG128780,CAM_DIF_VCP[EX_1],-0.031, °
ENG128781,CAM_DIF_VCP[IN_1],2.086, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],7.992, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],6.508, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],8.000, °
ENG112543,CAM_SP_IND_VCP[IN_1],7.000, °
ENG112544,CAM_VCP[EX_1],8.125, °
ENG112545,CAM_VCP[IN_1],3.023, °
ENG103849,Cat. ageing: bank 1: actual,0.000,
ENG102214,CPU_LOAD,52.9, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG101127,CTR_CDN_OBD_RBM,1,
ENG114826,CTR_EDGE_CAM_EX[1],126,
ENG114827,CTR_EDGE_CAM_IN[1],131,
ENG100536,CTR_IGK_CYC_RBM,77,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],0,
ENG125195,CTR_LAMB_SP_PI_REQ[2],0,
ENG125196,CTR_LAMB_SP_PI_REQ[3],0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],1,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],1,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],1,
ENG112558,CTR_MIS_TOT_NVMY_SAE,60,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,143.9,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,100,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,41,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,56,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST[0],NO_ERROR,
ENG99120,DIAG_INST[1],NO_ERROR,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,26, km
ENG103766,DIST_ENG_RUN_IN,0.3, m
ENG100531,DIST_ST,38700, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,-EngineControl,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG115973,Engine Exhaust Flow Rate,16.2, kg/h
ENG20102,Engine Friction - Percent Torque,6.0, %
ENG104044,Engine load,17.578125, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,60.44, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],0.478, %
ENG100298,FAC_LAM_CP,-0.592, %
ENG100108,FAC_LAM_LIM[1],-0.504, %
ENG99722,FAC_LAM_TCO_A[1],0.000, %
ENG103521,FAC_LAM_TCO_B[1],0.000, %
ENG103641,FAC_LAM_TCO_C[1],0.000, %
ENG101578,FAC_LAM_TCO_D[1],0.000, %
ENG100685,FAC_LAM_TCO_E[1],0.000, %
ENG103307,FAC_MAF_MAX,0.22733,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,12.890625, %
ENG102292,FAC_TPS_1_SAE,12.890625, %
ENG99630,Fan control relay: fan run-on,2,
ENG101437,Fan request from air conditioner,28.1, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,98.82353103, %
ENG104248,Fuel consumption signal,42315, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.24, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.24, g/s
ENG100250,Fuel regulating valve: duty cycle,27.516, %
ENG101692,Fuel supply system: high-pressure regulator,-53.4136, hPa
ENG114828,FUP_EFP_MES,6665.24, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,115304.4, hPa
ENG112563,FUP_H_SAE,11410.0, kPa
ENG103368,Gearbox -CAN bus messages,126839,
ENG99170,Height correction,988.63, hPa
ENG103575,High-pressure system: regulator,-3.24, mg
ENG103879,High-pressure system: regulator: mobile part,2.48, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,8.0, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],-4.500, °
ENG101655,IGA_IGC[1],-3.375, °
ENG100410,IGA_IGC[2],-1.875, °
ENG100407,IGA_IGC[3],-1.875, °
ENG112564,IGA_IGC_SAE,-1.0, °
ENG101741,Intake air temperature,27.00, °C
ENG100634-ENG119860,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Completion Condition Counts,19712, counts
ENG100634-ENG119872,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Conditions Encountered Counts,0, counts
ENG100634-ENG102823,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Ignition Cycle Counter,256, counts
ENG100634-ENG99988,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-OBD Monitoring Conditions Encountered Counts,7168, counts
ENG100634-ENG119377,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Raw Data,4D 00 00 00 01 00 00 00 00 00 01 00 01 00 00 00 00 00 07 00 01 00 09 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00,
ENG125209,KNKS_ERR_REL[0],0.0195, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],0.00159,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],-0.00024,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],0.00159,
ENG99674,Lambda controller: bank 1 (averaged value),-0.237, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000001 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG100478,Lambda probe correction: duty cycle offset: bank 1,-0.00549,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,401, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.953, V
ENG102763,Lambda probes actual: bank1,0.9893,
ENG104114,Lambda probes specified: bank1,0.9922,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],8191,
ENG112577,LF_IV_ERR_VLD_BSW[1],8191,
ENG112578,LF_IV_ERR_VLD_BSW[2],8191,
ENG112579,LF_IV_ERR_VLD_BSW[3],8191,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2011,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,3,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,15,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,1,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,8,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,34,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2011,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,1,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,26,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,20,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,48,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,43,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG122701,LMVDes_st_Mod_Out_VW,104,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,200.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,2195.75, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG07619,LV_ECRAS_FB_DIAG_POS_RESP[1],00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000001 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG36574,LV_ST_PROT_ACT_ERR,00000000 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG102523,MAF,156.90, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,36, kPa
ENG103501,MASS_SA_REL[0],0.969,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],0.00, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],0.00, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,800, /min
ENG103004,N_TCHA,14807.1, /min
ENG112590,N_TOOTH,796, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,204,
ENG126111,NL_PRE[0],0.15266, V
ENG126112,NL_PRE[1],0.37102, V
ENG126113,NL_PRE[2],0.24704, V
ENG126114,NL_PRE[3],0.20859, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG02464,PRS_UP_THR_MES,986.47, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],-3.5000, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],0.8125, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],-3.5000, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],-3.6250, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],0.8125, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],0.4375, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,-15.408, %
ENG112595,PWM_HLD_VCP[EX_1],34.918, %
ENG112596,PWM_HLD_VCP[IN_1],34.326, %
ENG112597,PWM_PAS_VCP[EX_1],9.216, %
ENG112598,PWM_PAS_VCP[IN_1],9.216, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,37,
ENG121344-ENG121493,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Off Coasting Timer (Lifetime),4294967295, s
ENG121344-ENG121494,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Off Coasting Timer (Recent),4294967295, s
ENG121344-ENG121497,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Running Coasting Timer (Lifetime),4294967295, s
ENG121344-ENG121498,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Running Coasting Timer (Recent),452984831, s
ENG121344-ENG121502,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Idle Stop-Start Timer (Lifetime),436207616, s
ENG121344-ENG121503,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Idle Stop-Start Timer (Recent),16777216, s
ENG112599,RVC_AV,140.14, °
ENG112601,RVC_SP,139.75, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER[0],0.0000,
ENG101135,SEG_AD_MMV_ER[1],-0.6258,
ENG99078,SEG_AD_MMV_ER[2],-0.0498,
ENG103257,SEG_AD_MMV_ER[3],-0.4554,
ENG102511,SEG_AD_MMV_ER_H[0],0.0000,
ENG103258,SEG_AD_MMV_ER_H[1],-0.6029,
ENG99291,SEG_AD_MMV_ER_H[2],-0.0429,
ENG99954,SEG_AD_MMV_ER_H[3],-0.4275,
ENG100568,SEG_AD_MMV_ER_L[0],0.0000,
ENG100601,SEG_AD_MMV_ER_L[1],-0.6258,
ENG102668,SEG_AD_MMV_ER_L[2],-0.0498,
ENG101232,SEG_AD_MMV_ER_L[3],-0.4554,
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000,
ENG102964,SEG_AD_MMV_ER_MID[1],-0.6029,
ENG100890,SEG_AD_MMV_ER_MID[2],-0.0429,
ENG99793,SEG_AD_MMV_ER_MID[3],-0.4275,
ENG103381,Shut-off time,0.50, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,0, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,21495872,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],CL,
ENG104238,STATE_NVLD,INI,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],ACT,
ENG101078,STATE_READY_OBD_1,39,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCGAB010 CB60050,
ENG128798,STATE_T_ES_RD,0,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,149, s
ENG104148,T_COOL_LOIL,529.4, ms
ENG112613,T_DTC_CLR_SAE,65, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,0, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,2880, min
ENG99463,T_ES_H,0, s
ENG128802,T_IGK,183.21, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG128803,T_PWL_CAN,73.6, s
ENG112636,T_SWI_VVL_ACR,67.8, ms
ENG101325,T_TEMP_SIG_LOIL,41.5, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,23.500, °C
ENG102048,Tank breather valve: duty cycle,7.421875, %
ENG101339,Tank breather valve: short trip result,0.3876, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,19, °C
ENG112611,TCO_1_ST,19, °C
ENG112612,TCO_1_SYS,63, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP[1],9.75, °C
ENG101581,TCO_C_LAM_AD_WUP[1],24.75, °C
ENG100354,TCO_D_LAM_AD_WUP[1],35.25, °C
ENG101973,TCO_E_LAM_AD_WUP[1],45.00, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],23.008, °C
ENG124460,TCO_MDL[TH],29.195, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],63.00, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],50.25, °C
ENG102279,TCS/ESP: specified torque,44.94, Nm
ENG99857,TCS: status,00000000 ,
ENG36581,TEG_DYN_LS_DOWN[0],434.9750, °C
ENG101250,TEG_DYN_LS_UP[0],370.7250, °C
ENG36582,TEG_DYN_UP_CAT[0],286.7875, °C
ENG36583,TEMP_CAT_DYN_MDL[0],414.2875, °C
ENG36584,TEMP_CAT_STAT_MDL[0],352.6000, °C
ENG112614,TEMP_CAT_UP_1_SAE,323.3, °C
ENG114837,TFPA,33, °C
ENG114838,TFU_HPP,23.25, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,2.918, °
ENG102845,Throttle valve deviation,-4.126, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],0.656, ms
ENG126120,TI_MES_4[PLS_1][1],0.600, ms
ENG126121,TI_MES_4[PLS_1][2],0.600, ms
ENG126122,TI_MES_4[PLS_1][3],0.572, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,34.529, °C
ENG125276,TIG_MES_SAE[IM],28, °C
ENG103351,Time since engine start,154.9, s
ENG112634,TLTS_MES[TCE],63.844, °C
ENG112635,TMAG_VCP,23, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,2.867, °
ENG99274,TPS_SP,2.874, °
ENG103021,TQ_CONV,2.00, Nm
ENG128804,TQI_ADD_ACT,48.50000, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP[1],720.0000, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7471, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.5, V
ENG103201,VCV_CLOSE_RNG,33.8, °
ENG115976,Vehicle Odometer,38.7, km
ENG121352-ENG121535,Vehicle Operation Data - Distance/Fuel Used-Total Distance Traveled (Lifetime),424463571.2, km
ENG121352-ENG121536,Vehicle Operation Data - Distance/Fuel Used-Total Distance Traveled (Recent),1677721.6, km
ENG121352-ENG121545,Vehicle Operation Data - Distance/Fuel Used-Total Fuel Consumed (Lifetime),28185722.27, l
ENG121352-ENG121546,Vehicle Operation Data - Distance/Fuel Used-Total Fuel Consumed (Recent),5368709.01, l
ENG121353-ENG121499,Vehicle Operation Data - Engine Run/Idle Time-Fueled Engine Operation Ignition Cycle Counter (Lifetime),285212672, counts
ENG121353-ENG121500,Vehicle Operation Data - Engine Run/Idle Time-Fueled Engine Operation Ignition Cycle Counter (Recent),1140850688, counts
ENG121353-ENG121504,Vehicle Operation Data - Engine Run/Idle Time-Ignition Counter (Lifetime),285212672, counts
ENG121353-ENG121505,Vehicle Operation Data - Engine Run/Idle Time-Ignition Counter (Recent),16777216, counts
ENG121353-ENG121543,Vehicle Operation Data - Engine Run/Idle Time-Total Engine Run Time (Lifetime),1140850709, s
ENG121353-ENG121544,Vehicle Operation Data - Engine Run/Idle Time-Total Engine Run Time (Recent),570425359, s
ENG121353-ENG121557,Vehicle Operation Data - Engine Run/Idle Time-Total Idle Engine Run Time (Lifetime),1677721611, s
ENG121353-ENG121558,Vehicle Operation Data - Engine Run/Idle Time-Total Idle Engine Run Time (Recent),3607101446, s
ENG121354-ENG121495,Vehicle Operation Data - PKE/EOE-Engine Output Energy (Lifetime),152672667.9, kWh
ENG121354-ENG121496,Vehicle Operation Data - PKE/EOE-Engine Output Energy (Recent),129184565.1, kWh
ENG121354-ENG121525,Vehicle Operation Data - PKE/EOE-Positive Kinetic Energy (Lifetime),2298478637, km/h²
ENG121354-ENG121526,Vehicle Operation Data - PKE/EOE-Positive Kinetic Energy (Recent),16777257, km/h²
ENG121355-ENG121533,Vehicle Operation Data - PSA-Total City Propulsion System Active Time (Lifetime),2986344454, s
ENG121355-ENG121534,Vehicle Operation Data - PSA-Total City Propulsion System Active Time (Recent),2063597573, s
ENG121355-ENG121559,Vehicle Operation Data - PSA-Total Idle Propulsion System Active Time (Lifetime),2164260875, s
ENG121355-ENG121560,Vehicle Operation Data - PSA-Total Idle Propulsion System Active Time (Recent),4110417926, s
ENG121355-ENG121561,Vehicle Operation Data - PSA-Total Propulsion System Active Time (Lifetime),1627389973, s
ENG121355-ENG121562,Vehicle Operation Data - PSA-Total Propulsion System Active Time (Recent),16777231, s
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,6,
ENG112639,VLS_DOWN_SAE[1],0.765, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002686, m³/s
ENG101929,VP_TPS_1,0.6348, V
ENG102985,VP_TPS_2,4.3555, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5029, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4922, V
ENG101674,VP_TPS_AD_LIH_1,0.8154, V
ENG99507,VP_TPS_AD_LIH_2,4.1748, V
Elapsed Time: 01:14
blockmap-01-5G0-906-259-Q_3VW6T7AU8LM010575-20200618-1055.CSV
;Component:R4 2.0l TFSI  H13 0005, Coding:092500124424012F1000
;EV_ECM20TFS0205G0906259Q,001006,EV_ECM20TFS0205G0906259Q.rod
;Thursday,18,June,2020,10:55:02:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: BC2ADFBAE6E8BEBBCF3-80E8
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VW6T7AU8LM01057,
IDE00018,Voltage terminal 15,14.219, V
IDE00019,Voltage terminal 30,14.453, V
IDE00021,Engine speed,796, /min
IDE00025,Coolant temperature,98, °C
IDE00078,Time since engine start,530, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,25, %
IDE00085,Normed load value,16.9, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,46.0, °C
IDE00148,Median injection timing,0.6, ms
IDE00149,Ignition angle of current cylinder: actual value,-2.25, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,72, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,332.0, °C
IDE00172,A/C compressor torque,-12.41, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,9.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,8.5, °
IDE00178,Camshaft adjustment intake bank 1: specified value,10.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,8.6, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-3.0, °
IDE00186,Fuel low pressure: actual value,6.666, bar
IDE00187,Coolant temperature at engine start,18.7, °C
IDE00188,Fuel high pressure: actual value,111.7, bar
IDE00189,Activation of fuel pump electronics,50.37, %
IDE00190,Charge air pressure specified value,0.989, bar
IDE00191,Charge air pressure: actual value,0.986, bar
IDE00192,Coolant temperature at radiator outlet: actual value,26.8, °C
IDE00193,Coolant temperature at engine outlet: specified value,98.2, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,71.2, °C
IDE00196,Engine oil temperature,50.0, °C
IDE00199,Mean engine air mass,14, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,110.8, bar
IDE00202,Low fuel pressure: specified value,5.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,48, l
IDE00348,Intake air temperature,37, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,14, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,54.7, °C
IDE00358,Limitation: torque,255.4, Nm
IDE00371,Fuel consumption,1.05, l/h
IDE00375,Generator: load signal,51.63, %
IDE00380,Coolant fan 1: activation,32.03, %
IDE00381,Coolant fan 2: activation,31.64, %
IDE00392,Accelerator pedal: sensor voltage 1,0.747, V
IDE00393,Accelerator pedal: sensor voltage 2,0.376, V
IDE00396,Charge Pressure Actuator: acknowledgment,3.525, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,11.47, %
IDE00405,Crankshaft speed (RPM),802, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00432,Particle filter: time since last regeneration,183, min
IDE00434,Particle filter: soot mass calculated,0.00, g
IDE00436,Particle filter: kilometers since last regeneration,38.7,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,9, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,30.45, %
IDE00477,Torque request: sum of auxiliary aggregate,28.3, Nm
IDE00478,Engine-drag torque,17.1, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,51.0, °C
IDE00496,Activation of oil pressure switch valve,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,24, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.988 Lambda / -0.027 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.105, V
IDE00582,Equivalence ratio target value,0.992, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,26, km
IDE00588,Fuel tank fill level,98.8, %
IDE00589,Fuel pressure,11070, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-3.5, Degrees
IDE00594,Absolute intake pressure,37, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,7.8, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,0, min
IDE01076-MAS00111,Time since ignition off-Seconds,0, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,2.9, °
IDE01378,High fuel pressure: control deviation,0.4, bar
IDE01385,Wear index,0.00000056,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,6.69, l
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.114, V
IDE01649,Throttle valve position 1,0.640, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,40.25, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,1.5, Nm
IDE01905,Average of ignition timing angle delay adjustment,13.12, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,-3.37, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,38, km
IDE01923,Control module distance driven,39, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,44.3, °
IDE01929,Open cam shaft angle at quantity control valve,5.7, °
IDE01931,High pressure pump injection volume control deviation,2, mg/stroke
IDE01932,High pressure pump injection volume,8, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,0,
IDE01977,Numb.of misfir.: cylinder 3,1,
IDE01978,Numb.of misfir.: cylinder 4,1,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,391.1, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.8, %
IDE02229,Exh.gas temp.sen 1,1110.0, °C
IDE02756,Number of manual engine starts,66,
IDE02757,Number of automatic engine starts,2,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,2,
IDE03010-MAS01627,Number of prevented stop processes-Steering,2,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,1,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,3,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,6,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,11,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,6,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.492, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.815, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.175, V
IDE03267,Intake air temperature: unconditioned voltage,1.675, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.597, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.760, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,42.0, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,1,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.251, V
IDE03582,Temperature sensor for engine temperature management,-48.0, °C
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat not complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control not complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,10, kg/h
IDE03767,Engine status,Idling,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,36.89, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,398, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,39.45, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,26.56, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,2.041, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,0.42, %
IDE03922,Mixture adaptation factor at idle speed,-1.49, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,-0.00030,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,0.03, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.525, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.526, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.48, %
IDE03957,Throttle valve angle: specified value,2.9, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,99.61, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04010,Engine torque: normalized,12, %
IDE04011,Nominal torque,350, Nm
IDE04110,Additional inputs and outputs,,
IDE04405,Mixture deviation in adapted partial load range 1,0.48, %
IDE04409,Intake manifold pressure: corrected,0.378, bar
IDE04410,Intake manifold pressure: target value,0.381, bar
IDE04412,Pressure before throttle valve: corrected,0.986, bar
IDE04415,Oxygen ctrl factor with precontrol correction,1.09, %
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04629,AVS operating condition,Test is running,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,100,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,0,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.982, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.379, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.03, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.5254, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5254, V
IDE05316,Charge air pressure control valve voltage: position open,0.5255, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.984, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,30,
