2020 Q3 F3N 1.5tfsi DFY/UDZ
Stratos858
Athens, Greece
C?ID=420167
Friday,16,October,2020,19:20:52:54202
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WAUZZZF37L1097826   License Plate:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 23 42 44 4B 52 5F 61 6C 75 A5
          BB BC CC D6 D7
VIN: WAUZZZF37L1097826   Mileage: 5533km-3438miles
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA)       Labels: None
   Part No SW: 05E 906 018 N    HW: 05E 907 309 C
   Component: R4 1.5l TFS   H20 9970
   Revision: 89H20000
   Coding: 0225003223641D0820006000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018N 003007
   ROD: EV_ECM15TFS01105E906018N.rod
   VCID: 3038EF05CAAE682BE23-8064
Readiness: 1110 0001
   Part No SW: 0GC 300 046 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2701
   Revision: 00H06V11
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2D06F671DD9C05C3C95-8078
   Part No SW: 5Q0 614 517 EL    HW: 5QM 614 517
   Component: ESC           H26 0313
   Revision: 00000000    Serial number: 60590000000944
   Coding: 17FF727FA5293B738B7F0E026AC948E84EA5DCD1705612FB18A1F074923D520B00032E64121A03102F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060013
   ROD: EV_Brake1UDSContiMK100OMG_060_VW37.rod
   VCID: 7F5AFC39477047532B9-802A
   Part No SW: 83A 820 043 H    HW: 83A 820 043 H
   Component: AC Automat    H04 0052
   Revision: 20026000    Serial number: 00000000375088
   Coding: 070030040000000110010000000011040000000000000000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU326 001005
   ROD: EV_AirCondiFrontVaAU326.rod
   VCID: 25160E51856C3D83015-8070
   Subsystem 1 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A18D00A500PAG0MUFU04
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H42 0312
   Serial number: 02002006501299
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015E7AC1318431A35DD-8054
   Subsystem 1 - Part No SW: 83B 955 119     HW: 83B 955 119
   Component: J400FRWISCH  063  0050
   Serial number: 890153F0402002303038
   Coding: 5DC72F
   Component: G397_RLFSS  H06  0002
   Serial number: 24418267X81A955555A0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K1 941 501 K    HW: 4K1 941 501 K
   Component: E1 - LTM  H05  0010
   Serial number: 92160SL50006W    10S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 H    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000004032020240783
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058420065
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F88F85AA6E082B823-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 C
   Component: ACCCONTIMQB   H05 0372
   Coding: 5200E78218FF8728747C63448050A700080000000000000044
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 43D2B0C96B18E3B30F1-8016
   Part No SW: 5Q0 959 655 BP    HW: 5Q0 959 655 BP
   Component: AirbagVW21    008 0403
   Serial number: 003FJR679A4E
   Coding: 88FCC0C0002000009C5400DF0048005400C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 0F7A4CF977D057D3DB9-805A
   Subsystem 1 - Part No SW: -----------    HW: 480 002 602 20
   Serial number: 3570000000085D28264K
   Subsystem 2 - Part No SW: -----------    HW: 480 000 403 20
   Serial number: 35800000000572309649
   Subsystem 3 - Part No SW: -----------    HW: 480 400 303 20
   Component: SideSensor_Dr  004 6149
   Serial number: 351000108636FBC5E24A
   Subsystem 4 - Part No SW: -----------    HW: 480 400 303 20
   Component: SideSensor_Pr  004 6149
   Serial number: 35200012E2CA197356D9
   Subsystem 5 - Part No SW: -----------    HW: 480 401 202 20
   Component: FrontSensor_D  002 6149
   Serial number: 35500010A6306705F6A$
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 202 20
   Component: FrontSensor_P  002 6149
   Serial number: 356000132630401300E8
   Part No SW: 83A 920 700 B    HW: 83A 920 700 B
   Component: KOMBI         H02 4192
   Coding: 058411086F8000081180A0401000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001041
   ROD: EV_DashBoardVDDMQBA0_AU37.rod
   VCID: 20181F459A4ED8AB723-8074
   Part No SW: 3Q0 907 530 AN    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5389
   Serial number: 07032011603417
   Coding: 020100041F0810005B10025A1A0B00000001010000000000000003000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 7BA2082953685B73071-802E
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20200106150529 31551
   Subsystem 2 - Part No SW: 5QA 915 181 D    HW: 5QA 915 181 D
   Serial number: 9748354105
   Part No SW: 3Q0 909 059 J    HW: 3Q0 909 059 B
   Component: EBKV          H06 0070
   Serial number: BPA085160220013
   Coding: 4302C504340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW37.rod
   VCID: 3E24C13D00FA8E5B60F-806A
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TB514507
   Coding: 001E0B005000000000001000
   VCID: 49CEA2E1493439E3C5D-801C
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 06032011604232
   Coding: 000000050900196A00102B00020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372AD4192FC0BF13A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TBI13768
   Coding: 001E0B005C00000000001000
   VCID: 48C8A7E5523EC0EBDA3-801C
   Part No SW: 83A 035 064 C    HW: 83A 035 064
   Component: MU-H-LN-EU    056 2711
   Coding: 01231600FF0A000043110001000800102F0002E4017008000E
   ROD: EV_MUHigGen2pALPI_AU37.rod
   VCID: 211E1A419144D1A37DD-8074
   Subsystem 2 - Part No SW: 83A 919 605 C    HW: 83A 919 605 C
   Component: DU AU326 High  H42 0137
   Serial number: MA48X1AEA0281372
   Compact Disc Database:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Serial number: 00004420000020419033
   Media socket:
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 5QF 915 105     HW: 5QF 915 105
   Component: BMS_48V_LiIon H09 0409
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   Coding: 0223160102002001400040
   VCID: 392ED22119D4A96355D-806C
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000002NVRG0
   Coding: 013261101FE820008005460120010000
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_AU37.rod
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1029
   Serial number: E33417011200650
   Coding: 0004088801484024409E00000000000000010000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BC250D04221A3B547-8026
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TB82344A
   Coding: 000E09004000000000001000
   VCID: 4BC298E943482BF3F71-801E
   Component: TSG HBFS004 0330
   Serial number: YE007TB813003
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 F    HW: 05E 903 018 F
   Component: iBSG4U_000    H16 0122
   Serial number: 5200306002347
   ASAM Dataset: EV_SGCM600200005E903018F 002005
   ROD: EV_SGCM600200005E903018F_002.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0031
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 71BE2A0101242123ADD-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
End----------(Elapsed Time: 01:40, VBatt start/end: 12.9V/13.0V)-----------
