Hi Everyone,
Need some help with the my B6 Passat. Originally started as a 1.8tsi.
I have done an engine swap to a 3.2 fsi with DSG gearbox, with 3AA ABS pump, 3AA EPB module, 3AA Parking Brake Switch,
I've coded the ABS pump with 0004772 but still have incorrect coding.
Any help to would be greatly appreciated.
Thursday,01,October,2020,13:02:05:33977
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WVWZZZ3CZ8E185971 License Plate:
Mileage: 142760km-88706mi Repair Order:
Chassis Type: 3C-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 53 56 61 62 72
76 C2
VIN: WVWZZZ3CZ8E185971 Mileage: 142760km-88706miles
76-Park Assist -- Status: Not registered 0011
C2-Auto Trans 2 -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AB HW: 03H 906 032 AB
Component: P3.2-FSI-EU4 G00 0764
Revision: 5GH02--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00028 028 00001
VCID: 6288538ABDCB089665-8036
P1653 - 004 -
Mileage: 142761 km
Date: 2015.02.22
Time: 00:01:46
Temperature: 36.0°C
Temperature: 17.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.573 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 002 - Signal too High
Fault Status: 01100010
Mileage: 142761 km
Date: 2015.02.22
Time: 00:01:48
RPM: 761 /min
Load: 29.0 %
Temperature: 27.0°C
Temperature: 13.0°C
Voltage: 14.097 V
P1653 - 001 -
Fault Status: 01100001
Mileage: 142761 km
Date: 2015.02.22
Time: 00:01:48
Temperature: 36.0°C
Temperature: 17.0°C
Voltage: 12.700 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Mileage: 142761 km
Date: 2015.02.22
Time: 00:01:52
RPM: 792 /min
Load: 28.6 %
Temperature: 28.0°C
Temperature: 13.0°C
Voltage: 14.224 V
P0300 - 001 -
Mileage: 142761 km
Date: 2015.02.22
Time: 00:02:01
RPM: 756 /min
Load: 29.4 %
Temperature: 29.0°C
Temperature: 13.0°C
Voltage: 14.097 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected
Mileage: 142761 km
Date: 2015.02.22
Time: 00:02:01
RPM: 756 /min
Load: 29.4 %
Temperature: 29.0°C
Temperature: 13.0°C
Voltage: 14.097 V
Readiness: 0110 0101
Part No SW: 02E 300 011 BN HW: 02E 927 770 AE
Component: GSG DSG 070 1302
Revision: 04507000 Serial number: 00000610230289
VCID: 5CF46D729FAF3E662F-8008
11 Faults Found:
00194 - Ignition Key Removal Lock
Fault Frequency: 255
Reset counter: 1
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:59
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent
18290 - Powertrain Data Bus
P1882 - 000 - Missing Message from Electric Parking Brake Controller - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
01196 - Engine-Transmission Data Bus
Mileage: 142761 km
Date: 2015.02.22
Time: 00:38:35
18274 - Powertrain Data Bus
P1866 - 000 - Missing Messages
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Mileage: 142761 km
Date: 2015.02.22
Time: 00:00:34
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VDD4 0023
Revision: --H07--- Serial number: 00000005592666
Coding: 0010000
Shop #: WSC 05311 000 00000
VCID: 72A823CA6D2B981615-8026
7 Faults Found:
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:28
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 216
Hex Value: 0x0000
03194 - Incompatible Interface
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Hex Value: 0x0000
Voltage: 12.50 V
Bin. Bits: 00000001
Count: 284
Hex Value: 0x0000
03201 - Adaptation Overboost
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:29
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
VCID: 73A626CE1231911E1E-8026
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Fault Status: 01110010
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:58
Fault Status: 00111110
Reset counter: 252
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:58
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008032672
Coding: 01040F0700041A00470A00000F00000000095D435C000100000000000000
Shop #: WSC 05124 123 12345
VCID: 71AA2CC6682DA30EEC-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 210108 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPPDND1$
Coding: 0012342
VCID: 3B36CEEE7AE1195E06-806E
Subsystem 1 - Serial number: 6333FTS620140118
Subsystem 2 - Serial number: 6343FTS638950158
Subsystem 3 - Serial number: 6353ETS6299ESVNH
Subsystem 4 - Serial number: 6363ETS6P1ODSVNP
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Fault Status: 11101001
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:60
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
