Q3 F3N 2020 DYF/UDZ retrofits
Stratos858
Athens, Greece
C?ID=420167
I am looking to add some goods on this vehicle.
Traffic Jam, signs recognition could be great as first step.
Anyone to suggest?
Stratos858
Athens, Greece
C?ID=420167
Friday,16,October,2020,19:20:52:54202
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WAUZZZF37L1097826   License Plate:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 23 42 44 4B 52 5F 61 6C 75 A5
          BB BC CC D6 D7
VIN: WAUZZZF37L1097826   Mileage: 5533km-3438miles
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA)       Labels: None
   Part No SW: 05E 906 018 N    HW: 05E 907 309 C
   Component: R4 1.5l TFS   H20 9970
   Revision: 89H20000
   Coding: 0225003223641D0820006000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018N 003007
   ROD: EV_ECM15TFS01105E906018N.rod
   VCID: 3038EF05CAAE682BE23-8064
Readiness: 1110 0001
   Part No SW: 0GC 300 046 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2701
   Revision: 00H06V11
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2D06F671DD9C05C3C95-8078
   Part No SW: 5Q0 614 517 EL    HW: 5QM 614 517
   Component: ESC           H26 0313
   Revision: 00000000    Serial number: 60590000000944
   Coding: 17FF727FA5293B738B7F0E026AC948E84EA5DCD1705612FB18A1F074923D520B00032E64121A03102F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060013
   ROD: EV_Brake1UDSContiMK100OMG_060_VW37.rod
   VCID: 7F5AFC39477047532B9-802A
   Part No SW: 83A 820 043 H    HW: 83A 820 043 H
   Component: AC Automat    H04 0052
   Revision: 20026000    Serial number: 00000000375088
   Coding: 070030040000000110010000000011040000000000000000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU326 001005
   ROD: EV_AirCondiFrontVaAU326.rod
   VCID: 25160E51856C3D83015-8070
   Subsystem 1 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A18D00A500PAG0MUFU04
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H42 0312
   Serial number: 02002006501299
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015E7AC1318431A35DD-8054
   Subsystem 1 - Part No SW: 83B 955 119     HW: 83B 955 119
   Component: J400FRWISCH  063  0050
   Serial number: 890153F0402002303038
   Coding: 5DC72F
   Component: G397_RLFSS  H06  0002
   Serial number: 24418267X81A955555A0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K1 941 501 K    HW: 4K1 941 501 K
   Component: E1 - LTM  H05  0010
   Serial number: 92160SL50006W    10S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 H    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000004032020240783
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058420065
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F88F85AA6E082B823-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 C
   Component: ACCCONTIMQB   H05 0372
   Coding: 5200E78218FF8728747C63448050A700080000000000000044
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 43D2B0C96B18E3B30F1-8016
   Part No SW: 5Q0 959 655 BP    HW: 5Q0 959 655 BP
   Component: AirbagVW21    008 0403
   Serial number: 003FJR679A4E
   Coding: 88FCC0C0002000009C5400DF0048005400C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 0F7A4CF977D057D3DB9-805A
   Subsystem 1 - Part No SW: -----------    HW: 480 002 602 20
   Serial number: 3570000000085D28264K
   Subsystem 2 - Part No SW: -----------    HW: 480 000 403 20
   Serial number: 35800000000572309649
   Subsystem 3 - Part No SW: -----------    HW: 480 400 303 20
   Component: SideSensor_Dr  004 6149
   Serial number: 351000108636FBC5E24A
   Subsystem 4 - Part No SW: -----------    HW: 480 400 303 20
   Component: SideSensor_Pr  004 6149
   Serial number: 35200012E2CA197356D9
   Subsystem 5 - Part No SW: -----------    HW: 480 401 202 20
   Component: FrontSensor_D  002 6149
   Serial number: 35500010A6306705F6A$
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 202 20
   Component: FrontSensor_P  002 6149
   Serial number: 356000132630401300E8
   Part No SW: 83A 920 700 B    HW: 83A 920 700 B
   Component: KOMBI         H02 4192
   Coding: 058411086F8000081180A0401000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001041
   ROD: EV_DashBoardVDDMQBA0_AU37.rod
   VCID: 20181F459A4ED8AB723-8074
   Part No SW: 3Q0 907 530 AN    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5389
   Serial number: 07032011603417
   Coding: 020100041F0810005B10025A1A0B00000001010000000000000003000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 7BA2082953685B73071-802E
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20200106150529 31551
   Subsystem 2 - Part No SW: 5QA 915 181 D    HW: 5QA 915 181 D
   Serial number: 9748354105
   Part No SW: 3Q0 909 059 J    HW: 3Q0 909 059 B
   Component: EBKV          H06 0070
   Serial number: BPA085160220013
   Coding: 4302C504340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW37.rod
   VCID: 3E24C13D00FA8E5B60F-806A
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TB514507
   Coding: 001E0B005000000000001000
   VCID: 49CEA2E1493439E3C5D-801C
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 06032011604232
   Coding: 000000050900196A00102B00020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372AD4192FC0BF13A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TBI13768
   Coding: 001E0B005C00000000001000
   VCID: 48C8A7E5523EC0EBDA3-801C
   Part No SW: 83A 035 064 C    HW: 83A 035 064
   Component: MU-H-LN-EU    056 2711
   Coding: 01231600FF0A000043110001000800102F0002E4017008000E
   ROD: EV_MUHigGen2pALPI_AU37.rod
   VCID: 211E1A419144D1A37DD-8074
   Subsystem 2 - Part No SW: 83A 919 605 C    HW: 83A 919 605 C
   Component: DU AU326 High  H42 0137
   Serial number: MA48X1AEA0281372
   Compact Disc Database:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Serial number: 00004420000020419033
   Media socket:
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 5QF 915 105     HW: 5QF 915 105
   Component: BMS_48V_LiIon H09 0409
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   Coding: 0223160102002001400040
   VCID: 392ED22119D4A96355D-806C
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000002NVRG0
   Coding: 013261101FE820008005460120010000
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_AU37.rod
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1029
   Serial number: E33417011200650
   Coding: 0004088801484024409E00000000000000010000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BC250D04221A3B547-8026
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TB82344A
   Coding: 000E09004000000000001000
   VCID: 4BC298E943482BF3F71-801E
   Component: TSG HBFS004 0330
   Serial number: YE007TB813003
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 F    HW: 05E 903 018 F
   Component: iBSG4U_000    H16 0122
   Serial number: 5200306002347
   ASAM Dataset: EV_SGCM600200005E903018F 002005
   ROD: EV_SGCM600200005E903018F_002.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0031
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 71BE2A0101242123ADD-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
End----------(Elapsed Time: 01:40, VBatt start/end: 12.9V/13.0V)-----------
siLc
Tallinn, Estonia
C?ID=330192
TJA and TSR are features of the module A5 camera. You have newer camera 2Q0980653, for which these things are not too well documented yet AFAIK.
Stratos858
Athens, Greece
C?ID=420167
Thank you. Maybe is worth to try and see.