IDE06006,Idle speed specified value,800, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06192,Knock sensor: cylinder 2: voltage,0.303, V
IDE06193,Knock sensor: cylinder 3: voltage,0.399, V
IDE06194,Knock sensor: cylinder 4: voltage,0.367, V
IDE06195,Knock sensor: cylinder 1: voltage,0.310, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000000 ,
IDE06307-MAS00106,Stop prevention history data-Year,2011,
IDE06307-MAS00107,Stop prevention history data-Month,4,
IDE06307-MAS00108,Stop prevention history data-Day,24,
IDE06307-MAS00109,Stop prevention history data-Hours,1,
IDE06307-MAS00110,Stop prevention history data-Minutes,6,
IDE06307-MAS00111,Stop prevention history data-Seconds,24,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06307,Stop prevention history data,Engine temperature,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,129, mm
IDE06387,Oil level: last valid dynamic value,129, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,-127, mm
IDE06390,Oil level: minimum value,385, mm
IDE06391,Oil temperature sensor 2,47.0, °C
IDE06392,Oil temperature sensor 2: raw value,47.000, V
IDE06393,Oil level: dynamic average value,144, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.437, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.804, V
IDE06397,Temperature sensor for engine temp. management: target value,107.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.803, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.811, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.948, V
IDE06567,Start-stop function deactivation frequency counter,0,
IDE06568,Stop prevention by driver frequency counter,40,
IDE06569,Vehicle stopped frequency counter,82,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,3,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-4.25, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,0,
IDE07011,Tank leak: number communication errors to engine control,0,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,379269,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,7e+006, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,126.25, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,126.72, °
IDE07550,Engine temp. management actuator: raw value,2032,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Start,
IDE07553,Engine temperature management actuator: after-run stop,3948,
IDE07554,Engine temperature management actuator: stop open,145,
IDE07564,Required torque adjustment by idling regulator,-4.3, Nm
IDE07571,Engine torque,27.0, Nm
IDE07572,High pressure regulation: adaptation value,2.61, mg
IDE07574,Long-term fuel trim bank 1 at idle,-0.17, mg/stroke
IDE07575,Driver request torque,-2.3, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,-3.7, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,not activated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,not activated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,No,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,not completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,not completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,not completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.215, counts
IDE08806,EVAP valve diag. activation condition at maximum load,605, mbar
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.597, V
IDE10380,Knock sensor average voltage bank 1,0.254, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,48.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12210,Particle filter: water mass,0.0, g
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,6.40, g
IDE13086,Particle filter: maximum soot build-up reached,8.00, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,3.000, counts
IDE13090,Particle filter: maximum soot loading ratio reached,4.000, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.000, counts
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.40460,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG121286-ENG121430,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Engine Warm-up Timer (Lifetime),318767117, s
ENG121286-ENG121431,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Engine Warm-up Timer (Recent),16777228, s
ENG121286-ENG121463,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Transmission Warm-up Timer (Lifetime),4294967295, s
ENG121286-ENG121464,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data-Active Transmission Warm-up Timer (Recent),1761607679, s
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,11.25, kg/h
ENG104264,Alternator load,1350, W
ENG103910,Ambient temperature,22.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0045, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.4, V
ENG07601,Bypasstool_a2l_name,ORIGINAL A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,5G0259Q 0005BXA,
ENG99697,Calibration Verification Number,01 26 20 F7,
ENG128780,CAM_DIF_VCP[EX_1],0.563, °
ENG128781,CAM_DIF_VCP[IN_1],-0.398, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],8.836, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],10.164, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],9.000, °
ENG112543,CAM_SP_IND_VCP[IN_1],10.000, °
ENG112544,CAM_VCP[EX_1],9.078, °
ENG112545,CAM_VCP[IN_1],10.344, °
ENG103849,Cat. ageing: bank 1: actual,0.000,
ENG102214,CPU_LOAD,52.8, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG101127,CTR_CDN_OBD_RBM,1,
ENG114826,CTR_EDGE_CAM_EX[1],79,
ENG114827,CTR_EDGE_CAM_IN[1],83,
ENG100536,CTR_IGK_CYC_RBM,77,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],0,
ENG125195,CTR_LAMB_SP_PI_REQ[2],0,
ENG125196,CTR_LAMB_SP_PI_REQ[3],0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],1,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],1,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],1,
ENG112558,CTR_MIS_TOT_NVMY_SAE,60,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,143.9,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,100,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,56,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST[0],NO_ERROR,
ENG99120,DIAG_INST[1],NO_ERROR,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,26, km
ENG103766,DIST_ENG_RUN_IN,0.3, m
ENG100531,DIST_ST,38700, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,-EngineControl,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG115973,Engine Exhaust Flow Rate,15.0, kg/h
ENG20102,Engine Friction - Percent Torque,5.0, %
ENG104044,Engine load,17.187500, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,64.06, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],0.478, %
ENG100298,FAC_LAM_CP,0.241, %
ENG100108,FAC_LAM_LIM[1],0.247, %
ENG99722,FAC_LAM_TCO_A[1],0.000, %
ENG103521,FAC_LAM_TCO_B[1],0.000, %
ENG103641,FAC_LAM_TCO_C[1],0.000, %
ENG101578,FAC_LAM_TCO_D[1],0.000, %
ENG100685,FAC_LAM_TCO_E[1],0.000, %
ENG103307,FAC_MAF_MAX,0.21243,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,12.500000, %
ENG102292,FAC_TPS_1_SAE,12.890625, %
ENG99630,Fan control relay: fan run-on,2,
ENG101437,Fan request from air conditioner,28.5, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,98.82353103, %
ENG104248,Fuel consumption signal,47215, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.22, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.22, g/s
ENG100250,Fuel regulating valve: duty cycle,30.605, %
ENG101692,Fuel supply system: high-pressure regulator,275.601, hPa
ENG114828,FUP_EFP_MES,6665.24, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,109711.2, hPa
ENG112563,FUP_H_SAE,10890.0, kPa
ENG103368,Gearbox -CAN bus messages,126839,
ENG99170,Height correction,988.63, hPa
ENG103575,High-pressure system: regulator,1.19, mg
ENG103879,High-pressure system: regulator: mobile part,-1.72, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,8.3, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],-4.125, °
ENG101655,IGA_IGC[1],-4.125, °
ENG100410,IGA_IGC[2],-3.750, °
ENG100407,IGA_IGC[3],-3.000, °
ENG112564,IGA_IGC_SAE,-2.5, °
ENG101741,Intake air temperature,37.50, °C
ENG100634-ENG119860,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Completion Condition Counts,19712, counts
ENG100634-ENG119872,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Conditions Encountered Counts,0, counts
ENG100634-ENG102823,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Ignition Cycle Counter,256, counts
ENG100634-ENG99988,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-OBD Monitoring Conditions Encountered Counts,7168, counts
ENG100634-ENG119377,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Raw Data,4D 00 00 00 01 00 00 00 00 00 01 00 01 00 00 00 00 00 07 00 01 00 09 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00,
ENG125209,KNKS_ERR_REL[0],0.0586, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],0.00159,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],-0.00031,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],0.00159,
ENG99674,Lambda controller: bank 1 (averaged value),0.389, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000000 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG100478,Lambda probe correction: duty cycle offset: bank 1,-0.00031,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,398, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),2.002, V
ENG102763,Lambda probes actual: bank1,0.9941,
ENG104114,Lambda probes specified: bank1,0.9922,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],8191,
ENG112577,LF_IV_ERR_VLD_BSW[1],8191,
ENG112578,LF_IV_ERR_VLD_BSW[2],8191,
ENG112579,LF_IV_ERR_VLD_BSW[3],8191,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2011,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,3,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,15,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,1,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,8,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,34,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2011,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,1,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,26,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,20,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,48,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,43,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG122701,LMVDes_st_Mod_Out_VW,104,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,200.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,2195.75, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG07619,LV_ECRAS_FB_DIAG_POS_RESP[1],00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG36574,LV_ST_PROT_ACT_ERR,00000000 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG102523,MAF,148.91, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,38, kPa
ENG103501,MASS_SA_REL[0],0.969,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],0.00, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],0.00, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,800, /min
ENG103004,N_TCHA,14959.7, /min
ENG112590,N_TOOTH,795, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,204,
ENG126111,NL_PRE[0],0.15625, V
ENG126112,NL_PRE[1],0.31845, V
ENG126113,NL_PRE[2],0.32433, V
ENG126114,NL_PRE[3],0.23621, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG02464,PRS_UP_THR_MES,986.47, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],-3.5000, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],0.8125, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],-3.5000, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],-3.6250, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],0.8125, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],0.4375, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,-12.808, %
ENG112595,PWM_HLD_VCP[EX_1],37.042, %
ENG112596,PWM_HLD_VCP[IN_1],40.271, %
ENG112597,PWM_PAS_VCP[EX_1],9.375, %
ENG112598,PWM_PAS_VCP[IN_1],9.216, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,37,
ENG121344-ENG121493,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Off Coasting Timer (Lifetime),4294967295, s
ENG121344-ENG121494,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Off Coasting Timer (Recent),4294967295, s
ENG121344-ENG121497,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Running Coasting Timer (Lifetime),4294967295, s
ENG121344-ENG121498,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Engine Running Coasting Timer (Recent),452984831, s
ENG121344-ENG121502,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Idle Stop-Start Timer (Lifetime),436207616, s
ENG121344-ENG121503,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data-Idle Stop-Start Timer (Recent),16777216, s
ENG112599,RVC_AV,123.56, °
ENG112601,RVC_SP,124.00, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER[0],0.0000,
ENG101135,SEG_AD_MMV_ER[1],-0.6258,
ENG99078,SEG_AD_MMV_ER[2],-0.0498,
ENG103257,SEG_AD_MMV_ER[3],-0.4554,
ENG102511,SEG_AD_MMV_ER_H[0],0.0000,
ENG103258,SEG_AD_MMV_ER_H[1],-0.6029,
ENG99291,SEG_AD_MMV_ER_H[2],-0.0429,
ENG99954,SEG_AD_MMV_ER_H[3],-0.4275,
ENG100568,SEG_AD_MMV_ER_L[0],0.0000,
ENG100601,SEG_AD_MMV_ER_L[1],-0.6258,
ENG102668,SEG_AD_MMV_ER_L[2],-0.0498,
ENG101232,SEG_AD_MMV_ER_L[3],-0.4554,
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000,
ENG102964,SEG_AD_MMV_ER_MID[1],-0.6029,
ENG100890,SEG_AD_MMV_ER_MID[2],-0.0429,
ENG99793,SEG_AD_MMV_ER_MID[3],-0.4275,
ENG103381,Shut-off time,0.50, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,0, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,17301568,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],CL,
ENG104238,STATE_NVLD,INI,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG101078,STATE_READY_OBD_1,39,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCGAB010 CB60050,
ENG128798,STATE_T_ES_RD,0,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,596, s
ENG104148,T_COOL_LOIL,484.2, ms
ENG112613,T_DTC_CLR_SAE,73, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,0, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,2880, min
ENG99463,T_ES_H,0, s
ENG128802,T_IGK,630.75, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG128803,T_PWL_CAN,73.6, s
ENG112636,T_SWI_VVL_ACR,67.8, ms
ENG101325,T_TEMP_SIG_LOIL,49.8, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,23.000, °C
ENG102048,Tank breather valve: duty cycle,7.812500, %
ENG101339,Tank breather valve: short trip result,0.3948, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,19, °C
ENG112611,TCO_1_ST,19, °C
ENG112612,TCO_1_SYS,101, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP[1],9.75, °C
ENG101581,TCO_C_LAM_AD_WUP[1],24.75, °C
ENG100354,TCO_D_LAM_AD_WUP[1],35.25, °C
ENG101973,TCO_E_LAM_AD_WUP[1],45.00, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],29.602, °C
ENG124460,TCO_MDL[TH],44.445, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],100.50, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],50.25, °C
ENG102279,TCS/ESP: specified torque,45.47, Nm
ENG99857,TCS: status,00000000 ,
ENG36581,TEG_DYN_LS_DOWN[0],323.4125, °C
ENG101250,TEG_DYN_LS_UP[0],391.8500, °C
ENG36582,TEG_DYN_UP_CAT[0],309.9750, °C
ENG36583,TEMP_CAT_DYN_MDL[0],346.0375, °C
ENG36584,TEMP_CAT_STAT_MDL[0],360.4125, °C
ENG112614,TEMP_CAT_UP_1_SAE,334.1, °C
ENG114837,TFPA,69, °C
ENG114838,TFU_HPP,60.75, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,2.918, °
ENG102845,Throttle valve deviation,-6.281, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],0.652, ms
ENG126120,TI_MES_4[PLS_1][1],0.628, ms
ENG126121,TI_MES_4[PLS_1][2],0.640, ms
ENG126122,TI_MES_4[PLS_1][3],0.612, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,40.623, °C
ENG125276,TIG_MES_SAE[IM],38, °C
ENG103351,Time since engine start,602.5, s
ENG112634,TLTS_MES[TCE],101.641, °C
ENG112635,TMAG_VCP,57, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,2.918, °
ENG99274,TPS_SP,2.874, °
ENG103021,TQ_CONV,2.00, Nm
ENG128804,TQI_ADD_ACT,47.00000, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP[1],720.0000, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7471, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.5, V
ENG103201,VCV_CLOSE_RNG,35.3, °
ENG115976,Vehicle Odometer,38.7, km
ENG121352-ENG121535,Vehicle Operation Data - Distance/Fuel Used-Total Distance Traveled (Lifetime),424463571.2, km
ENG121352-ENG121536,Vehicle Operation Data - Distance/Fuel Used-Total Distance Traveled (Recent),1677721.6, km
ENG121352-ENG121545,Vehicle Operation Data - Distance/Fuel Used-Total Fuel Consumed (Lifetime),30366760.30, l
ENG121352-ENG121546,Vehicle Operation Data - Distance/Fuel Used-Total Fuel Consumed (Recent),5368709.01, l
ENG121353-ENG121499,Vehicle Operation Data - Engine Run/Idle Time-Fueled Engine Operation Ignition Cycle Counter (Lifetime),285212672, counts
ENG121353-ENG121500,Vehicle Operation Data - Engine Run/Idle Time-Fueled Engine Operation Ignition Cycle Counter (Recent),1140850688, counts
ENG121353-ENG121504,Vehicle Operation Data - Engine Run/Idle Time-Ignition Counter (Lifetime),285212672, counts
ENG121353-ENG121505,Vehicle Operation Data - Engine Run/Idle Time-Ignition Counter (Recent),16777216, counts
ENG121353-ENG121543,Vehicle Operation Data - Engine Run/Idle Time-Total Engine Run Time (Lifetime),67108887, s
ENG121353-ENG121544,Vehicle Operation Data - Engine Run/Idle Time-Total Engine Run Time (Recent),570425361, s
ENG121353-ENG121557,Vehicle Operation Data - Engine Run/Idle Time-Total Idle Engine Run Time (Lifetime),603979789, s
ENG121353-ENG121558,Vehicle Operation Data - Engine Run/Idle Time-Total Idle Engine Run Time (Recent),2533359624, s
ENG121354-ENG121495,Vehicle Operation Data - PKE/EOE-Engine Output Energy (Lifetime),157705832.8, kWh
ENG121354-ENG121496,Vehicle Operation Data - PKE/EOE-Engine Output Energy (Recent),129184565.1, kWh
ENG121354-ENG121525,Vehicle Operation Data - PKE/EOE-Positive Kinetic Energy (Lifetime),2298478637, km/h²
ENG121354-ENG121526,Vehicle Operation Data - PKE/EOE-Positive Kinetic Energy (Recent),16777257, km/h²
ENG121355-ENG121533,Vehicle Operation Data - PSA-Total City Propulsion System Active Time (Lifetime),2986344454, s
ENG121355-ENG121534,Vehicle Operation Data - PSA-Total City Propulsion System Active Time (Recent),989855749, s
ENG121355-ENG121559,Vehicle Operation Data - PSA-Total Idle Propulsion System Active Time (Lifetime),1090519053, s
ENG121355-ENG121560,Vehicle Operation Data - PSA-Total Idle Propulsion System Active Time (Recent),3036676104, s
ENG121355-ENG121561,Vehicle Operation Data - PSA-Total Propulsion System Active Time (Lifetime),553648151, s
ENG121355-ENG121562,Vehicle Operation Data - PSA-Total Propulsion System Active Time (Recent),16777233, s
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,6,
ENG112639,VLS_DOWN_SAE[1],0.110, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002655, m³/s
ENG101929,VP_TPS_1,0.6396, V
ENG102985,VP_TPS_2,4.3506, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5029, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4922, V
ENG101674,VP_TPS_AD_LIH_1,0.8154, V
ENG99507,VP_TPS_AD_LIH_2,4.1748, V
Elapsed Time: 01:14
blockmap-02-0GC-300-020-G_3VW6T7AU8LM010575-20200618-1048.CSV
;Component:GSG DQ381     H06 2404, Coding:0014
;EV_TCMDQ381061,001,EV_TCMDQ381061.rod
;Thursday,18,June,2020,10:48:52:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: A61E1DD20864146B897-80F2
Group,Description,Actual
IDE00018,Voltage terminal 15,14.4, V
IDE00019,Voltage terminal 30,14.4, V
IDE00021-ENG99543,Engine speed-Engine RPM,814, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,814, /min
IDE00023,Transmission output speed,0, /min
IDE00024,Transmission fluid temperature,22, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1067.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,22, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,964.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,30.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02221,Engine torque: qualification,valid,
IDE02713,Brake Light Switch,not activated,
IDE02714,Brake test switch,not activated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,Voltage supply E-pump-Voltage Supply Electric Motor,14.5, V
IDE02727-ENG99192,Selector lever lock SPECIFIED condition-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,21, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,21, °C
IDE02742,Oil pressure actual value,1.21, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,2.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,1.21, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,2.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,1.21, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,372.1, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,372.0, mA
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,382.8, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,382.0, mA
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.00, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,50.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,51.0, mA
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.00, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,50.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,48.0, mA
IDE02820,Transmission mileage,40.0, km
IDE02821-ENG101653,Pressure supply specified pressure/threshold1-Pressure Supply Commanded Value Threshold 1,1.21, bar
IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,5Q1713025AT  VL4,
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Steering wheel paddle installation info-Application Info Steering Paddels,56,
IDE02828-ENG103640,Brake installation info-Application Info Breaksystem,56,
IDE02829-ENG103127,Steering wheel module installation info-Application Info Steering Modul,56,
IDE02830-ENG100103,Gateway installation info-Application Info Gateway,56,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02861-ENG103083,Mechatronic identification-Baudatum,200103,
IDE02861-ENG98675,Mechatronic identification-Construction version,N2,
IDE02861-ENG99175,Mechatronic identification-Kassel,K,
IDE02861-ENG104192,Mechatronic identification-Kennung der Mechatronik-Montagelinie,D15,
IDE02861-ENG103830,Mechatronic identification-Lfd.-Nr,5026,
IDE02861-ENG103525,Mechatronic identification-Teilenummer (3 letzten + Index),0GCE_,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,200105,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,TSX,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,D08,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,6316,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-9.91, mm
IDE02865-ENG104121,AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1,3006,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,0.0, mA
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,0.00, mm