Fault Status: 11101010
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:60
Fault Status: 11100001
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:60
00589 - Airbag Igniter 1; Passenger Side (N131)
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:00:12
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:58
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507CR
Coding: 0001713
Shop #: WSC 01458 111 56423
VCID: 74A425D2173F962607-8020
01426 - Controls in Steering Wheel (E221)
Part No SW: 3C0 920 972 J HW: 3C0 920 972 J
Component: KOMBI H03 0305
Coding: 141F00
Shop #: WSC 05314 115 12345
VCID: 2D12F0B67C9587EE88-8078
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 212
Mileage: 142761 km
Date: 2020.10.01
Time: 00:01:21
13639427 - Please Check Fault Codes in Engine Control Module
U101F 00 [009] - -
[Steuergerät für Motor: bitte Fehlerspeicher auslesen Öltemperatur]
Reset counter: 212
Mileage: 142761 km
Date: 2020.10.01
Time: 00:01:46
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 220312F1002827
Coding: 462007
Shop #: WSC 05314 123 12345
VCID: 3D32C0F6A4F5176E38-8068
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:23:37
Fault Frequency: 17
Mileage: 142761 km
Date: 2015.02.22
Time: 00:23:37
03406 - Control Module for Battery Monitoring
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:24:36
03989 - Transmission control module 2
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:00:14
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 06402 785 00200
VCID: 393AD4E670DD2B4E14-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02823 - Requirements for Locking the Steering Column Lock not met
Fault Status: 01110000
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:23:45
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 252
Mileage: 142761 km
Date: 2015.02.22
Time: 00:07:08
Address 2E: Media Player 3
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000030188205
Coding: 0000693
Fault Status: 01100101
Reset counter: 212
Mileage: 142761 km
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.133 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3620DFDA41C3C436F9-8062
02546 - Steering Limit Stop
Mileage: 142750 km
Temperature: 15.0°C
Voltage: 12.10 V
Voltage: 11.90 V
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E763004941570085F0B0078A1
Shop #: WSC 05311 123 12345
Reset counter: 252
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000577888123
Coding: 0000692
VCID: 3C34CDF27FEF1E660F-8068
Reset counter: 212
Mileage: 142761 km
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000342152
Coding: 0000056
VCID: 291A04A6807D9BCE64-807C
03288 - Lining/Pad Change Mode Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 212
Voltage: 12.10 V
Count: 44
Hex Value: 0x0170
Hex Value: 0x0082
Hex Value: 0x0101
03182 - Clutch Position Sensor (G476)
Fault Status: 11111010
Reset counter: 212
Voltage: 11.70 V
Count: 57
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 11101101
Reset counter: 212
Mileage: 142761 km
Voltage: 12.70 V
Count: 71
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
000 - - - MIL ON
Reset counter: 212
Voltage: 12.40 V
Count: 97
Hex Value: 0x1270
Hex Value: 0x0082
Hex Value: 0x0101
Address 56: Radio
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H40 1623
Coding: 030F1859
VCID: 71AA2CC6A82DA30EEC-8024
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:24:36
02252 - Generator
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:24:36
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1118
Revision: 11006001 Serial number: 00000001556431
Coding: 0000144
VCID: 3D32C0F664F5176E38-8068
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000197383
Coding: 0000144
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90640803601718
Coding: 0000014
Reset counter: 212
Mileage: 142761 km
Date: 2015.02.22
Time: 00:03:58
Address C2: Auto Trans 2
End----------(Elapsed Time: 01:40, VBatt start/end: 12.6V/12.6V)-----------
Friday,16,October,2020,16:53:43:33977
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
Coding: 0000175
P1653 - 004 -
Fault Frequency: 22
Mileage: 142761 km
Date: 2015.03.09
Time: 00:10:14
Temperature: 9.0°C
Temperature: 10.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.954 V
Mileage: 142761 km
Date: 2015.03.09
Time: 00:10:16
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 12.700 V
