Yet Another ABS issue Audi A5 2008 3.0tdi
Wk4522
London, UK
Hi all,
Wondering if anyone can help me with the weirdest abs issue i am having.
Abs/esp/parking brake malfuntion with associated lights on dashboard, speedo does not work sometimes and usually kicks in and out when doing a full lock or on hard acceleratiom buy abs lights remain.
VCDS has no communication with abs unit, a few times life has come back to the abs unit and lights turn off and vcds can read codes, this happens very randomly
So far the following i have done.
1. Checked wiring on abs plug three main power wires and ground all working no breaks and have 12v battery power or there abouts (11.8v)
2. Wiring checked on passenger wing for breaks all is fine.
3. Used abs pump plugged in to see if pump ecu issue (connector plugged in only not plummed in properly just to rule it out), still no communication, i have tried 2 abs pumps so it cant be the pump
4. Used a test light to check load, this is where it gets interesting, when test light is plugged in to any of the power wires going to the abs plug the voltage drops to 0v, take the test light off and u have 12v again. So at this point i thought must be resistance in the wires but this didnt make sense since its present in all 3 power wires unless they are linked somewhere ?
5. I plugged in the used abs unit and hard wired the power cables to the positive on the battery with a fuse, ignition on and all is fine and i can connecr vcds
Absolutely stumped by the issue as u can see i have tried alot to investigate but cant seem to see what would cause this ?
Vcds abs controller codes:
00446 - function limitation due to under voltage
002 - lower limit exceeded
U0121 - no communication with abs module
MartinsX
Riga, Latvia
C?ID=268515
1. Post an autoscan.
2. Do You have WD?
Wk4522
London, UK
Sure just got vcds sorted today will post scan later.
What does WD mean ?
South Molton, UK
What does WD mean ?
See how WD is bold green and underlined? Hover your mouse over any acronym like that on here and a popup will appear with an explanation.
Wk4522
London, UK
See below wiring diagram from elsawin not sure if i looked in correct place but 3 wires on top are power and two highlighted at bottom are ground, all show 12v after fitting new battery today
auto scan also below: note headlights are not plugged in so hence those errors, also a previous accident damaged car hence the airbag codes - airbag light on, i think just needs seatbelts for this.
Saturday,17,October,2020,17:32:21:00009
VCDS Version: 20.4.1.0
VIN: WAUZZZ8T38A007821   License Plate: SK AFTER
Mileage: 137430km-85395mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56
VIN: WAUZZZ8T38A007821   Mileage: 137430km-85395miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401     HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0008
   Revision: --H01---
   Coding: 01140023180F0018
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30LTDIA5 A01009
   ROD: EV_ECM30LTDIA5_A01.rod
   VCID: 68DF0DA79373D2C6A3-803C
8 Faults Found:
7136 - No Communication with ABS Brake Control Module
          U0121 00 [039] - -
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
                    Engine speed: 0.00 /min
                    Vehicle speed: 254 km/h
                    Coolant temperature: 15 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.940 V
                    Engine speed: 0.0 /min
                    Vehicle speed: 5.00 km/h
                    Accelerator position: 0.00 %
                    Vehicle voltage terminal 30: 11940 mV
                    Bus Diag st Node 0-Bits 0-7: 00000000
                    Com ct Rx TO GW-Bits 0-7: 00000000
                    Cr C st Key 0-Bits 0-7: 00000000
                    Cr C st Key 0-Bits 0-7: 00000001
4984 - Glowplug for Cylinder 1 (Q10)
          P161A 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Engine speed: 785.50 /min
                    Normed load value: 27.8 %
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.560 V
                    Engine speed: 785.5 /min
                    Vehicle voltage terminal 30: 13560 mV
                    Coolant temperature: 15.8 °C
                    Preheating system status-Bits 0-7: 00000000
                    Preheating system status-Bits 0-7: 10110000
                    Glw Plg r LVS Ps: 23.99 %
                    Intake air temperature: 12.4 °C
4985 - Glowplug for Cylinder 2 (Q11)
          P161B 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
4986 - Glowplug for Cylinder 3 (Q12)
          P161C 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
4987 - Glowplug for Cylinder 4 (Q13)
          P161D 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
5417 - Glowplug for Cylinder 5 (Q15)
          P161E 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
5418 - Glowplug for Cylinder 6 (Q15)
          P161F 00 [039] - Open Circuit
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
4713 - No Communication with ABS Brake Control Module
          U0121 00 [167] - -
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Voltage terminal 30: 11.960 V
                    Vehicle voltage terminal 30: 11960 mV
                    Com ct Rx TO BRK-Bits 0-7: 00001000
Address 03: ABS Brakes
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H37 0238
   Coding: 031000
   VCID: 397998E3B0599B4E0C-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H34 0050
   Serial number: 0107000093035012
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H34 0039
   Serial number: 0207000000283014
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001016282