IDE02873-ENG101728,AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1,2049,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,0.0, mA
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,0.00, mm
IDE02881-ENG99453,AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1,2053,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,0.0, mA
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-9.48, mm
IDE02889-ENG100525,AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1,1159,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,784.5, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,790.0, mA
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,655350, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,0,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Test stand data valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,655350, km
IDE03160-ENG100046,Remaining clutch fast adaptations: kiss point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,47.9, km
IDE03172-ENG100789,Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological,83, %
IDE03173-ENG103567,Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty,2, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,15, %
IDE03180-ENG103176,Number of standard trips-General Denominator,1,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,17,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG28506,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG28505,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG28507,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG28638,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG28504,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,0.00, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.01, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,0.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,0, km
IDE06425,Roller test bench mode: functional,not activated,
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,0,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,0,
IDE12712-ENG36173,Kilometerstand letzte Initialisierung Kupplungs-Reibwertmodell-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG36135,Kilometerstand Kupplungs-Reibwertmodell-Gearbox mileage,40.0, km
IDE13738-ENG36678,Function test auxiliary hydraulic pump for transmission oil status-Abbruchgrund,Do not cancel,
IDE13738-ENG36798,Function test auxiliary hydraulic pump for transmission oil status-Hauptdruck,0.00, bar
IDE13738-ENG101241,Function test auxiliary hydraulic pump for transmission oil status-Speed,0, /min
IDE13947-ENG36805,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,655340, km
IDE14615-MAS18568,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 1,-10.54, mm
IDE14615-MAS18569,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 2,-10.64, mm
IDE14615-MAS18570,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 3,10.86, mm
IDE14615-MAS18571,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 4,9.63, mm
IDE14615-MAS18572,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 5,8.97, mm
IDE14615-MAS18573,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 6,8.84, mm
IDE14615-MAS18574,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 7,-8.92, mm
IDE14615-MAS18575,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear R,-9.95, mm
IDE14616-MAS18576,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 1,-2.50, mm
IDE14616-MAS18577,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 2,-2.40, mm
IDE14616-MAS18578,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 3,2.30, mm
IDE14616-MAS18579,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 4,1.83, mm
IDE14616-MAS18580,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 5,1.29, mm
IDE14616-MAS18581,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 6,1.67, mm
IDE14616-MAS18582,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 7,-1.46, mm
IDE14616-MAS18583,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear R,-1.91, mm
IDE14617-MAS18584,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator A,-0.30, mm
IDE14617-MAS18585,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator B,-0.13, mm
IDE14617-MAS18586,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator C,0.08, mm
IDE14617-MAS18587,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator D,-0.13, mm
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,65535,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,0.0, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,19964.2, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,0.0, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,0.0, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,58, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,19395.1, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,561.9, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,5.5, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,2.2, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,164, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,19882.8, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,81.2, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,1.1, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,0.0, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,133, °C
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),1.7, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),0.1, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.0, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,119,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,133,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,107,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,68,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,57,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,43,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,16,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,89,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,0,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,0,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,0,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,0,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,0,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),5.4, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),0.2, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.0, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),5.5, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),0.0, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),0.2, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),0.1, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),0.0, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),0.0, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),0.2, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),0.1, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),0.0, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),0.0, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80117-MAS02330,Analysis 117-SPECIFIED condition,OFF,
IDE80117-MAS02331,Analysis 117-ACTUAL condition,OFF,
IDE80118-ENG36197,Analysis 118-Snapshot 1 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80119-ENG36200,Analysis 119-Snapshot 1 auxiliary transmission fluid pump motor electronics temperature,-40, °C
IDE80120-ENG36199,Analysis 120-Snapshot 1 auxiliary transmission fluid pump motor current,0, mA
IDE80121-ENG30203,Analysis 121-GOP current limitation failure status,OFF,
IDE80121-ENG30204,Analysis 121-GOP rotor position sensor failure status,OFF,
IDE80122-ENG36203,Analysis 122-Snapshot 1 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80123-ENG36198,Analysis 123-Snapshot 1 auxiliary transmission fluid pump motor commanded speed demand estimation,0, /min
IDE80124-ENG36201,Analysis 124-Snapshot 1 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80125-MAS02330,Analysis 125-SPECIFIED condition,OFF,
IDE80125-MAS02331,Analysis 125-ACTUAL condition,OFF,
IDE80126-ENG36204,Analysis 126-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80127-ENG36206,Analysis 127-Snapshot 2 auxiliary transmission fluid pump motor electronics temperature,-40, °C
IDE80128-ENG36205,Analysis 128-Snapshot 2 auxiliary transmission fluid pump motor current,0, mA
IDE80129-ENG30203,Analysis 129-GOP current limitation failure status,OFF,
IDE80129-ENG30204,Analysis 129-GOP rotor position sensor failure status,OFF,
IDE80130-ENG36208,Analysis 130-Snapshot 2 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80131-ENG36204,Analysis 131-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80132-ENG36207,Analysis 132-Snapshot 2 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80133-ENG36202,Analysis 133-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80134-ENG36202,Analysis 134-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80137-ENG36819,Analysis 137-Mode A FID event memory entry 1,FF FF,
IDE80137-ENG36820,Analysis 137-Mode A FID event memory entry 2,FF FF,
IDE80137-ENG36821,Analysis 137-Mode A FID event memory entry 3,FF FF,
IDE80137-ENG36822,Analysis 137-Mode A FID event memory entry 4,FF FF,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,38, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,0,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,420.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,420.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,0,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,655350, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,0,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,655350, km
IDE80303-ENG127833,Overall software description-Software full name,K24,
IDE80305-ENG125922,Parameter set description-Data set name,FL_0GC300020G_2404_HlDO.par,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,24, °C
ENG26477,Anzahl Launch Control Anfahrt,0,
ENG26429-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG26429-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG26429-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG26429-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG26429-ENG30200,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 00 00 00,
ENG26429-ENG36152,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG26429-ENG36153,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG26429-ENG30201,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG26429-ENG30202,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG26429-ENG36154,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG26429-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,,
ENG26429-ENG28937,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG26429-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,51.0, V
ENG26429-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,51.0, V
ENG26429-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,215, °C
ENG26429-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Odometer reading,655350, km
ENG26429-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,0,
ENG26429-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG26429-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,0,
ENG26429-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,FF,
ENG26429-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,1,
ENG26430-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG26430-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG26430-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG26430-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG26430-ENG30200,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG26430-ENG36152,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG26430-ENG36153,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG26430-ENG30201,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG26430-ENG30202,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG26430-ENG36154,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG26430-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,,
ENG26430-ENG28937,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG26430-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG26430-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG26430-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG26430-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Odometer reading,655350, km
ENG26430-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG26430-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG26430-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG26430-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG26430-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG26431-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG26431-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG26431-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG26431-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG26431-ENG30200,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG26431-ENG36152,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG26431-ENG36153,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG26431-ENG30201,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG26431-ENG30202,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG26431-ENG36154,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG26431-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,,
ENG26431-ENG28937,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG26431-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG26431-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG26431-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG26431-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Odometer reading,655350, km
ENG26431-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG26431-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG26431-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG26431-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG26431-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG26432-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG26432-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG26432-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG26432-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG26432-ENG30200,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG26432-ENG36152,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG26432-ENG36153,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG26432-ENG30201,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG26432-ENG30202,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG26432-ENG36154,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG26432-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,,
ENG26432-ENG28937,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG26432-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG26432-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG26432-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG26432-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Odometer reading,655350, km
ENG26432-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG26432-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG26432-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG26432-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG26432-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG26433-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG26433-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG26433-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG26433-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG26433-ENG30200,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG26433-ENG36152,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG26433-ENG36153,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG26433-ENG30201,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG26433-ENG30202,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG26433-ENG36154,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG26433-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,,
ENG26433-ENG28937,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG26433-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG26433-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG26433-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG26433-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Odometer reading,655350, km
ENG26433-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG26433-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG26433-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG26433-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG26433-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,FB 17 C3 91,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,F0 51 F1 13,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,7D 6B 3C 51,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,82 53 78 C0,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,2.40, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,4.28, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,10.31, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,14.00, bar
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,62, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,62, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,62, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,2.16, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,3.89, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,11.06, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,14.00, bar
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,62, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,62, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,62, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,62, km
ENG103186,Clutch center central plate temperature,21, °C
ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,1116521612,
ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,1116443149,
ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,3266784329,
ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,1103787008,
ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,1117720251,
ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,1116534451,
ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,3266138431,
ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,1102034760,
ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,1145302135,
ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,1134747596,
ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,1050667663,
ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,3248930091,
ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,3214307384,
ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,1103914734,
ENG107255-ENG103334,Coefficient vmd_k_CutOff_ OddC0-Koeffizient,1124843062,
ENG107256-ENG103334,Coefficient vmd_k_CutOff_ OddC1-Koeffizient,3181665424,
ENG107257-ENG103334,Coefficient vmd_k_CutOff_ OddC2-Koeffizient,1100841960,
ENG107258-ENG103334,Coefficient vmd_k_CutOff_Even_C0-Koeffizient,1129184084,
ENG107259-ENG103334,Coefficient vmd_k_CutOff_Even_C1-Koeffizient,3184105933,
ENG107260-ENG103334,Coefficient vmd_k_CutOff_Even_C2-Koeffizient,1108476936,
ENG107261-ENG103334,Coefficient vmd_k_CutOff_Even_C3-Koeffizient,1046373733,
ENG107262-ENG103334,Coefficient vmd_k_CutOff_Even_C4-Koeffizient,1099030849,
ENG107263-ENG103334,Coefficient vmd_k_CutOff_OddC3-Koeffizient,1057286820,
ENG107264-ENG103334,Coefficient vmd_k_CutOff_OddC4-Koeffizient,1117166376,
ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,1143799453,
ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,1146764563,
ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,1144222818,
ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,1147018589,
ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,1143206765,
ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,1146955720,
ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,1143588533,
ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,1147179871,
ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,1103850717,
ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,1115359464,
ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,1105856657,
ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,1116661567,
ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,1111293409,
ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,1115372964,
ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,1107975598,
ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,1116964091,
ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,1089196781,
ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,1090576696,
ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,1091733271,
ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,1095085994,
ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,1100230339,
ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,1094012342,
ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,1092331979,
ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,1093627275,
ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,3254882263,
ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,3247285918,
ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,3256506967,
ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,3255573242,
ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,1103330168,
ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,3250866384,
ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,3244019644,
ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,3257020885,
ENG107297-ENG103334,Coefficient vmd_k_Line_C0-Koeffizient,3234615519,
ENG107298-ENG103334,Coefficient vmd_k_Line_C1-Koeffizient,1150452390,
ENG107299-ENG103334,Coefficient vmd_k_Line_C2-Koeffizient,3257921153,
ENG107300-ENG103334,Coefficient vmd_k_Line_C3-Koeffizient,1037269160,
ENG107301-ENG103334,Coefficient vmd_k_Line_C4-Koeffizient,684473044,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,2.5, Nm
ENG100625,Coolant temperature,70, °C
ENG26438-ENG36192,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,4.0, mJ
ENG26438-ENG36193,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,349113.0, J
ENG26438-ENG36194,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,4.0, mJ
ENG26438-ENG36195,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,349113.0, J
ENG26438-ENG30210,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG26439-ENG36192,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,3.0, mJ
