Monday,13,July,2020,15:56:03:05482
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4L58D058502 License Plate: BRI Q7
Mileage: 102500km-63690mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 15 16 17 18 19 1E 28 34 37 3C
42 46 47 4F 52 55 56 61 62 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L58D058502 Mileage: 102500km-63690miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 409 D HW: 4E1 907 409 B
Component: 4.2L V8TDI G000AGMª0010
Revision: --H05--- Serial number:
Coding: 0011779
Shop #: WSC 31414 790 00001
VCID: 2B02FE5F7F0466F3D69-807E
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 JJ HW: 09D 927 750 JJ
Component: AL 750 6A 1167
Revision: 00H78000 Serial number:
Coding: 0000504
VCID: 7F5AFA0FDBFC2A532A1-802A
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103601
VCID: 290E045775F874E3245-807C
Fault Frequency: 70
Reset counter: 188
Mileage: 90880 km
Date: 2019.06.25
Time: 12:29:35
Count: 8261
Count: 128
Count: 41472
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601501014920
Coding: 0000147
Shop #: WSC 00759 210 86480
VCID: 6392567F5754EEB32E9-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Reset counter: 167
Mileage: 101441 km
Date: 2020.06.19
Time: 07:44:50
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 G HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 387CU087570244
Coding: 0002002
VCID: 2D06F047411068C3C8D-8078
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001018404
Subsystem 3 - Serial number: 0106.03.080000000100011472ÿ
Subsystem 4 - Serial number: 011472ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0030
Revision: 00---013 Serial number: 00000000159705
Coding: 0132120
VCID: 2312167F17D4AEB36E9-8076
Fault Frequency: 95
Reset counter: 186
Mileage: 92859 km
Date: 2019.08.10
Time: 13:17:13
Temperature: 62.0°C
Temperature: 23.0°C
Temperature: -55.0°C
RPM: 680 /min
Absolute Pres.: 1.0 bar
Current: 0.000 A
Temperature: 26.0°C
00003 - Control Module
Fault Status: 00100011
Mileage: 100259 km
Date: 2020.05.13
Time: 16:55:58
Temperature: 23.0°C
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0013121
VCID: 313EEC375D280C23EC5-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H11 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H45 0390
Revision: 00045002 Serial number: AUZ5ZBH8341582
VCID: 1E64278B3CB6835B417-804A
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0010
Coding: 0011779
Shop #: WSC 00046 000 00000
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D04937E
Coding: 0014129
VCID: 2E04F74B4C1613DBF17-807A
Subsystem 1 - Serial number: 6332QSME580434177
Subsystem 2 - Serial number: 6342QSME59667A4BY
Subsystem 3 - Serial number: 6352QSME5A09364DR
Subsystem 4 - Serial number: 6362QSME4F4E3B03W
Subsystem 5 - Serial number: 63734SME526E572FE
Subsystem 6 - Serial number: 63834SME526E1603$
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026080640174
Coding: 0102142
VCID: 270A026F63EC4293321-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 981 B
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 74132GJ38
Coding: 3681458
Shop #: WSC 80093 222 69422
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 815 071 E
Component: Heizgeraet H08 0090
Revision: 0000000D Serial number: 00000009014264
Coding: 0000001
VCID: 609859734642F5AB33B-8034
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D07A138075
Coding: F57BFEFF74720200
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
VCID: 290E045779F874E3245-807C
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 C
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---009 Serial number: 00000000157841
Coding: 0000006
VCID: 68884153AE728DEBFBB-803C
Mileage: 87316 km
Date: 2019.03.07
Time: 19:08:47
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 23
Mileage: 90518 km
Date: 2019.06.13
Time: 12:04:48
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
VCID: 2A0CFB5B70FE7FFB2DF-807E
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Fault Frequency: 111
Reset counter: 193
Mileage: 89552 km
Date: 2019.05.17
Time: 10:35:58
Error Code: 68
01583 - Leak in System Detected
Fault Frequency: 79
Reset counter: 194
Mileage: 98068 km
Date: 2020.01.17
Time: 12:13:56
Error Code: 70
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 399CV087604163
Shop #: WSC 00185 210 88124
VCID: 3038E9335622052BE3B-8064
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0130
Revision: 00H10000 Serial number: 6PZ 009 014-00
Coding: 0001101
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H08 0130
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F13.02.0800H0800000010084ÿ
Subsystem 4 - Serial number: 010084ÿ
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00000000 Serial number: @†T
Coding: 0002651
VCID: 2F3AEA4F4B1C1AD3FA1-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H08 0060
Revision: 0060 --- Serial number: 01102302440000
Coding: 7348475
VCID: 3332E63FA7343E339E9-8066
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000059340
Coding: 0000023
VCID: 280801536EF24DEB3BB-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000079229
Coding: 0011101
VCID: 5EE4678B7C36C35B017-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00000000 Serial number: XU
Coding: 0002651
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000022
VCID: 698E4457B578B4E3E45-803C
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388C4087678449
Coding: 0000001
00856 - Radio Antenna
Fault Status: 00100111
Reset counter: 160
Mileage: 101108 km
Date: 2020.06.07
Time: 16:57:22
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000011610
VCID: 2516086719E0508300D-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2803120276
Coding: 344630393135313035442056413032383033313230323736
Fault Frequency: 25
Mileage: 85963 km
Date: 2018.12.24
Time: 15:23:58
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0002058
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000803040012
Shop #: WSC 12336 024 394758
VCID: 3634DF2BB4462B1BB97-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J82420Q
Coding: 1021001
VCID: 2410156312DAA98B173-8070
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C803D43BA8AA1CB9F3-8038
Subsystem 3 - Serial number: RD11.03.08--H25001001A0179ÿ
Subsystem 4 - Serial number: 1A0179ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003527651-----
Coding: 0000001
VCID: 6596486759609083C0D-8030
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0002058
Part No SW: 4F0 910 283 K HW: 4F0 919 283 K
Component: Parkhilfe 8-Kan H12 0100
Revision: 00H12000 Serial number: 69840806601310
Coding: 0221146
VCID: 2C00FD437A0A61CBDF3-8078
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005115740
Coding: 0010900
End----(Elapsed Time: 02:24, VBatt start/end: 11.2V/11.7V. VIgn 11.6V)-----
Address 03: DTCs cleared
Address 05: DTCs cleared