P1653 - 001 -
Fault Frequency: 22
Mileage: 142761 km
Date: 2015.03.09
Time: 00:10:16
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 12.827 V
Mileage: 142761 km
Date: 2015.03.09
Time: 00:10:20
Temperature: 9.0°C
Temperature: 13.0°C
Voltage: 12.446 V
12 Faults Found:
Mileage: 142761 km
Date: 2015.03.09
Time: 00:45:14
Fault Status: 01101101
Mileage: 142761 km
Date: 2015.03.09
Time: 00:45:17
P1850 - 000 - Missing Message from ECU - Intermittent
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
P1866 - 000 - Missing Messages - Intermittent
Mileage: 142761 km
Date: 2015.03.09
Time: 00:32:17
U0103 - 004 - - Intermittent
Reset counter: 0
Mileage: 142761 km
Date: 2015.03.09
Time: 02:35:03
Address 03: ABS Brakes Labels:. User\3AA-614-109.lbl
Coding: 0001914
9 Faults Found:
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 252
Hex Value: 0x0000
Voltage: 11.00 V
Bin. Bits: 10000001
Count: 156
Hex Value: 0x0000
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 252
Hex Value: 0x0000
Voltage: 11.00 V
Bin. Bits: 10000001
Count: 157
Hex Value: 0x0000
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00000001
Count: 215
Hex Value: 0x0000
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Fault Frequency: 14
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:58
014 - Defective
Fault Status: 01111110
Fault Frequency: 15
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:58
Coding: 00046997
Shop #: WSC 05124
Coding: 0012342
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:60
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:60
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:60
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:12
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:58
Coding: 0001713
Coding: 140D00
Reset counter: 212
Mileage: 142761 km
Date: 2020.10.16
Time: 00:53:41
Coding: 462007
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:04
Mileage: 142761 km
Date: 2015.03.09
Time: 00:00:03
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:23:45
02827 - Wake-Up request via ESP
Fault Status: 00100111
Fault Frequency: 8
Reset counter: 252
Mileage: 142761 km
Date: 2015.03.09
Time: 00:09:51
02829 - Enabling Steering Column Lock from Steering Wheel Electronics
Reset counter: 252
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:09
Fault Status: 00111000
Reset counter: 252
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:27
Reset counter: 252
Mileage: 142761 km
Date: 2015.03.09
Time: 00:07:08
Coding: 0000693
Reset counter: 252
Mileage: 142761 km
Reset counter: 212
Mileage: 142761 km
Mileage: 142750 km
Temperature: 16.0°C
Voltage: 11.80 V
Voltage: 11.60 V
Coding: 0000692
Reset counter: 252
Mileage: 142761 km
Reset counter: 212
Mileage: 142761 km
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000097854
Coding: 0022057
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Status: 01110111
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 02:00:36
Voltage: 11.50 V
Count: 34
Hex Value: 0x1253
Hex Value: 0x0001
Hex Value: 0x0104
02442 - Function Lamp in Control Head
Fault Status: 00101001
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 02:20:03
Voltage: 11.20 V
Count: 79
Hex Value: 0x1142
Hex Value: 0x0008
Hex Value: 0x0104
03263 - Functional Restriction
Fault Status: 01111000
Reset counter: 212
Mileage: 103899 km
Date: 2015.11.11
Time: 23:14:57
Voltage: 11.60 V
Count: 135
Hex Value: 0x12D0
Hex Value: 0x0001
Hex Value: 0x0104
Fault Status: 01110101
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:45:19
Voltage: 12.00 V
Count: 99
Hex Value: 0x1142
Hex Value: 0x0008
Hex Value: 0x0104
Fault Status: 01111101
Fault Frequency: 32
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:45:39
Voltage: 11.90 V
Count: 69
Hex Value: 0x1242
Hex Value: 0x0001
Hex Value: 0x0104
Reset counter: 212
Mileage: 249825 km
Date: 2015.06.30
Time: 10:14:47
Voltage: 11.50 V
Count: 41
Hex Value: 0x1253
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio
Coding: 0000144
Coding: 0000144
Coding: 0000014
Fault Frequency: 42
Reset counter: 212
Mileage: 142761 km
Date: 2015.03.09
Time: 00:03:58
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.0V)-----------
Address 03,3AA 614 109 AG,recoded (Short coding),from,0001914,to,0005796,(05311/000/00000),
Address 03: DTCs cleared
Address 03,3AA 614 109 AG,recoded (Short coding),from,0005796,to,0004772,(05311/000/00000),