ENG26439-ENG36193,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,333556.3, J
ENG26439-ENG36194,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,3.0, mJ
ENG26439-ENG36195,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,333556.3, J
ENG26439-ENG30210,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,K23D02,
ENG98602,Driver request torque,-3.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG101251,Empty,Empty,
ENG99932,Engine coding info,69,
ENG98756,Engine torque,42.0, Nm
ENG104230,Engine torque loss,45.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,164, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,133, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.2, mm
ENG100089,Gangsteller B Adaption Neutralposition,0.1, mm
ENG103055,Gangsteller C Adaption Neutralposition,-0.2, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.1, mm
ENG110510,Gear actuator adaption engaged position G1,-9.4, mm
ENG110511,Gear actuator adaption engaged position G2,-9.4, mm
ENG110512,Gear actuator adaption engaged position G3,10.1, mm
ENG99484,Gear actuator adaption engaged position G4,9.9, mm
ENG110513,Gear actuator adaption engaged position G5,9.8, mm
ENG110514,Gear actuator adaption engaged position G6,9.2, mm
ENG110515,Gear actuator adaption engaged position G7,-9.7, mm
ENG110516,Gear actuator adaption engaged position GR,-9.5, mm
ENG110517,Gear actuator adaption synchro position G1,-2.2, mm
ENG110518,Gear actuator adaption synchro position G2,-2.0, mm
ENG110519,Gear actuator adaption synchro position G3,1.9, mm
ENG99198,Gear actuator adaption synchro position G4,2.1, mm
ENG110520,Gear actuator adaption synchro position G5,1.4, mm
ENG110521,Gear actuator adaption synchro position G6,1.9, mm
ENG110522,Gear actuator adaption synchro position G7,-1.8, mm
ENG110523,Gear actuator adaption synchro position GR,-1.6, mm
ENG26442-ENG30213,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG26442-ENG30214,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG26442-ENG30215,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG26442-ENG30216,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG26442-ENG30217,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG26442-ENG30218,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG26442-ENG30219,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG26442-ENG30220,Gear_ratio_control-Status R-Gang,Übersetzung i.O.,
ENG26442-ENG36209,Gear_ratio_control-Übersetzung 1-Gang,14.097,
ENG26442-ENG36210,Gear_ratio_control-Übersetzung 2-Gang,8.567,
ENG26442-ENG36211,Gear_ratio_control-Übersetzung 3-Gang,5.505,
ENG26442-ENG36212,Gear_ratio_control-Übersetzung 4-Gang,3.847,
ENG26442-ENG36213,Gear_ratio_control-Übersetzung 5-Gang,2.929,
ENG26442-ENG36214,Gear_ratio_control-Übersetzung 6-Gang,2.353,
ENG26442-ENG36215,Gear_ratio_control-Übersetzung 7-Gang,1.980,
ENG26442-ENG36216,Gear_ratio_control-Übersetzung R-Gang,12.043,
ENG26443-ENG36155,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_A,7.7, mm
ENG26443-ENG36156,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_B,-76.8, mm
ENG26443-ENG36157,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_A,-48.6, mm
ENG26443-ENG36158,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_B,-30.7, mm
ENG26443-ENG36159,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_A,7.7, mm
ENG26443-ENG36160,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_B,-76.8, mm
ENG26443-ENG36161,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_A,-48.6, mm
ENG26443-ENG36162,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_B,-30.7, mm
ENG26443-ENG36163,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_A,7.7, mm
ENG26443-ENG36164,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_B,-76.8, mm
ENG26443-ENG36165,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_A,-48.6, mm
ENG26443-ENG36166,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_B,-30.7, mm
ENG26443-ENG36167,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_A,7.7, mm
ENG26443-ENG36168,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_B,-76.8, mm
ENG26443-ENG36169,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_A,-48.6, mm
ENG26443-ENG36170,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_B,-30.7, mm
ENG26443-ENG36174,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_A,79.3, mm
ENG26443-ENG36175,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_B,-5.1, mm
ENG26443-ENG36176,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_A,33.3, mm
ENG26443-ENG36177,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_B,51.2, mm
ENG26443-ENG36178,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_A,79.3, mm
ENG26443-ENG36179,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_B,-5.1, mm
ENG26443-ENG36180,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_A,33.3, mm
ENG26443-ENG36181,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_B,51.2, mm
ENG26443-ENG36182,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_A,79.3, mm
ENG26443-ENG36183,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_B,-5.1, mm
ENG26443-ENG36184,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_A,33.3, mm
ENG26443-ENG36185,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_B,51.2, mm
ENG26443-ENG36186,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_A,79.3, mm
ENG26443-ENG36187,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_B,-5.1, mm
ENG26443-ENG36188,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_A,33.3, mm
ENG26443-ENG36189,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_B,51.2, mm
ENG26444-ENG36171,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_1,240.6, bar
ENG26444-ENG36172,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_2,240.6, bar
ENG26444-ENG36190,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_1,307.2, bar
ENG26444-ENG36191,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_2,281.6, bar
ENG99720,Height info,974, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,44.0, Nm
ENG99582,Intake air temperature,28, °C
ENG110538,Kupplung 2 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG110539,Kupplung 2 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,16,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,1,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,7,
ENG107605-ENG103083,Mechatronics-ID_Dev.-Baudatum,200103,
ENG107605-ENG98675,Mechatronics-ID_Dev.-Construction version,N2,
ENG107605-ENG99175,Mechatronics-ID_Dev.-Kassel,K,
ENG107605-ENG104192,Mechatronics-ID_Dev.-Kennung der Mechatronik-Montagelinie,D15,
ENG107605-ENG103830,Mechatronics-ID_Dev.-Lfd.-Nr,5026,
ENG107605-ENG103525,Mechatronics-ID_Dev.-Teilenummer (3 letzten + Index),0GCE_,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,210.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,4294967295, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.0, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),5.6, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),0.0, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,58, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.0, %
ENG103000,Run time complete system,5.5522, H
ENG102748,Selector lever error flags,00 00,
ENG100909,Snapshot 1 Info current ECM3 error 0,0,
ENG100722,Snapshot 1 Info current ECM3 error 1,0,
ENG103157,Snapshot 1 Info old ECM3 error 0,0,
ENG99098,Snapshot 1 Info old ECM3 error 1,0,
ENG102200,Snapshot 2 Info current ECM3 error 0,0,
ENG101765,Snapshot 2 Info current ECM3 error 1,0,
ENG101738,Snapshot 2 Info old ECM3 error 0,0,
ENG101881,Snapshot 2 Info old ECM3 error 1,0,
ENG101057,Specified idle speed,800, /min
ENG100803,Speed: output,0, /min
ENG100141,Transmission coding info,24,
ENG106780-ENG103213,Transmission-ID_Dev.-Aggregatekennzeichnung (Getriebe),006,
ENG106780-ENG103083,Transmission-ID_Dev.-Baudatum,200105,
ENG106780-ENG104019,Transmission-ID_Dev.-Getriebekennbuchstabe,TSX,
ENG106780-ENG99175,Transmission-ID_Dev.-Kassel,K,
ENG106780-ENG101707,Transmission-ID_Dev.-Kennung der Montagelinie,D08,
ENG106780-ENG103830,Transmission-ID_Dev.-Lfd.-Nr,6316,
ENG103964,Veh. odometer state: last change of GE gear selector data,655350, km
ENG101346,Version info driving strategy,FBJRMSHEH.039,
ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,467,
ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,486,
ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,480,
ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,474,
ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,699,
ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,847,
ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,727,
ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,842,
ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,715,
ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,846,
ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,700,
ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,853,
ENG109971-ENG103334,vmd_k_Line_PmaxKoeffizient vmd_k_Line_Pmax-Koeffizient,1103048026,
ENG109005,Voltage Common Highside 1,14.4, V
ENG99955,Voltage Common Highside 2,14.4, V
Elapsed Time: 00:40
blockmap-03-5Q0-614-517-DJ_3VW6T7AU8LM010575-20200618-1049.CSV
;Component:ESC           H45 0113, Coding:01FA6BA15021216C807C020760C86880D60A84014006167610415051D0894B0B0000000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,049012,EV_Brake1UDSContiMK100IPB_049_VW27.rod
;Thursday,18,June,2020,10:49:36:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: FCAA1FBAA6687EBB8F3-80A8
Group,Description,Actual
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,ERROR,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,not activated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,AU10575,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,-0.03125, m/s²
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,Not available due to specific system,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,Not available due to specific system,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,15,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,4,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,13,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,24,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.588, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,OFF,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-957, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.30, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,not activated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 28 2019,
IDE04442-IDE00010,Vacuum sensor-Serial number,04 7F 27 98 28,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-95, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,0.19620, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,-0.22563, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,-0.03125, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,-0.066, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,1.269, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,1.269, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,not activated,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not available due to specific system,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXDRAD00029,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,17, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00012,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-957, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.30, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,612, mbar
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,4, km
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,255,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,255,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,255,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,255,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,13, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,253,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,253,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,5404,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,65425,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,0,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,84,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 32 39 38 32 30 33 30 30 30 30 35 32 30 31 30 37 30 30 31 41 38 2F 02 0D 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,99.9936, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,99.9936, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,99.2124, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,4,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.9936, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,1,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,99.9936, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,1,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,99.9936, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,1,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,23.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,23.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,23.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,23.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,not activated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
blockmap-05-3Q0-959-435-N_3VW6T7AU8LM010575-20200618-1049.CSV
;Component:VWKESSYMQB    037 1307, Coding:132C0C0723
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB.rod
;Thursday,18,June,2020,10:49:52:14741
;VCID: C5DCBA5E9522FF73A0D-8090
IDE00019,Voltage terminal 30,14.579, V
IDE00021,Engine speed,781.0, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Current,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked at single door,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,151,
IDE02419,Proximity sensor frt.pass. door: number of triggers,73,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,31,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,17,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,AA,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,31,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,17,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,AA,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,00,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,00,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,Yes,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02495,Service key: number of activations,17,
IDE02496,Service key: number of timeouts,0,
IDE02497,Service key: number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,2,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2011,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,53,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,29,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Missing message from Engine Control Module,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Missing message from Engine Control Module,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Empty,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,62,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,52,
IDE05204,Manufacturing dates for driver door handle,1F 07 21 9A 51,
IDE05205,Manufacturing dates for frt.pass. door handle,1F 07 21 9A 51,
IDE05206,Manufacturing dates for left rear door handle,00 00 00 00 00,
IDE05207,Manufacturing dates for right rear door handle,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,89,
IDE08440,Recommendation energy management,no restriction,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,2,
IDE80258-MAS00110,Immobilizer status-Minutes,0,
IDE80258-MAS00111,Immobilizer status-Seconds,1,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2011,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,29,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,39,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop in start-stop mode active,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG29819,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG29818,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG29817,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG29816,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,14.568, V
ENG08690,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG114479,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,0, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,0, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,0, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG118078-MAS00111,History_low_voltage-Seconds,0, s
ENG118078-ENG118397,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG118078-ENG118381,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG118078-ENG118223,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG118078-ENG118309,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG118078-ENG118280,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG118078-ENG118389,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG118078-ENG118329,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG118078-ENG118282,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG118078-ENG118267,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG118078-ENG118278,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG26926-MAS00106,lf_shutdowns-Year,2000,
ENG26926-MAS00107,lf_shutdowns-Month,0,
ENG26926-MAS00108,lf_shutdowns-Day,0,
ENG26926-MAS00109,lf_shutdowns-Hours,0,
ENG26926-MAS00110,lf_shutdowns-Minutes,0,
ENG26926-MAS00111,lf_shutdowns-Seconds,0,
ENG26926-ENG32070,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG26926-ENG32071,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG26926-ENG32072,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG26926-ENG32073,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,13,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,19, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,19, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,0, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,0, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,0, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,0, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,0, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,0, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,0, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,0, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,0, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,0, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,0, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,0, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,0, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,0, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,0, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,0, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,0, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,0, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,10,
ENG26348-ENG30077,Scan_cycle_data-Retry_count_n -6,0,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,9,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,0,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,0,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,0,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,0,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,0,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,0,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,0,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,0,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,0,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,0,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,0,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,0,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,0,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,0,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,0,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,0,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,0,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Initial,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Initial,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Initial,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Initial,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Initial,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Initial,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Initial,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Initial,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Initial,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Initial,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Initial,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Initial,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Initial,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Initial,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,Initial,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Initial,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Initial,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Initial,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Reset_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2011,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,3,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,15,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,48,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,38,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG08630-ENG09181,WFS_key_signature-clap_15_activateing_signature,02,
ENG08630-ENG09176,WFS_key_signature-signature_key_1,03 9B,
ENG08630-ENG09177,WFS_key_signature-signature_key_2,03 80,
ENG08630-ENG09178,WFS_key_signature-signature_key_3,00 00,
ENG08630-ENG09179,WFS_key_signature-signature_key_4,00 00,
ENG08630-ENG09180,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:19
blockmap-08-5GM-907-426-G_3VW6T7AU8LM010575-20200618-1050.CSV
;Component:AC Manuell    H03 2001, Coding:00020004200110001000000000010004
;EV_ACManueBHBVW37X,004134,EV_ACManueBHBVW37X_004.rod
;Thursday,18,June,2020,10:50:13:14741
;VCID: CCCA8F7AB6480E3B7F3-8098
IDE00019,Voltage terminal 30,14.4, V
IDE00021,Engine speed,800, /min
IDE00025,Coolant temperature,78, °C
IDE00198,Refrigerant pressure,9.8, bar
IDE00767,No. of unscheduled ECU resets,8,
IDE00965,Compressor shut-off requirement,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.485, A
IDE00967,Compressor current: specified value,0.490, A
IDE00968,Compressor speed,800, /min
IDE00969,Compressor load,8.1, Nm
IDE00970,Coolant fan activation: actual value,30.0, %