   Coding: 08217025002444441000
   VCID: 55A134533C015F2E08-8000
   Part No SW: 8T2 820 043 G    HW: 8T2 820 043 G
   Component: KLIMA 3 ZONEN H04 0093
   Revision: D0000000    Serial number: 0111.07.070010
   Coding: 36060000
   VCID: 366393DF81477436E1-8062
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
03037 - Rear Temperature Selection Potentiometer (G538)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Voltage: 12.00 V
                    Voltage: 5.00 V
00713 - Centre Left Vent Positioning Motor (V110)
                    Fault Status: 00100001
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:27
                    Voltage: 12.10 V
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Count: 14252
                    Count: 14601
   Part No SW: 8K0 907 279 C    HW: 8K0 907 279 C
   Component: BCM1 1.0      H19 0141
   Revision: 04019001    Serial number: 00000000027436
   Coding: 260010110004AF010009000000005D5D001D030800010141000000
   Shop #: WSC 00001 899 00001
   VCID: 387F9DE78B538246F3-806C
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280607  H11 0040
   Serial number: SWFBIE 0000183
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10009801
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002106070132
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Status: 00101100
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
03205 - Control Circuit / Actuator for Left Low-Beam Shutter
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:00
00042 - Left Parking Light Lamp (M43)
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:00
00043 - Right Parking Light Lamp (M44)
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130719002289
   VCID: 76E353DFC1C7343621-8022
   Part No SW: 8K0 959 655     HW: 8K0 959 655
   Component: AirbagVW-AU10 H21 0334
   Serial number: 0038GD084DWB
   Coding: 30323232333030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 7AFB47EFFDDF505645-802E
   Serial number: 6334LSME1975271DH
   Serial number: 6344LSME19754647G
   Serial number: 6352QSME335716259
   Serial number: 6362QSME2B54531FO
   Serial number: 63834SME3301364BX
10 Faults Found:
          B1006 1B [137] - Resistance Too High
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:44
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
13636864 - Control Module for ABS Brakes
          U1015 00 [009] - No Communications
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
   Part No SW: 8K0 953 568 B    HW: 8K0 953 568 B
   Component: Lenks.Modul   H09 0011
   Revision: --------    Serial number: 90304GFU0003H
   Coding: 000012
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
02085 - Incorrect Control Module Installed
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:43
                    (no units): 44.0
                    Text: 2C8AFFFFFFFF00C0FF
                    Knock Sensor: 65.025 V
                    Raw, Index/Key Err.: 255 255 000
   Part No SW: 8T0 920 980 M    HW: 8T0 920 980 M
   Component: KOMBIINSTR.   H20 0136
   Revision: 00500000    Serial number: 6C1109677
   Coding: 2305010002002600010000
   Shop #: WSC 06325 123 12345
   VCID: 4581E413CCA1EFAE78-8010
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G076058106
   Coding: 000003
   Shop #: WSC 00481 210 83225
   VCID: 428BFF0FDD8FD8965D-8016
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0120
   Serial number: 17002275120607
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001016294
   Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
   Component: TSG FA        H09 0146
   Revision:             Serial number: 0Ee`
   Coding: 0110022240012201
   VCID: 3E738BFFA977BC7639-806A
   Revision: 00002001    Serial number: 0105139270
   Coding: 011B0682003A0440002000
   Component: DWA-Sensor  H02 0030
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Fault Status: 11100100
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:56:51
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:56:58
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223     HW: 8T0 035 223
   Component: DSP STD       H07 0200
   Revision: 16S00000
   Coding: 0203010101
   VCID: 6BD572AB8A85F9DECE-803E
00417 - Left Front DSP Mid-Bass Speaker (R101)
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:48
                    Voltage: 13.80 V
                    Temperature: 15.0°C
                    Bin. Bits: 00000001
   Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
   Component: TSG BF        H09 0146
   Revision:             Serial number: 0eg`
   Coding: 0110022244012201
   VCID: 3D718CF3A471A76E20-8068
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000012247
   VCID: 2F6DA6BB7E1D45FEA2-807A
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Voltage: 12.10 V
                    Count: 65
                    Hex Value: 0x0273
                    Hex Value: 0x0081
                    Hex Value: 0x1010
   Part No: 8K0 907 357 D
   Coding: 0000002
   VCID: 366393DF41477436E1-8062
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Fault Status: 00101010
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 A    HW: 8T1 035 195 A
   Component: Symphony3     H03 0050
   Revision: 00000000    Serial number: 12345678901234
   Coding: 0102008001040D0003DB070000
   VCID: 356194D39C417F2EE8-8060
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
00625 - Vehicle Speed Signal
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:15
End-------------------------(Elapsed Time: 03:03)--------------------------
Wk4522
London, UK
Also every now and then i loose the accelerator pedal - like it does nothing when i press it.