IDE00971,Coolant fan activation: specified value,26.0, %
IDE00973,Outside air temperature,23.0, °C
IDE00974,Outside air temperature internally calculated,23.0, °C
IDE00982,Temperature after evaporator,2.3, °C
IDE00987,Blower voltage: specified value,3.8, V
IDE00989,Blower status,active,
IDE00992,Recirculation flap specified value,Fresh air,
IDE01046,Temperature flap: actual value,0.0, %
IDE01046,Temperature flap: actual value,25,
IDE01047,Temperature flap: specified value,24,
IDE01048,Temperature flap: cold stop,29,
IDE01049,Temperature flap: warm stop,236,
IDE01059,Air distribution flap: actual value,0.0, %
IDE01059,Air distribution flap: actual value,27,
IDE01060,Air distribution flap: specified value,26,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,closed,
IDE01076,Time since ignition off,240, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,3.8, V
IDE01227,Blower current,1.00, A
IDE01232,Supply voltage for external components,5.1, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,32,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,4,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Speed shut-off,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS01577,Pressing a button-Parking heater,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02192,Pressing a button-SYNC,not activated,
IDE01442-MAS03196,Pressing a button-Menu,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04605,Pressing a button-AC MAX,not activated,
IDE01443,Left push-and-rotary knob counter,28,
IDE01444,Right push-and-rotary knob counter,110,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to setting,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127,Prevented stop processes (ring memory),Measured value not available,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128,Requested start processes (ring memory),Measured value not available,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,248, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,84,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,253,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measured value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measured value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load mgmnt.,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,59,
Elapsed Time: 00:08
blockmap-09-5Q0-937-087-BG_3VW6T7AU8LM010575-20200618-1050.CSV
;Component:BCM PQ37BOSCH 038 0303, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,020001,EV_BCMBOSCH_020.rod
;Thursday,18,June,2020,10:50:25:14741
;VCID: 81546E4EC18A1353DC5-80D4
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside air temperature,23.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,71,
IDE01943-MAS04352,Turn signal-Connector number,Plug A,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded/not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,not enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,not coded/not installed,
IDE02743-MAS02248,High Beam-Signal state,Measured value not available,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,0,
IDE02743-MAS04352,High Beam-Connector number,not coded/not installed,
IDE02744-MAS01632,Steering wheel heater-Status,switched off,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,255,
IDE02857-IDE03111,Activation current-Interior light,0, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,0, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,NOT-DEFINED,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Not available,
IDE03111-MAS01737,Interior light-Diagnosis,normal,
IDE03111-MAS02248,Interior light-Signal state,active,
IDE03111-MAS03873,Interior light-Duty cycle,88.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,12,
IDE03111-MAS04352,Interior light-Connector number,Plug C,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,71,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,29.00, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,33.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,OFF,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,not active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,Unlock. indiv. doors,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,not active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,5, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,5, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,not coded/not installed,
IDE03638-MAS02248,static AFS light-Signal state,Measured value not available,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,0,
IDE03638-MAS04352,static AFS light-Connector number,not coded/not installed,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,18.50, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,0,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,normal,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,45,
IDE05323-MAS04352,Fog light-Connector number,Plug B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,Measured value not available,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,not coded/not installed,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: engaged,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: engaged,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,Measured value not available,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,not coded/not installed,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,active,
IDE05739-MAS03873,Footwell light-Duty cycle,55.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not coded/not installed,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,0,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,Unknown (65534),
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,47600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,39,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Remote control,
IDE05841-MAS07519,Central locking history data-Command,Unlock. indiv. doors,
IDE05841-MAS07942,Central locking history data-Additional information,Rem. ctrl. no. 2,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,keine Bedienstelle,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Search lights-Diagnosis,normal,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,62,
IDE06012-MAS04352,Search lights-Connector number,Plug C,
IDE06012-MAS15156,Search lights-terminal,Variant A,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-38.1, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,87.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,127.0, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-38.1, °C
IDE06096-IDE03111,Interior lighting-Interior light,100, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.0, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,100.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,88.0, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,Measured value not available,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not activated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,OFF,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06649-MAS05016,Radio-frequency transmitter-Receiver status,not installed,
IDE06649-MAS05048,Radio-frequency transmitter-Number of transmitters adapted,0,
IDE06649-ENG116085,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG116115,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE06864-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,0,
IDE06864-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,38.30, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,799.3, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,4.992, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not activated,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,Unknown (254),
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,Unknown (254),
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,Unknown (254),
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Vehicle unlocked at single door,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,11,
IDE08211-MAS00107,History data control module reset-Month,1,
IDE08211-MAS00108,History data control module reset-Day,1,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,25,
IDE08211-MAS03129,History data control module reset-Reset counter,9,
IDE08211-MAS06734,History data control module reset-last cause of reset,Application 9,
IDE08343,Immobilizer Challenge,29 B8 36 19,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,40, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,80, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,40, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,Measured value not available,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,not coded/not installed,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not activated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not activated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not activated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not activated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not activated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not activated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not activated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not activated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not activated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not activated,
IDE12940,Lever functions of the steering column electronics,not activated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,14.50, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,14.50, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,14.55, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,14.55, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,14.55, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.95, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,14.55, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00043-ENG119641,Supply voltage: Terminal 30-Messauswertung Pruefspannung Wischerablagenheizung,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2011,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,29,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,29,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,not activated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-56,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,5, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,0,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,2,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,39,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog light-Signal state,Measured value not available,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,0,
MAS03836-MAS04352,Rear fog light-Connector number,not coded/not installed,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,no reason for cancellation,
MAS07959-MAS00107,Remote start history data-Month,15,
MAS07959-MAS00108,Remote start history data-Day,31,
MAS07959-MAS00109,Remote start history data-Hours,31,
MAS07959-MAS00110,Remote start history data-Minutes,63,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843-MAS00106,SE references from last used digital key devices-Year,0,
MAS18843-MAS00107,SE references from last used digital key devices-Month,0,
MAS18843-MAS00108,SE references from last used digital key devices-Day,0,
MAS18843-MAS00109,SE references from last used digital key devices-Hours,0,
MAS18843-MAS00110,SE references from last used digital key devices-Minutes,0,
MAS18843-ENG119380,SE references from last used digital key devices-km_Stand,1048574,
MAS18843-ENG118445,SE references from last used digital key devices-Secure_element_reference,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS18843-ENG118320,SE references from last used digital key devices-Secure_element_reference_state,invalid,
ENG116910,Control unit internal measured value (supplier),31 39 30 30 30 30 31 39 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116008-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG116008-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 08 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 32 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 78 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,2,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,1,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,1,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,1,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,1,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,1,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,10,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,13, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,14.9, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.5, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.5, V
ENG116791,Temperatures,23.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 01 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,Radio telegram: valid,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,23.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,not activated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.5, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 00:44
blockmap-13-5Q0-907-572-R_3VW6T7AU8LM010575-20200618-1051.CSV
;Component:ACC BOSCH MQB H11 0771, Coding:3500008101FFC728949C810500401600000000000000000014
;EV_ACCBOSCHVW416,003014,EV_ACCBOSCHVW416_003.rod
;Thursday,18,June,2020,10:51:12:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: C6DEBD52A824F46BA97-8092
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018-ENG99033,Voltage terminal 15-Voltage,14.4, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,42, °C
IDE00391,Adaptive distance regulation: status,ACC_reversible_error,
IDE01788-ENG98502,Heated lens control signal-Data,0.00, %
IDE01794,ACC operating lever signal,00000000 10100100 ,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,CA 29 9D C0,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 90 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 F7 2F 35 53 5E E2 17 A5 77 DB 79 FD 19 AF 44 A3 60 AB 15 CA A5 5E F9 45 CD 6F 1E F6 A2 BE 4E 8D 28 64 CF 1C 34 C7 C9 16 DE DE 67 B5 57 39 00 C2 53 57 B6 FB 19 A1 41 40 A0 F5 B2 60 C0 18 01 6D C7 8E B5 02 83 63 E2 BA D4 28 DD 96 22 FD D1 F4 87 8B 5F EC EC 1D 9D 62 41 0B 2B 9F 3C 6B 2B AE 87 95 D3 A9 B9 72 54 56 6C 80 1C 53 40 5F 4E CE C1 CD 32 AD 83 5B 53 DE BA EF E3 D0 D0 B8 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE05814,Individualization characteristic,8C 72 FA 35 67,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,not active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,24.464, °
IDE08769,Mirror deviation: vertical,-24.464, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.186, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.719, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,20,
IDE09380-MAS00107,Performed adjustment-Month,02,
IDE09380-MAS00108,Performed adjustment-Day,21,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.14, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.20, °
IDE09906,Vertical deadjustment,1.613, °
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.710, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,1.620, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,0.140, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,2.190, °
ENG107860,Number_of_ANB_partial_bracings,0,
ENG107861,Number_of_ANB_target_bracings,0,
ENG107862,Number_of_ANB-CM,0,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00915,Number_of_fully_developed_deceleration_1,0,
ENG00916,Number_of_fully_developed_deceleration_2,0,
ENG06681,Number_of_mainwarnings,0,
ENG03998,number_of_prewarnings,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,0, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,0, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,0, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,0, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG00933,Operating_time_STA_active,0, min
ENG00934,Operating_time_STA_off_activation_possible,0, min
ENG08760,Sw_version_supplier,1037605725;PF_R28.12.0_VW.MQB_48PA.0771_I1.1;0;Compiled by kca2bp on Tue Mar 19 10:23:34 2019$!,
Elapsed Time: 00:14
blockmap-15-5Q0-959-655-J_3VW6T7AU8LM010575-20200618-1051.CSV
;Component:AirbagVW20    012 0830, Coding:8CCCFC00000000005000001AC24800000065
;EV_AirbaVW20SMEVW37X,002144,EV_AirbaVW20SMEVW37X_VW37.rod
;Thursday,18,June,2020,10:51:28:14741
;VCID: C7C0B056AF2EED63521-8092
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.9, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.6, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.2, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.4, Ohm
IDE01115,side belt force limiter igniter ohm value,2.4, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,too Low,
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,6.2, mA
IDE01201,Frt.pass. seat position sensor current value,6.2, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01555,Number of frontal crashes,0,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE06959,Seat occupant detection: diagnosis signal,26.5, %
IDE06960,Seat occupant detection: msmt. signal,0.0, %
IDE06961,Seat occupant detection: ref. signal,1.0, %
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear safety belt tension igniter,cannot be measured currently,
MAS00022,Igniter for battery interrupt,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00044,Supply voltage: Terminal 15,14.5, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:12
blockmap-17-5G1-920-856-E_3VW6T7AU8LM010575-20200618-1046.CSV
;Component:KOMBI         343 6700, Coding:0BAD091AA988CF0502886B0950000000A0000000
;EV_DashBoardVDDMQBAB,009069,EV_DashBoardVDDMQBAB_009_VW37.rod
;Thursday,18,June,2020,10:46:21:14741
;VCID: B032FB8A3AA04ADB63B-80E4
IDE00019,Voltage terminal 30,13.4, V
IDE00021,Engine speed,1299.00, /min
IDE00025,Coolant temperature,20.25, °C
IDE00196,Engine oil temperature,20, °C
IDE00301,Distance,38, km
IDE00310,Outside air temperature,25.5, °C
IDE00316-IDE00500,Time-Hour,23, H
IDE00316-IDE00501,Time-Minute,59, min
IDE00316-MAS00111,Time-Seconds,0, s
IDE00317-IDE00502,Date-Year,2011, yr
IDE00317-IDE00503,Date-Month,4, mon
IDE00317-IDE00504,Date-Day,28, d
IDE00510,ESI: distance driven from inspection,38, km
IDE00511,ESI: time from inspection,117, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,300, km
IDE00520,Phototransistor,251,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,16070, km
IDE00698,ESI: remaining running time,248, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,118, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1958, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,1958, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,131068, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,operated,
IDE02642,Outside temp.: displayed value,25.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,103,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,117, d
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,9.7, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,48.5, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,51.7, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,10.4, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,6.2, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,12.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,12.1, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,6.3, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,0,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,79, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,1176,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,2339,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,48.3, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,77, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,46.9, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,46.9, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,46.9, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,46.9, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,46.9, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.03125, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,47.3, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,112,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0032377,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,15, H
IDE03477-IDE00501,GPS time-Minute,46, min
IDE03477-IDE00501,GPS time-Minute,45, min
IDE03477-IDE00502,GPS time-Year,2020, yr
IDE03477-IDE00503,GPS time-Month,6, mon
IDE03477-IDE00504,GPS time-Day,18, d
IDE03477-MAS00111,GPS time-Seconds,35, s
IDE03477-MAS00111,GPS time-Seconds,20, s
IDE03477-MAS03493,GPS time-last synchronization year,2020, yr
IDE03506,Distance: high resolution,00 00 97 4C,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,FF FF FF FF,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,FF FF FF FF,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,FF FF FF FF,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,FF FF FF FF,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,730, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
IDE14186-MAS17993,Communication transponder-Phase value,15,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,53, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,77, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG106922,Immobilizer - Challenge,A0 44 D1 31,
ENG99439,Instrument_recorder,03 23 61 00 4D 51 42 56 57 31 39 53 31 43 00 00 00 00 00 00 03 00 58 00 0B 00 09 07 20 00 00 03 02 80 00 00 0A 00 58 00 0B 00 09 07 9F 00 00 04 02 00 00 00 00 00 54 00 0B 00 02 03 56 00 00 00 B4 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 02 03 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 0B 00 58 00 20 07 09 00 02 03 00 00 0B 00 54 00 56 03 02 00 B4 00 00 00 0B 00 58 00 20 07 09 00 02 03 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7F FB,
ENG107920-ENG100914,onboard_computer-current_consumption,300.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.5, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.5, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,9.4, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,523, km
ENG107920-ENG119792,onboard_computer-range_R,530,
ENG107920-ENG112418,onboard_computer-total_range_gas,523, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,151,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,17,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Start_Delay,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 07 02 00 00 00 15 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,F8,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,F8,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109575,Transponder ID current Key,00 00 00 00,
ENG109576,Transponder ID Key 1,6F DB F4 E0,
ENG109577,Transponder ID Key 2,74 DB F4 E0,
Elapsed Time: 00:16
blockmap-19-3Q0-907-530-AC_3VW6T7AU8LM010575-20200618-1046.CSV
;Component:GW MQB High   521 5388, Coding:030100047F085900FB00006B1C0F00010001070000000000000000000000
;EV_GatewNF,013026,EV_GatewNF_VW37.rod
;Thursday,18,June,2020,10:46:41:14741
;VCID: F0B23B8AFA200ADB23B-80A4
IDE00019,Voltage terminal 30,13.7, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056-ENG20489,History data 1-Life Cycle Data String,       0000038km*09.0*01*01997***
       0000038km*18.8*01**
       0000038km*24.0*01**
       0000038km*00.5*01*00042***
       0000038km*18.3*01**
       0000038km*03.5*01**
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String,       0000013km*T*0*086*085*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000013km*T*0*087*087*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000013km*T*0*086*089*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000013km*T*0*088*091*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000012km*T*0*089*093*0-0-0-0-1-0-0*0*0*00.0*00.0**
       0000012km*T*0*089*093*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000012km*T*0*088*092*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000010km*T*0*090*094*1-0-0-0-0-0-0*0*0*00.0*00.0**
       0000009km*T*0*093*097*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000007km*T*0*092*097*1-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String,       0000000km*01*070*JCB*1111111111*09977*00067*000.0*000.0*000.0**
IDE00060-ENG20489,History data 5-Life Cycle Data String,-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489,History data 6-Life Cycle Data String,       0000038km*050*+22*+000.1*00.00*0.00*000**
       0000038km*054*+27*+000.6*00.00*0.00*000**
       0000038km*057*+26*+001.3*00.00*0.00*000**
       0000029km*056*+24*+006.8*00.20*0.00*000**
       0000028km*050*+22*+001.9*00.00*0.00*000**
       0000028km*052*+18*+000.5*00.00*0.00*000**
       0000028km*063*+16*+000.4*00.00*0.00*000**
       0000028km*069*+15*-000.1*00.00*0.00*000**
       0000028km*075*+21*+001.1*00.00*0.00*000**
       0000028km*070*+30*+003.6*00.00*0.00*000**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,       0000038km*045*+001.3*118.9*00.0*00.0**
       0000038km*049*+000.1*003.0*00.0*00.0**
       0000038km*050*+002.3*279.9*00.0*00.0**
       0000038km*052*+005.0*677.1*00.0*00.0**
       0000038km*055*+000.6*000.3*00.0*00.0**
       0000029km*050*+000.2*000.0*00.0*00.0**
       0000028km*051*+005.1*741.3*00.0*00.0**
       0000028km*047*+005.4*000.5*00.2*00.2**
       0000028km*064*+001.8*215.8*00.0*00.0**
       0000028km*071*+000.6*055.0*00.0*00.0**,
IDE00063-ENG20489,History data 8-Life Cycle Data String,       0000000km*1*02*00*00*00*-------------:--*01**
       0000000km*1*01*00*00*00*-------------:--*01**
IDE00064-ENG20489,History data 9-Life Cycle Data String,       0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
IDE00065-ENG20489,History data 10-Life Cycle Data String,-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066-ENG20489,History data 11-Life Cycle Data String,       0000028km*000*000*000*000*0000*000*00.0*00.0*074*071*073*069*01*00000*00001*00000*00007*00016**
       0000028km*000*000*000*001*0000*001*00.0*00.1*076*069*075*069*01**
       0000028km*000*000*000*005*0000*005*00.0*01.2*076*072*076*075*01**
       0000027km*000*000*004*000*0001*004*00.0*00.6*086*085*085*086*01**
       0000023km*000*000*000*009*0077*009*00.0*00.5*078*076*078*077*01**,
IDE00067-ENG20489,History data 12-Life Cycle Data String,       0000038km*0-0-0-0-0-0-1-0**
       0000029km*0-0-0-1-0-0-1-0**
00000*00000*00000*00003*00000*00000*00004*00000**
IDE00068-ENG20489,History data 13-Life Cycle Data String,-------------:--*---------*---.-*-----**
IDE00069-ENG20489,History data 14-Life Cycle Data String,       0000038km*3*00000*0000*0003*00.00*000004*+20*0000.1*0000.0*0000.0**
       0000038km*3*00000*0000*0003*00.00*000004*+27**
       0000038km*3*00000*0000*0003*00.00*000004*+22**
       0000038km*1*00000*0000*0000*00.00*000004*+27**
00062*00000*00013*00000*00000**
IDE00071-ENG20489,History data 16-Life Cycle Data String,       0000038km**
00029*00036*00015*00006*00000**
00067*00017*00002*00000**
00523*00008*00000*00000**
00049*00015*00001*00000**
00061*00004*00000**
00000*00000*00000*00000**
00009*00002*00000**
00000*00000*00000**
00005*00000*00000**
00001*00000*00001*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,CCS Switch,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,9,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,231,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Databus extended,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,16.9, H
IDE01810-MAS00106,History data 24-Year,2011,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,26,
IDE01810-MAS00109,History data 24-Hours,20, H
IDE01810-MAS00110,History data 24-Minutes,48, min
IDE01810-MAS14375,History data 24-Cycle counter,65,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,46,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,17 F0 00 09,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,1,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Databus extended,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,17 F0 00 32,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 00 00,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,0,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Unknown,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,89,
IDE01812-MAS03173,History data 26-Databus drivetrain,3,
IDE01812-MAS03174,History data 26-Comfort data bus,462,
IDE01812-MAS03175,History data 26-Databus extended,430,
IDE01812-MAS03177,History data 26-Databus Infotainment,0,
IDE01812-MAS03178,History data 26-Suspension data bus,3,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,898,
IDE01813-MAS03173,History data 27-Databus drivetrain,64,
IDE01813-MAS03174,History data 27-Comfort data bus,434,
IDE01813-MAS03175,History data 27-Databus extended,127,
IDE01813-MAS03177,History data 27-Databus Infotainment,14,
IDE01813-MAS03178,History data 27-Suspension data bus,64,
IDE01813-MAS14374,History data 27-Totals,703,
IDE01814-MAS03173,History data 28-Databus drivetrain,0,
IDE01814-MAS03174,History data 28-Comfort data bus,877,
IDE01814-MAS03175,History data 28-Databus extended,0,
IDE01814-MAS03177,History data 28-Databus Infotainment,0,
IDE01814-MAS03178,History data 28-Suspension data bus,0,
IDE01814-MAS14374,History data 28-Totals,880,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.0, H
IDE01816-MAS00106,History data 30-Year,2000,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,1,
IDE01816-MAS00109,History data 30-Hours,0, H
IDE01816-MAS00110,History data 30-Minutes,0, min
IDE01816-MAS14375,History data 30-Cycle counter,0,
IDE01816-ENG20570,History data 30-Bus_1,Unknown,
IDE01816-ENG20572,History data 30-Bus_2,Unknown,
IDE01816-ENG20574,History data 30-Bus_3,Unknown,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.0, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,16.9, H
IDE01819-MAS00106,History data 33-Year,2011,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,26,
IDE01819-MAS00109,History data 33-Hours,20, H
IDE01819-MAS00110,History data 33-Minutes,48, min
IDE01819-MAS14375,History data 33-Cycle counter,65,
IDE01819-MAS14393,History data 33-ID of the alerting message,17 F0 00 09,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Databus extended,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,118.9, H
IDE01820-MAS00106,History data 34-Year,2011,
IDE01820-MAS00107,History data 34-Month,4,
IDE01820-MAS00108,History data 34-Day,28,
IDE01820-MAS00109,History data 34-Hours,23, H
IDE01820-MAS00110,History data 34-Minutes,58, min
IDE01820-MAS14375,History data 34-Cycle counter,89,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,2, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,90,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Generator specified voltage value,14.6, V
IDE01828,Generator DF Signal,35.500, %
IDE01829,Generator exciter current,2.500, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82 - 140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,14.454, V
IDE01836,Battery current,26.376, A
IDE01837,Temperature of battery sensor,23, °C
IDE01838,Battery temperature,20, °C
IDE01839,Battery charge condition,52, %
IDE01841,Battery internal resistance,4.2, mOhm
IDE01842,Usable battery charge,43, Ah
IDE01843,Battery voltage at rest,12.1, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,0.2, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initializing,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,63.6, A
IDE01948,Battery internal resistance not normed,4.8, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,1E 7F 32 6F,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,4,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,3,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2011,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,15,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,8,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,1,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,34,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,51,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Possible service life too short,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Battery charge condition too low,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible service life too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Battery charge condition too low,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Battery charge condition too low,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start-stop conditions,Stop prohibition: no start request,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,70, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB+,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,invalid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,not activated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,not activated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,not activated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,not activated,
IDE05583-IDE02766,Pause recommendation-Malfunction status,not installed,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,51 99 57 DC 39,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module (ECM),
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,AUTO,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,208,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,52,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,76,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,44,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,36,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop - operation,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,outside permissible range,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,14.5, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,blocked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,blocked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,blocked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
IDE07637,Current charge contingent for feedback,1080.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.80,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.10, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,816, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,808, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,44.8, Ah
IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,67.4, Ah
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Not Used,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,1E 94 A5 01,
IDE08346-MAS06117,Generator Analysis-Rated voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,14.6, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.1, V
IDE08346-MAS06866,Generator Analysis-Generator speed,2181, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,24, °C
IDE08347,adapted battery capacity,109, Ah
IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,01 3E,
IDE08685-SFT09757,Status LIN user-Alternator,not active,
IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT09833,Status LIN user-Power Converter DC AC,not active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,not active,
IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Closed-circuit current of last LIN sleep phase,-1.176, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,7,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084,Status of component protection slaves,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,328,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.60, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.65, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,17.8, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14),
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initializing,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*0000-01-01-00-00-00*0**,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2011,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,28,
MAS00464-MAS00109,Standard - ambient data 1-Hours,23,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,59,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,57,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,8,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT09757,Alternator,-,
SFT09757-ENG119789,Alternator-alternator_family,35,
SFT09757-ENG114913,Alternator-asic_manufacturer,30 30,
SFT09757-ENG119379,Alternator-asic_variant,30 34,
SFT09757-ENG40398,Alternator-Manufacturer,30 30,
SFT09757-ENG99001,Alternator-Variant,31 34,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG20108,EM_electrical_system_current,44.303, A
ENG118437,EM_IAlternatorReserve,65.2, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,1300, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,98, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,99, %
ENG106157,EM_RecuMode_Engine,Acc.,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,101F,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,6710,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9112,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,0503,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7210,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initializing,
ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initializing,
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initializing,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,-204.0, A
ENG20120,MV-EM_dc_power_desired,-6325, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,-511, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG119298-ENG119462,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:47
blockmap-29-8V0-907-399-D_3VW6T7AU8LM010575-20200618-1051.CSV
;Component:LCM_MLBevoH09 0014, Coding:
;EV_LCMLeftHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
;Thursday,18,June,2020,10:51:43:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: C7C0B056AF2EED63521-8092
Group,Description,Actual
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,14.30, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.30, V
IDE06876-MAS01482,Signature light bulb-Hardwareversion,Not available,
IDE06876-MAS01483,Signature light bulb-Softwareversion,Not available,
IDE06876-MAS12381,Signature light bulb-Software subversion,0F,
IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,F0 4D 5F 4D 4C,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Unknown (0),
IDE08742-MAS01155,Operating time-Control module,4.96, H
IDE08742-MAS03835,Operating time-Parking light,1.54, H
IDE08742-MAS09325,Operating time-Daytime running lights,2.14, H
IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
IDE08742-MAS09332,Operating time-Turn signal,0.15, H
IDE08742-MAS09333,Operating time-Side-marker light,0.00, H
IDE08742-MAS09334,Operating time-Parking light,0.00, H
IDE09492-MAS01155,Temperatures-Control module,44.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,51.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,not installed,
IDE09768-MAS04121,LED channel 1-Voltage,0.00, V
IDE09768-MAS04136,LED channel 1-Current,0, mA
IDE09768-MAS09022,LED channel 1-PWM value,0.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,3,
IDE09768-MAS09328,LED channel 1-Primary function,Turn signal,
IDE09768-MAS09329,LED channel 1-Secondary function,no function,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,1,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
IDE09769-MAS09329,LED channel 2-Secondary function,no function,
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,Turn signal,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Parking light,
IDE09774-MAS03835,Number of activations-Parking light,29,
IDE09774-MAS09325,Number of activations-Daytime running lights,91,
IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
IDE09774-MAS09332,Number of activations-Turn signal,1552,
IDE09774-MAS09333,Number of activations-Side-marker light,0,
IDE09774-MAS09334,Number of activations-Parking light,0,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.00, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,0.00, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,0.00, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,98.65, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.96, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 76,
IDE09828-MAS01155,Head lamp variant-Control module,E0 76,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28928,
IDE09916-MAS09565,Data set names-Data set name,VMAV28iXK001,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,0,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
IDE11123-MAS04136,High side channel 4-Current,0, mA
IDE11123-MAS09022,High side channel 4-PWM value,0.00, %
IDE11123-MAS09326,High side channel 4-Function,no function,
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),65.60, %
IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-8.00, mm
IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,performed,
IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),36.80, %
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,-0.03, °
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,Not available,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,Not available,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
blockmap-2B-2Q0-905-861-A_3VW6T7AU8LM010575-20200618-1051.CSV
;Component:ELV-MQBB      H08 0021, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW37.rod
;Thursday,18,June,2020,10:51:48:14741
;VCID: B134FE8E31AA43D36C5-80E4
IDE00019,Voltage terminal 30,14.4,
IDE00021,Engine speed,794.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-obsolete,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-obsolete,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,not activated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,53,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Not adapted,
IDE06746-MAS08251,Locking requirements-Communication status signal ESP_21,Condition met,
IDE06746-MAS08252,Locking requirements-Communication status signal Klemmenstatus_01,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Cyclical Reception Signal ESP_21,Condition met,
IDE06746-MAS08792,Locking requirements-Cyclical Reception Signal ESP_10,Condition met,
IDE06746-MAS08794,Locking requirements-Cyclical Reception Signal Terminal Status_01,Condition met,
IDE06746-MAS11697,Locking requirements-Communication status signal ESP_10,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00108,Standard - ambient data 1-Day,29,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,28,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG124678,functional_check-Functional_Check_VW_EOL,Not confirmed,
Elapsed Time: 00:04
blockmap-32-0CQ-907-554-P_3VW6T7AU8LM010575-20200618-1051.CSV
;Component:Quersperre    H55 8043, Coding:0001
;EV_LockElectHA1VW37X,001007,EV_LockElectHA1VW37X.rod
;Thursday,18,June,2020,10:51:54:14741
;VCID: D2F69102546C58CB35F-8086
IDE00019,Voltage terminal 30,14.5, V
IDE00102,Control Module temperature,24, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Front right wheel speed,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,25.10, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,not active,
IDE02271-MAS01480,CAN output signal(s) status-Excess temp.,not active,
IDE02404,Checksum calculation,C9 DD AD 86,
IDE04502-MAS04730,Haldex clutch status-Degree of blockage,0.00, %
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05609,Cooling fin temperature,20.90, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump current,1.509, A
IDE05708,Haldex clutch pump PWM signal,12, %
IDE05710,Haldex clutch pump voltage,1.7, V
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,0,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS03129,Reset counter,2,
MAS06745,Difference front axle speed,0.0, km/h
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,1645,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,0,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,1,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,2317,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,5372,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,0,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,15,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,5006,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,0,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,10077,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,0,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,35,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,7532,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,12903168,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,30,
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:03
blockmap-39-8V0-907-399-D_3VW6T7AU8LM010575-20200618-1051.CSV
;EV_LCMRightHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
;Thursday,18,June,2020,10:51:59:14741
IDE03680-MAS01468,Supply voltages-Terminal 15,14.40, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.40, V
IDE08742-MAS09325,Operating time-Daytime running lights,2.17, H
IDE08742-MAS09332,Operating time-Turn signal,0.13, H