really need this sorted such a shame when i bought the car recently it had no issues then all of this has come out of nowhere and i am absolutely gutted
Wk4522
London, UK
also forgot to add once i do get access to the abs module by forcing power to it the following code is displayed see below image. It makes sense thre seems to be something stopping the voltage getting to the abs unit when the abs unit requests power which falls in line with my test light testWhatsApp Image 2020-10-17 at 18.58.28.jpeg
Please elaborate what exactly you're doing when you "get access .. by forcing power to it".
Wk4522
London, UK
Ahh right - there are 3 main power cables to the abs unit, and no communication suggests no power to the ecu, wiring and all other checks showed okay, apart from the test light test
so i connected the 3 power cables from the abs plug wiring direct to the positive on the battery under the bonnet with a fuse in between. tested with my test light on the pins in the plug for abs unit and the test light lit up suggesting power is now there under load. then i plugged abs unit in and put the ignition on, all lights off and vcds can connect to the abs module and read codes etc.... hence why i am really confused as to what is going on
MartinsX
Riga, Latvia
C?ID=268515
   Revision: --H01---
8 Faults Found:
          U0121 00 [039] - -
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:51
          U0121 00 [167] - -
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
   Coding: 031000
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
   Coding: 36060000
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Voltage: 12.00 V
                    Voltage: 5.00 V
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:27
                    Voltage: 12.10 V
                    Temperature: 11.0°C
                    Temperature: 11.0°C
                    Count: 14252
                    Count: 14601
   Coding: 00FD11
   Coding: 02532C
9 Faults Found:
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:57:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
            014 - Defective
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:00
10 Faults Found:
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:44
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:12
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
   Coding: 000012
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:43
                    (no units): 44.0
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
   Coding: 000003
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:09
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:56:51
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:56:58
   Revision: 16S00000
   Coding: 0203010101
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:29:48
                    Voltage: 13.80 V
                    Temperature: 15.0°C
                    Bin. Bits: 00000001
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Voltage: 12.10 V
                    Count: 65
                    Hex Value: 0x0273
                    Hex Value: 0x0081
                    Hex Value: 0x1010
   Coding: 0000002
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:10
                    Reset counter: 98
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:11
   Component: Display
                    Reset counter: 58
                    Mileage: 137434 km
                    Date: 2007.01.30
                    Time: 00:23:15
As Your location is shown UK, I assume You have a RHD car. So, check with load light is voltage disappearing when load is connected to fuses S123, S134 and S137 directly. If yes, check further WD what is common supply to those fuses. Fault must be somewhere there.
BTW does the car starts? Is the braekeable fuse with pyrotechnics at battery OK? i have seen multiple times that this piece of shit is half-broken after an accident - it allows some voltage to go through, but not with a load...
Wk4522
London, UK
Hi car starts and drives fine abs does not work but apart from that its fine. Those fuses are the 2 metal style fuses on the positive terminal of battery - they are not blown but i will check this with a test light tomorrow and let you know.
Then it sounds to me like the ABS is not being supplied with power via the car's harness for some reason. You'll have to trace it back, figure out why, and fix it. I suggest Load-testing the relevant circuits in the car's harness.