IDE09492-MAS01155,Temperatures-Control module,40.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,33.00, °C
IDE09768-MAS09327,LED channel 1-LED brightness class,4,
IDE09774-MAS09325,Number of activations-Daytime running lights,86,
IDE09774-MAS09332,Number of activations-Turn signal,1415,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),62.80, %
Elapsed Time: 00:03
blockmap-3C-5Q0-907-686-C_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:HRE_Master    H12 0081, Coding:01011103
;EV_HREntryHella,001028,EV_HREntryHella_VW37.rod
;Thursday,18,June,2020,10:52:05:14741
;VCID: BD2CD2BEFDF2B7B3F8D-80E8
IDE00018,Voltage terminal 15,14.40, V
IDE00102,Control Module temperature,35.0, °C
IDE00925,Yaw rate,-0.01, °/s
IDE01441,Back-up light,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not defined,
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,4.00, km
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,54, %
IDE02057-MAS10065,Dynamic calibration: status-Distance of object 4,24, %
IDE02057,Dynamic calibration: status,is running,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Positive,
IDE02219,Steering wheel angle: sign,0.00,
IDE03619,System status,On,
IDE05064,lane change assist. 2: supply voltage,14.38, V
IDE05065,lane change assist. 2: temperature,34.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,OFF,
IDE05070,Curve radius,14976, m
IDE05072,Status of lane change assist. indicator lamp,active,
IDE05077-IDE02389,Rain/light recognition sensor via data bus-Ambient brightness,0,
IDE05077,Rain/light recognition sensor via data bus,not defined,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,-120.00, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,0.00, m
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,0.00, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,-120.00, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,0.00, m
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,0.00, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,-120.00, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,0.00, m
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,0.00, m/s
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05086,Closest object lane used,No object recognized,
IDE05087,Dynamic angle offset lane change assist. 1,-0.37, °
IDE05088,Dynamic angle offset lane change assist. 2,0.31, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,20.32, °
IDE05093,Measured angle lane change assist. 2,20.32, °
IDE05094,Static angle offset lane change assist. 1,0.00, °
IDE05095,Static angle offset lane change assist. 2,0.00, °
IDE05100,Spray counter,0,
IDE10101,Dimming value of left warning light,0, %
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10105,Dimming value of right warning light,0, %
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,0,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,0,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane holding warn. syst.-LED,yellow,
IDE10236-MAS10041,Lane holding warn. syst.-Distance to lane,1.25, m
IDE10236-MAS10042,Lane holding warn. syst.-Time to lane crossing,3.1, s
IDE10236-MAS10043,Lane holding warn. syst.-Vehicle side,Left,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System status,System off,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,-120.00, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,0.00, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,-120.00, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,0.00, m
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,0.00, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,0.00, m/s
Elapsed Time: 00:08
blockmap-42-5Q4-959-593-K_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:TSG FS        007 0485, Coding:003E13200000040000000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHKLO.rod
;Thursday,18,June,2020,10:52:14:14741
;VCID: CDCC827E4D52073368D-8098
IDE00310,Outside air temperature,24.00, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.20, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.50, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-install,not installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,100, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,not activated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,4620,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,14.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,35, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,43, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not installed,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote release button,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,96, %
ENG117315-ENG32834,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
blockmap-44-5QN-909-144-B_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:EPS_MQB_ZFLS  507 5082, Coding:811F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Thursday,18,June,2020,10:52:25:14741
;VCID: D1F49E0E516A23D30C5-8084
IDE00018,Voltage terminal 15,14.55, V
IDE00019,Voltage terminal 30,14.46, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,789, /min
IDE00102,Control Module temperature,32.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,1A,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,A0,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,71,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,18,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,Function cannot be performed,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,31.999, Nm
IDE02006-MAS03095,Lane assistant-Function status,not activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,23.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,-15, /min
IDE03682-MAS02961,Sensor for motor position-Engine angle,32.8, °
IDE03682-MAS03083,Sensor for motor position-Cosine signal,2.264, V
IDE03682-MAS03211,Sensor for motor position-Sine signal,0.731, V
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,Unknown (3),
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,4095.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,4094.3, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,-0.110, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,-0.110, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-0.4, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-0.4, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,-0.019, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,14.53, V
IDE04187,Steering torque: raw value 1,-17.969, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-82.031, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,-17.969, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-82.031, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.41, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.40, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.38, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.3, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.1, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,-0.1, A
IDE04194,Steering assistance: electromotor power,-0.91, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,1.3, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-0.8, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.85, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.26, mm
IDE04460,Steering angle sensor: offset straight line running,0.7, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.68, mm
IDE05162-MAS01850,Software end stop-Right,-80.16, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,952,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,969,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,367,
IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,367,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,20954,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,5,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,12,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,12,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,969,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,2,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00106,Standard - ambient data 1-Year,2011,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,5,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,11,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38, km
MAS00976-IDE80003,Counter-Analysis 3,3656103925,
MAS00976-IDE80004,Counter-Analysis 4,87572,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,32.0, °C
ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,87572,
ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,0,
ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,3656103925,
ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG37819-ENG102605,Strain_detection-outside_temperature,24.0, °C
ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,3, /min
ENG37819-ENG26208,Strain_detection-Steering_angle,1.4, °
ENG37819-ENG37919,Strain_detection-steering_moment,-0.110, Nm
ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,-0.017, Nm
ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000006577, %
Elapsed Time: 00:07
blockmap-4B-3Q0-907-338-E_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:FCM MQB Low   003 0367, Coding:000000050900214A01110300040000000000000000000000000000000000
;EV_MultiModulContiVW48X,003003,EV_MultiModulContiVW48X_003_VW27.rod
;Thursday,18,June,2020,10:52:35:14741
;VCID: B720C096DFCE9DE3221-80E2
IDE00019,Voltage terminal 30,14.3, V
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,1.30, °
IDE01714,Status reverse gear,OFF,
IDE01717-ENG30211,Processor load-Software_component_AFS_MXB,14, %
IDE01717-ENG30223,Processor load-Total_system_FCM,28, %
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,6126, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,38.00, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-1.6, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03624,Left dynamic AFS light motor: specified value,0.000000, °
IDE03625,Right dynamic AFS light motor: specified value,0.000000, °
IDE03626,Left dynamic AFS light motor: status,no error,
IDE03627,Right dynamic AFS light motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,no error,
IDE03629,Adjusting motor for variable right front lighting: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,-7.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-7.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.0, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Light distribution status,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),38.40, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Left rear seat backrest fan 1,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Right rear seat backrest fan 1,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Right rear seat cushion fan 1,not installed,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of first warning,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of second warning,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of third warning,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2020,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,6,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,18,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,22,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,45,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,36,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,87,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2020,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,6,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,18,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,22,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,45,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,36,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,87,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2020,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,6,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,18,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,22,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,45,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,36,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,87,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2011,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,1,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,1,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,0,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,36,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,4,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,1,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,-0.031250, °
ENG26446-ENG30212,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0170,
ENG26446-ENG30225,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7200,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,-0.031250, °
Elapsed Time: 00:10
blockmap-52-5Q4-959-592-K_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:TSG BFS       007 0485, Coding:003E13200000040000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHKLO.rod
;Thursday,18,June,2020,10:52:48:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: CCCA8F7AB6480E3B7F3-8098
Group,Description,Actual
IDE00310,Outside air temperature,24.50, °C
IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear passenger side door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.20, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.60, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,4620,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,35, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,43, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,14.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
ENG117316-ENG32834,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:07
blockmap-5F-2GM-035-844-A_3VW6T7AU8LM010575-20200618-1052.CSV
;Component:MU-S-S-US     725 0520, Coding:02731000BE00000041220001001808009F0503D40120050002
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Thursday,18,June,2020,10:52:58:14741
;VCID: BFD0A8B6F7FEA5A3EA1-80EA
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,789.00, /min
IDE00668-MAS03231,Microphone current consumption-Microphone 1,6.00, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Condition not met,
IDE00916-IDE02128,Speaker status-Right front speaker,Condition not met,
IDE00916-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE00916-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,084°06'41.76"W,
IDE01712-MAS01780,GPS Position-Width,035°54'20.29"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,28,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,29,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,62, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,47, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,52, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,45, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,1,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,54, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,FF FB,
IDE03477-MAS00106,GPS time-Year,2020,
IDE03477-MAS00107,GPS time-Month,6,
IDE03477-MAS00108,GPS time-Day,18,
IDE03477-MAS00109,GPS time-Hours,14,
IDE03477-MAS00110,GPS time-Minutes,53,
IDE03477-MAS00111,GPS time-Seconds,1,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,FF,
IDE03880-MAS03425,MOST address-Physical address,FF FF,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,7, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,5, H
IDE04317-MAS00110,Total system run time-Minutes,44, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04547,Traffic information,OFF,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.3, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,4140, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,58 16 D7 48 0D 01,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05536-MAS01632,GPS almanac-Status,invalid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,00 00 00 00 00 00,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,--
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),00 00,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),00 00,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,--
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,--
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,00 00,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,00 00,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,00 00,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,00 00,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,00 00,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,00 00,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,00 00,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,00 00,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,00 00,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,00 00,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,00 00,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,00 00,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,00 00,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,00 00,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,00 00,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,00 00,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,00 00,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,99.94, %
IDE05814,Individualization characteristic,C4 EB FC 53 D9,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,1,
IDE06028-MAS04414,Control head button operation-Volume control,-1,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,19,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,01-00-01---,
IDE11034-MAS11961,Satellite radio: module information-Serial number,7GKCYAWH,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 08 00 37 47 4B 43 59 41 57 48 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 11 88 C3 2E DA D6 C0 2B 5B 41 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,0b-26-00---,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,02-04-04---,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,03-05-00---,
IDE11034-MAS11966,Satellite radio: module information-Database Version,02-04-04--A,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
MAS00464-MAS00108,Standard - ambient data 1-Day,29,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,6,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,4, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,44, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,14.6, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,70, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,51, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,98.7, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,48, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,46, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,46, dBµV
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS03121,Ring break diagnostic line status,Not available,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,0, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,0, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,0, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,0, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,0, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,0, s
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,not_subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,not_subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2034,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,31,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,63,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,63,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,0,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG127487-IDE02451,SDARS_tuner_status_2-Satellite radio antenna status,Electrical OK,
ENG127487-IDE02453,SDARS_tuner_status_2-Channel selection for satellite radio,45,
ENG127487-MAS01765,SDARS_tuner_status_2-Audio Signal,Available,
ENG127487-MAS01808,SDARS_tuner_status_2-Antenna current,111, mA
ENG127487-MAS02573,SDARS_tuner_status_2-Reception quality,optimum_signal,
ENG127487-MAS13343,SDARS_tuner_status_2-Satellite radio tuner: pre-activation status,05,
ENG127487-MAS13344,SDARS_tuner_status_2-Satellite radio tuner: pre-activation value,05,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,not activated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,25344,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,13057,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,60, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,0, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,40, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,52, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,0, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,29, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,60, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,0, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,39, °C
Elapsed Time: 00:31
blockmap-75-5WA-035-283_3VW6T7AU8LM010575-20200618-1053.CSV
;Component:OCUGen3Low    H10 0295, Coding:0237002019682C008005461160000607
;EV_OCUGen3Low,002036,EV_OCUGen3Low_002_VW37.rod
;Thursday,18,June,2020,10:53:32:14741
;VCID: 82566142C48C084BC5F-80D6
IDE00019,Voltage terminal 30,14.5, V
IDE00102,Control Module temperature,38, °C
IDE00608,Type of fuel,Petrol,
IDE00667-MAS03231,Microphone status-Microphone 1,Electrical OK,
IDE00667-MAS03232,Microphone status-Microphone 2,Not available,
IDE00668-MAS03231,Microphone current consumption-Microphone 1,6.0, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,0.0, mA
IDE00672,Roadside Assistance Button,not activated,
IDE00673,Information Service Button,not activated,
IDE00767,No. of unscheduled ECU resets,1,
IDE01215,Terminal 58d dimmer,Measured value not available,
IDE01216,Terminal 58s dimmer,100, %
IDE01588,Driving direction,128, °
IDE01588-MAS01632,Driving direction-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Button lighting in control unit for phone-Actuation time,0 s,
IDE01630-ENG39349,Button lighting in control unit for phone-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG39349,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,84°6'41.7"W,
IDE01712-MAS01780,GPS Position-Width,35°54'20.0"N,
IDE01712-MAS02230,GPS Position-Height,286, m
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,26, mA
IDE01971,Lowest recorded control module temperature,2, °C
IDE01972,Highest recorded control module temperature,60, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,62, %
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,7,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,8,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,11,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,53, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,51, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,44, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,52, dBµV
IDE03477-MAS00111,GPS time-Seconds,29,
IDE04293,Operating state for emer call module,registerstate_registered,
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03878,SIM cards-SIM IMSI,311480947887369,
IDE04750-MAS04226,SIM cards-Telephone number,               ,
IDE04750-MAS08401,SIM cards-SIM intern,operational,
IDE04750-MAS08402,SIM cards-SIM extern,Unknown,
IDE04750-MAS11003,SIM cards-ICCID,89148000005845139039,
IDE04750-MAS11004,SIM cards-UICCID,89033023312150000000000605215408,
IDE04790,Call for help button,not activated,
IDE05430,Telephone serial number,015278001146252,
IDE05431-MAS01167,Locking for H-V charge plug-Actuation time,0 s,
IDE05431-ENG39349,Locking for H-V charge plug-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,A/C heater function via remote control-Actuation time,0 s,
IDE07007-ENG39349,A/C heater function via remote control-IoReached Status,Output diagnostic test not active,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2020,
IDE07589-MAS00107,Update programming: status-Month,2,
IDE07589-MAS00108,Update programming: status-Day,21,
IDE07589-MAS00109,Update programming: status-Hours,13,
IDE07589-MAS00110,Update programming: status-Minutes,33,
IDE07589-MAS00111,Update programming: status-Seconds,24,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG39349,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charge function of H-V battery-Actuation time,0 s,
IDE07975-ENG39349,Remote control for charge function of H-V battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG39349,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 07 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,C9 6A 8E 92,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,62, %
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge condition,85, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG39349,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VW6T7AU8LM010575,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2011, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,1, mon
IDE13957-MAS00108,Mobile Online Service: connection status-Day,26, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,21, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,35, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,54, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2020, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),3, mon
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),18, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),12, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),23, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),20, s
IDE13957-ENG20907,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, mon
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,Not available,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, mon
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, mon
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG115012,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG115183,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG115048,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG115207,Mobile Online Service: service status-status_second_last_ok,65535,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,07,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2011,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,21,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,977, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,147,
MAS03615-MAS01167,Establishing a connection-Actuation time,0 s,
MAS03615-ENG39349,Establishing a connection-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country code for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,62, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,41728790,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,Electrical OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG39349,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,33 s,
MAS16678-ENG39349,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG39349,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,0250,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest#              ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
ENG123206,Antenna_Switch,LTE antenna 1,
ENG123492-ENG124418,Backup_Battery_SoH-BUB_ci,1117723034,
ENG123492-ENG124985,Backup_Battery_SoH-mcharge_time,0, s
ENG123492-ENG125013,Backup_Battery_SoH-mSoH,100,
ENG123492-ENG125230,Backup_Battery_SoH-rSoH,100,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.100.101.195,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,8224,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,8224,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4294967295, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,8224,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,no error,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,8224,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,12601,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,65535,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,65535,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,65535,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,65535,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,8224,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,12590,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,8447,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,13603,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,8224,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,65535, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,ERROR,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,808333616, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,65535,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333616, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,no error,
ENG114618,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG116737,Position_Confidence,36, m
ENG26349-MAS04460,Scan_Network_List-Validity,valid,
ENG26349-MAS04460,Scan_Network_List-Validity,invalid,
ENG26349-MAS08406,Scan_Network_List-Network type,LTE,
ENG26349-MAS08406,Scan_Network_List-Network type,GSM,
ENG26349-MAS08406,Scan_Network_List-Network type,UMTS,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,310,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,311,
ENG26349-ENG28580,Scan_Network_List-Mobile_Country_Code,313,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,410,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,260,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,480,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,589,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,580,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,100,
ENG26349-ENG28688,Scan_Network_List-Mobile_Network_Code,490,
ENG116740-ENG28257,Second_Last_Position-Latitude,--------------,
ENG116740-ENG28256,Second_Last_Position-Longitude,--------------,
ENG116750-ENG28257,Third_Last_Position-Latitude,--------------,
ENG116750-ENG28256,Third_Last_Position-Longitude,--------------,
ENG123779-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG123779-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG123779-MAS02230,VTT_First_GPS_fix-Height,3466, m
ENG123780,VTT_Last_SMS_Content,2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 00:46
blockmap-A9-5G0-907-159-G_3VW6T7AU8LM010575-20200618-1054.CSV
;Component:SAS-GEN 2     H07 0001, Coding:
;EV_SoundActuaGen2AU64X,003010,EV_SoundActuaGen2AU64X.rod
;Thursday,18,June,2020,10:54:20:14741
;VCID: B236F18234AC78CB15F-80E6
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
Elapsed Time: 00:00
blockmap-D6-7P5-941-572-A_3VW6T7AU8LM010575-20200618-1054.CSV
;Component:LED1L         H06 0002, Coding:
;EV_LEDMinMaxL_KEBODAVW481,001003,EV_LEDMinMaxL_KEBODAVW481.rod
;Thursday,18,June,2020,10:54:25:14741
;VCID: B924C6AEE9DA8B93D45-80EC
IDE00325,Diagnostic mode,Extended Session,
IDE00767-ENG14124,No. of unscheduled ECU resets-Test_Program_Watchdog_reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,14.4, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.6, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,0.0, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,0.0, V
IDE03680-ENG35973,Supply voltages-Supply_for_daytime_running_light,0.0, V
IDE03680-ENG35974,Supply voltages-Supply_for_logic,14.4, V
IDE06926-ENG28625,History memory: reset counter-reset_reason,Unknown (1),
IDE06926-ENG08623,History memory: reset counter-Timestamp,0B 04 1D 00 07,
IDE08742-MAS02946,Operating time-static AFS light,0.00, H
IDE08742-MAS07243,Operating time-Low beam,0.92, H
IDE08742-MAS07249,Operating time-High Beam,0.00, H
IDE08742-MAS09325,Operating time-Daytime running lights,0.00, H
IDE08742-ENG28624,Operating time-all_weather_light,0.00, H
IDE08742-ENG28616,Operating time-Control_module,3.50, H
IDE08742-ENG28502,Operating time-Motorway_light,9.43, H
IDE08742-ENG28679,Operating time-Tourist_light,0.00, H
IDE09774-MAS02946,Number of activations-static AFS light,14,
IDE09774-MAS07243,Number of activations-Low beam,18,
IDE09774-MAS07249,Number of activations-High Beam,6,
IDE09774-MAS09325,Number of activations-Daytime running lights,0,
IDE09774-ENG28624,Number of activations-all_weather_light,0,
IDE09774-ENG28914,Number of activations-High_beam_excess_temperature,0,
IDE09774-ENG28912,Number of activations-High_beam_excess_temperature_protection,0,
IDE09774-ENG28913,Number of activations-Low_beam_excess_temperature,0,
IDE09774-ENG28911,Number of activations-Low_beam_excess_temperature_protection,0,
IDE09774-ENG28502,Number of activations-Motorway_light,0,
IDE09774-ENG28679,Number of activations-Tourist_light,0,
IDE09828-ENG28616,Head lamp variant-Control_module,E0 76,
IDE09828-ENG11304,Head lamp variant-via_CAN,E0 76,
IDE10048-IDE09768,Supply information-LED channel 1,Not Used,
IDE10048-IDE09769,Supply information-LED channel 2,Terminal 15,
IDE10048-MAS01968,Supply information-Fan,Terminal 15,
IDE10048-MAS09754,Supply information-LED channel 3,Not Used,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal 15,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-ENG30205,Supply information-Highside_channel 1,Terminal 15,
IDE10048-ENG30206,Supply information-Highside_channel 2,Not Used,
IDE10048-ENG30207,Supply information-Highside_channel 3,Terminal 15,
IDE10048-ENG30208,Supply information-Highside_channel 4,Terminal 15,
IDE10165-IDE10205,LED channel 1: Master 1-Control module version,Max,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,42, °C
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,100.0, %
IDE10165-ENG35975,LED channel 1: Master 1-LED_brightness_class,4,
IDE10167-IDE10205,LED channel 1: Slave-Control module version,not defined,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,-50, °C
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,100.0, %
IDE10167-ENG35975,LED channel 1: Slave-LED_brightness_class,4,
IDE10168-IDE10205,LED channel 2: Master-Control module version,MXB 8,
IDE10168-MAS02201,LED channel 2: Master-Temperature,46, °C
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-ENG35975,LED channel 2: Master-LED_brightness_class,2,
IDE10169-IDE10205,LED channel 2: Slave-Control module version,not defined,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,-50, °C
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS09022,LED channel 2: Slave-PWM value,100.0, %
IDE10169-ENG35975,LED channel 2: Slave-LED_brightness_class,4,
IDE10170-IDE10205,LED channel 3: Master-Control module version,MXB Mid,
IDE10170-MAS02201,LED channel 3: Master-Temperature,48, °C
IDE10170-MAS04136,LED channel 3: Master-Current,0, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-ENG35975,LED channel 3: Master-LED_brightness_class,1,
IDE10171-IDE10205,LED channel 3: Slave-Control module version,MXB Mid,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,42, °C
IDE10171-MAS04136,LED channel 3: Slave-Current,0, mA
IDE10171-MAS09022,LED channel 3: Slave-PWM value,100.0, %
IDE10171-ENG35975,LED channel 3: Slave-LED_brightness_class,2,
IDE10173-ENG28909,Operating times in temperature ranges-Between_105C_and_115C,0.00, H
IDE10173-ENG28915,Operating times in temperature ranges-Between_-40C_and_95C,2.00, H
IDE10173-ENG28908,Operating times in temperature ranges-Between_95C_and_105C,0.00, H
IDE10173-ENG28910,Operating times in temperature ranges-Over_115C,0.00, H
IDE10205,Control module version,Max,
IDE10206-IDE10205,Fan for headlight-Control module version,MXB 8,
IDE10282-ENG36147,LED channels: voltages-Channel_1_Master,0.00, V
IDE10282-ENG36226,LED channels: voltages-Channel_1_Slave,0.00, V
IDE10282-ENG36148,LED channels: voltages-Channel_2_Master,0.00, V
IDE10282-ENG36227,LED channels: voltages-Channel_2_Slave,0.00, V
IDE10282-ENG36149,LED channels: voltages-Channel_3_Master,0.00, V
IDE10282-ENG36228,LED channels: voltages-Channel_3_Slave,0.00, V
IDE10864-MAS11562,Control mod. temperatures-Matrix light power output stage,0, °C
IDE10864-ENG35976,Control mod. temperatures-LED_headlamp_power_module,32, °C
MAS00468,Unlearning counter,1,
MAS09756-IDE10205,High side channel-Control module version,not defined,
MAS09756-MAS02526,High side channel-Activation,Channel not used,
MAS09756-MAS09022,High side channel-PWM value,0.0, %
SER00010,Read data,not active,
Elapsed Time: 00:03
blockmap-D7-7P5-941-572-A_3VW6T7AU8LM010575-20200618-1054.CSV
;Component:LED1R         H06 0002, Coding:
;EV_LEDMinMaxR_KEBODAVW481,001003,EV_LEDMinMaxRKEBODVW481.rod
;Thursday,18,June,2020,10:54:30:14741
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
Group,Description,Actual
IDE03680-MAS01468,Supply voltages-Terminal 15,14.3, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.5, V
IDE03680-MAS10129,Supply voltages-Daytime driving light supply,0.0, V
IDE03680-MAS12194,Supply voltages-Supply for logic,14.3, V
IDE08742-MAS01155,Operating time-Control module,3.50, H
IDE08742-MAS02923,Operating time-Highway light,9.43, H
IDE08742-MAS07013,Operating time-All-weather lights,0.00, H
IDE08742-MAS07014,Operating time-Tourist light,0.00, H
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS02946,Number of activations-static AFS light,13,
IDE09774-MAS07013,Number of activations-All-weather lights,0,
IDE09774-MAS07014,Number of activations-Tourist light,0,
IDE09774-MAS10110,Number of activations-Low beam: excessive temp. protect.,0,
IDE09774-MAS10111,Number of activations-Hi beam: excessive temp. protect.,0,
IDE09774-MAS10112,Number of activations-Low beam: excessive temp.,0,
IDE09774-MAS10113,Number of activations-High beam: excessive temp.,0,
IDE09828-MAS00890,Head lamp variant-via CAN,E0 76,
IDE09828-MAS01155,Head lamp variant-Control module,E0 76,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,28, °C
IDE10165-MAS09945,LED channel 1: Master 1-Fan 1: current,outside permissible range,
IDE10165-MAS09946,LED channel 1: Master 1-Fan 2: current,in permissible range,
IDE10165-MAS11628,LED channel 1: Master 1-Fan 1: activation,not installed,
IDE10165-MAS11629,LED channel 1: Master 1-Fan 2: activation,not installed,
IDE10165-ENG98490,LED channel 1: Master 1-Current,0, mA
IDE10165-ENG35975,LED channel 1: Master 1-LED_brightness_class,3,
IDE10167-MAS09945,LED channel 1: Slave-Fan 1: current,in permissible range,
IDE10167-MAS09946,LED channel 1: Slave-Fan 2: current,in permissible range,
IDE10167-MAS11628,LED channel 1: Slave-Fan 1: activation,not installed,
IDE10167-MAS11629,LED channel 1: Slave-Fan 2: activation,not installed,
IDE10167-ENG98490,LED channel 1: Slave-Current,0, mA
IDE10168-MAS02201,LED channel 2: Master-Temperature,32, °C
IDE10168-MAS09945,LED channel 2: Master-Fan 1: current,not installed,
IDE10168-MAS09946,LED channel 2: Master-Fan 2: current,in permissible range,
IDE10168-MAS11628,LED channel 2: Master-Fan 1: activation,not installed,
IDE10168-MAS11629,LED channel 2: Master-Fan 2: activation,not installed,
IDE10168-ENG98490,LED channel 2: Master-Current,0, mA
IDE10168-ENG35975,LED channel 2: Master-LED_brightness_class,1,
IDE10169-MAS09945,LED channel 2: Slave-Fan 1: current,in permissible range,
IDE10169-MAS09946,LED channel 2: Slave-Fan 2: current,in permissible range,
IDE10169-MAS11628,LED channel 2: Slave-Fan 1: activation,not installed,
IDE10169-MAS11629,LED channel 2: Slave-Fan 2: activation,not installed,
IDE10169-ENG98490,LED channel 2: Slave-Current,0, mA
IDE10170-MAS02201,LED channel 3: Master-Temperature,34, °C
IDE10170-MAS09945,LED channel 3: Master-Fan 1: current,Init,
IDE10170-MAS09946,LED channel 3: Master-Fan 2: current,in permissible range,
IDE10170-MAS11628,LED channel 3: Master-Fan 1: activation,not installed,
IDE10170-MAS11629,LED channel 3: Master-Fan 2: activation,not installed,
IDE10170-ENG98490,LED channel 3: Master-Current,0, mA
IDE10170-ENG35975,LED channel 3: Master-LED_brightness_class,2,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,28, °C
IDE10171-MAS09945,LED channel 3: Slave-Fan 1: current,Init,
IDE10171-MAS09946,LED channel 3: Slave-Fan 2: current,in permissible range,
IDE10171-MAS11628,LED channel 3: Slave-Fan 1: activation,not installed,
IDE10171-MAS11629,LED channel 3: Slave-Fan 2: activation,not installed,
IDE10171-ENG98490,LED channel 3: Slave-Current,0, mA
IDE10173-MAS09336,Operating times in temperature ranges-°C,0.00, H
IDE10173-MAS09337,Operating times in temperature ranges-between 105°C and 115°C,0.00, H
IDE10173-MAS09338,Operating times in temperature ranges-over 115°C,0.00, H
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,2.00, H
IDE10205-MAS09945,Control module version-Fan 1: current,outside permissible range,
IDE10205-MAS09946,Control module version-Fan 2: current,in permissible range,
IDE10205-MAS11628,Control module version-Fan 1: activation,not installed,
IDE10205-MAS11629,Control module version-Fan 2: activation,not installed,
IDE10206-MAS09945,Fan for headlight-Fan 1: current,not installed,
IDE10206-MAS09946,Fan for headlight-Fan 2: current,not installed,
IDE10206-MAS11628,Fan for headlight-Fan 1: activation,not installed,
IDE10206-MAS11629,Fan for headlight-Fan 2: activation,not installed,
IDE10864-MAS11561,Control mod. temperatures-Power output stage for LED,27, °C
MAS09756-MAS09945,High side channel-Fan 1: current,in permissible range,
MAS09756-MAS09946,High side channel-Fan 2: current,in permissible range,
MAS09756-MAS11628,High side channel-Fan 1: activation,with low beam,
MAS09756-MAS11629,High side channel-Fan 2: activation,not installed,
MAS09756-ENG98345,High side channel-Activation,Channel not used,
Elapsed Time: 00:03
blockmap-OBD_3VW6T7AU8LM010575-20200618-1054.CSV
;Thursday,18,June,2020,10:54:36:14741
04,Calculated load value,17.3 %
05,Engine coolant temperature,97 °C
0C,Engine RPM,795 /min
0D,Vehicle speed,0 km/h
21,Distance travelled with MIL on,0 km
23,Fuel Rail Press (rel),11280 kPa rel
2E,Commanded Evaporative Purge,8.2 %
2F,Fuel Level Input,98.8 %
30,Warm-ups since DTC cleared,1
31,Distance since DTC cleared,26 km
33,Barometric pressure,98 kPa abs
34,Bank 1 Sensor 1 Status,0.992 Lambda,-0.020 mA
3C,B1S1 Cat. Temp.,329.9 °C
42,Control module voltage,14.472 V,14.400 V
43,Absolute Load Value,26 %
44,Commanded Equivalence Ratio,0.992 Lambda
45,Relative Throttle Position,2 %
46,Ambient Air Temp,24 °C
47,Absolute Throttle Position B,13 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,2 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.8 %
62,Torque actual,12 %
63,Torque Reference,350 Nm
65,Auxiliary Input/Output,
70,Boost Press Ctrl A/B,BP_A act:99 kPa
Type 02 - VIN : 3VW6T7AU8LM010575 (Address E8)
Type 04 - Calibration ID : 5G0259Q 0005BXAJ (Address E8)
Type 04 - Calibration ID : 0GC300020G  2404 (Address E9)
Type 06 - Calibration Verification Number : 2620F768 (Address E8)
Type 06 - Calibration Verification Number : 7D6B3C51 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1
    Ignition cycle count : 77
         Catalyst monitor bank 1 : 0 / 1
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 1 / 1
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 7 / 1
         AIR monitor : 9 / 0
         EVAP monitor : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Bump for updated version 0.7 of the Alligator; link in post #1 of this thread.
From @Sage :
limits how much it tries to eat in one go. It will break down outputs larger than ~10k lines of text. The user will select each segment via drop down located next to the Copy button. The drop down will only appear when necessary to avoid any confusion.
NEtech
Denmark
C?ID=56995
It is nice and easy to post, but what about copy all to single files again, that takes a very long time.
It is much easier to post and especially copy, if it is an zipped file.
If I try 0.7 on this scanned car, error "Could not validate VIN" comes up.
Bump for updated version 0.8 of the Alligator; link in post #1 of this thread.
From @Sage
A new update is ready for the Alligator. You can now select the folder the Gator will search for Map files. There is also a link to the Forum post made by Jef so users can check that out as a quick help guide. More bug fixes have been made and the topic of different language support has come up.
I believe this can easily support other languages but I would need examples of Autoscans in different languages to make sure there isn't some weird mumbo jumbo that is unique to that specific language. As of now, this only works for versions of VCDS that generate an Autoscan in English.
I think I found a minor "anomaly" in 0.8:
If you have a set of MV maps that needs to be split into two parts, it does it as advertised.
But then if you check Adaptations from the same scan and they aren't big enough to need to be split, it still acts as though they are. Message box informing you remain, as does the drop-down, but the drop-down only lets you choose '1'.
Jef
HQ
Duplicated. Emailing Sage with info and tweak request.
Pro-Tip: Pasting of a large batch of maps (many thousands of lines) into the forum editor is substantially faster if you toggle the editor into BB code mode first (where all editor menu items except the gear are inactive) vs the very long time it can take when it's in WYSIWYG mode (where all the menu items are active).
